Title | Size | Downloads |
14-TRILL Configuration Guide-book.pdf | 332.57 KB |
Preface
This configuration guide describes TRILL fundamentals and configuration. TRansparent Interconnection of Lots of Links (TRILL) is suitable for large flat Layer 2 networks in data centers.
· Audience.
Audience
· Network planners.
· Network administrators working with the routers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Multi-level menus are separated by angle brackets. For example, File>Create>Folder. |
Symbols
Convention |
Analertthatcallsattentiontoimportantinformationthatifnotunderstoodorfollowedcanresultinpersonalinjury. |
Analertthatcallsattentiontoessentialinformation. |
NOTE: |
Analertthatcontainsadditionalorsupplementaryinformation. |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security product, such as a firewall, UTM, multiservice security gateway, or loadbalancing device. |
Represents a security module, such as a firewall, loadbalancing, NetStream, SSL VPN, IPS, or ACG module. |
Obtaining documentation
To access the most up-to-date H3Cproduct documentation, go to the H3C website at
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
Documentation feedback
You can e-mail your comments about product documentation [email protected].
We appreciate your comments.
