Title | Size | Downloads |
H3C WA Series Access Points Web-Based Configuration Guide-6W106-book.pdf | 9.6 MB |
Preface
The H3C WA Series Access Points Web-based Configuration Guide describes the web functions of the WA series, such as quick start, Web overview, wireless service configuration, security and authentication related configurations, QoS configuration, and advanced settings.
NOTE: · The grayed out functions or parameters on the web interface indicate that they are not supported or cannot be modified. · The displayed web pages may vary depending on your AP model. · The terms AP and fat AP in this document can refer to wireless bridges with fat AP functions. |
This preface includes:
· Audience
· About the H3C WA series access points documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the WA series
Conventions
This section describes the conventions used in this documentation set.
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
The H3C WA series access points documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation. |
Quick start |
Guides you through initial installation and setup procedures to help you quickly set up and use your AP with the minimum configuration. |
Installation guide |
Guides you through hardware specifications and installation methods to help you install your AP. |
Software configuration |
Getting started guide |
Guides you through the main functions of your AP, and describes how to install and log in to your AP, perform basic configurations, maintain software, and troubleshoot your AP. |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
