H3C WA4600 Series Indoor Access Points Compliance and Safety Manual-6W103
HomeSupportWirelessH3C WA4600 Series Indoor Access PointsInstall & UpgradeCompliance and Safety InformationH3C WA4600 Series Indoor Access Points Compliance and Safety Manual-6W103
01-Text
01-Text 1.05 MB
Safety Information/Sicherheits informationen/安全信息··· 1
Overview/Überblick/概述·· 1
Warning Symbol Conventions/ Erläuterung der Symbole/应用惯例·· 1
Important Safety Information/Wichtige Sicherheitshinweise/重要安全信息·· 2
Electricity Safety/Elektrische Sicherheit/用电安全·· 3
Hazardous Voltage/Gefährliche Spannungen /危险电压·· 3
Regulatory Compliance Information· 4
Regulatory compliance standards· 4
European Directives compliance· 4
Wireless CE Marking· 4
EU Country Restriction in 2.4GHz band· 6
EU Country Restriction in 5GHz band· 6
USA regulatory compliance· 7
FCC Part 15· 7
FDA· 8
Canada regulatory compliance· 8
ICES-003· 8
RF Compliance· 8
Japan regulatory compliance· 9
VCCI 9
MII 10
EN55022, AS/NZS CISPR 22, CISPR22 compliance· 10
EN55032, AS/NZS CISPR 32, CISPR32 compliance· 10
Environmental notices· 11
Waste Electrical and Electronic Equipment (WEEE) statements· 11
English recycling notice· 11
Bulgarian recycling notice· 11
Czech recycling notice· 12
Danish recycling notice· 12
Dutch recycling notice· 12
Estonian recycling notice· 13
Finnish recycling notice· 13
French recycling notice· 13
German recycling notice· 14
Greek recycling notice· 14
Hungarian recycling notice· 14
Italian recycling notice· 15
Latvian recycling notice· 15
Lithuanian recycling notice· 15
Polish recycling notice· 16
Portuguese recycling notice· 16
Romanian recycling notice· 16
Slovak recycling notice· 17
Spanish recycling notice· 17
Swedish recycling notice· 17
RoHS material content declarations· 18
Turkey RoHS material content declaration· 18
Ukraine RoHS material content declaration· 18
India RoHS material content declaration· 18
Perchlorate material — Special handling may apply· 18
List of Tables
Table 1 Safety symbol and description/Sicherheitssymbole und Beschreibung/安全标识和描述.. 1
Table 2 Regulatory compliance standards. 4
Table 3 Equipment may be operated in the following country: 5
Table 4 Europe-Restrictions for Use of 5GHz Frequencies in European Community Countries. 7
Table 5 Frequency band and channels in Canada and USA. 9
Note
Note
Before any operation is performed, please read the operation instructions and precautions carefully to minimize the possibility of accidents. The Note, Caution, Warning and Danger items in other manuals do not cover all safety precautions that should be followed. They are only the supplements to the safety precautions for operations as a whole.
When installing / operating the product, the precautions and special safety instructions provided with the products must be followed in full.
Note
Anmerkung
Lesen Sie sich vor der Inbetriebnahme die Betriebsanleitung und die Hinweise zu Vorsichtsmaßnahmen sorgfältig durch, um die Wahrscheinlichkeit von Unfällen zu minimieren. Die unter Hinweis, Achtung, Warnung und Gefahr genannten Informationen in anderen Handbüchern umfassen nicht sämtliche Sicherheitsmaßnahmen, die Sie ergreifen sollten.
Note
为了避免可能发生的事故,请在进行任何操作前,仔细阅读设备安装手册和本章节的安全规范。手册中 出现的说明、注意、警告、危险,不能涵盖所有的安全预防,仅仅是在整个操作过程中的安全提示和补充。
在操作本设备时,请认真执行产品手册规定的安全规范。
The symbols in this manual are shown in the following table. They are used to remind the reader of the safety precautions during equipment installation and maintenance.
Die in diesem Handbuch verwendeten Symbole sind in der folgenden Tabelle dargestellt. Diese Symbole sollen das Personal während der Installation und Instandhaltung der Ausrüstung an die Wichtigkeit der im Handbuch aufgeführten Sicherheitsvorschriften erinnern.
以下表格中的安全标识,是用来提示读者在进行设备安装和维护时的安全预防要求。
Safety Symbol
Symbole
安全标识
Erläuterung
Generic alarm symbol: To suggest a general safety concern.
