12 Acronyms
HomeSupportSwitchesH3C S5500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5500-HI Switch Series Configuration Guides-Release 5101-6W10012 Acronyms
Download Book
Title Size Downloads
12 Acronyms-book.pdf 93.75 KB
H3C network technology acronyms
# A B C D E F G H I L M N O P Q R S T U V W X Z
A
Return
AAL5
ATM Adaptation Layer 5
ABR
Area Border Router
AC
Access Controller
AC
Access Category
ACCM
Async-Control-Character-Map
ACFC
Address-and-Control-Field-Compression
ACFP
Application Control Forwarding Protocol
ACL
Access Control List
ACS
Auto-Configuration Server
AD
Active Directory
ADPCM
Adaptive Differential Pulse Code Modulation
ADSL
Asymmetric Digital Subscriber Line
AES
Advanced Encryption Standard
AFT
Address Family Translation
AFTR
Address Family Transition Router
AH
Authentication Header
AIFSN
Arbitration Inter Frame Spacing Number
AIS
Alarm Indication Signal
ALG
Application Level Gateway
AM
Analog Modem
AMI
Alternate Mark Inversion
ANSI
American National Standard Institute
AP
Access Point
APP
Application Protocol
APPN
Advanced Peer-to-Peer Networking
ARP
Address Resolution Protocol
AS
Autonomous System
AS
Authentication Server
ASBR
Autonomous System Boundary Router
ASM
Any-Source Multicast
ASPF
Application Specific Packet Filter
ATD
Attribute Discovery
ATM
Asynchronous Transfer Mode
AU
Administration Unit
AV
Anti-Virus
AVF
Active Virtual Forwarder
AVP
Attribute Value Pair
B
Return
B8ZS
Bipolar 8 zeros substitution
BAS
Broadband Access Server
BC
Boundary Clock
BC
Bandwidth Constraint
BCB
Backbone Core Bridge
BDI
Backward Defect Indication
BDR
Backup Designated Router
BEB
Backbone Edge Bridge
BFD
Bidirectional Forwarding Detection
BGP
Border Gateway Protocol
BIMS
Branch Intelligent Management System
B-MAC
Backbone MAC
BMC
Best Master Clock
BOOTP
Bootstrap Protocol
BPDU
Bridge Protocol Data Unit
BQ
Bandwidth Queuing
BSB
Blockade State Block
BSR
Bootstrap Router
BSS
Basic Service Set
BT
BitTorrent
B-VLAN
Backbone VLAN
C
Return
CA
Certificate Authority
CAC
Connect Admission Control
CAMS
Comprehensive Access Management Server
CAPWAP
Controlling and Provisioning of Wireless Access Point
CAR
Committed Access Rate
CBQ
Class Based Queuing
CBR
Constant Bit Rate
CBS
Committed Burst Size
C-BSR
Candidate-BSR
CBT
Core-Based Tree
CBWFQ
Class Based Weighted Fair Queuing
CC
Continuity Check
CCC
Circuit Cross Connect
CCM
Continuity Check Message
CDP
Cisco Discovery Protocol
CE
Customer Edge
CEE
Converged Enhanced Ethernet
CEM Class
Circuit Emulation Class
CESOPSN
Circuit Emulation Services over PSN
CFD
Connectivity Fault Detection
CFI
Canonical Format Indicator
CFM
Connectivity Fault Management
CHAP
Challenge Handshake Authentication Protocol
CIDR
Classless Inter-Domain Routing
CIR
Committed Information Rate
CIST
Common and Internal Spanning Tree
CO
Central Office
COPS
Common Open Policy Service
CPE
Customer Premises Equipment
CPS
Certification Practice Statement
CPTone
Call Progress Tone
CR
Constraint-based Routing
CRC4
Cyclic Redundancy Check 4
CRL
Certificate Revocation List
CR-LDP
Constraint-based Routed Label Distribution Protocol
CR-LSP
Constraint-based Routed Label Switched Paths
C-RP
Candidate-RP
CSNP
Complete SNP
