H3C S7500E-X Release 7178 System Log Message Reference-6W100
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesLog Message ReferencesH3C S7500E-X Release 7178 System Log Message Reference-6W100
H3C S7500E-X System Log Messages Reference
H3C_彩色.emf
Introduction· 1
System log message format 1
Managing and obtaining system log messages· 3
Obtaining log messages from the console terminal 3
Obtaining log messages from the log buffer 3
Obtaining log messages from a monitor terminal 3
Obtaining log messages from the log file· 4
Obtaining log messages from a log host 4
Software module list 4
Using this document 6
AAA messages· 7
AAA_FAILURE· 7
AAA_LAUNCH· 8
AAA_SUCCESS· 8
ACL messages· 8
ACL_IPV6_STATIS_INFO·· 9
ACL_NO_MEM·· 9
ACL_STATIS_INFO·· 9
PFILTER_GLB_IPV4_DACT_NO_RES· 10
PFILTER_GLB_IPV4_DACT_UNK_ERR· 10
PFILTER_GLB_IPV6_DACT_NO_RES· 11
PFILTER_GLB_IPV6_DACT_UNK_ERR· 11
PFILTER_GLB_MAC_DACT_NO_RES· 12
PFILTER_GLB_MAC_DACT_UNK_ERR· 12
PFILTER_GLB_NO_RES· 13
PFILTER_GLB_NOT_SUPPORT· 13
PFILTER_GLB_UNK_ERR· 14
PFILTER_IF_IPV4_DACT_NO_RES· 14
PFILTER_IF_IPV4_DACT_UNK_ERR· 15
PFILTER_IF_IPV6_DACT_NO_RES· 15
PFILTER_IF_IPV6_DACT_UNK_ERR· 16
PFILTER_IF_MAC_DACT_NO_RES· 16
PFILTER_IF_MAC_DACT_UNK_ERR· 17
PFILTER_IF_NO_RES· 17
PFILTER_IF_NOT_SUPPORT· 18
PFILTER_IF_UNK_ERR· 18
PFILTER_IPV6_STATIS_INFO·· 19
PFILTER_STATIS_INFO·· 19
PFILTER_VLAN_IPV4_DACT_NO_RES· 20
PFILTER_VLAN_IPV4_DACT_UNK_ERR· 20
PFILTER_VLAN_IPV6_DACT_NO_RES· 21
PFILTER_VLAN_IPV6_DACT_UNK_ERR· 21
PFILTER_VLAN_MAC_DACT_NO_RES· 22
PFILTER_VLAN_MAC_DACT_UNK_ERR· 22
PFILTER_VLAN_NO_RES· 23
PFILTER_VLAN_NOT_SUPPORT· 23
PFILTER_VLAN_UNK_ERR· 24
APMGR messages· 24
APMGR_ADDBAC_INFO·· 24
APMGR_DELBAC_INFO·· 25
ARP messages· 25
ARP_ACTIVE_ACK_NO_REPLY· 25
ARP_ACTIVE_ACK_NOREQUESTED_REPLY· 26
ARP_RATE_EXCEEDED· 26
ARP_SENDER_IP_INVALID· 27
ARP_SENDER_MAC_INVALID· 27
ARP_SRC_MAC_FOUND_ATTACK· 27
ARP_TARGET_IP_INVALID· 28
DUPIFIP· 28
DUPIP· 28
DUPVRRPIP· 29
BFD messages· 29
BFD_CHANGE_FSM·· 29
BFD_REACHED_UPPER_LIMIT· 30
BGP messages· 30
BGP_EXCEED_ROUTE_LIMIT· 30
BGP_EXCEEDS_THRESHOLD· 30
BGP_MEM_ALERT· 31
BGP_STATE_CHANGED· 31
CFD messages· 31
CFD_CROSS_CCM·· 32
CFD_ERROR_CCM·· 32
CFD_LOST_CCM·· 33
CFD_RECEIVE_CCM·· 33
CFGMAN messages· 33
CFGMAN_CFGCHANGED· 34
CFGMAN_OPTCOMPLETION· 34
DEV messages· 34
BOARD_REBOOT· 35
BOARD_REMOVED· 35
BOARD_STATE_FAULT· 36
BOARD_STATE_NORMAL· 36
CFCARD_INSERTED· 37
CFCARD_REMOVED· 37
CHASSIS_REBOOT· 38
DEV_CLOCK_CHANGE· 38
FAN_ABSENT· 39
FAN_ABSENT· 39
FAN_DIRECTION_NOT_PREFERRED· 40
FAN_FAILED· 40
FAN_FAILED· 40
FAN_RECOVERED· 41
FAN_RECOVERED· 41
POWER_ABSENT· 41
POWER_ABSENT· 42
POWER_FAILED· 42
POWER_FAILED· 42
POWER_MONITOR_ABSENT· 43
POWER_MONITOR_FAILED· 44
POWER_MONITOR_RECOVERED· 44
POWER_MONITOR_RECOVERED· 45
POWER_RECOVERED· 45
POWER_RECOVERED· 45
RPS_ABSENT· 46
RPS_ABSENT· 46
RPS_NORMAL· 46
RPS_NORMAL· 47
SUBCARD_FAULT· 47
SUBCARD_INSERTED· 48
SUBCARD_REBOOT· 48
SUBCARD_REMOVED· 49
SYSTEM_REBOOT· 49
TEMPERATURE_ALARM·· 50
TEMPERATURE_LOW·· 50
TEMPERATURE_NORMAL· 51
TEMPERATURE_SHUTDOWN· 51
TEMPERATURE_WARNING·· 52
DIAG messages· 52
MEM_BELOW_THRESHOLD· 52
MEM_EXCEED_THRESHOLD· 53
DLDP messages· 53
DLDP_AUTHENTICATION_FAILED· 53
DLDP_LINK_BIDIRECTIONAL· 54
DLDP_LINK_UNIDIRECTIONAL· 54
DLDP_NEIGHBOR_AGED· 54
DLDP_NEIGHBOR_CONFIRMED· 55
DLDP_NEIGHBOR_DELETED· 55
DOT1X messages· 55
DOT1X_NOTENOUGH_EADFREEIP_RES· 56
DOT1X_NOTENOUGH_EADFREERULE_RES· 56
DOT1X_NOTENOUGH_EADPORTREDIR_RES· 56
DOT1X_NOTENOUGH_EADMACREDIR_RES· 57
DOT1X_NOTENOUGH_ENABLEDOT1X_RES· 57
DOT1X_UNICAST_NOT_EFFECTIVE· 57
DOT1X_SMARTON_FAILURE· 58
DOT1X_LOGIN_FAILURE· 58
DOT1X_LOGIN_SUCC· 59
DOT1X_LOGOFF· 59
DRVPLAT messages· 59
DRVDEBUGMOD_VCF· 60
DRVPLAT/4/DrvDebug· 60
DRVPLAT/4/DrvDebug· 61
DRVPLAT/4/DrvDebug· 62
DRVDEBUGMOD_DEVM·· 63
DRVPLAT/4/DrvDebug· 63
DRVPLAT/2/DrvDebug· 64
DRVPLAT/4/DrvDebug· 65
DRVPLAT/4/DrvDebug· 66
DRVPLAT/4/DrvDebug· 67
DRVDEBUGMOD_GOLD· 68
DRVPLAT/4/DrvDebug· 68
DRVPLAT/2/DrvDebug· 69
DRVPLAT/2/DrvDebug· 70
DRVPLAT/4/DrvDebug· 70
DRVPLAT/2/DrvDebug· 71
DRVPLAT/4/DrvDebug· 72
DRVDEBUGMOD_SYSM·· 73
DRVPLAT/2/DrvDebug· 73
DRVPLAT/2/DrvDebug· 74
DRVPLAT/2/DrvDebug· 75
DRVPLAT/2/DrvDebug· 76
DRVPLAT/2/DrvDebug· 77
DRVPLAT/4/DrvDebug· 78
DRVPLAT/4/DrvDebug· 79
DRVPLAT/4/DrvDebug· 80
DRVPLAT/2/DrvDebug· 80
DRVPLAT/2/DrvDebug· 81
DRVPLAT/2/DrvDebug· 82
DRVPLAT/4/DrvDebug· 82
DRVPLAT/4/DrvDebug· 83
DRVPLAT/4/DrvDebug· 84
DRVPLAT/2/DrvDebug· 84
DRVPLAT/2/DrvDebug· 85
DRVPLAT/2/DrvDebug· 86
DRVPLAT/2/DrvDebug· 87
DRVPLAT/2/DrvDebug· 88
DRVPLAT/4/DrvDebug· 89
DRVDEBUGMOD_RXTX· 89
DRVPLAT/2/DrvDebug· 89
DRVDEBUGMOD_POE· 90
DRVPLAT/4/DrvDebug· 90
DRVPLAT/4/DrvDebug· 91
DRVDEBUGMOD_PORT· 92
DRVPLAT/4/DrvDebug· 92
DRVDEBUGMOD_STACK· 93
DRVPLAT/4/DrvDebug· 93
DRVPLAT/4/DrvDebug· 94
DRVPLAT/4/DrvDebug· 95
DRVPLAT/4/DrvDebug· 96
DRVPLAT/4/DrvDebug· 97
DRVDEBUGMOD_SWFA· 98
DRVPLAT/4/DrvDebug· 98
DRVPLAT/4/DrvDebug· 99
DRVPLAT/4/DrvDebug· 100
DRVPLAT/4/DrvDebug· 101
DRVPLAT/4/DrvDebug· 102
DRVPLAT/4/DrvDebug· 103
DRVDEBUGMOD_BSP· 103
DRVPLAT/3/DrvDebug· 103
DRVPLAT/3/DrvDebug· 104
DRVPLAT/3/DrvDebug· 105
DRVPLAT/3/DrvDebug· 106
DRVPLAT/3/DrvDebug· 107
DRVPLAT/3/DrvDebug· 108
ETHOAM messages· 108
ETHOAM_CONNECTION_FAIL_DOWN· 108
ETHOAM_CONNECTION_FAIL_TIMEOUT· 109
ETHOAM_CONNECTION_FAIL_UNSATISF· 109
ETHOAM_CONNECTION_SUCCEED· 109
ETHOAM_DISABLE· 110
ETHOAM_DISCOVERY_EXIT· 110
ETHOAM_ENABLE· 110
ETHOAM_ENTER_LOOPBACK_CTRLLED· 111
ETHOAM_ENTER_LOOPBACK_CTRLLING·· 111
ETHOAM_LOCAL_DYING_GASP· 111
ETHOAM_LOCAL_ERROR_FRAME· 112
ETHOAM_LOCAL_ERROR_FRAME_PERIOD· 112
ETHOAM_LOCAL_ERROR_FRAME_SECOND· 112
ETHOAM_LOCAL_LINK_FAULT· 113
ETHOAM_LOOPBACK_EXIT· 113
ETHOAM_LOOPBACK_EXIT_ERROR_STATU· 113
ETHOAM_LOOPBACK_NO_RESOURCE· 114
ETHOAM_LOOPBACK_NOT_SUPPORT· 114
ETHOAM_QUIT_LOOPBACK_CTRLLED· 114
ETHOAM_QUIT_LOOPBACK_CTRLLING·· 115
ETHOAM_REMOTE_CRITICAL· 115
ETHOAM_REMOTE_DYING_GASP· 115
ETHOAM_REMOTE_ERROR_FRAME· 116
ETHOAM_REMOTE_ERROR_FRAME_PERIOD· 116
ETHOAM_REMOTE_ERROR_FRAME_SECOND· 116
ETHOAM_REMOTE_ERROR_SYMBOL· 117
ETHOAM_REMOTE_EXIT· 117
ETHOAM_REMOTE_FAILURE_RECOVER· 117
ETHOAM_REMOTE_LINK_FAULT· 118
ETHOAM_NO_ENOUGH_RESOURCE· 118
ETHOAM_NOT_CONNECTION_TIMEOUT· 118
EVB messages· 118
EVB_AGG_FAILED· 119
EVB_VSI_OFFLINE· 119
EVB_VSI_ONLINE· 119
EVB_WARNING_NO_LICENSE· 120
EVIISIS messages· 120
EVIISIS_LICENSE_EXPIRED· 120
EVIISIS_LICENSE_EXPIRED_TIME· 120
EVIISIS_LICENSE_UNAVAILABLE· 121
EVIISIS_MEM_ALERT· 121
EVIISIS_NBR_CHG·· 121
FCOE messages· 122
FCOE_INTERFACE_NOTSUPPORT_FCOE· 122
FCOE_LICENSE_ERROR· 122
FCOE_LICENSE_EXPIRED_EXIT· 123
FCOE_LICENSE_EXPIRED_TIME· 123
FCLINK messages· 123
FCLINK_FDISC_REJECT_NORESOURCE· 123
FCLINK_FLOGI_REJECT_NORESOURCE· 124
FCZONE messages· 124
FCZONE_HARDZONE_DISABLED· 124
FCZONE_HARDZONE_ENABLED· 125
FIPS messages· 125
FCOE_FIPS_HARD_RESOURCE_NOENOUGH· 125
FCOE_FIPS_HARD_RESOURCE_RESTORE· 125
FTP messages· 126
FTP_REACH_SESSION_LIMIT· 126
HA messages· 126
HA_BATCHBACKUP_FINISHED· 126
HA_BATCHBACKUP_STARTED· 127
HA_STANDBY_NOT_READY· 127
HA_STANDBY_TO_MASTER· 127
HTTPD messages· 127
HTTPD_CONNECT· 128
HTTPD_CONNECT_TIMEOUT· 128
HTTPD_DISCONNECT· 128
HTTPD_FAIL_FOR_ACL· 129
HTTPD_FAIL_FOR_ACP· 129
HTTPD_REACH_CONNECT_LIMIT· 129
IFNET messages· 130
IFNET_MAD· 130
INTERFACE_INSERTED· 130
INTERFACE_REMOVED· 130
LINK_UPDOWN· 131
PHY_UPDOWN· 131
PROTOCOL_UPDOWN· 131
IKE messages· 131
IKE_P1_SA_ESTABLISH_FAIL· 132
IKE_P2_SA_ESTABLISH_FAIL· 132
IKE_P2_SA_TERMINATE· 133
IPSEC messages· 133
IPSEC_PACKET_DISCARDED· 133
IPSEC_SA_ESTABLISH· 134
IPSEC_SA_ESTABLISH_FAIL· 135
IPSEC_SA_INITINATION· 135
IPSEC_SA_TERMINATE· 136
IRDP messages· 136
IRDP_EXCEED_ADVADDR_LIMIT· 136
ISIS messages· 136
ISIS_MEM_ALERT· 137
ISIS_NBR_CHG·· 137
L2VPN messages· 137
L2VPN_HARD_RESOURCE_NOENOUGH· 138
L2VPN_HARD_RESOURCE_RESTORE· 138
LAGG messages· 138
LAGG_ACTIVE· 138
LAGG_INACTIVE_AICFG·· 139
LAGG_INACTIVE_CONFIGURATION· 139
LAGG_INACTIVE_DUPLEX· 140
LAGG_INACTIVE_HARDWAREVALUE· 140
LAGG_INACTIVE_LOWER_LIMIT· 141
LAGG_INACTIVE_PARTNER· 141
LAGG_INACTIVE_PHYSTATE· 142
LAGG_INACTIVE_RESOURCE_INSUFICIE· 142
LAGG_INACTIVE_SPEED· 143
LAGG_INACTIVE_UPPER_LIMIT· 143
LDP messages· 143
LDP_SESSION_CHG·· 144
LDP_SESSION_GR· 145
LDP_SESSION_SP· 145
LDP_MPLSLSRID_CHG·· 146
LICENSE messages· 146
LIC_INIT· 147
LLDP messages· 147
LLDP_CREATE_NEIGHBOR· 148
LLDP_DELETE_NEIGHBOR· 149
LLDP_LESS_THAN_NEIGHBOR_LIMIT· 149
LLDP_NEIGHBOR_AGE_OUT· 150
LLDP_PVID_INCONSISTENT· 150
LLDP_REACH_NEIGHBOR_LIMIT· 151
LOAD messages· 151
BOARD_LOADING·· 151
LOAD_FAILED· 152
LOAD_FINISHED· 152
LOGIN messages· 152
LOGIN_FAILED· 152
LPDT messages· 153
LPDT_LOOPED· 153
LPDT_RECOVERED· 153
LS messages· 153
LS_ADD_USER_TO_GROUP· 154
LS_AUTHEN_FAILURE· 154
LS_AUTHEN_SUCCESS· 155
LS_DEL_USER_FROM_GROUP· 155
LS_DELETE_PASSWORD_FAIL· 155
LS_PWD_ADDBLACKLIST· 156
LS_PWD_CHGPWD_FOR_AGEDOUT· 156
LS_PWD_CHGPWD_FOR_AGEOUT· 156
LS_PWD_CHGPWD_FOR_COMPOSITION· 157
LS_PWD_CHGPWD_FOR_FIRSTLOGIN· 157
LS_PWD_CHGPWD_FOR_LENGTH· 157
LS_PWD_FAILED2WRITEPASS2FILE· 158
LS_PWD_MODIFY_FAIL· 158
LS_PWD_MODIFY_SUCCESS· 158
LS_REAUTHEN_FAILURE· 159
LS_UPDATE_PASSWORD_FAIL· 159
LS_USER_CANCEL· 159
LS_USER_PASSWORD_EXPIRE· 160
LS_USER_ROLE_CHANGE· 160
LSPV messages· 160
LSPV_PING_STATIS_INFO·· 161
MAC messages· 161
MAC_TABLE_FULL_GLOBAL· 161
MAC_TABLE_FULL_PORT· 162
MAC_TABLE_FULL_VLAN· 162
MACA messages· 162
MACA_ENABLE_NOT_EFFECTIVE· 163
MACA_LOGIN_FAILURE· 163
MACA_LOGIN_SUCC· 164
MACA_LOGOFF· 164
MBFD messages· 164
MBFD_TRACEROUTE_FAILURE· 165
MDC messages· 165
MDC_CREATE· 165
MDC_CREATE_ERR· 166
MDC_DELETE· 166
MDC_LICENSE_EXPIRE· 166
MDC_NO_FORMAL_LICENSE· 167
MDC_NO_LICENSE_EXIT· 167
MDC_OFFLINE· 167
MDC_ONLINE· 168
MDC_STATE_CHANGE· 168
MFIB messages· 168
MFIB_MEM_ALERT· 168
MGROUP messages· 169
MGROUP_APPLY_SAMPLER_FAIL· 169
MGROUP_RESTORE_CPUCFG_FAIL· 169
MGROUP_RESTORE_IFCFG_FAIL· 170
MGROUP_SYNC_CFG_FAIL· 170
MPLS messages· 170
MPLS_HARD_RESOURCE_NOENOUGH· 171
MPLS_HARD_RESOURCE_RESTORE· 171
MSTP messages· 171
MSTP_BPDU_PROTECTION· 171
MSTP_BPDU_RECEIVE_EXPIRY· 172
MSTP_DETECTED_TC· 172
MSTP_DISABLE· 172
MSTP_DISCARDING·· 173
MSTP_ENABLE· 173
MSTP_FORWARDING·· 173
MSTP_LOOP_PROTECTION· 174
MSTP_NOT_ROOT· 174
MSTP_NOTIFIED_TC· 174
MSTP_ROOT_PROTECTION· 175
MTLK messages· 175
MTLK_UPLINK_STATUS_CHANGE· 175
ND messages· 175
ND_CONFLICT· 176
ND_DUPADDR· 176
ND_RAGUARD_DROP· 177
NQA messages· 177
NQA_LOG_UNREACHABLE· 177
NTP messages· 177
NTP_CHANGE_LEAP· 178
NTP_CHANGE_STRATUM·· 178
NTP_CLOCK_CHANGE· 178
NTP_SOURCE_CHANGE· 179
NTP_SOURCE_LOST· 179
OPTMOD messages· 179
BIAS_HIGH· 179
BIAS_LOW·· 180
BIAS_NORMAL· 180
CFG_ERR· 180
CHKSUM_ERR· 181
FIBER_SFPMODULE_INVALID· 181
FIBER_SFPMODULE_NOWINVALID· 181
IO_ERR· 182
MOD_ALM_OFF· 182
MOD_ALM_ON· 182
MODULE_IN· 183
MODULE_OUT· 183
PHONY_MODULE· 183
RX_ALM_OFF· 184
RX_ALM_ON· 184
RX_POW_HIGH· 184
RX_POW_LOW·· 185
RX_POW_NORMAL· 185
TEMP_HIGH· 185
TEMP_LOW·· 186
TEMP_NORMAL· 186
TX_ALM_OFF· 186
TX_ALM_ON· 187
TX_POW_HIGH· 187
TX_POW_LOW·· 187
TX_POW_NORMAL· 188
TYPE_ERR· 188
VOLT_HIGH· 188
VOLT_LOW·· 189
VOLT_NORMAL· 189
OSPF messages· 189
OSPF_LAST_NBR_DOWN· 190
OSPF_MEM_ALERT· 190
OSPF_NBR_CHG·· 191
OSPF_RT_LMT· 191
OSPF_RTRID_CHG·· 191
OSPF_VLINKID_CHG·· 192
OSPFV3 messages· 192
OSPFV3_LAST_NBR_DOWN· 192
OSPFV3_MEM_ALERT· 193
OSPFV3_NBR_CHG·· 193
OSPFV3_RT_LMT· 193
PBB messages· 194
PBB_JOINAGG_WARNING·· 194
PBR messages· 194
PBR_HARDWARE_ERROR· 194
PEX messages· 195
PEX_ASSOCIATEID_MISMATCHING·· 195
PEX_CONFIG_ERROR· 196
PEX_CONNECTION_ERROR· 196
PEX_STACKCONNECTION_ERROR· 197
PEX_FORBID_STACK· 197
PEX_LINK_BLOCK· 198
PEX_LINK_DOWN· 199
PEX_LINK_FORWARD· 199
PEX_REG_JOININ· 200
PEX_REG_LEAVE· 200
PEX_REG_REQUEST· 201
PIM messages· 201
PIM_MEM_ALERT· 201
PIM_NBR_DOWN· 202
PIM_NBR_UP· 202
PING messages· 202
PING_STATIS_INFO·· 203
PING_VPN_STATIS_INFO·· 203
PKI messages· 204
REQUEST_CERT_FAIL· 204
REQUEST_CERT_SUCCESS· 204
PKT2CPU messages· 204
PKT2CPU_NO_RESOURCE· 205
PORTSEC messages· 205
PORTSEC_ACL_FAILURE· 205
PORTSEC_LEARNED_MACADDR· 206
PORTSEC_NTK_NOT_EFFECTIVE· 206
PORTSEC_PORTMODE_NOT_EFFECTIVE· 207
PORTSEC_PROFILE_FAILURE· 207
PORTSEC_VIOLATION· 207
PPP messages· 208
IPPOOL_ADDRESS_EXHAUSTED· 208
PWDCTL messages· 208
ADDBLACKLIST· 208
CHANGEPASSWORD· 209
FAILEDTOWRITEPWD· 209
QoS messages· 209
QOS_CBWFQ_REMOVED· 210
QOS_POLICY_APPLYCOPP_CBFAIL· 210
QOS_POLICY_APPLYCOPP_FAIL· 211
QOS_POLICY_APPLYGLOBAL_CBFAIL· 211
QOS_POLICY_APPLYGLOBAL_FAIL· 212
QOS_POLICY_APPLYIF_CBFAIL· 212
QOS_POLICY_APPLYIF_FAIL· 213
QOS_POLICY_APPLYVLAN_CBFAIL· 213
QOS_POLICY_APPLYVLAN_FAIL· 214
QOS_NOT_ENOUGH_BANDWIDTH· 214
RADIUS messages· 214
RADIUS_AUTH_FAILURE· 215
RADIUS_AUTH_SUCCESS· 215
RADIUS_DELETE_HOST_FAIL· 215
RIP messages· 215
RIP_MEM_ALERT· 216
RIP_RT_LMT· 216
RIPNG messages· 216
RIPNG_MEM_ALERT· 216
RIPNG_RT_LMT· 217
RM messages· 217
RM_ACRT_REACH_LIMIT· 217
RM_ACRT_REACH_THRESVALUE· 218
RM_THRESHLD_VALUE_REACH· 218
RPR messages· 218
DRVDEBUGMOD_RPR· 219
DRVPLAT/4/DrvDebug· 219
DRVPLAT/4/DrvDebug· 220
DRVPLAT/4/DrvDebug· 221
DRVPLAT/4/DrvDebug· 222
DRVPLAT/4/DrvDebug· 223
DRVPLAT/4/DrvDebug· 224
DRVPLAT/4/DrvDebug· 225
DRVPLAT/4/DrvDebug· 226
DRVPLAT/4/DrvDebug· 227
DRVPLAT/4/DrvDebug· 228
RPR_LAGGCONFIG_INCONSITENT· 228
RPR_LAGGCONFIG_INCONSITENT_OVER· 228
SCM messages· 229
JOBINFO·· 229
RECV_DUPLICATEEVENT· 229
SERVICE_RESTART· 229
SERVICE_STATEERROR· 230
SERVICE_STATUSFAILED· 230
SET_WRONGSTATUS· 230
SCRLSP messages· 230
SCRLSP_LABEL_DUPLICATE· 231
SHELL messages· 231
SHELL_CMD· 231
SHELL_CMD_CONFIRM·· 232
SHELL_CMD_EXECUTEFAIL· 232
SHELL_CMD_INPUT· 233
SHELL_CMD_INPUT_TIMEOUT· 233
SHELL_CMD_MATCHFAIL· 234
SHELL_CMDDENY· 234
SHELL_CMDFAIL· 235
SHELL_CRITICAL_CMDFAIL· 235
SHELL_LOGIN· 235
SHELL_LOGOUT· 236
SLSP messages· 236
SLSP_LABEL_DUPLICATE· 236
SMLK messages· 236
SMLK_LINK_SWITCH· 237
SNMP messages· 237
SNMP_ACL_RESTRICTION· 237
SNMP_GET· 238
SNMP_NOTIFY· 238
SNMP_SET· 239
SNMP_USM_NOTINTIMEWINDOW·· 239
SNMP_AUTHENTICATION_FAILURE· 240
SPBM messages· 240
SPBM_LICENSE_EXPIRED· 240
SPBM_LICENSE_EXPIRED_TIME· 240
SPBM_LICENSE_UNAVAILABLE· 241
SSHS messages· 241
SSHS_ALGORITHM_MISMATCH· 241
SSHS_AUTH_EXCEED_RETRY_TIMES· 242
SSHS_AUTH_FAIL· 242
SSHS_AUTH_TIMEOUT· 243
SSHS_CONNECT· 243
SSHS_DECRYPT_FAIL· 243
SSHS_DISCONNECT· 244
SSHS_ENCRYPT_FAIL· 244
SSHS_LOG·· 244
SSHS_MAC_ERROR· 245
SSHS_REACH_SESSION_LIMIT· 245
SSHS_REACH_USER_LIMIT· 245
SSHS_SCP_OPER· 246
SSHS_SFTP_OPER· 246
SSHS_VERSION_MISMATCH· 247
STAMGR messages· 247
STAMGR_ADDBAC_INFO·· 247
STAMGR_ADDSTA_INFO·· 247
STAMGR_DELBAC_INFO·· 248
STAMGR_DELSTA_INFO·· 248
STAMGR_STAIPCHANGE_INFO·· 248
STM messages· 248
STM_AUTO_UPDATE· 249
STM_MEMBERID_CONFLICT· 249
STM_MERGE· 249
STM_MERGE_NEED_REBOOT· 250
STM_LINK_RECOVERY· 250
STM_LINK_STATUS_DOWN· 250
STM_LINK_STATUS_TIMEOUT· 251
STM_LINK_STATUS_UP· 251
STM_SOMER_CHECK· 251
SYSLOG messages· 251
SYSLOG_LOGFILE_FULL· 252
SYSLOG_RESTART· 252
TACACS messages· 252
TACACS_AUTH_FAILURE· 252
TACACS_AUTH_SUCCESS· 253
TACACS_DELETE_HOST_FAIL· 253
TELNETD messages· 253
TELNETD_REACH_SESSION_LIMIT· 253
TRILL messages· 254
TRILL_DUP_SYSTEMID· 254
TRILL_INTF_CAPABILITY· 254
TRILL_INTF ENTERED_SUSPENDED· 255
TRILL_INTF EXITED_SUSPENDED· 255
TRILL_LICENSE_UNAVAILABLE· 255
TRILL_LICENSE_EXPIRED· 256
TRILL_LICENSE_EXPIRED_TIME· 256
TRILL_MEM_ALERT· 256
TRILL_NBR_CHG·· 257
VLAN messages· 257
VLAN_FAILED· 257
VLAN_VLANMAPPING_FAILED· 258
VLAN_VLANTRANSPARENT_FAILED· 258
VRRP messages· 258
VRRP_AUTH_FAILED· 259
VRRP_CONFIG_ERROR· 259
VRRP_PACKET_ERROR· 260
VRRP_STATUS_CHANGE· 260
VRRP_VF_STATUS_CHANGE· 261
VRRP_VMAC_INEFFECTIVE· 261
Introduction
This document includes the following system messages:
·     Messages specific to Release 7178 of the device.
·     Messages for the Comware 7 software platform version based on which Release 7178 was produced. Some platform system messages might not be available on the device.
This document is intended only for managing S7500E-X switches. Do not use this document for any other device models.
This document assumes that the readers are familiar with data communications technologies and H3C networking products.
By default, the system log messages use one of the following formats depending on the output destination:
·     Log host:
<PRI>TIMESTAMP Sysname %%vendorMODULE/severity/MNEMONIC: location; CONTENT
·     Destinations except for the log host:
Prefix TIMESTAMP Sysname MODULE/severity/MNEMONIC: CONTENT
Table 1 System log message elements
Element
<PRI>
Priority identifier. It is calculated by using the following formula:
Priority identifier=facilityx8+severity
Where:
·     Facility is specified by using the info-center loghost command. A log host uses this parameter to identify log sources and filter log messages.
·     Severity represents the importance of the message. For more information about severity levels, see Table 2.
Prefix
Message type identifier. This element is contained in the system log messages sent to non-log host destinations.
The element uses the following symbols to indicate message severity:
·     Percentage sign (%)—Informational and higher levels.
·     Asterisk (*)—Debug level.
TIMESTAMP
Date and time when the event occurred.
The following are commands for configuring the timestamp format:
·     Log host—Use the info-center timestamp loghost command.
·     Non-log host destinations—Use the info-center timestamp command.
Sysname
Name or IP address of the device that generated the message.
%%vendor
Manufacturer flag. This element is %%10 for H3C.
This element is only available in messages sent to the log host.
MODULE
Name of the module that produced the message.
severity
Severity level of the message. (For more information about severity levels, see Table 2.)
MNEMONIC
Text string that uniquely identifies the system message. The maximum length is 32 characters.
location
Optional. This element presents location information for the message in the following format:
-attribute1=x-attribute2=y…-attributeN=z
This element is separated from the message description by using a semicolon (;).
CONTENT
Text string that contains detailed information about the event or error.
For variable fields in this element, this document uses the representations in Table 3.
System log messages are classified into eight severity levels from 0 to 7. The lower the number, the higher the severity.
Table 2 System log message severity levels
Level
Severity
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes or a storage card is unplugged.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debug
Debugging message.
For variable fields in the message text, this document uses the representations in Table 3. The values are case insensitive, even though the representations are uppercase letters.
Table 3 Variable field representations
Representation
Information type
INT16
Signed 16-bit decimal number.
UINT16
Unsigned 16-bit decimal number.
INT32
Signed 32-bit decimal number.
UINT32
Unsigned 32-bit decimal number.
INT64
Signed 64-bit decimal number.
UINT64
Unsigned 64-bit decimal number.
DOUBLE
Two dot-separated signed 32-bit decimal numbers. The format is [INTEGER].[INTEGER].
HEX
Hexadecimal number.
CHAR
Single character.
STRING
Character string.
IPADDR
IP address.
MAC
MAC address.
DATE
Date.
TIME
Time.
You can manage system log messages by using the information center.
By default, the information center is enabled. Log messages can be output to the console, log buffer, monitor terminal, log host, and log file.
To filter log messages, use the info-center source command to specify log output rules. A log output rule specifies the source modules and the lowest severity level of log messages that can be output to a destination. A log message is output if its severity level is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), log messages that have a severity level from 0 to 6 are output.
For more information about using the information center, see the network management and monitoring configuration guide for the product.
Access the device through the console port. Real-time log messages are displayed on the console terminal.
Use the display logbuffer command to display history log messages in the log buffer.
Monitor terminals refer to terminals that access the device through the AUX, VTY, or TTY lines (for example, Telnet). To obtain log messages from a monitor terminal, use the following guidelines:
·     To display log messages on the monitor terminal, you must configure the terminal monitor command.
·     For monitor terminals, the lowest level of log messages that can be displayed is determined by both the terminal logging level and info-center source commands.
By default, the log file feature automatically saves logs from the log file buffer to the log file every 24 hours. You can use the info-center logfile frequency command to change the automatic saving internal.
To manually save logs to the log file, use the logfile save command. The log file buffer is cleared each time a save operation is performed.
By default, you can obtain the log file from the cfa0:/logfile/ path if the CF card is not partitioned. If the CF card is partitioned, the file path is cfa1:/logfile/.
Use the info-center loghost command to specify the service port number and IP address of a log host. To specify multiple log hosts, repeat the command.
For a successful log message transmission, make sure the specified port number is the same as the port number used on the log host. The default service port number is 514.
Table 4 lists all software modules that might produce system log messages.
Table 4 Software module list
Module name representation
Module name expansion
AAA
Authentication, Authorization and Accounting
ACL
Access Control List
APMGR
Access Point Management
ARP
Address Resolution Protocol
BFD
Bidirectional Forwarding Detection
BGP
Border Gateway Protocol
CFD
Connectivity Fault Detection
CFGMAN
Configuration Management
DEV
Device Management
DIAG
Diagnosis
DLDP
Device Link Detection Protocol
DOT1X
Dot1x
DRVPLAT
Driver Platform
ETHOAM
Ethernet Operation, Administration and Maintenance
EVB
Edge Virtual Bridging
EVIISIS
Ethernet Virtual Interconnect Intermediate System-to-Intermediate System
FCOE
Fibre Channel Over Ethernet
FCLINK
Fibre Channel Link
FCZONE
Fibre Channel Zone
FIPS
FIP Snooping
FTP
File Transfer Protocol
HA
High Availability
HTTPD
Hypertext Transfer Protocol Daemon
IFNET
Interface Net Management
IKE
Internet Key Exchange
IPSEC
IP Security
IRDP
ICMP Router Discovery Protocol
ISIS
L2VPN
Layer 2 VPN
LAGG
Link Aggregation
LDP
Label Distribution Protocol
LICENSE
License
LLDP
Link Layer Discovery Protocol
LOAD
Load Management
LOGIN
Login
LPDT
Loopback Detection
LS
Local Server
LSPV
LSP Verification
MAC
Media Access Control
MBFD
MPLS BFD
MDC
Multitenant Device Context
MFIB
Multicast Forwarding Information Base
MGROUP
Mirroring group
MPLS
Multiprotocol Label Switching
MSTP
Multiple Spanning Tree Protocol
MTLK
Monitor Link
ND
Neighbor Discovery
NQA
Network Quality Analyzer
NTP
Network Time Protocol
OPTMOD
Optical Module
OSPF
Open Shortest Path First
OSPFV3
Open Shortest Path First Version 3
PBB
Provider Backbone Bridge
PBR
Policy-based Routing
PIM
Protocol Independent Multicast
PING
Packet Internet Groper
PKI
Public Key Infrastructure
PKT2CPU
Packet to CPU
PORTSEC
Port Security
PPP
Point to Point Protocol
PWDCTL
Password Control
QOS
Quality of Service
RADIUS
Remote Authentication Dial In User Service
RIP
Routing Information Protocol
RIPNG
Routing Information Protocol Next Generation
RM
Routing Management
RPR
Resilient Packet Ring
SCM
Service Control Manager
SCRLSP
Static CRLSP
SHELL
Shell
SLSP
Static LSP
SMLK
Smart Link
SNMP
Simple Network Management Protocol
SSHS
Secure Shell Server
STAMGR
Station Management
STM
Stack Topology Management (IRF)
SYSLOG
System Log
TACACS
Terminal Access Controller Access Control System
TELNETD
Telecom Munication Network Protocol Daemon
TRILL
Transparent Interconnect of Lots of Links
VLAN
Virtual Local Area Network
VRRP
Virtual Router Redundancy Protocol
Using this document
This document categorizes system log messages by software modules. The modules are ordered alphabetically. For each module, the system log messages are also listed in alphabetic order of their mnemonic names.
