Title | Size | Downloads |
H3C S5560-EI System Log Messages Reference-6W102-book.pdf | 961.43 KB |
H3C S5560-EI Switch Series System Log Messages Reference
Copyright © 2015-2018 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
PFILTER_VLAN_IPV4_DACT_UNK_ERR
PFILTER_VLAN_IPV6_DACT_UNK_ERR
ARP_ACTIVE_ACK_NOREQUESTED_REPLY
ETHOAM_CONNECTION_FAIL_TIMEOUT
ETHOAM_CONNECTION_FAIL_UNSATISF
ETHOAM_ENTER_LOOPBACK_CTRLLING
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
ETHOAM_LOCAL_ERROR_FRAME_SECOND
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
ETHOAM_REMOTE_ERROR_FRAME_SECOND
FCOE_INTERFACE_NOTSUPPORT_FCOE
FCLINK_FDISC_REJECT_NORESOURCE
FCLINK_FLOGI_REJECT_NORESOURCE
FCOE_FIPS_HARD_RESOURCE_NOENOUGH
FCOE_FIPS_HARD_RESOURCE_RESTORE
LAGG_INACTIVE_RESOURCE_INSUFICIE
Introduction
This document includes the following system messages:
· Messages specific to Release 1109 of the switch.
· Messages for the Comware V7 software platform version based on which Release 1109 was produced. Some platform system messages might not be available on the switch.
This document is intended only for managing S5560-EI switches. Do not use this document for any other device models.
This document assumes that the readers are familiar with data communications technologies and H3C networking products.
System log message format
By default, the system log messages use the following RFC 3164-compliant format:
<PRI>TIMESTAMP HOSTNAME %%vendorMODULE/ severity /MNEMONIC: location; CONTENT
Table 1 System log message elements
Element |
<PRI> |
Priority identifier. It is calculated by using the following formula: Priority identifier=facilityx8+severity Where: · Facility is specified by using the info-center loghost command. A log host uses this parameter to identify log sources and filter log messages. · Severity represents the importance of the message. For more information about severity levels, see Table 2. Different log host might present the priority identifier element in different formats. |
TIMESTAMP |
Date and time when the event occurred. You can use the info-center timestamp loghost command to specify the format. |
HOSTNAME |
Device name. |
%%vendor |
Manufacturer flag. This element is %%10 for H3C. |
MODULE |
Name of the module that produced the message. |
severity |
Severity level of the message. (For more information about severity levels, see Table 2.) |
MNEMONIC |
Text string that uniquely identifies the system message. |
location |
Optional. This element presents location information for the message in the following format: -attribute1=x-attribute2=y…-attributeN=z This element is separated from the message description by using a semicolon (;). |
CONTENT |
Text string that contains detailed information about the event or error. For variable fields in this element, this document uses the representations in Table 3. |
System log messages are classified into eight severity levels from 0 to 7. The lower the number, the higher the severity.
Table 2 System log message severity levels
Level |
Severity |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
3 |
Error |
Error condition. For example, the link state changes or a storage card is unplugged. |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
5 |
Notice |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
7 |
Debug |
Debugging message. |
For variable fields in the message text, this document uses the representations in Table 3. The values are case insensitive, even though the representations are uppercase letters.
Table 3 Variable field representations
Representation |
Information type |
INT16 |
Signed 16-bit decimal number. |
UINT16 |
Unsigned 16-bit decimal number. |
INT32 |
Signed 32-bit decimal number. |
UINT32 |
Unsigned 32-bit decimal number. |
INT64 |
Signed 64-bit decimal number. |
UINT64 |
Unsigned 64-bit decimal number. |
DOUBLE |
Two dot-separated signed 32-bit decimal numbers. The format is [INTEGER].[INTEGER]. |
HEX |
Hexadecimal number. |
CHAR |
Single character. |
STRING |
Character string. |
IPADDR |
IP address. |
MAC |
MAC address. |
DATE |
Date. |
TIME |
Time. |
Software module list
Table 4 lists all software modules that might produce system log messages.
Module name representation |
Module name expansion |
AAA |
Authentication, Authorization and Accounting |
ACL |
Access Control List |
APMGR |
Access Point Management |
ARP |
Address Resolution Protocol |
BFD |
Bidirectional Forwarding Detection |
BGP |
Border Gateway Protocol |
CFD |
Connectivity Fault Detection |
CFGMAN |
Configuration Management |
DEV |
Device Management |
DIAG |
Diagnosis |
DLDP |
Device Link Detection Protocol |
ETHOAM |
Ethernet Operation, Administration and Maintenance |
EVB |
Edge Virtual Bridging |
EVIISIS |
Ethernet Virtual Interconnect Intermediate System-to-Intermediate System |
FCOE |
Fibre Channel Over Ethernet |
FCLINK |
Fibre Channel Link |
FCZONE |
Fibre Channel Zone |
FIPS |
FIP Snooping |
FTP |
File Transfer Protocol |
HA |
High Availability |
HTTPD |
Hypertext Transfer Protocol Daemon |
IFNET |
Interface Net Management |
IKE |
Internet Key Exchange |
IPSEC |
IP Security |
IRDP |
ICMP Router Discovery Protocol |
ISIS |
L2VPN |
Layer 2 VPN |
LAGG |
Link Aggregation |
LDP |
Label Distribution Protocol |
LLDP |
Link Layer Discovery Protocol |
LOAD |
Load Management |
LOGIN |
Login |
LPDT |
Loopback Detection |
LS |
Local Server |
LSPV |
LSP Verification |
MAC |
Media Access Control |
MBFD |
MPLS BFD |
MDC |
Multitenant Device Context |
MFIB |
Multicast Forwarding Information Base |
MGROUP |
Mirroring group |
MPLS |
Multiprotocol Label Switching |
MSTP |
Multiple Spanning Tree Protocol |
MTLK |
Monitor Link |
ND |
Neighbor Discovery |
NQA |
Network Quality Analyzer |
NTP |
Network Time Protocol |
OPTMOD |
Optical Module |
OSPF |
Open Shortest Path First |
OSPFV3 |
Open Shortest Path First Version 3 |
PBB |
Provider Backbone Bridge |
PIM |
Protocol Independent Multicast |
PING |
Packet Internet Groper |
PKI |
Public Key Infrastructure |
PKT2CPU |
Packet to CPU |
PORTSEC |
Port Security |
PPP |
Point to Point Protocol |
PWDCTL |
Password Control |
QOS |
Quality of Service |
RADIUS |
Remote Authentication Dial In User Service |
RIP |
Routing Information Protocol |
RIPNG |
Routing Information Protocol Next Generation |
RM |
Routing Management |
SCM |
Service Control Manager |
Static CRLSP |
SHELL |
Shell |
Static LSP |
SMLK |
Smart Link |
SNMP |
Simple Network Management Protocol |
SSHS |
Secure Shell Server |
STAMGR |
Station Management |
STM |
Stack Topology Management (IRF) |
SYSLOG |
System Log |
TACACS |
Terminal Access Controller Access Control System |
TELNETD |
Telecom Munication Network Protocol Daemon |
TRILL |
Transparent Interconnect of Lots of Links |
VLAN |
Virtual Local Area Network |
VRRP |
Virtual Router Redundancy Protocol |
Using this document
This document categorizes system log messages by software modules. The modules appear in this document in alphabetic order. For each module, the system log messages are also listed in alphabetic order of their mnemonic names.
This document explains messages in tables. Table 5 describes information provided in these tables.
Table 5 Message explanation table contents
Item |
Content |
Example |
Message text |
Presents the message description. |
ACL [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
Briefly describes the variable fields in the order that they appear in the message text. The variable fields are numbered in the "$Number" form to help you identify their location in the message text. |
$1: ACL number. $2: ID and content of an ACL rule. $3: Number of packets that matched the rule. |
Severity level |
Provides the severity level of the message. |
6 |
Example |
Provide a real message example. The example does not include the "<Int_16>TIMESTAMP HOSTNAME %%vendor" part, because information in this part varies with system settings. |
ACL/6/ACL_STATIS_INFO: ACL 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
Explanation |
Explains the message, including the event or error cause. |
Number of packets that matched an ACL rule. This message is sent when the packet counter changes. |
Recommended action |
Provides recommended actions. For informational messages, no action is required. |
No action is required. |
AAA messages
This section contains AAA messages.
AAA_FAILURE
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA failed. |
Variable fields |
$1: AAA type. $2: AAA scheme. $3: Service. $4: User name. |
Severity level |
5 |
Example |
AAA/5/AAA_FAILURE: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is failed. |
Explanation |
An AAA request was rejected. The following are the common reasons: · No response was received from the server. · The user name or password was incorrect. · The service type that the user applied for was incorrect. |
1. Verify that the device is correctly connected to the server. 2. Enter the correct username and password. 3. Verify that the server settings are the same as the settings on the device. 4. If the problem persists, contact H3C Support. |
AAA_LAUNCH
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA launched. |
Variable fields |
Severity level |
6 |
Example |
AAA/6/AAA_LAUNCH: -AAAType=AUTHEN-AAADomain=domain1-Service=login-UserName=cwf@system; AAA launched. |
Explanation |
An AAA request was received. |
AAA_SUCCESS
Message text |
-AAAType=[STRING]-AAADomain=[STRING]-Service=[STRING]-UserName=[STRING]; AAA is successful. |
Variable fields |
Severity level |
6 |
Example |
AAA/6/AAA_SUCCESS: -AAAType=AUTHOR-AAADomain=domain1-Service=login-UserName=cwf@system; AAA is successful. |
Explanation |
An AAA request was accepted. |
ACL messages
This section contains ACL messages.
ACL_IPV6_STATIS_INFO
Message text |
IPv6 ACL [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
$1: ACL number. $2: ID and content of an IPv6 ACL rule. $3: Number of packets that matched the rule. |
Severity level |
6 |
Example |
ACL6/6/ACL_IPV6_STATIS_INFO: IPv6 ACL 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
Explanation |
The number of packets matching the IPv6 ACL rule changed. |
ACL_NO_MEM
Message text |
Failed to configure [STRING] ACL [UINT] due to lack of memory. |
Variable fields |
$1: ACL version. $2: ACL number. |
Severity level |
3 |
Example |
ACL/3/ACL_NO_MEM: Failed to configure ACL 2001 due to lack of memory. |
Explanation |
Configuring the ACL failed because memory is insufficient. |
Use the display memory-threshold command to check the memory usage. |
ACL_STATIS_INFO
Message text |
Variable fields |
$1: ACL number. $2: ID and content of an IPv4 ACL rule. $3: Number of packets that matched the rule. |
Severity level |
6 |
Example |
Explanation |
The number of packets matching the IPv4 ACL rule changed. |
PFILTER_GLB_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
$1: Traffic direction. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv4 default action to a specific direction globally. · Updating the IPv4 default action applied to a specific direction globally. |
Use the display qos-acl resource command to check hardware resource usage. |
PFILTER_GLB_IPV4_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions due to an unknown error: · Applying the IPv4 default action to a specific direction globally. · Updating the IPv4 default action applied to a specific direction globally. |
PFILTER_GLB_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv6 default action to a specific direction globally. · Updating the IPv6 default action applied to a specific direction globally. |
PFILTER_GLB_IPV6_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the IPv6 default action to a specific direction globally. · Updating the IPv6 default action applied to a specific direction globally. |
PFILTER_GLB_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the MAC default action to a specific direction globally. · Updating the MAC default action applied to a specific direction globally. |
PFILTER_GLB_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the MAC default action to a specific direction globally. · Updating the MAC default action applied to a specific direction globally. |
PFILTER_GLB_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The resources are insufficient. |
Variable fields |
$1: ACL version. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
PFILTER_GLB_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
Verify the ACL configuration and remove the settings that are not supported. |
PFILTER_GLB_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction globally. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_GLB_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction globally. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying an ACL rule to a specific direction globally. · Updating an ACL rule applied to a specific direction globally. |
PFILTER_IF_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
$1: Traffic direction. $2: Interface name. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv4 default action to a specific direction of an interface. · Updating the IPv4 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV4_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions because an unknown error: · Applying the IPv4 default action to a specific direction of an interface. · Updating the IPv4 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv6 default action to a specific direction of an interface. · Updating the IPv6 default action applied to a specific direction of an interface. |
PFILTER_IF_IPV6_DACT_UNK_ERR
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the IPv6 default action to a specific direction of an interface. · Updating the IPv6 default action applied to a specific direction of an interface. |
PFILTER_IF_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the MAC default action to a specific direction of an interface. · Updating the MAC default action applied to a specific direction of an interface. |
PFILTER_IF_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the MAC default action to a specific direction of an interface. · Updating the MAC default action applied to a specific direction of an interface. |
PFILTER_IF_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The resources are insufficient. |
Variable fields |
$1: ACL version. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. $5: Interface name. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IF_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_NOT_SUPPORT: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IF_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_IF_UNK_ERR: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of interface Ethernet 3/1/2. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying an ACL rule to a specific direction of an interface. · Updating an ACL rule applied to a specific direction of an interface. |
PFILTER_IPV6_STATIS_INFO
Message text |
[STRING] ([STRING]): Packet-filter IPv6 [UINT32] [STRING] [STRING] [UINT64] packet(s). |
Variable fields |
$1: Destination to which packet filter applies. $2: Traffic direction. $3: ACL number. $4: ID and content of an ACL rule. $5: Number of packets that matched the rule. |
Severity level |
6 |
Example |
ACL/6/PFILTER_IPV6_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter IPv6 2000 rule 0 permit source 1:1::/64 logging 1000 packet(s). |
Explanation |
The number of packets matching the packet-filter IPv6 ACL rule changed. |
PFILTER_STATIS_INFO
Message text |
[STRING] ([STRING]): Packet-filter [UINT32] [STRING] [UINT64] packet(s). |
Variable fields |
Severity level |
6 |
Example |
ACL/6/PFILTER_STATIS_INFO: Ethernet0/4/0 (inbound): Packet-filter 2000 rule 0 permit source 1.1.1.1 0 logging 10000 packet(s). |
Explanation |
The number of packets matching the packet-filter IPv4 ACL rule changed. |
PFILTER_VLAN_IPV4_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
$1: Traffic direction. $2: VLAN ID. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_NO_RES: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv4 default action to a specific direction of a VLAN. · Updating the IPv4 default action applied to a specific direction of a VLAN. |
Message text |
Failed to apply or refresh the IPv4 default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV4_DACT_UNK_ERR: Failed to apply or refresh the IPv4 default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the IPv4 default action to a specific direction of a VLAN. · Updating the IPv4 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_IPV6_DACT_NO_RES
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_NO_RES: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the IPv6 default action to a specific direction of a VLAN. · Updating the IPv6 default action applied to a specific direction of a VLAN. |
Message text |
Failed to apply or refresh the IPv6 default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_IPV6_DACT_UNK_ERR: Failed to apply or refresh the IPv6 default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the IPv6 default action to a specific direction of a VLAN. · Updating the IPv6 default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_MAC_DACT_NO_RES
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_MAC_DACT_NO_RES: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying the MAC default action to a specific direction of a VLAN. · Updating the MAC default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_MAC_DACT_UNK_ERR
Message text |
Failed to apply or refresh the MAC default action to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_MAC_DACT_UNK_ERR: Failed to apply or refresh the MAC default action to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying the MAC default action to a specific direction of a VLAN. · Updating the MAC default action applied to a specific direction of a VLAN. |
PFILTER_VLAN_NO_RES
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The resources are insufficient. |
Variable fields |
$1: ACL version. $2: ACL number. $3: ACL rule ID. $4: Traffic direction. $5: VLAN ID. |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_NO_RES: Failed to apply or refresh IPv6 ACL 2000 rule 1 to the inbound direction of VLAN 1. The resources are insufficient. |
Explanation |
The system failed to perform one of the following actions because hardware resources were insufficient: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
PFILTER_VLAN_NOT_SUPPORT
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. The ACL is not supported. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_NOT_SUPPORT: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. The ACL is not supported. |
Explanation |
The system failed to perform one of the following actions because the ACL rule is not supported: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
PFILTER_VLAN_UNK_ERR
Message text |
Failed to apply or refresh [STRING] ACL [UINT] [STRING] to the [STRING] direction of VLAN [UINT16]. |
Variable fields |
Severity level |
3 |
Example |
PFILTER/3/PFILTER_VLAN_UNK_ERR: Failed to apply or refresh ACL 2000 rule 1 to the inbound direction of VLAN 1. |
Explanation |
The system failed to perform one of the following actions because of an unknown error: · Applying an ACL rule to a specific direction of a VLAN. · Updating an ACL rule applied to a specific direction of a VLAN. |
APMGR messages
This section contains access point management messages.
APMGR_ADDBAC_INFO
Message text |
Add BAS AC [STRING]. |
Variable fields |
$1: MAC address of the BAS AC. |
Severity level |
6 |
Example |
APMGR/6/APMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was connected to the master AC. |
APMGR_DELBAC_INFO
Message text |
Delete BAS AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
APMGR/6/APMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was disconnected from the master AC. |
ARP messages
This section contains ARP messages.
ARP_ACTIVE_ACK_NO_REPLY
Message text |
No ARP reply from IP [STRING] was received on interface [STRING] |
Variable fields |
$1: IP address. $2: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_ACTIVE_ACK_NO_REPLY: No ARP reply from IP 192.168.10.1 was received on interface Ethernet0/1/0. |
Explanation |
An attack was detected by ARP active acknowledgement. An interface sent an ARP request to the sender IP of a received ARP message, but did not receive an ARP reply. |
Verify that the host that sends the ARP message is legitimate. |
Message text |
Interface [STRING] received from IP [STRING] an ARP reply that was not requested by the device. |
Variable fields |
$1: Interface name. $2: IP address. |
Severity level |
6 |
Example |
ARP/6/ARP_ACTIVE_ACK_NOREQUESTED_REPLY: Interface Ethernet0/1/0 received from IP 192.168.10.1 an ARP reply that was not requested by the device. |
Explanation |
The ARP active acknowledgement feature received an unsolicited ARP reply from a sender IP. This message indicates the risk of attacks. |
No action is required. The device discards the ARP reply automatically. |
ARP_RATE_EXCEEDED
Message text |
The ARP packet rate ([UINT32] pps) exceeded the rate limit ([UINT32] pps) on interface [STRING] in the last [UINT32] seconds |
Variable fields |
$1: ARP packet rate. $2: ARP limit rate. $3: Interface name. $4: Interval time. |
Severity level |
4 |
Example |
ARP/4/ARP_RATE_EXCEEDED: The ARP packet rate (100 pps) exceeded the rate limit (80 pps) on interface Ethernet0/1/0 in the last 10 seconds. |
Explanation |
An interface received ARP messages at a higher rate than the rate limit. |
Verify that the host that sends the ARP packets is legitimate. |
ARP_SENDER_IP_INVALID
Message text |
Sender IP [STRING] was not on the same network as the receiving interface [STRING] |
Variable fields |
Severity level |
6 |
Example |
ARP/6/ARP_SENDER_IP_INVALID: Sender IP 192.168.10.2 was not on the same network as the receiving interface Ethernet0/1/0. |
Explanation |
The sender IP of a received ARP message was not on the same network as the receiving interface. |
Verify that the host with the sender IP address is legitimate. |
ARP_SENDER_MAC_INVALID
Message text |
Sender MAC [STRING] was not identical to Ethernet source MAC [STRING] on interface [STRING] |
Variable fields |
$1: MAC address. $2: MAC address. $3: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_SENDER_MAC_INVALID: Sender MAC 0000-5E14-0E00 was not identical to Ethernet source MAC 0000-5C14-0E00 on interface Ethernet0/1/0. |
Explanation |
An interface received an ARP message. The sender MAC address in the message body was not identical to the source MAC address in the Ethernet header. |
Verify that the host with the sender MAC address is legitimate. |
ARP_SRC_MAC_FOUND_ATTACK
Message text |
An attack from MAC [STRING] was detected on interface [STRING] |
Variable fields |
$1: MAC address. $2: Interface name. |
Severity level |
6 |
Example |
ARP/6/ARP_SRC_MAC_FOUND_ATTACK: An attack from MAC 0000-5E14-0E00 was detected on interface Ethernet0/1/0. |
Explanation |
An attack was detected by source MAC-based ARP attack detection. The number of ARP packets that the device received from the same MAC address within 5 seconds exceeded the specified threshold. |
Verify that the host with the source MAC address is legitimate. |
ARP_TARGET_IP_INVALID
Message text |
Target IP [STRING] was not the IP of the receiving interface [STRING] |
Variable fields |
Severity level |
6 |
Example |
ARP/6/ARP_TARGET_IP_INVALID: Target IP 192.168.10.2 was not the IP of the receiving interface Ethernet0/1/0. |
Explanation |
The target IP address of a received ARP message was not the IP address of the receiving interface. |
Verify that the host that sends this ARP message is legitimate. |
DUPIFIP
Message text |
Duplicate address [STRING] on interface [STRING], sourced from [STRING] |
Variable fields |
$1: IP address. $2: Interface name. $3: MAC Address. |
Severity level |
6 |
Example |
ARP/6/DUPIFIP: Duplicate address 1.1.1.1 on interface Ethernet1/1/1, sourced from 0015-E944-A947 |
Explanation |
A duplicate address was detected by ARP. The sender IP in a received ARP packet was being used by the receiving interface. |
Modify the IP address configuration. |
DUPIP
Message text |
IP address [STRING] conflicts with global or imported IP address, sourced from [STRING] |
Variable fields |
$1: IP address. $2: MAC Address. |
Severity level |
6 |
Example |
ARP/6/DUPIP: IP address 30.1.1.1 conflicts with global or import IP address, sourced from 0000-0000-0001 |
Explanation |
The sender IP address of the received ARP packet conflicted with the global or imported IP address. |
DUPVRRPIP
Message text |
IP address [STRING] collision with VRRP virtual IP address on interface [STRING], sourced from [STRING] |
Variable fields |
$1: IP address. $2: Interface name. $3: MAC address. |
Severity level |
6 |
Example |
ARP/6/DUPVRRPIP: IP address 1.1.1.1 conflicts with VRRP virtual IP address on interface Ethernet1/1/1, sourced from 0015-E944-A947 |
Explanation |
The sender IP address of the received ARP packet conflicted with the VRRP virtual IP address. |
BFD messages
This section contains BFD messages.
