H3C ANT-2506V-M6-E omnidirectional antenna installation guide-5PW100
HomeSupportWirelessH3C External AntennaInstall & UpgradeInstallation GuidesH3C ANT-2506V-M6-E omnidirectional antenna installation guide-5PW100
Technical specifications
The ANT-2506V-M6-E antenna is designed for use in outdoor environments. It is connected to the 2.4-GHz or 5-GHz antenna port on an H3C outdoor AP through an N-type connector.
Figure 1 Antenna view
Table 1 Technical specifications
Antenna type
ANT-2506V-M6-E
Operating frequency range
2400 MHz to 2483 MHz
5150 MHz to 5850 MHz
Bandwidth
83 MHz
700 MHz
Peak gain
6 dBi
8 dBi
Voltage standing wave ratio (VSWR)
≤ 1.5
Impedance
50 Ω
Polarization type
Vertical
Max. power
20 W
Connector
N-Female
Number of connector ports
6
Dimensions
145 mm (5.71 in) diameter and 300 mm (11.81 in) length
Weight
1.2 kg (2.65 lb)
Operating temperature
–40°C to +60°C (–40°F to +140°F)
Installation
Mast mounting
Figure 2, Figure 3, Figure 4, and Figure 5 show the horizontal and vertical radiation patterns.
Figure 2 2.4-GHz horizontal pattern
SPQ-2400-8-H
Figure 3 2.4-GHz vertical pattern
2400
Figure 4 5-GHz horizontal pattern
SPQ-5800-10-H
Figure 5 5-GHz vertical pattern
5800
Safety precautions
WARNING
WARNING!
·     Installing antennas is dangerous. For your safety, follow the installation directions.
·     Keep the antenna away from power source, street lamps, distribution box, or other places that may cause electrical shock.
·     Do not touch any power lines for your safety.
·     Keep safety in mind when you select your installation site. Keep the antenna away from electric power lines and other lines.
·     Do not work alone when you install the antenna.
·     If you need to raise the mast, work with other people to avoid bodily injury.
·     Do not use a metal ladder. Do not work on a wet or windy day. Dress properly, for example, shoes with rubber soles. Wear rubber gloves.
·     If the antenna, antenna cable, or any other installation accessory drops, get away from it to avoid bodily injury.
·     If an accident, for example, electrical shock, occurs with the power lines, immediately call for qualified emergency help.
Installation guidelines
The ANT-2506V-M6-E is designed to create a MIMO-omnidirectional broadcast pattern, and is applicable to towers or building top. If the mounting location is on the side of a building or tower, the antenna pattern will be degraded on the building or tower side. Typically, the higher an antenna is above the ground, the better it performs. Install the antenna vertically and mount it as high as possible. Keep the antenna away from metal obstructions and wire mesh.
Choosing a mounting location
The ANT-2506V-M6-E is typically installed on a high position, such as tower or building roof, with a mast. The higher an antenna is above the floor, the better it performs. If possible, use a cable as short as possible to connect the antenna and AP.
Mounting the antenna
You can install the ANT-2506V-M6-E antenna on a mast. The installation accessories are provided (installation tools are user provided). If you intend to install your antenna on another surface, you must provide the appropriate installation accessories.
Tools and equipment required
Provided with the antenna:
·     Four M8 hex nuts that have been attached to the antenna
·     Two U-bolts
·     Four M8 hex nuts
·     Eight 8 mm (0.32 in) flat washers
·     Eight 8 mm (0.32 in) spring washers
·     One L-mounting bracket
·     Two U-mounting brackets
User-supplied:
·     One adjustable wrench
·     One knife
·     A cable tie
·     Grounding cable
·     Sealant tape and sealing clay
·     One mast with a diameter of 40 to 80 mm (1.57 to 3.15 in)
Mounting the antenna on a mast
To mount the antenna on a mast:
1.     Use four sets of M8 hex nuts, spring washers, and flat washers to attach the L-mounting bracket to the antenna bottom.
Figure 6 Attaching the L-mounting bracket to the antenna
(1) Grounding terminal
(2) M8 hex nut, spring washer, and flat washer
(3) L-mounting bracket
2.     Place a U-bolt around the mast, and pass the U-bolt through the target installation holes on the U-mounting bracket. Make sure the antenna is vertical to the ground.
3.     Place a spring washer and flat washer on each end of the U-bolt, start an M8 hex nut on each end of the U-bolt and tighten the nut with an adjustable wrench.
4.     Repeat Steps 2 and 3 to attach the other U-bolt to the mounting brackets.
Figure 7 Installing the antenna
(1) M8 U-bolt
(2) U-mounting bracket
(3) M8 hex nut, spring washer, and flat washer
(4) L-mounting bracket
Recommended cable
H3C recommends that you use a high-quality, low-loss cable with the antenna. Coaxial cable loses efficiency as the frequency increases, causing signal loss. Keep the cable as short as possible because cable length also causes signal loss (the longer the run, the greater the loss).