This document explains messages in tables. Table 5 describes information provided in these tables.
Table 5 Message explanation table contents
Item
Content
Example
Message text
Presents the message description.
ACL [UINT32] [STRING] [UINT64] packet(s).
Variable fields
Briefly describes the variable fields in the order that they appear in the message text.
The variable fields are numbered in the "$Number" form to help you identify their location in the message text.
$1: ACL number.
$2: ID and content of an ACL rule.
$3: Number of packets that matched the rule.
Severity level
Provides the severity level of the message.
6
Example
Provides a real message example. The examples do not include the "<PRI>TIMESTAMP Sysname %%vendor" part or the "Prefix TIMESTAMP Sysname" part, because information in this part varies with system settings.
ACL/6/ACL_STATIS_INFO: ACL 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s).
Explanation
Explains the message, including the event or error cause.
Number of packets that matched an ACL rule. This message is sent when the packet counter changes.
Recommended action
Provides recommended actions. For informational messages, no action is required.
No action is required.
AAA messages
This section contains AAA messages.
AAA_FAILURE
Message text
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA failed.
Variable fields
$1: AAA type.
$2: AAA scheme.
$3: Service.
$4: User name.
Severity level
5
Example
AAA/5/AAA_FAILURE: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is failed.
Explanation
An AAA request was rejected.
The following are the common reasons:
·     No response was received from the server.
·     The user name or password was incorrect.
·     The service type that the user applied for was incorrect.
Recommended action
1.     Verify that the device is correctly connected to the server.
2.     Enter the correct username and password.
3.     Verify that the server settings are the same as the settings on the device.
4.     If the problem persists, contact H3C Support.
AAA_LAUNCH
Message text
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA launched.
Variable fields
$1: AAA type.
$2: AAA scheme.
$3: Service.
$4: User name.
Severity level
6
Example
AAA/6/AAA_LAUNCH: -AAAType=AUTHEN-AAADomain=domain1-Service=login-UserName=cwf@system; AAA launched.
Explanation
An AAA request was received.
Recommended action
AAA_SUCCESS
Message text
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA is successful.
Variable fields
$1: AAA type.
$2: AAA scheme.
$3: Service.
$4: User name.
Severity level
6
Example
AAA/6/AAA_SUCCESS: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is successful.
Explanation
An AAA request was accepted.
Recommended action
ACL messages
This section contains ACL messages.
Message text
IPv6 ACL [UINT32] [STRING] [UINT64] packet(s).
Variable fields
$1: ACL number.
$2: ID and content of an IPv6 ACL rule.
Severity level
6
Example
ACL6/6/ACL_IPV6_STATIS_INFO: IPv6 ACL 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s).
Explanation
The number of packets matching the IPv6 ACL rule changed.
Recommended action
ACL_NO_MEM
Message text
Failed to configure [STRING] ACL [UINT] due to lack of memory.
Variable fields
$1: ACL version.
$2: ACL number.
Severity level
3
Example
ACL/3/ACL_NO_MEM: Failed to configure ACL 2001 due to lack of memory.
Explanation
Configuring the ACL failed because memory is insufficient.
Recommended action
Use the display memory-threshold command to check the memory usage.
ACL_STATIS_INFO
Message text
Variable fields
$1: ACL number.
$2: ID and content of an IPv4 ACL rule.
Severity level
6
Example
Explanation
The number of packets matching the IPv4 ACL rule changed.
Recommended action
Message text
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. The resources are insufficient.
Variable fields
$1: Traffic direction.
Severity level
3
Example
PFILTER/3/PFILTER_GLB_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction globally. The resources are insufficient.
Explanation
The system failed to perform one of the following actions because hardware resources were insufficient:
·     Applying the IPv4 default action to a specific direction globally.
·     Updating the IPv4 default action applied to a specific direction globally.
Recommended action
Use the display qos-acl resource command to check hardware resource usage.
Message text
Variable fields
Severity level
3
Example
PFILTER/3/PFILTER_GLB_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction globally.
Explanation
The system failed to perform one of the following actions due to an unknown error:
Recommended action
Message text
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. The resources are insufficient.
Variable fields
Severity level
3
Example
PFILTER/3/PFILTER_GLB_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction globally. The resources are insufficient.
Explanation
·     Applying the IPv6 default action to a specific direction globally.
·     Updating the IPv6 default action applied to a specific direction globally.
Recommended action
Message text
Variable fields
Severity level
3
Example
PFILTER/3/PFILTER_GLB_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction globally.
Explanation
The system failed to perform one of the following actions because of an unknown error:
Recommended action
Message text
Failed to apply or refresh the MAC default action to the [STRING] direction globally. The resources are insufficient.
Variable fields
Severity level
3
Example
PFILTER/3/PFILTER_GLB_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction globally. The resources are insufficient.
Explanation
·     Applying the MAC default action to a specific direction globally.
·     Updating the MAC default action applied to a specific direction globally.
Recommended action
Message text
Variable fields
Severity level
3
Example
PFILTER/3/PFILTER_GLB_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction globally.
Explanation
Recommended action
PFILTER_GLB_NO_RES
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The resources are insufficient.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$4: Traffic direction.
Severity level
3
Example
PFILTER/3/PFILTER_GLB_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The resources are insufficient.
Explanation
·     Applying an ACL rule to a specific direction globally.
·     Updating an ACL rule applied to a specific direction globally.
Recommended action
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The ACL is not supported.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
Severity level
3
Example
PFILTER/3/PFILTER_GLB_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The ACL is not supported.
Explanation
The system failed to perform one of the following actions because the ACL rule is not supported:
Recommended action
Verify the ACL configuration and remove the settings that are not supported.
PFILTER_GLB_UNK_ERR
Message text
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
Severity level
3
Example
PFILTER/3/PFILTER_GLB_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally.
Explanation
Recommended action
Message text
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. The resources are insufficient.
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient.
Explanation
·     Applying the IPv4 default action to a specific direction of an interface.
·     Updating the IPv4 default action applied to a specific direction of an interface.
Recommended action
Message text
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2.
Explanation
The system failed to perform one of the following actions because an unknown error:
Recommended action
Message text
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. The resources are insufficient.
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient.
Explanation
·     Applying the IPv6 default action to a specific direction of an interface.
·     Updating the IPv6 default action applied to a specific direction of an interface.
Recommended action
Message text
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2.
Explanation
Recommended action
Message text
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. The resources are insufficient.
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient.
Explanation
·     Applying the MAC default action to a specific direction of an interface.
·     Updating the MAC default action applied to a specific direction of an interface.
Recommended action
Message text
Variable fields
$2: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2.
Explanation
Recommended action
PFILTER_IF_NO_RES
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The resources are insufficient.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient.
Explanation
·     Applying an ACL rule to a specific direction of an interface.
·     Updating an ACL rule applied to a specific direction of an interface.
Recommended action
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The ACL is not supported.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The ACL is not supported.
Explanation
Recommended action
PFILTER_IF_UNK_ERR
Message text
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: Interface name.
Severity level
3
Example
PFILTER/3/PFILTER_IF_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2.
Explanation
Recommended action
Message text
[STRING] ([STRING]): Packet-filter IPv6 [UINT32] [STRING] [STRING] [UINT64] packet(s).
Variable fields
$1: Destination to which packet filter applies.
$2: Traffic direction.
$3: ACL number.
$4: ID and content of an ACL rule.
$5: Number of packets that matched the rule.
Severity level
6
Example
ACL/6/PFILTER_IPV6_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter IPv6 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s).
Explanation
The number of packets matching the packet-filter IPv6 ACL rule changed.
Recommended action
PFILTER_STATIS_INFO
Message text
[STRING] ([STRING]): Packet-filter [UINT32] [STRING] [UINT64] packet(s).
Variable fields
$3: ACL number.
Severity level
6
Example
ACL/6/PFILTER_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s).
Explanation
The number of packets matching the packet-filter IPv4 ACL rule changed.
Recommended action
Message text
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient.
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. The resources are insufficient.
Explanation
·     Applying the IPv4 default action to a specific direction of a VLAN.
·     Updating the IPv4 default action applied to a specific direction of a VLAN.
Recommended action
Message text
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1.
Explanation
Recommended action
Message text
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient.
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. The resources are insufficient.
Explanation
·     Applying the IPv6 default action to a specific direction of a VLAN.
·     Updating the IPv6 default action applied to a specific direction of a VLAN.
Recommended action
Message text
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1.
Explanation
Recommended action
Message text
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient.
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. The resources are insufficient.
Explanation
·     Applying the MAC default action to a specific direction of a VLAN.
·     Updating the MAC default action applied to a specific direction of a VLAN.
Recommended action
Message text
Variable fields
$2: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1.
Explanation
Recommended action
PFILTER_VLAN_NO_RES
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The resources are insufficient.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of VLAN 1. The resources are insufficient.
Explanation
·     Applying an ACL rule to a specific direction of a VLAN.
·     Updating an ACL rule applied to a specific direction of a VLAN.
Recommended action
Message text
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The ACL is not supported.
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_NOT_SUPPORT: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. The ACL is not supported.
Explanation
Recommended action
Message text
Variable fields
$1: ACL version.
$2: ACL number.
$3: ACL rule ID.
$5: VLAN ID.
Severity level
3
Example
PFILTER/3/PFILTER_VLAN_UNK_ERR: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1.
Explanation
Recommended action
APMGR messages
This section contains access point management messages.
APMGR_ADDBAC_INFO
Message text
Add BAS AC [STRING].
Variable fields
$1: MAC address of the BAS AC.
Severity level
6
Example
APMGR/6/APMGR_ADDBAC_INFO:
Add BAS AC 3ce5-a616-28cd.
Explanation
The BAS AC was connected to the master AC.
Recommended action
APMGR_DELBAC_INFO
Message text
Delete BAS AC [STRING].
Variable fields
Severity level
6
Example
APMGR/6/APMGR_DELBAC_INFO:
Delete BAS AC 3ce5-a616-28cd.
Explanation
The BAS AC was disconnected from the master AC.
Recommended action
ARP messages
This section contains ARP messages.
Message text
No ARP reply from IP [STRING] was received on interface [STRING]
Variable fields
$1: IP address.
$2: Interface name.
Severity level
6
Example
ARP/6/ARP_ACTIVE_ACK_NO_REPLY: No ARP reply from IP 192.168.10.1 was received on interface Ethernet0/1/0.
Explanation
An attack was detected by ARP active acknowledgement.
An interface sent an ARP request to the sender IP of a received ARP message, but did not receive an ARP reply.
Recommended action
Verify that the host that sends the ARP message is legitimate.
Message text
 Interface [STRING] received from IP [STRING] an ARP reply that was not requested by the device.
Variable fields
$1: Interface name.
$2: IP address.
Severity level
6
Example
ARP/6/ARP_ACTIVE_ACK_NOREQUESTED_REPLY: Interface Ethernet0/1/0 received from IP 192.168.10.1 an ARP reply that was not requested by the device.
Explanation
The ARP active acknowledgement feature received an unsolicited ARP reply from a sender IP.
This message indicates the risk of attacks.
Recommended action
No action is required. The device discards the ARP reply automatically.
ARP_RATE_EXCEEDED
Message text
The ARP packet rate ([UINT32] pps) exceeded the rate limit ([UINT32] pps) on interface [STRING] in the last [UINT32] seconds
Variable fields
$1: ARP packet rate.
$2: ARP limit rate.
$3: Interface name.
$4: Interval time.
Severity level
4
Example
ARP/4/ARP_RATE_EXCEEDED: The ARP packet rate (100 pps) exceeded the rate limit (80 pps) on interface Ethernet0/1/0 in the last 10 seconds.
Explanation
An interface received ARP messages at a higher rate than the rate limit.
Recommended action
Verify that the host that sends the ARP packets is legitimate.
Message text
Sender IP [STRING] was not on the same network as the receiving interface [STRING]
Variable fields
$1: IP address.
$2: Interface name.
Severity level
6
Example
ARP/6/ARP_SENDER_IP_INVALID: Sender IP 192.168.10.2 was not on the same network as the receiving interface Ethernet0/1/0.
Explanation
The sender IP of a received ARP message was not on the same network as the receiving interface.
Recommended action
Verify that the host with the sender IP address is legitimate.
Message text
Sender MAC [STRING] was not identical to Ethernet source MAC [STRING] on interface [STRING]
Variable fields
$1: MAC address.
$2: MAC address.
$3: Interface name.
Severity level
6
Example
ARP/6/ARP_SENDER_MAC_INVALID: Sender MAC 0000-5E14-0E00 was not identical to Ethernet source MAC 0000-5C14-0E00 on interface Ethernet0/1/0.
Explanation
An interface received an ARP message. The sender MAC address in the message body was not identical to the source MAC address in the Ethernet header.
Recommended action
Verify that the host with the sender MAC address is legitimate.
Message text
An attack from MAC [STRING] was detected on interface [STRING]
Variable fields
$1: MAC address.
$2: Interface name.
Severity level
6
Example
ARP/6/ARP_SRC_MAC_FOUND_ATTACK: An attack from MAC 0000-5E14-0E00 was detected on interface Ethernet0/1/0.
Explanation
An attack was detected by source MAC-based ARP attack detection.
The number of ARP packets that the device received from the same MAC address within 5 seconds exceeded the specified threshold.
Recommended action
Verify that the host with the source MAC address is legitimate.
Message text
Target IP [STRING] was not the IP of the receiving interface [STRING]
Variable fields
$1: IP address.
$2: Interface name.
Severity level
6
Example
ARP/6/ARP_TARGET_IP_INVALID: Target IP 192.168.10.2 was not the IP of the receiving interface Ethernet0/1/0.
Explanation
The target IP address of a received ARP message was not the IP address of the receiving interface.
Recommended action
Verify that the host that sends this ARP message is legitimate.
DUPIFIP
Message text
Duplicate address [STRING] on interface [STRING], sourced from [STRING]
Variable fields
$1: IP address.
$2: Interface name.
$3: MAC Address.
Severity level
6
Example
ARP/6/DUPIFIP: Duplicate address 1.1.1.1 on interface Ethernet1/1/1, sourced from 0015-E944-A947
Explanation
A duplicate address was detected by ARP.
The sender IP in a received ARP packet was being used by the receiving interface.
Recommended action
Modify the IP address configuration.
DUPIP
Message text
IP address [STRING] conflicts with global or imported IP address, sourced from [STRING]
Variable fields
$1: IP address.
$2: MAC Address.
Severity level
6
Example
ARP/6/DUPIP: IP address 30.1.1.1 conflicts with global or import IP address, sourced from 0000-0000-0001
Explanation
The sender IP address of the received ARP packet conflicted with the global or imported IP address.
Recommended action
DUPVRRPIP
Message text
IP address [STRING] collision with VRRP virtual IP address on interface [STRING], sourced from [STRING]
Variable fields
$1: IP address.
$2: Interface name.
$3: MAC address.
Severity level
6
Example
ARP/6/DUPVRRPIP: IP address 1.1.1.1 conflicts with VRRP virtual IP address on interface Ethernet1/1/1, sourced from 0015-E944-A947
Explanation
The sender IP address of the received ARP packet conflicted with the VRRP virtual IP address.
Recommended action
BFD messages
This section contains BFD messages.
BFD_CHANGE_FSM
Message text
Sess[STRING], Sta: [STRING]->[STRING], Diag: [UINT32]
Variable fields
$1: Source address, destination address, interface, and message type of the BFD session.
$2: Name of FSM before changing.
$3: Name of FSM after changing.
$4: Diagnostic code.
Severity level
5
Example
BFD/5/BFD_CHANGE_FSM:Sess[20.0.4.2/20.0.4.1,LD/RD:533/532, Interface:Vlan204, SessType:Ctrl, LinkType:INET], Sta: INIT->UP, Diag: 0.
Explanation
The FSM of the BFD session has been changed. This informational message appears when a BFD session comes up or goes down. Unexpected session loss might indicate high error or packet loss rates in the network.
Recommended action
Check for incorrect BFD configuration or network congestion.
Message text
The total number of BFD sessions [ULONG] reached the upper limit. Please avoid creating a new session.
Variable fields
$1: Total number of BFD sessions.
Severity level
5
Example
BFD/5/ BFD_REACHED_UPPER_LIMIT: The total number of BFD sessions 1024 reached the upper limit. Please avoid creating a new session.
Explanation
The total number of BFD sessions has reached the upper limit.
Recommended action
Check the BFD configuration and make sure the total number of BFD sessions does not reach the upper limit.
BGP messages
This section contains BGP messages.
Message text
The number of routes from peer [STRING] in exceeded the limit [UINT32].
Variable fields
$1: BGP peer IP address.
$2: Maximum number of routes.
Severity level
4
Example
BGP/4/BGP_EXCEEDED_ROUTE_LIMIT: The number of routes from peer 1.1.1.1 in exceeded the limit 100.
Explanation
The number of routes received from a peer exceeded the maximum number of routes that can be received from the peer.
Recommended action
Check whether you need to increase the maximum number of routes.
Message text
Threshold value [UINT32] reached for prefixes received from peer  [STRING].
Variable fields
$1: Percentage of received routes to the maximum number of routes.
$2: Peer IP address.
Severity level
5
Example
BGP/5/BGP_RECHED_THRESHOLD: Threshold value 20 reached for prefixes received from peer  1.1.1.1.
Explanation
The number of received routes reached the threshold.
Recommended action
Check whether you need to increase the threshold value or the maximum number of routes that can be received from the peer.
BGP_MEM_ALERT
Message text
BGP Process receive system memory alert  [STRING] event.
Variable fields
$1: Type of the memory alarm.
Severity level
5
Example
BGP/5/BGP_MEM_ALERT: BGP Process receive system memory alert start event.
Explanation
BGP received a memory alarm.
Recommended action
Check the system memory.
BGP_STATE_CHANGED
Message text
[STRING] state is changed from [STRING] to [STRING].
BGP. [STRING]: [STRING] State is changed from [STRING]to [STRING].
Variable fields
$1: VPN instance name.
$3: Name of FSM before a state change.
$4: Name of FSM after a state change.
Severity level
5
Example
BGP/5/BGP_STATE_CHANGED: BGP.vpn1:192.99.0.2 state is changed from ESTABLISHED to IDLE.
Explanation
The FSM of a BGP peer changed.
This message is generated when a BGP peer comes up or goes down.
Recommended action
If a peer goes down unexpectedly, check for network failure or packet loss.
CFD messages
This section contains CFD messages.
CFD_CROSS_CCM
Message text
MEP [UINT16] in SI [INT32] received a cross-connect CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING].
Variable fields
$1: Service instance ID.
$2: Local MEP ID.
$3: Source MAC address.
$4: Sequence number.
$5: Remote MEP ID.
$6: MD ID. If no MD ID is available, "without ID" is displayed.
$7: MA ID.
Severity level
6
Example
CFD/6/CFD_CROSS_CCM: MEP 13 in SI 10 received a cross-connect CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 78, RMEP is 12, MD ID is without ID, MA ID is 0.
Explanation
A MEP received a cross-connect CCM containing a different MA ID or MD ID.
Recommended action
Check the configurations of MEPs at both ends. Make sure the MEPs have the same configurations, including MD, MA, and level.
CFD_ERROR_CCM
Message text
MEP [UINT16] in SI [INT32] received an error CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING].
Variable fields
$2: Local MEP ID.
$5: Remote MEP ID.
$7: MA ID.
Severity level
6
Example
CFD/6/CFD_ERROR_CCM: MEP 2 in SI 7 received an error CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 21, RMEP is 2, MD ID is 7, MA ID is 1.
Explanation
A MEP received an error CCM containing an unexpected MEP ID or lifetime.
Recommended action
Check the CCM configuration. Make sure the CCM intervals are the same at both ends, and the remote MEP ID is included in the MEP list of the local end.
CFD_LOST_CCM
Message text
MEP [UINT16] in SI [INT32] failed to receive CCMs from RMEP [UINT16].
Variable fields
$1: Local MEP ID.
$2: Service instance ID.
$3: Remote MEP ID.
Severity level
6
Example
CFD/6/CFD_LOST_CCM: MEP 1 in SI 7 received CCMs from RMEP 2.
Explanation
A MEP failed to receive CCMs within 3.5 sending intervals because the link was faulty or the remote MEP did not send CCM within 3.5 sending intervals.
Recommended action
1.     Check the link status for a faulty state (for example, the down or unidirectional state), and then recover the link.
2.     Check the configuration of the remote MEP. If the remote MEP is configured with the same service instance, make sure the CCM sending intervals are the same at both ends.
3.     If the problem persists, contact H3C Support.
CFD_RECEIVE_CCM
Message text
MEP [UINT16] in SI [INT32] received CCMs from RMEP [UINT16]
Variable fields
$1: Local MEP ID.
$3: Remote MEP ID.
Severity level
6
Example
CFD/6/CFD_RECEIVE_CCM: MEP 1 in SI 7 received CCMs from RMEP 2.
Explanation
A MEP received CCMs from a remote MEP.
Recommended action
CFGMAN messages
This section contains configuration management messages.
CFGMAN_CFGCHANGED
Message text
-EventIndex=[INT32]-CommandSource=[INT32]-ConfigSource=[INT32]-ConfigDestination=[INT32]; Configuration is changed.
Variable fields
$1: Event index in the range of 1 to 2147483647.
$2: Specify the source command which brought the log, in the range of 1 to 3.
$3: Source of the configuration data event, in the range of 1 to 7.
$4: Destination for the configuration data event, in the range of 1 to 7.
Severity level
5
Example
CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[6]-Comman
dSource=[2]-ConfigSource=[4]-ConfigDestination=[2]; Configuration is changed.
Explanation
The device recorded the logtale index, cmdsource, configsource, and configdestination for the running configuration that changed in the past 10 minutes.
Recommended action
Message text
-OperateType=[INT32]-OperateTime=[INT32]-OperateState=[INT32]-OperateEndTime=[INT32]; Operation is completed.
Variable fields
$1: Operation type in the range of 1 to 6.
$2: Operation time.
$3: Operation state in the range of 1 to 20.
$4: Operation end time.
Severity level
5
Example
CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=[1]-OperateTime=[248]-OperateState=[2]-OperateEndTime=[959983]; Operation is completed.
Explanation
The device recorded the type, state, start time, and end time of an operation.
Recommended action
DEV messages
This section contains device management messages.
BOARD_REBOOT
Message text
Board is rebooting on Chassis [INT32] Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
5
Example
DEV/5/BOARD_REBOOT: Board is rebooting on Chassis 1 Slot 5.
Explanation
A card was manually or automatically rebooted.
Recommended action
If an unexpected automatic reboot occurred, perform the following tasks:
4.     Execute the display version command after the card starts up.
5.     Check the Last reboot reason field for the reboot reason.
6.     If an exception caused the reboot, contact H3C Support.
BOARD_REMOVED
Message text
Board is removed from Chassis [INT32] Slot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type.
Severity level
3
Example
DEV/3/BOARD_REMOVED: Board is removed from Chassis 1 Slot 5, type is LSQ1FV48SA.
Explanation
An LPU or standby MPU was removed.
Recommended action
If the LPU or MPU was not manually removed, perform the following tasks:
7.     Verify that the card is securely seated.
8.     Replace the card if the message persists.
9.     If the problem persists, contact H3C Support.
BOARD_STATE_FAULT
Message text
Board state changes to FAULT on Chassis [INT32] Slot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type.
Severity level
2
Example
DEV/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 1 Slot 5, type is LSQ1FV48SA.
Explanation
The card was starting up (initializing or loading software) or was not operating correctly.
Recommended action
·     If the card was newly installed, wait for the card to start up. The required startup time varies by card model and software version and is typically less than 10 minutes.
·     If the card was not newly installed, contact H3C Support.
BOARD_STATE_NORMAL
Message text
Board state changes to NORMAL on Chassis [INT32] Slot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type.
Severity level
5
Example
DEV/5/BOARD_STATE_NORMAL: Board state changes to NORMAL on Chassis 1 Slot 5, type is LSQ1FV48SA.
Explanation
A newly installed LPU or standby MPU completed initialization.
Recommended action
CFCARD_INSERTED
Message text
Compact Flash Card is inserted in Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Flash slot ID.
Severity level
4
Example
DEV/4/CFCARD_INSERTED: Compact Flash Card is inserted in Chassis 1 Slot 5 Compact Flash Slot 1.
Explanation
A CF card was installed.
Recommended action
CFCARD_REMOVED
Message text
Compact Flash Card is removed from Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Flash slot ID.
Severity level
3
Example
DEV/3/CFCARD_REMOVED: Compact Flash Card is removed from Chassis 1 Slot 5 Compact Flash Slot 1.
Explanation
A CF card was removed.
Recommended action
If the CF card was not manually removed, perform the following tasks:
10.     Verify that the card is securely seated.
11.     Replace the card if the message persists.
12.     If the problem persists, contact H3C Support.
CHASSIS_REBOOT
Message text
Chassis [INT32] is rebooting now.
Variable fields
$1: Chassis ID.
Severity level
5
Example
DEV/5/CHASSIS_REBOOT: Chassis 1 is rebooting now.
Explanation
The chassis was manually or automatically rebooted.
Recommended action
If an unexpected automatic reboot occurs, perform the following tasks:
13.     Execute the display version command after the chassis starts up.
14.     Check the Last reboot reason field for the reboot reason.
15.     If an exception caused the reboot, contact H3C Support.
DEV_CLOCK_CHANGE
Message text
-User=[STRING]-IPAddr=[IPADDR]; System clock changed from [STRING] to [STRING].
Variable fields
$1: Username of the login user.
$2: IP address of the login user.
$3: Old time.
$4: New time.
Severity level
5
Example
DEV/5/DEV_CLOCK_CHANGE: -User=[STRING]-IPAddr=[IPADDR]; System clock changed from 15:49:52 11/02/2011 to 15:50:00 11/02/2011.
Explanation
The system time changed.
Recommended action
FAN_ABSENT
Message text
Chassis [INT32] Fan [INT32] is absent.
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
Severity level
3
Example
DEV/3/FAN_ABSENT: Chassis 1 Fan 2 is absent.
Explanation
A fan tray was not in place.
Recommended action
1.     Check the fan tray slot:
?     If the fan tray slot is empty, install a fan tray.
?     If a fan tray is present, verify that the fan tray is securely seated.
2.     Replace the fan tray if the message persists.
FAN_ABSENT
Message text
Variable fields
$1: Fan tray ID.
Severity level
3
Example
DEV/3/FAN_ABSENT: Fan 2 is absent.
Explanation
Recommended action
Message text
Fan [INT32] airflow direction is not preferred on slot [INT32], please check it.
Variable fields
$1: Fan tray ID.
$2: Slot ID.
Severity level
1
Example
DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 3, please check it.
Explanation
The airflow direction of the fan tray is different from the airflow direction setting.
Recommended action
1.     Verify that the airflow direction setting is correct.
2.     Verify that the fan tray model provides the same airflow direction as the configured setting.
FAN_FAILED
Message text
Chassis [INT32] Fan [INT32] failed.
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
Severity level
2
Example
DEV/2/FAN_FAILED: Chassis 1 Fan 2 failed.
Explanation
The fan tray stopped because of an exception.
Recommended action
Replace the fan tray.
FAN_FAILED
Message text
Fan [INT32] failed.
Variable fields
$1: Fan tray ID.
Severity level
2
Example
DEV/2/FAN_FAILED: Fan 2 failed.
Explanation
Recommended action
FAN_RECOVERED
Message text
Chassis [INT32] Fan [INT32] recovered.
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
Severity level
5
Example
DEV/5/FAN_RECOVERED: Chassis 1 Fan 2 recovered.
Explanation
The fan tray started to operate correctly after it was installed.
Recommended action
FAN_RECOVERED
Message text
Variable fields
$1: Fan tray ID.
Severity level
5
Example
DEV/5/FAN_RECOVERED: Fan 2 recovered.
Explanation
Recommended action
POWER_ABSENT
Message text
Power [INT32] is absent.
Variable fields
$1: Power supply ID.
Severity level
3
Example
DEV/3/POWER_ABSENT: Power 1 is absent.
Explanation
A power supply was removed.
Recommended action
1.     Check the power supply slot.
?     If the power supply slot is empty, install a power supply.
?     If a power supply is present, verify that the power supply is securely seated.
2.     If the problem persists, replace the power supply.
POWER_ABSENT
Message text
Chassis [INT32] Power [INT32] is absent.
Variable fields
$1: Chassis ID.
$2: Power supply ID.
Severity level
3
Example
DEV/3/POWER_ABSENT: Chassis 1 Power 1 is absent.
Explanation
Recommended action
POWER_FAILED
Message text
Power [INT32] failed.
Variable fields
Severity level
2
Example
DEV/2/POWER_FAILED: Power 1 failed.
Explanation
A power supply failed.
Recommended action
Replace the power supply.
POWER_FAILED
Message text
Chassis [INT32] Power [INT32] failed.
Variable fields
$1: Chassis ID.
Severity level
2
Example
DEV/2/POWER_FAILED: Chassis 1 Power 1 failed.
Explanation
Recommended action
Message text
Power monitor unit [INT32] is absent.
Variable fields
$1: Power monitoring module ID.
Severity level
3
Example
DEV/3/POWER_MONITOR_ABSENT: Power monitor unit 1 is absent.
Explanation
A power monitoring module was removed.
Recommended action
1.     Check the power monitoring module slot.
?     If the power monitoring module slot is empty, install a power monitoring module.
?     If a power monitoring module is present, verify that the power monitoring module is securely seated.
2.     If the problem persists, replace the power monitoring module.
Message text
Chassis [INT32] Power monitor unit [INT32] is absent.
Variable fields
$1: Chassis ID.
$2: Power monitoring module ID.
Severity level
3
Example
DEV/3/POWER_MONITOR_ABSENT: Chassis 2 Power monitor unit 1 is absent.
Explanation
Recommended action
Message text
Power monitor unit [INT32] failed.
Variable fields
Severity level
2
Example
DEV/2/POWER_MONITOR_FAILED: Power monitor unit 1 failed.
Explanation
A power monitoring module failed.
Recommended action
Replace the power monitoring module.
Message text
Chassis [INT32] Power monitor unit [INT32] failed.
Variable fields
$1: Chassis ID.
Severity level
2
Example
DEV/2/POWER_MONITOR_FAILED: Chassis 2 Power monitor unit 1 failed.
Explanation
Recommended action
Message text
Power monitor unit [INT32] recovered.
Variable fields
Severity level
5
Example
DEV/5/POWER_MONITOR_RECOVERED: Power monitor unit 1 recovered.
Explanation
The power monitoring module started to operate correctly after it was installed.
Recommended action
Message text
Chassis [INT32]  Power monitor unit [INT32] recovered.
Variable fields
$1: Chassis ID.
Severity level
5
Example
DEV/5/POWER_MONITOR_RECOVERED: Chassis 2 Power monitor unit 1 recovered.
Explanation
Recommended action
POWER_RECOVERED
Message text
Power [INT32] recovered.
Variable fields
Severity level
5
Example
DEV/5/POWER_RECOVERED: Power 1 recovered.
Explanation
The power supply started to operate correctly after it was installed.
Recommended action
POWER_RECOVERED
Message text
Chassis [INT32] Power [INT32] recovered.
Variable fields
$1: Chassis ID.
Severity level
5
Example
DEV/5/POWER_RECOVERED: Chassis 1 Power 1 recovered.
Explanation
Recommended action
RPS_ABSENT
Message text
RPS [INT32] is absent.
Variable fields
$1: RPS ID.
Severity level
3
Example
DEV/3/RPS_ABSENT: RPS 1 is absent.
Explanation
An RPS was removed.
Recommended action
1.     Check the RPS slot.
?     If the RPS slot is empty, install a RPS.
?     If an RPS is present, verify that the RPS is securely seated.
2.     If the problem persists, replace the RPS.
RPS_ABSENT
Message text
Chassis [INT32] RPS [INT32] is absent.
Variable fields
$1: Chassis ID.
$2: RPS ID.
Severity level
3
Example
DEV/3/RPS_ABSENT: Chassis 1 RPS 1 is absent.
Explanation
An RPS was removed.
Recommended action
RPS_NORMAL
Message text
RPS [INT32] is normal.
Variable fields
$1: RPS ID.
Severity level
5
Example
DEV/5/RPS_NORMAL: RPS 1 is normal.
Explanation
The RPS started to operate correctly after it was installed.
Recommended action
RPS_NORMAL
Message text
Chassis [INT32] RPS [INT32] is normal.
Variable fields
$1: Chassis ID.
$2: RPS ID.
Severity level
5
Example
DEV/5/RPS_NORMAL: Chassis 1 RPS 1 is normal.
Explanation
Recommended action
SUBCARD_FAULT
Message text
SubCard state changes to FAULT on Chassis [INT32] slot [INT32] SubSlot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Subslot ID.
$4: Subcard type.
Severity level
2
Example
DEV/2/SUBCARD_FAULT: SubCard state changes to FAULT on Chassis 1 slot 5 SubSlot 1, type is MIM-1ATM-OC3SML.
Explanation
The subcard failed, or its status changed to Fault after it was rebooted.
Recommended action
Track the status of the subcard.
·     If the status of the subcard changes to Normal later, no action is required.
·     If the status is always Fault, replace the subcard.
SUBCARD_INSERTED
Message text
SubCard is inserted in Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Subslot ID.
$4: Subcard type.
Severity level
4
Example
DEV/4/SUBCARD_INSERTED: SubCard is inserted in Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML.
Explanation
A subcard was installed.
Recommended action
SUBCARD_REBOOT
Message text
SubCard is rebooting on Chassis [INT32] Slot [INT32] SubSlot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Subslot ID.
Severity level
5
Example
DEV/5/SUBCARD_REBOOT: SubCard is rebooting on Chassis 1 Slot 5 SubSlot 1.
Explanation
The subcard was manually or automatically rebooted.
Recommended action
·     If the subcard operates correct after it starts up, no action is required.
·     If you want to know the reboot reason or the subcard keeps rebooting, contact H3C Support.
SUBCARD_REMOVED
Message text
SubCard is removed from Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Subslot ID.
$4: Subcard type.
Severity level
3
Example
DEV/3/SUBCARD_REMOVED: SubCard is removed from Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML.
Explanation
A subcard was removed.
Recommended action
If the subcard was not manually removed, perform the following tasks:
4.     Verify that the subcard is securely seated.
5.     Replace the subcard if the message persists.
6.     If the problem persists, contact H3C Support.
SYSTEM_REBOOT
Message text
System is rebooting now.
Variable fields
N/A
Severity level
5
Example
DEV/5/SYSTEM_REBOOT: System is rebooting now.
Explanation
The system was manually or automatically rebooted.
Recommended action
7.     Execute the display version command after the system starts up.
8.     Check the Last reboot reason field for the reboot reason.
9.     If an exception caused the reboot, contact H3C Support.
TEMPERATURE_ALARM
Message text
Temperature is greater than alarm upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Sensor type.
$4: Sensor ID.
Severity level
4
Example
DEV/4/TEMPERATURE_ALARM: Temperature is greater than alarm upper limit on Chassis 1 slot 5 sensor inflow 1.