BFD_CHANGE_FSM
Message text |
Sess[STRING], Sta: [STRING]->[STRING], Diag: [UINT32] |
Variable fields |
$1: Source address, destination address, interface, and message type of the BFD session. $2: Name of FSM before changing. $3: Name of FSM after changing. $4: Diagnostic code. |
Severity level |
5 |
Example |
BFD/5/BFD_CHANGE_FSM:Sess[20.0.4.2/20.0.4.1,LD/RD:533/532, Interface:Vlan204, SessType:Ctrl, LinkType:INET], Sta: INIT->UP, Diag: 0. |
Explanation |
The FSM of the BFD session has been changed. This informational message appears when a BFD session comes up or goes down. Unexpected session loss might indicate high error or packet loss rates in the network. |
Check for incorrect BFD configuration or network congestion. |
BFD_REACHED_UPPER_LIMIT
Message text |
The total number of BFD sessions [UINT] reached the upper limit. Please avoid creating a new session. |
Variable fields |
$1: Total number of BFD sessions. |
Severity level |
5 |
Example |
BFD/5/BFD_REACHED_UPPER_LIMIT: The total number of BFD sessions 100 reached upper limit. Please avoid creating a new session. |
Explanation |
The total number of BFD sessions reached the upper limit. |
Check the BFD session configuration. |
BGP messages
This section contains BGP messages.
BGP_EXCEED_ROUTE_LIMIT
Message text |
The number of routes from peer [STRING] in exceeded the limit [UINT32]. |
Variable fields |
$1: BGP peer IP address. $2: Maximum number of routes. |
Severity level |
4 |
Example |
BGP/4/BGP_EXCEEDED_ROUTE_LIMIT: The number of routes from peer 1.1.1.1 in exceeded the limit 100. |
Explanation |
The number of routes received from a peer exceeded the maximum number of routes that can be received from the peer. |
Check whether you need to increase the maximum number of routes. |
BGP_EXCEEDS_THRESHOLD
Message text |
Threshold value [UINT32] reached for prefixes received from peer [STRING]. |
Variable fields |
$1: Percentage of received routes to the maximum number of routes. $2: Peer IP address. |
Severity level |
5 |
Example |
BGP/5/BGP_RECHED_THRESHOLD: Threshold value 20 reached for prefixes received from peer 1.1.1.1. |
Explanation |
The number of received routes reached the threshold. |
Check whether you need to increase the threshold value or the maximum number of routes that can be received from the peer. |
BGP_MEM_ALERT
Message text |
BGP Process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm. |
Severity level |
5 |
Example |
BGP/5/BGP_MEM_ALERT: BGP Process receive system memory alert start event. |
Explanation |
BGP received a memory alarm. |
Check the system memory. |
BGP_STATE_CHANGED
Message text |
[STRING] state is changed from [STRING] to [STRING]. BGP. [STRING]: [STRING] State is changed from [STRING]to [STRING]. |
Variable fields |
$1: VPN instance name. $2: Peer IP address. $3: Name of FSM before a state change. $4: Name of FSM after a state change. |
Severity level |
5 |
Example |
BGP/5/BGP_STATE_CHANGED: BGP.vpn1:192.99.0.2 state is changed from ESTABLISHED to IDLE. |
Explanation |
The FSM of a BGP peer changed. This message is generated when a BGP peer comes up or goes down. |
If a peer goes down unexpectedly, check for network failure or packet loss. |
CFD messages
This section contains CFD messages.
CFD_CROSS_CCM
Message text |
MEP [UINT16] in SI [INT32] received a cross-connect CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
Variable fields |
$1: Service instance ID. $2: Local MEP ID. $3: Source MAC address. $4: Sequence number. $5: Remote MEP ID. $6: MD ID. If no MD ID is available, "without ID" is displayed. $7: MA ID. |
Severity level |
6 |
Example |
CFD/6/CFD_CROSS_CCM: MEP 13 in SI 10 received a cross-connect CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 78, RMEP is 12, MD ID is without ID, MA ID is 0. |
Explanation |
A MEP received a cross-connect CCM containing a different MA ID or MD ID. |
Check the configurations of MEPs at both ends. Make sure the MEPs have the same configurations, including MD, MA, and level. |
CFD_ERROR_CCM
Message text |
MEP [UINT16] in SI [INT32] received an error CCM. It’s SrcMAC is [MAC], SeqNum is [INT32], RMEP is [UINT16], MD ID is [STRING], MA ID is [STRING]. |
Variable fields |
Severity level |
6 |
Example |
CFD/6/CFD_ERROR_CCM: MEP 2 in SI 7 received an error CCM. Its SrcMAC is 0011-2233-4401, SeqNum is 21, RMEP is 2, MD ID is 7, MA ID is 1. |
Explanation |
A MEP received an error CCM containing an unexpected MEP ID or lifetime. |
Check the CCM configuration. Make sure the CCM intervals are the same at both ends, and the remote MEP ID is included in the MEP list of the local end. |
CFD_LOST_CCM
Message text |
MEP [UINT16] in SI [INT32] failed to receive CCMs from RMEP [UINT16]. |
Variable fields |
$1: Local MEP ID. $2: Service instance ID. $3: Remote MEP ID. |
Severity level |
6 |
Example |
CFD/6/CFD_LOST_CCM: MEP 1 in SI 7 received CCMs from RMEP 2. |
Explanation |
A MEP failed to receive CCMs within 3.5 sending intervals because the link was faulty or the remote MEP did not send CCM within 3.5 sending intervals. |
1. Check the link status for a faulty state (for example, the down or unidirectional state), and then recover the link. 2. Check the configuration of the remote MEP. If the remote MEP is configured with the same service instance, make sure the CCM sending intervals are the same at both ends. 3. If the problem persists, contact H3C Support. |
CFD_RECEIVE_CCM
Message text |
MEP [UINT16] in SI [INT32] received CCMs from RMEP [UINT16] |
Variable fields |
Severity level |
6 |
Example |
CFD/6/CFD_RECEIVE_CCM: MEP 1 in SI 7 received CCMs from RMEP 2. |
Explanation |
A MEP received CCMs from a remote MEP. |
CFGMAN messages
This section contains configuration management messages.
CFGMAN_CFGCHANGED
Message text |
-EventIndex=[INT32]-CommandSource=[INT32]-ConfigSource=[INT32]-ConfigDestination=[INT32]; Configuration is changed. |
Variable fields |
$1: Event index in the range of 1 to 2147483647. $2: Specify the source command which brought the log, in the range of 1 to 3. $3: Source of the configuration data event, in the range of 1 to 7. $4: Destination for the configuration data event, in the range of 1 to 7. |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[6]-Comman dSource=[2]-ConfigSource=[4]-ConfigDestination=[2]; Configuration is changed. |
Explanation |
The device recorded the logtale index, cmdsource, configsource, and configdestination for the running configuration that changed in the past 10 minutes. |
CFGMAN_OPTCOMPLETION
Message text |
-OperateType=[INT32]-OperateTime=[INT32]-OperateState=[INT32]-OperateEndTime=[INT32]; Operation is completed. |
Variable fields |
$1: Operation type in the range of 1 to 6. $2: Operation time. $3: Operation state in the range of 1 to 20. $4: Operation end time. |
Severity level |
5 |
Example |
CFGMAN/5/CFGMAN_OPTCOMPLETION: -OperateType=[1]-OperateTime=[248]-OperateState=[2]-OperateEndTime=[959983]; Operation is completed. |
Explanation |
The device recorded the type, state, start time, and end time of an operation. |
DEV messages
This section contains device management messages.
BOARD_REBOOT
Message text |
Board is rebooting on Chassis [INT32] Slot [INT32]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. |
Severity level |
5 |
Example |
DEV/5/BOARD_REBOOT: Board is rebooting on Chassis 1 Slot 5. |
Explanation |
A card was manually or automatically rebooted. |
If an unexpected automatic reboot occurred, perform the following tasks: 1. Execute the display version command after the card starts up. 2. Check the Last reboot reason field for the reboot reason. 3. If an exception caused the reboot, contact H3C Support. |
BOARD_REMOVED
Message text |
Board is removed from Chassis [INT32] Slot [INT32], type is [STRING]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Card type. |
Severity level |
3 |
Example |
DEV/3/BOARD_REMOVED: Board is removed from Chassis 1 Slot 5, type is LSQ1FV48SA. |
Explanation |
An LPU or standby MPU was removed. |
If the LPU or MPU was not manually removed, perform the following tasks: 1. Verify that the card is securely seated. 2. Replace the card if the message persists. 3. If the problem persists, contact H3C Support. |
BOARD_STATE_FAULT
Message text |
Board state changes to FAULT on Chassis [INT32] Slot [INT32], type is [STRING]. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/BOARD_STATE_FAULT: Board state changes to FAULT on Chassis 1 Slot 5, type is LSQ1FV48SA. |
Explanation |
The card was starting up (initializing or loading software) or was not operating correctly. |
· If the card was newly installed, wait for the card to start up. The required startup time varies by card model and software version and is typically less than 10 minutes. · If the card was not newly installed, contact H3C Support. |
BOARD_STATE_NORMAL
Message text |
Board state changes to NORMAL on Chassis [INT32] Slot [INT32], type is [STRING]. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/BOARD_STATE_NORMAL: Board state changes to NORMAL on Chassis 1 Slot 5, type is LSQ1FV48SA. |
Explanation |
A newly installed LPU or standby MPU completed initialization. |
CFCARD_INSERTED
Message text |
Compact Flash Card is inserted in Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Flash slot ID. |
Severity level |
4 |
Example |
DEV/4/CFCARD_INSERTED: Compact Flash Card is inserted in Chassis 1 Slot 5 Compact Flash Slot 1. |
Explanation |
A CF card was installed. |
CFCARD_REMOVED
Message text |
Compact Flash Card is removed from Chassis [INT32] Slot [INT32] Compact Flash Slot [INT32]. |
Variable fields |
Severity level |
3 |
Example |
DEV/3/CFCARD_REMOVED: Compact Flash Card is removed from Chassis 1 Slot 5 Compact Flash Slot 1. |
Explanation |
A CF card was removed. |
If the CF card was not manually removed, perform the following tasks: 1. Verify that the card is securely seated. 2. Replace the card if the message persists. 3. If the problem persists, contact H3C Support. |
CHASSIS_REBOOT
Message text |
Chassis [INT32] is rebooting now. |
Variable fields |
$1: Chassis ID. |
Severity level |
5 |
Example |
DEV/5/CHASSIS_REBOOT: Chassis 1 is rebooting now. |
Explanation |
The chassis was manually or automatically rebooted. |
If an unexpected automatic reboot occurs, perform the following tasks: 1. Execute the display version command after the chassis starts up. 2. Check the Last reboot reason field for the reboot reason. 3. If an exception caused the reboot, contact H3C Support. |
DEV_CLOCK_CHANGE
Message text |
-User=[STRING]-IPAddr=[IPADDR]; System clock changed from [STRING] to [STRING]. |
Variable fields |
$1: Username of the login user. $2: IP address of the login user. $3: Old time. $4: New time. |
Severity level |
5 |
Example |
DEV/5/DEV_CLOCK_CHANGE: -User=[STRING]-IPAddr=[IPADDR]; System clock changed from 15:49:52 11/02/2011 to 15:50:00 11/02/2011. |
Explanation |
The system time changed. |
FAN_ABSENT
Message text |
Chassis [INT32] Fan [INT32] is absent. |
Variable fields |
$1: Chassis ID. $2: Fan tray ID. |
Severity level |
3 |
Example |
DEV/3/FAN_ABSENT: Chassis 1 Fan 2 is absent. |
Explanation |
A fan tray was not in place. |
1. Check the fan tray slot: · If the fan tray slot is empty, install a fan tray. · If a fan tray is present, verify that the fan tray is securely seated. 2. Replace the fan tray if the message persists. 3. If the problem persists, contact H3C Support. |
FAN_ABSENT
Message text |
Variable fields |
$1: Fan tray ID. |
Severity level |
3 |
Example |
DEV/3/FAN_ABSENT: Fan 2 is absent. |
Explanation |
FAN_DIRECTION_NOT_PREFERRED
Message text |
Fan [INT32] airflow direction is not preferred on slot [INT32], please check it. |
Variable fields |
$1: Fan tray ID. $2: Slot ID. |
Severity level |
1 |
Example |
DEV/1/FAN_DIRECTION_NOT_PREFERRED: Fan 1 airflow direction is not preferred on slot 3, please check it. |
Explanation |
The airflow direction of the fan tray is different from the airflow direction setting. |
1. Verify that the airflow direction setting is correct. 2. Verify that the fan tray model provides the same airflow direction as the configured setting. 3. If the problem persists, contact H3C Support. |
FAN_FAILED
Message text |
Chassis [INT32] Fan [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/FAN_FAILED: Chassis 1 Fan 2 failed. |
Explanation |
The fan tray stopped because of an exception. |
Replace the fan tray. |
FAN_FAILED
Message text |
Variable fields |
$1: Fan tray ID. |
Severity level |
2 |
Example |
DEV/2/FAN_FAILED: Fan 2 failed. |
Explanation |
FAN_RECOVERED
Message text |
Chassis [INT32] Fan [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/FAN_RECOVERED: Chassis 1 Fan 2 recovered. |
Explanation |
The fan tray started to operate correctly after it was installed. |
FAN_RECOVERED
Message text |
Variable fields |
$1: Fan tray ID. |
Severity level |
5 |
Example |
DEV/5/FAN_RECOVERED: Fan 2 recovered. |
Explanation |
POWER_ABSENT
Message text |
Power [INT32] is absent. |
Variable fields |
$1: Power supply ID. |
Severity level |
3 |
Example |
DEV/3/POWER_ABSENT: Power 1 is absent. |
Explanation |
A power supply was removed. |
1. Check the power supply slot. · If the power supply slot is empty, install a power supply. · If a power supply is present, verify that the power supply is securely seated. 2. If the problem persists, replace the power supply. 3. If the problem persists, contact H3C Support. |
POWER_ABSENT
Message text |
Chassis [INT32] Power [INT32] is absent. |
Variable fields |
$1: Chassis ID. $2: Power supply ID. |
Severity level |
3 |
Example |
DEV/3/POWER_ABSENT: Chassis 1 Power 1 is absent. |
Explanation |
POWER_FAILED
Message text |
Power [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_FAILED: Power 1 failed. |
Explanation |
A power supply failed. |
Replace the power supply. |
POWER_FAILED
Message text |
Chassis [INT32] Power [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_FAILED: Chassis 1 Power 1 failed. |
Explanation |
POWER_MONITOR_ABSENT
Message text |
Power monitor unit [INT32] is absent. |
Variable fields |
$1: Power monitoring module ID. |
Severity level |
3 |
Example |
DEV/3/POWER_MONITOR_ABSENT: Power monitor unit 1 is absent. |
Explanation |
A power monitoring module was removed. |
1. Check the power monitoring module slot. · If the power monitoring module slot is empty, install a power monitoring module. · If a power monitoring module is present, verify that the power monitoring module is securely seated. 2. If the problem persists, replace the power monitoring module. 3. If the problem persists, contact H3C Support. |
Message text |
Chassis [INT32] Power monitor unit [INT32] is absent. |
Variable fields |
$1: Chassis ID. $2: Power monitoring module ID. |
Severity level |
3 |
Example |
DEV/3/POWER_MONITOR_ABSENT: Chassis 2 Power monitor unit 1 is absent. |
Explanation |
POWER_MONITOR_FAILED
Message text |
Power monitor unit [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_MONITOR_FAILED: Power monitor unit 1 failed. |
Explanation |
A power monitoring module failed. |
Replace the power monitoring module. |
Message text |
Chassis [INT32] Power monitor unit [INT32] failed. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/POWER_MONITOR_FAILED: Chassis 2 Power monitor unit 1 failed. |
Explanation |
POWER_MONITOR_RECOVERED
Message text |
Power monitor unit [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_MONITOR_RECOVERED: Power monitor unit 1 recovered. |
Explanation |
The power monitoring module started to operate correctly after it was installed. |
Message text |
Chassis [INT32] Power monitor unit [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_MONITOR_RECOVERED: Chassis 2 Power monitor unit 1 recovered. |
Explanation |
POWER_RECOVERED
Message text |
Power [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_RECOVERED: Power 1 recovered. |
Explanation |
The power supply started to operate correctly after it was installed. |
POWER_RECOVERED
Message text |
Chassis [INT32] Power [INT32] recovered. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/POWER_RECOVERED: Chassis 1 Power 1 recovered. |
Explanation |
RPS_ABSENT
Message text |
RPS [INT32] is absent. |
Variable fields |
$1: RPS ID. |
Severity level |
3 |
Example |
DEV/3/RPS_ABSENT: RPS 1 is absent. |
Explanation |
An RPS was removed. |
1. Check the RPS slot. · If the RPS slot is empty, install a RPS. · If an RPS is present, verify that the RPS is securely seated. 2. If the problem persists, replace the RPS. 3. If the problem persists, contact H3C Support. |
RPS_ABSENT
Message text |
Chassis [INT32] RPS [INT32] is absent. |
Variable fields |
$1: Chassis ID. $2: RPS ID. |
Severity level |
3 |
Example |
DEV/3/RPS_ABSENT: Chassis 1 RPS 1 is absent. |
Explanation |
RPS_NORMAL
Message text |
RPS [INT32] is normal. |
Variable fields |
$1: RPS ID. |
Severity level |
5 |
Example |
DEV/5/RPS_NORMAL: RPS 1 is normal. |
Explanation |
The RPS started to operate correctly after it was installed. |
RPS_NORMAL
Message text |
Chassis [INT32] RPS [INT32] is normal. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/RPS_NORMAL: Chassis 1 RPS 1 is normal. |
Explanation |
SUBCARD_FAULT
Message text |
SubCard state changes to FAULT on Chassis [INT32] slot [INT32] SubSlot [INT32], type is [STRING]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Subslot ID. $4: Subcard type. |
Severity level |
2 |
Example |
DEV/2/SUBCARD_FAULT: SubCard state changes to FAULT on Chassis 1 slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
Explanation |
The subcard failed, or its status changed to Fault after it was rebooted. |
Track the status of the subcard. · If the status of the subcard changes to Normal later, no action is required. · If the status is always Fault, replace the subcard. |
SUBCARD_INSERTED
Message text |
SubCard is inserted in Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/SUBCARD_INSERTED: SubCard is inserted in Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
Explanation |
A subcard was installed. |
SUBCARD_REBOOT
Message text |
SubCard is rebooting on Chassis [INT32] Slot [INT32] SubSlot [INT32]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Subslot ID. |
Severity level |
5 |
Example |
DEV/5/SUBCARD_REBOOT: SubCard is rebooting on Chassis 1 Slot 5 SubSlot 1. |
Explanation |
The subcard was manually or automatically rebooted. |
· If the subcard operates correct after it starts up, no action is required. · If you want to know the reboot reason or the subcard keeps rebooting, contact H3C Support. |
SUBCARD_REMOVED
Message text |
SubCard is removed from Chassis [INT32] Slot [INT32] SubSlot [INT32], type is [STRING]. |
Variable fields |
Severity level |
3 |
Example |
DEV/3/SUBCARD_REMOVED: SubCard is removed from Chassis 1 Slot 5 SubSlot 1, type is MIM-1ATM-OC3SML. |
Explanation |
A subcard was removed. |
If the subcard was not manually removed, perform the following tasks: 1. Verify that the subcard is securely seated. 2. Replace the subcard if the message persists. 3. If the problem persists, contact H3C Support. |
SYSTEM_REBOOT
Message text |
System is rebooting now. |
Variable fields |
N/A |
Severity level |
5 |
Example |
DEV/5/SYSTEM_REBOOT: System is rebooting now. |
Explanation |
The system was manually or automatically rebooted. |
If an unexpected automatic reboot occurred, perform the following tasks: 1. Execute the display version command after the system starts up. 2. Check the Last reboot reason field for the reboot reason. 3. If an exception caused the reboot, contact H3C Support. |
TEMPERATURE_ALARM
Message text |
Temperature is greater than alarm upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. $3: Sensor type. $4: Sensor ID. |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_ALARM: Temperature is greater than alarm upper limit on Chassis 1 slot 5 sensor inflow 1. |
Explanation |
A sensor's temperature exceeded the high-temperature alarming threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
1. Verify that the ambient temperature is normal and the ventilation system is operating correctly. 2. Use the display fan command to verify that the fan trays are in position and operating correctly. If a fan tray is missing, install the fan tray. If a fan tray does not operate correctly, replace it. |
TEMPERATURE_LOW
Message text |
Temperature is less than lower limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_LOW: Temperature is less than lower limit on Chassis 1 slot 5 sensor inflow 1. |
Explanation |
A sensor's temperature fell below the low-temperature threshold. |
Adjust the ambient temperature higher. |
TEMPERATURE_NORMAL
Message text |
Temperature changes to normal on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
5 |
Example |
DEV/5/TEMPERATURE_NORMAL: Temperature changes to normal on Chassis 1 slot 5 sensor inflow 1. |
Explanation |
A sensor's temperature is normal (between the low-temperature threshold and the high-temperature warning threshold). |
TEMPERATURE_SHUTDOWN
Message text |
Temperature is greater than shutdown upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32] the slot will be powered off automatically. |
Variable fields |
Severity level |
2 |
Example |
DEV/2/TEMPERATURE_SHUTDOWN: Temperature is greater than shutdown upper limit on Chassis 1 slot 5 sensor inflow 1 the slot will be powered off automatically. |
Explanation |
A sensor's temperature exceeded the high-temperature shutdown threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
TEMPERATURE_WARNING
Message text |
Temperature is greater than warning upper limit on Chassis [INT32] slot [INT32] sensor [STRING] [INT32]. |
Variable fields |
Severity level |
4 |
Example |
DEV/4/TEMPERATURE_WARNING: Temperature is greater than warning upper limit on Chassis 1 slot 2 sensor inflow 1. |
Explanation |
A sensor's temperature exceeded the high-temperature warning threshold. The ambient temperature was too high or the fan tray was not operating correctly. |
DIAG messages
This section contains diagnostic messages.