Alarm: Hinweis auf ein generelles Sicherheitsproblem.
一般注意标识:用于一般安全提示。
ESD protection symbol: To suggest electrostatic-sensitive equipment.
ESD-Schutz: Hinweis auf ESD-gefährdete Bauteile.
防静电标识:用于表示设备对静电敏感。
Electric shock symbol: To suggest a danger of hazardous Voltage.
Elektrischer Schlag: Zeigt Gefährdungen durch gefährliche Spannungen an.
电击防护标识:用于表示高压危险。
Caution: You must read all of the installation instructions in the Installation Guide supplied with your equipment and the following safety instructions before installation or operation.
Achtung: Sie müssen vor der Installation oder Bedienung das mit Ihrer Anlage mitgelieferten Installationshandbuch und die folgende Sicherheitshinweise lesen.
注意:在安装和操作本设备时,务必阅读设备安装手册的内容,以及下文的所有安全说明。
Warning: DC mains input: the DC input shall be separated from AC mains by reinforced insulation or double insulation according to IEC 60950-1.
Warnung: DC-Stromnetz-Eingang: der DC-Eingang muss vom Wechselstromnetz durch eine verstärkte Isolierung oder Doppelisolierung entsprechend IEC 60950-1 getrennt sein.
警告:当设备由外部DC电源供电时:DC供电电源和AC电网之间的绝缘等级必须满足IEC60950-1标准定义的加强绝缘或者双重绝缘。
Warning: For SELV DC input: the DC power source shall comply with the Safety Extra-Low Voltage (SELV) requirements of IEC 60950-1.
Warnung: Mit Gleichstrom betriebenes Modell: Das Gerät arbeitet mit Gleichstrom, wobei die Anforderungen der Norm (IEC60950-1) für Schutzkleinspannung eingehalten werden müssen.
警告:SELV DC电源输入:设备使用满足IEC60950-1安规标准的安全特低电压(SELV)电源。
Warning: Before an ac power cable is either plugged in to or removed from a unit, the ac power source supplying this cable must be switched off.
Warnung: Bevor ein Wechselstromnetzkabel entweder an eine Einheit angeschlossen oder von dieser abgezogen wird, muss die Wechselstromquelle, die dieses Kabel speist, ausgeschaltet werden.
警告:在安装、移动电源线之前,请切断电源。
Caution: To ensure the equipment is mounted on the wall firmly,  please use a screw at least 4.2 mm diameter and the screw head at least 8 mm diameter.
Achtung: Um das Gerät an der Wand zu befestigen, benutzen Sie Nagel mit einem Mindestdurchmesser von 4.2 mm. Der Durchmesser der Nagelkappe muss mindestens 8 mm betragen.
注意为确保设备紧固的安装在墙上请用直径最小是4.2mm螺钉并且螺帽的直径要大于8mm
Warning: When installing the product on the wall you must choose a suitable fixing.
Achtung: Wenn Sie das Produkt an der Wand anbringen, müssen Sie eine passende Befestigungslösung wählen.
警告:将设备安装到墙上时,必须选取合适的固定方式。
Warning: When mounting the product on a wall, do not mount it with ventilation holes facing up or down.
Warnung: Wenn das Produkt an einer Wand montiert wird, installieren Sie ihn nicht mit den Lüftungsöffnungen nach oben oder unten gerichtet.
警告:将设备安装到墙上时,请勿将散热孔朝上或朝下。
Warning: When making connections, be careful not to push the product up and off the wall.
Warnung: Achten Sie darauf, das Produkt nicht nach oben und von der Wand zu schieben, wenn Sie die Anschlüsse vornehmen.
警告:进行连接时,请不要向上推动设备,以免设备从墙上掉落。
Warning Power Cord Table:
The power cord set must be approved for the country where it is used.
WARNUNG Netzkabel Tabelle:
Das Netzkabel muss für das Land, in dem es verwendet wird, zugelassen werden.
警告:电源线表格:
电源线组件必须满足使用的国家认证要求。
U.S.A. and Canada
·     The cord set must be UL approved and CSA certified
·     The minimum specification for the flexible cord is:
·     No. 18 AWG
·     Type SV / SVT or SJ / SJT or SPT-2
·     3 conductor.
·     The cord set must have a rated current carrying capacity of at least 10A.