Explanation
A sensor's temperature exceeded the high-temperature alarming threshold. The ambient temperature was too high or the fan tray was not operating correctly.
Recommended action
1.     Verify that the ambient temperature is normal and the ventilation system is operating correctly.
2.     Use the display fan command to verify that the fan trays are in position and operating correctly. If a fan tray is missing, install the fan tray. If a fan tray does not operate correctly, replace it.
TEMPERATURE_LOW
Message text
Temperature is less than lower limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Sensor type.
$4: Sensor ID.
Severity level
4
Example
DEV/4/TEMPERATURE_LOW: Temperature is less than lower limit on Chassis 1 slot 5 sensor inflow 1.
Explanation
A sensor's temperature fell below the low-temperature threshold.
Recommended action
Adjust the ambient temperature higher.
TEMPERATURE_NORMAL
Message text
Temperature changes to normal on Chassis [INT32] slot [INT32] sensor [STRING] [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Sensor type.
$4: Sensor ID.
Severity level
5
Example
DEV/5/TEMPERATURE_NORMAL: Temperature changes to normal on Chassis 1 slot 5 sensor inflow 1.
Explanation
A sensor's temperature is normal (between the low-temperature threshold and the high-temperature warning threshold).
Recommended action
TEMPERATURE_SHUTDOWN
Message text
Temperature is greater than shutdown upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32] the slot will be powered off automatically.
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Sensor type.
$4: Sensor ID.
Severity level
2
Example
DEV/2/TEMPERATURE_SHUTDOWN: Temperature is greater than shutdown upper limit on Chassis 1 slot 5 sensor inflow 1 the slot will be powered off automatically.
Explanation
A sensor's temperature exceeded the high-temperature shutdown threshold. The ambient temperature was too high or the fan tray was not operating correctly.
Recommended action
TEMPERATURE_WARNING
Message text
Temperature is greater than warning upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Sensor type.
$4: Sensor ID.
Severity level
4
Example
DEV/4/TEMPERATURE_WARNING: Temperature is greater than warning upper limit on Chassis 1 slot 2 sensor inflow 1.
Explanation
A sensor's temperature exceeded the high-temperature warning threshold. The ambient temperature was too high or the fan tray was not operating correctly.
Recommended action
DIAG messages
This section contains diagnostic messages.
MEM_BELOW_THRESHOLD
Message text
Memory usage has dropped below [STRING] threshold.
Variable fields
$1: Memory usage threshold name: minor, severe, or critical.
Severity level
1
Example
DIAG/1/MEM_BELOW_THRESHOLD: Memory usage has dropped below critical threshold.
Explanation
A memory alarm was removed.
Recommended action
MEM_EXCEED_THRESHOLD
Message text
Memory [STRING] threshold has been exceeded.
Variable fields
Severity level
1
Example
DIAG/1/MEM_EXCEED_THRESHOLD: Memory minor threshold has been exceeded.
Explanation
The amount of used memory space exceeded a threshold.
Recommended action
All service modules are notified of the alarm and perform auto repair, such as releasing memory and stopping requesting memory.
Users can perform the following operations:
3.     Verify that the device is not under attack by checking the ARP table and routing table.
4.     Check and optimize the networking to reduce the number of routes.
5.     Replace the device with a device that has a better performance.
DLDP messages
This section contains DLDP messages.
DLDP_AUTHENTICATION_FAILED
Message text
The DLDP packet failed the authentication because of unmatched [STRING] field.
Variable fields
$1: Authentication field.
?     AUTHENTICATION PASSWORD—Authentication password mismatch.
?     AUTHENTICATION TYPE—Authentication type mismatch.
?     INTERVAL—Advertisement interval mismatch.
Severity level
5
Example
DLDP/5/DLDP_AUTHENTICATION_FAILED: The DLDP packet failed the authentication because of unmatched INTERVAL field.
Explanation
The packet authentication failed.
Possible reasons:
·     Unmatched authentication type.
·     Unmatched authentication password.
·     Unmatched advertisement interval.
Recommended action
Verify that the two ends use the same DLDP authentication type, authentication password, and advertisement interval.
DLDP_LINK_BIDIRECTIONAL
Message text
DLDP detected a bidirectional link on interface [STRING].
Variable fields
$1: Interface name.
Severity level
6
Example
DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ethernet1/1.
Explanation
DLDP detected a bidirectional link on an interface.
Recommended action
DLDP_LINK_UNIDIRECTIONAL
Message text
DLDP detected a unidirectional link on interface [STRING]. [STRING].
Variable fields
$1: Interface name.
$2: Action according to the port shutdown mode:
?     DLDP automatically blocked the interface.
?     Please manually shut down the interface.
Severity level
3
Example
DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ethernet1/1. DLDP automatically blocked the interface.
Explanation
DLDP detected a unidirectional link on an interface.
Recommended action
Check for connectivity issues, including incorrect cable connection and cable falloff.
DLDP_NEIGHBOR_AGED
Message text
A neighbor on interface [STRING] was deleted because the neighbor was aged. The neighbor's system MAC is [MAC], and the port index is [UINT16].
Variable fields
$1: Interface name.
$2: MAC address.
$3: Port index.
Severity level
5
Example
DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface Ethernet1/1 was deleted because the neighbor was aged. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1.
Explanation
The interface deleted an aged neighbor.
Recommended action
DLDP_NEIGHBOR_CONFIRMED
Message text
A neighbor was confirmed on interface [STRING]. The neighbor's system MAC is [MAC], and the port index is [UINT16].
Variable fields
$1: Interface name.
$2: MAC address.
$3: Port index.
Severity level
6
Example
DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ethernet1/1. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1.
Explanation
The interface detected a confirmed neighbor.
Recommended action
DLDP_NEIGHBOR_DELETED
Message text
A neighbor on interface [STRING] was deleted because a [STRING] packet arrived. The neighbor's system MAC is [MAC], and the port index is [UINT16].
Variable fields
$1: Interface name.
$2: Packet type, DISABLE or LINKDOWN.
$3: MAC address.
$4: Port index.
Severity level
5
Example
DLDP/5/DLDP_NEIGHBOR_DELETED: A neighbor on interface Ethernet1/1 was deleted because a DISABLE packet arrived. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1.
Explanation
The interface deleted a confirmed neighbor because it received a DISABLE or LINKDOWN packet.
Recommended action
DOT1X messages
This section contains 802.1X messages.
DOT1X_NOTENOUGH_EADFREEIP_RES
Message text
Failed to assign a rule for free IP [IPADDR] on interface [STRING] due to lack of ACL resources.
Variable fields
$1: Free IP.
$2: Interface type and number.
Severity level
3
Example
DOT1X/3/DOT1X_NOTENOUGH_EADFREEIP_RES: Failed to assign a rule for free IP 1.1.1.0 on interface Ethernet3/1/2 due to lack of ACL resources.
Explanation
The device failed to assign an ACL rule to permit a free IP on an interface because of ACL resource shortage.
Recommended action
Disable 802.1X on the interface, and then re-enable 802.1X.
DOT1X_NOTENOUGH_EADFREERULE_RES
Message text
Failed to assign a rule for permitting DHCP and DNS packets on interface [STRING] due to lack of ACL resources.
Variable fields
$1: Interface type and number.
Severity level
3
Example
DOT1X/3/DOT1X_NOTENOUGH_EADFREERULE_RES: Failed to assign a rule for permitting DHCP and DNS packets on interface Ethernet3/1/2 due to lack of ACL resources.
Explanation
The device failed to assign an ACL rule to permit DHCP and DNS packets on an interface because of ACL resource shortage.
Recommended action
DOT1X_NOTENOUGH_EADPORTREDIR_RES
Message text
Failed to assign a rule for redirecting HTTP packets on interface [STRING] due to lack of ACL resources.
Variable fields
Severity level
3
Example
DOT1X/3/DOT1X_NOTENOUGH_EADPORTREDIR_RES: Failed to assign a rule for redirecting HTTP packets on interface Ethernet3/1/2 due to lack of ACL resources.
Explanation
The device failed to assign an ACL rule to redirect HTTP packets on an interface because of ACL resource shortage.
Recommended action
DOT1X_NOTENOUGH_EADMACREDIR_RES
Message text
Failed to assign a rule for redirecting HTTP packets with source MAC address [MAC] on interface [STRING].
Variable fields
$1: Source MAC address of HTTP packets.
Severity level
3
Example
DOT1X/3/DOT1X_NOTENOUGH_EADMACREDIR_RES: Failed to assign a rule for redirecting HTTP packets with source MAC address 00e0-fc00-5915 on interface Ethernet3/1/2.
Explanation
The device failed to redirect HTTP packet with the designated source MAC on an interface because of ACL resource shortage.
Recommended action
DOT1X_NOTENOUGH_ENABLEDOT1X_RES
Message text
Failed to enable 802.1X on interface [STRING] due to lack of ACL resources.
Variable fields
Severity level
3
Example
DOT1X/3/DOT1X_NOTENOUGH_ENABLEDOT1X_RES: Failed to enable 802.1X on interface Ethernet3/1/2 due to lack of ACL resources.
Explanation
Failed to enable 802.1X on an interface because of ACL resource shortage.
Recommended action
DOT1X_UNICAST_NOT_EFFECTIVE
Message text
The unicast trigger feature is enabled but is not effective on interface [STRING].
Variable fields
Severity level
3
Example
DOT1X/3/DOT1X_UNICAST_NOT_EFFECTIVE: The unicast trigger feature is enabled but is not effective on interface Ethernet3/1/2.
Explanation
The unicast trigger setting does not take effect on an interface, because the interface does not support unicast trigger.
Recommended action
1.     Reconnect the 802.1X clients to an interface that supports the unicast trigger feature.
2.     Enable 802.1X and the unicast trigger feature on the new interface.
DOT1X_SMARTON_FAILURE
Message text
-IfName=[STRING]-MACAddr=[STRING]; User failed SmartOn authentication because [STRING].
Variable fields
$2: MAC address.
$3: Cause of failure:
·     the password is mismatched.
·     the switch ID is mismatched.
Severity level
6
Example
DOT1X/6/DOT1X_SMARTON_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; User failed SmartOn authentication because the password is mismatched.
Explanation
SmartOn authentication failed.
Recommended action
Handle the problem according to the failure cause.
DOT1X_LOGIN_FAILURE
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]; User failed 802.1X authentication.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
Severity level
6
Example
DOT1X/6/DOT1X_LOGIN_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa; User failed 802.1X authentication.
Explanation
A user failed 802.1X authentication.
Recommended action
Locate the failure cause and handle the problem according to the failure cause.
DOT1X_LOGIN_SUCC
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]; User passed 802.1X authentication and came online.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
Severity level
6
Example
DOT1X/6/DOT1X_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa; User passed 802.1X authentication and came online.
Explanation
A user passed 802.1X authentication.
Recommended action
DOT1X_LOGOFF
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-ErrCode=[STRING]; 802.1X user was logged off.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
$5: Error code.
Severity level
6
Example
DOT1X/6/DOT1X_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=aaa-ErrCode=11; 802.1X user was logged off.
Explanation
An 802.1X user was logged off.
Recommended action
Locate the logoff cause and remove the problem. If the logoff was requested by the user, no action is required.
DRVPLAT messages
This section contains driver messages.
DRVDEBUGMOD_VCF
DRVPLAT/4/DrvDebug
Message text
Can't configure PEX settings in standalone mode.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Can't configure PEX settings in standalone mode.
Explanation
Failed to configure PEX settings because the device is operating in standalone mode.
Recommended action
To configure PEX settings:
3.     Use the chassis convert mode irf command to change the device operating mode to IRF mode.
4.     Use the irf mode { enhanced | light } command to enable enhanced or light IRF mode.
DRVPLAT/4/DrvDebug
Message text
Can't configure PEX settings in normal IRF mode.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Can't configure PEX settings in normal IRF mode.
Explanation
Failed to configure PEX settings because the device is operating in normal IRF mode.
Recommended action
To configure PEX settings, first use the irf mode { enhanced | light } command to enable enhanced or light IRF mode.
DRVPLAT/4/DrvDebug
Message text
Slot [UINT16] does not support the card in subslot [UINT32]
Variable fields
$1: PEX virtual chassis number.
$2: Slot number of an expansion interface card.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=100; Slot 100 does not support the card in subslot 1
Explanation
The PEX contains an unsupported expansion interface card.
An S5120-28SC-HI or S5120-52SC-HI PEX supports only the 2-port SFP+ expansion interface card (LSPM2SP2P). This message occurs if the PEX contains any other types of expansion interface cards.
Recommended action
Replace the expansion interface card with an LSPM2SP2P expansion interface card.
DRVPLAT/4/DrvDebug
Message text
In light IRF mode, the IRF member ID can't be 3 or 4.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; In light IRF mode, the IRF member ID can't be 3 or 4.
Explanation
Failed to change the IRF member ID of a parent device to 3 or 4 because the parent fabric is operating in light IRF mode.
Recommended action
Use one of the following methods:
·     Change the IRF member ID of the parent device to 1 or 2.
·     Change the IRF operating mode of the parent fabric to enhanced, and then change the IRF member ID of the parent device to 3 or 4.
DRVPLAT/4/DrvDebug
Message text
PEX stacking not supported. Only S5130 PEXs support stacking.
Variable fields
N/A
Severity level
4
Example
IRF3 DRVPLAT/4/DrvDebug: -MDC=1-Chassis=109-Slot=0;
Explanation
PEXs failed to form a stack to connect to the parent fabric. This message appears when non-S5130 PEXs are used to form a stack.
Recommended action
·     If only one tier of PEXs are required, perform the following tasks:
a.     Disconnect the PEXs from each other.
b.     Remove the PEX stack configuration on the parent fabric for the PEX ports.
c.     Reconfigure PEX settings for one-tier PEX access.
d.     Connect PEXs to the parent fabric. PEXs are not connected to each other. All PEXs are directly connected to the parent fabric.
·     If two tiers of PEXs are required, perform the following tasks:
e.     Check the PEX model.
f.     Replace the PEXs with S5130 PEXs to form a PEX stack.
DRVPLAT/4/DrvDebug
Message text
Operation failed. Please configure the parent fabric to operate in light IRF mode first.
Variable fields
N/A
Severity level
4
Example
Explanation
PEXs failed to form a stack to connect to the parent fabric. This message appears when the parent fabric is not operating in light IRF mode.
Recommended action
·     If two tiers of PEXs are required, use the irf mode command to change the operating mode to light.
DRVDEBUGMOD_DEVM
DRVPLAT/4/DrvDebug
Message text
At least one fabric module slot is empty. Make sure a blank filler module has been installed in each empty slot so the switch can work correctly.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; At least one fabric module slot is empty. Make sure a blank filler module has been installed in each empty slot so the switch can work correctly.
Explanation
One or more switching fabric module slots were not installed with a switching fabric module or a blank filler panel.
The device checks for empty switching fabric module slots when it detects the temperature is higher than 68°C (154.4°F).
Recommended action
Install a switching fabric module or a blank filler panel in each empty switching fabric module slot.
DRVPLAT/4/DrvDebug
Message text
Fabric boards in chassis [UINT32] slot [UINT32] and slot [UINT32] do not exist. Traffic can not be forwarded in chassis [UINT32] [UINT32].
Variable fields
$1: Chassis ID. In standalone mode, this field displays 0.
$2: Slot ID.
$3: Slot ID.
$4: Chassis ID. In standalone mode, this field displays 0.
$5: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Fabric boards in chassis 1 slot 0 and slot 1 do not exist. Traffic can not be forwarded in chassis 1 3.
Explanation
The first two switching fabric module slots were not installed with switching fabric modules.
On a device installed with LSQ series OAA cards, the system checks the first two switching fabric module slots every 60 seconds. If both slots are empty, the system outputs this log.
Recommended action
1.     Check the first two switching fabric module slots.
?     If the two slots are empty, install a minimum of one switching fabric module in the slots.
?     If one or both of the slots are installed with switching fabric modules, reinstall the modules firmly.
DRVPLAT/2/DrvDebug
Message text
No switching fabric modules are present. For the system to work correctly, verify that at least one fabric module is available and operating correctly.
Variable fields
N/A
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;No switching fabric modules are present. For the system to work correctly, verify that at least one fabric module is available and operating correctly.
Explanation
The device detected that it did not have a switching fabric module installed.
The system outputs this log in the following situations:
·     The device does not find any switching fabric modules at startup.
·     You remove all switching fabrics from the device while the device is operating.
Recommended action
1.     Check all switching fabric module slots.
?     If no switching fabric modules are installed, install a minimum of one switching fabric module.
?     If one or more switching fabric modules are installed, reinstall the modules firmly.
DRVPLAT/2/DrvDebug
Message text
Fabric modules don't exist. Please install one or multiple fabric modules.
Variable fields
N/A
Severity level
2
Example
Explanation
The device checks for switching fabric modules every second. If no switching fabric modules are found within 60 seconds, the device outputs this log.
Recommended action
DRVPLAT/4/DrvDebug
Message text
In Mode [STRING], please move the card in slot [INT32] to any one of slot [INT32] to slot [INT32].
Variable fields
$1: LPU forwarding mode, compatible or high-speed.
$2: Slot ID.
$3: Slot ID.
$4: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: In Mode compatible, please move the card in slot 5 to any one of slot 0 to slot 1.
Explanation
The LPU forwarding mode does not support installing the LPU in the current slot. This log might be output for an S7506E-X switch.
Recommended action
Determine whether to continue to use the current LPU forwarding mode.
·     To continue to use the mode, move the LPU as required by the log message.
·     To use a different mode, use the fabric-mode command to change the mode.
DRVPLAT/4/DrvDebug
Message text
In Mode [STRING], please move the card in chassis [INT32] slot [INT32] to any one of chassis  [INT32] slot [INT32] to slot [INT32].
Variable fields
$2: Chassis ID.
$3: Slot ID.
$4: Chassis ID.
$5: Slot ID.
$6: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: In Mode compatible, please move the card in chassis 1 slot 5 to any one of chassis 1 slot 0 to slot 1.
Explanation
Recommended action
DRVPLAT/4/DrvDebug
Message text
In Mode [STRING], the card in slot [INT32] is not supported. Now rebooting.
Variable fields
$1: LPU forwarding mode. The value of this field is fixed at standard.
$2: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: In Mode standard, the card in slot 3 is not supported. Now rebooting.
Explanation
The device did not support the card and was rebooting the card.
When the LPU forwarding mode is standard, an S7506E-X switch does not support the following cards: SA cards, SC cards, LSQM1TGS12EC0 cards, LSQM2TGS16SF0 cards, LSUM1SPMAEC0 cards, and OAP cards.
Recommended action
Determine whether to continue to use the LPU forwarding mode standard.
·     To continue to use the mode, replace the LPU with a supported LPU.
DRVPLAT/4/DrvDebug
Message text
In Mode [STRING], the card in chassis [INT32] slot [INT32] is not supported. Now rebooting.
Variable fields
$2: Chassis ID.
$3: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: In Mode standard, the card in chassis 1 slot 3 is not supported. Now rebooting.
Explanation
Recommended action
DRVPLAT/4/DrvDebug
Message text
Please move the card in slot [INT32] to any one of slot [INT32] to slot [INT32].
Variable fields
$1: Slot ID.
$2: Slot ID.
$3: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: Please move the card in slot 5 to any one of slot 0 to slot 3.
Explanation
The slot did not support the LPU. This log might be output for an S7506E-X switch.
Recommended action
Move the LPU as required by the log message.
DRVPLAT/4/DrvDebug
Message text
Please move the card in chassis [INT32] slot [INT32] to any one of chassis  [INT32] slot [INT32] to slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Chassis ID.
$4: Slot ID.
$5: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1: Please move the card in chassis 1 slot 5 to any one of chassis 1 slot 0 to slot 3.
Explanation
Recommended action
DRVDEBUGMOD_GOLD
DRVPLAT/4/DrvDebug
Message text
WARNING: interface [STRING] has FCS errors, please check.
Variable fields
$1: Interface number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: interface GigabitEthernet 1/0/1  has FCS errors, please check.
Explanation
A frame check sequence (FCS) error was detected on an interface.
Recommended action
Contact H3C Support.
DRVPLAT/4/DrvDebug
Message text
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] has FCS errors, please check.
Variable fields
$1: IRF member ID.
$2: Slot number.
$3: Chip number.
$4: Port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 has FCS errors, please check.
Explanation
A frame check sequence (FCS) error was detected on an interface of an IRF member device.
Recommended action
DRVPLAT/2/DrvDebug
Message text
WARNING: interface [STRING] link down
Variable fields
Severity level
4
Example
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: interface GigabitEthernet 1/0/1 link down
Explanation
The link on an interface went down.
Recommended action
1.     Verify that the network cable is installed correctly. If the cable is installed incorrectly, remove it and install it again.
2.     Verify that the network cable is not faulty. If the network cable is faulty, replace it.
3.     Verify that the local interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot.
4.     Verify that the peer interface is not faulty by connecting the cable to another port. H3C recommends that you use a port on the same type of card in another slot.
5.     If the problem persists, contact H3C Support.
DRVPLAT/2/DrvDebug
Message text
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32]Port [UINT32] link down
Variable fields
$1: IRF member ID.
$2: Slot number.
$3: Chip number.
$4: Port number.
Severity level
4
Example
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 link down
Explanation
The link on an interface went down on an IRF member device.
Recommended action
DRVPLAT/2/DrvDebug
Message text
WARNING: Chip [UINT32] IPT CRC [UINT32], please check.
Variable fields
$1: Chip number.
$2: Port number.
Severity level
4
Example
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: Chip 0 IPT CRC 101, please check.
Explanation
A cyclic redundancy check (CRC) error was detected by a chip.
Recommended action
DRVPLAT/4/DrvDebug
Message text
WARNING: Unit=[UINT32],Port=[UINT32] has FCS errors, please check.
Variable fields
$1: Chip number.
$2: Port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: Unit=0,Port=1 has FCS errors, please check.
Explanation
Recommended action
DRVPLAT/2/DrvDebug
Message text
WARNING: Local Slot [UINT32] update port info for GOLD failed, while port monitor enable!
Variable fields
$1: Slot number.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;WARNING: Local Slot 5 update port info for GOLD failed, while port monitor enable!
Explanation
GOLD interface information update failed on a card when interface monitoring was enabled.
Recommended action
DRVPLAT/2/DrvDebug
Message text
WARNING: Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] link up/down too frequently
Variable fields
$1: IRF member ID.
$2: Slot number.
$3: Chip number.
$4: Port number.
Severity level
2
Example
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 Slot 5 Unit 0 Port 1 link up/down too frequently
Explanation
The link on an interface came up and went down frequently on an IRF member device.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] error frame detected!
Variable fields
$1: IRF member ID.
$2: Slot number.
$3: Chip number.
$4: Port number.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;Chassis 1 Slot 5 Unit 0 Port 1 error frame detected!
Explanation
An interface of an IRF member device received error frames.
Recommended action
DRVPLAT/4/DrvDebug
Message text
WARNING: Chassis [UINT32] slot [UINT32] is isolated already. Maybe caused by the hardware failure, please remove and check it.
Variable fields
$1: IRF member ID.
$2: Slot number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;WARNING: Chassis 1 slot 5 is isolated already. Maybe caused by the hardware failure, please remove and check it.
Explanation
A card was isolated on an IRF member device because of hardware errors.
Recommended action
1.     Remove the isolated card.
DRVPLAT/4/DrvDebug
Message text
WARNING: Slot [UINT32] is isolated already. Maybe caused by the hardware failure, please remove and check it.
Variable fields
$1: Slot number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;WARNING: Slot 5 is isolated already. Maybe caused by the hardware failure, please remove and check it.
Explanation
A card was isolated because of hardware errors.
Recommended action
DRVPLAT/4/DrvDebug
Message text
MMU Crashed, Please replace the device
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug:-MDC=1;MMU Crashed, Please replace the device
Explanation
The MMU became faulty.
Recommended action
1.     Replace the faulty MMU.
DRVDEBUGMOD_SYSM
DRVPLAT/2/DrvDebug
Message text
Please check switch mode in slot [UINT]. May need reboot it.
Variable fields
$1: Slot ID.
Severity level
2
Example
DRVPLAT/2/DrvDebug:-MDC=1; Please check switch mode in slot 3. May need reboot it.
Explanation
The operating mode specified for the LPU was different from the current mode of the LPU.
Recommended action
1.     Use the display switch-mode status command to display the operating modes of LPUs.
2.     Save the running configuration.
3.     Reboot the LPUs whose configured operating modes are different from the current operating modes.
DRVPLAT/2/DrvDebug
Message text
Please check switch mode in chassisID [UINT] slot [UINT]. May need reboot it.
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
2
Example
DRVPLAT/2/DrvDebug:-MDC=1; Please check switch mode in chassisID 1 slot 7. May need reboot it.
Explanation
Recommended action
DRVPLAT/2/DrvDebug
Message text
Power [UINT32] Remove.
Variable fields
$1: Power module ID.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1-Slot=2;Power 2 Remove.
Explanation
A power module was removed.
Recommended action
Determine whether it is required to install a power module. If it is required, contact H3C Support.
DRVPLAT/2/DrvDebug
Message text
The power of this device is not enough.
Variable fields
N/A
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1-Slot=2;The power of this device is not enough.
Explanation
Device power was insufficient.
Recommended action
1.     Determine the power requirement of the device.
2.     Determine the number of power modules to install. Make sure the total output power of the power modules is greater than the required power. H3C recommends that you arrange a power allowance of 20%.
3.     Install power modules as required.
DRVPLAT/2/DrvDebug
Message text
Fan Fault! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed < 500(R.P.M).
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
$3: Fan ID.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Fan Fault! Chassis 1 Frame 0 fan 1 speed < 500(R.P.M).
Explanation
The speed of a fan was lower than 500 rpm.
Recommended action
1.     Use the display fan command to display the operating status of the fan tray.
2.     If the fan tray status is fault, reinstall the fan tray.
DRVPLAT/2/DrvDebug
Message text
Fan Fault! Frame [UINT32] fan [UINT32] speed < 500(R.P.M).
Variable fields
$1: Fan tray ID.
$2: Fan ID.
Severity level
2
Example
Fan Fault!  Frame 0 fan 1 speed < 500(R.P.M).
Explanation
Recommended action
DRVPLAT/2/DrvDebug
Message text
Fan Adjusting failed! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too low!
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
$3: Fan ID.
$4: Fan speed.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Chassis 1 Frame 0 fan 1 speed is 1124(R.P.M), is too low!
Explanation
The actual fan speed was lower than the minimum speed for the specified fan operating mode.
Recommended action
1.     Identify whether the log message appeared multiple times.
2.     If the log message appeared only once, identify whether a user was using the debug sysm fan command to set the fan operating mode to high. If yes, no problems occurred. No action is required.
3.     If the log message appeared multiple times or no user was performing the configuration task, execute the display fan command.
4.     If the fan tray status is fault, reinstall the fan tray.
5.     If the fan tray status is normal, wait two minutes and identify whether the log message appeared again.
6.     If the log message does not appear again, the fan has automatically adjusted its speed. No action is required.
7.     If the problem persists, contact H3C Support.
DRVPLAT/2/DrvDebug
Message text
Fan Adjusting failed! Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too low!
Variable fields
$1: Fan tray ID.
$2: Fan ID.
$2: Fan speed.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Frame 0 fan 1 speed is 1124(R.P.M), is too low!
Explanation
Recommended action
DRVPLAT/2/DrvDebug
Message text
Fan Adjusting failed! Chassis [UINT32] Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too high!
Variable fields
$1: Chassis ID.
$2: Fan tray ID.
$3: Fan ID.
$4: Fan speed.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Chassis 1 Frame 0 fan 1 speed is 3524(R.P.M), is too high!
Explanation
The actual fan speed was higher than the maximum speed for the specified fan operating mode.
Recommended action
1.     Identify whether a user was using the debug sysm fan [ fan-id ] [ section-id ] command to set the fan operating mode to low or auto. If yes, no problems occurred. No action is required.
2.     If no user was performing the configuration task, execute the display fan command.
3.     If the fan tray status is fault, reinstall the fan tray.
4.     If the fan tray status is normal, wait two minutes and identify whether the log message appeared again.
5.     If the log message does not appear again, the fan has automatically adjusted its speed. No action is required.
DRVPLAT/2/DrvDebug
Message text
Fan Adjusting failed! Frame [UINT32] fan [UINT32] speed is [UINT32] (R.P.M), is too high!
Variable fields
$1: Fan tray ID.
$2: Fan ID.
$3: Fan speed.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Fan Adjusting failed! Frame 0 fan 1 speed is 3524(R.P.M), is too high!
Explanation
Recommended action
DRVPLAT/4/DrvDebug
Message text
Pmu diag info: [STRING]
Variable fields
$1: Power monitoring module alarm message.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Pmu diag info:
[02/0308]: I2C[1] int error, status = 0x20
[02/0672]: I2C[1] read 46 cmd 0xd0 failed!
[13/0433]: Get psu 3 info failed, cmd = 0
[14/1980]: Get output info of psu 3 failed!
Explanation
Possible reasons for this log message include:
·     The PoE power module or PoE power monitoring module has a problem.
·     The link between the PoE power monitoring module and the MPU or PoE power module has a problem.
Recommended action
1.     Reconnect the power cord. Make sure the power cord is firmly connected to the device.
2.     If the problem persists, use a power cord and a PoE power module that can operate correctly to replace the power cord and PoE power module.
DRVPLAT/4/DrvDebug
Message text
POE Power Chassis [UINT32] PSU Power No. [UINT32] State change to normal!
Variable fields
$1: PoE external power frame ID. In standalone mode, the value of this field is fixed at 0. In IRF mode, the value of this field is the chassis ID.
$2: PoE power module ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;POE Power Chassis 1 PSU Power No.1 State change to normal!
Explanation
The status of a power module in a PoE power frame changed to normal.
Recommended action
DRVPLAT/4/DrvDebug
Message text
POE Power Chassis [UINT32] PSU Power No. [UINT32] State change to absent!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;POE Power Chassis 1 PSU Power No.1 State change to absent!
Explanation
The status of a power module in a PoE power frame changed to absent.
Recommended action
1.     Check the PoE power switch. If the switch is off, turn on the switch.
2.     Check the PoE power module slot. If the slot is empty, install a PoE power module in the slot.
3.     If the problem persists, identify whether the PoE power cord is connected firmly.
4.     If the power cord is not connected firmly, reconnect the cable.
5.     If the problem persists, use a power cord that can operate correctly to replace the current power cord.
DRVPLAT/4/DrvDebug
Message text
POE Power Chassis [UINT32] PSU Power No. [UINT32] State change to error: [UINT32]!
Variable fields
$1: PoE power frame ID.
$3: PoE power error code. Possible error code values:
?     2Input error.
?     4Output error.
?     8The voltage is too high.
?     10The temperature is too high.
?     20Fan error.
?     40Closed.
?     80The current exceeded the limit.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;POE Power Chassis 1 PSU Power No.1 State change to error: 2!
Explanation
A power module in a PoE power frame had a problem.
Recommended action
1.     Replace the power module.
DRVPLAT/4/DrvDebug
Message text
Chassis has [UINT32] poe power
Variable fields
$1: Number of PoE power modules.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;Chassis has 3 poe power
Explanation
The number of PoE power modules that were correctly operating on the device.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The available poe power now is [UINT32]
Variable fields
$2: Available power of the PoE power modules.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The available poe power now is 1400
Explanation
This log message shows the available power of the PoE power modules.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning:Fans stop running in chassis [UINT32], please check it right now. otherwise all lpu boards will be powered down after [UINT32] minutes.
Variable fields
$1: Chassis ID.
$2: Time duration in minutes.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning:Fans stop running in chassis 1, please check it right now. otherwise all lpu boards will be powered down after 3 minutes.
Explanation
All fans had stopped operating or no fans were present on an IRF member device. When such an event occurs, the system powers off all cards on the device after a period of time. Before powering off all cards, the system issues an alarm every minute.
Recommended action
1.     Use the display fan command to display the operating status of fan trays.
?     If a fan tray is in absent state, identify whether there is a fan tray installed in the slot. If a fan tray is installed, reinstall the fan tray firmly.
?     If a fan is in fault state, reinstall the fan tray.
DRVPLAT/2/DrvDebug
Message text
Warning:Fans stop running, please check it right now. otherwise all lpu boards will be powered down after [UINT32] minutes.
Variable fields
$1: Time duration in minutes.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning:Fans stop running, please check it right now.
Explanation
All fans had stopped operating or no fans were present on the device. When such an event occurs, the system powers off all cards after a period of time. Before powering off all cards, the system issues an alarm every minute.
Recommended action
DRVPLAT/2/DrvDebug
Message text
There is maybe some wrong with the ADM1029 temperature chip!
Variable fields
N/A
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;There is maybe some wrong with the ADM1029 temperature chip!
Explanation
The ADM1029 temperature chip had a problem.
Recommended action
1.     Check the ambient temperature. If the ambient temperature is higher than 45°C (113°F), verify that the ventilation system for the room is operating correctly.
2.     Check the air outlet of the device. If the outlet is blocked, clear the outlet.
3.     Verify that the fan trays are in position and are operating correctly. If a fan tray is missing or is not operating correctly, replace the fan tray.
4.     If the problem persists, use the debug sysm fan [ fan-id ] [ section-id ] command to set the fan operating mode to high.
DRVPLAT/2/DrvDebug
Message text
There is maybe some wrong with temperature chip!
Variable fields
N/A
Severity level
2
Example
Explanation
The temperature chip had a problem.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The device does not support board in chassis [UINT32] slot [UINT32] ,type is unknown(0x[UINT32]), Please check.
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type value.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;The device does not support board in chassis 1 slot 5 ,type is unknown(0x108), Please check.
Explanation
An IRF member device did not support an installed card.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The device does not support board in slot [UINT32] ,type is unknown(0x[UINT32]), Please check.
Variable fields
$1: Slot ID.
$2: Card type value.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The device does not support board in slot 5 ,type is unknown(0x108), Please check.
Explanation
The device did not support an installed card.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Board in chassis [UINT32] slot [UINT32] doesn't support in enhanced IRF mode. Please remove the board for PEX to operate correctly.
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;Board in chassis 1 slot 5 doesn't support in enhanced IRF mode. Please remove the board for PEX to operate correctly.
Explanation
A device operating in enhanced IRF mode did not support a card.
Recommended action
For the device to operate in enhanced IRF mode, replace the specified card with a card of the following types: EC card, SF card, SG card, LSU1WCME0,LSQM2GP44TSSC0,LSQM2GP24TSSC0,LSQM2GT24PTSSC0,LSQM2GT24TSSC0,LSQM2GT48SC0,LSQM4GV48SC0,LSQ1QGS4SC0,LSQM2TGS16SF0 or LSQM1TGS12EC0.
For the device to operate in light IRF mode, enable light IRF mode.
DRVPLAT/4/DrvDebug
Message text
Board in chassis [UINT32] slot [UINT32] (type: [UINT32]) doesn't support in light IRF mode. Please remove the board for PEX to operate correctly.
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5;Board in chassis 1 slot 5 (type:264) doesn't support in light IRF mode. Please remove the board for PEX to operate correctly.
Explanation
A device operating in light IRF mode does not support LSQ series OAA cards.
Recommended action
For the device to operate in light IRF mode, replace installed LSQ series OAA cards with other models of cards.
For the device to operate in enhanced IRF mode, enable enhanced IRF mode.
DRVPLAT/2/DrvDebug
Message text
Warning: Power off all lpu boards, please check it right now.
Variable fields
N/A
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1; Warning: Power off all lpu boards, please check it right now.
Explanation
The system was powering off all cards.
Recommended action
DRVPLAT/2/DrvDebug
Message text
All lpu boards were powered down because Fans stopped running.
Variable fields
N/A
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;All lpu boards were powered down because Fans stopped running.
