Title | Size | Downloads |
H3C WA2620-AGN WLAN Access Point Quick Start-6PW104-book.pdf | 1.17 MB |
- Fundamentals Configuration Guide
- WLAN Configuration Guide
- H3C WA2600 Series Indoor WLAN Access Points Installation Manual-5PW102
- About the H3C WA Configuration Guides
- H3C WA2600 Series Indoor Access Points Compliance and Safety Manual-6W103
- H3C WA2600 Series Enhanced Access Points Compliance and Safety Manual-6PW107
Preface
H3C WA2620-AGN WLAN Access Point Quick Start describes the basic steps necessary to install and configure your H3C WA2620-AGN (11n 2.4+5GHz PoE) Access Point.
This preface includes:
· Audience
· About the H3C WA2620-AGN documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WA2620-AGN WLAN Access Point.
Conventions
This section describes the conventions used in this documentation set.
Symbols
Convention |
NOTE |
The H3C WA2620-AGN documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Technology white papers |
Provide an in-depth description of software features and technologies. |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation |
Quick start |
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Configuration examples |
Describe typical network scenarios and provide configuration examples and instructions. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] – Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