·     The attachment plug must be an earth-grounding type with a NEMA 5-15P (15A, 125V) or NEMA 6-15P (15A, 250V) configuration
United Kingdom
·     The supply plug must comply with BS1363 (3-pin, 13A) and be fitted with a 13A fuse that complies with BS1362
·     The mains cord must <HAR> or <BASEC> marked and be of type H03VVF3G1.0 (minimum).
Europe
·     The supply plug must comply with CEE 7/7 (“SCHUKO”)
·     The mains cord must <HAR> or <BASEC> marked and be of type H05VVF3G1.0 (minimum)
Denmark
·     The supply plug must comply with section 107-2-D1, standard DK2-1a or DK2-5a.
Switzerland
·     The supply plug must comply with SEV/ASE 1011
Argentina
(for 3 pins)
·     The power cord set must be certified by UL, IRAM, TÜV (or other authorized certification body), for three conductors cables.
·     The attachment plug must be an earth-grounding type with an IRAM-2073 (10 A, 250 V).
中国
·     电源线组件必须通过CCC认证。
·     使用符合GB1002,额定值为250V/10A的单相两级带接地插头
·     电源线最小线径为1.0mm2;当电源线长度小于2m时,电源线最小直径为0.75mm2
·     Conducting articles, such as a watch, hand chain, bracelet or ring should be removed during the installation.
·     Es ist nicht erlaubt während dieser Arbeiten leitende Gegenstände wie Uhren, Armbänder, Armreifen und Ringe am Körper zu tragen.
·     在操作中不能穿戴导电性的物品,如:手表,手琏,手镯和项链等。
·     Do not use this product near water.
·     Verwenden Sie dieses Produkt nicht in der Nähe von Wasser.
·     请勿在靠近水的地方使用此产品。
Discipline
Standards
EMC
FCC Part 15 (CFR 47) CLASS B
ICES-003 CLASS B
VCCI-3 CLASS B
VCCI-4 CLASS B
CISPR 22 CLASS B
CISPR 32 CLASS B
EN 55022 CLASS B
EN 55032 CLASS B
AS/NZS CISPR22 CLASS B
AS/NZS CISPR32 CLASS B
EN 61000-3-2
EN 61000-3-3
EN 301 489-1
EN 301 489-17
GB 9254
Safety
UL 60950-1
CAN/CSA C22.2 No 60950-1
IEC 60950-1
EN 60950-1
AS/NZS 60950-1
GB 4943.1
RF
FCC Bulletin OET-65C
FCC part15 subpart C/E
RSS-210
RSS-GEN
EN 300 328
EN 301 893
EN 50385
Wireless CE Marking
AT
BE
CY
CZ
DK
EE
FI
FR
DE
GR
HU
IE
IT
LV
LT
LU
MT
NL
PL
PT
SK
SI
ES
SE
GB
IS
LI
NO
CH
BG
RO
TR
HR
1.     Select the country in which this product is installed to ensure product operation is in compliance with local regulations. For information on how to select the country, refer to theH3C A-Series Access Controllers WLAN Command Reference”.
2.     Intended use: IEEE 802.11 a/b/g/n/ac radio LAN device.
3.     This product must maintain a minimum distance of 20cm from body to antenna.Under these conditions This product will meet the Basic Restriction limits of 1999/519/EC(Council Recommendation of 12 July 1999 on the limitation of exposure of the general public to electromagnetic fields(0Hz-300GHz)).
R&TTE declaration statements:
Česky [Czech]
H3C Technologies Co., Limited tímto prohlašuje, že tento Zařízení je ve shodě se základními požadavky a dalšími příslušnými ustanoveními směrnice 1999/5/ES.
Dansk [Danish]
Undertegnede H3C Technologies Co., Limited erklærer herved, at følgende udstyr zařízení overholder de væsentlige krav og øvrige relevante krav i direktiv 1999/5/EF.
Deutsch [German]
Hiermit erklärt H3C Technologies Co., Limited, dass sich das Gerät Ausrüstung in Übereinstimmung mit den grundlegenden Anforderungen und den übrigen einschlägigen Bestimmungen der Richtlinie 1999/5/EG befindet.
Eesti [Estonian]
Käesolevaga kinnitab H3C Technologies Co., Limited seadmed vastavust direktiivi 1999/5/EÜ põhinõuetele ja nimetatud direktiivist tulenevatele teistele asjakohastele sätetele.
English
Hereby, H3C Technologies Co., Limited, declares that this Equipment is in compliance with the essential requirements and other relevant provisions of Directive 1999/5/EC.
