Title | Size | Downloads |
H3C LSCM2CGT24TSSC0 Card Manual-APW100-book.pdf | 69.67 KB |
book | 69.67 KB |
24-port 10/100/1000BASE-T electrical Ethernet interface + 4-port 10GBASE-R-SFP+ Main Processing Unit with Switching and Routing—LSCM2CGT24TSSC0
1 Card identifier
The card identifier LSCM2CGT24TSSC0 is in the upper right corner of the front panel.
2 Specifications
Table 1 Card specifications
Item |
Specifications |
Flash |
4 GB |
BootROM |
4 MB * 2 |
NVRAM |
1 MB |
SDRAM |
2 GB |
Card size (H × W × D) |
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in) |
Power consumption |
23 W to 41 W |
Ports |
· 1 console port · 1 USB console port · 1 network management port · 1 primary USB port · 24 10/100/1000BASE-T copper ports · 4 10GBASE-R-SFP+ fiber ports |
Port rate |
· Console port: 9600 bps to 115200 bps (default: 9600 bps) · USB console port: ≤ 115200 bps (default: 9600 bps) · network management port: 10/100/1000 Mbps, half/full duplex · 10/100/1000BASE-T copper ports: 10/100/1000 Mbps · SFP+ fiber ports: 1 Gbps and 10 Gbps |
Transmission medium and max transmission distance |
· Console port: 15 m (49.21 ft) over asynchronous EIA/TIA-232 cables · USB console port: 10 m (32.81 ft) over USB-AB cables · network management port: 100 m (328.08 ft) over Category 5 or higher twisted pair cables · 10/100/1000BASE-T copper ports: 100 m (328.08 ft) over Category 5 or higher twisted pair cables · SFP+: GE SFP fiber module specifications and GE SFP+ fiber module specifications |
Applicable hardware platforms |
S7503X-M-G |
NOTE: · H3C recommends not using a USB extender cable to connect the USB port. · To verify the compatibility of the module with the software release you are using, see the release notes. |
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin |
10BASE-T/100BASE-TX/1000BASE-T |
Signal |
Function |
1 |
MX_0+ |
Transmits and receives data. |
2 |
MX_0- |
3 |
MX_1+ |
4 |
MX_2+ |
5 |
MX_2- |
6 |
MX_1- |
7 |
MX_3+ |
8 |
MX_3- |
IMPORTANT: For more information about transceiver modules and cables available for the card, see H3C S7500X-G Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
3 Related documentation
For module installation, see the installation guide for the device.
For software upgrade, see the release notes for the device.
Copyright © 2020 New H3C Technologies Co ., Ltd.
