Zhejiang Rural Credit Cooperative
    10-10-2022
In recent years, the rapid development of digital technology has laid new ground for financial organizations to break through their own development limitations. Facing the regional and scale limits, many regional financial organizations embraced the digital transformation. They actively opened e-banks and mobile banking, and built their own financial cloud. Zhejiang Rural Credit Cooperative (hereinafter referred to as "ZJRC") is one of them. As a regional financial organization with 81 branches and more than 4600 outlets, ZJRC broke through the constraints of distributed outlets and traditional IT architectures, and with the help of H3C (under UNIS), used H3C CAS (cloud automation system) virtualization solution to build a unique Fengshou Kechuang cloud, strongly promoting the development of new services.
Break the bounds of traditional architectures and launch cloud services
ZJRC has been exploring cloud services since 2014, and the financial private cloud platform and private cloud of ZJRC were built in 2017 and 2018. Before the transformation, ZJRC carried a "historical IT burden". At that time, the IT systems of prefectural and municipal branches were built and maintained by local technical departments. Lacking of unified planning, the overall architecture was weak and hard to connect to devices. However, H3C CAS virtualization solution solved this problem easily.
Thanks to the powerful compatibility with heterogeneous virtualization, the H3C CAS virtualization platform was fully compatible with the VMware formats, so that service VMs running on various devices in each branch were migrated to H3C CAS platform, thereby greatly improving service online efficiency. In addition, H3C Group also assigned professional and technical teams to support the platform so that migration would not affect daily operation.
With the support of H3C CAS virtualization platform, ZJRC's Fengshou Kechuang cloud was quickly built. At present, Fengshou Kechuang cloud has had two major service clusters: Production and Internet, with 48 deployment nodes. H3C CAS and ONEStor distributed storage provides IaaS support for Fengshou Kechuang cloud. Through a unified operation portal, local branches can easily deliver, manage and operate cloud resources and effectively promote new services.
Build a reliable operation platform to speed up service development
From the local device to the cloud, ZJRC has created a safe and reliable operating environment for the system. Internet services (such as portal and Internet finance) and production services (such as customer service, OA, card registration and audit) run on more than 400 VMs, eliminating the impact of hardware faults on services. In case of a hardware device fault, H3C CAS virtualization platform will enable the disaster recovery of services in minutes, and switch services to the standby VM rapidly, to ensure the uninterrupted service and non-stop system. This also provides technical support for the subsequent construction of disaster recovery cloud.
The launch of Fengshou Kechuang cloud makes ZJRC address external challenges confidently. Based on the AsiaInfo anti-virus function integrated on the CAS virtualization platform, Fengshou Kechuang cloud can protect VMs from external viruses. If the service growth causes the performance bottleneck of database access, H3C CAS can effectively link with ONEStor distributed storage, improve the read/write performance, effectively avoid the access delay caused by excessive load of the core components such as the database, and make the applications on Fengshou Kechuang cloud run at full speed.
The cloud also changed the separated O&M of outlets effectively. The unified and interconnected cloud platform reduced the infrastructure O&M workload of the technical team of each branch. By using the Cloud OS, the technical team can easily apply for VM resources, configure the service resources according to the actual local conditions, and launch new online services, solving the issue of imbalanced O&M resources.
From the virtualization transformation of bank outlets to the construction of financial cloud, H3C CAS virtualization solution has accompanied the financial industry all the way over the past decade, promoting the development of service transformation in different scenarios. In the future, the service on cloud is still the mainstream in the development of financial science and technology. Guided by the strategy of "cloud and AI native", H3C group will realize the breakthrough and innovation of H3C CAS virtualization solution, and help the financial industry to take every step on the path of launching cloud services.
