04-WLAN Configuration Guide
HomeSupportSwitchesH3C S5560X-EI Switch SeriesConfigure & DeployConfiguration GuidesH3C Unified Wired and Wireless Access Controller User Manual (R5204)-6W10004-WLAN Configuration Guide
Download Book
Title Size Downloads
04-WLAN Configuration Guide-book.pdf 3.05 MB
Preface
This configuration guide describes the WLAN configuration tasks for the Unified Wired and Wireless Access Controllers. It covers the following features:
·     AP management.
·     Radio management, WLAN radio resource measurement, and WLAN RRM.
·     WLAN access, WLAN security, and WLAN authentication.
·     WLAN QoS, WLAN load balancing, channel scanning, band navigation, and WLAN high availability.
·     WLAN roaming and 802.11r.
·     WLAN IP snooping.
·     Audience.
·     Conventions.
·     Obtaining documentation.
·     Technical support
·     Documentation feedback.
Audience
·     Network planners.
·     Network administrators working with the Unified Wired and Wireless Access Controller.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Wireless terminator unit.
Wireless terminator.
To access the most up-to-date H3C product documentation, go to the H3C website at http://www.h3c.com.hk.
To obtain information about installation, configuration, and maintenance, click
http://www.h3c.com.hk/Technical_Documents
To obtain software version information such as release notes, click
http://www.h3c.com.hk/Software_Download
Technical support
[email protected]
You can email your comments about product documentation to [email protected].
We appreciate your comments.
