Title | Size | Downloads |
H3C LSCM2SUP03B0 Card Manual-APW100-book.pdf | 68.12 KB |
book | 68.12 KB |
LSCM2SUP03B0 supervisor engine unit
1 Module identifier
The module identifier LSCM2SUP03B0 is in the upper right corner of the front panel.
2 Specifications
Table 1 Module specifications
Item |
Specification |
Flash |
4 GB |
BootROM |
8 MB |
NVRAM |
1 MB |
SDRAM |
4 GB |
Dimensions (H × W × D) |
45 × 199 × 355 mm (1.77 × 7.83 × 13.98 in) |
Power consumption |
9 W to 16 W |
Interfaces |
· 1 console port · 1 USB console port · 2 network management ports: 1 RJ-45 ports and 1 SFP fiber ports · 1 primary USB port |
Transmission rate |
· Console port: 9600 bps to 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · network management ports ( RJ-45 ): 10/100/1000 Mbps, half/full duplex · network management ports (SFP ): 1000 Mbps |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous EIA/TIA-232 cables · USB console port: 10 m (32.81 ft) over USB-AB cables · network management ports ( RJ-45 ): 100 m (328.08 ft) over Category 5 or higher twisted pair cables · network management ports (SFP ): GE SFP fiber module specification |
Compatible device models |
S7503X-G |
NOTE: · The USB port does not support a USB extension cable. · For information about transceiver modules and cables available for the module, see H3C S7500X-G Switch Series Cards and Transceiver Modules Compatibility Matrixes. · To verify compatibility of the module with the software release you are using, see the release notes. |
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin |
10BASE-T/100BASE-TX/1000BASE-T |
Signal |
Function |
1 |
MX_0+ |
Transmits and receives data. |
2 |
MX_0- |
3 |
MX_1+ |
4 |
MX_2+ |
5 |
MX_2- |
6 |
MX_1- |
7 |
MX_3+ |
8 |
MX_3- |
3 Related documentation
For information about installing the module, see H3C S7500X-G Switch Series Installation Guide.
For information about software upgrade, see the release notes for the device.
Copyright © 2021 New H3C Technologies Co., Ltd.