CSPF
Constraint-based Shortest Path First
CST
Common Spanning Tree
CT
Class Type
CTR
Counter mode
CV
Connectivity Verification
CWMP
CPE WAN Management Protocol
D
Return
DAD
Duplicate Address Detection
DAR
Deeper Application Recognition
DCBX
Data Center Bridging Exchange Protocol
DCC
Dial Control Center
DCE
Date Center Ethernet
DCE
Data Circuit-terminating Equipment
DCF
Distributed Coordination Function
DD
Database Description
DDN
Digital Data Network
DDNS
Dynamic Domain Name System
DDoS
Distributed Denial of Service
DER
Distinguished Encoding Rules
DF
Designated Forwarder
DH
Diffie-Hellman
DHCP
Dynamic Host Configuration Protocol
DHCPv6
Dynamic Host Configuration Protocol for IPv6
DiffServ
Differentiated Service
DLCI
Data Link Connection Identifier
DLDP
Device Link Detection Protocol
DLSw
Data Link Switching
DM
Dense Mode
DM
Delay Measurement
DMM
Delay Measurement Message
DMR
Delay Measurement Reply
DMZ
Demilitarized Zone
DN
Distinguished Name
DNAT
Destination NAT
DNS
Domain Name System
DoD
Downstream On Demand
DoS
Denial of Service
DPD
Dead Peer Detection
DR
Designated Router
DS
Differentiated Services
DSA
Digital Signature Algorithm
DSCP
Differentiated Services Codepoint
DS-lite
Dual Stack Lite
DTE
Data Terminal Equipment
DTMF
Dual Tone Multi-Frequency
DU
Downstream Unsolicited
DUID
DHCP Unique Identifier
DUID-LL
DUID Based on Link-layer Address
DVMRP
Distance Vector Multicast Routing Protocol
DVPN
Dynamic Virtual Private Network
DWDM
Dense Wavelength Division Multiplexing
E
Return
E2ETC
End-to-End Transparent Clock
EACL
Enhanced ACL
EAD
Endpoint Admission Defense
EAIS
Ethernet Alarm Indication Signal
EAP
Extensible Authentication Protocol
EAPOL
Extensible Authentication Protocol over LAN
EBS
Excess Burst Size
ECDSA
Elliptic Curve Digital Signature Algorithm
ECM
Error Correction Mode
ECWmax
Exponent form of CWmax
ECWmin
Exponent form of CWmin
EDCA
Enhanced Distributed Channel Access
EGP
Exterior Gateway Protocol
End-Of-RIB
End of Routing-Information-Base
ENUM
Telephone Number Mapping
ERT
Export Route-target
ESF
Extended Super Frame
ESP
Encapsulating Security Payload
ESS
Extended Service Set
ETS
Enhanced Transmission Selection
ETSI
European Telecommunications Standards Institute
F
Return
FC
Fibre Channel
FCoE
Fibre Channel over Ethernet
FEC
Forwarding Equivalence Class
FFD
Fast Failure Detection
FIB
Forwarding Information Base
FIFO
First In First Out
FIP
FCoE Initialization Protocol
FQDN
Fully Qualified Domain Name
FRR
Fast Reroute
FSK
Frequency Shift Keying
FTN
FEC to NHLFE map
FTP
File Transfer Protocol
G
Return
GARP
Generic Attribute Registration Protocol
GBIC
Gigabit Interface Converter
GI
Guard Interval
GNS
Get Nearest Server
GPS
Global Positioning System
GR
Graceful Restart
GRE
Generic Routing Encapsulation
GTK
Group Temporal Key
GTP
GPRS Tunneling Protocol
GTS
Generic Traffic Shaping
GTSM
Generalized TTL Security Mechanism
GVRP
GARP VLAN Registration Protocol
H
Return
HABP
HW Bypass Protocol
HDB3
High-density Bipolar 3
HDLC
High-level Data Link Control
HGMP
HW Group Management Protocol
HGMPv2
HW Group Management Protocol version 2
HQoS
Hierarchical Quality of Service
HTTP
Hypertext Transfer Protocol
HTTPS
Hypertext Transfer Protocol Secure
