| Title | Size | Downloads |
| LICENSE_SERVER-ISO-E1153.iso | 5.12 GB | |
| LICENSE_SERVER-E1153.deb.md5 | 60 bytes | |
| LICENSE_SERVER-E1153.rpm.md5 | 60 bytes | |
| LICENSE_SERVER-E1153.deb | 173.63 MB | |
| LICENSE_SERVER-ISO-E1153.iso.md5 | 64 bytes | |
| LICENSE_SERVER-E1153.rpm | 177.11 MB | |
| H3C_LICENSE_SERVER-E1153_Release_Notes.pdf | 758.99 KB |
H3C LICENSE_SERVER-E1153 Release Notes
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Software compatibility matrix· 4
Upgrade restrictions and guidelines· 5
Software feature and command updates· 6
Open problems and workarounds· 6
Resolved problems in LICENSE_SERVER_E1153· 7
Resolved problems in LICENSE_SERVER_E1152· 8
Resolved problems in LICENSE_SERVER-E1151· 8
Resolved problems in LICENSE_SERVER-E1150· 8
Obtaining technical documents· 9
Introduction
This document describes the features, restrictions and guidelines, open problems, and workarounds for version LICENSE_SERVER-E1152. Before you use this version on a live network, back up the configuration and test the version to avoid software upgrade affecting your live network.
Use this document in conjunction with the documents listed in "Related documentation."
Version information
Version number
Note: To see the version number, click About icon
at the upper right corner on the dashboard of the License Server GUI, as shown in Figure 1.
Version history
Version number | Last version | Release date | Release type | Compatible versions | Remarks |
LICENSE_SERVER -E1153 | LICENSE_SERVER-E1152 | 2021-09-16 | ESS version | · LICENSE_SERVER-E1152 · LICENSE_SERVER_H3C-E1146P01 · LICENSE_SERVER_H3C-E1144P01 · LICENSE_SERVER_H3C-E1143P01 · LICENSE_SERVER-E1142P01 · LICENSE_SERVER-E1141P01 | Fixed bugs. |
LICENSE_SERVER -E1152 | LICENSE_SERVER_H3C-E1146P01 | 2021-04-26 | ESS version | · LICENSE_SERVER_H3C-E1146P01 · LICENSE_SERVER_H3C-E1144P01 · LICENSE_SERVER_H3C-E1143P01 · LICENSE_SERVER-E1142P01 · LICENSE_SERVER-E1141P01 | Fixed bugs. |
LICENSE_SERVER_H3C-E1146P01 | LICENSE_SERVER_H3C-E1144P01 | 2020-06-17 | ESS version | · LICENSE_SERVER_H3C-E1144P01 · LICENSE_SERVER_H3C-E1143P01 · LICENSE_SERVER-E1142P01 · LICENSE_SERVER-E1141P01 | 1. The following functions are supported in this version: ¡ Display the H3C logo. ¡ Disable the HTTP login. ¡ IPv6 deployment. ¡ Allow non-root users to start the Redis service. ¡ Display QR codes for license barcodes. ¡ Sort the licenses in chronological order for a client. 1. Fixed bugs found in the live network and test network. |
LICENSE_SERVER_H3C-E1144P01 | LICENSE_SERVER_H3C-E1143P01 | 2019-11-27 | ESS version | · LICENSE_SERVER_H3C-E1143P01 · LICENSE_SERVER-E1142P01 · LICENSE_SERVER-E1141P01 | 2. The following functions are supported in this version: ¡ Display the name UNIVERGE Network Operation Engine Overlay Network Extension. ¡ Manually adjust the reporting interval for logs of the same type to the log server. ¡ Export license details. ¡ Display the backup path of the configuration file during the license server uninstallation. ¡ Display prompts during HA configuration. 3. Fixed bugs found in the live network and test network. |
LICENSE_SERVER_H3C-E1143P01 | LICENSE_SERVER-E1142P01 | 2019-08-15 | ESS version | · LICENSE_SERVER-E1142P01 · LICENSE_SERVER-E1141P01 | · Display both H3C and H3C copyright information. · Support HTTPS login. |
LICENSE_SERVER-E1142P01 | LICENSE_SERVER-E1141P01 | 2019-02-28 | ESS version | LICENSE_SERVER-E1141P01 | Fix security vulnerabilities of Tomcat and OpenSSL, and solve the list of problems |
LICENSE_SERVER-E1141P01 | N/A | 2019-01-30 | ESS version | N/A | Initial release |
Hardware requirements
Item | CPU | Memory size | Available disk space | NIC speed | Remarks |
Recommended configuration | · x86-64 (Intel 64/AMD 64) · 16 cores · 2.6 GHz or above | 64 GB or above | 64 GB or above for the system partition that contains the root directory | 1 to 10 Gbps | Support for full-size clients |
Minimal configuration | · X86-64 (Intel 64/AMD 64) · quad cores · 2.0 GHz or above | 16 GB or above | 64 GB or above for the system partition that contains the root directory | 1 to 10 Gbps | Support only for a maximum of 20 clients |
Software requirements
| CAUTION: Before you upgrade software, make sure the software requirements are met. |
The server to host a license server must be installed with one of the following operating systems:
· CentOS 7.3 1611 64-bit operating system (DVD edition).