Español [Spanish]
Por medio de la presente H3C Technologies Co., Limited declara que el equipo cumple con los requisitos esenciales y cualesquiera otras disposiciones aplicables o exigibles de la Directiva 1999/5/CE.
Ελληνική [Greek]
ΜΕ ΤΗΝ ΠΑΡΟΥΣΑ H3C Technologies Co., Limited ΔΗΛΩΝΕΙ ΟΤΙ εξοπλισμός ΣΥΜΜΟΡΦΩΝΕΤΑΙ ΠΡΟΣ ΤΙΣ ΟΥΣΙΩΔΕΙΣ ΑΠΑΙΤΗΣΕΙΣ ΚΑΙ ΤΙΣ ΛΟΙΠΕΣ ΣΧΕΤΙΚΕΣ ΔΙΑΤΑΞΕΙΣ ΤΗΣ ΟΔΗΓΙΑΣ 1999/5/ΕΚ.
Français [French]
Par la présente H3C Technologies Co., Limited déclare que l'appareil équipement est conforme aux exigences essentielles et aux autres dispositions pertinentes de la directive 1999/5/CE.
Italiano [Italian]
Con la presente H3C Technologies Co., Limited dichiara che questo attrezzatura è conforme ai requisiti essenziali ed alle altre disposizioni pertinenti stabilite dalla direttiva 1999/5/CE.
Latviski [Latvian]
Ar šo H3C Technologies Co., Limited deklarē, ka iekārta atbilst Direktīvas 1999/5/EK būtiskajām prasībām un citiem ar to saistītajiem noteikumiem.
Lietuvių [Lithuanian]
Šiuo H3C Technologies Co., Limited deklaruoja, kad šis įranga atitinka esminius reikalavimus ir kitas 1999/5/EB Direktyvos nuostatas.
Nederlands [Dutch]
Hierbij verklaart H3C Technologies Co., Limited dat het toestel uitrusting in overeenstemming is met de essentiële eisen en de andere relevante bepalingen van richtlijn 1999/5/EG.
Malti [Maltese]
Hawnhekk, H3C Technologies Co., Limited, jiddikjara li dan tagħmir  jikkonforma mal-ħtiġijiet essenzjali u ma provvedimenti oħrajn relevanti li hemm fid-Dirrettiva 1999/5/EC.
Magyar [Hungarian]
Alulírott, H3C Technologies Co., Limited nyilatkozom, hogy a aprīkojums megfelel a vonatkozó alapvetõ követelményeknek és az 1999/5/EC irányelv egyéb elõírásainak.
Polski [Polish]
Niniejszym H3C Technologies Co., Limited oświadcza, że urządzenie jest zgodny z zasadniczymi wymogami oraz pozostałymi stosownymi postanowieniami Dyrektywy 1999/5/EC.
Português [Portuguese]
H3C Technologies Co., Limited declara que este equipamento está conforme com os requisitos essenciais e outras disposições da Directiva 1999/5/CE.
Slovensko [Slovenian]
H3C Technologies Co., Limited izjavlja, da je ta oprema v skladu z bistvenimi zahtevami in ostalimi relevantnimi določili direktive 1999/5/ES.
Slovensky [Slovak]
H3C Technologies Co., Limited týmto vyhlasuje, že zariadenie spĺňa základné požiadavky a všetky príslušné ustanovenia Smernice 1999/5/ES.
Suomi [Finnish]
H3C Technologies Co., Limited vakuuttaa täten että laitteet tyyppinen laite on direktiivin 1999/5/EY oleellisten vaatimusten ja sitä koskevien direktiivin muiden ehtojen mukainen.
Svenska [Swedish]
Härmed intygar H3C Technologies Co., Limited att denna utrustning står I överensstämmelse med de väsentliga egenskapskrav och övriga relevanta bestämmelser som framgår av direktiv 1999/5/EG.
Íslenska [Icelandic]
Hér með lýsir H3C Technologies Co., Limited yfir því að búnaður er í samræmi við grunnkröfur og aðrar kröfur, sem gerðar eru í tilskipun 1999/5/EC.
Norsk [Norwegian]
H3C Technologies Co., Limited erklærer herved at utstyret utstyr er i samsvar med de grunnleggende krav og øvrige relevante krav i direktiv 1999/5/EF.
Hrvatska [Croatian]
Ovime tvrtka H3C Technologies Co., Limited izjavljuje da je ova oprema usklađena s osnovnim preduvjetima i drugim važnim odredbama direktive 1999/5/EZ.