Explanation
The system was powering off all cards because it did not detect any fans or all fans had stopped operating.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: Not enough power to power on board chassis [UINT32] slot [UINT32]. Board power is [UINT32]w, system available power is [UINT32]w.
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Power required for the card to operate correctly.
$4: Available power.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1-Chassis=1-Slot=5;Warning: Not enough power to power on board chassis 1 slot 5. Board power is 225w, system available power is 130w.
Explanation
The system did not have enough power to power on the specified card.
Recommended action
1.     Use the display power command to display power module information.
2.     If no power modules are in fault state, install a new power module.
3.     If a power module is in fault state, reinstall the power module firmly.
4.     If the problem persists, use a power cord that can operate correctly to replace the power cord.
5.     If the problem persists, replace the power module.
DRVPLAT/2/DrvDebug
Message text
Warning: Not enough power to power on board slot [UINT32]. Board power is [UINT32]w, system available power is [UINT32]w.
Variable fields
$1: Slot ID.
$2: Power required for the card to operate correctly.
$3: Available power. The value of this field is fixed at 0.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power to power on board slot 5. Board power is 225w, system available power is 130w.
Explanation
Recommended action
5.     If the problem persists, replace the power module..
DRVPLAT/2/DrvDebug
Message text
Warning: Not enough power on chassis [UINT32], system available power is [UINT32]w.
Variable fields
$1: Chassis ID.
$2: Available power. The value of this field is fixed at 0.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power on chassis 1, system available power is 0w.
Explanation
If the available power is 0, the system outputs this log message every 3 minutes.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: Not enough power on the device, system available power is [UINT32]w.
Variable fields
$1: Available power.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Not enough power on the device, system available power is 0w.
Explanation
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: The LPU board on chassis [UINT32] slot [UINT32] is not compatible with MPU board, its board type is [ULONG].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type.
Severity level
2
Example
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;Warning: The LPU board on chassis 1 slot 5 is not compatible with MPU board, its board type is 261.2.
Explanation
The card in the specified slot had a different device identification label than the local active MPU.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: The LPU board on slot [UINT32] is not compatible with MPU board, its board type is [ULONG].
Variable fields
$1: Slot ID.
$2: Card type.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1; Warning: The LPU board on slot 5 is not compatible with MPU board,  its board type is 261.2.
Explanation
The card in the specified slot had a different device identification label than the active MPU.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: Standby board on chassis [UINT32] slot [UINT32] is not compatible with master  board, Standby board type is [ULONG].
Variable fields
$1: Chassis ID.
$2: Slot ID.
$3: Card type.
Severity level
2
Example
DRVPLAT/2/DrvDebug:-MDC=1-Chassis=1-Slot=5;Warning: Standby board on chassis 1 slot 1 is not compatible with master  board, Standby board type is 256.2.
Explanation
The standby MPU had a different device identification label than the local active MPU.
Recommended action
DRVPLAT/2/DrvDebug
Message text
Warning: Standby board on slot [UINT32] is not compatible with master  board, Standby board type is [ULONG].
Variable fields
$1: Slot ID.
$2: Card type.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1;Warning: Standby board on slot1 is not compatible with master  board, Standby board type is 256.2.
Explanation
The standby MPU had a different device identification label than the active MPU.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Some cards do not support the data center features. See the release notes for more information.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Some cards do not support the data center features. See the release notes for more information.
Explanation
The system outputs this log when you use data center features on a card that does not support these features. For more information, see the release notes.
Recommended action
Do not use data center features on a card that does not support these features.
DRVDEBUGMOD_RXTX
DRVPLAT/2/DrvDebug
Message text
Loopback exists on the interface [UINT32] [STRING].
Variable fields
$1: Interface number in the card.
$2: Interface name.
Severity level
2
Example
DRVPLAT/2/DrvDebug: -MDC=1; Loopback exists on the interface 1 GigabitEthernet 1/0/1.
Explanation
The loop detection feature detected a loop on the interface.
Recommended action
1.     Check cable connections for the loop.
2.     Run protocols such as a spanning tree protocol to remove the loop condition.
3.     If the problem persists, contact H3C Support.
DRVDEBUGMOD_POE
DRVPLAT/4/DrvDebug
Message text
The temperature of [STRING] exceeded [UINT32] Centigrade. Power supply stopped.
Variable fields
$1: PoE interface (PI) number.
$2: Temperature.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The temperature of GigabitEthernet 1/0/1 exceeded 135 Centigrade. Power supply stopped.
Explanation
The system stopped power supply to the PI because the PI temperature exceeded the upper temperature threshold.
PoE over-temperature protection enables the system to monitor the chassis internal temperature in real time. When the temperature exceeds the upper limit, the system disables PoE for all PIs. When the temperature is in the acceptable range, the power supply is restored. The upper temperature limit depends on hardware specifications and is not configurable at the CLI.
Recommended action
1.     Use the debug sysm fan command to increase the fan rotation speed. Or take other measures to decrease the ambient temperature.
DRVPLAT/4/DrvDebug
Message text
The temperature of [STRING] dropped to [UINT32] Centigrade. Power supply stopped.
Variable fields
$1: PI number.
$2: Temperature.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The temperature of GigabitEthernet 1/0/1 dropped to 0 Centigrade. Power supply stopped.
Explanation
The system stopped power supply to the PI because the PI temperature dropped below the lower temperature threshold.
PoE over-temperature protection enables the system to monitor the chassis internal temperature in real time. When the temperature drops below the lower limit, the system disables PoE for all PIs. When the temperature is in the acceptable range, the power supply is restored. The lower temperature limit depends on hardware specifications and is not configurable at the CLI.
Recommended action
1.     Use the debug sysm fan command to decrease the fan rotation speed. Or take other measures to increase the ambient temperature.
DRVPLAT/4/DrvDebug
Message text
The temperature of [STRING] dropped to [UINT32] Centigrade. Power supply recovered.
Variable fields
$1: PI number.
$2: Temperature.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The temperature of GigabitEthernet 1/0/1 dropped to 125 Centigrade. Power supply recovered.
Explanation
The PI temperature dropped to the acceptable range, and the power was supplied.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The temperature of [STRING] exceeded [UINT32] Centigrade. Power supply recovered
Variable fields
$1: PI number.
$2: Temperature.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1;The temperature of GigabitEthernet 1/0/1 exceeded 0 Centigrade. Power supply recovered
Explanation
The PI temperature rose to the acceptable range, and the power was supplied.
Recommended action
DRVDEBUGMOD_PORT
DRVPLAT/4/DrvDebug
Message text
Bind the interfaces [STRING] to [STRING] to one or two IRF ports or cancel the bindings on all of them.
Variable fields
$1: IRF physical interface name.
$2: IRF physical interface name.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; Bind the interfaces GigabitEthernet 1/0/1 to GigabitEthernet 1/0/4 to one or two IRF ports or cancel the bindings on all of them.
Explanation
Ports on the SF, SC1 and EC LPUs are grouped. You must use all or none of the ports in the same group for IRF links. The message occurs if this binding requirement is violated.
The ports on the SF or EC LPUs are grouped as follows:
·     The breakout ports of a 40-GE port are in one group.
·     The 10-GE ports on all SF and EC LPUs are grouped by port number in order, starting from 1. Each group contains four ports.
Recommended action
1.     Remove all IRF port bindings that contain the ports in the group, or bind all ports in the group to IRF ports. If you use the ports for IRF links, follow these restrictions and guidelines:
?     The ports can be bound to different IRF ports.
?     Before you bind one port in the group to an IRF port or remove it from the IRF port, you must shut down all the ports in the group. If any of the ports are in up state, the bind or remove action will fail.
?     Bring up the ports after you complete the operations.
2.     If the problem persists, contact H3C Support.
DRVPLAT/4/DrvDebug
Message text
The IRF port [STRING] doesn't support GE transceiver modules. Please remove the module.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; The IRF port Ten-GigabitEthernet 1/0/1 doesn't support GE transceiver modules. Please remove the module.
Explanation
IRF links must operate at a minimum of 10 Gbps. This message occurs if an SFP transceiver module is installed for an IRF physical interface.
Recommended action
Replace the transceiver module.
DRVDEBUGMOD_STACK
DRVPLAT/4/DrvDebug
Message text
The port [STRING] has been changed to inactive status, please check.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=2; The port Ten1/2/0/1 has been changed to inactive status, please check.
Explanation
The IRF physical interface changed to the inactive state.
Recommended action
1.     Verify that the transceiver module is installed securely.
DRVPLAT/4/DrvDebug
Message text
The port [STRING] has been changed to active status.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=4; The port Ten2/4/0/1 has been changed to active status.
Explanation
The IRF physical interface changed to the active state.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The port [STRING] can't receive irf pkt and has been changed to inactive status, please check.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=4; The port Ten2/4/0/1 can't receive irf pkt and has been changed to inactive status, please check.
Explanation
The IRF physical interface cannot receive IRF protocol packets, and it has changed to the inactive state.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The port [STRING] can't receive irf pkt, please check.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=2; The port Ten1/2/0/13 can't receive irf pkt, please check.
Explanation
The IRF physical interface cannot receive IRF protocol packets.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Port [STRING] Connect fail, Reason: [STRING], please check.
Variable fields
$2: Failure reason, including:
?     MemberID is the same.
?     IRF-Port is the same.
?     LoopBack.
?     Check timeout.
?     Fiber Connect Error.
?     Topo Invalid.
?     Peer Notify.
?     Other reason.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=1-Slot=5; Port Ten1/5/0/1 Connect fail, Reason: Check timeout, please check.
Explanation
The IRF physical interface failed to connect to the peer because of the reason displayed in the message.
Recommended action
1.     Resolve the problem depending on the failure reason:
?     MemberID is the same—Change the IRF member ID of either member device. Make sure each member device has a unique IRF member ID.
?     IRF-Port is the sameMake sure the IRF physical interfaces of IRF-port 1 on one member are connected to the IRF physical interfaces of IRF-port 2 on the other member device.
?     LoopBackUse the undo loopback command to remove the loopback configuration on the IRF physical interface.
?     Check timeout—Check the settings on the local and peer ports for any errors. Verify that the local and peer ports are IRF physical interfaces.
?     Fiber Connect Error—Verify that the IRF connections are consistent with the IRF port bindings.
?     Topo InvalidCheck the IRF connections for topology errors.
?     Peer NotifyReinstall the transceiver module of the peer IRF physical interface.
?     Other reasonContact H3C Support.
DRVPLAT/4/DrvDebug
Message text
The max-ecmp-num configuration should be the same on devices in one IRF.
Please check it on the neighbor device connected to IRF-port [STRING]
Variable fields
$1: IRF port index.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; The max-ecmp-num configuration should be the same on devices in one IRF.
Please check it on the neighbor device connected to IRF-port 2
Explanation
The maximum number of ECMP routes must be the same across member devices in an IRF fabric.
Recommended action
1.     Execute the display max-ecmp-num command to check the maximum number of ECMP routes on each device.
2.     Execute the max-ecmp-num command to change the maximum number of ECMP routes to the same value for the devices. The value change takes effect after a reboot.
DRVPLAT/4/DrvDebug
Message text
The device vendor must be the same for all member devices in one IRF fabric.
Please check the vendor of the neighbor device connected to IRF-port [STRING].
Variable fields
$1: IRF port index.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; The device vendor must be the same for all member devices in one IRF fabric.
Explanation
This message appears if the device and the neighbor device are from different vendors.
Recommended action
Use devices from the same vendor to set up an IRF fabric.
DRVPLAT/4/DrvDebug
Message text
The Systemworking mode configuration should be the same on devices in one IRF.
Variable fields
$1: IRF port index.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; The Systemworking mode configuration should be the same on devices in one IRF.
Explanation
The system operating mode must be the same across member devices in an IRF fabric.
Recommended action
1.     Execute the display system-working-mode command to check the device operating mode on each device.
2.     Execute the system-working-mode command to change the system operating mode to the same mode for the devices. The mode change takes effect after a reboot.
DRVPLAT/4/DrvDebug
Message text
The pex mode configuration should be the same on devices in one IRF.
Variable fields
$1: IRF port index.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; The pex mode configuration should be the same on devices in one IRF.
Explanation
The IRF operating mode must be the same across member devices in an IRF fabric.
Recommended action
1.     Execute the display irf command to check the IRF mode setting on each device.
2.     Execute the irf mode command to change the IRF operating mode to the same mode for the devices. The mode change takes effect after a reboot.
DRVDEBUGMOD_SWFA
DRVPLAT/4/DrvDebug
Message text
Chassis [UINT32] Slot [UINT32] Unit [UINT32] Port [UINT32] link down
Variable fields
$1: IRF member ID of the device.
$2: Slot number of the card.
$3: Chip number.
$4: Port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug :Chassis 1 Slot 2 Unit 0 Port 18 link down
Explanation
Port 18 on chip 0 of card 2 on member device 1 was down.
Recommended action
If this log appears during device loading, no action is required.
If this log persists, contact H3C Support.
DRVPLAT/4/DrvDebug
Message text
Variable fields
$1: Slot number of the card.
$2: Chip number.
$3: Port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug:Slot 2 Unit 0 Port 18 link down.
Explanation
Port 18 on chip 0 of card 2 was down.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Warning: In chassis [UINT32] slot [UINT32],all interconnected ports from chip [UINT32] to chip [UINT32] are fault,please check.
Variable fields
$3: Chip number.
$4: Chip number.
Severity level
4
Example
DRVPLAT/4/DrvDebug :Warning: In chassis 1 slot 1,all interconnected ports from chip 0 to chip 1 are fault,please check.
Explanation
The status was down for the port connecting chip 0 on card 1 and chip 1 on card 2 of IRF member device 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Warning: In slot [UINT32],all interconnected ports from chip [UINT32] to chip [UINT32] are fault,please check..
Variable fields
$2: Chip number.
$3: Chip number.
Severity level
4
Example
DRVPLAT/4/DrvDebug :Warning: In slot 1 ,all interconnected ports from chip 0 to chip 1 are fault,please check.
Explanation
The status was down for the port connecting chip 0 and chip 1 on card 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Warning: In chassis [UINT32],all interconnected ports from slot [UINT32] to slot [UINT32] are fault,please check.
Variable fields
$3: Slot number of the card.
Severity level
4
Example
DRVPLAT/4/DrvDebug:Warning: In chassis 1,all interconnected ports from slot 2 to slot 4 are fault,please check.
Explanation
The status was down for the port connecting card 2 and card 4 on IRF member device 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Warning: All interconnected ports from slot [UINT32] to slot [UINT32] are fault,please check.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug:Warning: All interconnected ports from slot 1 to slot 2 are fault,please check.
Explanation
The status was down for the port connecting card 1 and card 2.
Recommended action
DRVPLAT/4/DrvDebug
Message text
In chassis [UINT32] slot [UINT32], some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are [UINT32]
Variable fields
$3: Channel number.
Severity level
4
Example
DRVPLAT/4/DrvDebug:In chassis 1 slot 2, some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are1
Explanation
The number of error packets increased for Channel 1 on card 2 of IRF member device 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
In slot [UINT32], some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are [UINT32]
Variable fields
$2: Channel number.
Severity level
4
Example
DRVPLAT/4/DrvDebug:In slot 1, some internal channels 'RxCrcError' counter increase continuously. Please check.The error channels are 1
Explanation
The number of error packets increased for Channel 1 on card 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
On chip [UINT32] in chassis [UINT32] slot [UINT32], at least two internal ports are down. Please check the internal ports.The down ports are sfi [UINT32]
Variable fields
$1: Chip number.
$2: IRF member ID of the device.
$3: Chip number.
$4: Internal port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug:On chip 0 in chassis 1 slot 2, at least two internal ports are down. Please check the internal ports.The down ports are sfi1  sfi 2
Explanation
The status was down for ports sfi1 and sfi2 on chip 0 of card 2 on IRF member device 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
On chip [UINT32] in slot [UINT32], at least two internal ports are down. Please check the internal ports. The down ports are sfi [UINT32]
Variable fields
$1: Chip number.
$2: Chip number.
$3: Internal port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug:On chip 0 in slot 1, at least two internal ports are down. Please check the internal ports. The down ports are  sfi1  sfi 2
Explanation
The status was down for ports sfi1 and sfi2 on chip 0 of card 1.
Recommended action
DRVPLAT/4/DrvDebug
Message text
In chassis [UINT32],the specified fabric-board [UINT32] does not work
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug:In chassis 1,the specified fabric-board 2 does not work
Explanation
The switching fabric module is isolated and is not operating.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The specified fabric-board [UINT32] does not work.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug:The specified fabric-board 1 does not work.
Explanation
Recommended action
DRVPLAT/4/DrvDebug
Message text
In chassis [UINT32],the specified fabric-board [UINT32] resume work.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug:In chassis1,the specified fabric-board 1 resume work.
Explanation
The switching fabric module is not isolated and is operating.
Recommended action
DRVPLAT/4/DrvDebug
Message text
The specified fabric-board [UINT32] resume work.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug:The specified fabric-board 1 resume work.
Explanation
Recommended action
DRVPLAT/4/DrvDebug
Message text
All internal ports on an interface module that were connected to other modules were down. The system would reboot the interface module.
Variable fields
None
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Chassis=2-Slot=5; All internal ports on an interface module that were connected to other modules were down. The system would reboot the interface module
Explanation
The system detected that all internal ports on an interface module that were connected to other modules were down.
Recommended action
1.     Verify that the MPUs were securely installed.
2.     Verify that the switching fabric moduels were securely installed.
DRVDEBUGMOD_BSP
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] is busy, SlaveAddr: [STRING]
Variable fields
$1: I2C bus number.
$2: I2C address of the subordinate device.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 is busy, SlaveAddr: 0x59
Explanation
The I2C bus with the specified subordinate I2C address is busy.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] generate start failed, dev: [STRING], status: [STRING]
Variable fields
$1: I2C bus number.
$2: I2C address of the device.
$3: I2C status.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 generate start failed, dev:0x59 , status: busy
Explanation
The I2C bus with the specified I2C address failed to start. The I2C bus is busy.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] wait interrupt failed when writing data, dev: [STRING].
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 wait interrupt failed when writing data, dev: 0x59.
Explanation
Errors occurred for the specified waiting process during the writing for the I2C bus with the specified I2C address.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] interrupt process [STRING] is error when writing data, dev: [STRING].
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 interrupt process 1 is error when writing data, dev: 0x59.
Explanation
Errors occurred for the specified interrupting process during the writing for the I2C bus with the specified I2C address.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] wait interrupt failed when reading data, dev: [STRING].
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 wait interrupt failed when reading data, dev:0x59.
Explanation
Errors occurred for the specified waiting process during the reading for the I2C bus with the specified I2C address.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] interrupt process [STRING] is error when reading data, dev: [STRING].
Variable fields
$1: I2C bus number.
$2: Process number.
$3: I2C address of the device.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 interrupt process 1 is error when reading data, dev:0x59.
Explanation
Errors occurred for the specified interrupting process during the reading for the I2C bus with the specified I2C address.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] write failed, invalid param. dev: [STRING], reg: [STRING], datalen: [STRING].
Variable fields
$1: I2C bus number.
$3: I2C address offset.
$4: Data length.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, invalid param. dev: 0x59, reg:0x20, datalen: 0x20.
Explanation
Writing failed for the I2C bus with the specified address and offset because of the invalid parameter.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] write failed, invalid bus num.
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, invalid bus num.
Explanation
Writing failed for the I2C bus because of the invalid bus number.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] free-sem take failed when writing data.
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 free-sem take failed when writing data.
Explanation
The I2C bus failed to obtain the signal volume during the writing process.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] write failed, retry resume! i2c trace: [STRING], dev: [STRING], reg: [STRING]
Variable fields
$1: I2C bus number.
$2: I2C trace.
$4: I2C address offset.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 write failed, retry resume! i2c trace: 2, dev: 0x59, reg: 0x20
Explanation
Writing failed for the I2C bus with the specified trace, address, and offset.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] read failed, invalid param. dev: [STRING], reg: [STRING], datalen: [STRING].
Variable fields
$1: I2C bus number.
$4: Data length.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, invalid param. dev: 0x59, reg:0x20, datalen: 0x20.
Explanation
Reading failed for the I2C bus with the specified address and offset because of the invalid parameter.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] read failed, invalid bus num.
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, invalid bus num.
Explanation
Reading failed for the I2C bus because of the invalid bus number.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING] free-sem take failed when reading data.
Variable fields
$1: I2C bus number.
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 free-sem take failed when reading data.
Explanation
The I2C bus failed to obtain the signal volume during the reading process.
Recommended action
DRVPLAT/3/DrvDebug
Message text
I2C bus [STRING]read failed, retry resume! i2c trace: [STRING], dev: [STRING], reg: [STRING]
Variable fields
$1: Bus number.
$2: I2C trace
Severity level
3
Example
DRVPLAT/3/DrvDebug:-MDC=1;I2C bus 1 read failed, retry resume! i2c trace: 2, dev: 0x59, reg:0x20
Explanation
Recommended action
ETHOAM messages
This section contains Ethernet OAM messages.
ETHOAM_CONNECTION_FAIL_DOWN
Message text
The link is down on port [string] because a remote failure occurred on peer port.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ETHOAM_OAM_LINK_DOWN: The link is down on port Ethernet1/0/1 because a remote failure occurred on peer port.
Explanation
The link went down because a remote failure occurred on the peer port.
Recommended action
Check the link status or the OAM status on the peer.
ETHOAM_CONNECTION_FAIL_TIMEOUT
Message text
Port [string] removed the OAM connection because it received no Information OAMPDU before the timer times out.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ETHOAM_CONNECTION_FAIL_TIMEOUT: Port Ethernet1/0/1 removed the OAM connection because it received no Information OAMPDU before the timer times out.
Explanation
The port removed the OAM connection because it had not received Information OAMPDUs before the timer timed out.
Recommended action
ETHOAM_CONNECTION_FAIL_UNSATISF
Message text
Port [string] failed to establish an OAM connection because the peer doesn’t match the capacity of the local port.
Variable fields
$1: Port name.
Severity level
3
Example
ETHOAM/3/ETHOAM_CONNECTION_FAIL_UNSATISF: Port Ethernet1/0/1 failed to establish an OAM connection because the peer doesn’t match the capacity of the local port.
Explanation
Failed to establish an OAM connection because the OAM protocol states do not match at the two ends.
Recommended action
Check the protocol state field of OAM packets sent by both ends.
ETHOAM_CONNECTION_SUCCEED
Message text
An OAM connection is established on port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_CONNECTION_SUCCEED: An OAM connection is established on port Ethernet1/0/1.
Explanation
An OAM connection was established.
Recommended action
ETHOAM_DISABLE
Message text
Ethernet OAM is now disabled on port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_DISABLE: Ethernet OAM is now disabled on port Ethernet1/0/1.
Explanation
Ethernet OAM was disabled.
Recommended action
ETHOAM_DISCOVERY_EXIT
Message text
OAM port [string] quits OAM connection.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ ETHOAM_DISCOVERY_EXIT: OAM port Ethernet1/0/1 quits OAM connection.
Explanation
The local port ended the OAM connection.
Recommended action
ETHOAM_ENABLE
Message text
Ethernet OAM is now enabled on port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_ENABLE: Ethernet OAM is now enabled on port Ethernet1/0/1.
Explanation
Ethernet OAM was enabled.
Recommended action
ETHOAM_ENTER_LOOPBACK_CTRLLED
Message text
The local OAM entity enters remote loopback as controlled DTE on OAM port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLED: The local OAM entity enters remote loopback as controlled DTE on OAM port Ethernet1/0/1.
Explanation
This event occurs when you enable OAM loopback on the peer end.
Recommended action
ETHOAM_ENTER_LOOPBACK_CTRLLING
Message text
The local OAM entity enters remote loopback as controlling DTE on OAM port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLING: The local OAM entity enters remote loopback as controlling DTE on OAM port Ethernet1/0/1.
Explanation
This event occurs when you enable OAM loopback on the port.
Recommended action
ETHOAM_LOCAL_DYING_GASP
Message text
A local Dying Gasp event has occurred on [string].
Variable fields
$1: Interface name.
Severity level
4
Example
ETHOAM/4/ETHOAM_LOCAL_DYING_GASP: A local Dying Gasp event has occurred on Ethernet1/0/1.
Explanation
A local Dying Gasp event occurs when you reboot the local device or shut down the interface.
Recommended action
Do not use the link until it recovers.
ETHOAM_LOCAL_ERROR_FRAME
Message text
An errored frame event occurred on local port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME: An errored frame event occurred on local port Ethernet1/0/1.
Explanation
An errored frame event occurred on the local port.
Recommended action
Check the link.
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
Message text
An errored frame period event occurred on local port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_PERIOD: An errored frame period event occurred on local port Ethernet1/0/1.
Explanation
An errored frame period event occurred on the local port.
Recommended action
Check the link.
ETHOAM_LOCAL_ERROR_FRAME_SECOND
Message text
An errored frame seconds event occurred on local port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_SECOND: An errored frame seconds event occurred on local port Ethernet1/0/1.
Explanation
An errored frame seconds event occurred on the local port.
Recommended action
Check the link.
ETHOAM_LOCAL_LINK_FAULT
Message text
A local Link Fault event occurred on [string].
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_LOCAL_LINK_FAULT: A local Link Fault event occurred on Ethernet1/0/1.
Explanation
This event occurs when the local link goes down.
Recommended action
Re-connect the Rx end of the fiber on the local port.
ETHOAM_LOOPBACK_EXIT
Message text
OAM port [string] quits remote loopback.
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_LOOPBACK_EXIT: OAM port Ethernet1/0/1 quits remote loopback.
Explanation
The OAM port ended remote loopback after remote loopback was disabled on the port and the OAM connection was torn down.
Recommended action
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
Message text
OAM port [string] quits remote loopback due to incorrect multiplexer or parser status.
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_LOOPBACK_EXIT_ERROR_STATU: OAM port Ethernet1/0/1 quits remote loopback due to incorrect multiplexer or parser status.
Explanation
OAM port Ethernet1/0/1 ended remote loopback due to incorrect multiplexer or parser status.
Recommended action
Disable, and then re-enable Ethernet OAM on the OAM entity.
ETHOAM_LOOPBACK_NO_RESOURCE
Message text
OAM port [string] can’t enter remote loopback due to insufficient resources.
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_LOOPBACK_NO_RESOURCE: OAM port Ethernet1/0/1 can’t enter remote loopback due to insufficient resources.
Explanation
The OAM port cannot enter remote loopback due to insufficient resources when you execute the oam remote-loopback start command on the local or remote OAM entity.
Recommended action
Release the resources, and then execute the oam remote-loopback start command again.
ETHOAM_LOOPBACK_NOT_SUPPORT
Message text
OAM port [string] can’t enter remote loopback because the operation is not supported.
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_LOOPBACK_NOT_SUPPORT: OAM port Ethernet1/0/1 can't enter remote loopback because the operation is not supported.
Explanation
The OAM port cannot enter remote loopback because the operation is not supported on the device.
Recommended action
ETHOAM_QUIT_LOOPBACK_CTRLLED
Message text
The local OAM entity quits remote loopback as controlled DTE on OAM port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ ETHOAM_QUIT_LOOPBACK_CTRLLED: The local OAM entity quits remote loopback as controlled DTE on OAM port Ethernet1/0/1.
Explanation
The local OAM entity ended remote loopback as controlled DTE after you disabled OAM loopback on the peer end.
Recommended action
ETHOAM_QUIT_LOOPBACK_CTRLLING
Message text
The local OAM entity quits remote loopback as controlling DTE on OAM port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLING: The local OAM entity quits remote loopback as controlling DTE on OAM port Ethernet1/0/1.
Explanation
The local OAM entity ended remote loopback as controlling DTE after you disabled OAM loopback on the port.
Recommended action
ETHOAM_REMOTE_CRITICAL
Message text
A remote Critical event occurred on [string].
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_REMOTE_CRITICAL: A remote Critical event occurred on Ethernet1/0/1.
Explanation
A remote critical event occurred.
Recommended action
ETHOAM_REMOTE_DYING_GASP
Message text
A remote Dying Gasp event occurred on [string].
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_REMOTE_DYING_GASP: A remote Dying Gasp event occurred on Ethernet1/0/1.
Explanation
This event occurs when you reboot the remote device and shut down the port.
Recommended action
Do not use this link until it recovers.
ETHOAM_REMOTE_ERROR_FRAME
Message text
An errored frame event occurred on the peer port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME: An errored frame event occurred on the peer port Ethernet1/0/1.
Explanation
An errored frame event occurred on the peer.
Recommended action
Check the link.
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
Message text
An errored frame period event occurred on the peer port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_PERIOD: An errored frame period event occurred on the peer port Ethernet1/0/1.
Explanation
An errored frame period event occurred on the peer port.
Recommended action
Check the link.
ETHOAM_REMOTE_ERROR_FRAME_SECOND
Message text
An errored frame seconds event occurred on the peer port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_SECOND: An errored frame seconds event occurred on the peer port Ethernet1/0/1.
Explanation
An errored frame seconds event occurred on the peer.
Recommended action
Check the link.
ETHOAM_REMOTE_ERROR_SYMBOL
Message text
An errored symbol event occurred on the peer port [string].
Variable fields
$1: Port name.
Severity level
6
Example
ETHOAM/6/ETHOAM_REMOTE_ERROR_SYMBOL: An errored symbol event occurred on the peer port Ethernet1/0/1.
Explanation
An errored symbol event occurred on the peer.
Recommended action
Check the link.
ETHOAM_REMOTE_EXIT
Message text
OAM port [string] quits OAM connection because Ethernet OAM is disabled on the peer port.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ ETHOAM_REMOTE_EXIT: OAM port Ethernet1/0/1  quits OAM connection because Ethernet OAM is disabled on the peer port.
Explanation
The local port ended the OAM connection because Ethernet OAM was disabled on the peer port.
Recommended action
ETHOAM_REMOTE_FAILURE_RECOVER
Message text
Peer port [string] recovered.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ ETHOAM_REMOTE_FAILURE_RECOVER: Peer port Ethernet1/0/1 recovered.
Explanation
The Link fault was cleared from the peer port and the OAM connection was restored.
Recommended action
ETHOAM_REMOTE_LINK_FAULT
Message text
A remote Link Fault event occurred on [string].
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ETHOAM_REMOTE_LINK_FAULT: A remote Link Fault event occurred on Ethernet1/0/1.
Explanation
The remote link went down.
Recommended action
Reconnect the Rx end of the fiber on the remote port.
ETHOAM_NO_ENOUGH_RESOURCE
Message text
OAM port [string] the configuration failed because of insufficient hardware resources.
Variable fields
$1: Port name.
Severity level
4
Example
ETHOAM/4/ ETHOAM_NO_ENOUGH_RESOURCE: Ethernet1/0/1 the configuration failed because of insufficient hardware resources.
Explanation
The configuration failed on the OAM port because of insufficient hardware resources.
Recommended action
Release the resources, and execute the command again.
ETHOAM_NOT_CONNECTION_TIMEOUT
Message text
Port [string] quits Ethernet OAM because it received no Information OAMPDU before the timer times out.
Variable fields
$1: Port name.
Severity level
5
Example
ETHOAM/5/ ETHOAM_NOT_CONNECTION_TIMEOUT: Port Ethernet1/0/1 quits Ethernet OAM because it received no Information OAMPDU before the timer times out.
Explanation
The local port ended Ethernet OAM because it had not received Information OAMPDUs before the timer timed out.
Recommended action
EVB messages
This section contains EVB messages.
EVB_AGG_FAILED
Message text
Remove the port [STRING] from the aggregation group [STRING]. Otherwise, the EVB feature does not take effect.
Variable fields
$1: Port name.
$2: Aggregation port name.
Severity level
6
Example
EVB/6/EVB_AGG_FAILED: Remove the port GigabitEthernet5/0/5 from the aggregation group Bridge-Aggregation5. Otherwise, the EVB feature does not take effect.
Explanation
The EVB bridge failed to process a port in an aggregation group.
Recommended action
Remove the port from the aggregation group.
EVB_VSI_OFFLINE
Message text
VSI [STRING] went offline.
Variable fields
$1: VSI name.
Severity level
6
Example
EVB/6/EVB_VSI_OFFLINE: VSI Schannel-Aggregation1:2.0 went offline.
Explanation
The VSI interface was deleted.
This event occurs in the following situations:
·     The EVB bridge receives a VDP packet from the EVB station.
·     The EVB bridge has not received an acknowledgement after a VDP packet times out.
Recommended action
EVB_VSI_ONLINE
Message text
VSI [STRING] came online, status is [STRING].
Variable fields
$1: VSI name.
$2: VSI status.
Severity level
6
Example
EVB/6/EVB_VSI_ONLINE: VSI Schannel-Aggregation1:2.0 came online, status is association.
Explanation
The EVB bridge received a VDP packet and created a VSI successfully.
Recommended action
EVB_WARNING_NO_LICENSE
Message text
License of the [STRING] feature will be expired in [UINT32] days. Install a permanent license.
Variable fields
$1: Feature name.
$2: Validity period of the license.
Severity level
6
Example
EVB/6/EVB_WARNING_NO_LICENSE: License of the EVB feature will be expired in 15 days. Install a permanent license.
Explanation
The EVB license on an MPU is about to expire.
Recommended action
Renew the license.
EVIISIS messages
This section contains EVI IS-IS messages.
EVIISIS_LICENSE_EXPIRED
Message text
The EVIISIS feature is being disabled, because its license has expired.
Variable fields
N/A
Severity level
3
Example
EVIISIS/3/EVIISIS_LICENSE_EXPIRED: The EVIISIS feature is being disabled, because its license has expired.
Explanation
The EVI IS-IS license has expired.
Recommended action
Install a valid license for EVI IS-IS.
EVIISIS_LICENSE_EXPIRED_TIME
Message text
The EVIISIS feature will be disabled in [ULONG] days.
Variable fields
$1: Available period of the feature.
Severity level
5
Example
EVIISIS/5/EVIISIS_LICENSE_EXPIRED_TIME: The EVIISIS feature will be disabled in 2 days.
Explanation
EVI IS-IS will be disabled because no EVI IS-IS license is available. After an active/standby MPU switchover, you can use EVI IS-IS only for 30 days if the new active MPU does not have an EVI IS-IS license.
Recommended action
Install a new license.
EVIISIS_LICENSE_UNAVAILABLE
Message text
The EVIISIS feature has no available license.
Variable fields
N/A
Severity level
3
Example
EVIISIS/3/EVIISIS_LICENSE_UNAVAILABLE: The EVIISIS feature has no available license.
Explanation
No license was found for EVI IS-IS when the EVI IS-IS process started.
Recommended action
EVIISIS_MEM_ALERT
Message text
EVIISIS process receive system memory alert [STRING] event.
Variable fields
$1: Type of the memory alert.
Severity level
5
Example
EVIISIS/5/EVIISIS_MEM_ALERT: EVIISIS process receive system memory alert start event.
Explanation
EVI IS-IS received a memory alarm.
Recommended action
Check the system memory.
EVIISIS_NBR_CHG
Message text
EVIISIS [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING].
Variable fields
$1: EVI IS-IS process ID.
$2: EVI IS-IS neighbor level.
$3: Neighbor system ID.
$4: Interface name.
$5: Current adjacency state.
Severity level
5
Example
EVIISIS/5/EVIISIS_NBR_CHG: EVIISIS 1, Level-1 adjacency 0011.2200.1501 (Evi-Link0), state change to: down.
Explanation
The EVI IS-IS adjacency state changed on an interface.
Recommended action
If the adjacency with a neighbor changes to down or initializing on an interface, check for EVI IS-IS configuration errors and loss of network connectivity.
FCOE messages
This section contains FCoE messages.
FCOE_INTERFACE_NOTSUPPORT_FCOE
Message text
Because the aggregate interface [STRING] has been bound to a VFC interface, assigning the interface [STRING] that does not support FCoE to the aggregate interface will cause incorrect processing.