MEM_BELOW_THRESHOLD
Message text |
Memory usage has dropped below [STRING] threshold. |
Variable fields |
$1: Memory usage threshold name: minor, severe, or critical. |
Severity level |
1 |
Example |
DIAG/1/MEM_BELOW_THRESHOLD: Memory usage has dropped below critical threshold. |
Explanation |
A memory alarm was removed. |
MEM_EXCEED_THRESHOLD
Message text |
Memory [STRING] threshold has been exceeded. |
Variable fields |
Severity level |
1 |
Example |
DIAG/1/MEM_EXCEED_THRESHOLD: Memory minor threshold has been exceeded. |
Explanation |
The amount of used memory space exceeded a threshold. |
All service modules are notified of the alarm and perform auto repair, such as releasing memory and stopping requesting memory. Users can perform the following operations: 1. Verify that the device is not under attack by checking the ARP table and routing table. 2. Check and optimize the networking to reduce the number of routes. 3. Replace the device with a device that has a better performance. |
DLDP messages
This section contains DLDP messages.
DLDP_AUTHENTICATION_FAILED
Message text |
The DLDP packet failed the authentication because of unmatched [STRING] field. |
Variable fields |
$1: Authentication field. · AUTHENTICATION PASSWORD—Authentication password mismatch. · AUTHENTICATION TYPE—Authentication type mismatch. · INTERVAL—Advertisement interval mismatch. |
Severity level |
5 |
Example |
DLDP/5/DLDP_AUTHENTICATION_FAILED: The DLDP packet failed the authentication because of unmatched INTERVAL field. |
Explanation |
The packet authentication failed. Possible reasons: · Unmatched authentication type. · Unmatched authentication password. · Unmatched advertisement interval. |
Verify that the two ends use the same DLDP authentication type, authentication password, and advertisement interval. |
DLDP_LINK_BIDIRECTIONAL
Message text |
DLDP detected a bidirectional link on interface [STRING]. |
Variable fields |
$1: Interface name. |
Severity level |
6 |
Example |
DLDP/6/DLDP_LINK_BIDIRECTIONAL: DLDP detected a bidirectional link on interface Ethernet1/1. |
Explanation |
DLDP detected a bidirectional link on an interface. |
DLDP_LINK_UNIDIRECTIONAL
Message text |
DLDP detected a unidirectional link on interface [STRING]. [STRING]. |
Variable fields |
$1: Interface name. $2: Action according to the port shutdown mode: · DLDP automatically blocked the interface. · Please manually shut down the interface. |
Severity level |
3 |
Example |
DLDP/3/DLDP_LINK_UNIDIRECTIONAL: DLDP detected a unidirectional link on interface Ethernet1/1. DLDP automatically blocked the interface. |
Explanation |
DLDP detected a unidirectional link on an interface. |
Check for connectivity issues, including incorrect cable connection and cable falloff. |
DLDP_NEIGHBOR_AGED
Message text |
A neighbor on interface [STRING] was deleted because the neighbor was aged. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
$1: Interface name. $2: MAC address. $3: Port index. |
Severity level |
5 |
Example |
DLDP/5/DLDP_NEIGHBOR_AGED: A neighbor on interface Ethernet1/1 was deleted because the neighbor was aged. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface deleted an aged neighbor. |
DLDP_NEIGHBOR_CONFIRMED
Message text |
A neighbor was confirmed on interface [STRING]. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
Severity level |
6 |
Example |
DLDP/6/DLDP_NEIGHBOR_CONFIRMED: A neighbor was confirmed on interface Ethernet1/1. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface detected a confirmed neighbor. |
DLDP_NEIGHBOR_DELETED
Message text |
A neighbor on interface [STRING] was deleted because a [STRING] packet arrived. The neighbor's system MAC is [MAC], and the port index is [UINT16]. |
Variable fields |
$1: Interface name. $2: Packet type, DISABLE or LINKDOWN. $3: MAC address. $4: Port index. |
Severity level |
5 |
Example |
DLDP/5/DLDP_NEIGHBOR_DELETED: A neighbor on interface Ethernet1/1 was deleted because a DISABLE packet arrived. The neighbor's system MAC is 000f-e269-5f21, and the port index is 1. |
Explanation |
The interface deleted a confirmed neighbor because it received a DISABLE or LINKDOWN packet. |
ETHOAM messages
This section contains Ethernet OAM messages.
ETHOAM_CONNECTION_FAIL_DOWN
Message text |
The link is down on port [string] because a remote failure occurred on peer port. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_OAM_LINK_DOWN: The link is down on port Ethernet1/0/1 because a remote failure occurred on peer port. |
Explanation |
The link went down because a remote failure occurred on the peer port. |
Check the link status or the OAM status on the peer. |
ETHOAM_CONNECTION_FAIL_TIMEOUT
Message text |
Port [string] removed the OAM connection because it received no Information OAMPDU before the timer times out. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ETHOAM_CONNECTION_FAIL_TIMEOUT: Port Ethernet1/0/1 removed the OAM connection because it received no Information OAMPDU before the timer times out. |
Explanation |
The port removed the OAM connection because it had not received Information OAMPDUs before the timer timed out. |
ETHOAM_CONNECTION_FAIL_UNSATISF
Message text |
Port [string] failed to establish an OAM connection because the peer doesn’t match the capacity of the local port. |
Variable fields |
$1: Port name. |
Severity level |
3 |
Example |
ETHOAM/3/ETHOAM_CONNECTION_FAIL_UNSATISF: Port Ethernet1/0/1 failed to establish an OAM connection because the peer doesn’t match the capacity of the local port. |
Explanation |
Failed to establish an OAM connection because the OAM protocol states do not match at the two ends. |
Check the protocol state field of OAM packets sent by both ends. |
ETHOAM_CONNECTION_SUCCEED
Message text |
An OAM connection is established on port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_CONNECTION_SUCCEED: An OAM connection is established on port Ethernet1/0/1. |
Explanation |
An OAM connection was established. |
ETHOAM_DISABLE
Message text |
Ethernet OAM is now disabled on port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_DISABLE: Ethernet OAM is now disabled on port Ethernet1/0/1. |
Explanation |
Ethernet OAM was disabled. |
ETHOAM_DISCOVERY_EXIT
Message text |
OAM port [string] quits OAM connection. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_DISCOVERY_EXIT: OAM port Ethernet1/0/1 quits OAM connection. |
Explanation |
The local port ended the OAM connection. |
ETHOAM_ENABLE
Message text |
Ethernet OAM is now enabled on port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_ENABLE: Ethernet OAM is now enabled on port Ethernet1/0/1. |
Explanation |
Ethernet OAM was enabled. |
ETHOAM_ENTER_LOOPBACK_CTRLLED
Message text |
The local OAM entity enters remote loopback as controlled DTE on OAM port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLED: The local OAM entity enters remote loopback as controlled DTE on OAM port Ethernet1/0/1. |
Explanation |
This event occurs when you enable OAM loopback on the peer end. |
ETHOAM_ENTER_LOOPBACK_CTRLLING
Message text |
The local OAM entity enters remote loopback as controlling DTE on OAM port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_ENTER_LOOPBACK_CTRLLING: The local OAM entity enters remote loopback as controlling DTE on OAM port Ethernet1/0/1. |
Explanation |
This event occurs when you enable OAM loopback on the port. |
ETHOAM_LOCAL_DYING_GASP
Message text |
A local Dying Gasp event has occurred on [string]. |
Variable fields |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_DYING_GASP: A local Dying Gasp event has occurred on Ethernet1/0/1. |
Explanation |
A local Dying Gasp event occurs when you reboot the local device or shut down the interface. |
Do not use the link until it recovers. |
ETHOAM_LOCAL_ERROR_FRAME
Message text |
An errored frame event occurred on local port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME: An errored frame event occurred on local port Ethernet1/0/1. |
Explanation |
An errored frame event occurred on the local port. |
Check the link. |
ETHOAM_LOCAL_ERROR_FRAME_PERIOD
Message text |
An errored frame period event occurred on local port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_PERIOD: An errored frame period event occurred on local port Ethernet1/0/1. |
Explanation |
An errored frame period event occurred on the local port. |
Check the link. |
ETHOAM_LOCAL_ERROR_FRAME_SECOND
Message text |
An errored frame seconds event occurred on local port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOCAL_ERROR_FRAME_SECOND: An errored frame seconds event occurred on local port Ethernet1/0/1. |
Explanation |
An errored frame seconds event occurred on the local port. |
Check the link. |
ETHOAM_LOCAL_LINK_FAULT
Message text |
A local Link Fault event occurred on [string]. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOCAL_LINK_FAULT: A local Link Fault event occurred on Ethernet1/0/1. |
Explanation |
This event occurs when the local link goes down. |
Re-connect the Rx end of the fiber on the local port. |
ETHOAM_LOOPBACK_EXIT
Message text |
OAM port [string] quits remote loopback. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_EXIT: OAM port Ethernet1/0/1 quits remote loopback. |
Explanation |
The OAM port ended remote loopback after remote loopback was disabled on the port and the OAM connection was torn down. |
ETHOAM_LOOPBACK_EXIT_ERROR_STATU
Message text |
OAM port [string] quits remote loopback due to incorrect multiplexer or parser status. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_LOOPBACK_EXIT_ERROR_STATU: OAM port Ethernet1/0/1 quits remote loopback due to incorrect multiplexer or parser status. |
Explanation |
OAM port Ethernet1/0/1 ended remote loopback due to incorrect multiplexer or parser status. |
Disable, and then re-enable Ethernet OAM on the OAM entity. |
ETHOAM_LOOPBACK_NO_RESOURCE
Message text |
OAM port [string] can’t enter remote loopback due to insufficient resources. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NO_RESOURCE: OAM port Ethernet1/0/1 can’t enter remote loopback due to insufficient resources. |
Explanation |
The OAM port cannot enter remote loopback due to insufficient resources when you execute the oam remote-loopback start command on the local or remote OAM entity. |
Recommended action |
Release the resources, and then execute the oam remote-loopback start command again. |
ETHOAM_LOOPBACK_NOT_SUPPORT
Message text |
OAM port [string] can’t enter remote loopback because the operation is not supported. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_LOOPBACK_NOT_SUPPORT: OAM port Ethernet1/0/1 can't enter remote loopback because the operation is not supported. |
Explanation |
The OAM port cannot enter remote loopback because the operation is not supported on the device. |
No action is required. |
ETHOAM_QUIT_LOOPBACK_CTRLLED
Message text |
The local OAM entity quits remote loopback as controlled DTE on OAM port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ ETHOAM_QUIT_LOOPBACK_CTRLLED: The local OAM entity quits remote loopback as controlled DTE on OAM port Ethernet1/0/1. |
Explanation |
The local OAM entity ended remote loopback as controlled DTE after you disabled OAM loopback on the peer end. |
ETHOAM_QUIT_LOOPBACK_CTRLLING
Message text |
The local OAM entity quits remote loopback as controlling DTE on OAM port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_QUIT_LOOPBACK_CONTROLLING: The local OAM entity quits remote loopback as controlling DTE on OAM port Ethernet1/0/1. |
Explanation |
The local OAM entity ended remote loopback as controlling DTE after you disabled OAM loopback on the port. |
ETHOAM_REMOTE_CRITICAL
Message text |
A remote Critical event occurred on [string]. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_CRITICAL: A remote Critical event occurred on Ethernet1/0/1. |
Explanation |
A remote critical event occurred. |
ETHOAM_REMOTE_DYING_GASP
Message text |
A remote Dying Gasp event occurred on [string]. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_DYING_GASP: A remote Dying Gasp event occurred on Ethernet1/0/1. |
Explanation |
This event occurs when you reboot the remote device and shut down the port. |
Do not use this link until it recovers. |
ETHOAM_REMOTE_ERROR_FRAME
Message text |
An errored frame event occurred on the peer port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME: An errored frame event occurred on the peer port Ethernet1/0/1. |
Explanation |
An errored frame event occurred on the peer. |
Check the link. |
ETHOAM_REMOTE_ERROR_FRAME_PERIOD
Message text |
An errored frame period event occurred on the peer port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_PERIOD: An errored frame period event occurred on the peer port Ethernet1/0/1. |
Explanation |
An errored frame period event occurred on the peer port. |
Check the link. |
ETHOAM_REMOTE_ERROR_FRAME_SECOND
Message text |
An errored frame seconds event occurred on the peer port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_FRAME_SECOND: An errored frame seconds event occurred on the peer port Ethernet1/0/1. |
Explanation |
An errored frame seconds event occurred on the peer. |
Check the link. |
ETHOAM_REMOTE_ERROR_SYMBOL
Message text |
An errored symbol event occurred on the peer port [string]. |
Variable fields |
$1: Port name. |
Severity level |
6 |
Example |
ETHOAM/6/ETHOAM_REMOTE_ERROR_SYMBOL: An errored symbol event occurred on the peer port Ethernet1/0/1. |
Explanation |
An errored symbol event occurred on the peer. |
Check the link. |
ETHOAM_REMOTE_EXIT
Message text |
OAM port [string] quits OAM connection because Ethernet OAM is disabled on the peer port. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_REMOTE_EXIT: OAM port Ethernet1/0/1 quits OAM connection because Ethernet OAM is disabled on the peer port. |
Explanation |
The local port ended the OAM connection because Ethernet OAM was disabled on the peer port. |
ETHOAM_REMOTE_FAILURE_RECOVER
Message text |
Peer port [string] recovered. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_REMOTE_FAILURE_RECOVER: Peer port Ethernet1/0/1 recovered. |
Explanation |
The Link fault was cleared from the peer port and the OAM connection was restored. |
ETHOAM_REMOTE_LINK_FAULT
Message text |
A remote Link Fault event occurred on [string]. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ETHOAM_REMOTE_LINK_FAULT: A remote Link Fault event occurred on Ethernet1/0/1. |
Explanation |
The remote link went down. |
Reconnect the Rx end of the fiber on the remote port. |
ETHOAM_NO_ENOUGH_RESOURCE
Message text |
OAM port [string] the configuration failed because of insufficient hardware resources. |
Variable fields |
$1: Port name. |
Severity level |
4 |
Example |
ETHOAM/4/ ETHOAM_NO_ENOUGH_RESOURCE: Ethernet1/0/1 the configuration failed because of insufficient hardware resources. |
Explanation |
The configuration failed on the OAM port because of insufficient hardware resources. |
Release the resources, and execute the command again. |
ETHOAM_NOT_CONNECTION_TIMEOUT
Message text |
Port [string] quits Ethernet OAM because it received no Information OAMPDU before the timer times out. |
Variable fields |
$1: Port name. |
Severity level |
5 |
Example |
ETHOAM/5/ ETHOAM_NOT_CONNECTION_TIMEOUT: Port Ethernet1/0/1 quits Ethernet OAM because it received no Information OAMPDU before the timer times out. |
Explanation |
The local port ended Ethernet OAM because it had not received Information OAMPDUs before the timer timed out. |
EVB messages
This section contains EVB messages.
EVB_AGG_FAILED
Message text |
Remove the port [STRING] from the aggregation group [STRING]. Otherwise, the EVB feature does not take effect. |
Variable fields |
$1: Port name. $2: Aggregation port name. |
Severity level |
6 |
Example |
EVB/6/EVB_AGG_FAILED: Remove the port GigabitEthernet5/0/5 from the aggregation group Bridge-Aggregation5. Otherwise, the EVB feature does not take effect. |
Explanation |
The EVB bridge failed to process a port in an aggregation group. |
Remove the port from the aggregation group. |
EVB_VSI_OFFLINE
Message text |
VSI [STRING] went offline. |
Variable fields |
$1: VSI name. |
Severity level |
6 |
Example |
EVB/6/EVB_VSI_OFFLINE: VSI Schannel-Aggregation1:2.0 went offline. |
Explanation |
The VSI interface was deleted. This event occurs in the following situations: · The EVB bridge receives a VDP packet from the EVB station. · The EVB bridge has not received an acknowledgement after a VDP packet times out. |
EVB_VSI_ONLINE
Message text |
VSI [STRING] came online, status is [STRING]. |
Variable fields |
$1: VSI name. $2: VSI status. |
Severity level |
6 |
Example |
EVB/6/EVB_VSI_ONLINE: VSI Schannel-Aggregation1:2.0 came online, status is association. |
Explanation |
The EVB bridge received a VDP packet and created a VSI successfully. |
EVB_WARNING_NO_LICENSE
Message text |
License of the [STRING] feature will be expired in [UINT32] days. Install a permanent license. |
Variable fields |
$1: Feature name. $2: Validity period of the license. |
Severity level |
6 |
Example |
EVB/6/EVB_WARNING_NO_LICENSE: License of the EVB feature will be expired in 15 days. Install a permanent license. |
Explanation |
The EVB license on an MPU is about to expire. |
Renew the license. |
EVIISIS messages
This section contains EVI IS-IS messages.
EVIISIS_NBR_CHG
Message text |
EVIISIS [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING]. |
Variable fields |
$1: EVI IS-IS process ID. $2: EVI IS-IS neighbor level. $3: Neighbor system ID. $4: Interface name. $5: Current adjacency state. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_NBR_CHG: EVIISIS 1, Level-1 adjacency 0011.2200.1501 (Evi-Link0), state change to: down. |
Explanation |
The EVI IS-IS adjacency state changed on an interface. |
If the adjacency with a neighbor changes to down or initializing on an interface, check for EVI IS-IS configuration errors and loss of network connectivity. |
EVIISIS_MEM_ALERT
Message text |
EVIISIS process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alert. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_MEM_ALERT: EVIISIS process receive system memory alert start event. |
Explanation |
EVI IS-IS received a memory alarm. |
EVIISIS_LICENSE
Message text |
The feature EVIISIS has [STRING] license. |
Variable fields |
$1: License state change event type. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_LICENSE: The feature EVIISIS has available license. |
Explanation |
This message is generated when EVI IS-IS license status changes. For example, an EVI IS-IS license is installed or becomes invalid. |
Install a valid EVI IS-IS license if the current EVI IS-IS license becomes invalid. |
EVIISIS_LICENSE_UNAVAILABLE
Message text |
No license is found for EVI IS-IS. |
Variable fields |
N/A |
Severity level |
3 |
Example |
EVIISIS /3/ EVIISIS_LICENSE_UNAVAILABLE: No license is found for EVI IS-IS. |
Explanation |
Install a license for EVI IS-IS. |
EVIISIS_LICENSE_EXPIRED
Message text |
EVI IS-IS is unavailable because its license has expired. |
Variable fields |
N/A |
Severity level |
3 |
Example |
EVIISIS/3/EVIISIS_LICENSE_EXPIRED: EVI IS-IS is unavailable because its license has expired. |
Explanation |
The EVI IS-IS license has expired. |
Install a valid license for EVI IS-IS. |
EVIISIS_LICENSE_EXPIRED_TIME
Message text |
EVI IS-IS will become unavailable in [ULONG] days. |
Variable fields |
$1:Available period of the feature. |
Severity level |
5 |
Example |
EVIISIS/5/EVIISIS_LICENSE_EXPIRED_TIME: EVI IS-IS will become unavailable in 2 days. |
Explanation |
EVI IS-IS will be disabled because the EVI IS-IS license has expired. You can use EVI IS-IS for 30 days after the license is expired. |
Install a new license. |
FCOE messages
This section contains FCoE messages.
FCOE_INTERFACE_NOTSUPPORT_FCOE
Message text |
Because the aggregate interface [STRING] has been bound to a VFC interface, assigning the interface [STRING] that does not support FCoE to the aggregate interface will cause incorrect processing. |
Variable fields |
$1: Aggregate interface name. $2: Ethernet interface name. |
Severity level |
4 |
Example |
FCOE/4/FCOE_INTERFACE_NOTSUPPORT_FCOE: Because the aggregate interface Bridge-Aggregation 1 has been bound to a VFC interface, assigning the interface Ten-GigabitEthernet 2/0/1 that does not support FCoE to the aggregate interface will cause incorrect processing. |
Explanation |
This message is generated when an interface that does not support FCoE is assigned to an aggregate interface that has been bound to a VFC interface. |
Assign an interface that supports FCoE to the aggregate interface, or remove the binding from the VFC interface. |
FCOE_LICENSE_ERROR
Message text |
No license is found for FCoE. |
Variable fields |
N/A |
Severity level |
3 |
Example |
FCOE/3/FCOE_LICENSE_ERROR: No license is found for FCoE. |
Explanation |
Install a license for FCoE. |
FCOE_LICENSE_EXPIRED_EXIT
Message text |
FCoE is unavailable because its license has expired. |
Variable fields |
N/A |
Severity level |
3 |
Example |
FCOE/3/FCOE_LICENSE_EXPIRED_EXIT: FCoE is unavailable because its license has expired. |
Explanation |
The FCoE license has expired. |
Install a valid license for FCoE. |
FCOE_LICENSE_EXPIRED_TIME
Message text |
FCoE will become unavailable in [ULONG] days. |
Variable fields |
Severity level |
4 |
Example |
FCOE/4/FCOE_LICENSE_EXPIRED_TIME: FCoE will become unavailable in 2 days. |
Explanation |
FCoE will be disabled because the FCoE license has expired. You can use FCoE for 30 days after the license is expired. |
FCLINK messages
This section contains FC link messages.
FCLINK_FDISC_REJECT_NORESOURCE
Message text |
VSAN [UINT16], Interface [STRING]: An FDISC was rejected because the hardware resource is not enough. |
Variable fields |
$1: VSAN ID. $2: Interface name. |
Severity level |
4 |
Example |
FCLINK/4/FCLINK_FDISC_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FDISC was rejected because the hardware resource is not enough. |
Explanation |
This event occurs if an FDISC packet is received when hardware resources are insufficient. |
Reduce the number of nodes. |
FCLINK_FLOGI_REJECT_NORESOURCE
Message text |
VSAN [UINT16], Interface [STRING]: An FLOGI was rejected because the hardware resource is not enough. |
Variable fields |
Severity level |
4 |
Example |
FCLINK/4/FCLINK_FLOGI_REJECT_NORESOURCE: VSAN 1, Interface FC2/0/1: An FLOGI was rejected because the hardware resource is not enough. |
Explanation |
This event occurs if an FLOGI packet is received when hardware resources are insufficient. |
FCZONE messages
This section contains FC zone messages.
FCZONE_HARDZONE_DISABLED
Message text |
VSAN [UINT16]: No enough hardware resource for zone rule, switched to soft zoning. |
Variable fields |
$1: VSAN ID. |
Severity level |
2 |
Example |
FCZONE/2/FCZONE_HARDZONE_DISABLED: VSAN 2: No enough hardware resource for zone rule, switched to soft zoning. |
Explanation |
This event occurs when hardware resources are insufficient. |
Activate a smaller zone set. |
FCZONE_HARDZONE_ENABLED
Message text |
VSAN [UINT16]: Hardware resource for zone rule is restored, switched to hard zoning. |
Variable fields |
$1: VSAN ID. |
Severity level |
1 |
Example |
FCZONE/1/FCZONE_HARDZONE_ENABLED: VSAN 2: Hardware resource for zone rule is restored, switched to hard zoning. |
Explanation |
Hard zoning in the VSAN was enabled because hardware resources were restored. |
FIPS messages
This section contains FIP snooping messages.
