06 ACL and QoS Configuration Guide
HomeSupportSwitchesH3C S6800 Switch SeriesConfigure & DeployConfiguration GuidesH3C S6800 Configuration Guides-Release 2407-6W10006 ACL and QoS Configuration Guide
Download Book
Preface
The H3C S6800 documentation set includes 9 configuration guides, which describe the software features for the H3C S6800 Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The ACL and QoS Configuration Guide describes fundamentals and configuration of ACL and QoS. It describes how to create IPv4 ACL and IPv6 ACL, use ACL for packet filtering, use QoS polices to control traffic, and configure common QoS techniques such as traffic policing, traffic shaping, congestion management, and congestion avoidance.
This preface includes:
·     Audience
·     Conventions
·     About the H3C S6800 documentation set
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S6800 series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access controller, a unified wired-WLAN module, or the switching engine on a unified wired-WLAN switch.
Represents an access point.
Represents a security product, such as a firewall, a UTM, or a load-balancing or security card that is installed in a device.
Represents a security card, such as a firewall card, a load-balancing card, or a NetStream card.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S6800 documentation set includes:
Category
Documents
Purposes
Product description and specifications
Marketing brochures
Describe product specifications and benefits.
Hardware specifications and installation
Compliance and safety manual
Provides regulatory information and the safety instructions that must be followed during installation.
Installation quick start
Provides basic installation instructions.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
H3C LSWM1HFANSC & LSWM1HFANSCB Fan Assemblies Installtion
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies.
H3C SFP/SFP+/XFP Transceiver Modules Installation Guide
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules.
H3C LSVM1AC650 & LSVM1DC650 Power Modules User Manual
Describes the appearance, specifications, and installation and removal of hot-swappable power modules.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
MIB Companion
Describes the MIBs for the software release.
Release notes
Provide information about the product release and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
