02-IRF Command Reference
HomeSupportSwitchesH3C S5800-EI Switch SeriesReference GuidesCommand ReferencesH3C S5800-EI Switch Series Command References-R71xx-6W10102-IRF Command Reference
Download Book
Title Size Downloads
02-IRF Command Reference-book.pdf 185.32 KB
Preface
This command reference describes IRF configuration commands for setting up and maintaining an IRF fabric, including:
·     Commands for IRF port binding configuration.
·     Commands for IRF member ID and priority configuration.
·     Commands for detecting IRF splits and maintaining the IRF fabric.
·     Audience
·     Conventions
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the S5800-EI switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
To access the most up-to-date H3C product documentation, go to the H3C website at
http://www.h3c.com.hk
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
We appreciate your comments.