Variable fields
$1: Aggregate interface name.
$2: Ethernet interface name.
Severity level
4
Example
FCOE/4/FCOE_INTERFACE_NOTSUPPORT_FCOE: Because the aggregate interface Bridge-Aggregation 1 has been bound to a VFC interface, assigning the interface Ten-GigabitEthernet 2/0/1 that does not support FCoE to the aggregate interface will cause incorrect processing.
Explanation
This message is generated when an interface that does not support FCoE is assigned to an aggregate interface that has been bound to a VFC interface.
Recommended action
Assign an interface that supports FCoE to the aggregate interface, or remove the binding from the VFC interface.
FCOE_LICENSE_ERROR
Message text
No license is found for FCoE.
Variable fields
N/A
Severity level
3
Example
FCOE/3/FCOE_LICENSE_ERROR: No license is found for FCoE.
Explanation
Recommended action
Install a license for FCoE.
FCOE_LICENSE_EXPIRED_EXIT
Message text
FCoE is unavailable because its license has expired.
Variable fields
N/A
Severity level
3
Example
FCOE/3/FCOE_LICENSE_EXPIRED_EXIT: FCoE is unavailable because its license has expired.
Explanation
The FCoE license has expired.
Recommended action
Install a valid license for FCoE.
FCOE_LICENSE_EXPIRED_TIME
Message text
FCoE will become unavailable in [ULONG] days.
Variable fields
Severity level
4
Example
FCOE/4/FCOE_LICENSE_EXPIRED_TIME: FCoE will become unavailable in 2 days.
Explanation
FCoE will be disabled because the FCoE license has expired. You can use FCoE for 30 days after the license is expired.
Recommended action
FCLINK messages
This section contains FC link messages.
FCLINK_FDISC_REJECT_NORESOURCE
Message text
VSAN [UINT16], Interface [STRING]: An FDISC was rejected because the hardware resource is not enough.
Variable fields
$1: VSAN ID.
$2: Interface name.
Severity level
4
Example
FCLINK/4/FCLINK_FDISC_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FDISC was rejected because the hardware resource is not enough.
Explanation
This event occurs if an FDISC packet is received when hardware resources are insufficient.
Recommended action
Reduce the number of nodes.
FCLINK_FLOGI_REJECT_NORESOURCE
Message text
VSAN [UINT16], Interface [STRING]: An FLOGI was rejected because the hardware resource is not enough.
Variable fields
$1: VSAN ID.
$2: Interface name.
Severity level
4
Example
FCLINK/4/FCLINK_FLOGI_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FLOGI was rejected because the hardware resource is not enough.
Explanation
This event occurs if an FLOGI packet is received when hardware resources are insufficient.
Recommended action
FCZONE messages
This section contains FC zone messages.
FCZONE_HARDZONE_DISABLED
Message text
VSAN [UINT16]: No enough hardware resource for zone rule, switched to soft zoning.
Variable fields
$1: VSAN ID.
Severity level
2
Example
FCZONE/2/FCZONE_HARDZONE_DISABLED: VSAN 2: No enough hardware resource for zone rule, switched to soft zoning.
Explanation
This event occurs when hardware resources are insufficient.
Recommended action
Activate a smaller zone set.
FCZONE_HARDZONE_ENABLED
Message text
VSAN [UINT16]: Hardware resource for zone rule is restored, switched to hard zoning.
Variable fields
$1: VSAN ID.
Severity level
1
Example
FCZONE/1/FCZONE_HARDZONE_ENABLED: VSAN 2: Hardware resource for zone rule is restored, switched to hard zoning.
Explanation
Hard zoning in the VSAN was enabled because hardware resources were restored.
Recommended action
FIPS messages
This section contains FIP snooping messages.
FCOE_FIPS_HARD_RESOURCE_NOENOUGH
Message text
No enough hardware resource for FIP Snooping rule.
Variable fields
N/A
Severity level
4
Example
FIPS/4/FCOE_FIPS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for FIP Snooping rule.
Explanation
This message is generated if hardware resources are insufficient.
Recommended action
FCOE_FIPS_HARD_RESOURCE_RESTORE
Message text
Hardware resource for FIP Snooping rule is restored.
Variable fields
N/A
Severity level
6
Example
FIPS/6/FCOE_FIPS_HARD_RESOURCE_RESTORE: Hardware resource for FIP Snooping is restored.
Explanation
This message is generated when hardware resources for FIP snooping rules are restored.
Recommended action
FTP messages
This section contains FTP messages.
FTP_REACH_SESSION_LIMIT
Message text
FTP client [IPADDR] failed to log in. Number of FTP sessions reached the limit.
Variable fields
$1: IP address of an FTP client.
Severity level
6
Example
FTPD/6/FTPD_REACH_SESSION_LIMIT: FTP client 1.1.1.1 failed to log in. Number of FTP sessions reached the limit.
Explanation
Number of online FTP users already reached the limit.
Recommended action
HA messages
This section contains HA messages.
HA_BATCHBACKUP_FINISHED
Message text
Batch backup of standby board in [STRING] is finished.
Variable fields
$1: MPU location.
Severity level
5
Example
HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in chassis 0 slot 1 is finished.
Explanation
Batch backup from the active MPU to the standby MPU was finished.
Recommended action
HA_BATCHBACKUP_STARTED
Message text
Batch backup(s) of standby board(s) in [STRING] started.
Variable fields
$1: MPU location.
Severity level
5
Example
HA/5/HA_BATCHBACKUP_STARTED: Batch backup(s) of standby board(s) in chassis 0 slot 1 started.
Explanation
Batch backup from the active MPU to the standby MPU started.
Recommended action
HA_STANDBY_NOT_READY
Message text
Standby board in [STRING] is not ready, reboot ...
Variable fields
$1: MPU location.
Severity level
4
Example
HA/4/HA_STANDBY_NOT_READY: Standby board in chassis 0 slot 1 is not ready, reboot ...
Explanation
Both the active and standby MPUs were rebooted.
This event occurs if you perform an active/standby switchover while the standby MPU is backing up the configuration in bulk.
Recommended action
Do not perform an active/standby switchover before the standby MPU completes the batch backup.
HA_STANDBY_TO_MASTER
Message text
Standby board in [STRING] changes to master.
Variable fields
$1: MPU location.
Severity level
5
Example
HA/5/HA_STANDBY_TO_MASTER: Standby board in chassis 0 slot 1 changes to master.
Explanation
The standby MPU changed to active.
Recommended action
HTTPD messages
This section contains HTTP daemon messages.
HTTPD_CONNECT
Message text
[STRING] client [STRING] connected to the server successfully.
Variable fields
$1: Connection type, HTTP or HTTPS.
$2: Client IP address.
Severity level
6
Example
HTTPD/6/HTTPD_CONNECT: HTTP client 192.168.30.117 connected to the server successfully.
Explanation
The HTTP or HTTPS server accepted the request from a client. The HTTP or HTTPS connection was set up.
Recommended action
HTTPD_CONNECT_TIMEOUT
Message text
[STRING] client [STRING] connection idle timeout.
Variable fields
Severity level
6
Example
HTTPD/6/HTTPD_CONNECT_TIMEOUT: HTTP client 192.168.30.117 connection to server idle timeout.
Explanation
An HTTP or HTTPS connection was disconnected because its idle timeout timer expired.
Recommended action
No action is required.
HTTPD_DISCONNECT
Message text
[STRING] client [STRING] disconnected from the server.
Variable fields
Severity level
6
Example
HTTPD/6/HTTPD_DISCONNECT: HTTP client 192.168.30.117 disconnected from the server.
Explanation
An HTTP or HTTPS client was disconnected from the server.
Recommended action
HTTPD_FAIL_FOR_ACL
Message text
[STRING] client [STRING] failed the ACL check and could not connect to the server.
Variable fields
Severity level
6
Example
HTTPD/6/HTTPD_FAIL_FOR_ACL: HTTP client 192.168.30.117 failed the ACL check and cannot connect to the server.
Explanation
An HTTP or HTTPS client was filtered by the ACL.
Recommended action
HTTPD_FAIL_FOR_ACP
Message text
[STRING] client [STRING] was denied by the certificate access control policy and could not connect to the server.
Variable fields
Severity level
6
Example
HTTPD/6/HTTPD_FAIL_FOR_ACP: HTTP client 192.168.30.117 was denied by the certificate attribute access control policy and could not connect to the server.
Explanation
An HTTP or HTTPS client was denied by the certificate access control policy.
Recommended action
HTTPD_REACH_CONNECT_LIMIT
Message text
[STRING] client [STRING] failed to connect to the server, because the number of connections reached the upper limit.
Variable fields
Severity level
6
Example
HTTPD/6/HTTPD_REACH_CONNECT_LIMIT: HTTP client 192.168.30.117 failed to connect to the server, because the number of connections reached the upper limit.
Explanation
The number of connections reached the limit.
Recommended action
IFNET messages
This section contains interface management messages.
IFNET_MAD
Message text
Multi-active devices detected, please fix it.
Variable fields
N/A
Severity level
1
Example
IFNET/1/IFNET_MAD: Multi-active devices detected, please fix it.
Explanation
MAD detected multiple identical active IRF fabrics. This message appears when an IRF fabric splits.
Recommended action
Check the IRF connections for a link failure, and use the IRF configuration guide as a reference to merge the split IRF fabrics.
INTERFACE_INSERTED
Message text
Interface [STRING] is inserted.
Variable fields
$1: Interface name.
Severity level
6
Example
IFNET/6/INTERFACE_INSERTED: Interface Ethernet0/1 is inserted.
Explanation
An interface was added.
Recommended action
INTERFACE_REMOVED
Message text
Interface [STRING] is removed.
Variable fields
$1: Interface name.
Severity level
6
Example
IFNET/6/INTERFACE_REMOVED: Interface Ethernet0/1 is removed.
Explanation
An interface was removed.
Recommended action
LINK_UPDOWN
Message text
Line protocol on the interface [STRING] is [STRING].
Variable fields
$1: Interface name.
$2: State of link layer protocol.
Severity level
5
Example
IFNET/5/LINK_UPDOWN: Line protocol on the interface Ethernet0/0 is down.
Explanation
The state of the link layer protocol changed on an interface.
Recommended action
PHY_UPDOWN
Message text
[STRING]: link status is [STRING].
Variable fields
$1: Interface name.
$2: Link state.
Severity level
3
Example
IFNET/3/PHY_UPDOWN: Ethernet0/0: link status is down.
Explanation
The link state changed on an interface.
Recommended action
PROTOCOL_UPDOWN
Message text
Protocol [STRING] on the interface [STRING] is [STRING].
Variable fields
$1: Protocol name.
$2: Interface name.
$3: Protocol state.
Severity level
5
Example
IFNET/5/PROTOCOL_UPDOWN: Protocol IPX on the interface Ethernet6/4/1 is up.
Explanation
The state of a protocol changed on an interface.
Recommended action
IKE messages
This section contains IKE messages.
IKE_P1_SA_ESTABLISH_FAIL
Message text
Failed to establish phase 1 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING].
Variable fields
$1: no matching proposal | invalid ID information | unavailable certificate | unsupported DOI | unsupported situation | invalid proposal syntax | invalid SPI | invalid protocol ID | invalid certificate | authentication failure | invalid message header | invalid transform ID | malformed payload | retransmission timeout | incorrect configuration.
$2: Source address.
$3: Destination address.
Severity level
6
Example
IKE/6/IKE_P1_SA_ESTABLISH_FAIL: Failed to establish phase 1 SA for the reason of no matching proposal. The SA’s source address is 1.1.1.1 and its destination address is 2.2.2.2.
Explanation
An IKE SA was not established because of the displayed reason.
Recommended action
Check the IKE configuration on the local and remote devices.
IKE_P2_SA_ESTABLISH_FAIL
Message text
Failed to establish phase 2 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING].
Variable fields
$1: invalid key information | invalid ID information | unavailable proposal | unsupported DOI | unsupported situation | invalid proposal syntax |  invalid SPI | invalid protocol ID | invalid hash information | invalid message header | malformed payload | retransmission timeout | incorrect configuration.
$2: Source address.
Severity level
6
Example
IKE/6/IKE_P2_SA_ESTABLISH_FAIL: Failed to establish phase 2 SA for the reason of invalid key information. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2.
Explanation
An IPsec SA was not established because of the displayed reason.
Recommended action
Check the IKE and IPsec configurations on the local and remote devices.
IKE_P2_SA_TERMINATE
Message text
The IKE phase 2 SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING].
Variable fields
$1: Reason that the SA is deleted, which is SA expiration.
$2: Source address.
Severity level
6
Example
IKE/6/IKE_P2_SA_TERMINATE: The IKE phase 2 SA was deleted for the reason of SA expiration. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2.
Explanation
An IPsec SA was deleted because it expired.
Recommended action
IPSEC messages
This section contains IPsec messages.
IPSEC_PACKET_DISCARDED
Message text
IPsec packet discarded, Src IP:[STRING], Dst IP:[STRING], SPI:[UINT32], SN:[UINT32], Cause:[STRING].
Variable fields
$1: Source IP address.
$2: Destination IP address.
$3: Security parameter index (SPI).
$4: Sequence number of the packet.
$5: Reason for dropping this packet:
?     Anti-replay checking failed.
?     AH authentication failed.
?     ESP authentication failed.
?     Invalid SA.
?     ESP decryption failed.
?     Source address of packet does not match the SA.
?     No ACL rule matched.
Severity level
6
Example
IPSEC/6/IPSEC_PACKET_DISCARDED: IPsec packet discarded, Src IP:1.1.1.2, Dest IP:1.1.1.4, SPI:1002, SN:0, Cause:ah authentication failed
Explanation
An IPsec packet was dropped. Possible reasons include anti-replay checking failed, AH/ESP authentication failed, invalid SA, ESP decryption failed, source address of packet did not match the SA, and no ACL rule matched.
Recommended action
IPSEC_SA_ESTABLISH
Message text
Established IPsec SA. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32].
Variable fields
$1: Source address.
$2: Destination address.
$3: Security protocol.
$4: SPI.
Severity level
6
Example
IPSEC/6/IPSEC_SA_ESTABLISH: Established IPsec SA. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is AH, and SPI is 2435.
Explanation
An IPsec SA was established.
Recommended action
IPSEC_SA_ESTABLISH_FAIL
Message text
Failed to establish IPsec SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING].
Variable fields
$1: Reason for the IPsec SA establishment failure:
?     Tunnel establishment failure.
?     Incomplete configuration.
?     Unavailable transform set.
$2: Source address.
Severity level
6
Example
IPSEC/6/IPSEC_SA_ESTABLISH_FAIL: Failed to establish IPsec SA for the reason of creating tunnel failure. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2.
Explanation
An IPsec SA was not established. Possible reasons include tunnel establishment failure, incomplete configuration, and unavailable transform set.
Recommended action
Verify the IPsec configuration on the local and remote devices.
IPSEC_SA_INITINATION
Message text
Began to establish IPsec SA. The SA’s source address is [STRING], and its destination address is [STRING].
Variable fields
$1: Source address.
Severity level
6
Example
IPSEC/6/IPSEC_SA_INITINATION: Began to establish IPsec SA. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2.
Explanation
An IPsec SA was being established.
Recommended action
IPSEC_SA_TERMINATE
Message text
The IPsec SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32].
Variable fields
$1: Reason for the IPsec SA removal:
?     SA idle timeout.
?     reset command executed.
$2: Source address.
$4: Security protocol.
$5: SPI.
Severity level
6
Example
IPSEC/6/IPSEC_SA_TERMINATE: The IPsec SA was deleted for the reason of SA idle timeout. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is ESP, and SPI is 34563.
Explanation
An IPsec SA was deleted. Possible reasons include SA idle timeout and using the reset command.
Recommended action
IRDP messages
This section contains IRDP messages.
IRDP_EXCEED_ADVADDR_LIMIT
Message text
The number of advertisement addresses on interface [STRING] exceeded the limit 255.
Variable fields
$1: Interface name.
Severity level
6
Example
IRDP/6/IRDP_EXCEED_ADVADDR_LIMIT: The number of advertisement addresses on interface Ethernet1/1/0/2 exceeded the limit 255.
Explanation
The number of addresses to be advertised on an interface exceeded the upper limit.
Recommended action
Remove unused addresses on the interface.
ISIS messages
This section contains IS-IS messages.
ISIS_MEM_ALERT
Message text
ISIS Process receive system memory alert  [STRING] event.
Variable fields
$1: Type of the memory alarm.
Severity level
5
Example
ISIS/5/ISIS_MEM_ALERT: ISIS Process receive system memory alert start event.
Explanation
Recommended action
ISIS_NBR_CHG
Message text
IS-IS [UINT32], [STRING] adjacency %s (%s), state change to: %s.
Variable fields
$1: IS-IS process ID.
$2: Neighbor level.
$2: Neighbor ID.
$3: Interface name.
$4: Current adjacency state.
Severity level
5
Example
ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-1 adjacency 0000.0000.8888 (Eth1/4/1/3), state change to:DOWN.
Explanation
The IS-IS adjacency state changed on an interface.
Recommended action
When the adjacency with a neighbor changes to down on an interface, check for IS-IS configuration errors and loss of network connectivity.
L2VPN messages
This section contains L2VPN messages.
L2VPN_HARD_RESOURCE_NOENOUGH
Message text
No enough hardware resource for L2VPN.
Variable fields
N/A
Severity level
4
Example
L2VPN/4/L2VPN_HARD_RESOURCE_NOENOUGH: No enough hardware resource for L2VPN.
Explanation
Hardware resources for L2VPN were insufficient.
Recommended action
Check whether unnecessary VSIs, PWs, or ACs had been generated. If yes, delete them.
L2VPN_HARD_RESOURCE_RESTORE
Message text
Hardware resource for L2VPN is restored.
Variable fields
N/A
Severity level
6
Example
L2VPN/6/L2VPN_HARD_RESOURCE_RESTORE: Hardware resource for L2VPN is restored.
Explanation
Hardware resources for L2VPN restored.
Recommended action
LAGG messages
This section contains link aggregation messages.
LAGG_ACTIVE
Message text
Member port [STRING] of aggregation group [STRING] became active.
Variable fields
$1: Port name.
$2: Link aggregation group type and ID.
Severity level
6
Example
LAGG/6/LAGG_ACTIVE: Member port FGE1/0/50 of aggregation group BAGG1 became active.
Explanation
A member port in an aggregation group changed to the Selected state.
Recommended action
LAGG_INACTIVE_AICFG
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of the port is different from that of the aggregation group.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_AICFG: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of the port is different from that of the aggregation group.
Explanation
A member port in an aggregation group changed to the Unselected state because the member port and the aggregate interface had different attribute configurations.
Recommended action
Modify the attribute configurations of the member port to be consistent with the aggregate interface.
LAGG_INACTIVE_CONFIGURATION
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration on the port is improper.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration on the port is improper.
Explanation
A member port in an aggregation group changed to the Unselected state because the member port and the aggregate interface had different aggregation configuration.
Recommended action
LAGG_INACTIVE_DUPLEX
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the duplex mode configuration on the port is improper.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_DUPLEX: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the duplex mode configuration on the port is improper.
Explanation
A member port in an aggregation group changed to the Unselected state because the duplex mode was different between the member port and the Selected ports.
Recommended action
Change the duplex mode of the member port to be the same as the Selected ports.
LAGG_INACTIVE_HARDWAREVALUE
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the hardware restriction on the port is improper.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_HARDWAREVALUE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the hardware restriction on the port is improper.
Explanation
A member port in an aggregation group changed to the Unselected state because of the port's hardware restriction.
Recommended action
LAGG_INACTIVE_LOWER_LIMIT
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports is below the lower limit.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_LOWER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports is below the lower limit.
Explanation
A member port in an aggregation group was placed in Unselected state because the required minimum number of Selected ports was not reached.
Recommended action
Make sure the minimum number of Selected ports is met.
LAGG_INACTIVE_PARTNER
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of its partner is improper.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of its partner is improper.
Explanation
A member port in an aggregation group changed to the Unselected state because the port's partner changed to the Unselected state.
Recommended action
LAGG_INACTIVE_PHYSTATE
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the physical state of the port is down.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the physical state of the port is down.
Explanation
A member port in an aggregation group changed to the Unselected state because the port went down.
Recommended action
Bring up the member port.
LAGG_INACTIVE_RESOURCE_INSUFICIE
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because all aggregate resources are occupied.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_RESOURCE_INSUFICIE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because all aggregate resources are occupied.
Explanation
A member port in an aggregation group changed to the Unselected state because all aggregation resources were used.
Recommended action
LAGG_INACTIVE_SPEED
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the speed configuration on the port is improper.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_SPEED: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the speed configuration on the port is improper.
Explanation
A member port in an aggregation group changed to the Unselected state because the speed was different between the member port and the Selected ports.
Recommended action
Change the speed of the member port to be the same as the Selected ports.
LAGG_INACTIVE_UPPER_LIMIT
Message text
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports has reached the upper limit.
Variable fields
$1: Port name.
Severity level
6
Example
LAGG/6/LAGG_INACTIVE_UPPER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports has reached the upper limit.
Explanation
The number of Selected ports reached the upper limit in a dynamic aggregation group. A member port in the aggregation group changed to the Unselected state because a more eligible port joined the aggregation group.
Recommended action
LDP messages
This section contains LDP messages.
LDP_SESSION_CHG
Message text
Session ([STRING], [STRING]) is [STRING].
Variable fields
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained.
$2: VPN instance's name. Value public instance indicates that the session belongs to the public network.
$3: State of the session, up or down. When the state is down, the reason why the session becomes down is bracketed. Reasons include:
?     interface not operational.
?     MPLS disabled on interface.
?     LDP disabled on interface.
?     LDP auto-configure disabled on interface.
?     VPN instance changed on interface.
?     LDP instance deleted.
?     targeted peer deleted.
?     L2VPN disabled targeted peer.
?     TE tunnel disabled targeted peer.
?     session protection disabled targeted peer.
?     process deactivated.
?     failed to receive the initialization message.
?     graceful restart reconnect timer expired.
?     failed to recover adjacency by NSR.
?     failed to upgrade session by NSR.
?     closed the GR session.
?     keepalive hold timer expired.
?     adjacency hold timer expired.
?     session reset manually.
?     TCP connection down.
?     received a fatal notification message.
?     internal error.
?     memory in critical state.
?     transport address changed on interface.
Severity level
5
Example
LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, public instance) is up.
LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, VPN instance: vpn1) is down (hello hold timer expired).
Explanation
The session state changed.
Recommended action
1.     When the session state comes up, no action is required.
2.     When the session state goes down, check the interface state, link state, and other configurations depending on the reason displayed.
LDP_SESSION_GR
Message text
Session ([STRING], [STRING]): ([STRING]).
Variable fields
$3: State of the session graceful restart:
?     Start reconnection.
?     Reconnection failed.
?     Start recovery.
?     Recovery completed.
Severity level
5
Example
LDP/5/LDP_SESSION_GR: Session (22.22.22.2:0, VPN instance: vpn1): Start reconnection.
Explanation
When a GR-capable LDP session went down, LDP GR started. This message is generated during the GR of the LDP session, indicating the current GR state.
Recommended action
1.     Check for the reason of session graceful restart, which can be obtained from the LDP_SESSION_CHG log message.
2.     When the graceful restart state Reconnection failed is displayed, verify the interface state, link state, and other configurations according to the reason for the session graceful restart. No action is required for other graceful restart states.
LDP_SESSION_SP
Message text
Variable fields
$3: State of the session protection:
?     Hold up the session.
?     Session recovered successfully.
?     Session recovery failed.
Severity level
5
Example
LDP/5/LDP_SESSION_SP: Session (22.22.22.2:0, VPN instance: vpn1): Hold up the session.
Explanation
When the last hello adjacency of the session was removed, session protection started. This message is generated during the session protection process, indicating the current session protection state.
Recommended action
Verify the interface state and link state.
LDP_MPLSLSRID_CHG
Message text
Please reset LDP sessions if you want to make the new MPLS LSR ID take effect.
Variable fields
N/A
Severity level
5
Example
LDP/5/LDP_MPLSLSRID_CHG: -MDC=1; Please reset LDP sessions if you want to make the new MPLS LSR ID take effect.
Explanation
If you configure an LDP LSR ID by using the lsr-id command in LDP view or LDP-VPN instance view, LDP uses the LDP LSR ID. If no LDP LSR ID is configured, LDP uses the MPLS LSR ID configured by the mpls lsr-id command.
If no LDP LSR ID is configured, this message is sent when the MPLS LSR ID is modified.
Recommended action
1.     Execute the display mpls ldp parameter [ vpn-instance vpn-instance-name ] command to display the LSR ID.
2.     Check whether the LSR ID is the same as the configured MPLS LSR ID.
If they are not the same, reset LDP sessions by executing the reset mpls ldp command.
LICENSE messages
This section contains license messages.
LIC_INIT
Message text
[STRING]
Variable fields
$1: Reason that causes license process failure:
·     Failed to create hash.
·     Failed to create socket server.
·     Failed to create fifo pipe.
·     Failed to create check process.
·     Failed to process config file.
·     Failed to process data file.
·     Failed to parse config file.
·     Failed to read config file.
·     Failed to open product policy so.
·     Failed to get product policy function.
·     Failed to get product config parameter.
·     Failed to get product config parameter number.
·     Failed to parse product config parameter.
·     Failed to read PID.
·     Failed to create epoll and errno=[ULONG].
·     The epoll process fails and the license task will exit.
·     Failed to load storage data.
·     Failed to update storage data.
·     Failed to synchronize standby board data.
Severity level
3
Example
LIC/3/ LICENSE: Failed to create hash.
Explanation
The message appears when the license process fails.
Recommended action
Record the message and contact H3C Support.
LLDP messages
This section contains LLDP messages.
LLDP_CREATE_NEIGHBOR
Message text
[STRING] agent new neighbor created on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING].
Variable fields
$1: Agent type.
$2: Port name.
$3: Port ifIndex.
$4: Neighbor's chassis ID.
$5: Neighbor's port ID.
Severity level
6
Example
LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5.
Explanation
The port received an LLDP message from a new neighbor.
Recommended action
LLDP_DELETE_NEIGHBOR
Message text
[STRING] agent neighbor deleted on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING].
Variable fields
$1: Agent type.
$2: Port name.
$3: Port ifIndex.
Severity level
6
Example
LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5.
Explanation
The port received a deletion message when a neighbor was deleted.
Recommended action
LLDP_LESS_THAN_NEIGHBOR_LIMIT
Message text
The number of [STRING] agent neighbors maintained by port [STRING] (IfIndex [UINT32]) is less than [UINT32], and new neighbors can be added.
Variable fields
$1: Agent type.
$2: Port name.
$3: Port ifIndex.
$4: Maximum number of neighbors a port can maintain.
Severity level
6
Example
LLDP/6/LLDP_LESS_THAN_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by port 1 (IfIndex 587599) is less than 16, and new neighbors can be added.
Explanation
New neighbors can be added for the port because the limit has not been reached.
Recommended action
LLDP_NEIGHBOR_AGE_OUT
Message text
[STRING] agent neighbor aged out on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING].
Variable fields
$1: Agent type.
$2: Port name.
$3: Port ifIndex.
Severity level
5
Example
LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on Port Ten-GigabitEthernet10/0/15 (IfIndex599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5.
Explanation
This message is generated when the port failed to receive LLDPDUs from the neighbor within a certain period of time.
Recommended action
Verify the link status or the receive/transmit status of LLDP on the peer.
LLDP_PVID_INCONSISTENT
Message text
The PVID of port [STRING] (IfIndex [ULONG]) is inconsistent with it's neighbor's.
Variable fields
$1: Port name.
$2: Port ID.
Severity level
5
Example
LLDP/5/LLDP_PVID_INCONSISTENT: -MDC=1; The PVID of
port Ten-GigabitEthernet2/0/6 (IfIndex 7) is inconsistent with it's neighbor's.
Explanation
This message is generated when a Layer 2 interface receives an LLDP packet that contains a PVID different from the local PVID.
Recommended action
Configure the same PVID for the local and peer interfaces.
LLDP_REACH_NEIGHBOR_LIMIT
Message text
The number of [STRING] agent neighbors maintained by the port [STRING] (IfIndex [UINT32]) has reached [UINT32], and no more neighbors can be added.
Variable fields
$1: Agent type.
$2: Port name.
$3: Port ifIndex.
Severity level
5
Example
LLDP/5/LLDP_REACH_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by the port Ten-GigabitEthernet1/0/15 (IfIndex 15) has reached 5, and no more neighbors can be added.
Explanation
This message is generated when the port with its maximum number of neighbors reached received an LLDP packet.
Recommended action
LOAD messages
This section contains load management messages.
BOARD_LOADING
Message text
Board is loading file on Chassis [INT32] Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
4
Example
LOAD/4/BOARD_LOADING: Board is loading file on Chassis 1 Slot 5.
Explanation
The specified card is loading files because of a reboot.
Recommended action
LOAD_FAILED
Message text
Board failed to load file on Chassis [INT32] Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
3
Example
LOAD/3/LOAD_FAILED: Board failed to load file on Chassis 1 Slot 5.
Explanation
The specified card failed to load files.
Recommended action
Check for the fault and fix it.
LOAD_FINISHED
Message text
Board has finished loading file on Chassis [INT32] Slot [INT32].
Variable fields
$1: Chassis ID.
$2: Slot ID.
Severity level
5
Example
LOAD/5/LOAD_FINISHED: Board has finished loading file on Chassis 1 Slot 5.
Explanation
The specified card has finished loading files.
Recommended action
LOGIN messages
This section contains login messages.
LOGIN_FAILED
Message text
[STRING] failed to login from [STRING].
Variable fields
$1: Username.
$2: Line name or IP address.
Severity level
5
Example
LOGIN/5/LOGIN_FAILED: TTY failed to log in from console0.
LOGIN/5/LOGIN_FAILED: usera failed to log in from 192.168.11.22.
Explanation
A login attempt failed.
Recommended action
LPDT messages
This section contains loop detection messages.
LPDT_LOOPED
Message text
Loopback exists on [STRING].
Variable fields
$1: Interface name.
Severity level
4
Example
LPDT/4/LPDT_LOOPED:  Loopback exists on Ethernet 6/4/2.
Explanation
A loop was detected on a port.
Recommended action
Check the links and configuration on the device for the loop, and remove the loop.
LPDT_RECOVERED
Message text
Loopback on [STRING] recovered.
Variable fields
$1: Interface name.
Severity level
5
Example
LPDT/5/LPDT_RECOVERED: Loopback on Ethernet 6/4/1 recovered.
Explanation
A loop on a port was removed.
Recommended action
LS messages
This section contains Local Server messages.
LS_ADD_USER_TO_GROUP
Message text
Admin [STRING] added user [STRING] to group [STRING].
Variable fields
$1: Admin name.
$2: User name.
$3: User group name.
Severity level
4
Example
LS/4/LS_ADD_USER_TO_GROUP: Admin admin added user user1 to group group1.
Explanation
The administrator added a user into a user group.
Recommended action
LS_AUTHEN_FAILURE
Message text
User [STRING] from [STRING] failed authentication. [STRING]
Variable fields
$1: User name.
$2: IP address.
$3: Reason of failure:
?     "User not found."
?     "Password verified failed."
?     "User not active."
?     "Access type mismatch."
?     "Binding attribute is failed."
?     "User in blacklist."
Severity level
5
Example
LS/5/LS_AUTHEN_FAILURE: User cwf@system from 192.168.0.22 failed authentication. "User not found."
Explanation
The local server rejected a user's authentication request.
Recommended action
LS_AUTHEN_SUCCESS
Message text
User [STRING] from [STRING] was authenticated successfully.
Variable fields
$1: User name.
$2: IP address.
Severity level
6
Example
LS/6/LS_AUTHEN_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully.
Explanation
The local server accepted a user's authentication request.
Recommended action
LS_DEL_USER_FROM_GROUP
Message text
Admin [STRING] delete user [STRING] from group [STRING].
Variable fields
$1: Admin name.
$2: User name.
Severity level
4
Example
LS/4/LS_DEL_USER_FROM_GROUP: Admin admin delete user user1 from group group1.
Explanation
The administrator deleted a user from a user group.
Recommended action
LS_DELETE_PASSWORD_FAIL
Message text
Failed to delete the password for user [STRING].
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_DELETE_PASSWORD_FAIL: Failed to delete the password for user abcd.
Explanation
Failed to delete the password for a user.
Recommended action
Check the file system for errors.
LS_PWD_ADDBLACKLIST
Message text
User [STRING] was added to the blacklist due to multiple login failures, [STRING].
Variable fields
$1: User name.
$2: Options include:
?     but could make other attempts.
?     and is permanently blocked.
?     and was temporarily blocked for [UINT32] minutes.
Severity level
4
Example
LS/4/LS_PWD_ADDBLACKLIST: user1 was added to the blacklist due to multiple login failures, but could make other attempts.
Explanation
A user was added to the blacklist because of multiple login failures.
Recommended action
Check the user's password.
LS_PWD_CHGPWD_FOR_AGEDOUT
Message text
User [STRING] changed the password because it was expired.
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_PWD_CHGPWD_FOR_AGEDOUT: aaa changed the password because it was expired.
Explanation
A user changed the password because the password expired.
Recommended action
LS_PWD_CHGPWD_FOR_AGEOUT
Message text
User [STRING] changed the password because it was about to expire.
Variable fields
$1: User name.
$2: Aging time.
Severity level
4
Example
LS/4/LS_PWD_CHGPWD_FOR_AGEOUT: aaa changed the password because it was about to expire.
Explanation
A user changed the password because the password is about to expire.
Recommended action
LS_PWD_CHGPWD_FOR_COMPOSITION
Message text
User [STRING] changed the password because it had an invalid composition.
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_PWD_CHGPWD_FOR_COMPOSITION: aaa changed the password because it had an invalid composition.
Explanation
A user changed the password because it had an invalid composition.
Recommended action
LS_PWD_CHGPWD_FOR_FIRSTLOGIN
Message text
User [STRING] changed the password at the first login.
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_PWD_CHGPWD_FOR_FIRSTLOGIN: aaa changed the password at the first login.
Explanation
A user changed the password at the first login.
Recommended action
LS_PWD_CHGPWD_FOR_LENGTH
Message text
User [STRING] changed the password because it was too short.
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_PWD_CHGPWD_FOR_LENGTH: aaa changed the password because it was too short.
Explanation
A user changed the password because it was too short.
Recommended action
LS_PWD_FAILED2WRITEPASS2FILE
Message text
Failed to write the password records to file.
Variable fields
N/A
Severity level
4
Example
LS/4/LS_PWD_FAILED2WRITEPASS2FILE: Failed to write the password records to file.
Explanation
Recommended action
LS_PWD_MODIFY_FAIL
Message text
Admin [STRING] from [STRING] could not modify the password for user [STRING], because [STRING].
Variable fields
$1: Admin name.
$2: IP address.
$3: User name.
$4: Reason. Options include:
?     passwords did not match.
?     the password history cannot be written.
?     the password cannot be verified.
Severity level
4
Example
LS/4/LS_PWD_MODIFY_FAIL: Admin admin from 1.1.1.1 could not modify the password for user user1, because passwords do not match.
Explanation
An administrator failed to modify a user's password.
Recommended action
LS_PWD_MODIFY_SUCCESS
Message text
Admin [STRING] from [STRING] modify the password for user [STRING] successfully.
Variable fields
$1: Admin name.
$2: IP address.
$3: User name.
Severity level
6
Example
LS/6/LS_PWD_MODIFY_SUCCESS: Admin admin from 1.1.1.1 modify the password for user abc successfully.
Explanation
An administrator successfully modified a user's password.
Recommended action
LS_REAUTHEN_FAILURE
Message text
User [STRING] from [STRING] failed reauthentication.
Variable fields
$1: User name.
$2: IP address.
