H3C WA2620X-AGNP Access Point Installation Guide-APW100
HomeSupportWirelessH3C WA2600 Series WLAN Access PointsInstall & UpgradeInstallation GuidesH3C WA2620X-AGNP Access Point Installation Guide-APW100
Download Book
Preface
The H3C WA2620X-AGNP AP Installation Guide describes the hardware specifications of the new generation WA2600 802.11n outdoor AP, preparations before installation, installation procedure, cabling and grounding, and login procedure. An appendix is included to describe how to crimp RJ-45 connectors.
The preface includes:
·           Audience
·           Conventions
·           About the H3C WA2620X-AGNP documentation set
·           Obtaining documentation
·           Technical support
·           Documentation feedback
Audience
·           Network planners
·           Field technical support and servicing engineers
·           Network administrators working with the WA2620X-AGNP APs
Conventions
Symbols
Convention
 CAUTION
NOTE
The H3C WA2620X-AGNP documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Technology white papers
Provide an in-depth description of software features and technologies.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Configuration examples
Describe typical network scenarios and provide configuration examples and instructions.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents] – Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions] Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download] – Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
