Title | Size | Downloads |
00-About the S7500E-XS Configuration Guides-book(chm).rar | 18.55 MB |
About the H3C S7500E-XS configuration guides
Configuration guide |
Content |
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes: · CLI · RBAC · Login management · FTP and TFTP · File system management · Configuration file management · Software upgrade · ISSU · Automatic configuration · Device management · Tcl · Management with Boot ROM · Python |
Describes the H3C proprietary Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers. |
Covers the configuration of various interfaces. This guide includes: · Bulk interface configuration · Ethernet interface · Loopback, null, and inloopback interface |
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes: · MAC address table · Ethernet link aggregation · Port isolation · Spanning tree · Loop detection · VLAN · MVRP · QinQ · VLAN mapping · LLDP · Service loopback group |
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, DHCPv6, tunneling, and GRE. This guide includes: · DHCP · IP forwarding basics · Fast forwarding · Adjacency table · IRDP · IP performance optimization · UDP Helper · IPv6 basics · IPv6 fast forwarding |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering. This guide includes: · Basic IP routing · Static routing · RIP · OSPF · IS-IS · BGP · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 IS-IS · IPv6 policy-based routing · Routing policy |
Covers Layer 3 IPv4 multicast protocols (IGMP, PIM, MSDP, and multicast VPN), Layer 3 IPv6 multicast protocols (MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes: · Multicast overview · IGMP snooping · PIM snooping · Multicast VLAN · Multicast routing and forwarding · IGMP · PIM · MSDP · Multicast VPN · MLD snooping · IPv6 PIM snooping · IPv6 multicast VLAN · IPv6 multicast routing and forwarding · MLD · IPv6 PIM |
Describes fundamentals and configurations of MPLS and extended MPLS functions. This configuration guide includes: · Basic MPLS · MPLS L2VPN |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes: · ACL · Data buffer |
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes: · AAA · 802.1X · MAC authentication · Port security · Password control · Public key management · SSL · PKI · IPsec · SSH · IP source guard · ARP attack protection · uRPF · FIPS · Attack detection and prevention · MACsec · MFF · ND attack defense · Keychain |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · High Availability Overview · Ethernet OAM · CFD · DLDP · RRPP · Smart Link · Monitor Link · VRRP · BFD · Track |
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes: · System maintenance and debugging · NQA · NETCONF · RMON · EAA · Process monitoring and maintenance · sFlow · Mirroring · Information center · GOLD · Packet capture |
Describes the application scenarios, fundamentals, and configuration of FCoE. |
Describes TRILL fundamentals and configuration. TRansparent Interconnection of Lots of Links (TRILL) is suitable for large flat Layer 2 networks in data centers. |
Describes the application scenarios, fundamentals, and configuration of EVB. |
Describes how to use the H3C MAC-in-IP technology Ethernet Virtual Interconnect (EVI) to provide Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. EVI enables dynamic allocation and management of resources and transparent migration of virtual machines between network sites. |
Describes the application scenarios, fundamentals, and configuration of OpenFlow. |
Describes VXLAN fundamentals and configuration. Virtual eXtensible LAN (VXLAN) is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. |