Severity level
5
Example
LS/5/LS_REAUTHEN_FAILURE: User abcd from 1.1.1.1 failed reauthentication.
Explanation
A user failed reauthentication because the old password entered for reauthentication is invalid.
Recommended action
Check the old password.
LS_UPDATE_PASSWORD_FAIL
Message text
Failed to update the password for user [STRING].
Variable fields
$1: User name.
Severity level
4
Example
LS/4/LS_UPDATE_PASSWORD_FAIL: Failed to update the password for user abc.
Explanation
Failed to update the password for a user.
Recommended action
LS_USER_CANCEL
Message text
User [STRING] from [STRING] cancelled inputting the password.
Variable fields
$1: User name.
$2: IP address.
Severity level
5
Example
LS/5/LS_USER_CANCEL: User 1 from 1.1.1.1 cancelled inputting the password.
Explanation
The user cancelled inputting the password or did not input the password in 90 seconds.
Recommended action
LS_USER_PASSWORD_EXPIRE
Message text
User [STRING]'s login idle timer timed out.
Variable fields
$1: User name.
Severity level
5
Example
LS/5/LS_USER_PASSWORD_EXPIRE: User 1's login idle timer timed out.
Explanation
The login idle time for a user expired.
Recommended action
LS_USER_ROLE_CHANGE
Message text
Admin [STRING] [STRING] the user role [STRING] for [STRING].
Variable fields
$1: Admin name.
$2: Added/Deleted.
$3: User role.
$4: User name.
Severity level
4
Example
LS/4/LS_USER_ROLE_CHANGE: Admin admin add user role network-admin for user abcd.
Explanation
The administrator added a user role for a user.
Recommended action
LSPV messages
This section contains LSP verification messages.
LSPV_PING_STATIS_INFO
Message text
Ping statistics for [STRING]: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max = [UINT32]/[ UINT32]/[ UINT32] ms.
Variable fields
$1: FEC.
$2: Number of echo requests sent.
$3: Number of echo replies received.
$4: Percentage of the non-replied packets to the total requests.
$5: Minimum round-trip delay.
$6: Average round-trip delay.
$7: Maximum round-trip delay.
Severity level
6
Example
LSPV/6/LSPV_PING_STATIS_INFO: Ping statistics for FEC 192.168.1.1/32: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max = 1/2/5 ms.
Explanation
Ping statistics for an LSP tunnel or a PW.
This message is generated when the ping mpls command is executed.
Recommended action
If no reply is received, verify the connectivity of the LSP tunnel or the PW.
MAC messages
This section contains MAC messages.
MAC_TABLE_FULL_GLOBAL
Message text
MAC address table exceeded maximum number [UINT32].
Variable fields
$1: Maximum number of MAC addresses.
Severity level
4
Example
MAC/4/MAC_TABLE_FULL_GLOBAL: MAC address table exceeded maximum number 2.
Explanation
The number of entries in the global MAC address table exceeded the upper limit.
Recommended action
MAC_TABLE_FULL_PORT
Message text
MAC address table exceeded maximum number [UINT32] on interface [STRING].
Variable fields
$2: Interface name.
Severity level
4
Example
MAC/4/MAC_TABLE_FULL_PORT: MAC address table exceeded maximum number 2 on interface GigabitEthernet2/0/32.
Explanation
The number of entries in the MAC address table for an interface exceeded the upper limit.
Recommended action
MAC_TABLE_FULL_VLAN
Message text
MAC address table exceeded maximum number [UINT32] on Vlan [UINT32].
Variable fields
$2: VLAN ID.
Severity level
4
Example
MAC/4/MAC_TABLE_FULL_VLAN: MAC address table exceeded maximum number 2 on Vlan 2.
Explanation
The number of entries in the MAC address table for a VLAN exceeded the upper limit.
Recommended action
MACA messages
This section contains MAC authentication messages.
MACA_ENABLE_NOT_EFFECTIVE
Message text
MAC authentication is enabled but is not effective on interface [STRING].
Variable fields
$1: Interface type and number.
Severity level
3
Example
MACA/3/MACA_ENABLE_NOT_EFFECTIVE: MAC authentication is enabled but is not effective on interface Ethernet3/1/2.
Explanation
MAC authentication configuration does not take effect on an interface, because the interface does not support MAC authentication.
Recommended action
1.     Disable MAC authentication on the interface.
2.     Reconnect the connected devices to an interface that supports MAC authentication.
3.     Enable MAC authentication on the new interface.
MACA_LOGIN_FAILURE
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; User failed MAC authentication.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
$5: User account format.
Severity level
6
Example
MACA/6/MACA_LOGIN_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; User failed MAC authentication.
Explanation
A user failed MAC authentication.
Recommended action
Locate the failure cause and handle the problem according to the failure cause.
MACA_LOGIN_SUCC
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; User passed MAC authentication and came online.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
Severity level
6
Example
MACA/6/MACA_LOGIN_SUCC:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; User passed MAC authentication and came online.
Explanation
A user passed MAC authentication.
Recommended action
MACA_LOGOFF
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-Username=[STRING]-UsernameFormat=[STRING]; MAC authentication user was logged off.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Username.
Severity level
6
Example
MACA/6/MACA_LOGOFF:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-Username=00-10-84-00-22-b9-UsernameFormat=MAC address; MAC authentication user was logged off.
Explanation
A MAC authentication user was logged off.
Recommended action
Locate the logoff cause and remove the problem. If the logoff was requested by the user, no action is required.
MBFD messages
This section contains MPLS BFD messages.
MBFD_TRACEROUTE_FAILURE
Message text
[STRING] in failure. ([STRING].)
Variable fields
$1: LSP information.
$2: Reason for the LSP failure.
Severity level
5
Example
MBFD/5/MBFD_TRACEROUTE_FAILURE: LSP (LDP IPv4: 22.22.2.2/32, nexthop: 20.20.20.2) in failure. (Replying router has no mapping for the FEC.)
MBFD/5/MBFD_TRACEROUTE_FAILURE: TE tunnel (RSVP IPv4: Tunnel1) in failure. (No label entry.)
Explanation
LSP/MPLS TE tunnel failure was detected by periodic MPLS traceroute. This message is generated when the system receives an MPLS echo reply with an error return code.
Recommended action
Verify the configuration for the LSP or MPLS TE tunnel.
MDC messages
This section contains MDC messages.
MDC_CREATE
Message text
MDC [UINT16] is created.
Variable fields
$1: MDC ID.
Severity level
5
Example
MDC/5/MDC_CREATE: MDC 2 is created.
Explanation
An MDC was created successfully.
Recommended action
MDC_CREATE_ERR
Message text
Failed to create MDC [UINT16] for not enough resources.
Variable fields
$1: MDC ID.
Severity level
5
Example
MDC/5/MDC_CREATE_ERR: Failed to create MDC 2 for not enough resources.
Explanation
The standby MPU did not have enough resources to create the MDC.
At startup, the standby MPU obtains MDC configuration information from the active MPU and tries to create the same MDCs. If the standby MPU does not have enough resources to create an MDC, it outputs this log message.
Recommended action
1.     Use the display mdc resource command to display the CPU, memory, and disk space resources on the standby MPU.
2.     Perform one of the following tasks:
?     If the memory space is insufficient, increase the memory space. If the disk space is insufficient, delete unused files.
?     Use the undo mdc command to remove the specified MDC.
3.     Remove the standby MPU.
MDC_DELETE
Message text
MDC [UINT16] is deleted.
Variable fields
$1: MDC ID.
Severity level
5
Example
MDC/5/MDC_DELETE: MDC 2 is deleted.
Explanation
An MDC was deleted successfully.
Recommended action
MDC_LICENSE_EXPIRE
Message text
The MDC feature's license will expire in [UINT32] days.
Variable fields
$1: Number of days, in the range of 1 to 30.
Severity level
5
Example
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature's license will expire in 5 days.
Explanation
The license for the MDC feature was about to expire.
Recommended action
MDC_NO_FORMAL_LICENSE
Message text
The feature MDC has no available formal license.
Variable fields
N/A
Severity level
5
Example
MDC/5/MDC_NO_FORMAL_LICENSE: The feature MDC has no available formal license.
Explanation
The standby MPU became the active MPU but it did not have a formal license. The MDC feature has a free trial period. To use the feature after the period elapses, you must install a license for the standby MPU.
Recommended action
Install a formal license.
MDC_NO_LICENSE_EXIT
Message text
The MDC feature is being disabled, because it has no license.
Variable fields
N/A
Severity level
5
Example
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature is being disabled, because it has no license.
Explanation
The MDC feature was disabled because the license for the MDC feature expired or was uninstalled.
Recommended action
Install the required license.
MDC_OFFLINE
Message text
MDC [UINT16] is offline now.
Variable fields
$1: MDC ID.
Severity level
5
Example
MDC/5/MDC_OFFLINE: MDC 2 is offline now.
Explanation
An MDC was stopped.
Recommended action
MDC_ONLINE
Message text
MDC [UINT16] is online now.
Variable fields
$1: MDC ID.
Severity level
5
Example
MDC/5/MDC_ONLINE: MDC 2 is online now.
Explanation
An MDC was started.
Recommended action
MDC_STATE_CHANGE
Message text
MDC [UINT16] state changed to [STRING].
Variable fields
$1: MDC ID.
$2: Current status.
Severity level
5
Example
MDC/5/MDC_STATE_CHANGE: MDC 2 state changed to active.
Explanation
The status of an MDC changed.
Recommended action
MFIB messages
This section contains MFIB messages.
MFIB_MEM_ALERT
Message text
MFIB Process receive system memory alert  [STRING] event.
Variable fields
$1: Type of the memory alert event.
Severity level
5
Example
MFIB/5/MFIB_MEM_ALERT: MFIB Process receive system memory alert start event.
Explanation
MFIB received a memory alert event from the system.
Recommended action
MGROUP messages
This section contains mirroring group messages.
MGROUP_APPLY_SAMPLER_FAIL
Message text
Failed to apply the sampler for mirroring group [UINT16], because the sampler resources are insufficient.
Variable fields
$1: Mirroring group ID.
Severity level
3
Example
MGROUP/3/MGROUP_APPLY_SAMPLER_FAIL: Failed to apply the sampler for mirroring group 1, because the sampler resources are insufficient.
Explanation
A sampler was not applied to the mirroring group because the sampler resources were insufficient.
Recommended action
MGROUP_RESTORE_CPUCFG_FAIL
Message text
Failed to restore configuration for mirroring CPU of [STRING] in mirroring group [UINT16], because [STRING]
Variable fields
$1: Slot number.
$2: Mirroring group ID.
$3: Failure reason.
Severity level
3
Example
MGROUP/3/MGROUP_RESTORE_CPUCFG_FAIL: Failed to restore configuration for mirroring CPU of chassis 1 slot 2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported.
Explanation
When the CPU of the card in the slot is the source CPU in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the source CPU configuration might fail.
Recommended action
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the source CPU in the mirroring group.
MGROUP_RESTORE_IFCFG_FAIL
Message text
Failed to restore configuration for interface [STRING] in mirroring group [UINT16], because [STRING]
Variable fields
$1: Interface name.
$3: Failure reason.
Severity level
3
Example
MGROUP/3/MGROUP_RESTORE_IFCFG_FAIL: Failed to restore configuration for interface Ethernet3/1/2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported.
Explanation
When the interface of the card in the slot is the monitor port in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the monitor port configuration might fail.
Recommended action
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the monitor port in the mirroring group.
MGROUP_SYNC_CFG_FAIL
Message text
Failed to restore configuration for mirroring group [UINT16] in [STRING], because [STRING]
Variable fields
$2: Slot number.
$3: Failure reason.
Severity level
3
Example
MGROUP/3/MGROUP_SYNC_CFG_FAIL: Failed to restore configuration for mirroring group 1 in chassis 1 slot 2, because monitor resources are insufficient.
Explanation
When the complete mirroring group configuration was synchronized on the card in the slot, restoring configuration failed because resources on the card were insufficient.
Recommended action
Delete the mirroring group.
MPLS messages
This section contains MPLS messages.
MPLS_HARD_RESOURCE_NOENOUGH
Message text
No enough hardware resource for MPLS.
Variable fields
N/A
Severity level
4
Example
MPLS/4/MPLS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for MPLS.
Explanation
Hardware resources for MPLS were insufficient.
Recommended action
Check whether unnecessary LSPs had been generated. If yes, configure or modify the LSP generation policy, label advertisement policy, and label acceptance policy to filter out unnecessary LSPs.
MPLS_HARD_RESOURCE_RESTORE
Message text
Hardware resource for MPLS is restored.
Variable fields
N/A
Severity level
6
Example
MPLS/6/MPLS_HARD_RESOURCE_RESTORE: Hardware resource for MPLS is restored.
Explanation
Hardware resources for MPLS restored.
Recommended action
MSTP messages
This section contains MSTP messages.
MSTP_BPDU_PROTECTION
Message text
BPDU-Protection port [STRING] received BPDUs.
Variable fields
$1: Interface name.
Severity level
4
Example
MSTP/4/MSTP_BPDU_PROTECTION: BPDU-Protection port Ethernet 1/0/4 received BPDUs.
Explanation
A BPDU-guard-enabled port received BPDUs.
Recommended action
Check whether the downstream device is a terminal and check for possible attacks from the downstream device or other devices.
MSTP_BPDU_RECEIVE_EXPIRY
Message text
Instance [UINT32]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
5
Example
MSTP/5/MSTP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet 0/4/1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out.
Explanation
The state changed because a non-designated port did not receive a BPDU within the max age.
Recommended action
Check the STP status of the upstream device and possible attacks from other devices.
MSTP_DETECTED_TC
Message text
Instance [UINT32]'s port [STRING] detected a topology change.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
6
Example
MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet 0/1/1 detected a topology change.
Explanation
The MSTP instance to which the port belongs had a topology change, and the local end detected the change.
Recommended action
Identify the topology change cause and handle the issue. For example, if the change is caused by a link down event, recover the link.
MSTP_DISABLE
Message text
STP is now disabled on the device.
Variable fields
N/A
Severity level
6
Example
MSTP/6/MSTP_DISABLE: STP is now disabled on the device.
Explanation
STP was disabled globally on the device.
Recommended action
MSTP_DISCARDING
Message text
Instance [UINT32]'s port [STRING] has been set to discarding state.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
6
Example
MSTP/6/MSTP_DISCARDING: Instance 0's port Ethernet 1/0/2 has been set to discarding state.
Explanation
MSTP calculated the state of the ports within the instance, and a port was set to the discarding state.
Recommended action
MSTP_ENABLE
Message text
STP is now enabled on the device.
Variable fields
N/A
Severity level
6
Example
MSTP/6/MSTP_ENABLE: STP is now enabled on the device.
Explanation
STP was enabled globally on the device.
Recommended action
MSTP_FORWARDING
Message text
Instance [UINT32]'s port [STRING] has been set to forwarding state.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
6
Example
MSTP/6/MSTP_FORWARDING: Instance 0's port Ethernet 1/0/2 has been set to forwarding state.
Explanation
MSTP calculated the state of the ports within the instance, a port was set to the forwarding state.
Recommended action
MSTP_LOOP_PROTECTION
Message text
Instance [UINT32]'s LOOP-Protection port [STRING] failed to receive configuration BPDUs.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
4
Example
MSTP/4/MSTP_LOOP_PROTECTION: Instance 0's LOOP-Protection port Ethernet 1/0/2 failed to receive configuration BPDUs.
Explanation
A loop-guard-enabled port failed to receive configuration BPDUs.
Recommended action
MSTP_NOT_ROOT
Message text
The current switch is no longer the root of instance [UINT32].
Variable fields
$1: Instance ID.
Severity level
5
Example
MSTP/5/MSTP_NOT_ROOT: The current switch is no longer the root of instance 0.
Explanation
The current switch is no longer the root bridge of an instance. It received a superior BPDU after it was configured as the root bridge.
Recommended action
Check the bridge priority configuration and possible attacks from other devices.
MSTP_NOTIFIED_TC
Message text
Instance [UINT32]'s port [STRING] was notified of a topology change.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
6
Example
MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet 0/1/1 was notified of a topology change.
Explanation
The neighboring device notified the current device that a topology change occurred in the instance to which the port belongs.
Recommended action
MSTP_ROOT_PROTECTION
Message text
Instance [UINT32]'s ROOT-Protection port [STRING] received superior BPDUs.
Variable fields
$1: Instance ID.
$2: Interface name.
Severity level
4
Example
MSTP/4/MSTP_ROOT_PROTECTION: Instance 0's ROOT-Protection port Ethernet 1/0/2 received superior BPDUs.
Explanation
A root-guard-enabled port received BPDUs that are superior to the BPDUs generated by itself.
Recommended action
MTLK messages
This section contains Monitor Link messages.
MTLK_UPLINK_STATUS_CHANGE
Message text
The uplink of monitor link group [UINT32] is [STRING].
Variable fields
$1: Monitor link group ID.
$2: Monitor Link group status, up or down.
Severity level
6
Example
MTLK/6/MTLK_UPLINK_STATUS_CHANGE: The uplink of monitor link group 1 is up.
Explanation
The uplink status of a monitor link group changed to up or down.
Recommended action
Check a link when it fails.
ND messages
This section contains ND messages.
ND_CONFLICT
Message text
[STRING] is inconsistent
Variable fields
$1: Configuration type:
?     M_FLAG.
?     O_FLAG.
?     CUR_HOP_LIMIT.
?     REACHABLE TIME.
?     NS INTERVAL.
?     MTU.
?     PREFIX VALID TIME.
?     PREFIX PREFERRED TIME.
Severity level
6
Example
ND/6/ND_CONFLICT: PREFIX VALID TIME is inconsistent
Explanation
A router advertisement was received, which caused the configuration inconsistency between neighboring routers.
Recommended action
Verify that the configurations on the device and the neighboring router are consistent.
ND_DUPADDR
Message text
Duplicate address: [STRING] on the interface [STRING]
Variable fields
$1: Address that is to be assigned to an interface.
$2: Name of the interface.
Severity level
6
Example
ND/6/ND_DUPADDR: Duplicate address: 33::8 on interface Vlan-interface9.
Explanation
The address that was to be assigned to the interface is already used by another device.
Recommended action
Assign a different address to the interface.
ND_RAGUARD_DROP
Message text
Dropped RA messages with the source IPv6 address [STRING] on interface [STRING]. [STRING] messages dropped in total on the interface.
Variable fields
$1: Source IP address of the dropped RA messages.
$2: Name of the interface that received the dropped RA messages.
$3: Number of the RA messages dropped on the interface.
Severity level
4
Example
ND/6/ND_RAGUARD_DROP: Dropped RA messages with the source IPv6 address FE80::20 on interface GigabitEthernet0/0/1. 20 messages dropped in total on the interface.
Explanation
Forged RA messages were detected on the interface. The device dropped the forged RA messages and generated a log.
Recommended action
Check the vadility of the device or host that sends the RA messages based on the RA guard configuration.
NQA messages
This section contains NQA messages.
NQA_LOG_UNREACHABLE
Message text
Server [STRING] unreachable.
Variable fields
$1: IP address of the NQA server.
Severity level
6
Example
NQA/6/NQA_LOG_UNREACHABLE: Server 192.168.30.117 unreachable.
Explanation
An unreachable server was detected.
Recommended action
Check the network environment.
NTP messages
This section contains NTP messages.
NTP_CHANGE_LEAP
Message text
System Leap Indicator changed from [UINT32] to [UINT32] after clock update.
Variable fields
$1: Original Leap Indicator.
$2: Current Leap Indicator.
Severity level
5
Example
NTP/5/NTP_CHANGE_LEAP: System Leap Indicator changed from 00 to 01 after clock update.
Explanation
The system Leap Indicator changed. For example, the NTP status changed from unsynchronized to synchronized.
NTP Leap Indicator is a two-bit code warning of an impending leap second to be inserted in the NTP timescale.
The bits are set before 23:59 on the day of insertion and reset after 00:00 on the following day. This causes the number of seconds (rolloverinterval) in the day of insertion to be increased or decreased by one.
Recommended action
NTP_CHANGE_STRATUM
Message text
System stratum changed from [UINT32] to [UINT32] after clock update.
Variable fields
$1: Original stratum.
$2: Current stratum.
Severity level
5
Example
NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 6 to 5 after clock update.
Explanation
System stratum changed.
Recommended action
NTP_CLOCK_CHANGE
Message text
System clock changed from [STRING] to [STRING], the server is [STRING].
Variable fields
$1: Time before synchronization.
$2: Time after synchronization.
$3: IP address.
Severity level
5
Example
NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:12:58 12/28/2012 to 02:29:12 12/28/2012, the server is 192.168.30.116.
Explanation
The NTP server triggered the NTP client to synchronize the client time.
Recommended action
NTP_SOURCE_CHANGE
Message text
NTP server changed from [STRING] to [STRING].
Variable fields
$1: IP address of the original time source.
$2: IP address of the new time source.
Severity level
5
Example
NTP/5/NTP_SOURCE_CHANGE: NTP server changed from 1.1.1.1 to 1.1.1.2.
Explanation
The system changed the time source.
Recommended action
Assign another NTP server as the time source.
NTP_SOURCE_LOST
Message text
Lost synchronization with NTP server [STRING].
Variable fields
$1: IP address.
Severity level
5
Example
NTP/5/NTP_SOURCE_LOST: Lost synchronization with NTP server 1.1.1.1.
Explanation
The clock source of the NTP association is in unsynchronized state or it is unreachable.
Recommended action
Check the NTP server and network connection.
OPTMOD messages
This section contains transceiver module messages.
BIAS_HIGH
Message text
[STRING]: Bias current is high!
Variable fields
Severity level
2
Example
OPTMOD/2/BIAS_HIGH: GigabitEthernet1/0/13: Bias current is high!
Explanation
The bias current of the transceiver module has exceeded the upper limit.
Recommended action
Locate the fault and fix it. If it cannot be fixed, replace the transceiver module.
BIAS_LOW
Message text
[STRING]: Bias current is low!
Variable fields
Severity level
5
Example
OPTMOD/5/BIAS_LOW: GigabitEthernet1/0/13: Bias current is low!
Explanation
The bias current of the transceiver module is below the lower limit.
Recommended action
BIAS_NORMAL
Message text
[STRING]: Bias current is normal!
Variable fields
Severity level
5
Example
OPTMOD/5/BIAS_NORMAL: GigabitEthernet1/0/13: Bias current is normal!
Explanation
The bias current of the transceiver module has returned to the acceptable range.
Recommended action
CFG_ERR
Message text
[STRING]: The transceiver type does not match port configuration!
Variable fields
Severity level
3
Example
OPTMOD/3/CFG_ERR: GigabitEthernet1/0/13: The transceiver type does not match port configuration!
Explanation
The transceiver module type does not match the port configuration.
Recommended action
Identify the reason causing the mismatch and replace the transceiver module.
CHKSUM_ERR
Message text
[STRING]: The checksum of transceiver information is bad!
Variable fields
Severity level
5
Example
OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/13: The checksum of transceiver information is bad!
Explanation
The checksum verification on the register information on the transceiver module failed.
Recommended action
FIBER_SFPMODULE_INVALID
Message text
[STRING]: This transceiver module is not compatible with the interface card. H3C therefore shall NOT guarantee the normal function of the transceiver. The transceiver module will be invalidated in [UINT32] days.
Variable fields
$2: Number of days that the transceiver module will be invalid.
Severity level
4
Example
OPTMOD/4/FIBER_SFPMODULE_INVALID: GigabitEthernet1/0/13: This transceiver module is not compatible with the interface card. H3C therefore shall NOT guarantee the normal function of the transceiver. The transceiver module will be invalidated in 3 days.
Explanation
The transceiver module is not compatible with the interface card.
Recommended action
Replace the transceiver module.
FIBER_SFPMODULE_NOWINVALID
Message text
Variable fields
Severity level
4
Example
OPTMOD/4/FIBER_SFPMODULE_NOWINVALID: GigabitEthernet1/0/13: This transceiver module is not compatible with the interface card. H3C therefore shall NOT guarantee the normal function of the transceiver.
Explanation
Recommended action
IO_ERR
Message text
[STRING]: The transceiver information I/O failed!
Variable fields
Severity level
5
Example
OPTMOD/5/IO_ERR: GigabitEthernet1/0/13: The transceiver information I/O failed!
Explanation
The device failed to access the register information of the transceiver module.
Recommended action
MOD_ALM_OFF
Message text
[STRING]: [STRING] is gone.
Variable fields
$2: Fault type.
Severity level
5
Example
OPTMOD/5/MOD_ALM_OFF: GigabitEthernet1/0/13: Module_not_ready is gone.
Explanation
A fault was removed from the transceiver module.
Recommended action
No action is required.
MOD_ALM_ON
Message text
[STRING]: [STRING] is detected!
Variable fields
$2: Fault type.
Severity level
5
Example
OPTMOD/5/MOD_ALM_ON: GigabitEthernet1/0/13: Module_not_ready is detected!
Explanation
A fault was detected on the transceiver module.
Recommended action
Fix the fault. If it cannot be fixed, replace the transceiver module.
MODULE_IN
Message text
[STRING]: The transceiver is [STRING].
Variable fields
$2: Type of the transceiver module.
Severity level
4
Example
OPTMOD/4/MODULE_IN: GigabitEthernet1/0/13: The transceiver is 1000_BASE_T_AN_SFP.
Explanation
When a transceiver module is inserted, the OPTMOD module generates the message to display the transceiver module type.
Recommended action
MODULE_OUT
Message text
[STRING]: The transceiver is absent.
Variable fields
Severity level
4
Example
OPTMOD/4/MODULE_OUT: GigabitEthernet1/0/13: The transceiver is absent.
Explanation
The transceiver module was removed.
Recommended action
PHONY_MODULE
Message text
[STRING]: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof!
Variable fields
Severity level
4
Example
OPTMOD/4/PHONY_MODULE: GigabitEthernet1/0/13: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof!
Explanation
The transceiver module is not sold by H3C.
Recommended action
Verify the transceiver module compatibility. If it is not compatible, replace it.
RX_ALM_OFF
Message text
Variable fields
$2: RX fault type.
Severity level
5
Example
OPTMOD/5/RX_ALM_OFF: GigabitEthernet1/0/13: RX_not_ready is gone.
Explanation
An RX fault was removed from the transceiver module.
Recommended action
RX_ALM_ON
Message text
Variable fields
$2: RX fault type.
Severity level
5
Example
OPTMOD/5/RX_ALM_ON: GigabitEthernet1/0/13: RX_not_ready is detected!
Explanation
An RX fault was detected on the transceiver module.
Recommended action
RX_POW_HIGH
Message text
[STRING]: RX power is high!
Variable fields
Severity level
5
Example
OPTMOD/5/RX_POW_HIGH: GigabitEthernet1/0/13: RX power is high!
Explanation
The RX power of the transceiver module has exceeded the upper limit.
Recommended action
RX_POW_LOW
Message text
[STRING]: RX power is low!
Variable fields
Severity level
5
Example
OPTMOD/5/RX_POW_LOW: GigabitEthernet1/0/13: RX power is low!
Explanation
The RX power of the transceiver module is below the lower limit.
Recommended action
RX_POW_NORMAL
Message text
[STRING]: RX power is normal!
Variable fields
Severity level
5
Example
OPTMOD/5/RX_POW_NORMAL: GigabitEthernet1/0/13: RX power is normal!
Explanation
The RX power of the transceiver module has returned to the acceptable range.
Recommended action
TEMP_HIGH
Message text
[STRING]: Temperature is high!
Variable fields
Severity level
5
Example
OPTMOD/5/TEMP_HIGH: GigabitEthernet1/0/13: Temperature is high!
Explanation
The temperature of the transceiver module has exceeded  the upper limit.
Recommended action
TEMP_LOW
Message text
[STRING]: Temperature is low!
Variable fields
Severity level
5
Example
OPTMOD/5/TEMP_LOW: GigabitEthernet1/0/13: Temperature is low!
Explanation
The temperature of the transceiver module is below the lower limit.
Recommended action
TEMP_NORMAL
Message text
[STRING]: Temperature is normal!
Variable fields
Severity level
5
Example
OPTMOD/5/TEMP_NORMAL: GigabitEthernet1/0/13: Temperature is normal!
Explanation
The temperature of the transceiver module has returned to the acceptable range.
Recommended action
TX_ALM_OFF
Message text
Variable fields
$2: TX fault type.
Severity level
5
Example
OPTMOD/5/TX_ALM_OFF: GigabitEthernet1/0/13: TX_fault is gone.
Explanation
A TX fault was removed from the transceiver module.
Recommended action
TX_ALM_ON
Message text
Variable fields
$2: TX fault type.
Severity level
5
Example
OPTMOD/5/TX_ALM_ON: GigabitEthernet1/0/13: TX_fault is detected!
Explanation
A TX fault was detected on the transceiver module.
Recommended action
TX_POW_HIGH
Message text
[STRING]: TX power is high!
Variable fields
Severity level
2
Example
OPTMOD/2/TX_POW_HIGH: GigabitEthernet1/0/13: TX power is high!
Explanation
The TX power of the transceiver module has exceeded the upper limit.
Recommended action
Locate the fault and fix it. If it cannot be fixed replace the transceiver module.
TX_POW_LOW
Message text
[STRING]: TX power is low!
Variable fields
Severity level
5
Example
OPTMOD/5/TX_POW_LOW: GigabitEthernet1/0/13: TX power is low!
Explanation
The TX power of the transceiver module is below the lower limit.
Recommended action
TX_POW_NORMAL
Message text
[STRING]: TX power is normal!
Variable fields
Severity level
5
Example
OPTMOD/5/TX_POW_NORMAL: GigabitEthernet1/0/13: TX power is normal!
Explanation
The TX power of the transceiver module has returned to the acceptable range.
Recommended action
TYPE_ERR
Message text
[STRING]: The transceiver type is not supported by port hardware!
Variable fields
Severity level
3
Example
OPTMOD/3/TYPE_ERR: GigabitEthernet1/0/13: The transceiver type is not supported by port hardware!
Explanation
The transceiver module is not supported by the port.
Recommended action
VOLT_HIGH
Message text
[STRING]: Voltage is high!
Variable fields
Severity level
5
Example
OPTMOD/5/VOLT_HIGH: GigabitEthernet1/0/13: Voltage is high!
Explanation
The voltage of the transceiver module has exceeded the upper limit.
Recommended action
VOLT_LOW
Message text
[STRING]: Voltage is low!
Variable fields
Severity level
5
Example
OPTMOD/5/VOLT_LOW: GigabitEthernet1/0/13: Voltage is low!
Explanation
The voltage of the transceiver module is below the lower limit.
Recommended action
VOLT_NORMAL
Message text
[STRING]: Voltage is normal!
Variable fields
Severity level
5
Example
OPTMOD/5/VOLT_NORMAL: GigabitEthernet1/0/13: Voltage is normal!
Explanation
The voltage of the transceiver module has returned to the acceptable range.
Recommended action
OSPF messages
This section contains OSPF messages.
OSPF_LAST_NBR_DOWN
Message text
OSPF [UINT32] Last neighbor down event: Router ID: [STRING] Local address: [STRING] Remote address: [STRING] Reason: [STRING]
Variable fields
$1: OSPF process ID.
$2: Router ID.
$3: Local IP address.
$4: Neighbor IP address.
$5: Reason.
Severity level
6
Example
OSPF/6/OSPF_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 Local address: 10.1.1.1 Remote address: 10.1.1.2 Reason: Dead Interval timer expired.
Explanation
The device records the OSPF neighbor down event caused by a specific reason.
Recommended action
1.     When a down event occurred because of configuration changes (for example, interface parameter changes), check for the configuration errors.
2.     When a down event occurred because of dead interval expiration, check for the dead interval configuration error and loss of network connectivity.
3.     When a down event occurred because of BFD session down, check for the BFD detection time configuration error and loss of network connectivity.
4.     When a down event occurred because of interface status changes, check for loss of network connectivity.
OSPF_MEM_ALERT
Message text
OSPF Process receive system memory alert  [STRING] event.
Variable fields
Severity level
5
Example
OSPF/5/OSPF_MEM_ALERT: OSPF Process receive system memory alert start event.
Explanation
OSPF received a memory alarm.
Recommended action
Check the system memory.
OSPF_NBR_CHG
Message text
OSPF [UINT32] Neighbor [STRING] ([STRING]) from [STRING] to [STRING]
Variable fields
$2: Neighbor IP address.
$3: Interface name.
$4: Old adjacency state.
$5: New adjacency state.
Severity level
5
Example
OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 2.2.2.2 (Vlan-interface100) from Full to Down.
Explanation
The OSPF adjacency state changed on an interface.
Recommended action
When the adjacency with a neighbor changes from Full to another state on an interface, check for OSPF configuration errors and loss of network connectivity.
OSPF_RT_LMT
Message text
OSPF [UINT32] route limit reached.
Variable fields
Severity level
4
Example
OSPF/4/OSPF_RT_LMT: OSPF 1 route limit reached.
Explanation
The number of routes of an OSPF process reached the upper limit.
Recommended action
1.     Check for network attacks.
2.     Reduce the number of routes.
OSPF_RTRID_CHG
Message text
OSPF [UINT32] New router ID elected, please restart OSPF if you want to make the new router ID take effect.
Variable fields
Severity level
5
Example
OSPF/5/OSPF_RTRID_CHG: OSPF 1 New router ID elected, please restart OSPF if you want to make the new router ID take effect.
Explanation
The OSPF router ID was changed because the user changed the router ID or the interface IP address used as the router ID changed.
Recommended action
Use the reset ospf process command to make the new router ID take effect.
OSPF_VLINKID_CHG
Message text
OSPF [UINT32] Router ID changed, re-configure Vlink on peer
Variable fields
Severity level
5
Example
OSPF/5/OSPF_VLINKID_CHG:OSPF 1 Router ID changed, re-configure Vlink on peer
Explanation
A new OSPF router ID takes effect.
Recommended action
Check and modify the virtual link configuration on the peer router to match the new router ID.
OSPFV3 messages
This section contains OSPFv3 messages.
OSPFV3_LAST_NBR_DOWN
Message text
OSPFv3 [UINT32] Last neighbor down event: Router ID: [STRING]  local Interface Id: [UINT32]  Remote Interface Id: [UINT32]  Reason: [STRING].
Variable fields
$1: OSPFv3 process ID.
$2: Router ID.
$3: Local interface ID.
$4: Remote interface ID.
$5: Reason.
Severity level
6
Example
OSPFV3/6/OSPFV3_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 local Interface Id: 1111  Remote Interface Id: 2222 Reason: Dead Interval timer expired.
Explanation
The device records the most recent OSPFv3 neighbor down event caused by a specific reason.
Recommended action
Check the reason for the most recent OSPFv3 neighbor down event.
OSPFV3_MEM_ALERT
Message text
OSPFV3 Process receive system memory alert  [STRING] event.
Variable fields
$1: Type of the memory alarm.
Severity level
5
Example
OSPFV3/5/OSPFV3_MEM_ALERT: OSPFV3 Process receive system memory alert start event.
Explanation
OSPFv3 received a memory alarm.
Recommended action
OSPFV3_NBR_CHG
Message text
OSPFv3 [UINT32] Neighbor [STRING] ([STRING]) received [STRING]  and its state from [STRING]  to [STRING].
Variable fields
$1: Process ID.
$2: Neighbor router ID.
$3: Interface name.
$4: Neighbor event.
$5: Old adjacency state.
$6: New adjacency state.
Severity level
5
Example
OSPFV3/5/OSPFV3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2 (Vlan100)  received  1-Way  from Full to Init.
Explanation
The OSPFv3 adjacency state changed on an interface.
Recommended action
When the adjacency with a neighbor changes to down on an interface, check for OSPFv3 configuration errors and loss of network connectivity.
OSPFV3_RT_LMT
Message text
OSPFv3 [UINT32] Route limit reached.
Variable fields
$1: Process ID.