FCOE_FIPS_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for FIP Snooping rule. |
Variable fields |
N/A |
Severity level |
4 |
Example |
FIPS/4/FCOE_FIPS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for FIP Snooping rule. |
Explanation |
This message is generated if hardware resources are insufficient. |
FCOE_FIPS_HARD_RESOURCE_RESTORE
Message text |
Hardware resource for FIP Snooping rule is restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
FIPS/6/FCOE_FIPS_HARD_RESOURCE_RESTORE: Hardware resource for FIP Snooping is restored. |
Explanation |
This message is generated when hardware resources for FIP snooping rules are restored. |
FTP messages
This section contains FTP messages.
FTP_REACH_SESSION_LIMIT
Message text |
FTP client [IPADDR] failed to log in. Number of FTP sessions reached the limit. |
Variable fields |
$1: IP address of an FTP client. |
Severity level |
6 |
Example |
FTPD/6/FTPD_REACH_SESSION_LIMIT: FTP client 1.1.1.1 failed to log in. Number of FTP sessions reached the limit. |
Explanation |
Number of online FTP users already reached the limit. |
HA messages
This section contains HA messages.
HA_BATCHBACKUP_FINISHED
Message text |
Batch backup of standby board in [STRING] is finished. |
Variable fields |
$1: MPU location. |
Severity level |
5 |
Example |
HA/5/HA_BATCHBACKUP_FINISHED: Batch backup of standby board in chassis 0 slot 1 is finished. |
Explanation |
Batch backup from the active MPU to the standby MPU was finished. |
HA_BATCHBACKUP_STARTED
Message text |
Batch backup(s) of standby board(s) in [STRING] started. |
Variable fields |
$1: MPU location. |
Severity level |
5 |
Example |
HA/5/HA_BATCHBACKUP_STARTED: Batch backup(s) of standby board(s) in chassis 0 slot 1 started. |
Explanation |
Batch backup from the active MPU to the standby MPU started. |
HA_STANDBY_NOT_READY
Message text |
Standby board in [STRING] is not ready, reboot ... |
Variable fields |
$1: MPU location. |
Severity level |
4 |
Example |
HA/4/HA_STANDBY_NOT_READY: Standby board in chassis 0 slot 1 is not ready, reboot ... |
Explanation |
Both the active and standby MPUs were rebooted. This event occurs if you perform an active/standby switchover while the standby MPU is backing up the configuration in bulk. |
Do not perform an active/standby switchover before the standby MPU completes the batch backup. |
HA_STANDBY_TO_MASTER
Message text |
Standby board in [STRING] changes to master. |
Variable fields |
$1: MPU location. |
Severity level |
5 |
Example |
HA/5/HA_STANDBY_TO_MASTER: Standby board in chassis 0 slot 1 changes to master. |
Explanation |
The standby MPU changed to active. |
HTTPD messages
This section contains HTTP daemon messages.
HTTPD_CONNECT
Message text |
[STRING] client [STRING] connected to the server successfully. |
Variable fields |
$1: Connection type, HTTP or HTTPS. $2: Client IP address. |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_CONNECT: HTTP client 192.168.30.117 connected to the server successfully. |
Explanation |
The HTTP or HTTPS server accepted the request from a client. The HTTP or HTTPS connection was set up. |
HTTPD_CONNECT_TIMEOUT
Message text |
[STRING] client [STRING] connection idle timeout. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_CONNECT_TIMEOUT: HTTP client 192.168.30.117 connection to server idle timeout. |
Explanation |
An HTTP or HTTPS connection was disconnected because its idle timeout timer expired. |
HTTPD_DISCONNECT
Message text |
[STRING] client [STRING] disconnected from the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_DISCONNECT: HTTP client 192.168.30.117 disconnected from the server. |
Explanation |
An HTTP or HTTPS client was disconnected from the server. |
HTTPD_FAIL_FOR_ACL
Message text |
[STRING] client [STRING] failed the ACL check and could not connect to the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_FAIL_FOR_ACL: HTTP client 192.168.30.117 failed the ACL check and cannot connect to the server. |
Explanation |
An HTTP or HTTPS client was filtered by the ACL. |
HTTPD_FAIL_FOR_ACP
Message text |
[STRING] client [STRING] was denied by the certificate access control policy and could not connect to the server. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_FAIL_FOR_ACP: HTTP client 192.168.30.117 was denied by the certificate attribute access control policy and could not connect to the server. |
Explanation |
An HTTP or HTTPS client was denied by the certificate access control policy. |
HTTPD_REACH_CONNECT_LIMIT
Message text |
[STRING] client [STRING] failed to connect to the server, because the number of connections reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
HTTPD/6/HTTPD_REACH_CONNECT_LIMIT: HTTP client 192.168.30.117 failed to connect to the server, because the number of connections reached the upper limit. |
Explanation |
The number of connections reached the limit. |
IFNET messages
This section contains interface management messages.
IFNET_MAD
Message text |
Multi-active devices detected, please fix it. |
Variable fields |
N/A |
Severity level |
1 |
Example |
IFNET/1/IFNET_MAD: Multi-active devices detected, please fix it. |
Explanation |
MAD detected multiple identical active IRF fabrics. This message appears when an IRF fabric splits. |
Check the IRF connections for a link failure, and use the IRF configuration guide as a reference to merge the split IRF fabrics. |
INTERFACE_INSERTED
Message text |
Interface [STRING] is inserted. |
Variable fields |
Severity level |
6 |
Example |
IFNET/6/INTERFACE_INSERTED: Interface Ethernet0/1 is inserted. |
Explanation |
An interface was added. |
INTERFACE_REMOVED
Message text |
Interface [STRING] is removed. |
Variable fields |
Severity level |
6 |
Example |
IFNET/6/INTERFACE_REMOVED: Interface Ethernet0/1 is removed. |
Explanation |
An interface was removed. |
LINK_UPDOWN
Message text |
Line protocol on the interface [STRING] is [STRING]. |
Variable fields |
$1: Interface name. $2: State of link layer protocol. |
Severity level |
5 |
Example |
IFNET/5/LINK_UPDOWN: Line protocol on the interface Ethernet0/0 is down. |
Explanation |
The state of the link layer protocol changed on an interface. |
PHY_UPDOWN
Message text |
[STRING]: link status is [STRING]. |
Variable fields |
$1: Interface name. $2: Link state. |
Severity level |
3 |
Example |
IFNET/3/PHY_UPDOWN: Ethernet0/0: link status is down. |
Explanation |
The link state changed on an interface. |
PROTOCOL_UPDOWN
Message text |
Protocol [STRING] on the interface [STRING] is [STRING]. |
Variable fields |
$1: Protocol name. $2: Interface name. $3: Protocol state. |
Severity level |
5 |
Example |
IFNET/5/PROTOCOL_UPDOWN: Protocol IPX on the interface Ethernet6/4/1 is up. |
Explanation |
The state of a protocol changed on an interface. |
IKE messages
This section contains IKE messages.
IKE_P1_SA_ESTABLISH_FAIL
Message text |
Failed to establish phase 1 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: no matching proposal | invalid ID information | unavailable certificate | unsupported DOI | unsupported situation | invalid proposal syntax | invalid SPI | invalid protocol ID | invalid certificate | authentication failure | invalid message header | invalid transform ID | malformed payload | retransmission timeout | incorrect configuration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P1_SA_ESTABLISH_FAIL: Failed to establish phase 1 SA for the reason of no matching proposal. The SA’s source address is 1.1.1.1 and its destination address is 2.2.2.2. |
Explanation |
An IKE SA was not established because of the displayed reason. |
Check the IKE configuration on the local and remote devices. |
IKE_P2_SA_ESTABLISH_FAIL
Message text |
Failed to establish phase 2 SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: invalid key information | invalid ID information | unavailable proposal | unsupported DOI | unsupported situation | invalid proposal syntax | invalid SPI | invalid protocol ID | invalid hash information | invalid message header | malformed payload | retransmission timeout | incorrect configuration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P2_SA_ESTABLISH_FAIL: Failed to establish phase 2 SA for the reason of invalid key information. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA was not established because of the displayed reason. |
Check the IKE and IPsec configurations on the local and remote devices. |
IKE_P2_SA_TERMINATE
Message text |
The IKE phase 2 SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason that the SA is deleted, which is SA expiration. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IKE/6/IKE_P2_SA_TERMINATE: The IKE phase 2 SA was deleted for the reason of SA expiration. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA was deleted because it expired. |
IPSEC messages
This section contains IPsec messages.
IPSEC_PACKET_DISCARDED
Message text |
IPsec packet discarded, Src IP:[STRING], Dst IP:[STRING], SPI:[UINT32], SN:[UINT32], Cause:[STRING]. |
Variable fields |
$1: Source IP address. $2: Destination IP address. $3: Security parameter index (SPI). $4: Sequence number of the packet. $5: Reason for dropping this packet: · Anti-replay checking failed. · AH authentication failed. · ESP authentication failed. · Invalid SA. · ESP decryption failed. · Source address of packet does not match the SA. · No ACL rule matched. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_PACKET_DISCARDED: IPsec packet discarded, Src IP:1.1.1.2, Dest IP:1.1.1.4, SPI:1002, SN:0, Cause:ah authentication failed |
Explanation |
An IPsec packet was dropped. Possible reasons include anti-replay checking failed, AH/ESP authentication failed, invalid SA, ESP decryption failed, source address of packet did not match the SA, and no ACL rule matched. |
IPSEC_SA_ESTABLISH
Message text |
Established IPsec SA. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
Variable fields |
$1: Source address. $2: Destination address. $3: Security protocol. $4: SPI. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_ESTABLISH: Established IPsec SA. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is AH, and SPI is 2435. |
Explanation |
An IPsec SA was established. |
IPSEC_SA_ESTABLISH_FAIL
Message text |
Failed to establish IPsec SA for the reason of [STRING]. The SA’s source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Reason for the IPsec SA establishment failure: · Tunnel establishment failure. · Incomplete configuration. · Unavailable transform set. $2: Source address. $3: Destination address. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_ESTABLISH_FAIL: Failed to establish IPsec SA for the reason of creating tunnel failure. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA was not established. Possible reasons include tunnel establishment failure, incomplete configuration, and unavailable transform set. |
Verify the IPsec configuration on the local and remote devices. |
IPSEC_SA_INITINATION
Message text |
Began to establish IPsec SA. The SA’s source address is [STRING], and its destination address is [STRING]. |
Variable fields |
$1: Source address. $2: Destination address. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_INITINATION: Began to establish IPsec SA. The SA’s source address is 1.1.1.1, and its destination address is 2.2.2.2. |
Explanation |
An IPsec SA was being established. |
IPSEC_SA_TERMINATE
Message text |
The IPsec SA was deleted for the reason of [STRING]. The SA’s source address is [STRING], destination address is [STRING], protocol is [STRING], and SPI is [UINT32]. |
Variable fields |
$1: Reason for the IPsec SA removal: · SA idle timeout. · reset command executed. $2: Source address. $3: Destination address. $4: Security protocol. $5: SPI. |
Severity level |
6 |
Example |
IPSEC/6/IPSEC_SA_TERMINATE: The IPsec SA was deleted for the reason of SA idle timeout. The SA’s source address is 1.1.1.1, destination address is 2.2.2.2, protocol is ESP, and SPI is 34563. |
Explanation |
An IPsec SA was deleted. Possible reasons include SA idle timeout and using the reset command. |
IRDP messages
This section contains IRDP messages.
IRDP_EXCEED_ADVADDR_LIMIT
Message text |
The number of advertisement addresses on interface [STRING] exceeded the limit 255. |
Variable fields |
Severity level |
6 |
Example |
IRDP/6/IRDP_EXCEED_ADVADDR_LIMIT: The number of advertisement addresses on interface Ethernet1/1/0/2 exceeded the limit 255. |
Explanation |
The number of addresses to be advertised on an interface exceeded the upper limit. |
Remove unused addresses on the interface. |
ISIS messages
This section contains IS-IS messages.
ISIS_MEM_ALERT
Message text |
ISIS Process receive system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
ISIS/5/ISIS_MEM_ALERT: ISIS Process receive system memory alert start event. |
Explanation |
ISIS_NBR_CHG
Message text |
IS-IS [UINT32], [STRING] adjacency %s (%s), state change to: %s. |
Variable fields |
$1: IS-IS process ID. $2: Neighbor level. $2: Neighbor ID. $3: Interface name. $4: Current adjacency state. |
Severity level |
5 |
Example |
ISIS/5/ISIS_NBR_CHG: IS-IS 1, Level-1 adjacency 0000.0000.8888 (Eth1/4/1/3), state change to:DOWN. |
Explanation |
The IS-IS adjacency state changed on an interface. |
When the adjacency with a neighbor changes to down on an interface, check for IS-IS configuration errors and loss of network connectivity. |
L2VPN messages
This section contains L2VPN messages.
L2VPN_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for L2VPN. |
Variable fields |
N/A |
Severity level |
4 |
Example |
L2VPN/4/L2VPN_HARD_RESOURCE_NOENOUGH: No enough hardware resource for L2VPN. |
Explanation |
Hardware resources for L2VPN were insufficient. |
Check whether unnecessary VSIs, PWs, or ACs had been generated. If yes, delete them. |
L2VPN_HARD_RESOURCE_RESTORE
Message text |
Hardware resource for L2VPN is restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
L2VPN/6/L2VPN_HARD_RESOURCE_RESTORE: Hardware resource for L2VPN is restored. |
Explanation |
Hardware resources for L2VPN restored. |
LAGG messages
This section contains link aggregation messages.
LAGG_ACTIVE
Message text |
Member port [STRING] of aggregation group [STRING] became active. |
Variable fields |
$1: Port name. $2: Link aggregation group type and ID. |
Severity level |
6 |
Example |
LAGG/6/LAGG_ACTIVE: Member port FGE1/0/50 of aggregation group BAGG1 became active. |
Explanation |
A member port in an aggregation group changed to the Selected state. |
LAGG_INACTIVE_AICFG
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of the port is different from that of the aggregation group. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_AICFG: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of the port is different from that of the aggregation group. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the member port and the aggregate interface had different attribute configurations. |
Modify the attribute configurations of the member port to be consistent with the aggregate interface. |
LAGG_INACTIVE_CONFIGURATION
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration on the port is improper. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_CONFIGURATION: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration on the port is improper. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the member port and the aggregate interface had different aggregation configuration. |
LAGG_INACTIVE_DUPLEX
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the duplex mode configuration on the port is improper. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_DUPLEX: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the duplex mode configuration on the port is improper. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the duplex mode was different between the member port and the Selected ports. |
Change the duplex mode of the member port to be the same as the Selected ports. |
LAGG_INACTIVE_HARDWAREVALUE
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the hardware restriction on the port is improper. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_HARDWAREVALUE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the hardware restriction on the port is improper. |
Explanation |
A member port in an aggregation group changed to the Unselected state because of the port's hardware restriction. |
LAGG_INACTIVE_LOWER_LIMIT
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports is below the lower limit. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_LOWER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports is below the lower limit. |
Explanation |
A member port in an aggregation group was placed in Unselected state because the required minimum number of Selected ports was not reached. |
Make sure the minimum number of Selected ports is met. |
LAGG_INACTIVE_PARTNER
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the aggregation configuration of its partner is improper. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PARTNER: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the aggregation configuration of its partner is improper. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the port's partner changed to the Unselected state. |
LAGG_INACTIVE_PHYSTATE
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the physical state of the port is down. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_PHYSTATE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the physical state of the port is down. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the port went down. |
Bring up the member port. |
LAGG_INACTIVE_RESOURCE_INSUFICIE
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because all aggregate resources are occupied. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_RESOURCE_INSUFICIE: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because all aggregate resources are occupied. |
Explanation |
A member port in an aggregation group changed to the Unselected state because all aggregation resources were used. |
LAGG_INACTIVE_SPEED
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the speed configuration on the port is improper. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_SPEED: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the speed configuration on the port is improper. |
Explanation |
A member port in an aggregation group changed to the Unselected state because the speed was different between the member port and the Selected ports. |
Change the speed of the member port to be the same as the Selected ports. |
LAGG_INACTIVE_UPPER_LIMIT
Message text |
Member port [STRING] of aggregation group [STRING] became inactive, because the number of active ports has reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
LAGG/6/LAGG_INACTIVE_UPPER_LIMIT: Member port FGE1/0/50 of aggregation group BAGG1 became inactive, because the number of active ports has reached the upper limit. |
Explanation |
The number of Selected ports reached the upper limit in a dynamic aggregation group. A member port in the aggregation group changed to the Unselected state because a more eligible port joined the aggregation group. |
LDP messages
This section contains LDP messages.
LDP_SESSION_CHG
Message text |
Session ([STRING], [STRING]) is [STRING]. |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session, up or down. When the state is down, the reason why the session becomes down is bracketed. Reasons include: · interface not operational. · MPLS disabled on interface. · LDP disabled on interface. · LDP auto-configure disabled on interface. · VPN instance changed on interface. · LDP instance deleted. · targeted peer deleted. · L2VPN disabled targeted peer. · TE tunnel disabled targeted peer. · session protection disabled targeted peer. · process deactivated. · failed to receive the initialization message. · graceful restart reconnect timer expired. · failed to recover adjacency by NSR. · failed to upgrade session by NSR. · closed the GR session. · keepalive hold timer expired. · adjacency hold timer expired. · session reset manually. · TCP connection down. · received a fatal notification message. · internal error. · memory in critical state. · transport address changed on interface. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, public instance) is up. LDP/5/LDP_SESSION_CHG: Session (22.22.22.2:0, VPN instance: vpn1) is down (hello hold timer expired). |
Explanation |
The session state changed. |
1. When the session state comes up, no action is required. 2. When the session state goes down, check the interface state, link state, and other configurations depending on the reason displayed. |
LDP_SESSION_GR
Message text |
Session ([STRING], [STRING]): ([STRING]). |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session graceful restart: · Start reconnection. · Reconnection failed. · Start recovery. · Recovery completed. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_GR: Session (22.22.22.2:0, VPN instance: vpn1): Start reconnection. |
Explanation |
When a GR-capable LDP session went down, LDP GR started. This message is generated during the GR of the LDP session, indicating the current GR state. |
1. Check for the reason of session graceful restart, which can be obtained from the LDP_SESSION_CHG log message. 2. When the graceful restart state Reconnection failed is displayed, verify the interface state, link state, and other configurations according to the reason for the session graceful restart. No action is required for other graceful restart states. |
LDP_SESSION_SP
Message text |
Variable fields |
$1: Peer's LDP ID. Value 0.0.0.0:0 indicates that the peer's LDP ID cannot be obtained. $2: VPN instance's name. Value public instance indicates that the session belongs to the public network. $3: State of the session protection: · Hold up the session. · Session recovered successfully. · Session recovery failed. |
Severity level |
5 |
Example |
LDP/5/LDP_SESSION_SP: Session (22.22.22.2:0, VPN instance: vpn1): Hold up the session. |
Explanation |
When the last hello adjacency of the session was removed, session protection started. This message is generated during the session protection process, indicating the current session protection state. |
Verify the interface state and link state. |
LLDP messages
This section contains LLDP messages.
LLDP_CREATE_NEIGHBOR
Message text |
[STRING] agent new neighbor created on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
$1: Agent type. $2: Port name. $3: Port ifIndex. $4: Neighbor's chassis ID. $5: Neighbor's port ID. |
Severity level |
6 |
Example |
LLDP/6/LLDP_CREATE_NEIGHBOR: Nearest bridge agent new neighbor created on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
Explanation |
The port received an LLDP message from a new neighbor. |
LLDP_DELETE_NEIGHBOR
Message text |
[STRING] agent neighbor deleted on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
Severity level |
6 |
Example |
LLDP/6/LLDP_DELETE_NEIGHBOR: Nearest bridge agent neighbor deleted on Port Ten-GigabitEthernet10/0/15 (IfIndex 599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
Explanation |
The port received a deletion message when a neighbor was deleted. |
LLDP_LESS_THAN_NEIGHBOR_LIMIT
Message text |
The number of [STRING] agent neighbors maintained by port [STRING] (IfIndex [UINT32]) is less than [UINT32], and new neighbors can be added. |
Variable fields |
$1: Agent type. $2: Port name. $3: Port ifIndex. $4: Maximum number of neighbors a port can maintain. |
Severity level |
6 |
Example |
LLDP/6/LLDP_LESS_THAN_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by port 1 (IfIndex 587599) is less than 16, and new neighbors can be added. |
Explanation |
New neighbors can be added for the port because the limit has not been reached. |
LLDP_NEIGHBOR_AGE_OUT
Message text |
[STRING] agent neighbor aged out on Port [STRING] (IfIndex [UINT32]), Chassis ID is [STRING], Port ID is [STRING]. |
Variable fields |
Severity level |
5 |
Example |
LLDP/5/LLDP_NEIGHBOR_AGE_OUT: Nearest bridge agent neighbor aged out on Port Ten-GigabitEthernet10/0/15 (IfIndex599), Chassis ID is 3822-d666-ba00, Port ID is GigabitEthernet6/0/5. |
Explanation |
This message is generated when the port failed to receive LLDPDUs from the neighbor within a certain period of time. |
Verify the link status or the receive/transmit status of LLDP on the peer. |
LLDP_REACH_NEIGHBOR_LIMIT
Message text |
The number of [STRING] agent neighbors maintained by the port [STRING] (IfIndex [UINT32]) has reached [UINT32], and no more neighbors can be added. |
Variable fields |
Severity level |
5 |
Example |
LLDP/5/LLDP_REACH_NEIGHBOR_LIMIT: The number of nearest bridge agent neighbors maintained by the port Ten-GigabitEthernet1/0/15 (IfIndex 15) has reached 5, and no more neighbors can be added. |
Explanation |
This message is generated when the port with its maximum number of neighbors reached received an LLDP packet. |
LOAD messages
This section contains load management messages.