H-VPLS
Hierarchy of VPLS
HWTACACS
HW Terminal Access Controller Access Control System
I
Return
IA
Identity Association
IACTP
Inter Access Controller Tunneling Protocol
IAD
Integrated Access Device
IANA
Internet Assigned Numbers Authority
IBGP
Internal Border Gateway Protocol
ICMP
Internet Control Message Protocol
ICMPv6
Internet Control Message Protocol for IPv6
ICPIF
Calculated Planning Impairment Factor
ID
Direct Inward Dialing
IDS
Intrusion Detection System
IE
Information Element
IEEE
Institute of Electrical and Electronics Engineers
IETF
Internet Engineering Task Force
IGMP
Internet Group Management Protocol
IGMP Snooping
Internet Group Management Protocol Snooping
IGP
Interior Gateway Protocol
IKE
Internet Key Exchange
ILM
Incoming Label Map
ILS
Internet Locator Service
IM
Instant Messaging
IMA
Inverse Multiplexing for ATM
IMSI
International Mobile Subscriber Identification Number
InARP
Inverse Address Resolution Protocol
IntServ
Integrated Service
IPC
Inter-process Communication
IPHC
IP Header Compression
IPng
IP Next Generation
IPS
Intrusion Prevention System
IPsec
IP Security
IPTA
IP Terminal Access
IPv6
Internet Protocol Version 6
IPX
Internetwork Packet Exchange
IRDP
ICMP Router Discovery Protocol
IRF
Intelligent Resilient Framework
ISAKMP
Internet Security Association and Key Management Protocol
ISATAP
Intra-Site Automatic Tunnel Addressing Protocol
ISDN
Integrated Services Digital Network
I-SID
Backbone Service Instance Identifier
IS-IS
Intermediate System-to-Intermediate System
ISP
Internet Service Provider
ISPF
Incremental Shortest Path First
ISSU
In-Service Software Upgrade
IST
ITSP
Internet Telephone Service Provider
IVR
Interactive Voice Response
L
Return
L2F
Layer 2 Forwarding
L2TP
Layer 2 Tunneling Protocol
LAC
L2TP Access Concentrator
LACP
Link Aggregation Control Protocol
LACPDU
Link Aggregation Control Protocol Data Unit
LAN
Local Area Network
LB
Load Balance
LBM
Loopback Message
LBR
Loopback Reply
LC
Logic Channel
LCI
Logic Channel Identifier
LCP
Link Control Protocol
LDAP
Lightweight Directory Access Protocol
LDP
LER
Label Edge Router
LFI
Link Fragmentation and Interleaving
LFIB
Label Forwarding Information Base
LLDP
Link Layer Discovery Protocol
LLDPDU
Link Layer Discovery Protocol Data Unit
LLDP-MED
Media Endpoint Discovery
LLQ
Low Latency Queuing
LM
Loss Measurement
LMI
Local Management Interface
LMM
Loss Measurement Message
LMR
Loss Measurement Reply
LNS
L2TP Network Server
LOCV
Loss of Connectivity Verification defect
LR
Line Rate
LSA
Link State Advertisement
LSAck
Link State Acknowledgment
LSDB
Link State Database
LSP
Label Switched Path
LSR
Link State Request
LSR
Label Switching Router
LSU
Link State Update
LTM
Linktrace Message
LTR
Linktrace Reply
LVF
Listening Virtual Forwarder
M
Return
MA
Maintenance Association
MAC
Media Access Control
MAC
Message Authentication Code
MAD
Multi-Active Detection
MAM
Maximum Allocation Model
MAN
Metropolitan Area Network
MBGP
Multicast BGP
MCE
Multi-VPN-instance Customer Edge
MCS
Modulation and Coding Scheme
MD
Maintenance Domain
MD
Multicast Domain
MDI
Medium Dependent Interface
MEP
Maintenance association End Point
MIB
Management Information Base
