H3C LSCM1SUP03A0 Card Manual-6PW102
HomeSupportSwitchesH3C S7500X-G Switch SeriesInstall & UpgradeMPU Card ManualsH3C LSCM1SUP03A0 Card Manual-6PW102
Title Size Downloads
H3C LSCM1SUP03A0 Card Manual-6PW102-book.pdf 51.10 KB
Table of Contents
Related Documents
book
book 51.10 KB
LSCM1SUP03A0 supervisor engine unit
1  Identifier
The module identifier LSCM1SUP03A0 is in the upper right corner of the front panel.
2  Specifications
Table 1 Module specifications
Item
Specifications
Flash
1 GB
BootROM
16 MB
NVRAM
1 MB
SDRAM (DDR3)
2 GB
Dimensions (H × W × D)
45 × 199 × 355 mm (1.77 × 7.83× 13.98 in)
Power consumption
19 W to 23 W
Ports
·     1 × console port
·     1 × USB console port
·     2 × network management ports (one RJ-45 port and one SFP port)
·     1 × primary USB port
Port transmission rate
·     Console port: 9600 (default) to 115200 bps
·     USB console port: ≤ 115200 bps (default: 9600 bps)
·     RJ-45 network management port: 10/100/1000 Mbps, half/full duplex
·     SFP network management port: 1000 Mbps
Available cable and maximum transmission distance
·     Console port: 15 m (49.21 ft) over an asynchronous EIA/TIA-232 cable
·     USB console port: 10 m (32.81 ft) over a micro USB Type-B cable
·     RJ-45 network management port: 100 m ( 328.08 ft ) over a Category 5 or above twisted pair cable
Applicable hardware platforms
S7503X-G
·     The USB port does not support USB extension cables.
·     To verify the compatibility of the module with the software release you are using, see the release notes.
The 10/100/1000BASE-T copper port uses an RJ-45 connector.
Figure 1 RJ-45 connector
Table 2 RJ-45 GE connector pinout
Pin
10BASE-T/100BASE-TX/1000BASE-T
Signal
Function
1
MX_0+
Transmits and receives data.
2
MX_0-
3
MX_1+
4
MX_2+
5
MX_2-
6
MX_1-
7
MX_3+
8
MX_3-
IMPORTANT
IMPORTANT:
For more information about transceiver modules and cables available for the module, see H3C S7500X-G Switch Series Cards and Transceiver Modules Compatibility Matrixes.
3  Related documentation
For information about installing the module, see the installation guide for the device.
For information about upgrading system software, see the release notes.
Copyright © 2017-2021 New H3C Technologies Co ., Ltd.