BOARD_LOADING
Message text |
Board is loading file on Chassis [INT32] Slot [INT32]. |
Variable fields |
$1: Chassis ID. $2: Slot ID. |
Severity level |
4 |
Example |
LOAD/4/BOARD_LOADING: Board is loading file on Chassis 1 Slot 5. |
Explanation |
The specified card is loading files because of a reboot. |
LOAD_FAILED
Message text |
Board failed to load file on Chassis [INT32] Slot [INT32]. |
Variable fields |
Severity level |
3 |
Example |
LOAD/3/LOAD_FAILED: Board failed to load file on Chassis 1 Slot 5. |
Explanation |
The specified card failed to load files. |
Check for the fault and fix it. |
LOAD_FINISHED
Message text |
Board has finished loading file on Chassis [INT32] Slot [INT32]. |
Variable fields |
Severity level |
5 |
Example |
LOAD/5/LOAD_FINISHED: Board has finished loading file on Chassis 1 Slot 5. |
Explanation |
The specified card has finished loading files. |
LOGIN messages
This section contains login messages.
LOGIN_FAILED
Message text |
[STRING] failed to login from [STRING]. |
Variable fields |
$1: Username. $2: Line name or IP address. |
Severity level |
5 |
Example |
LOGIN/5/LOGIN_FAILED: TTY failed to log in from console0. LOGIN/5/LOGIN_FAILED: usera failed to log in from 192.168.11.22. |
Explanation |
A login attempt failed. |
LPDT messages
This section contains loop detection messages.
LPDT_LOOPED
Message text |
Loopback exists on [STRING]. |
Variable fields |
Severity level |
4 |
Example |
LPDT/4/LPDT_LOOPED: Loopback exists on Ethernet 6/4/2. |
Explanation |
A loop was detected on a port. |
Check the links and configuration on the device for the loop, and remove the loop. |
LPDT_RECOVERED
Message text |
Loopback on [STRING] recovered. |
Variable fields |
Severity level |
5 |
Example |
LPDT/5/LPDT_RECOVERED: Loopback on Ethernet 6/4/1 recovered. |
Explanation |
A loop on a port was removed. |
LS messages
This section contains Local Server messages.
LS_ADD_USER_TO_GROUP
Message text |
Admin [STRING] added user [STRING] to group [STRING]. |
Variable fields |
$1: Admin name. $2: User name. $3: User group name. |
Severity level |
4 |
Example |
LS/4/LS_ADD_USER_TO_GROUP: Admin admin added user user1 to group group1. |
Explanation |
The administrator added a user into a user group. |
LS_AUTHEN_FAILURE
Message text |
User [STRING] from [STRING] failed authentication. [STRING] |
Variable fields |
$1: User name. $2: IP address. $3: Reason of failure: · "User not found." · "Password verified failed." · "User not active." · "Access type mismatch." · "Binding attribute is failed." · "User in blacklist." |
Severity level |
5 |
Example |
LS/5/LS_AUTHEN_FAILURE: User cwf@system from 192.168.0.22 failed authentication. "User not found." |
Explanation |
The local server rejected a user's authentication request. |
LS_AUTHEN_SUCCESS
Message text |
User [STRING] from [STRING] was authenticated successfully. |
Variable fields |
$1: User name. $2: IP address. |
Severity level |
6 |
Example |
LS/6/LS_AUTHEN_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully. |
Explanation |
The local server accepted a user's authentication request. |
LS_DEL_USER_FROM_GROUP
Message text |
Admin [STRING] delete user [STRING] from group [STRING]. |
Variable fields |
Severity level |
4 |
Example |
LS/4/LS_DEL_USER_FROM_GROUP: Admin admin delete user user1 from group group1. |
Explanation |
The administrator deleted a user from a user group. |
LS_DELETE_PASSWORD_FAIL
Message text |
Failed to delete the password for user [STRING]. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_DELETE_PASSWORD_FAIL: Failed to delete the password for user abcd. |
Explanation |
Failed to delete the password for a user. |
Check the file system for errors. |
LS_PWD_ADDBLACKLIST
Message text |
User [STRING] was added to the blacklist due to multiple login failures, [STRING]. |
Variable fields |
$1: User name. $2: Options include: · but could make other attempts. · and is permanently blocked. · and was temporarily blocked for [UINT32] minutes. |
Severity level |
4 |
Example |
LS/4/LS_PWD_ADDBLACKLIST: user1 was added to the blacklist due to multiple login failures, but could make other attempts. |
Explanation |
A user was added to the blacklist because of multiple login failures. |
Check the user's password. |
LS_PWD_CHGPWD_FOR_AGEDOUT
Message text |
User [STRING] changed the password because it was expired. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_AGEDOUT: aaa changed the password because it was expired. |
Explanation |
A user changed the password because the password expired. |
LS_PWD_CHGPWD_FOR_AGEOUT
Message text |
User [STRING] changed the password because it was about to expire. |
Variable fields |
$1: User name. $2: Aging time. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_AGEOUT: aaa changed the password because it was about to expire. |
Explanation |
A user changed the password because the password is about to expire. |
LS_PWD_CHGPWD_FOR_COMPOSITION
Message text |
User [STRING] changed the password because it had an invalid composition. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_COMPOSITION: aaa changed the password because it had an invalid composition. |
Explanation |
A user changed the password because it had an invalid composition. |
LS_PWD_CHGPWD_FOR_FIRSTLOGIN
Message text |
User [STRING] changed the password at the first login. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_FIRSTLOGIN: aaa changed the password at the first login. |
Explanation |
A user changed the password at the first login. |
LS_PWD_CHGPWD_FOR_LENGTH
Message text |
User [STRING] changed the password because it was too short. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_PWD_CHGPWD_FOR_LENGTH: aaa changed the password because it was too short. |
Explanation |
A user changed the password because it was too short. |
LS_PWD_FAILED2WRITEPASS2FILE
Message text |
Failed to write the password records to file. |
Variable fields |
N/A |
Severity level |
4 |
Example |
LS/4/LS_PWD_FAILED2WRITEPASS2FILE: Failed to write the password records to file. |
Explanation |
LS_PWD_MODIFY_FAIL
Message text |
Admin [STRING] from [STRING] could not modify the password for user [STRING], because [STRING]. |
Variable fields |
$1: Admin name. $2: IP address. $3: User name. $4: Reason. Options include: · passwords did not match. · the password history cannot be written. · the password cannot be verified. |
Severity level |
4 |
Example |
LS/4/LS_PWD_MODIFY_FAIL: Admin admin from 1.1.1.1 could not modify the password for user user1, because passwords do not match. |
Explanation |
An administrator failed to modify a user's password. |
LS_PWD_MODIFY_SUCCESS
Message text |
Admin [STRING] from [STRING] modify the password for user [STRING] successfully. |
Variable fields |
$1: Admin name. $2: IP address. $3: User name. |
Severity level |
6 |
Example |
LS/6/LS_PWD_MODIFY_SUCCESS: Admin admin from 1.1.1.1 modify the password for user abc successfully. |
Explanation |
An administrator successfully modified a user's password. |
LS_REAUTHEN_FAILURE
Message text |
User [STRING] from [STRING] failed reauthentication. |
Variable fields |
Severity level |
5 |
Example |
LS/5/LS_REAUTHEN_FAILURE: User abcd from 1.1.1.1 failed reauthentication. |
Explanation |
A user failed reauthentication because the old password entered for reauthentication is invalid. |
Check the old password. |
LS_UPDATE_PASSWORD_FAIL
Message text |
Failed to update the password for user [STRING]. |
Variable fields |
$1: User name. |
Severity level |
4 |
Example |
LS/4/LS_UPDATE_PASSWORD_FAIL: Failed to update the password for user abc. |
Explanation |
Failed to update the password for a user. |
LS_USER_CANCEL
Message text |
User [STRING] from [STRING] cancelled inputting the password. |
Variable fields |
Severity level |
5 |
Example |
LS/5/LS_USER_CANCEL: User 1 from 1.1.1.1 cancelled inputting the password. |
Explanation |
The user cancelled inputting the password or did not input the password in 90 seconds. |
LS_USER_PASSWORD_EXPIRE
Message text |
User [STRING]'s login idle timer timed out. |
Variable fields |
$1: User name. |
Severity level |
5 |
Example |
LS/5/LS_USER_PASSWORD_EXPIRE: User 1's login idle timer timed out. |
Explanation |
The login idle time for a user expired. |
LS_USER_ROLE_CHANGE
Message text |
Admin [STRING] [STRING] the user role [STRING] for [STRING]. |
Variable fields |
$1: Admin name. $2: Added/Deleted. $3: User role. $4: User name. |
Severity level |
4 |
Example |
LS/4/LS_USER_ROLE_CHANGE: Admin admin add user role network-admin for user abcd. |
Explanation |
The administrator added a user role for a user. |
LSPV messages
This section contains LSP verification messages.
LSPV_PING_STATIS_INFO
Message text |
Ping statistics for [STRING]: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max = [UINT32]/[ UINT32]/[ UINT32] ms. |
Variable fields |
$1: FEC. $2: Number of echo requests sent. $3: Number of echo replies received. $4: Percentage of the non-replied packets to the total requests. $5: Minimum round-trip delay. $6: Average round-trip delay. $7: Maximum round-trip delay. |
Severity level |
6 |
Example |
LSPV/6/LSPV_PING_STATIS_INFO: Ping statistics for FEC 192.168.1.1/32: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max = 1/2/5 ms. |
Explanation |
Ping statistics for an LSP tunnel or a PW. This message is generated when the ping mpls command is executed. |
If no reply is received, verify the connectivity of the LSP tunnel or the PW. |
MAC messages
This section contains MAC messages.
MAC_TABLE_FULL_GLOBAL
Message text |
MAC address table exceeded maximum number [UINT32]. |
Variable fields |
$1: Maximum number of MAC addresses. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_GLOBAL: MAC address table exceeded maximum number 2. |
Explanation |
The number of entries in the global MAC address table exceeded the upper limit. |
MAC_TABLE_FULL_PORT
Message text |
MAC address table exceeded maximum number [UINT32] on interface [STRING]. |
Variable fields |
$1: Maximum number of MAC addresses. $2: Interface name. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_PORT: MAC address table exceeded maximum number 2 on interface GigabitEthernet2/0/32. |
Explanation |
The number of entries in the MAC address table for an interface exceeded the upper limit. |
MAC_TABLE_FULL_VLAN
Message text |
MAC address table exceeded maximum number [UINT32] on Vlan [UINT32]. |
Variable fields |
$1: Maximum number of MAC addresses. $2: VLAN ID. |
Severity level |
4 |
Example |
MAC/4/MAC_TABLE_FULL_VLAN: MAC address table exceeded maximum number 2 on Vlan 2. |
Explanation |
The number of entries in the MAC address table for a VLAN exceeded the upper limit. |
MBFD messages
This section contains MPLS BFD messages.
MBFD_TRACEROUTE_FAILURE
Message text |
[STRING] in failure. ([STRING].) |
Variable fields |
$1: LSP information. $2: Reason for the LSP failure. |
Severity level |
5 |
Example |
MBFD/5/MBFD_TRACEROUTE_FAILURE: LSP (LDP IPv4: 22.22.2.2/32, nexthop: 20.20.20.2) in failure. (Replying router has no mapping for the FEC.) MBFD/5/MBFD_TRACEROUTE_FAILURE: TE tunnel (RSVP IPv4: Tunnel1) in failure. (No label entry.) |
Explanation |
LSP/MPLS TE tunnel failure was detected by periodic MPLS traceroute. This message is generated when the system receives an MPLS echo reply with an error return code. |
Verify the configuration for the LSP or MPLS TE tunnel. |
MDC messages
This section contains MDC messages.
MDC_CREATE
Message text |
MDC [UINT16] is created. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_CREATE: MDC 2 is created. |
Explanation |
An MDC was created successfully. |
MDC_CREATE_ERR
Message text |
Failed to create MDC [UINT16] for not enough resources. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_CREATE_ERR: Failed to create MDC 2 for not enough resources. |
Explanation |
The standby MPU did not have enough resources to create the MDC. At startup, the standby MPU obtains MDC configuration information from the active MPU and tries to create the same MDCs. If the standby MPU does not have enough resources to create an MDC, it outputs this log message. |
1. Use the display mdc resource command to display the CPU, memory, and disk space resources on the standby MPU. 2. Perform one of the following tasks: · If the memory space is insufficient, increase the memory space. If the disk space is insufficient, delete unused files. · Use the undo mdc command to remove the specified MDC. 3. Remove the standby MPU. |
MDC_DELETE
Message text |
MDC [UINT16] is deleted. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_DELETE: MDC 2 is deleted. |
Explanation |
An MDC was deleted successfully. |
MDC_LICENSE_EXPIRE
Message text |
The MDC feature's license will expire in [UINT32] days. |
Variable fields |
$1: Number of days, in the range of 1 to 30. |
Severity level |
5 |
Example |
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature's license will expire in 5 days. |
Explanation |
The license for the MDC feature was about to expire. |
MDC_NO_FORMAL_LICENSE
Message text |
The feature MDC has no available formal license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
MDC/5/MDC_NO_FORMAL_LICENSE: The feature MDC has no available formal license. |
Explanation |
The standby MPU became the active MPU but it did not have a formal license. The MDC feature has a free trial period. To use the feature after the period elapses, you must install a license for the standby MPU. |
Install a formal license. |
MDC_NO_LICENSE_EXIT
Message text |
The MDC feature is being disabled, because it has no license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
MDC/5/MDC_NO_LICENSE_EXIT: The MDC feature is being disabled, because it has no license. |
Explanation |
The MDC feature was disabled because the license for the MDC feature expired or was uninstalled. |
Install the required license. |
MDC_OFFLINE
Message text |
MDC [UINT16] is offline now. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_OFFLINE: MDC 2 is offline now. |
Explanation |
An MDC was stopped. |
MDC_ONLINE
Message text |
MDC [UINT16] is online now. |
Variable fields |
$1: MDC ID. |
Severity level |
5 |
Example |
MDC/5/MDC_ONLINE: MDC 2 is online now. |
Explanation |
An MDC was started. |
MDC_STATE_CHANGE
Message text |
MDC [UINT16] state changed to [STRING]. |
Variable fields |
$1: MDC ID. $2: Current status. |
Severity level |
5 |
Example |
MDC/5/MDC_STATE_CHANGE: MDC 2 state changed to active. |
Explanation |
The status of an MDC changed. |
MFIB messages
This section contains MFIB messages.
MFIB_MEM_ALERT
Message text |
MFIB Process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alert event. |
Severity level |
5 |
Example |
MFIB/5/MFIB_MEM_ALERT: MFIB Process receive system memory alert start event. |
Explanation |
MFIB received a memory alert event from the system. |
Check the system memory. |
MGROUP messages
This section contains mirroring group messages.
MGROUP_APPLY_SAMPLER_FAIL
Message text |
Failed to apply the sampler for mirroring group [UINT16], because the sampler resources are insufficient. |
Variable fields |
$1: Mirroring group ID. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_APPLY_SAMPLER_FAIL: Failed to apply the sampler for mirroring group 1, because the sampler resources are insufficient. |
Explanation |
A sampler was not applied to the mirroring group because the sampler resources were insufficient. |
MGROUP_RESTORE_CPUCFG_FAIL
Message text |
Failed to restore configuration for mirroring CPU of [STRING] in mirroring group [UINT16], because [STRING] |
Variable fields |
$1: Slot number. $2: Mirroring group ID. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_RESTORE_CPUCFG_FAIL: Failed to restore configuration for mirroring CPU of chassis 1 slot 2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
Explanation |
When the CPU of the card in the slot is the source CPU in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the source CPU configuration might fail. |
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the source CPU in the mirroring group. |
MGROUP_RESTORE_IFCFG_FAIL
Failed to restore configuration for interface [STRING] in mirroring group [UINT16], because [STRING] |
Variable fields |
$1: Interface name. $2: Mirroring group ID. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_RESTORE_IFCFG_FAIL: Failed to restore configuration for interface Ethernet3/1/2 in mirroring group 1, because the type of the monitor port in the mirroring group is not supported. |
Explanation |
When the interface of the card in the slot is the monitor port in the mirroring group, configuration changes after the card is removed. When the card is reinstalled into the slot, restoring the monitor port configuration might fail. |
Check for the failure reason. If the reason is that the system does not support the changed configuration, delete the unsupported configuration, and reconfigure the monitor port in the mirroring group. |
MGROUP_SYNC_CFG_FAIL
Message text |
Failed to restore configuration for mirroring group [UINT16] in [STRING], because [STRING] |
Variable fields |
$1: Mirroring group ID. $2: Slot number. $3: Failure reason. |
Severity level |
3 |
Example |
MGROUP/3/MGROUP_SYNC_CFG_FAIL: Failed to restore configuration for mirroring group 1 in chassis 1 slot 2, because monitor resources are insufficient. |
Explanation |
When the complete mirroring group configuration was synchronized on the card in the slot, restoring configuration failed because resources on the card were insufficient. |
Delete the mirroring group. |
MPLS messages
This section contains MPLS messages.
MPLS_HARD_RESOURCE_NOENOUGH
Message text |
No enough hardware resource for MPLS. |
Variable fields |
N/A |
Severity level |
4 |
Example |
MPLS/4/MPLS_HARD_RESOURCE_NOENOUGH: No enough hardware resource for MPLS. |
Explanation |
Hardware resources for MPLS were insufficient. |
Check whether unnecessary LSPs had been generated. If yes, configure or modify the LSP generation policy, label advertisement policy, and label acceptance policy to filter out unnecessary LSPs. |
MPLS_HARD_RESOURCE_RESTORE
Message text |
Hardware resource for MPLS is restored. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MPLS/6/MPLS_HARD_RESOURCE_RESTORE: Hardware resource for MPLS is restored. |
Explanation |
Hardware resources for MPLS restored. |
Recommended action |
MSTP messages
This section contains MSTP messages.
MSTP_BPDU_PROTECTION
Message text |
BPDU-Protection port [STRING] received BPDUs. |
Variable fields |
$1: Interface name. |
Severity level |
4 |
Example |
MSTP/4/MSTP_BPDU_PROTECTION: BPDU-Protection port Ethernet 1/0/4 received BPDUs. |
Explanation |
A BPDU-guard-enabled port received BPDUs. |
Check whether the downstream device is a terminal and check for possible attacks from the downstream device or other devices. |
MSTP_BPDU_RECEIVE_EXPIRY
Message text |
Instance [UINT32]'s port [STRING] received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Variable fields |
$1: Instance ID. $2: Interface name. |
Severity level |
5 |
Example |
MSTP/5/MSTP_BPDU_RECEIVE_EXPIRY: Instance 0's port GigabitEthernet 0/4/1 received no BPDU within the rcvdInfoWhile interval. Information of the port aged out. |
Explanation |
The state changed because a non-designated port did not receive a BPDU within the max age. |
Check the STP status of the upstream device and possible attacks from other devices. |
MSTP_DETECTED_TC
Message text |
Instance [UINT32]'s port [STRING] detected a topology change. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_DETECTED_TC: Instance 0's port GigabitEthernet 0/1/1 detected a topology change. |
Explanation |
The MSTP instance to which the port belongs had a topology change, and the local end detected the change. |
Identify the topology change cause and handle the issue. For example, if the change is caused by a link down event, recover the link. |
MSTP_DISABLE
Message text |
STP is now disabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MSTP/6/MSTP_DISABLE: STP is now disabled on the device. |
Explanation |
STP was disabled globally on the device. |
No action is required. |
MSTP_DISCARDING
Message text |
Instance [UINT32]'s port [STRING] has been set to discarding state. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_DISCARDING: Instance 0's port Ethernet 1/0/2 has been set to discarding state. |
Explanation |
MSTP calculated the state of the ports within the instance, and a port was set to the discarding state. |
MSTP_ENABLE
Message text |
STP is now enabled on the device. |
Variable fields |
N/A |
Severity level |
6 |
Example |
MSTP/6/MSTP_ENABLE: STP is now enabled on the device. |
Explanation |
STP was enabled globally on the device. |
MSTP_FORWARDING
Message text |
Instance [UINT32]'s port [STRING] has been set to forwarding state. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_FORWARDING: Instance 0's port Ethernet 1/0/2 has been set to forwarding state. |
Explanation |
MSTP calculated the state of the ports within the instance, a port was set to the forwarding state. |
MSTP_LOOP_PROTECTION
Message text |
Instance [UINT32]'s LOOP-Protection port [STRING] failed to receive configuration BPDUs. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_LOOP_PROTECTION: Instance 0's LOOP-Protection port Ethernet 1/0/2 failed to receive configuration BPDUs. |
Explanation |
A loop-guard-enabled port failed to receive configuration BPDUs. |
MSTP_NOT_ROOT
Message text |
The current switch is no longer the root of instance [UINT32]. |
Variable fields |
$1: Instance ID. |
Severity level |
5 |
Example |
MSTP/5/MSTP_NOT_ROOT: The current switch is no longer the root of instance 0. |
Explanation |
The current switch is no longer the root bridge of an instance. It received a superior BPDU after it was configured as the root bridge. |
Check the bridge priority configuration and possible attacks from other devices. |
MSTP_NOTIFIED_TC
Message text |
Instance [UINT32]'s port [STRING] was notified of a topology change. |
Variable fields |
Severity level |
6 |
Example |
MSTP/6/MSTP_NOTIFIED_TC: Instance 0's port GigabitEthernet 0/1/1 was notified of a topology change. |
Explanation |
The neighboring device notified the current device that a topology change occurred in the instance to which the port belongs. |
MSTP_ROOT_PROTECTION
Message text |
Instance [UINT32]'s ROOT-Protection port [STRING] received superior BPDUs. |
Variable fields |
Severity level |
4 |
Example |
MSTP/4/MSTP_ROOT_PROTECTION: Instance 0's ROOT-Protection port Ethernet 1/0/2 received superior BPDUs. |
Explanation |
A root-guard-enabled port received BPDUs that are superior to the BPDUs generated by itself. |
MTLK messages
This section contains Monitor Link messages.
MTLK_UPLINK_STATUS_CHANGE
Message text |
The uplink of monitor link group [UINT32] is [STRING]. |
Variable fields |
$1: Monitor link group ID. $2: Monitor Link group status, up or down. |
Severity level |
6 |
Example |
MTLK/6/MTLK_UPLINK_STATUS_CHANGE: The uplink of monitor link group 1 is up. |
Explanation |
The uplink status of a monitor link group changed to up or down. |
Check a link when it fails. |
ND messages
This section contains ND messages.
