H3Care Onsite Inspection
15-11-2019Onsite inspection is a high-end service provided by H3C to the customer purchasing this service. Onsite inspection is to comprehensively check the customer’s network and equipment to satisfy the customer’s requirement for ensuring the network. It can alarm a possible hidden danger of problem in the customer network and work out a solution, so that the customer can take proper precautions, thus reducing the network operation risk to the maximum extent.
H3C onsite inspection
No. | Inspection content | ||
1 | Inspection items of running status of the hardware | ||
Board status | Power module status | Fan status | |
Whole-equipment indicator status | Air filter in the frame | Temperature and humidity in the equipment room | |
Grounding cable of the equipment | |||
2 | Inspection items of running condition of the software | ||
Running condition of the equipment | Network message analysis | Running condition of equipment interconnection | |
Running condition of route | Network change | History fault of the network | |
3 | Survey of overall running condition of the network | ||
Network running problem | Network change condition | History fault of network | |
The above inspection contents vary with the specific condition of the equipment | |||
The above contents are normal inspection ones. H3C can add or delete the specific items of inspection content according to the requirements of the customer and characteristics of the equipment and networking and confirm these items in the statement of work.