The most up to date copy of the signed EU Declaration of Conformity can be downloaded from:
http://www.h3c.com/cn/Technical_Documents
This product may be used indoors or outdoors in all countries of the European Community using the 2.4GHz band: Channel 1-13, except where noted below.
1.     In Italy the end-user must apply for a license from the national spectrum authority to operate this device outdoors.
1.     This device may not be operated outdoors when using the bands 5150-5350MHz (Channels 36, 40, 44, 48, 52, 56, 50, 64).
2.     In Italy the end-user must apply for a license from the national spectrum authority to operate this device outdoors.
3.     To remain in conformance with European spectrum usage laws for Wireless LAN operation, the above 2.4GHz and 5GHz channel limitations apply. The user should check the current channel of operation. If operation is occurring outside of the allowable frequencies as listed above, the user must cease operating the H3C WA4600 Series Indoor Access Points product at that location and consult the local technical support staff responsible for the wireless network.
4.     This device must be used with the radar detection feature required for European Community operation in the 5GHz bands. This device will avoid operating on a channel occupied by any radar system in the area. The presence of nearby radar operation may result in temporary interruption in communications of this device. The Access Point’s radar detection feature will automatically restart operation on a channel free of radar. You may consult with the local technical support staff responsible for the wireless network to ensure the Access Point device(s) are properly configured for European Community operation.
Allowed Frequency Bands
Allowed Channel Numbers
Countries
5.15-5.35&
5.470-5.725GHz
36,40,44,48,52,56,60,64,100,104,108,112,116,132,136,140
38,46,54,62, 102,110,134
Austria, Belgium, Bulgaria, Cyprus, Croatia, Czech Republic, Denmark, Estonia, Finland, France, Germany, Greece, Hungary, Iceland, Ireland, Italy, Latvia, Liechtenstein, Lithuania, Luxembourg, Malta, Netherlands, Norway, Poland, Portugal, Romania, Slovakia, Slovenia, Spain, Sweden, Switzerland, U.K.
FCC Part 15
US Federal Communications Commission (FCC) EMC Compliance
This product has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed to provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not  occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can  be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures:
·     Reorient or relocate the receiving antenna.
·     Increase the separation between the equipment and receiver.
·     Connect the equipment into an outlet on a circuit different from that to which the receiver is connected.
·     Consult the dealer or an experienced radio/ TV technician for help.
This product complies with Part 15 of the FCC Rules. Operation is subject to the following two conditions:
1.     This device may not cause harmful interference.
2.     This device must accept any interference received, including interference that may cause undesired operation.
If the customer modifies the equipment without the authorization of H3C, which directly or indirectly contribute to the equipment incompliance with FCC requirements for Class B digital devices, H3C is not liable for such interference problem and the expenses incurred there from shall be covered by the customers.
RF Requirements
1.     RF exposure Hazard Warning
This device generates and radiates radio-frequency energy. To ensure compliance with the requirements of FCC radio-frequency exposure, a minimum body to antenna distance of 20cm (8 inch) must be maintained when the device is installed and operated.
2.     RF Frequency Requirements
This equipment complies with FCC RF radiation exposure limits set forth for an uncontrolled environment. This device and its antenna must not be co-located or operating in conjunction with any other antenna or transmitter.
This device is for indoor use only when it is operated at 5.15 to 5.25GHz frequency range.
High power radars are allocated as primary users of the 5.25 to 5.35GHz and 5.65 to 5.85GHz bands. These radar stations can cause interference with and /or damage this device.
Antennas
Only use the supplied antenna. Unauthorized antennas, modifications or change to the antennas could violate FCC regulations and void the user’s authority to operate the equipment.
FDA
This product conforms to the applicable requirements of 21 CFR Subchapter J.
ICES-003
This Class B  digital apparatus complies with Canadian Standard ICES-003.
Cet appareil numérique de la classe B est conforme à la norme NMB-003 du Canada.
RF Compliance
This product complies with RSS-210 of Industry Canada.
Operation is subject to the following two conditions: (1) this device may not cause interference, and (2) this device must accept any interference, including interference that may cause undesired operation of this device.
L ‘ utilisation de ce dispositif est autorisée seulement aux conditions suivantes: (1) il ne doit pas produire de brouillage et (2) l’ utilisateur du dispositif doit étre prêt à accepter tout brouillage radioélectrique reçu, même si ce brouillage est susceptible de compromettre le fonctionnement du dispositif.
