Title | Size | Downloads |
14-EVI Configuration Guide-book.pdf | 579.00 KB |
Preface
This configuration guide describes EVI fundamentals and configuration. It describes how to use MAC-in-IP technology Ethernet Virtual Interconnect (EVI) to provide Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. EVI enables dynamic allocation and management of resources and transparent migration of virtual machines between network sites.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S7500X switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