| IMPORTANT: Vulnerabilities, for example, Shellshock, might exist on the CentOS operating system. Please focus on the updates released at the official website to fix vulnerabilities. |
· H3Linux Release 1.1.2 (3.10 or 4.14 kernel edition).
| CAUTION: To avoid an upgrade failure, use Table 3 to verify the software compatibility before performing an upgrade. |
Table 3 Software compatibility matrix
Item | Specifications |
Model | H3C License Server |
Software image files | · LICENSE_SERVER-E1153.rpm · LICENSE_SERVER-E1153.rpm.md5 · LICENSE_SERVER-ISO-E1153.iso · LICENSE_SERVER-ISO-E1153.iso.md5 · LICENSE_SERVER-E1153.deb · LICENSE_SERVER-E1153.deb.md5 |
Browser | · Google Chrome 27 or later · Mozilla Firefox 31 or later · Internet Explorer 9 or later |
Software dependencies | N/A |
Remarks | · The LICENSE_SERVER-E1153.rpm file is the software installation package for the CentOS 64-bit operating system and H3Linux operating system. The LICENSE_SERVER-E1153.rpm.md5 file is used for checking the integrity of the LICENSE_SERVER-E1153.rpm file. · The LICENSE_SERVER-ISO-E1153.iso file is the software installation package in ISO format. This package contains the software image files of the license server and the software image files of the operating system. The LICENSE_SERVER-ISO-E1153.iso.md5 file is used for checking the integrity of the LICENSE_SERVER-ISO-E1153.iso file. · The LICENSE_SERVER-E1153.deb file is the software installation package for the Linux operating system. The LICENSE_SERVER-E1153.deb.md5 file is used for checking the integrity of the LICENSE_SERVER-E1153.deb file. |
To check the version number, click About icon
at the upper right corner on the dashboard of the License Server GUI. The user window as shown in Figure 1 opens to display license server version.
N/A.
Hardware feature updates
For more information, see H3C LICENSE_SERVER-E1153 Release Notes (Software Feature Changes).
MIB updates
Operation changes
N/A.
Restrictions and cautions
Before obtaining and installing a license server in your network, check the products for their compatible license server version.
To avoid licensing failure caused by single points of failure, deploy redundant license servers for high availability.
201906150092
· Symptom: The client cannot obtain licenses from the license server after the server has unexpected power failure or other abnormal conditions.
· Condition: This symptom might occur if the anomalies such as unexpected power failure cause Redis data loss.
· Workaround: Avoid unexpected power failure on the license server during the service interaction. If HA is configured, avoid the simultaneous power failure on the master and standby license servers. Once the problem occurs, force the clients to go offline and to re-apply for licenses.
201908200031
· Symptom: The login page opens after you import a manually modified configuration file and select Configuration > System Configuration from the navigation pane.
· Condition: This symptom might occur if the adminuser node information in the imported configuration file has been changed.
· Workaround: Do not import any manually modified configuration file.
201910250213
· Symptom: It takes much time to load the Overview, License Management > License Resources > License Overview, and License Management > License Resources > License Details pages.
· Condition: This symptom occurs when a large number of activation files are installed on the license server, for example, 20 thousands activation files are installed.
· Workaround: None.
List of resolved problems
202108180008
· Symptom: The CVE-2021-30640 vulnerability exists.
· Condition: This issue is found through vulnerability scanning.
202108060345
· Symptom: License server HA cluster changed to the fail-safe state upon master/backup switchover that occurred after the hardware information of the backup license server had changed.
· Condition: This symptom occurs after the following series of events has occurred:
a. The hardware information of the backup license server changes.
b. The backup license server takes over the master role before the original master license server obtains the new hardware information of the backup license server.