The term "IC" before the equipment certification number only signifies that the Industry Canada technical specifications were met.
To reduce potential radio interference to other users, the antenna type and its gain should be so chosen that the equivalent isotropically radiated power (EIRP) is not more than that required for successful communication. To prevent radio interference to the licensed service, this device is intended to be operated indoors and away from windows to provide maximum shielding. Equipment (or its transmit antenna) that is installed outdoors is subject to licensing.
Pour empecher que cet appareil cause du brouillage au service faisant l'objet d'une licence, il doit etre utilize a l'interieur et devrait etre place loin des fenetres afin de Fournier un ecram de blindage maximal. Si le matriel (ou son antenne d'emission) est installe a l'exterieur, il doit faire l'objet d'une licence.
This device must not be co-located or operated in conjunction with any other unauthorized antenna or transmitter.
Radiation Exposure Statement:
This equipment complies with IC RSS-102 with radiation exposure limits set forth for an uncontrolled environment. This equipment should be installed and operated with minimum distance 20cm between the radiator & your body.
Déclaration d'exposition aux radiations:Cet équipement est conforme aux limites d'exposition aux rayonnements IC établies pour un environnement non contrôlé. Cet équipement doit être installé et utilisé avec un minimum de 20 cm de distance entre la source de rayonnement et votre corps.
Allowed Frequency Bands and Channel Numbers – 2.4GHz
Allowed Frequency Bands and Channel Numbers – 5GHz
Restriction
11bg & 11n HT20 : 2412~2462MHz (ch1-11)
11n HT40
2422~2452MHz (ch3-9)
11a & 11n &11ac
HT20&VHT20:
5180~5320 MHz, 5500~5700MHz(*), 5745~5825MHz
Ch #s : 36,40,44,48,52,56,60,64,100,104,108,112,116 ,132,136,140, 149, 153, 157, 161,165
HT40& VHT40:
5190~5310MHz, 5510~5670 MHz(*), 5755~5795MHz
Ch#s :38,46,54,62, 102,110, 134, 151, 159
VHT80:
5210~5290MHz, 5530MHz, 5775MHz
Ch#s :42, 58, 106, 155
5GHz DFS required bands :
5250~5350MHz; 5470~5725MHz
This device is Indoor use only in Canada when operating in below frequency bands:
5150~5250MHz
Note: (*). No operation in band 5600-5650MHz in USA and Canada
VCCI
This product complies with the requirements of VCCI Class B Information Technology Equipment (ITE).
Warning
This is a Class B equipment. Although this equipment is intended for use in a residential
environment, it could cause poor reception if used near a radio or a television receiver. Please
follow instructions in the instruction manual. VCCI-B
この装置は、クラスB機器です。この装置は、住宅環境で使用することを目的としていますが、この装置がラジオやテレビジョン受信機に近接して使用されると、受信障害を引き起こすことがあります。取扱説明書に従って正しい取り扱いをして下さい。 VCCI-B
MII
This product complies with the ARIB requirements in the W52, W53 and W56 2.4GHz frequency bands. This product is indoor use only.
This product complies with the requirements of EN55022, AS/NZS CISPR 22, CISPR22 for Class B Information Technology Equipment (ITE).
This product complies with the requirements of EN55032, AS/NZS CISPR 32, CISPR32 for Class B Information Technology Equipment (ITE).
H3C is committed to providing our customers with information about the chemical substances in our products as needed to comply with legal requirements such as REACH (Regulation EC No 1907/2006 of the European Parliament and the Council).
Türkiye Cumhuriyeti: EEE Yönetmeliğine Uygundur
Обладнання відповідає вимогам Технічного регламенту щодо обмеження використання деяких
небезпечних речовин в електричному та електронному обладнанні, затвердженого постановою
Кабінету Міністрів України від 3 грудня 2008 № 1057
This product complies with the "India E-waste (Management and Handling) Rule 2011" and prohibits use of lead, mercury, hexavalent chromium, polybrominated biphenyls or polybrominated diphenyl ethers in concentrations exceeding 0.1 weight % and 0.01 weight % for cadmium, except for the exemptions set in Schedule 2 of the Rule.
Perchlorate material Special handling may apply
Perchlorate material - special handling may apply.
See http://www.dtsc.ca.gov/hazardouswaste/perchlorate/.
This product’s real-time clock battery or coin cell battery may contain perchlorate and may require special handling when recycled or disposed of in California.
