- Released At: 15-01-2020
- Page Views:
- Downloads:
About the H3C S5560-EI command references
Command reference |
Content |
Fundamentals Command Reference |
Covers the commands for logging in to and setting up the switch. This command reference includes: · Basic CLI. · Login management. · RBAC. · FTP and TFTP. · File system management. · Configuration file management. · Software upgrade. · ISSU. · Device management. · Tcl. · Python. · License management. |
IRF Command Reference |
Covers the commands for configuring IRF and IRF 3.1. |
Layer 2—LAN Switching Command Reference |
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes: · Ethernet interface. · Loopback, null, and inloopback interfaces. · Bulk interface configuration. · MAC address table and MAC Information. · Ethernet link aggregation. · Port isolation. · Spanning tree. · Loop detection. · VLAN (including VLAN, super VLAN, private VLAN, and voice VLAN). · MVRP. · QinQ. · VLAN mapping. · LLDP. · L2PT. · Service loopback group. |
Layer 3—IP Services Command Reference |
Covers the commands for configuring IP addressing, IP performance optimization, ARP, IP forwarding basic, DHCP, DNS, UDP helper, IPv6 basics, DHCPv6 server, tunneling, and GRE. This command reference includes: · ARP (including gratuitous ARP, proxy ARP, and ARP snooping). · IP addressing. · DNS (including DDNS). · IP forwarding basics (including basic IP forwarding and load sharing). · Fast forwarding. · Adjacency table. · IRDP. · IP performance optimization. · UDP helper. · IPv6 fast forwarding. · HTTP redirect. |
Layer 3—IP Routing Command Reference |
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes. This command reference includes: · Basic IP routing. · Static routing. · RIP. · OSPF. · IS-IS. · BGP. · Policy-based routing. · IPv6 static routing. · RIPng. · OSPFv3. · IPv6 IS-IS. · IPv6 policy-based routing. · Routing policy. |
IP Multicast Command Reference |
Covers the commands for Layer 3 IPv4 multicast protocols (including IGMP, PIM, and MSDP), Layer 3 IPv6 multicast protocols (including MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (including IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (including MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This command reference includes: · IGMP snooping. · PIM snooping. · Multicast VLAN. · Multicast routing and forwarding. · IGMP. · PIM. · MSDP. · MLD snooping. · IPv6 multicast routing and forwarding. · MLD. · IPv6 PIM. |
MPLS Command Reference |
Covers the commands for configuring basic MPLS and extended MPLS functions. This command reference includes: · Basic MPLS. · LDP. · MPLS TE. · Static CRLSP. · RSVP. · Tunnel policy. · MPLS L3VPN and IPv6 MPLS L3VPN. · MPLS L2VPN. · VPLS. · MPLS OAM. · MCE and IPv6 MCE. |
ACL and QoS Command Reference |
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes: · ACL. · QoS (including QoS policy, priority mapping, GTS and rate limit, queue-based accounting, congestion management, per-port queue-based accounting, congestion avoidance, and aggregate CAR). · Data buffer. · Time range. · QCN. |
Security Command Reference |
Covers security feature commands. Available security features include identity authentication, secure management, and attack protection. This command reference includes: · AAA. · 802.1X. · MAC authentication. · Portal. · Web authentication. · Triple authentication. · Port security. · User profile. · Password control. · Keychain. · PKI. · IPsec and IKE. · SSH. · SSL. · Attack detection and prevention. · IP source guard. · ARP attack protection. · ND attack defense. · uRPF. · MFF. · FIPS. |
High Availability Command Reference |
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes: · Ethernet OAM. · CFD. · DLDP. · RRPP. · ERPS. · Smart Link. · Monitor Link. · VRRP. · BFD. · Track. |
Network Management and Monitoring Command Reference |
Covers the commands that help you manage and monitor your network, for example, manage system events, and test network connectivity. This command reference includes: · System maintenance and debugging (ping, tracert, and system debugging). · NQA. · NTP (including SNTP). · NETCONF. · CWMP. · EAA. · Process monitoring and maintenance. · Mirroring (including both port and flow mirroring). · Information center. · Packet capture. |
OpenFlow Command Reference |
Covers the commands for configuring OpenFlow. |