Severity level
5
Example
OSPFV3/5/OSPFV3_RT_LMT:OSPFv3 1 Route limit reached.
Explanation
The number of routes of an OSPFv3 process reached the upper limit.
Recommended action
Modify the route limit configuration.
PBB messages
This section contains PBB messages.
PBB_JOINAGG_WARNING
Message text
Because the aggregate interface [STRING] has been configured with PBB, assigning the interface [STRING] that does not support PBB to the aggregate group will cause incorrect processing.
Variable fields
$1: Aggregation group name.
$2: Interface name.
Severity level
4
Example
PBB/4/PBB_JOINAGG_WARNING: Because the aggregate interface Bridge-Aggregation1 has been configured with PBB, assigning the interface Ten-GigabitEthernet9/0/30 that does not support PBB to the aggregate group will cause incorrect processing.
Explanation
Because the interface does not support PBB, assigning the interface to an aggregation group configured with PBB will cause incorrect processing. If an aggregate interface is a PBB uplink port, all its members should support PBB.
Recommended action
Remove the interface from the aggregation group.
PBR messages
This section contains PBR messages.
PBR_HARDWARE_ERROR
Message text
Failed to update Policy: [STRING] due to [STRING].
Variable fields
$1: Name of the policy.
$2: Causes for the policy update failure:
·     Insufficient hardware resources.
·     Not supported operations.
·     Insufficient hardware resources and not supported operations.
Severity level
4
Example
PBR4/4/PBR_HARDWARE_ERROR: Failed to update Policy: aaa due to insufficient hardware resources and not supported operations.
Explanation
The cause for the policy update failure was logged.
Recommended action
Reduce the number of interfaces to which the policy is applied or the number of nodes configured for the policy.
PEX messages
This section contains PEX messages.
PEX_ASSOCIATEID_MISMATCHING
Message text
The associated ID of PEX port [UNIT32] is [UNIT32] on the parent fabric, but the PEX connected to the port has obtained ID [UNIT32].
Variable fields
$1: PEX port ID.
$2: Virtual slot number configured on the parent fabric for a PEX. (Centralized IRF devices.)
$2: Virtual chassis number configured on the parent fabric for a PEX. (Distributed devices in IRF mode.)
$3: Virtual slot number that the PEX has obtained. (Centralized IRF devices.)
$3: Virtual chassis number that the PEX has obtained. (Distributed devices in IRF mode.)
Severity level
5
Example
PEX/5/PEX_ASSOCIATEID_MISMATCHING: The associated ID of PEX port 1 is 100 on the parent fabric, but the PEX connected to the port has obtained ID 101.
Explanation
The configured virtual slot number for a PEX is different from the virtual slot number that the PEX has obtained. (Centralized IRF devices.)
The configured virtual chassis number for a PEX is different from the virtual chassis number that the PEX has obtained. (Distributed devices in IRF mode.)
Recommended action
Check the network connection.
PEX_CONFIG_ERROR
Message text
PEX port [UINT32] discarded a REGISTER request received from [STRING] through interface [STRING]. Reason: The PEX was not assigned an ID, or the PEX was assigned an ID equal to or greater than the maximum value ([UINT32]).
Variable fields
$1: PEX port ID.
$2: PEX model.
$3: Name of a PEX physical interface.
$4: Maximum virtual slot number for PEX devices. (Centralized IRF devices.)
$4: Maximum virtual chassis number for PEX devices. (Distributed devices in IRF mode.)
Severity level
4
Example
PEX/4/PEX_CONFIG_ERROR: PEX port 1 discarded a REGISTER request received from PEX-S5120HI-S5500HI through interface Ten-GigabitEthernet10/0/31. Reason: The PEX was not assigned an ID, or the PEX was assigned an ID equal to or greater than the maximum value 130.
Explanation
This message is generated in the following situations:
·     The PEX is not assigned a virtual slot number.
·     The PEX is assigned a virtual slot number that is equal to or greater than the maximum value allowed for the PEX model.
Recommended action
1.     Use the associate command to assign a valid slot number to the PEX. Make sure the slot number is within the value range for the PEX model.
2.     If the problem persists, contact H3C Support.
PEX_CONNECTION_ERROR
Message text
PEX port [UINT32] discarded a REGISTER request received from [STRING] through interface [STRING]. Reason: Another PEX has been registered on the PEX port.
Variable fields
$1: PEX port ID.
$2: PEX model.
Severity level
4
Example
PEX/4/PEX_CONNECTION_ERROR: PEX port 1 discarded a REGISTER request received from PEX-S5120HI-S5500HI through interface Ten-GigabitEthernet10/0/31. Reason: Another PEX has been registered on the PEX port.
Explanation
This message is generated if a PEX port is connected to multiple PEXs.
Recommended action
1.     Reconnect PEXs to ensure sure that only one PEX is connected to the PEX port.
PEX_STACKCONNECTION_ERROR
Message text
A device was connected to a PEX that already had two neighboring devices.
Variable fields
N/A
Severity level
5
Example
PEX/5/PEX_STACKCONNECTION_ERROR: A device was connected to a PEX that already had two neighboring devices.
Explanation
Connection error was detected. A device was connected to a PEX that already has two neighboring devices in an IRF 3 system.
Recommended action
PEX_FORBID_STACK
Message text
Can't connect PEXs [UNIT32] and [UNIT32]: The PEX ports to which the PEXs belong are in different PEX port groups.
Variable fields
$1: Virtual slot number of a PEX. (Centralized IRF devices.)
$1: Virtual chassis number of a PEX. (Distributed devices in IRF mode.)
$2: Virtual slot number of a PEX. (Centralized IRF devices.)
$2: Virtual chassis number of a PEX. (Distributed devices in IRF mode.)
Severity level
5
Example
PEX/5/PEX_FORBID_STACK: Can't connect PEXs 100 and 102: The PEX ports to which the PEXs belong are in different PEX port groups.
Explanation
PEXs belonging to PEX ports of different PEX port groups were connected.
Recommended action
PEX_LINK_BLOCK
Message text
Status of [STRING] changed from [STRING] to blocked.
Variable fields
$1: Name of a PEX physical interface.
$2: Data link status of the interface.
Severity level
4
Example
PEX/4/PEX_LINK_BLOCK: Status of Ten-GigabitEthernet2/0/1 changed from forwarding to blocked.
Explanation
Data link of the PEX physical interface has changed to blocked. The blocked state is a transitional state between forwarding and down. In blocked state, a PEX physical interface can forward protocol packets, but it cannot forward data packets.
This state change occurs in one of the following situations:
·     Incorrect physical connection:
?     The PEX physical links on a PEX are connected to different PEX ports on the parent device.
?     The PEX port on the parent device contains physical links to different PEXs.
·     The data link is forced to the blocked state. In the startup phase, a PEX blocks the link of a PEX physical interface if the interface is physically up, but it is not used for loading startup software.
·     The physical state of the interface is up, but the PEX connection between the PEX and the parent device has been disconnected. The PEX and the parent device cannot receive PEX heartbeat packets from each other.
Recommended action
If a down PEX link changes from blocked to up quickly, you do not need to take action. If the link stays in blocked state, check the PEX cabling to verify that:
·     The PEX's all PEX physical interfaces are connected to the physical interfaces assigned to the same PEX port on the parent device.
·     The PEX port contains only physical links to the same PEX.
If a forwarding PEX link stays in blocked state when it is changing to the down state, verify that an IRF fabric split has occurred. When an IRF fabric split occur, a PEX link is be blocked if it is connected to the Recovery-state IRF member device.
PEX_LINK_DOWN
Message text
Status of [STRING] changed from [STRING] to down.
Variable fields
Severity level
4
Example
PEX/4/PEX_LINK_DOWN: Status of Ten-GigabitEthernet2/0/1 changed from forwarding to down.
Explanation
Data link of the PEX physical interface has changed to the down state and cannot forward any packets.
The following are common reasons for this state change:
·     Physical link fails.
·     The interface is shut down administratively.
·     The system reboots.
Recommended action
If the interface has been shut down administratively or in the down state because of a system reboot, use the undo shutdown command to bring up the interface as needed.
If the interface is down because of a physical link failure, verify that the cable has been securely connected and is in good condition.
PEX_LINK_FORWARD
Message text
Status of [STRING] changed from [STRING] to forwarding.
Variable fields
Severity level
5
Example
PEX/5/PEX_LINK_FORWARD: Status of Ten-GigabitEthernet2/0/1 changed from blocked to forwarding.
Explanation
Data link of the PEX physical interface has changed to the forwarding state and can forward data packets.
This link state change occurs when one of the following events occurs:
·     The link is detected again after it changes to the blocked state.
·     The PEX loads startup software images from the parent device through the interface.
Recommended action
PEX_REG_JOININ
Message text
PEX ([STRING]) registered successfully on PEX port [UINT32].
Variable fields
$2: PEX port ID.
Severity level
5
Example
PEX/5/PEX_REG_JOININ: PEX (slot 101) registered successfully on PEX port 1.
Explanation
The PEX has been registered successfully. You can configure and manage the PEX attached to the PEX port on the parent device as if the PEX was an interface card.
Recommended action
PEX_REG_LEAVE
Message text
PEX ([STRING]) unregistered on PEX port [UINT32].
Variable fields
$2: PEX port ID.
Severity level
4
Example
PEX/4/PEX_REG_LEAVE: PEX (slot 101) unregistered on PEX port 1.
Explanation
The PEX has been unregistered. You cannot operate the PEX from the parent device.
A PEX unregister event occurs when one of the following events occurs:
·     The PEX reboots.
·     All physical interfaces in the PEX port are down. For example, all physical interfaces are shut down administratively, or all the physical links are disconnected.
·     The PEX fails to start up within 30 minutes.
·     Link detection fails on all physical interfaces in the PEX port.
Recommended action
If the event occurs because the PEX reboots or PEX physical interfaces are shut down administratively, use the undo shutdown command to bring up the interfaces as needed.
To resolve the problem that occurs for any other reasons:
·     Use the display device command to verify that the slot number of the PEX is present and the state is correct.
·     Use the display pex-port command to verify that the PEX physical interfaces are configured correctly and in a correct state.
·     Use the display interface command to verify that the physical state of the PEX physical interfaces is up. If the Current state field displays down, check the cabling for a physical link failure.
PEX_REG_REQUEST
Message text
Received a REGISTER request on PEX port [UINT32] from PEX ([STRING]).
Variable fields
$1: PEX port ID.
Severity level
5
Example
PEX/5/PEX_REG_REQUEST: Received a REGISTER request on PEX port 1 from PEX (slot 101).
Explanation
The PEX sent a registration request to the parent device.
This event occurs when the PEX starts up after PEX configuration is completed and the PEX device is connected to the patent device correctly. The parent device will allow the PEX to load startup software images after it receives a REGISTER request.
Recommended action
PIM messages
This section contains PIM messages.
PIM_MEM_ALERT
Message text
PIM Process receive system memory alert  [STRING] event.
Variable fields
$1: Event type of the memory alert.
Severity level
5
Example
PIM/5/PIM_MEM_ALERT: PIM Process receive system memory alert start event.
Explanation
When the memory changed, the PIM module received a memory alert event.
Recommended action
PIM_NBR_DOWN
Message text
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is down. ([STRING][STRING])
[STRING]: Neighbor [STRING] ([STRING]) is down.
Variable fields
$1: Public network or VPN instance.
$2: IP address of the neighbor.
$3: Interface name.
Severity level
5
Example
PIM/5/PIM_NBR_DOWN: (public net): Neighbor 10.1.1.1(Vlan-interface10) is down.
Explanation
The PIM neighbor was down.
Recommended action
Check the PIM configuration and network status.
PIM_NBR_UP
Message text
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is up. ([STRING][STRING])
[STRING]: Neighbor [STRING] ([STRING]) is up.
Variable fields
$3: Interface name.
Severity level
5
Example
PIM/5/PIM_NBR_UP: (public net): Neighbor 10.1.1.1(Vlan-interface10) is up.
Explanation
The PIM neighbor was up.
Recommended action
PING messages
This section contains ping messages.
PING_STATIS_INFO
Message text
[STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms.
Variable fields
$1: IP address, IPv6 address, or host name for the destination.
$2: Ping or ping6.
$3: Number of echo requests sent.
$4: Number of echo replies received.
$5: Percentage of the non-replied packets to the total request packets.
$6: Minimum round-trip delay.
$7: Average round-trip delay.
$8: Maximum round-trip delay.
$9: Standard deviation round-trip delay.
Severity level
6
Example
PING/6/PING_STATIS_INFO: 192.168.0.115 ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms.
Explanation
Statistics for a ping operation.
Recommended action
If there is no packet received, identify whether the interface is down.
PING_VPN_STATIS_INFO
Message text
[STRING] in VPN-instance [STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms.
Variable fields
$2: VPN instance name.
$3: ping or ping6.
$4: Number of echo requests sent.
$5: Number of echo replies received.
$6: Percentage of the non-replied packets to the total request packets.
$7: Minimum round-trip delay.
$8: Average round-trip delay.
$9: Maximum round-trip delay.
$10: Standard deviation round-trip delay.
Severity level
6
Example
PING/6/PING_VPN_STATIS_INFO: 192.168.0.115 in VPN-instance VPNA ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms.
Explanation
Recommended action
PKI messages
This section contains PKI messages.
REQUEST_CERT_FAIL
Message text
Failed to request certificate of domain [STRING].
Variable fields
$1: PKI domain name
Severity level
5
Example
PKI/5/REQUEST_CERT_FAIL: Failed to request certificate of domain abc.
Explanation
Failed to request certificate for a domain.
Recommended action
Check the configuration of the device and CA server, and the network between them.
REQUEST_CERT_SUCCESS
Message text
Request certificate of domain [STRING] successfully.
Variable fields
$1: PKI domain name
Severity level
5
Example
PKI/5/REQUEST_CERT_SUCCESS: Request certificate of domain abc successfully.
Explanation
Successfully requested certificate for a domain.
Recommended action
PKT2CPU messages
This section contains PKT2CPU messages.
PKT2CPU_NO_RESOURCE
Message text
-Interface=[STRING]-ProtocolType=[UINT32]-MacAddr=[STRING]; The resources is insufficient.
-Interface=[STRING]-ProtocolType=[UINT32]-SrcPort=[UINT32]-DstPort=[UINT32]; The resources is insufficient.
Variable fields
$2: Protocol type.
$3: MAC address or source port.
$4: Destination port.
Severity level
4
Example
PKT2CPU/4/PKT2CPU_NO_RESOURCE: -Interface=Ethernet0/0/2-ProtocolType=21-MacAddr=0180-c200-0014; The resources is insufficient.
Explanation
Hardware resources were insufficient.
Recommended action
Remove the configuration.
PORTSEC messages
This section contains port security messages.
PORTSEC_ACL_FAILURE
Message text
-IfName=[STRING]-MACAddr=[STRING]; ACL authorization failed because [STRING].
Variable fields
$2: MAC address.
$3: Cause of failure:
·     the specified ACL didn't exist.
·     this type of ACL is not supported.
·     hardware resources were insufficient.
·     the specified ACL conflicted with other ACLs applied to the interface.
·     the specified ACL didn't contain any rules.
Severity level
5
Example
PORTSEC/5/PORTSEC_ACL_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; ACL authorization failed because the specified ACL didn't exist.
Explanation
ACL authorization failed.
Recommended action
Handle the problem according to the failure cause.
PORTSEC_LEARNED_MACADDR
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]; A new MAC address was learned.
Variable fields
$2: MAC address.
$3: VLAN ID.
Severity level
6
Example
PORTSEC/6/PORTSEC_LEARNED_MACADDR:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444; A new MAC address was learned.
Explanation
A new secure MAC address was learned on the interface.
Recommended action
PORTSEC_NTK_NOT_EFFECTIVE
Message text
The NeedToKnow feature is configured but is not effective on interface [STRING].
Variable fields
Severity level
3
Example
PORTSEC/3/PORTSEC_NTK_NOT_EFFECTIVE: The NeedToKnow feature is configured but is not effective on interface Ethernet3/1/2.
Explanation
The NeedToKnow mode does not take effect on an interface, because the interface does not support the NeedToKnow mode.
Recommended action
1.     Remove the problem depending on the network requirements:
2.     If the NeedToKnow feature is not required, disable the NeedToKnow feature on the interface.
3.     If the NeedToKnow feature is required, reconnect the connected devices to another interface that supports the NeedToKnow mode. Then, configure the NeedToKnow mode on the new interface.
4.     If the problem persists, contact H3C Support.
PORTSEC_PORTMODE_NOT_EFFECTIVE
Message text
The port-security mode is configured but is not effective on interface [STRING].
Variable fields
$1: Interface name.
Severity level
3
Example
PORTSEC/3/PORTSEC_PORTMODE_NOT_EFFECTIVE: The port-security mode is configured but is not effective on interface Ethernet3/1/2.
Explanation
The port security mode does not take effect on an interface, because the interface does not support this mode.
Recommended action
Change the port security mode or disable the port security feature on the interface.
PORTSEC_PROFILE_FAILURE
Message text
-IfName=[STRING]-MACAddr=[STRING]; Failed to assign a user profile to driver.
Variable fields
$2: MAC address.
Severity level
5
Example
PORTSEC/5/PORTSEC_PROFILE_FAILURE:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9; Failed to assign a user profile to driver.
Explanation
The device failed to assign a user profile to the driver.
Recommended action
PORTSEC_VIOLATION
Message text
-IfName=[STRING]-MACAddr=[STRING]-VLANID=[STRING]-IfStatus=[STRING]; Intrusion protection was triggered.
Variable fields
$2: MAC address.
$3: VLAN ID.
$4: Interface status.
Severity level
5
Example
PORTSEC/5/PORTSEC_VIOLATION:-IfName=GigabitEthernet1/0/4-MACAddr=0010-8400-22b9-VLANID=444-IfStatus=Up; Intrusion protection was triggered.
Explanation
Recommended action
·     Check the authentication and port security configuration.
·     Change the port security mode.
PPP messages
This section contains PPP messages.
IPPOOL_ADDRESS_EXHAUSTED
Message text
The address pool [STRING] is exhausted.
Variable fields
$1: Pool name.
Severity level
5
Example
PPP/5/IPPOOL_ADDRESS_EXHAUSTED: The address pool aaa is exhausted.
Explanation
This message is generated when the last address is assigned from the pool.
Recommended action
1.     Add addresses to the pool.
PWDCTL messages
This section contains password control messages.
ADDBLACKLIST
Message text
[STRING] was added to the blacklist for failed login attempts.
Variable fields
$1: Username.
Severity level
6
Example
PWDCTL/6/ADDBLACKLIST: hhh was added to the blacklist for failed login attempts.
Explanation
A user was added to the password control blacklist because of a login failure caused by a wrong password.
Recommended action
CHANGEPASSWORD
Message text
[STRING] changed the password because [STRING].
Variable fields
$1: Username.
$2: Reasons for changing the password.
?     Because it is the first login of the account.
?     Because the password had expired.
?     Because the password was too short.
?     Because the password was not complex enough.
Severity level
6
Example
PWDCTL/6/CNAHGEPASSWORD: hhh changed the password because first login.
Explanation
The user changed the password for some reason, for example, for the first login.
Recommended action
FAILEDTOWRITEPWD
Message text
Variable fields
N/A
Severity level
6
Example
PWDCTL/6/FAILEDTOWRITEPWD: Failed to write the password records to file.
Explanation
The device failed to write a password to a file.
Recommended action
1.     Check the file system of the device for memory space insufficiency.
QoS messages
This section contains QoS messages.
QOS_CBWFQ_REMOVED
Message text
CBWFQ is removed from [STRING].
Variable fields
$1: Interface name.
Severity level
3
Example
QOS/3/QOS_CBWFQ_REMOVED: CBWFQ is removed from GigabitEthernet4/0/1.
Explanation
CBWFQ was removed from an interface because the maximum bandwidth or speed configured on the interface was below the bandwidth or speed required for CBWFQ.
Recommended action
Increase the bandwidth or speed and apply the removed CBWFQ again.
QOS_POLICY_APPLYCOPP_CBFAIL
Message text
Failed to apply classifier-behavior [STRING] in policy [STRING] to the  [STRING] direction of control plane slot [UINT32]. [STRING].
Variable fields
$1: Name of a classifier-behavior association.
$2: Policy name.
$3: Traffic direction.
$4: Slot number.
$5: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYCOPP_CBFAIL: Failed to apply classifier-behavior d in policy b to the inbound direction of control plane slot 3. No actions in behavior.
Explanation
The system failed to perform one of the following actions:
·     Apply a classifier-behavior association to a specific direction of a control plane.
·     Update a classifier-behavior association applied to a specific direction of a control plane.
Recommended action
Configure actions for the behavior.
QOS_POLICY_APPLYCOPP_FAIL
Message text
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING].
Variable fields
$1: Policy name.
$2: Traffic direction.
$3: Slot number.
$4: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYCOPP_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of control plane slot 3. Not supported by hardware.
Explanation
·     Apply a QoS policy to a specific direction of a control plane.
·     Update a QoS policy applied to a specific direction of a control plane.
Recommended action
Modify the contents of the QoS policy.
QOS_POLICY_APPLYGLOBAL_CBFAIL
Message text
Failed to apply classifier-behavior [STRING] in policy [STRING] to the  [STRING] direction globally. [STRING].
Variable fields
$2: Policy name.
$4: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYGLOBAL_CBFAIL: Failed to apply classifier-behavior a in policy b to the outbound direction globally. No actions in behavior.
Explanation
·     Apply a classifier-behavior association to a specific direction globally.
·     Update a classifier-behavior association applied to a specific direction globally.
Recommended action
QOS_POLICY_APPLYGLOBAL_FAIL
Message text
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction globally. [STRING].
Variable fields
$1: Policy name.
$3: Cause.
Severity level
4
Example
QOS/4/ QOS_POLICY_APPLYGLOBAL_FAIL: Failed to apply or refresh QoS policy b to the inbound direction globally. Not supported by hardware.
Explanation
·     Apply a QoS policy to a specific direction globally.
·     Update a QoS policy applied to a specific direction globally.
Recommended action
QOS_POLICY_APPLYIF_CBFAIL
Message text
Failed to apply classifier-behavior [STRING] in policy [STRING] to the  [STRING] direction of interface [STRING]. [STRING].
Variable fields
$2: Policy name.
$4: Interface name.
$5: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of interface Ethernet3/1/2. No actions in behavior.
Explanation
·     Apply a classifier-behavior association to a specific direction of an interface.
·     Update a classifier-behavior association applied to a specific direction of an interface.
Recommended action
QOS_POLICY_APPLYIF_FAIL
Message text
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of interface [STRING]. [STRING].
Variable fields
$1: Policy name.
$3: Interface name.
$4: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYIF_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of interface Ethernet3/1/2. Not supported by hardware.
Explanation
·     Apply a QoS policy to a specific direction of an interface.
·     Update a QoS policy applied to a specific direction of an interface.
Recommended action
QOS_POLICY_APPLYVLAN_CBFAIL
Message text
Failed to apply classifier-behavior [STRING] in policy [STRING] to the  [STRING] direction of VLAN [UINT32]. [STRING].
Variable fields
$2: Policy name.
$4: VLAN ID.
$5: Cause.
Severity level
4
Example
QOS/4QOS_POLICY_APPLYVLAN_CBFAIL: Failed to apply  classifier-behavior b in policy b to the inbound direction of VLAN 2. No actions in behavior.
Explanation
·     Apply a classifier-behavior association to a specific direction of a VLAN.
·     Update a classifier-behavior association applied to a specific direction of a VLAN.
Recommended action
QOS_POLICY_APPLYVLAN_FAIL
Message text
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING].
Variable fields
$1: Policy name.
$3: VLAN ID.
$4: Cause.
Severity level
4
Example
QOS/4/QOS_POLICY_APPLYVLAN_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of VLAN 2. Not supported by hardware.
Explanation
·     Apply a QoS policy to a specific direction of a VLAN.
·     Update a QoS policy applied to a specific direction of a VLAN.
Recommended action
QOS_NOT_ENOUGH_BANDWIDTH
Message text
Policy [STRING] requested bandwidth [UINT32](kbps). Only [UINT32](kbps) is available on [STRING].
Variable fields
$1: Policy name.
$2: Required bandwidth for CBWFQ.
$3: Available bandwidth on an interface.
$4: Interface name.
Severity level
3
Example
QOS/3/QOS_NOT_ENOUGH_BANDWIDTH: Policy d requested bandwidth 10000(kbps). Only 80(kbps) is available on GigabitEthernet4/0/1.
Explanation
Configuring CBWFQ on an interface failed because the maximum bandwidth on the interface was less than the bandwidth required for CBWFQ.
Recommended action
Increase the maximum bandwidth configured for the interface or set lower bandwidth required for CBWFQ.
RADIUS messages
This section contains RADIUS messages.
RADIUS_AUTH_FAILURE
Message text
User [STRING] from [STRING] failed authentication.
Variable fields
$1: User name.
$2: IP address.
Severity level
5
Example
RADIUS/5/RADIUS_AUTH_FAILURE: User abc@system from 192.168.0.22 failed authentication.
Explanation
An authentication request was rejected by the RADIUS server.
Recommended action
RADIUS_AUTH_SUCCESS
Message text
User [STRING] from [STRING] was authenticated successfully.
Variable fields
$1: User name.
$2: IP address.
Severity level
6
Example
RADIUS/6/RADIUS_AUTH_SUCCESS: User abc@system from 192.168.0.22 was authenticated successfully.
Explanation
An authentication request was accepted by the RADIUS server.
Recommended action
RADIUS_DELETE_HOST_FAIL
Message text
Failed to delete servers in scheme [STRING].
Variable fields
$1: Scheme name.
Severity level
4
Example
RADIUS/4/RADIUS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc.
Explanation
Failed to delete servers from a RADIUS scheme.
Recommended action
RIP messages
This section contains RIP messages.
RIP_MEM_ALERT
Message text
RIP Process receive system memory alert  [STRING] event.
Variable fields
Severity level
5
Example
RIP/5/RIP_MEM_ALERT: RIP Process receive system memory alert start event.
Explanation
RIP received a memory alarm.
Recommended action
RIP_RT_LMT
Message text
RIP [UINT32] Route limit reached
Variable fields
$1: Process ID.
Severity level
6
Example
RIP/6/RIP_RT_LMT: RIP 1 Route limit reached.
Explanation
The number of routes of a RIP process reached the upper limit.
Recommended action
RIPNG messages
This section contains RIPng messages.
RIPNG_MEM_ALERT
Message text
RIPNG Process receive system memory alert  [STRING] event.
Variable fields
Severity level
5
Example
RIPNG/5/RIPNG_MEM_ALERT: RIPNG Process receive system memory alert start event.
Explanation
RIPng received a memory alarm.
Recommended action
RIPNG_RT_LMT
Message text
RIPng [UINT32] Route limit reached
Variable fields
$1: Process ID
Severity level
6
Example
RIPNG/6/RIPNG_RT_LMT: RIPng 1 Route limit reached.
Explanation
The number of routes of a RIPng process reached the upper limit.
Recommended action
RM messages
This section contains RM messages.
RM_ACRT_REACH_LIMIT
Message text
Max active [STRING] routes [UINT32] reached in URT of [STRING]
Variable fields
$1: IPv4 or IPv6.
$2: Maximum number of active routes.
$3: VPN instance name.
Severity level
4
Example
RM/4/RM_ROUTE_REACH_LIMIT: Max active IPv4 routes 100000 reached in URT of VPN1
Explanation
The number of active routes reached the upper limit in the unicast routing table of a VPN instance.
Recommended action
Remove unused active routes.
RM_ACRT_REACH_THRESVALUE
Message text
Threshold value [UINT32] of max active [STRING] routes reached in URT of [STRING]
Variable fields
$1: Threshold of the maximum number of active routes in percentage.
$2: IPv4 or IPv6.
Severity level
4
Example
RM/4/RM_ACRT_REACH_THRESVALUE: Threshold value 50% of max active IPv4 routes reached in URT of vpn1
Explanation
The percentage of the maximum number of active routes was reached in the unicast routing table of a VPN instance.
Recommended action
Modify the threshold value or the route limit configuration.
RM_THRESHLD_VALUE_REACH
Message text
Threshold value [UINT32] of active [STRING] routes reached in URT of [STRING]
Variable fields
$1: Maximum number of active routes.
$2: IPv4 or IPv6.
Severity level
4
Example
RM/4/RM_THRESHLD_VALUE_REACH: Threshold value 10000 of active IPv4 routes reached in URT of vpn1
Explanation
The number of active routes reached the threshold in the unicast routing table of a VPN instance.
Recommended action
RPR messages
This section contains RPR messages.
DRVDEBUGMOD_RPR
DRVPLAT/4/DrvDebug
Message text
[STRING] mate is Down!
Variable fields
$1: RPR physical port name.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=0; RPRXGE0/2/1 mate is Down!
Explanation
The mate port on the LSUM1SPMAEC0 is down.
Recommended action
1.     Verify that the mate port is connected correctly.
2.     Verify that the cable is not faulty. Replace the cable if the cable is faulty.
3.     If the problem persists, contact H3C Support.
DRVPLAT/4/DrvDebug
Message text
[STRING] mate is Up!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=0; RPRXGE0/2/1 mate is Up!
Explanation
The mate port on the LSUM1SPMAEC0 is up.
Recommended action
DRVPLAT/4/DrvDebug
Message text
SF should be in the range of 10e-3 to 10e-5.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=0; RPRXGE0/2/1 SF should be in the range of 10e-3 to 10e-5!
Explanation
The SF alarm threshold of the RPRPOS interface exceeded the supported range.
Recommended action
1.     Set the SF alarm threshold to a value in the range of 10e-3 to 10e-5.
DRVPLAT/4/DrvDebug
Message text
SD should be in the range of 10e-5 to 10e-7.
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=0; RPRXGE0/2/1 SD should be in the range of 10e-5 to 10e-7!
Explanation
The SD alarm threshold of the RPRPOS interface exceeded the supported range.
Recommended action
1.     Set the SD alarm threshold to a value in the range of 10e-5 to 10e-7.
DRVPLAT/4/DrvDebug
Message text
SF should be within 2 levels of SD!
Variable fields
N/A
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=0; RPRXGE0/2/1 SF should be within 2 levels of SD!
Explanation
The difference between the SD alarm threshold and the SF alarm threshold of the RPRPOS interface is greater than 10e-2.
Recommended action
1.     If the SD alarm threshold is 10e-sdvalue and the SF alarm threshold is 10e-sfvalue, make sure the difference between the sdvalue and sfvalue is smaller than or equal to 2.
DRVPLAT/4/DrvDebug
Message text
Ringlet [STRING] [STRING] class congestion alarm is present.
Variable fields
$1: Ringlet ID (Ringlet 0 or 1).
$2: Service class (Class A, B, or C).
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=1; Ringlet 0 C class congestion alarm is present.
Explanation
Service traffic congestion occurred on the ringlet.
Recommended action
1.     Use flow control to limit traffic for the service class.
2.     Use the rpr rate-limit command to configure more reserved bandwidth for the service class.
DRVPLAT/4/DrvDebug
Message text
Ringlet [STRING] [STRING] class congestion alarm.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=1; Ringlet 0 A class congestion alarm is present.
Explanation
Service traffic congestion persists on the ringlet.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Ringlet [STRING] [STRING] class congestion alarm is over.
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=1; Ringlet 0 C class congestion alarm is over
Explanation
Service traffic congestion alarm on the ringlet was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] Miscabling report Happened
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Miscabling report Happened
Explanation
The optical fiber for the PRP physical port was not connected correctly.
Recommended action
1.     Make sure the Rx end of the RPR physical port is connected to the Tx end of the peer interface.
DRVPLAT/4/DrvDebug
Message text
[STRING] Miscabling report  Over
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Miscabling report  Over
Explanation
The alarm of fiber misconnection for the RPR physical port was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] LOF alarm is present!
Variable fields
$1: RPR physical port number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 LOF alarm is present!
Explanation
A loss of frame (LOF) alarm was generated on the RPRPOS interface.
Recommended action
1.     Use the display interface command to verify that the RPR physical port is up.
?     If the interface is administratively down, use the undo shutdown command to bring up the interface.
?     If the interface is physically down, verify that the line is up and the peer port is up.
2.     Verify that the optical fiber and transceiver module are installed correctly.
3.     Use the display transceiver alarm command to verify that the transceiver module is not faulty.
DRVPLAT/4/DrvDebug
Message text
[STRING] LOF alarm is over!
Variable fields
Severity level
4
Example
RPRPOS1/2/1 LOF alarm is over!
Explanation
The LOF alarm on the RPRPOS interface was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] LOS alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 LOS alarm is present!
Explanation
A loss of signal (LOS) alarm was generated on the RPRPOS interface.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] LOS alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 LOS alarm is over!
Explanation
The LOS alarm on the RPRPOS interface was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] Line AIS alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Line AIS alarm is present!
Explanation
A line alarm indication signal (LAIS) alarm was generated on the RPRPOS interface.
Recommended action
DRVPLAT/4/DrvDebug
Message text
 [STRING] Line AIS alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Line AIS alarm is over!
Explanation
The LAIS alarm on the RPRPOS interface was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] Path AIS alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Path AIS alarm is present!
Explanation
A path alarm indication signal (PAIS) alarm was generated on the RPRPOS interface.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] Path AIS alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Path AIS alarm is over!
Explanation
The PAIS alarm on the RPRPOS interface was cleared.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] SF alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 SF alarm is present!
Explanation
A signal failure (SF) alarm was generated on the RPRPOS interface.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] SF alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 SF alarm is over!
Explanation
The SF alarm was cleared on the RPRPOS interface.
Recommended action
DRVPLAT/4/DrvDebug
Message text
[STRING] Mate LOS alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Mate LOS alarm is present!
Explanation
An LOS alarm was generated on the mate port of the RPR physical port.
Recommended action
1.     Verify that the cable connection for the mate port is correct.
DRVPLAT/4/DrvDebug
Message text
[STRING] Mate LOS alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Mate LOS alarm is over!
Explanation
The LOS alarm was cleared on the RPR mate port of the RPR physical port.
Recommended action
DRVPLAT/4/DrvDebug
Message text
Subcard [UINT32] remove, The Board will reboot!
Variable fields
$1: Subslot number.
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1-Slot=2;Subcard 1 remove, The Board will reboot!
Explanation
The card will restart because the subcard is removed.
Recommended action
1.     Install the subcard securely.
DRVPLAT/4/DrvDebug
Message text
[STRING] Keepalive alarm is present!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Keepalive alarm is present!
Explanation
The RPR physical port generated an RPR keepalive alarm because it did not receive the single choke fairness frame (SCFF) frame before the keepalive timer expired.
Recommended action
4.     Verify that the PRP physical port is bound to an RPR logical interface.
5.     If the problem persists, contact H3C Support.
DRVPLAT/4/DrvDebug
Message text
[STRING] Keepalive alarm is over!
Variable fields
Severity level
4
Example
DRVPLAT/4/DrvDebug: -MDC=1; RPRPOS1/2/1 Keepalive alarm is over!
Explanation
The RPR keepalive alarm was cleared because the PRP physical port received the SCFF frame.
Recommended action
RPR_LAGGCONFIG_INCONSITENT
Message text
An inconsitent LAGG configuration is present on the ring corresponding to RPR logical interface [STRING].
Variable fields
$1: RPR logical interface number.
Severity level
4
Example
RPR/4/RPR_LAGGCONFIG_INCONSITENT: -MDC=1-Slot=1; An inconsitent LAGG configuration is present on the ring corresponding to RPR logical interface RPR4/0/1.
Explanation
The logical interfaces on the RPR station and its neighbor station have different aggregation configuration.
Recommended action
1.     Use the display link-aggregation verbose command to examine the aggregation configuration of the logical interfaces on the RPR station and its neighbor stations. Make sure the logical interfaces on the RPR station and its neighbor station have the same aggregation configuration.