MIC
Message Integrity Check
MIP
Maintenance association Intermediate Point
MLD
Multicast Listener Discovery Protocol
MLD Snooping
Multicast Listener Discovery Snooping
MLSP
Mobile Link Switch Protocol
MOS
Mean Opinion Scores
MP
Maintenance Point
MP-BGP
Multiprotocol Border Gateway Protocol
MPLS
Multiprotocol Label Switching
MPLS TE
Multiprotocol Label Switching Traffic Engineering
MPLS-TP
MPLS Transport Profile
MSDP
Multicast Source Discovery Protocol
MSTI
Multiple Spanning Tree Instance
MSTP
Multiple Spanning Tree Protocol
MTBF
Mean Time Between Failures
MTR
Multi-Topology Routing
MTTR
Mean Time to Repair
MTU
Maximum Transmission Unit
MU
Mobile Unit
N
Return
NAPT
Network Address Port Translation
NAPT-PT
Network Address Port Translation-Protocol Translation
NAS
Network Access Server
NAT
Network Address Translation
NAT-PT
Network Address Translation-Protocol Translation
NBMA
Non-Broadcast Multi-Access
NCP
Network Control Protocol
ND
Neighbor Discovery
NDA
NetStream Data Analyzer
NDE
NetStream Data Exporter
NDP
Neighbor Discover Protocol
NET
Network Entity Title
NETCONF
Network Configuration Protocol
NHLFE
Next Hop Label Forwarding Entry
NLPID
Network Layer Protocol Identifier
NLRI
Network Layer Reachability Information
NMS
Network Management System
NNI
Network-to-Network Interface
NQA
Network Quality Analyzer
nrt_VBR
Nonreal-time Variable Bit Rate
NSC
NetStream Collector
NSF
Non-Standard Facilities
NSR
Nonstop Routing
NTDP
Neighbor Topology Discover Protocol
NTP
Network Time Protocol
O
Return
OAA
Open Application Architecture
OAMPDU
OAM Protocol Data Units
OAP
Open Application Platform
OC
Optical Carrier
OC
Ordinary Clock
OID
Object Identifier
ORF
Outbound Route Filtering
OSPF
Open Shortest Path First
OUI
Organizationally Unique Identifier
P
Return
P2MP
Point-to-MultiPoint
P2P
Point-to-Point
P2P
Peer-to-Peer
P2P
PW to PW
P2P
Point to Point
P2PTC
Peer-to-Peer Transparent Clock
PAGP
Port Aggregation Protocol
PAM
Port to Application Map
PAP
Password Authentication Protocol
PAT
Port Address Translation
PBB
Provider Backbone Bridge
PBBN
Provider Backbone Bridge Network
PBN
Provider Bridge Network
PCM
PCR
Peak Cell Rate
PD
Powered Device
PD
Prefix Delegation
PDH
Plesiochronous Digital Hierarchy
PDP
Policy Decision Point
PDU
Protocol Data Unit
PE
Provider Edge
PE-agg
PE Aggregation
PEAP-GTC
Protected Extensible Authentication Protocol-Microsoft Generic Token Card
PEAP-MSCHAPv2
Protected Extensible Authentication Protocol-Microsoft Challenge Handshake Authentication Protocol v2
PEP
Policy Enforcement Point
PFC
Protocol-Field-Compression
PFC
Priority-based Flow Control
PFS
Perfect Forward Secrecy
PHP
Penultimate Hop Popping
PI
Power Interface
PIM
Protocol Independent Multicast
PIM Snooping
Protocol Independent Multicast Snooping
PKCS
Public Key Cryptography Standards
PKI
Public Key Infrastructure
PMK
Pairwise Master Key
PMTU
Path MTU
PoE
Power over Ethernet
POH
Path Overhead
POP3
Post Office Protocol, Version 3
POS
Point of Sale
PPP
Point-to-Point Protocol
PPPoE
Point-to-Point Protocol over Ethernet
PPTP
Point-to-Point Tunneling Protocol
PRL
Preferred Roming List
PS
Protection Switching
PSB
Path State Block
PSC
Protection State Coordination
