H3C S7500X-G Switch Series Configuration Guides-R7748Pxx-6W100-book_CHM.rar(37.02 MB)
H3C S7500X-G Switch Series Configuration Guides-R7748Pxx-6W100-book.pdf(32.89 MB)
- Released At: 29-08-2023
- Page Views:
- Downloads:
About the H3C S7500X-G configuration guides
Configuration guide |
Content |
Fundamentals Configuration Guide |
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes: · CLI · RBAC · Login management · FTP and TFTP · File system management · Configuration file management · Software upgrade · ISSU · GIR · Device management · Automatic configuration · Tcl · Python · License management · Management with BootWare |
Virtual Technologies Configuration Guide |
Covers virtual technologies. This guide includes: · IRF · MDC |
Interface Configuration Guide |
Describes how to configure interfaces. This guide includes: · Bulk interface · Ethernet interface · Loopback, null, and inloopback interface |
Layer 2—LAN Switching Configuration Guide |
Describes LAN switching features and tasks for Layer 2 network configuration. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, customer network packets transparent to the service provider network, remark VLAN tags, and so on. This guide includes: · MAC address table · Ethernet link aggregation · M-LAG · Port isolation · VLAN · MVRP · QinQ · VLAN mapping · Loop detection · Spanning tree · LLDP · Layer 2 forwarding |
Layer 3—IP Services Configuration Guide |
Describes the IP services fundamentals and configuration procedures. You can use these features to configure IP addressing, IP performance optimization, ARP, DNS, UDP helper, and interoperation between IPv4 and IPv6. This guide includes: · DHCP · DNS · IP forwarding basics · Fast forwarding · Adjacency table · IRDP · IP performance optimization · IPv6 fast forwarding · Tunneling · GRE · HTTP redirect |
Layer 3—IP Routing Configuration Guide |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy based routing. This guide includes: · Basic IP routing · Static routing · RIP · OSPF · IS-IS · BGP · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 policy-based routing · Routing policy · DCN |
IP Multicast Configuration Guide |
Covers Layer 2 and Layer 3 multicast protocols. This guide includes: · Multicast overview · IGMP snooping · Multicast VLAN · Multicast routing and forwarding · IGMP · PIM · MSDP · MLD snooping · IPv6 multicast VLAN · IPv6 multicast routing and forwarding · MLD · IPv6 PIM |
MCE Configuration Guide |
Describes the fundamentals and configuration procedures for MCE. |
ACL and QoS Configuration Guide |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes: · ACL · Time range · Data buffer |
Security Configuration Guide |
Covers security features. The major security features available on the switch include: identity authentication, access security authentication, secure management, and attack protection. This guide includes: · AAA · 802.1X · MAC authentication · Portal · Port security · Password control · Keychain · PKI · IPsec · SSH · SSL · Attack detection and prevention · TCP attack prevention · IP source guard · ARP attack protection · ND attack defense · uRPF · MFF · 802.1X client |
High Availability Configuration Guide |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · Ethernet OAM · DLDP · RRPP · ERPS · Smart Link · Monitor Link · Error code detection · VRRP · Reth interface · BFD · Track |
Network Management and Monitoring Configuration Guide |
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes: · System maintenance and debugging · NQA · PoE · SNMP · RMON · NETCONF · SmartMC · CWMP · EAA · Process monitoring and maintenance · Sampler · Mirroring · sFlow · Information center · GOLD · Packet capture · Performance managemen · Ansible · Cloud connection · VCF fabric |
Telemetry Configuration Guide |
Describes the application scenarios, fundamentals, and configuration of Telemetry.This guide includes: · gRPC |
OpenFlow Configuration Guide |
Describes the application scenarios, fundamentals, and configuration of OpenFlow. OpenFlow allows a controller to directly access and operate the forwarding plane of the switch, separating the control plane from the data plane. The switch matches and forwards packets according to the flow tables issued by the controller. In the same flow table, the switch matches the packets according to the priority of the flow entries. An OpenFlow switch can contain one or more flow tables. |
