Title | Size | Downloads |
04 Layer 3 - IP Routing Configuration Guide-book.pdf | 3.07 MB |
Preface
The H3C S6800 documentation set includes 9 configuration guides, which describe the software features for the H3C S6800 Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 3—IP Routing Configuration Guide describes routing fundamentals and configuration. It covers the mainstream routing protocols for IPv4 and IPv6 networks, and describes how to use policies to filter routes and affect routing decisions.
This preface includes:
· Audience
· About the H3C S6800 documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S6800 series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access controller, a unified wired-WLAN module, or the switching engine on a unified wired-WLAN switch. |
Represents an access point. |
Represents a security product, such as a firewall, a UTM, or a load-balancing or security card that is installed in a device. |
Represents a security card, such as a firewall card, a load-balancing card, or a NetStream card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S6800 documentation set includes:
Category |
Documents |
Purposes |
Product description and specifications |
Marketing brochures |
Describe product specifications and benefits. |
Hardware specifications and installation |
Compliance and safety manual |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Provides basic installation instructions. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
H3C LSWM1HFANSC & LSWM1HFANSCB Fan Assemblies Installtion |
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies. |
H3C SFP/SFP+/XFP Transceiver Modules Installation Guide |
Describe the installation, and replacement of SFP/SFP+/XFP transceiver modules. |
H3C LSVM1AC650 & LSVM1DC650 Power Modules User Manual |
Describes the appearance, specifications, and installation and removal of hot-swappable power modules. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
MIB Companion |
Describes the MIBs for the software release. |
Release notes |
Provide information about the product release and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the links on the top navigation bar to obtain different categories of product documentation:
[Technical Support & Documents > Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Technical Support & Documents > Software Download]—Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