ND_CONFLICT
Message text |
[STRING] is inconsistent |
Variable fields |
$1: Configuration type: · M_FLAG. · O_FLAG. · CUR_HOP_LIMIT. · REACHABLE TIME. · NS INTERVAL. · MTU. · PREFIX VALID TIME. · PREFIX PREFERRED TIME. |
Severity level |
6 |
Example |
ND/6/ND_CONFLICT: PREFIX VALID TIME is inconsistent |
Explanation |
A router advertisement was received, which caused the configuration inconsistency between neighboring routers. |
Verify that the configurations on the device and the neighboring router are consistent. |
ND_DUPADDR
Message text |
Duplicate address: [STRING] on the interface [STRING] |
Variable fields |
$1: Address that is to be assigned to an interface. $2: Name of the interface. |
Severity level |
6 |
Example |
ND/6/ND_DUPADDR: Duplicate address: 33::8 on interface Vlan-interface9. |
Explanation |
The address that was to be assigned to the interface is already used by another device. |
Assign a different address to the interface. |
NQA messages
This section contains NQA messages.
NQA_LOG_UNREACHABLE
Message text |
Server [STRING] unreachable. |
Variable fields |
$1: IP address of the NQA server. |
Severity level |
6 |
Example |
NQA/6/NQA_LOG_UNREACHABLE: Server 192.168.30.117 unreachable. |
Explanation |
An unreachable server was detected. |
Check the network environment. |
NTP messages
This section contains NTP messages.
NTP_CHANGE_LEAP
Message text |
System Leap Indicator changed from [UINT32] to [UINT32] after clock update. |
Variable fields |
$1: Original Leap Indicator. $2: Current Leap Indicator. |
Severity level |
5 |
Example |
NTP/5/NTP_CHANGE_LEAP: System Leap Indicator changed from 00 to 01 after clock update. |
Explanation |
The system Leap Indicator changed. For example, the NTP status changed from unsynchronized to synchronized. NTP Leap Indicator is a two-bit code warning of an impending leap second to be inserted in the NTP timescale. The bits are set before 23:59 on the day of insertion and reset after 00:00 on the following day. This causes the number of seconds (rolloverinterval) in the day of insertion to be increased or decreased by one. |
NTP_CHANGE_STRATUM
Message text |
System stratum changed from [UINT32] to [UINT32] after clock update. |
Variable fields |
$1: Original stratum. $2: Current stratum. |
Severity level |
5 |
Example |
NTP/5/NTP_CHANGE_STRATUM: System stratum changed from 6 to 5 after clock update. |
Explanation |
System stratum changed. |
NTP_CLOCK_CHANGE
Message text |
System clock changed from [STRING] to [STRING], the server is [STRING]. |
Variable fields |
$1: Time before synchronization. $2: Time after synchronization. $3: IP address. |
Severity level |
5 |
Example |
NTP/5/NTP_CLOCK_CHANGE: System clock changed from 02:12:58 12/28/2012 to 02:29:12 12/28/2012, the server is 192.168.30.116. |
Explanation |
The NTP server triggered the NTP client to synchronize the client time. |
NTP_SOURCE_CHANGE
Message text |
NTP server changed from [STRING] to [STRING]. |
Variable fields |
$1: IP address of the original time source. $2: IP address of the new time source. |
Severity level |
5 |
Example |
NTP/5/NTP_SOURCE_CHANGE: NTP server changed from 1.1.1.1 to 1.1.1.2. |
Explanation |
The system changed the time source. |
Assign another NTP server as the time source. |
NTP_SOURCE_LOST
Message text |
Lost synchronization with NTP server [STRING]. |
Variable fields |
$1: IP address. |
Severity level |
5 |
Example |
NTP/5/NTP_SOURCE_LOST: Lost synchronization with NTP server 1.1.1.1. |
Explanation |
The clock source of the NTP association is in unsynchronized state or it is unreachable. |
Check the NTP server and network connection. |
OPTMOD messages
This section contains transceiver module messages.
BIAS_HIGH
Message text |
[STRING]: Bias current is high! |
Variable fields |
$1: Interface type and number. |
Severity level |
2 |
Example |
OPTMOD/2/BIAS_HIGH: GigabitEthernet1/0/13: Bias current is high! |
Explanation |
The bias current of the transceiver module has exceeded the upper limit. |
Locate the fault and fix it. If it cannot be fixed, replace the transceiver module. |
BIAS_LOW
Message text |
[STRING]: Bias current is low! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/BIAS_LOW: GigabitEthernet1/0/13: Bias current is low! |
Explanation |
The bias current of the transceiver module is below the lower limit. |
BIAS_NORMAL
Message text |
[STRING]: Bias current is normal! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/BIAS_NORMAL: GigabitEthernet1/0/13: Bias current is normal! |
Explanation |
The bias current of the transceiver module has returned to the acceptable range. |
CFG_ERR
Message text |
[STRING]: The transceiver type does not match port configuration! |
Variable fields |
Severity level |
3 |
Example |
OPTMOD/3/CFG_ERR: GigabitEthernet1/0/13: The transceiver type does not match port configuration! |
Explanation |
The transceiver module type does not match the port configuration. |
Identify the reason causing the mismatch and replace the transceiver module. |
CHKSUM_ERR
Message text |
[STRING]: The checksum of transceiver information is bad! |
Variable fields |
$1: Interface type and number |
Severity level |
5 |
Example |
OPTMOD/5/CHKSUM_ERR: GigabitEthernet1/0/13: The checksum of transceiver information is bad! |
Explanation |
The checksum verification on the register information on the transceiver module failed. |
IO_ERR
Message text |
[STRING]: The transceiver information I/O failed! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/IO_ERR: GigabitEthernet1/0/13: The transceiver information I/O failed! |
Explanation |
The device failed to access the register information of the transceiver module. |
MOD_ALM_OFF
Message text |
[STRING]: [STRING] is gone. |
Variable fields |
$1: Interface type and number. $2: Fault type. |
Severity level |
5 |
Example |
OPTMOD/5/MOD_ALM_OFF: GigabitEthernet1/0/13: Module_not_ready is gone. |
Explanation |
A fault was removed from the transceiver module. |
MOD_ALM_ON
Message text |
[STRING]: [STRING] is detected! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/MOD_ALM_ON: GigabitEthernet1/0/13: Module_not_ready is detected! |
Explanation |
A fault was detected on the transceiver module. |
Fix the fault. If it cannot be fixed, replace the transceiver module. |
MODULE_IN
Message text |
[STRING]: The transceiver is [STRING]. |
Variable fields |
$1: Interface type and number. $2: Type of the transceiver module. |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_IN: GigabitEthernet1/0/13: The transceiver is 1000_BASE_T_AN_SFP. |
Explanation |
When a transceiver module is inserted, the OPTMOD module generates the message to display the transceiver module type. |
MODULE_OUT
Message text |
[STRING]: The transceiver is absent. |
Variable fields |
Severity level |
4 |
Example |
OPTMOD/4/MODULE_OUT: GigabitEthernet1/0/13: The transceiver is absent. |
Explanation |
The transceiver module was removed. |
PHONY_MODULE
Message text |
[STRING]: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! |
Variable fields |
Severity level |
4 |
Example |
OPTMOD/4/PHONY_MODULE: GigabitEthernet1/0/13: This transceiver is NOT sold by H3C. H3C therefore shall NOT guarantee the normal function of the device or assume the maintenance responsibility thereof! |
Explanation |
The transceiver module is not sold by H3C. |
Verify the transceiver module compatibility. If it is not compatible, replace it. |
RX_ALM_OFF
Message text |
Variable fields |
$1: Interface type and number. $2: RX fault type. |
Severity level |
5 |
Example |
OPTMOD/5/RX_ALM_OFF: GigabitEthernet1/0/13: RX_not_ready is gone. |
Explanation |
An RX fault was removed from the transceiver module. |
RX_ALM_ON
Message text |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_ALM_ON: GigabitEthernet1/0/13: RX_not_ready is detected! |
Explanation |
An RX fault was detected on the transceiver module. |
RX_POW_HIGH
Message text |
[STRING]: RX power is high! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_HIGH: GigabitEthernet1/0/13: RX power is high! |
Explanation |
The RX power of the transceiver module has exceeded the upper limit. |
RX_POW_LOW
Message text |
[STRING]: RX power is low! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_LOW: GigabitEthernet1/0/13: RX power is low! |
Explanation |
The RX power of the transceiver module is below the lower limit. |
RX_POW_NORMAL
Message text |
[STRING]: RX power is normal! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/RX_POW_NORMAL: GigabitEthernet1/0/13: RX power is normal! |
Explanation |
The RX power of the transceiver module has returned to the acceptable range. |
TEMP_HIGH
Message text |
[STRING]: Temperature is high! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_HIGH: GigabitEthernet1/0/13: Temperature is high! |
Explanation |
The temperature of the transceiver module has exceeded the upper limit. |
TEMP_LOW
Message text |
[STRING]: Temperature is low! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_LOW: GigabitEthernet1/0/13: Temperature is low! |
Explanation |
The temperature of the transceiver module is below the lower limit. |
TEMP_NORMAL
Message text |
[STRING]: Temperature is normal! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TEMP_NORMAL: GigabitEthernet1/0/13: Temperature is normal! |
Explanation |
The temperature of the transceiver module has returned to the acceptable range. |
TX_ALM_OFF
Message text |
Variable fields |
$1: Interface type and number. $2: TX fault type. |
Severity level |
5 |
Example |
OPTMOD/5/TX_ALM_OFF: GigabitEthernet1/0/13: TX_fault is gone. |
Explanation |
A TX fault was removed from the transceiver module. |
TX_ALM_ON
Message text |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_ALM_ON: GigabitEthernet1/0/13: TX_fault is detected! |
Explanation |
A TX fault was detected on the transceiver module. |
TX_POW_HIGH
Message text |
[STRING]: TX power is high! |
Variable fields |
Severity level |
2 |
Example |
OPTMOD/2/TX_POW_HIGH: GigabitEthernet1/0/13: TX power is high! |
Explanation |
The TX power of the transceiver module has exceeded the upper limit. |
Locate the fault and fix it. If it cannot be fixed replace the transceiver module. |
TX_POW_LOW
Message text |
[STRING]: TX power is low! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_POW_LOW: GigabitEthernet1/0/13: TX power is low! |
Explanation |
The TX power of the transceiver module is below the lower limit. |
TX_POW_NORMAL
Message text |
[STRING]: TX power is normal! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/TX_POW_NORMAL: GigabitEthernet1/0/13: TX power is normal! |
Explanation |
The TX power of the transceiver module has returned to the acceptable range. |
TYPE_ERR
Message text |
[STRING]: The transceiver type is not supported by port hardware! |
Variable fields |
Severity level |
3 |
Example |
OPTMOD/3/TYPE_ERR: GigabitEthernet1/0/13: The transceiver type is not supported by port hardware! |
Explanation |
The transceiver module is not supported by the port. |
Replace the transceiver module. |
VOLT_HIGH
Message text |
[STRING]: Voltage is high! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_HIGH: GigabitEthernet1/0/13: Voltage is high! |
Explanation |
The voltage of the transceiver module has exceeded the upper limit. |
VOLT_LOW
Message text |
[STRING]: Voltage is low! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_LOW: GigabitEthernet1/0/13: Voltage is low! |
Explanation |
The voltage of the transceiver module is below the lower limit. |
VOLT_NORMAL
Message text |
[STRING]: Voltage is normal! |
Variable fields |
Severity level |
5 |
Example |
OPTMOD/5/VOLT_NORMAL: GigabitEthernet1/0/13: Voltage is normal! |
Explanation |
The voltage of the transceiver module has returned to the acceptable range. |
OSPF messages
This section contains OSPF messages.
OSPF_LAST_NBR_DOWN
Message text |
OSPF [UINT32] Last neighbor down event: Router ID: [STRING] Local address: [STRING] Remote address: [STRING] Reason: [STRING] |
Variable fields |
$1: OSPF process ID. $2: Router ID. $3: Local IP address. $4: Neighbor IP address. $5: Reason. |
Severity level |
6 |
Example |
OSPF/6/OSPF_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 Local address: 10.1.1.1 Remote address: 10.1.1.2 Reason: Dead Interval timer expired. |
Explanation |
The device records the OSPF neighbor down event caused by a specific reason. |
1. When a down event occurred because of configuration changes (for example, interface parameter changes), check for the configuration errors. 2. When a down event occurred because of dead interval expiration, check for the dead interval configuration error and loss of network connectivity. 3. When a down event occurred because of BFD session down, check for the BFD detection time configuration error and loss of network connectivity. 4. When a down event occurred because of interface status changes, check for loss of network connectivity. |
OSPF_MEM_ALERT
Message text |
OSPF Process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alarm. |
Severity level |
5 |
Example |
OSPF/5/OSPF_MEM_ALERT: OSPF Process receive system memory alert start event. |
Explanation |
OSPF received a memory alarm. |
OSPF_NBR_CHG
Message text |
OSPF [UINT32] Neighbor [STRING] ([STRING]) from [STRING] to [STRING] |
Variable fields |
$1: OSPF process ID. $2: Neighbor IP address. $3: Interface name. $4: Old adjacency state. $5: New adjacency state. |
Severity level |
5 |
Example |
OSPF/5/OSPF_NBR_CHG: OSPF 1 Neighbor 2.2.2.2 (Vlan-interface100) from Full to Down. |
Explanation |
The OSPF adjacency state changed on an interface. |
When the adjacency with a neighbor changes from Full to another state on an interface, check for OSPF configuration errors and loss of network connectivity. |
OSPF_RT_LMT
Message text |
OSPF [UINT32] route limit reached. |
Variable fields |
$1: OSPF process ID. |
Severity level |
4 |
Example |
OSPF/4/OSPF_RT_LMT: OSPF 1 route limit reached. |
Explanation |
The number of routes of an OSPF process reached the upper limit. |
1. Check for network attacks. 2. Reduce the number of routes. |
OSPF_RTRID_CHG
Message text |
OSPF [UINT32] New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Variable fields |
Severity level |
5 |
Example |
OSPF/5/OSPF_RTRID_CHG: OSPF 1 New router ID elected, please restart OSPF if you want to make the new router ID take effect. |
Explanation |
The OSPF router ID was changed because the user changed the router ID or the interface IP address used as the router ID changed. |
Use the reset ospf process command to make the new router ID take effect. |
OSPF_VLINKID_CHG
Message text |
OSPF [UINT32] Router ID changed, re-configure Vlink on peer |
Variable fields |
Severity level |
5 |
Example |
OSPF/5/OSPF_VLINKID_CHG:OSPF 1 Router ID changed, re-configure Vlink on peer |
Explanation |
A new OSPF router ID takes effect. |
Check and modify the virtual link configuration on the peer router to match the new router ID. |
OSPFV3 messages
This section contains OSPFv3 messages.
OSPFV3_LAST_NBR_DOWN
Message text |
OSPFv3 [UINT32] Last neighbor down event: Router ID: [STRING] local Interface Id: [UINT32] Remote Interface Id: [UINT32] Reason: [STRING]. |
Variable fields |
$1: OSPFv3 process ID. $2: Router ID. $3: Local interface ID. $4: Remote interface ID. $5: Reason. |
Severity level |
6 |
Example |
OSPFV3/6/OSPFV3_LAST_NBR_DOWN: OSPF 1 Last neighbor down event: Router ID: 2.2.2.2 local Interface Id: 1111 Remote Interface Id: 2222 Reason: Dead Interval timer expired. |
Explanation |
The device records the most recent OSPFv3 neighbor down event caused by a specific reason. |
Check the reason for the most recent OSPFv3 neighbor down event. |
OSPFV3_MEM_ALERT
Message text |
OSPFV3 Process receive system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_MEM_ALERT: OSPFV3 Process receive system memory alert start event. |
Explanation |
OSPFv3 received a memory alarm. |
OSPFV3_NBR_CHG
Message text |
OSPFv3 [UINT32] Neighbor [STRING] ([STRING]) received [STRING] and its state from [STRING] to [STRING]. |
Variable fields |
$1: Process ID. $2: Neighbor router ID. $3: Interface name. $4: Neighbor event. $5: Old adjacency state. $6: New adjacency state. |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_NBR_CHG: OSPFv3 1 Neighbor 2.2.2.2 (Vlan100) received 1-Way from Full to Init. |
Explanation |
The OSPFv3 adjacency state changed on an interface. |
When the adjacency with a neighbor changes to down on an interface, check for OSPFv3 configuration errors and loss of network connectivity. |
OSPFV3_RT_LMT
Message text |
OSPFv3 [UINT32] Route limit reached. |
Variable fields |
$1: Process ID. |
Severity level |
5 |
Example |
OSPFV3/5/OSPFV3_RT_LMT:OSPFv3 1 Route limit reached. |
Explanation |
The number of routes of an OSPFv3 process reached the upper limit. |
Modify the route limit configuration. |
PBB messages
This section contains PBB messages.
PBB_JOINAGG_WARNING
Message text |
Because the aggregate interface [STRING] has been configured with PBB, assigning the interface [STRING] that does not support PBB to the aggregate group will cause incorrect processing. |
Variable fields |
$1: Aggregation group name. $2: Interface name. |
Severity level |
4 |
Example |
PBB/4/PBB_JOINAGG_WARNING: Because the aggregate interface Bridge-Aggregation1 has been configured with PBB, assigning the interface Ten-GigabitEthernet9/0/30 that does not support PBB to the aggregate group will cause incorrect processing. |
Explanation |
Because the interface does not support PBB, assigning the interface to an aggregation group configured with PBB will cause incorrect processing. If an aggregate interface is a PBB uplink port, all its members should support PBB. |
Remove the interface from the aggregation group. |
PIM messages
This section contains PIM messages.
PIM_MEM_ALERT
Message text |
PIM Process receive system memory alert [STRING] event. |
Variable fields |
$1: Event type of the memory alert. |
Severity level |
5 |
Example |
PIM/5/PIM_MEM_ALERT: PIM Process receive system memory alert start event. |
Explanation |
When the memory changed, the PIM module received a memory alert event. |
PIM_NBR_DOWN
Message text |
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is down. ([STRING][STRING]) [STRING]: Neighbor [STRING] ([STRING]) is down. |
Variable fields |
$1: Public network or VPN instance. $2: IP address of the neighbor. $3: Interface name. |
Severity level |
5 |
Example |
PIM/5/PIM_NBR_DOWN: (public net): Neighbor 10.1.1.1(Vlan-interface10) is down. |
Explanation |
The PIM neighbor was down. |
Check the PIM configuration and network status. |
PIM_NBR_UP
Message text |
[STRING]PIM-NBR change: Neighbor [STRING]([STRING]) is up. ([STRING][STRING]) [STRING]: Neighbor [STRING] ([STRING]) is up. |
Variable fields |
Severity level |
5 |
Example |
PIM/5/PIM_NBR_UP: (public net): Neighbor 10.1.1.1(Vlan-interface10) is up. |
Explanation |
The PIM neighbor was up. |
PING messages
This section contains ping messages.
PING_STATIS_INFO
Message text |
[STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
Variable fields |
$1: IP address, IPv6 address, or host name for the destination. $2: Ping or ping6. $3: Number of echo requests sent. $4: Number of echo replies received. $5: Percentage of the non-replied packets to the total request packets. $6: Minimum round-trip delay. $7: Average round-trip delay. $8: Maximum round-trip delay. $9: Standard deviation round-trip delay. |
Severity level |
6 |
Example |
PING/6/PING_STATIS_INFO: 192.168.0.115 ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
Explanation |
Statistics for a ping operation. |
If there is no packet received, identify whether the interface is down. |
PING_VPN_STATIS_INFO
Message text |
[STRING] in VPN-instance [STRING] [STRING] statistics: [UINT32] packet(s) transmitted, [UINT32] packet(s) received, [DOUBLE]% packet loss, round-trip min/avg/max/std-dev = [DOUBLE]/[DOUBLE]/[DOUBLE]/[DOUBLE] ms. |
Variable fields |
$1: IP address, IPv6 address, or host name for the destination. $2: VPN instance name. $3: ping or ping6. $4: Number of echo requests sent. $5: Number of echo replies received. $6: Percentage of the non-replied packets to the total request packets. $7: Minimum round-trip delay. $8: Average round-trip delay. $9: Maximum round-trip delay. $10: Standard deviation round-trip delay. |
Severity level |
6 |
Example |
PING/6/PING_VPN_STATIS_INFO: 192.168.0.115 in VPN-instance VPNA ping statistics: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.000/0.800/2.000/0.748 ms. |
Explanation |
PKI messages
This section contains PKI messages.
REQUEST_CERT_FAIL
Message text |
Failed to request certificate of domain [STRING]. |
Variable fields |
$1: PKI domain name |
Severity level |
5 |
Example |
PKI/5/REQUEST_CERT_FAIL: Failed to request certificate of domain abc. |
Explanation |
Failed to request certificate for a domain. |
Check the configuration of the device and CA server, and the network between them. |
REQUEST_CERT_SUCCESS
Message text |
Request certificate of domain [STRING] successfully. |
Variable fields |
Severity level |
5 |
Example |
PKI/5/REQUEST_CERT_SUCCESS: Request certificate of domain abc successfully. |
Explanation |
Successfully requested certificate for a domain. |
PKT2CPU messages
This section contains PKT2CPU messages.
PKT2CPU_NO_RESOURCE
Message text |
-Interface=[STRING]-ProtocolType=[UINT32]-MacAddr=[STRING]; The resources is insufficient. -Interface=[STRING]-ProtocolType=[UINT32]-SrcPort=[UINT32]-DstPort=[UINT32]; The resources is insufficient. |
Variable fields |
$1: Interface type and number. $2: Protocol type. $3: MAC address or source port. $4: Destination port. |
Severity level |
4 |
Example |
PKT2CPU/4/PKT2CPU_NO_RESOURCE: -Interface=Ethernet0/0/2-ProtocolType=21-MacAddr=0180-c200-0014; The resources is insufficient. |
Explanation |
Hardware resources were insufficient. |
Remove the configuration. |
PORTSEC messages
This section contains port security messages.