RPR_LAGGCONFIG_INCONSITENT_OVER
Message text
An inconsitent LAGG configuration is cleared on the ring corresponding to RPR logical interface [STRING].
Variable fields
Severity level
5
Example
RPR/5/RPR_LAGGCONFIG_INCONSITENT_OVER: -MDC=1-Slot=1: An inconsitent LAGG configuration is cleared on the ring corresponding to RPR logical interface RPR4/0/1.
Explanation
The logical interfaces on the RPR station and its neighbor stations have the same aggregation configuration.
Recommended action
SCM messages
This section contains SCM messages.
JOBINFO
Message text
The service [STRING] is[STRING]...
Variable fields
$1: Service name.
$2: State of the service.
Severity level
6
Example
SCM/6/JOBINFO: The service DEV is starting...
Explanation
The system is starting, or a user is managing the service.
Recommended action
RECV_DUPLICATEEVENT
Message text
The service [STRING] receives a duplicate event in status [STRING], ignore it.
Variable fields
$1: Service name.
$2: Service state.
Severity level
5
Example
The service DEV set status stopping (Must be starting), Ignore.
Explanation
A service received a duplicate event in the same state.
Recommended action
SERVICE_RESTART
Message text
Standby service [STRING] in [STRING] failed to become the active service and restarted because of incomplete synchronization.
Variable fields
$1: Service name.
$2: Card location.
Severity level
4
Example
SCM/4/SERVICE_RESTART: Standby service ospf in slot 0 failed to become the active service and restarted because of incomplete synchronization.
Explanation
The active service abnormally stopped when the standby service did not complete synchronization to the active service.
Recommended action
SERVICE_STATEERROR
Message text
The service [STRING] receives an error event in status [STRING], drop it.
Variable fields
$1: Service name.
$2: Service state.
Severity level
5
Example
SCM/5/SERVICE_STATEERROR: The service DEV receives an error event in status starting, drop it.
Explanation
A service received an error event in a specific state.
Recommended action
SERVICE_STATUSFAILED
Message text
The service %s status failed : no response!
Variable fields
$1: Service name.
Severity level
5
Example
SCM/5/SERVICE_STATUSFAILED: The service DEV status failed : no response!
Explanation
A service failed.
Recommended action
SET_WRONGSTATUS
Message text
The service [STRING] set status [STRING] (Must be [STRING]), Ignore.
Variable fields
$1: Service name.
$2: Service state.
$3: Service state.
Severity level
5
Example
SCM/5/SET_WRONGSTATUS: The service DEV receives a duplicate event in status starting, ignore it.
Explanation
A service received an event in an incorrect state.
Recommended action
SCRLSP messages
This section contains static CRLSP messages.
SCRLSP_LABEL_DUPLICATE
Message text
Incoming label [INT32] for static CRLSP [STRING] is duplicate.
Variable fields
$1: Incoming label value.
$2: Static CRLSP name.
Severity level
4
Example
SCRLSP/4/SCRLSP_LABEL_DUPLICATE: Incoming label 1024 for static CRLSP aaa is duplicate.
Explanation
The incoming label of a static CRLSP was used by a static PW or by a static LSP. This message is generated when one of the following occurs:
·     When MPLS is enabled, configure a static CRLSP with the same incoming label as an existing static PW or static LSP.
·     Enable MPLS when a static CRLSP has the same incoming label as an existing static PW or static LSP.
Recommended action
Remove this static CRLSP, and reconfigure it with another incoming label.
SHELL messages
This section contains shell messages.
SHELL_CMD
Message text
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command is [STRING]
Variable fields
$1: Line name. If there is not a line name, '**' is displayed.
$2: IP address. If there is not an IP address, '**' is displayed.
$3: Username. If there is not a username, '**' is displayed.
$4: Command string.
Severity level
6
Example
SHELL/6/SHELL_CMD: -Line=aux0-IPAddr=**-User=**; Command is quit
Explanation
A command was executed successfully.
Recommended action
SHELL_CMD_CONFIRM
Message text
Confirm option of command [STRING] is [STRING].
Variable fields
$1: Command string.
$4: Confirm option:
·     yes—The user confirmed the operation.
·     no—The user denied the operation.
·     timeout—The user did not confirm or deny the operation before the timeout timer expired.
·     cancel—The user pressed Ctrl+C to abort the operation.
Severity level
6
Example
SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save is no.
Explanation
This message indicates the confirmation option that the user selected for the command.
Recommended action
SHELL_CMD_EXECUTEFAIL
Message text
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be executed.
Variable fields
$1: Username.
$2: IP address.
$3: Command string.
$4: Command view.
Severity level
4
Example
SHELL/4/SHELL_CMD_EXECUTEFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be executed.
Explanation
The command failed to be executed.
Recommended action
1.     Verify that the command does not conflict with a configured feature.
SHELL_CMD_INPUT
Message text
Input string for the [STRING] command is [STRING].
Variable fields
$1: Command string.
$2: Input string.
Severity level
6
Example
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is startup.cfg.
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is CTRL_C.
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is the Enter key.
Explanation
An interactive command was executed and the user interacted with the command.
Recommended action
SHELL_CMD_INPUT_TIMEOUT
Message text
Operation timed out: Getting input for the [STRING] command.
Variable fields
$1: Command string.
Severity level
6
Example
SHELL/6/SHELL_CMD_INPUT_TIMEOUT: Operation timed out: Getting input for the fdisk command.
Explanation
An interactive command was executed but the user did not interact with the command before timeout timer expired.
Recommended action
SHELL_CMD_MATCHFAIL
Message text
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be matched.
Variable fields
$1: Username.
$2: IP address.
$3: Command string.
$4: Command view.
Severity level
4
Example
SHELL/4/SHELL_CMD_MATCHFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be matched.
Explanation
The command string has errors, or the view does not support the command.
Recommended action
1.     Check whether the view supports the command.
2.     Verify that you enter the correct command string.
SHELL_CMDDENY
Message text
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command [STRING] is permission denied.
Variable fields
$4: Command string.
Severity level
5
Example
SHELL/5/SHELL_CMDDENY: -Line=vty0-IPAddr=192.168.62.138-User=**; Command vlan 10 is permission denied.
Explanation
A command was not executed because the user did not have the right to use the command.
Recommended action
SHELL_CMDFAIL
Message text
Command [STRING] fails to recover configuration.
Variable fields
$1: Command string.
Severity level
6
Example
SHELL/6/SHELL_CMDFAIL: Command display this fails to recover configuration.
Explanation
The configuration restore operation failed.
Recommended action
SHELL_CRITICAL_CMDFAIL
Message text
 -User=[STRING]-IPAddr=[STRING]; Command is [STRING] .
Variable fields
$1: Username.
$2: IP address.
$3: Command string.
Severity level
6
Example
SHELL/6/SHELL_CRITICAL_CMDFAIL: -User=admin-IPAddr=169.254.0.7; Command is save.
Explanation
A command failed to be executed or was canceled.
Recommended action
SHELL_LOGIN
Message text
[STRING] login from [STRING].
Variable fields
$1: Username.
$2: Line name.
Severity level
5
Example
SHELL/5/SHELL_LOGIN: Console logged in from console0.
Explanation
A user logged in.
Recommended action
SHELL_LOGOUT
Message text
[STRING] logout from [STRING].
Variable fields
$1: Username.
$2: Line name.
Severity level
5
Example
SHELL/5/SHELL_LOGOUT: Console logged out from console0.
Explanation
A user logged out.
Recommended action
SLSP messages
This section contains static LSP messages.
SLSP_LABEL_DUPLICATE
Message text
Incoming label [INT32] for static LSP [STRING] is duplicate.
Variable fields
$2: Static LSP name.
Severity level
4
Example
SLSP/4/SLSP_LABEL_DUPLICATE: Incoming label 1024 for static LSP aaa is duplicate.
Explanation
The incoming label of a static LSP was used by a static PW or by a static CRLSP. This message is generated when one of the following occurs:
·     When MPLS is enabled, configure a static LSP with the same incoming label as an existing static CRLSP or static PW.
·     Enable MPLS when a static LSP has the same incoming label as an existing static CRLSP or static PW.
Recommended action
Remove this static LSP, and reconfigure it with another incoming label.
SMLK messages
This section contains Smart Link messages.
SMLK_LINK_SWITCH
Message text
Status of port [STRING] in smart link group [UINT16] changes to active.
Variable fields
$1: Port name.
$2: Smart link group ID.
Severity level
4
Example
SMLK/4/SMLK_LINK_SWITCH: Status of port GigabitEthernet0/1/4 in smart link group 1 changes to active.
Explanation
The port took over to forward traffic after the former primary port failed.
Recommended action
Remove the network faults.
SNMP messages
This section contains SNMP messages.
SNMP_ACL_RESTRICTION
Message text
SNMP [STRING] from [STRING] is rejected due to ACL restriction.
Variable fields
$1: SNMP community/usm-user/group.
$2: IP address of the NMS.
Severity level
3
Example
SNMP/3/SNMP_ACL_RESTRICTION: SNMP community public from 192.168.1.100 is rejected due to ACL restrictions.
Explanation
A syslog is printed if SNMP packets are denied because of ACL restrictions.
Recommended action
Check the ACL configuration on the SNMP agent, and check if the agent was attacked.
SNMP_GET
Message text
-seqNO=[UINT32]-srcIP=[STRING]-op=GET-node=[STRING]-value=[STRING]; The agent received a message.
Variable fields
$1: Sequence number of an SNMP operation log.
$3: MIB object name and OID.
$4: Value field of the request packet.
Severity level
6
Example
SNMP/6/SNMP_GET: -seqNO=1-srcIP=192.168.28.28-op=GET-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=; The agent received a message.
Explanation
SNMP received a Get request from an NMS. The system logs SNMP operations only when SNMP logging is enabled.
Recommended action
No action is required.
SNMP_NOTIFY
Message text
Notification [STRING] [STRING].
Variable fields
$1: Notification name.
$2: The variable-binding filed of notifications. If no variable-binding exists, the OID becomes a null value.
Severity level
6
Example
SNMP/6/SNMP_NOTIFY: Notification hh3cLogIn(1.3.6.1.4.1.25506.2.2.1.1.3.0.1) with hh3cTerminalUserName(1.3.6.1.4.1.25506.2.2.1.1.2.1.0)=;hh3cTerminalSource(1.3.6.1.4.1.25506.2.2.1.1.2.2.0)=Console.
Explanation
The SNMP agent sent a notification. This message displays the notification content.
Recommended action
SNMP_SET
Message text
-seqNO=[UINT32]-srcIP=[STRING]-op=SET-errorIndex=[UINT32]-errorStatus=[STRING]-node=[STRING]-value=[STRING]; The agent received a message.
Variable fields
$3: Error index of the Set operation.
$4: Error status of the Set operation.
$5: MIB object name and OID.
$6: Value of the MIB object changed by the Set operation.
Severity level
6
Example
SNMP/6/SNMP_SET: -seqNO=3-srcIP=192.168.28.28-op=SET-errorIndex=0-errorStatus=noError-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=Hangzhou China; The agent received a message.
Explanation
SNMP received a Set request from an NMS. The system logs SNMP operations only when SNMP logging is enabled.
Recommended action
SNMP_USM_NOTINTIMEWINDOW
Message text
 -User=[STRING]-IPAddr=[STRING]; SNMPv3 message is not in time window.
Variable fields
$1: Username.
$2: IP address.
Severity level
4
Example
SNMP/4/SNMP_USM_NOTINTIMEWINDOW: -User=admin-IPAddr=169.254.0.7; SNMPv3 message is not in time window.
Explanation
The SNMPv3 message is not in the time window.
Recommended action
SNMP_AUTHENTICATION_FAILURE
Message text
Failed to authenticate SNMP message.
Variable fields
N/A
Severity level
4
Example
SNMP/4/SNMP_AUTHENTICATION_FAILURE: Failed to authenticate SNMP message.
Explanation
The SNMP agent failed to authenticate an NMS because the community name or username is not the same on the agent and NMS.
Recommended action
Verify that an NMS and an SNMP agent use the same community name or username. For SNMPv3, the authentication and privacy modes, and authentication and privacy keys must also be the same on the NMS and agent.
SPBM messages
This section contains SPBM messages.
SPBM_LICENSE_EXPIRED
Message text
The SPBM feature is being disabled, because its license has expired.
Variable fields
N/A
Severity level
3
Example
SPBM/3/SPBM_LICENSE_EXPIRED: The SPBM feature is being disabled, because its license has expired.
Explanation
The SPBM license has expired.
Recommended action
Install a valid license for SPBM.
SPBM_LICENSE_EXPIRED_TIME
Message text
The SPBM feature will be disabled in [ULONG] days.
Variable fields
$1: Available period of the feature.
Severity level
5
Example
SPBM/5/SPBM_LICENSE_EXPIRED_TIME: The SPBM feature will be disabled in 2 days.
Explanation
SPBM will be disabled because the SPBM license has expired. You can use SPBM for 30 days after the license has expired.
Recommended action
Install a new license.
SPBM_LICENSE_UNAVAILABLE
Message text
The SPBM feature has no available license.
Variable fields
N/A
Severity level
3
Example
SPBM/3/SPBM_LICENSE_UNAVAILABLE: The SPBM feature has no available license.
Explanation
No license is found for SPBM.
Recommended action
SSHS messages
This section contains SSH server messages.
SSHS_ALGORITHM_MISMATCH
Message text
SSH client [STRING] failed to log in because of [STRING] algorithm mismatch.
Variable fields
$1: IP address of the SSH client.
$2: Type of the algorithm, including encryption, key exchange, MAC, and public key.
Severity level
6
Example
SSHS/6/SSHS_ALGORITHM_MISMATCH: SSH client 192.168.30.117 failed to log in because of encryption algorithm mismatch.
Explanation
The SSH client and the SSH server used different algorithms.
Recommended action
Check that the SSH client and the SSH server use the same algorithm.
SSHS_AUTH_EXCEED_RETRY_TIMES
Message text
SSH user [STRING] (IP: [STRING]) failed to log in, because the number of authentication attempts exceeded the upper limit.
Variable fields
$1: User name.
$2: IP address of the SSH client.
Severity level
6
Example
SSHS/6/SSHS_AUTH_EXCEED_RETRY_TIMES: SSH user David (IP: 192.168.30.117) failed to log in, because the number of authentication attempts exceeded the upper limit.
Explanation
The number of authentication attempts by an SSH user reached the upper limit.
Recommended action
Prompt the SSH user to use the correct login data to try again.
SSHS_AUTH_FAIL
Message text
SSH user [STRING] (IP: [STRING]) didn't pass public key authentication for [STRING].
Variable fields
$1: Username.
$3: Failure reasons:
?     Wrong public key algorithm.
?     Wrong public key.
?     Wrong digital signature.
Severity level
5
Example
SSHS/5/SSHS_AUTH_FAIL: SSH user David (IP: 192.168.30.117) didn't pass public key authentication for wrong public key algorithm.
Explanation
An SSH user failed the publickey authentication.
Recommended action
Tell the SSH user to try to log in again.
SSHS_AUTH_TIMEOUT
Message text
Authentication timed out for [IPADDR].
Variable fields
Severity level
6
Example
SSHS/6/SSHS_AUTH_TIMEOUT: Authentication timed out for 1.1.1.1.
Explanation
The authentication timeout timer expired, and the SSH user failed the authentication.
Recommended action
Make sure the SSH user enters the correct authentication information before the authentication timeout timer expires.
SSHS_CONNECT
Message text
SSH user [STRING] (IP: [STRING]) connected to the server successfully.
Variable fields
$1: Username.
Severity level
6
Example
SSHS/6/SSHS_CONNECT: SSH user David (IP: 192.168.30.117) connected to the server successfully.
Explanation
An SSH user logged in to the server successfully.
Recommended action
SSHS_DECRYPT_FAIL
Message text
The packet from [STRING] failed to be decrypted with [STRING].
Variable fields
$2: Encryption algorithm, such as AES256-CBC.
Severity level
5
Example
SSHS/5/SSHS_DECRYPT_FAIL: The packet from 192.168.30.117 failed to be decrypted with aes256-cbc.
Explanation
A packet from an SSH client failed to be decrypted.
Recommended action
SSHS_DISCONNECT
Message text
SSH user [STRING] (IP: [STRING]) disconnected from the server.
Variable fields
$1: Username.
Severity level
6
Example
SSHS/6/SSHS_DISCONNECT: SSH user David (IP: 192.168.30.117) disconnected from the server.
Explanation
An SSH user logged out.
Recommended action
SSHS_ENCRYPT_FAIL
Message text
The packet to [STRING] failed to be encrypted with [STRING].
Variable fields
$2: Encryption algorithm, such as aes256-cbc.
Severity level
5
Example
SSHS/5/SSHS_ENCRYPT_FAIL: The packet to 192.168.30.117 failed to be encrypted with aes256-cbc.
Explanation
A packet to an SSH client failed to be encrypted.
Recommended action
SSHS_LOG
Message text
Authentication failed for [STRING] from [STRING] port [INT32] ssh2.
Variable fields
$2: Username.
$3: Port number.
Severity level
6
Example
SSHS/6/SSHS_LOG: Authentication failed for David from 140.1.1.46 port 16266 ssh2.
Explanation
An SSH user failed password authentication because the username or password was wrong.
Recommended action
SSHS_MAC_ERROR
Message text
SSH server received a packet with wrong message authentication code (MAC) from [STRING].
Variable fields
Severity level
6
Example
SSHS/6/SSHS_MAC_ERROR: SSH server received a packet with wrong message authentication code (MAC) from 192.168.30.117.
Explanation
The SSH server received a packet with a wrong MAC from a client.
Recommended action
SSHS_REACH_SESSION_LIMIT
Message text
SSH client [STRING] failed to log in, because the number of SSH sessions reached the upper limit.
Variable fields
Severity level
6
Example
SSHS/6/SSHS_REACH_SESSION_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of SSH sessions reached the upper limit.
Explanation
The number of SSH sessions reached the upper limit.
Recommended action
SSHS_REACH_USER_LIMIT
Message text
SSH client [STRING] failed to log in, because the number of users reached the upper limit.
Variable fields
Severity level
6
Example
SSHS/6/SSHS_REACH_USER_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of users reached the upper limit.
Explanation
The number of SSH users reached the upper limit.
Recommended action
SSHS_SCP_OPER
Message text
User [STRING] at [IPADDR] requested operation: [STRING].
Variable fields
$1: Username.
$3: Requested file operation:
?     get file "name"—Downloads the file name.
?     put file "name"—Uploads the file name.
Severity level
6
Example
SSHS/6/SSHS_SCP_OPER: User user1 at 1.1.1.1 requested operation: put file " flash:/aa".
Explanation
The SCP sever received a file operation request from an SSH client.
Recommended action
SSHS_SFTP_OPER
Message text
Variable fields
$1: Username.
$3: Requested operation on a file or directory:
?     open dir "path"—Opens the directory path.
?     open "file" (attribute code code) in MODE mode—Opens the file file with the attribute code code in Mode mode.
?     remove file "path"—Deletes the file path.
?     mkdir "path" (attribute code code)—Creates a new directory path with the attribute code code.
?     rmdir "path"Deletes the directory path.
?     rename old "old-name" to new "new-name"Changes the name of a file or folder from old-name to new-name.
Severity level
6
Example
SSHS/6/SSHS_SFTP_OPER: User user1 at 1.1.1.1 requested operation: open dir "flash:/".
Explanation
The SFTP sever received an operation request from an SSH client.
Recommended action
SSHS_VERSION_MISMATCH
Message text
SSH client [STRING] failed to log in because of version mismatch.
Variable fields
Severity level
6
Example
SSHS/6/SSHS_VERSION_MISMATCH: SSH client 192.168.30.117 failed to log in because of version mismatch.
Explanation
The SSH client and the SSH server used different SSH versions.
Recommended action
Check that the SSH client and the SSH server use the same SSH version.
STAMGR messages
This section contains station management messages.
STAMGR_ADDBAC_INFO
Message text
Add BAS AC [STRING].
Variable fields
$1: MAC address of the BAS AC.
Severity level
6
Example
STAMGR/6/STAMGR_ADDBAC_INFO:
Add BAS AC 3ce5-a616-28cd.
Explanation
The BAS AC was connected to the master AC.
Recommended action
STAMGR_ADDSTA_INFO
Message text
Add client [STRING].
Variable fields
$1: MAC address of the client.
Severity level
6
Example
STAMGR/6/STAMGR_ADDSTA_INFO:
Add client 3ce5-a616-28cd.
Explanation
The client was connected to the BAS AC.
Recommended action
STAMGR_DELBAC_INFO
Message text
Delete BAS AC [STRING].
Variable fields
Severity level
6
Example
STAMGR/6/STAMGR_DELBAC_INFO:
Delete BAS AC 3ce5-a616-28cd.
Explanation
The BAS AC was disconnected from the master AC.
Recommended action
STAMGR_DELSTA_INFO
Message text
Delete client [STRING].
Variable fields
Severity level
6
Example
STAMGR/6/STAMGR_DELSTA_INFO:
Delete client 3ce5-a616-28cd.
Explanation
The client was disconnected from the BAS AC.
Recommended action
STAMGR_STAIPCHANGE_INFO
Message text
IP address of client [STRING] changed to [STRING].
Variable fields
$1: New IP address of the client.
Severity level
6
Example
STAMGR/6/STAMGR_STAIPCHANGE_INFO:
IP address of client 3ce5-a616-28cd changed to 4.4.4.4.
Explanation
The IP address of the client was updated.
Recommended action
STM messages
This section contains IRF messages.
STM_AUTO_UPDATE
Message text
Slot [UINT32] auto-update failed because [STRING].
Variable fields
$1: Slot ID.
$2: Failure reason.
Severity level
4
Example
STM/4/STM_AUTO_UPDATE: Slot 5 auto-update failed because incompatible software version.
Explanation
Software synchronization from the master failed on a slot.
Recommended action
Upgrade software manually for the device to join the IRF fabric.
STM_MEMBERID_CONFLICT
Message text
Self member-id is changed from [UINT32] to [UINT32].
Variable fields
$1: Old member ID.
$2: New member ID.
Severity level
4
Example
STM/4/STM_MEMBERID_CONFLICT: Self member-id changed from 1 to 4.
Explanation
The device's member ID changed.
Recommended action
STM_MERGE
Message text
Merge occurs. This IRF need NOT be rebooted.
Variable fields
N/A
Severity level
5
Example
STM/5/STM_MERGE: Merge occurs. This IRF need NOT be rebooted.
Explanation
You do not need to reboot the current IRF fabric for IRF merge, because it was elected the master.
Recommended action
STM_MERGE_NEED_REBOOT
Message text
Merge occurs. This IRF need be rebooted.
Variable fields
N/A
Severity level
4
Example
STM/4/STM_MERGE_NEED_REBOOT: Merge occurs. This IRF need be rebooted.
Explanation
You must reboot the current IRF fabric for IRF merge, because it failed in the master election.
Recommended action
STM_LINK_RECOVERY
Message text
Merge occurs.
Variable fields
N/A
Severity level
4
Example
STM/4/STM_LINK_RECOVERY: Merge occurs.
Explanation
IRF merge occurred.
Recommended action
STM_LINK_STATUS_DOWN
Message text
IRF port [UINT32] is down.
Variable fields
$1: IRF port name.
Severity level
3
Example
STM/3/STM_LINK_STATUS_DOWN: IRF port 2 is down.
Explanation
The IRF port went down. This event occurs when all physical ports bound to an IRF port are down.
Recommended action
Check the physical ports bound to the IRF port. Make sure at least one member physical port is up.
STM_LINK_STATUS_TIMEOUT
Message text
IRF port [UINT32] is down because heartbeat timed out.
Variable fields
$1: IRF port name.
Severity level
2
Example
STM/2/STM_LINK_STATUS_TIMEOUT: IRF port 1 is down because heartbeat timed out.
Explanation
The IRF port went down because of heartbeat timeout.
Recommended action
Check the IRF link for link failure.
STM_LINK_STATUS_UP
Message text
IRF port [UINT32] is up.
Variable fields
$1: IRF port name.
Severity level
6
Example
STM/6/STM_LINK_STATUS_UP: IRF port 1 is up.
Explanation
An IRF port came up.
Recommended action
STM_SOMER_CHECK
Message text
Neighbor of IRF port [UINT32] can't be stacked.
Variable fields
$1: IRF port name.
Severity level
3
Example
STM/3/STM_SOMER_CHECK: Neighbor of IRF port 1 can't be stacked.
Explanation
The neighbor connected to the IRF port cannot form an IRF fabric with the device.
Recommended action
1.     Check the following items:
2.     The device models can form an IRF fabric.
3.     The IRF settings are correct. For more information, see the IRF configuration guide for the device.
SYSLOG messages
This section contains syslog messages.
SYSLOG_LOGFILE_FULL
Message text
Log file space is full.
Variable fields
N/A
Severity level
4
Example
SYSLOG/4/SYSLOG_LOGFILE_FULL: Log file space is full.
Explanation
The log file space is full.
Recommended action
Back up the log file, delete the original log file, and then bring up interfaces if needed.
SYSLOG_RESTART
Message text
System restarted --
[STRING] [STRING] Software.
Variable fields
$1: Company name. Available options include H3C.
$2: Software name. Available options include Comware and Router.
Severity level
6
Example
SYSLOG/6/SYSLOG_RESTART: System restarted --
H3C Comware Software
Explanation
A system restart log was created.
Recommended action
TACACS messages
This section contains TACACS messages.
TACACS_AUTH_FAILURE
Message text
Variable fields
$1: User name.
$2: IP address.
Severity level
5
Example
TACACS/5/TACACS_AUTH_FAILURE: User cwf@system from 192.168.0.22 failed authentication.
Explanation
An authentication request was rejected by the TACACS server.
Recommended action
TACACS_AUTH_SUCCESS
Message text
Variable fields
$1: User name.
$2: IP address.
Severity level
6
Example
TACACS/6/TACACS_AUTH_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully.
Explanation
An authentication request was accepted by the TACACS server.
Recommended action
TACACS_DELETE_HOST_FAIL
Message text
Variable fields
$1: Scheme name.
Severity level
4
Example
TACACS/4/TACACS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc.
Explanation
Failed to delete servers from a TACACS scheme.
Recommended action
TELNETD messages
This section contains Telnet messages.
TELNETD_REACH_SESSION_LIMIT
Message text
Telnet client [IPADDR] failed to log in. Number of Telnet sessions reached the limit.
Variable fields
$1: IP address of a Telnet client.
Severity level
6
Example
TELNETD/6/TELNETD_REACH_SESSION_LIMIT:Telent client 1.1.1.1 failed to log in. Number of Telnet sessions reached the limit.
Explanation
Number of online Telnet users already reached the limit.
Recommended action
TRILL messages
This section contains TRILL messages.
TRILL_DUP_SYSTEMID
Message text
Duplicate system ID [STRING] in [STRING] PDU sourced from RBridge 0x[HEX].
Variable fields
$1: System ID.
$2: PDU type.
$3: Source RBridge's nickname.
Severity level
5
Example
TRILL/5/TRILL_DUP_SYSTEMID: Duplicate system ID 0011.2200.1501 in LSP PDU sourced from RBridge 0xc758.
Explanation
The local RBridge received an LSP or IIH PDU that has the same system ID as the local RBridge. The possible reasons include:
·     The same system ID is assigned to the local RBridge and the remote RBridge.
·     The local RBridge received a self-generated LSP PDU with an old nickname.
Recommended action
Please check the RBridge system IDs on the campus network.
TRILL_INTF_CAPABILITY
Message text
The interface [STRING] does not support TRILL.
Variable fields
$1: Interface name.
Severity level
4
Example
TRILL/4/TRILL_INTF_CAPABILITY: The interface GigabitEthernet0/1/3 does not support TRILL.
Explanation
An interface that does not support TRILL was assigned to a link aggregation group.
Recommended action
Remove the interface that does not support TRILL from the link aggregation group.
TRILL_INTF ENTERED_SUSPENDED
Message text
Interface [STRING] entered the suspended state.
Variable fields
$1: Interface name.
Severity level
4
Example
TRILL/4/TRILL_INTF_ENTERED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 entered the suspended state.
Explanation
The RB put a TRILL port to the suspended state. The message is sent in any of the following situations:
·     The TRILL port is on the same broadcast network as a high-priority TRILL port of the RB.
·     Loops exist on the TRILL port.
Recommended action
To resolve the problem, perform the following tasks:
·     Remove redundant TRILL ports of the RB from the broadcast network.
·     Eliminate the loops on the TRILL port.
TRILL_INTF EXITED_SUSPENDED
Message text
Interface [STRING] exited the suspended state.
Variable fields
$1: Interface name.
Severity level
4
Example
TRILL/4/TRILL_INTF_EXITED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 exited the suspended state.
Explanation
A TRILL port exited the suspended state. The message is sent in any of the following situations:
·     Redundant TRILL ports of the RB are removed from the broadcast network that is connected to the TRILL port.
·     Loops are eliminated from the TRILL port.
Recommended action
TRILL_LICENSE_UNAVAILABLE
Message text
The TRILL feature has no available license.
Variable fields
N/A
Severity level
3
Example
TRILL/3/TRILL_LICENSE_UNAVAILABLE: The TRILL feature has no available license.
Explanation
No license was found for TRILL when the TRILL process started.
Recommended action
Install a license for TRILL.
TRILL_LICENSE_EXPIRED
Message text
The TRILL feature is being disabled, because its license has expired.
Variable fields
N/A
Severity level
3
Example
TRILL/3/TRILL_LICENSE_EXPIRED: The TRILL feature is being disabled, because its license has expired.
Explanation
TRILL is being disabled because its license has expired.
Recommended action
Install a valid license for TRILL.
TRILL_LICENSE_EXPIRED_TIME
Message text
The TRILL feature will be disabled in [ULONG] days.
Variable fields
Severity level
5
Example
TRILL/5/TRILL_LICENSE_EXPIRED_TIME: The TRILL feature will be disabled in 2 days.
Explanation
TRILL will be disabled because no TRILL license is available. After an active/standby MPU switchover, you can use TRILL only for 30 days if the new active MPU does not have a TRILL license.
Recommended action
TRILL_MEM_ALERT
Message text
TRILL process receive system memory alert [STRING] event.
Variable fields
$1: Type of the memory alert event.
Severity level
5
Example
TRILL/5/TRILL_MEM_ALERT: TRILL process receive system memory alert start event.
Explanation
TRILL received a memory alert event from the system.
Recommended action
Check the system memory.
TRILL_NBR_CHG
Message text
TRILL [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING].
Variable fields
$1: TRILL process ID.
$2: Neighbor level.
$3: Neighbor system ID.
$4: Interface name.
$5: Current neighbor state.
Severity level
5
Example
TRILL/5/TRILL_NBR_CHG: TRILL 1, Level-1 adjacency 0011.2200.1501 (GigabitEthernet0/1/3), state change to: down.
Explanation
The state of a TRILL neighbor changed.
Recommended action
When the neighbor state changes to down or initializing, please check the TRILL configuration and network status according to the reason for the neighbor state change.
VLAN messages
This section contains VLAN messages.
VLAN_FAILED
Message text
Failed to add interface [STRING] to the default VLAN.
Variable fields
$1: Interface name.
Severity level
4
Example
VLAN/4/VLAN_FAILED: Failed to add interface S-Channel 4/2/0/19:100 to the default VLAN.
Explanation
An S-channel interface was created when hardware resources were insufficient. The S-channel interface failed to be assigned to the default VLAN.
Recommended action
VLAN_VLANMAPPING_FAILED
Message text
The configuration failed because of resource insufficiency or conflicts on [STRING].
Variable fields
$1: Interface name.
Severity level
4
Example
VLAN/4/VLAN_VLANMAPPING_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0.
Explanation
Part of or all VLAN mapping configurations on the interface were lost because of one of the following occurrences:
·     Hardware resources were insufficient for the interface.
·     The interface joined or left a Layer 2 aggregation group.
Recommended action
VLAN_VLANTRANSPARENT_FAILED
Message text
Variable fields
$1: Interface name.
Severity level
4
Example
VLAN/4/VLAN_VLANTRANSPARENT_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0.
Explanation
Part of or all VLAN transparent transmission configurations on the interface were lost because of one of the following occurrences:
Recommended action
VRRP messages
This section contains VRRP messages.
VRRP_AUTH_FAILED
Message text
Authentication failed in [STRING] virtual router [UINT32] (configured on [STRING]): [STRING].
Variable fields
$1: VRRP version.
$2: VRRP group number.
$3: Name of the interface where the VRRP group is configured.
$4: Error information details.
Severity level
6
Example
VRRP/6/VRRP_AUTH_FAILED: Authentication failed in IPv4 virtual router 10 (configured on Ethernet0/0): authentication type mismatch.
Explanation
A VRRP packet was received, but did not pass the authentication examination.
Recommended action
Check the configuration of the VRRP group on the specified interface. Make sure every router in the VRRP group uses the same authentication mode and authentication key.
VRRP_CONFIG_ERROR
Message text
The [STRING] virtual router [UINT32] (configured on [STRING]) detected a VRRP configuration error: [STRING].
Variable fields
$1: VRRP version.
$3: Name of the interface where VRRP group is configured.
Severity level
6
Example
VRRP/6/VRRP_CONFIG_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) detected a VRRP configuration error: VIRTUAL IP ADDRESS COUNT ERROR.
Explanation
The VRRP group configuration was not correct. For example, the virtual IP address count of the VRRP group was not the same on the members.
Recommended action
Check the VRRP group configuration on the specified interface. Make sure every member in the VRRP group uses the same configuration.
VRRP_PACKET_ERROR
Message text
The [STRING] virtual router [UINT32] (configured on [STRING]) received an error packet: [STRING].
Variable fields
$1: VRRP version.
$3: Interface where the VRRP group is configured.
Severity level
6
Example
VRRP/6/VRRP_PACKET_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) received an error packet: CKSUM ERROR.
Explanation
The VRRP group received an invalid VRRP packet. For example, the checksum was not correct.
Recommended action
VRRP_STATUS_CHANGE
Message text
The status of [STRING] virtual router [UINT32] (configured on [STRING]) changed from [STRING] to [STRING]: [STRING].
Variable fields
$1: VRRP version.
$4: Original status.
$5: Current status.
$6: Reason for status change.
Severity level
6
Example
VRRP/6/VRRP_STATUS_CHANGE: The status of IPv4 virtual router 10 (configured on Ethernet0/0) changed (from Backup to Master): Timer expired.
Explanation
The VRRP group status changed because the timer expired.
Recommended action
Check the VRRP group status to make sure it is operating correctly.
VRRP_VF_STATUS_CHANGE
Message text
The [STRING] virtual router [UINT32] (configured on [STRING]) virtual forwarder [UINT32] detected status change (from [STRING] to [STRING]): [STRING].
Variable fields
$1: VRRP version.
$4: VF ID.
$5: Original status of VF.
$6: Current status of VF.
$7: Reason for the status change.
Severity level
6
Example
VRRP/6/VRRP_VF_STATUS_CHANGE: The IPv4 virtual router 10 (configured on GigabitEthernet5/1) virtual forwarder 2 detected status change (from Active to Initialize): Weight changed.
Explanation
The status of the virtual forwarder changed because the weight changed, the timeout timer expired, or VRRP went down.
Recommended action
Check the status of the track entry.
VRRP_VMAC_INEFFECTIVE
Message text
The [STRING] virtual router [UINT32] (configured on [STRING]) failed to add virtual MAC: [STRING].
Variable fields
$1: VRRP version.
$4: Reason for the error.
Severity level
3
Example
VRRP/3/VRRP_VMAC_INEFFECTIVE: The IPv4 virtual router 10 (configured on Ethernet0/0) failed to add virtual MAC: Hardware resources insufficient.
Explanation
The virtual router failed to add a virtual MAC address.
Recommended action
Find out the root cause for the operation failure and fix the problem.
