H3C LSCM3SUP03A0 Card Manual-APW100
HomeSupportSwitchesH3C S7500X-G Switch SeriesInstall & UpgradeMPU Card ManualsH3C LSCM3SUP03A0 Card Manual-APW100
Download Book
  • Released At: 02-03-2023
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
LSCM3SUP03A0 supervisor engine unit
1  Identifier
The module identifier LSCM3SUP03A0 is in the upper right corner of the front panel.
2  Specifications
Table 1 Module specifications
Item
Specifications
Flash
2 GB
BootROM
32 MB
NVRAM
1 MB
SDRAM
4 GB
Dimensions (H × W × D)
45 × 199 × 355 mm (1.77 × 7.83× 13.98 in)
Power consumption
23 W to 29 W
Ports
·         1 × console port
·         1 × USB console port
·         2 × network management ports (one RJ-45 port and one SFP port)
·         1 × primary USB port
Port transmission rate
·         Console port: 9600 (default) to 115200 bps
·         USB console port: ≤ 115200 bps (default: 9600 bps)
·         RJ-45 network management port: 10/100/1000 Mbps, half/full duplex
·         SFP network management port: 1000 Mbps
Available cable and maximum transmission distance
·         Console port: 15 m (49.21 ft) over an asynchronous EIA/TIA-232 cable
·         USB console port: 10 m (32.81 ft) over a micro USB Type-B cable
·         RJ-45 network management port: 100 m ( 328.08 ft ) over a Category 5 or above twisted pair cable
Applicable device models
S7503X-G
·      The USB port does not support USB extension cables.
·      To verify the compatibility of the module with the software release you are using, see the release notes.
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin
10BASE-T/100BASE-TX/1000BASE-T
Signal
Function
1
MX_0+
Transmits and receives data.
2
MX_0-
3
MX_1+
4
MX_2+
5
MX_2-
6
MX_1-
7
MX_3+
8
MX_3-
IMPORTANT
IMPORTANT:
For more information about transceiver modules and cables available for the module, see H3C S7500X-G Switch Series Cards and Transceiver Modules Compatibility Matrixes.
3  Related documentation
For information about installing the module, see the installation guide for the device.
For information about upgrading system software, see the release notes.
Copyright © 2021 New H3C Technologies Co ., Ltd.