202108050472
· Symptom: When the license server is in fail-safe state, activation files can be bulk uninstalled. However, they cannot be uninstalled by using their license-specific uninstallation icons in the Actions column.
· Condition: This symptom occurs if you uninstall the activation file for a license by clicking the license-specific uninstallation icon in the Actions column on the License Files page when the license server is in fail-safe state.
202108031089
· Symptom: The following vulnerabilities exist on the HTTPS port:
¡ TLS VERSION 1.0 PROTOCOL DETECTION.
¡ SSL Medium Strength Cipher Suites Supported (SWEET32).
¡ SSL Cipher Block Chaining Cipher Suites Supported.
· Condition: This issue is found through vulnerability scanning with Nessus.
202107280035
· Symptom: After a license server HA cluster is created, the keepalived configuration file does not contain the virtual IP address of the HA cluster. As a result, the backup license server remains in inactive state.
· Condition: This symptom might occur if you configure a license server HA cluster and then quickly click OK twice on the HA configuration page.
202107260085
· Symptom: Failed to set up a license server HA cluster.
· Condition: This symptom occurs if the IP address of a subinterface is assigned to the primary or backup license server.
202107260993
· Symptom: The CVE-2011-1473 vulnerability exists.
202106300234
· Symptom: The CVE-2016-1000031 vulnerability exists.
202104210033
· Symptom: After the operating system is restarted, the license server service might have exceptions and exit unexpectedly with a low probability.
· Condition: This symptom occurs if the operating system is restarted or the server is powered off and then restarted.
202104190616
· Symptom: When a client synchronizes the license information from the license server, the license server service reboot unexpectedly.
· Condition: This symptom occurs when the following conditions exist:
¡ A client requests a large number of licenses.
¡ These licenses are about to expire or become invalid.
¡ The client synchronizes the license information from the license server.
202103300015
· Symptom: The license server is vulnerable due to the Apache Tomcat security vulnerability CVE-2020-9484.
· Condition: This symptom might occur if Apache Tomcat is of a version earlier than 7.0.103.
202011240804
· Symptom: On the Web interface of the license server, access menu Configuration > Admin to configure or change the password of an administrator. However, this feature is described as Modifying the login username and password of the system administrator in the online help. The feature description is inconsistent with the function of the feature on the Web interface.
· Condition: This symptom occurs when you view the online help.
202008240720
· Symptom: A client fails to communicate with the license server over an SSL connection. Optimization is required for calling OpenSSL library.
· Condition: This symptom might occur when exceptions exist in the network, for example, network instability.
Initial version.
· H3C License Server Installation Guide-5W111
· H3C License Server Operation Log Messages Reference-5W102
· H3C License Server System Log Messages Reference-5W103
· H3C License Server Troubleshooting Guide-5W103
To obtain the latest documents at H3C official website www.h3c.com:
1. Access the website at http://www.h3c.com/cn/Technical_Documents.
2. Select a product category and product model to obtain and download manuals for the selected product model.
Technical support
To obtain assistance, contact H3C by email or phone or access documents at the H3C website.
· Email:
¡ China: [email protected]
¡ Hongkong, China: [email protected]
¡ Other countries or regions: [email protected]
· Technical support hotline:
To find contacts for your local area, access the H3C global contacts page at https://www.h3c.com/en/Support/Online_Help/Service_Hotlines/
· Website: http://www.h3c.com
Appendix A Feature list
Hardware features
Item | Remarks |
N/A | No hardware deliverables are involved. |
Software features
Category | Features |
Activation file management | · Viewing the list and details of the activation files. · Installing, uninstalling and deleting the activation files. · Exporting the activation files, the uninstalling records of the activation files, and the DID files. |
Activation file time management | · The validity period of the time-based activation files is calculated in hours · Supporting on-demand time-based licensing. |
License information | Viewing license summary and details. |
License client management | · Viewing the client information. · Reclaiming licenses deployed to clients. · Support for notification on license expiration. · Deploying licenses request by the clients and reclaiming licenses from clients. |
User management | · Creating, modifying, and deleting users. · Modifying the passwords. |
Configuration management | · Configuring service port number and operation timeout. · Importing and exporting the configuration file. |
High availability | Supporting dual-host HA mode. In HA mode, one IP address is provided for license service and management. Dual hosts can be deployed across Layer 3 networks. |
Log management | · Supporting operation logs and system logs. · Supporting log file export. · Supporting standard SYSLOG logs. |
System diagnosis | · Using the collected system diagnostic information for troubleshooting. · Exporting the system diagnostic information as a single compressed file. |