PORTSEC_PORTMODE_NOT_EFFECTIVE
Message text |
The port-security mode is configured but is not effective on interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PORTSEC/3/PORTSEC_PORTMODE_NOT_EFFECTIVE: The port-security mode is configured but is not effective on interface Ethernet3/1/2. |
Explanation |
The port security mode does not take effect on an interface, because the interface does not support this mode. |
Change the port security mode or disable the port security feature on the interface. |
PORTSEC_NTK_NOT_EFFECTIVE
Message text |
The NeedToKnow feature is configured but is not effective on interface [STRING]. |
Variable fields |
Severity level |
3 |
Example |
PORTSEC/3/PORTSEC_NTK_NOT_EFFECTIVE: The NeedToKnow feature is configured but is not effective on interface Ethernet3/1/2. |
Explanation |
The NeedToKnow mode does not take effect on an interface, because the interface does not support the NeedToKnow mode. |
1. Remove the problem depending on the network requirements: 2. If the NeedToKnow feature is not required, disable the NeedToKnow feature on the interface. 3. If the NeedToKnow feature is required, reconnect the connected devices to another interface that supports the NeedToKnow mode. Then, configure the NeedToKnow mode on the new interface. 4. If the problem persists, contact H3C Support. |
PPP messages
This section contains PPP messages.
IPPOOL_ADDRESS_EXHAUSTED
Message text |
The address pool [STRING] is exhausted. |
Variable fields |
$1: Pool name. |
Severity level |
5 |
Example |
PPP/5/IPPOOL_ADDRESS_EXHAUSTED: The address pool aaa is exhausted. |
Explanation |
This message is generated when the last address is assigned from the pool. |
1. Add addresses to the pool. 2. If the problem persists, contact H3C Support. |
PWDCTL messages
This section contains password control messages.
ADDBLACKLIST
Message text |
[STRING] was added to the blacklist for failed login attempts. |
Variable fields |
$1: Username. |
Severity level |
6 |
Example |
PWDCTL/6/ADDBLACKLIST: hhh was added to the blacklist for failed login attempts. |
Explanation |
A user was added to the password control blacklist because of a login failure caused by a wrong password. |
CHANGEPASSWORD
Message text |
[STRING] changed the password because [STRING]. |
Variable fields |
$1: Username. $2: Reasons for changing the password. · Because it is the first login of the account. · Because the password had expired. · Because the password was too short. · Because the password was not complex enough. |
Severity level |
6 |
Example |
PWDCTL/6/CNAHGEPASSWORD: hhh changed the password because first login. |
Explanation |
The user changed the password for some reason, for example, for the first login. |
FAILEDTOWRITEPWD
Message text |
Variable fields |
N/A |
Severity level |
6 |
Example |
PWDCTL/6/FAILEDTOWRITEPWD: Failed to write the password records to file. |
Explanation |
The device failed to write a password to a file. |
1. Check the file system of the device for memory space insufficiency. 2. If the problem persists, contact H3C Support. |
QoS messages
This section contains QoS messages.
QOS_CBWFQ_REMOVED
Message text |
CBWFQ is removed from [STRING]. |
Variable fields |
Severity level |
3 |
Example |
QOS/3/QOS_CBWFQ_REMOVED: CBWFQ is removed from GigabitEthernet4/0/1. |
Explanation |
CBWFQ was removed from an interface because the maximum bandwidth or speed configured on the interface was below the bandwidth or speed required for CBWFQ. |
Increase the bandwidth or speed and apply the removed CBWFQ again. |
QOS_POLICY_APPLYCOPP_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: Slot number. $5: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_CBFAIL: Failed to apply classifier-behavior d in policy b to the inbound direction of control plane slot 3. No actions in behavior. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of a control plane. · Update a classifier-behavior association applied to a specific direction of a control plane. |
Configure actions for the behavior. |
QOS_POLICY_APPLYCOPP_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of control plane slot [UINT32]. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Slot number. $4: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYCOPP_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of control plane slot 3. Not supported by hardware. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of a control plane. · Update a QoS policy applied to a specific direction of a control plane. |
Modify the contents of the QoS policy. |
QOS_POLICY_APPLYGLOBAL_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction globally. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYGLOBAL_CBFAIL: Failed to apply classifier-behavior a in policy b to the outbound direction globally. No actions in behavior. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction globally. · Update a classifier-behavior association applied to a specific direction globally. |
QOS_POLICY_APPLYGLOBAL_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction globally. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Cause. |
Severity level |
4 |
Example |
QOS/4/ QOS_POLICY_APPLYGLOBAL_FAIL: Failed to apply or refresh QoS policy b to the inbound direction globally. Not supported by hardware. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction globally. · Update a QoS policy applied to a specific direction globally. |
QOS_POLICY_APPLYIF_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: Interface name. $5: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of interface Ethernet3/1/2. No actions in behavior. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of an interface. · Update a classifier-behavior association applied to a specific direction of an interface. |
QOS_POLICY_APPLYIF_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of interface [STRING]. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: Interface name. $4: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYIF_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of interface Ethernet3/1/2. Not supported by hardware. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of an interface. · Update a QoS policy applied to a specific direction of an interface. |
QOS_POLICY_APPLYVLAN_CBFAIL
Message text |
Failed to apply classifier-behavior [STRING] in policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
Variable fields |
$1: Name of a classifier-behavior association. $2: Policy name. $3: Traffic direction. $4: VLAN ID. $5: Cause. |
Severity level |
4 |
Example |
QOS/4QOS_POLICY_APPLYVLAN_CBFAIL: Failed to apply classifier-behavior b in policy b to the inbound direction of VLAN 2. No actions in behavior. |
Explanation |
The system failed to perform one of the following actions: · Apply a classifier-behavior association to a specific direction of a VLAN. · Update a classifier-behavior association applied to a specific direction of a VLAN. |
QOS_POLICY_APPLYVLAN_FAIL
Message text |
Failed to apply or refresh QoS policy [STRING] to the [STRING] direction of VLAN [UINT32]. [STRING]. |
Variable fields |
$1: Policy name. $2: Traffic direction. $3: VLAN ID. $4: Cause. |
Severity level |
4 |
Example |
QOS/4/QOS_POLICY_APPLYVLAN_FAIL: Failed to apply or refresh QoS policy b to the inbound direction of VLAN 2. Not supported by hardware. |
Explanation |
The system failed to perform one of the following actions: · Apply a QoS policy to a specific direction of a VLAN. · Update a QoS policy applied to a specific direction of a VLAN. |
QOS_NOT_ENOUGH_BANDWIDTH
Message text |
Policy [STRING] requested bandwidth [UINT32](kbps). Only [UINT32](kbps) is available on [STRING]. |
Variable fields |
$1: Policy name. $2: Required bandwidth for CBWFQ. $3: Available bandwidth on an interface. $4: Interface name. |
Severity level |
3 |
Example |
QOS/3/QOS_NOT_ENOUGH_BANDWIDTH: Policy d requested bandwidth 10000(kbps). Only 80(kbps) is available on GigabitEthernet4/0/1. |
Explanation |
Configuring CBWFQ on an interface failed because the maximum bandwidth on the interface was less than the bandwidth required for CBWFQ. |
Increase the maximum bandwidth configured for the interface or set lower bandwidth required for CBWFQ. |
RADIUS messages
This section contains RADIUS messages.
RADIUS_AUTH_FAILURE
Message text |
User [STRING] from [STRING] failed authentication. |
Variable fields |
Severity level |
5 |
Example |
RADIUS/5/RADIUS_AUTH_FAILURE: User abc@system from 192.168.0.22 failed authentication. |
Explanation |
An authentication request was rejected by the RADIUS server. |
RADIUS_AUTH_SUCCESS
Message text |
Variable fields |
Severity level |
6 |
Example |
RADIUS/6/RADIUS_AUTH_SUCCESS: User abc@system from 192.168.0.22 was authenticated successfully. |
Explanation |
An authentication request was accepted by the RADIUS server. |
RADIUS_DELETE_HOST_FAIL
Message text |
Failed to delete servers in scheme [STRING]. |
Variable fields |
$1: Scheme name. |
Severity level |
4 |
Example |
RADIUS/4/RADIUS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc. |
Explanation |
Failed to delete servers from a RADIUS scheme. |
RIP messages
This section contains RIP messages.
RIP_MEM_ALERT
Message text |
RIP Process receive system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
RIP/5/RIP_MEM_ALERT: RIP Process receive system memory alert start event. |
Explanation |
RIP received a memory alarm. |
RIP_RT_LMT
Message text |
RIP [UINT32] Route limit reached |
Variable fields |
$1: Process ID. |
Severity level |
6 |
Example |
RIP/6/RIP_RT_LMT: RIP 1 Route limit reached. |
Explanation |
The number of routes of a RIP process reached the upper limit. |
RIPNG messages
This section contains RIPng messages.
RIPNG_MEM_ALERT
Message text |
RIPNG Process receive system memory alert [STRING] event. |
Variable fields |
Severity level |
5 |
Example |
RIPNG/5/RIPNG_MEM_ALERT: RIPNG Process receive system memory alert start event. |
Explanation |
RIPng received a memory alarm. |
RIPNG_RT_LMT
Message text |
RIPng [UINT32] Route limit reached |
Variable fields |
$1: Process ID |
Severity level |
6 |
Example |
RIPNG/6/RIPNG_RT_LMT: RIPng 1 Route limit reached. |
Explanation |
The number of routes of a RIPng process reached the upper limit. |
RM messages
This section contains RM messages.
RM_ACRT_REACH_LIMIT
Message text |
Max active [STRING] routes [UINT32] reached in URT of [STRING] |
Variable fields |
$1: IPv4 or IPv6. $2: Maximum number of active routes. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_ROUTE_REACH_LIMIT: Max active IPv4 routes 100000 reached in URT of VPN1 |
Explanation |
The number of active routes reached the upper limit in the unicast routing table of a VPN instance. |
Remove unused active routes. |
RM_ACRT_REACH_THRESVALUE
Message text |
Threshold value [UINT32] of max active [STRING] routes reached in URT of [STRING] |
Variable fields |
$1: Threshold of the maximum number of active routes in percentage. $2: IPv4 or IPv6. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_ACRT_REACH_THRESVALUE: Threshold value 50% of max active IPv4 routes reached in URT of vpn1 |
Explanation |
The percentage of the maximum number of active routes was reached in the unicast routing table of a VPN instance. |
Modify the threshold value or the route limit configuration. |
RM_THRESHLD_VALUE_REACH
Message text |
Threshold value [UINT32] of active [STRING] routes reached in URT of [STRING] |
Variable fields |
$1: Maximum number of active routes. $2: IPv4 or IPv6. $3: VPN instance name. |
Severity level |
4 |
Example |
RM/4/RM_THRESHLD_VALUE_REACH: Threshold value 10000 of active IPv4 routes reached in URT of vpn1 |
Explanation |
The number of active routes reached the threshold in the unicast routing table of a VPN instance. |
SCM messages
This section contains SCM messages.
JOBINFO
Message text |
The service [STRING] is[STRING]... |
Variable fields |
$1: Service name. $2: State of the service. |
Severity level |
6 |
Example |
SCM/6/JOBINFO: The service DEV is starting... |
Explanation |
The system is starting, or a user is managing the service. |
RECV_DUPLICATEEVENT
Message text |
The service [STRING] receives a duplicate event in status [STRING], ignore it. |
Variable fields |
$1: Service name. $2: Service state. |
Severity level |
5 |
Example |
The service DEV set status stopping (Must be starting), Ignore. |
Explanation |
A service received a duplicate event in the same state. |
SERVICE_RESTART
Message text |
Standby service [STRING] in [STRING] failed to become the active service and restarted because of incomplete synchronization. |
Variable fields |
$1: Service name. $2: Card location. |
Severity level |
4 |
Example |
SCM/4/SERVICE_RESTART: Standby service ospf in slot 0 failed to become the active service and restarted because of incomplete synchronization. |
Explanation |
The active service abnormally stopped when the standby service did not complete synchronization to the active service. |
SERVICE_STATEERROR
Message text |
The service [STRING] receives an error event in status [STRING], drop it. |
Variable fields |
Severity level |
5 |
Example |
SCM/5/SERVICE_STATEERROR: The service DEV receives an error event in status starting, drop it. |
Explanation |
A service received an error event in a specific state. |
SERVICE_STATUSFAILED
Message text |
The service %s status failed : no response! |
Variable fields |
$1: Service name. |
Severity level |
5 |
Example |
SCM/5/SERVICE_STATUSFAILED: The service DEV status failed : no response! |
Explanation |
A service failed. |
SET_WRONGSTATUS
Message text |
The service [STRING] set status [STRING] (Must be [STRING]), Ignore. |
Variable fields |
$1: Service name. $2: Service state. $3: Service state. |
Severity level |
5 |
Example |
SCM/5/SET_WRONGSTATUS: The service DEV receives a duplicate event in status starting, ignore it. |
Explanation |
A service received an event in an incorrect state. |
SCRLSP messages
This section contains static CRLSP messages.
SCRLSP_LABEL_DUPLICATE
Message text |
Incoming label [INT32] for static CRLSP [STRING] is duplicate. |
Variable fields |
$1: Incoming label value. $2: Static CRLSP name. |
Severity level |
4 |
Example |
SCRLSP/4/SCRLSP_LABEL_DUPLICATE: Incoming label 1024 for static CRLSP aaa is duplicate. |
Explanation |
The incoming label of a static CRLSP was used by a static PW or by a static LSP. This message is generated when one of the following occurs: · When MPLS is enabled, configure a static CRLSP with the same incoming label as an existing static PW or static LSP. · Enable MPLS when a static CRLSP has the same incoming label as an existing static PW or static LSP. |
Remove this static CRLSP, and reconfigure it with another incoming label. |
SHELL messages
This section contains shell messages.
SHELL_CMD
Message text |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command is [STRING] |
Variable fields |
$1: Line name. If there is not a line name, '**' is displayed. $2: IP address. If there is not an IP address, '**' is displayed. $3: Username. If there is not a username, '**' is displayed. $4: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD: -Line=aux0-IPAddr=**-User=**; Command is quit |
Explanation |
A command was executed successfully. |
SHELL_CMD_CONFIRM
Message text |
Confirm option of command [STRING] is [STRING]. |
Variable fields |
$1: Command string. $2: Confirm option: · yes—The user confirmed the operation. · no—The user denied the operation. · timeout—The user did not confirm or deny the operation before the timeout timer expired. · cancel—The user pressed Ctrl+C to abort the operation. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_CONFIRM: Confirm option of command save is no. |
Explanation |
This message indicates the confirmation option that the user selected for the command. |
SHELL_CMD_EXECUTEFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be executed. |
Variable fields |
$1: Username. $2: IP address. $3: Command string. $4: Command view. |
Severity level |
4 |
Example |
SHELL/4/SHELL_CMD_EXECUTEFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be executed. |
Explanation |
The command failed to be executed. |
1. Verify that the command does not conflict with a configured feature. 2. If the problem persists, contact H3C Support. |
SHELL_CMD_INPUT
Message text |
Input string for the [STRING] command is [STRING]. |
Variable fields |
$1: Command string. $2: Input string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_INPUT: Input string for the save command is startup.cfg. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is CTRL_C. SHELL/6/SHELL_CMD_INPUT: Input string for the save command is the Enter key. |
Explanation |
An interactive command was executed and the user interacted with the command. |
SHELL_CMD_INPUT_TIMEOUT
Message text |
Operation timed out: Getting input for the [STRING] command. |
Variable fields |
$1: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMD_INPUT_TIMEOUT: Operation timed out: Getting input for the fdisk command. |
Explanation |
An interactive command was executed but the user did not interact with the command before timeout timer expired. |
SHELL_CMD_MATCHFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command [STRING] in view [STRING] failed to be matched. |
Variable fields |
Severity level |
4 |
Example |
SHELL/4/SHELL_CMD_MATCHFAIL: -User=**-IPAddr=192.168.62.138; Command description 10 in view system failed to be matched. |
Explanation |
The command string has errors, or the view does not support the command. |
1. Check whether the view supports the command. 2. Verify that you enter the correct command string. 3. If the problem persists, contact H3C Support. |
SHELL_CMDDENY
Message text |
-Line=[STRING]-IPAddr=[STRING]-User=[STRING]; Command [STRING] is permission denied. |
Variable fields |
Severity level |
5 |
Example |
SHELL/5/SHELL_CMDDENY: -Line=vty0-IPAddr=192.168.62.138-User=**; Command vlan 10 is permission denied. |
Explanation |
A command was not executed because the user did not have the right to use the command. |
SHELL_CMDFAIL
Message text |
Command [STRING] fails to recover configuration. |
Variable fields |
Severity level |
6 |
Example |
SHELL/6/SHELL_CMDFAIL: Command display this fails to recover configuration. |
Explanation |
The configuration restore operation failed. |
SHELL_CRITICAL_CMDFAIL
Message text |
-User=[STRING]-IPAddr=[STRING]; Command is [STRING] . |
Variable fields |
$1: Username. $2: IP address. $3: Command string. |
Severity level |
6 |
Example |
SHELL/6/SHELL_CRITICAL_CMDFAIL: -User=admin-IPAddr=169.254.0.7; Command is save. |
Explanation |
A command failed to be executed or was canceled. |
SHELL_LOGIN
Message text |
[STRING] login from [STRING]. |
Variable fields |
$1: Username. $2: Line name. |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGIN: Console logged in from console0. |
Explanation |
A user logged in. |
SHELL_LOGOUT
Message text |
[STRING] logout from [STRING]. |
Variable fields |
Severity level |
5 |
Example |
SHELL/5/SHELL_LOGOUT: Console logged out from console0. |
Explanation |
A user logged out. |
SLSP messages
This section contains static LSP messages.
SLSP_LABEL_DUPLICATE
Message text |
Incoming label [INT32] for static LSP [STRING] is duplicate. |
Variable fields |
$1: Incoming label value. $2: Static LSP name. |
Severity level |
4 |
Example |
SLSP/4/SLSP_LABEL_DUPLICATE: Incoming label 1024 for static LSP aaa is duplicate. |
Explanation |
The incoming label of a static LSP was used by a static PW or by a static CRLSP. This message is generated when one of the following occurs: · When MPLS is enabled, configure a static LSP with the same incoming label as an existing static CRLSP or static PW. · Enable MPLS when a static LSP has the same incoming label as an existing static CRLSP or static PW. |
Remove this static LSP, and reconfigure it with another incoming label. |
SMLK messages
This section contains Smart Link messages.
SMLK_LINK_SWITCH
Message text |
Status of port [STRING] in smart link group [UINT16] changes to active. |
Variable fields |
$1: Port name. $2: Smart link group ID. |
Severity level |
4 |
Example |
SMLK/4/SMLK_LINK_SWITCH: Status of port GigabitEthernet0/1/4 in smart link group 1 changes to active. |
Explanation |
The port took over to forward traffic after the former primary port failed. |
Remove the network faults. |
SNMP messages
This section contains SNMP messages.
SNMP_ACL_RESTRICTION
Message text |
SNMP [STRING] from [STRING] is rejected due to ACL restriction. |
Variable fields |
$1: SNMP community/usm-user/group. $2: IP address of the NMS. |
Severity level |
3 |
Example |
SNMP/3/SNMP_ACL_RESTRICTION: SNMP community public from 192.168.1.100 is rejected due to ACL restrictions. |
Explanation |
A syslog is printed if SNMP packets are denied because of ACL restrictions. |
Check the ACL configuration on the SNMP agent, and check if the agent was attacked. |
SNMP_GET
Message text |
-seqNO=[UINT32]-srcIP=[STRING]-op=GET-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: Sequence number of an SNMP operation log. $2: IP address of the NMS. $3: MIB object name and OID. $4: Value field of the request packet. |
Severity level |
6 |
Example |
SNMP/6/SNMP_GET: -seqNO=1-srcIP=192.168.28.28-op=GET-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=; The agent received a message. |
Explanation |
SNMP received a Get request from an NMS. The system logs SNMP operations only when SNMP logging is enabled. |
SNMP_NOTIFY
Message text |
Notification [STRING] [STRING]. |
Variable fields |
$1: Notification name. $2: The variable-binding filed of notifications. If no variable-binding exists, the OID becomes a null value. |
Severity level |
6 |
Example |
SNMP/6/SNMP_NOTIFY: Notification hh3cLogIn(1.3.6.1.4.1.25506.2.2.1.1.3.0.1) with hh3cTerminalUserName(1.3.6.1.4.1.25506.2.2.1.1.2.1.0)=;hh3cTerminalSource(1.3.6.1.4.1.25506.2.2.1.1.2.2.0)=Console. |
Explanation |
The SNMP agent sent a notification. This message displays the notification content. |
SNMP_SET
Message text |
-seqNO=[UINT32]-srcIP=[STRING]-op=SET-errorIndex=[UINT32]-errorStatus=[STRING]-node=[STRING]-value=[STRING]; The agent received a message. |
Variable fields |
$1: Sequence number of an SNMP operation log. $2: IP address of the NMS. $3: Error index of the Set operation. $4: Error status of the Set operation. $5: MIB object name and OID. $6: Value of the MIB object changed by the Set operation. |
Severity level |
6 |
Example |
SNMP/6/SNMP_SET: -seqNO=3-srcIP=192.168.28.28-op=SET-errorIndex=0-errorStatus=noError-node=sysLocation(1.3.6.1.2.1.1.6.0)-value=Hangzhou China; The agent received a message. |
Explanation |
SNMP received a Set request from an NMS. The system logs SNMP operations only when SNMP logging is enabled. |
SNMP_USM_NOTINTIMEWINDOW
Message text |
-User=[STRING]-IPAddr=[STRING]; SNMPv3 message is not in time window. |
Variable fields |
$1: Username. $2: IP address. |
Severity level |
4 |
Example |
SNMP/4/SNMP_USM_NOTINTIMEWINDOW: -User=admin-IPAddr=169.254.0.7; SNMPv3 message is not in time window. |
Explanation |
The SNMPv3 message is not in the time window. |
SNMP_AUTHENTICATION_FAILURE
Message text |
Failed to authenticate SNMP message. |
Variable fields |
N/A |
Severity level |
4 |
Example |
SNMP/4/SNMP_AUTHENTICATION_FAILURE: Failed to authenticate SNMP message. |
Explanation |
The SNMP agent failed to authenticate an NMS because the community name or username is not the same on the agent and NMS. |
Verify that an NMS and an SNMP agent use the same community name or username. For SNMPv3, the authentication and privacy modes, and authentication and privacy keys must also be the same on the NMS and agent. |
SSHS messages
This section contains SSH server messages.
SSHS_ALGORITHM_MISMATCH
Message text |
SSH client [STRING] failed to log in because of [STRING] algorithm mismatch. |
Variable fields |
$1: IP address of the SSH client. $2: Type of the algorithm, including encryption, key exchange, MAC, and public key. |
Severity level |
6 |
Example |
SSHS/6/SSHS_ALGORITHM_MISMATCH: SSH client 192.168.30.117 failed to log in because of encryption algorithm mismatch. |
Explanation |
The SSH client and the SSH server used different algorithms. |
Check that the SSH client and the SSH server use the same algorithm. |
SSHS_AUTH_EXCEED_RETRY_TIMES
Message text |
SSH user [STRING] (IP: [STRING]) failed to log in, because the number of authentication attempts exceeded the upper limit. |
Variable fields |
$1: User name. $2: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_EXCEED_RETRY_TIMES: SSH user David (IP: 192.168.30.117) failed to log in, because the number of authentication attempts exceeded the upper limit. |
Explanation |
The number of authentication attempts by an SSH user reached the upper limit. |
Prompt the SSH user to use the correct login data to try again. |
SSHS_AUTH_FAIL
Message text |
SSH user [STRING] (IP: [STRING]) didn't pass public key authentication for [STRING]. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Failure reasons: · Wrong public key algorithm. · Wrong public key. · Wrong digital signature. |
Severity level |
5 |
Example |
SSHS/5/SSHS_AUTH_FAIL: SSH user David (IP: 192.168.30.117) didn't pass public key authentication for wrong public key algorithm. |
Explanation |
An SSH user failed the publickey authentication. |
Tell the SSH user to try to log in again. |
SSHS_AUTH_TIMEOUT
Message text |
Authentication timed out for [IPADDR]. |
Variable fields |
$1: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_AUTH_TIMEOUT: Authentication timed out for 1.1.1.1. |
Explanation |
The authentication timeout timer expired, and the SSH user failed the authentication. |
Make sure the SSH user enters the correct authentication information before the authentication timeout timer expires. |
SSHS_CONNECT
Message text |
SSH user [STRING] (IP: [STRING]) connected to the server successfully. |
Variable fields |
$1: Username. $2: IP address of the SSH client. |
Severity level |
6 |
Example |
SSHS/6/SSHS_CONNECT: SSH user David (IP: 192.168.30.117) connected to the server successfully. |
Explanation |
An SSH user logged in to the server successfully. |
SSHS_DECRYPT_FAIL
Message text |
The packet from [STRING] failed to be decrypted with [STRING]. |
Variable fields |
$1: IP address of the SSH client. $2: Encryption algorithm, such as AES256-CBC. |
Severity level |
5 |
Example |
SSHS/5/SSHS_DECRYPT_FAIL: The packet from 192.168.30.117 failed to be decrypted with aes256-cbc. |
Explanation |
A packet from an SSH client failed to be decrypted. |
SSHS_DISCONNECT
Message text |
SSH user [STRING] (IP: [STRING]) disconnected from the server. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_DISCONNECT: SSH user David (IP: 192.168.30.117) disconnected from the server. |
Explanation |
An SSH user logged out. |
SSHS_ENCRYPT_FAIL
Message text |
The packet to [STRING] failed to be encrypted with [STRING]. |
Variable fields |
$1: IP address of the SSH client. $2: Encryption algorithm, such as aes256-cbc. |
Severity level |
5 |
Example |
SSHS/5/SSHS_ENCRYPT_FAIL: The packet to 192.168.30.117 failed to be encrypted with aes256-cbc. |
Explanation |
A packet to an SSH client failed to be encrypted. |
SSHS_LOG
Message text |
Authentication failed for [STRING] from [STRING] port [INT32] ssh2. |
Variable fields |
$1: IP address of the SSH client. $2: Username. $3: Port number. |
Severity level |
6 |
Example |
SSHS/6/SSHS_LOG: Authentication failed for David from 140.1.1.46 port 16266 ssh2. |
Explanation |
An SSH user failed password authentication because the username or password was wrong. |
SSHS_MAC_ERROR
Message text |
SSH server received a packet with wrong message authentication code (MAC) from [STRING]. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_MAC_ERROR: SSH server received a packet with wrong message authentication code (MAC) from 192.168.30.117. |
Explanation |
The SSH server received a packet with a wrong MAC from a client. |
SSHS_REACH_SESSION_LIMIT
Message text |
SSH client [STRING] failed to log in, because the number of SSH sessions reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_REACH_SESSION_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of SSH sessions reached the upper limit. |
Explanation |
The number of SSH sessions reached the upper limit. |
SSHS_REACH_USER_LIMIT
Message text |
SSH client [STRING] failed to log in, because the number of users reached the upper limit. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_REACH_USER_LIMIT: SSH client 192.168.30.117 failed to log in, because the number of users reached the upper limit. |
Explanation |
The number of SSH users reached the upper limit. |
SSHS_SCP_OPER
Message text |
User [STRING] at [IPADDR] requested operation: [STRING]. |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Requested file operation: · get file "name"—Downloads the file name. · put file "name"—Uploads the file name. |
Severity level |
6 |
Example |
SSHS/6/SSHS_SCP_OPER: User user1 at 1.1.1.1 requested operation: put file " flash:/aa". |
Explanation |
The SCP sever received a file operation request from an SSH client. |
SSHS_SFTP_OPER
Message text |
Variable fields |
$1: Username. $2: IP address of the SSH client. $3: Requested operation on a file or directory: · open dir "path"—Opens the directory path. · open "file" (attribute code code) in MODE mode—Opens the file file with the attribute code code in Mode mode. · remove file "path"—Deletes the file path. · mkdir "path" (attribute code code)—Creates a new directory path with the attribute code code. · rmdir "path"—Deletes the directory path. · rename old "old-name" to new "new-name"—Changes the name of a file or folder from old-name to new-name. |
Severity level |
6 |
Example |
SSHS/6/SSHS_SFTP_OPER: User user1 at 1.1.1.1 requested operation: open dir "flash:/". |
Explanation |
The SFTP sever received an operation request from an SSH client. |
SSHS_VERSION_MISMATCH
Message text |
SSH client [STRING] failed to log in because of version mismatch. |
Variable fields |
Severity level |
6 |
Example |
SSHS/6/SSHS_VERSION_MISMATCH: SSH client 192.168.30.117 failed to log in because of version mismatch. |
Explanation |
The SSH client and the SSH server used different SSH versions. |
Check that the SSH client and the SSH server use the same SSH version. |
STAMGR messages
This section contains station management messages.
STAMGR_ADDBAC_INFO
Message text |
Add BAS AC [STRING]. |
Variable fields |
$1: MAC address of the BAS AC. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_ADDBAC_INFO: Add BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was connected to the master AC. |
Recommended action |
STAMGR_ADDSTA_INFO
Message text |
Add client [STRING]. |
Variable fields |
$1: MAC address of the client. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_ADDSTA_INFO: Add client 3ce5-a616-28cd. |
Explanation |
The client was connected to the BAS AC. |
STAMGR_DELBAC_INFO
Message text |
Delete BAS AC [STRING]. |
Variable fields |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_DELBAC_INFO: Delete BAS AC 3ce5-a616-28cd. |
Explanation |
The BAS AC was disconnected from the master AC. |
STAMGR_DELSTA_INFO
Message text |
Delete client [STRING]. |
Variable fields |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_DELSTA_INFO: Delete client 3ce5-a616-28cd. |
Explanation |
The client was disconnected from the BAS AC. |
STAMGR_STAIPCHANGE_INFO
Message text |
IP address of client [STRING] changed to [STRING]. |
Variable fields |
$1: MAC address of the client. $2: New IP address of the client. |
Severity level |
6 |
Example |
STAMGR/6/STAMGR_STAIPCHANGE_INFO: IP address of client 3ce5-a616-28cd changed to 4.4.4.4. |
Explanation |
The IP address of the client was updated. |
STM messages
This section contains IRF messages.
STM_AUTO_UPDATE
Message text |
Slot [UINT32] auto-update failed because [STRING]. |
Variable fields |
$1: Slot ID. $2: Failure reason. |
Severity level |
4 |
Example |
STM/4/STM_AUTO_UPDATE: Slot 5 auto-update failed because incompatible software version. |
Explanation |
Software synchronization from the master failed on a slot. |
Upgrade software manually for the device to join the IRF fabric. |
STM_MEMBERID_CONFLICT
Message text |
Self member-id is changed from [UINT32] to [UINT32]. |
Variable fields |
$1: Old member ID. $2: New member ID. |
Severity level |
4 |
Example |
STM/4/STM_MEMBERID_CONFLICT: Self member-id changed from 1 to 4. |
Explanation |
The device's member ID changed. |
No action is required. |
STM_MERGE
Message text |
Merge occurs. This IRF need NOT be rebooted. |
Variable fields |
N/A |
Severity level |
5 |
Example |
STM/5/STM_MERGE: Merge occurs. This IRF need NOT be rebooted. |
Explanation |
You do not need to reboot the current IRF fabric for IRF merge, because it was elected the master. |
STM_MERGE_NEED_REBOOT
Message text |
Merge occurs. This IRF need be rebooted. |
Variable fields |
N/A |
Severity level |
4 |
Example |
STM/4/STM_MERGE_NEED_REBOOT: Merge occurs. This IRF need be rebooted. |
Explanation |
You must reboot the current IRF fabric for IRF merge, because it failed in the master election. |
STM_LINK_RECOVERY
Message text |
Merge occurs. |
Variable fields |
N/A |
Severity level |
4 |
Example |
STM/4/STM_LINK_RECOVERY: Merge occurs. |
Explanation |
IRF merge occurred. |
STM_LINK_STATUS_DOWN
Message text |
IRF port [UINT32] is down. |
Variable fields |
$1: IRF port name. |
Severity level |
3 |
Example |
STM/3/STM_LINK_STATUS_DOWN: IRF port 2 is down. |
Explanation |
The IRF port went down. This event occurs when all physical ports bound to an IRF port are down. |
Check the physical ports bound to the IRF port. Make sure at least one member physical port is up. |
STM_LINK_STATUS_TIMEOUT
Message text |
IRF port [UINT32] is down because heartbeat timed out. |
Variable fields |
Severity level |
2 |
Example |
STM/2/STM_LINK_STATUS_TIMEOUT: IRF port 1 is down because heartbeat timed out. |
Explanation |
The IRF port went down because of heartbeat timeout. |
Check the IRF link for link failure. |
STM_LINK_STATUS_UP
Message text |
IRF port [UINT32] is up. |
Variable fields |
Severity level |
6 |
Example |
STM/6/STM_LINK_STATUS_UP: IRF port 1 is up. |
Explanation |
An IRF port came up. |
STM_SOMER_CHECK
Message text |
Neighbor of IRF port [UINT32] can't be stacked. |
Variable fields |
Severity level |
3 |
Example |
STM/3/STM_SOMER_CHECK: Neighbor of IRF port 1 can't be stacked. |
Explanation |
The neighbor connected to the IRF port cannot form an IRF fabric with the device. |
1. Check the following items: 2. The device models can form an IRF fabric. 3. The IRF settings are correct. For more information, see the IRF configuration guide for the device. 4. If the problem persists, contact H3C Support. |
SYSLOG messages
This section contains syslog messages.
SYSLOG_LOGFILE_FULL
Message text |
Log file space is full. |
Variable fields |
N/A |
Severity level |
4 |
Example |
SYSLOG/4/SYSLOG_LOGFILE_FULL: Log file space is full. |
Explanation |
The log file space is full. |
Back up the log file, delete the original log file, and then bring up interfaces if needed. |
SYSLOG_RESTART
Message text |
System restarted -- [STRING] [STRING] Software. |
Variable fields |
$1: Company name. Available options include H3C and H3C. $2: Software name. Available options include Comware and Router. |
Severity level |
6 |
Example |
SYSLOG/6/SYSLOG_RESTART: System restarted -- H3C Comware Software |
Explanation |
A system restart log was created. |
TACACS messages
This section contains TACACS messages.
TACACS_AUTH_FAILURE
Message text |
Variable fields |
$1: User name. $2: IP address. |
Severity level |
5 |
Example |
TACACS/5/TACACS_AUTH_FAILURE: User cwf@system from 192.168.0.22 failed authentication. |
Explanation |
An authentication request was rejected by the TACACS server. |
TACACS_AUTH_SUCCESS
Message text |
User [STRING] from [STRING] was authenticated successfully. |
Variable fields |
Severity level |
6 |
Example |
TACACS/6/TACACS_AUTH_SUCCESS: User cwf@system from 192.168.0.22 was authenticated successfully. |
Explanation |
An authentication request was accepted by the TACACS server. |
TACACS_DELETE_HOST_FAIL
Message text |
Variable fields |
$1: Scheme name. |
Severity level |
4 |
Example |
TACACS/4/TACACS_DELETE_HOST_FAIL: Failed to delete servers in scheme abc. |
Explanation |
Failed to delete servers from a TACACS scheme. |
TELNETD messages
This section contains Telnet messages.
TELNETD_REACH_SESSION_LIMIT
Message text |
Telnet client [IPADDR] failed to log in. Number of Telnet sessions reached the limit. |
Variable fields |
$1: IP address of a Telnet client. |
Severity level |
6 |
Example |
TELNETD/6/TELNETD_REACH_SESSION_LIMIT:Telent client 1.1.1.1 failed to log in. Number of Telnet sessions reached the limit. |
Explanation |
Number of online Telnet users already reached the limit. |
TRILL messages
This section contains TRILL messages.
TRILL_DUP_SYSTEMID
Message text |
Duplicate system ID [STRING] in [STRING] PDU sourced from RBridge 0x[HEX]. |
Variable fields |
$1: System ID. $2: PDU type. $3: Source RBridge's nickname. |
Severity level |
5 |
Example |
TRILL/5/TRILL_DUP_SYSTEMID: Duplicate system ID 0011.2200.1501 in LSP PDU sourced from RBridge 0xc758. |
Explanation |
The local RBridge received an LSP or IIH PDU that has the same system ID as the local RBridge. The possible reasons include: · The same system ID is assigned to the local RBridge and the remote RBridge. · The local RBridge received a self-generated LSP PDU with an old nickname. |
Please check the RBridge system IDs on the campus network. |
TRILL_INTF_CAPABILITY
Message text |
The interface [STRING] does not support TRILL. |
Variable fields |
$1: Interface name. |
Severity level |
4 |
Example |
TRILL/4/TRILL_INTF_CAPABILITY: The interface GigabitEthernet0/1/3 does not support TRILL. |
Explanation |
An interface that does not support TRILL was assigned to a link aggregation group. |
Remove the interface that does not support TRILL from the link aggregation group. |
TRILL_INTF ENTERED_SUSPENDED
Message text |
Interface [STRING] entered the suspended state. |
Variable fields |
Severity level |
4 |
Example |
TRILL/4/TRILL_INTF_ENTERED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 entered the suspended state. |
Explanation |
The RB put a TRILL port to the suspended state. The message is sent in any of the following situations: · The TRILL port is on the same broadcast network as a high-priority TRILL port of the RB. · Loops exist on the TRILL port. |
To resolve the problem, perform the following tasks: · Remove redundant TRILL ports of the RB from the broadcast network. · Eliminate the loops on the TRILL port. |
TRILL_INTF EXITED_SUSPENDED
Message text |
Interface [STRING] exited the suspended state. |
Variable fields |
Severity level |
4 |
Example |
TRILL/4/TRILL_INTF_EXITED_SUSPENDED: Interface Ten-GigabitEthernet1/0/1 exited the suspended state. |
Explanation |
A TRILL port exited the suspended state. The message is sent in any of the following situations: · Redundant TRILL ports of the RB are removed from the broadcast network that is connected to the TRILL port. · Loops are eliminated from the TRILL port. |
TRILL_LICENSE_UNAVAILABLE
Message text |
The TRILL feature is being disabled, because it has no license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
TRILL/5/TRILL_LICENSE_UNAVAILABLE: The TRILL feature is being disabled, because it has no license. |
Explanation |
The TRILL license has been invalidated. |
Check the TRILL license. |
Message text |
The feature TRILL has no available license. |
Variable fields |
N/A |
Severity level |
5 |
Example |
TRILL/5/TRILL_LICENSE_UNAVAILABLE: The feature TRILL has no available license. |
Explanation |
No license is found for TRILL. |
Message text |
Variable fields |
N/A |
Severity level |
3 |
Example |
TRILL/3/TRILL_LICENSE_UNAVAILABLE: No license is found for TRILL. |
Explanation |
Install a license for TRILL. |
TRILL_LICENSE_EXPIRED
Message text |
TRILL is unavailable because its license has expired. |
Variable fields |
N/A |
Severity level |
3 |
Example |
TRILL/3/TRILL_LICENSE_EXPIRED: TRILL is unavailable because its license has expired. |
Explanation |
The TRILL license has expired. |
Install a valid license for TRILL. |
TRILL_LICENSE_EXPIRED_TIME
Message text |
TRILL will become unavailable in [ULONG] days. |
Variable fields |
$1:Available period of the feature. |
Severity level |
5 |
Example |
TRILL/5/TRILL_LICENSE_EXPIRED_TIME: TRILL will become unavailable in 2 days. |
Explanation |
TRILL will be disabled because the TRILL license has expired. You can use TRILL for 30 days after the license is expired. |
Install a new license. |
TRILL_MEM_ALERT
Message text |
TRILL process receive system memory alert [STRING] event. |
Variable fields |
$1: Type of the memory alert event. |
Severity level |
5 |
Example |
TRILL/5/TRILL_MEM_ALERT: TRILL process receive system memory alert start event. |
Explanation |
TRILL received a memory alert event from the system. |
Check the system memory. |
TRILL_NBR_CHG
Message text |
TRILL [UINT32], [STRING] adjacency [STRING] ([STRING]), state change to: [STRING]. |
Variable fields |
$1: TRILL process ID. $2: Neighbor level. $3: Neighbor system ID. $4: Interface name. $5: Current neighbor state. |
Severity level |
5 |
Example |
TRILL/5/TRILL_NBR_CHG: TRILL 1, Level-1 adjacency 0011.2200.1501 (GigabitEthernet0/1/3), state change to: down. |
Explanation |
The state of a TRILL neighbor changed. |
When the neighbor state changes to down or initializing, please check the TRILL configuration and network status according to the reason for the neighbor state change. |
VLAN messages
This section contains VLAN messages.
VLAN_FAILED
Message text |
Failed to add interface [STRING] to the default VLAN. |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_FAILED: Failed to add interface S-Channel 4/2/0/19:100 to the default VLAN. |
Explanation |
An S-channel interface was created when hardware resources were insufficient. The S-channel interface failed to be assigned to the default VLAN. |
VLAN_VLANMAPPING_FAILED
Message text |
The configuration failed because of resource insufficiency or conflicts on [STRING]. |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_VLANMAPPING_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
Explanation |
Part of or all VLAN mapping configurations on the interface were lost because of one of the following occurrences: · Hardware resources were insufficient for the interface. · The interface joined or left a Layer 2 aggregation group. |
VLAN_VLANTRANSPARENT_FAILED
Message text |
Variable fields |
Severity level |
4 |
Example |
VLAN/4/VLAN_VLANTRANSPARENT_FAILED: The configuration failed because of resource insufficiency or conflicts on Ethernet0/0. |
Explanation |
Part of or all VLAN transparent transmission configurations on the interface were lost because of one of the following occurrences: · Hardware resources were insufficient for the interface. · The interface joined or left a Layer 2 aggregation group. |
VRRP messages
This section contains VRRP messages.
VRRP_AUTH_FAILED
Message text |
Authentication failed in [STRING] virtual router [UINT32] (configured on [STRING]): [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: Error information details. |
Severity level |
6 |
Example |
VRRP/6/VRRP_AUTH_FAILED: Authentication failed in IPv4 virtual router 10 (configured on Ethernet0/0): authentication type mismatch. |
Explanation |
A VRRP packet was received, but did not pass the authentication examination. |
Check the configuration of the VRRP group on the specified interface. Make sure every router in the VRRP group uses the same authentication mode and authentication key. |
VRRP_CONFIG_ERROR
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) detected a VRRP configuration error: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where VRRP group is configured. $4: Error information details. |
Severity level |
6 |
Example |
VRRP/6/VRRP_CONFIG_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) detected a VRRP configuration error: VIRTUAL IP ADDRESS COUNT ERROR. |
Explanation |
The VRRP group configuration was not correct. For example, the virtual IP address count of the VRRP group was not the same on the members. |
Check the VRRP group configuration on the specified interface. Make sure every member in the VRRP group uses the same configuration. |
VRRP_PACKET_ERROR
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) received an error packet: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Interface where the VRRP group is configured. $4: Error information details. |
Severity level |
6 |
Example |
VRRP/6/VRRP_PACKET_ERROR: The IPv4 virtual router 10 (configured on Ethernet0/0) received an error packet: CKSUM ERROR. |
Explanation |
The VRRP group received an invalid VRRP packet. For example, the checksum was not correct. |
Check the VRRP group configuration on the specified interface. |
VRRP_STATUS_CHANGE
Message text |
The status of [STRING] virtual router [UINT32] (configured on [STRING]) changed from [STRING] to [STRING]: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: Original status. $5: Current status. $6: Reason for status change. |
Severity level |
6 |
Example |
VRRP/6/VRRP_STATUS_CHANGE: The status of IPv4 virtual router 10 (configured on Ethernet0/0) changed (from Backup to Master): Timer expired. |
Explanation |
The VRRP group status changed because the timer expired. |
Check the VRRP group status to make sure it is operating correctly. |
VRRP_VF_STATUS_CHANGE
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) virtual forwarder [UINT32] detected status change (from [STRING] to [STRING]): [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: VF ID. $5: Original status of VF. $6: Current status of VF. $7: Reason for the status change. |
Severity level |
6 |
Example |
VRRP/6/VRRP_VF_STATUS_CHANGE: The IPv4 virtual router 10 (configured on GigabitEthernet5/1) virtual forwarder 2 detected status change (from Active to Initialize): Weight changed. |
Explanation |
The status of the virtual forwarder changed because the weight changed, the timeout timer expired, or VRRP went down. |
Check the status of the track entry. |
VRRP_VMAC_INEFFECTIVE
Message text |
The [STRING] virtual router [UINT32] (configured on [STRING]) failed to add virtual MAC: [STRING]. |
Variable fields |
$1: VRRP version. $2: VRRP group number. $3: Name of the interface where the VRRP group is configured. $4: Reason for the error. |
Severity level |
3 |
Example |
VRRP/3/VRRP_VMAC_INEFFECTIVE: The IPv4 virtual router 10 (configured on Ethernet0/0) failed to add virtual MAC: Hardware resources insufficient. |
Explanation |
The virtual router failed to add a virtual MAC address. |
Find out the root cause for the operation failure and fix the problem. |