PSE
Power Sourcing Equipment
PSK
Pre-Shared Key
PSNP
Partial SNP
PSTN
Public Switched Telephone Network
PTP
Precision Time Protocol
PTY
Pseudo-Terminals
PVC
Permanent Virtual Circuit
PVST
Per VLAN Spanning Tree
PXE
Preboot eXecution Environment
Q
Return
QoS
Quality of Service
QPPB
QoS Policy Propagation Through the Border Gateway Protocol
R
Return
RA
Router Advertisement
RA
Registration Authority
RADIUS
Remote Authentication Dial-In User Service
RD
Route Distinguisher
RDI
Remote Defect Indication
RDM
Russian Dolls Model
RED
Random Early Detection
RFID
Radio Frequency Identification
RIP
Routing Information Protocol
RIP-2
Routing Information Protocol version 2
RLSN
Remote Link Status Notification
RMON
Remote Network Monitoring
RP
Rendezvous Point
RPA
Rendezvous Point Address
RPF
Reverse Path Forwarding
RPL
Rendezvous Point Link
RPR
Resilient Packet Ring
RPT
Rendezvous Point Tree
RR
Router Renumber
RRPP
Rapid Ring Protection Protocol
RS
Router Solicitation
RSA
Rivest Shamir and Adleman
RSB
Reservation State Block
RSH
Remote Shell
RSN
Robust Security Network
RSNA
Robust Security Network Association
RSTP
Rapid Spanning Tree Protocol
RSVP
Resource Reservation Protocol
rt_VBR
Real-time Variable Bit Rate
RTC
Remote Terminal Connection
RTCP
Real-Time Transport Control Protocol
RTP
Real-Time Transport Protocol
RTS
Request to Send
RTSP
Real Time Streaming Protocol
S
Return
SA
SA
Source Active
SABM
Set Asynchronous Balanced Mode
SAN
Storage Area Networks
SAP
Service Advertising Protocol
SATOP
Structure-Agnostic TDM over Packet
SAVI
Source Address Validation
SBM
Subnetwork Bandwidth Management
SCCP
Skinny Client Control Protocol
SCEP
Simple Certificate Enrollment Protocol
SCFF
Single Choke Fairness Frame
SDH
Synchronous Digital Hierarchy
SDLC
Synchronous Data Link Control
SDP
Session Description Protocol
SDU
Service Data Unit
SF
Super Frame
sFlow
Sampled Flow
SFM
Source-Filtered Multicast
SFP
Small Form-factor Pluggable
SFTP
Secure FTP
SIP
Session Initiation Protocol
SIPS
SIP secure
SLA
Service Level Agreement
SLAAC-Only
Stateless Address Autoconfiguration
SLIP
Serial Line Internet Protocol
SM
Sparse Mode
SMTP
Simple Mail Transfer Protocol
SNA
System Network Architecture
SNAP
Subnetwork Access Protocol
SNMP
Simple Network Management Protocol
SNPA
Subnetwork Point of Attachment
SNR
Signal-to-Noise Ratio
SONET
Synchronous Optical Network
SOO
Site of Origin
SP
Service Provider
SP
Strict Priority
SPCS
Stored Program Control Switching System
SPE
Superstratum PE or Sevice Provider-end PE
SPF
Shortest Path First
SPI
Security Parameter Index
SPID
Service Profile Identification
SPT
Shortest Path Tree
SQL
Structured Query Language
SRTP
Secure Real-time Transport Protocol
SSH
Secure Shell
SSID
Service Set Identifier
SSL
Secure Sockets Layer
SSM
Source-Specific Multicast
SSM
Synchronization Status Marker
SSP
Switch-to-Switch Protocol
ST
Shared Tree
STP
SVC
Static Virtual Circuit
SVC
Switched Virtual Circuit
SVP
Spectralink Voice Priority
T
Return
TA
Terminal Adapter
TC
Topology Checksum
TC
Transparent Clock
TCI
Tag Control Information
TCN BPDU
Topology Change Notification BPDU
TDM
Time Division Multiplexing
TE
Traffic Engineering
TEDB
TE DataBase
TFTP
Trivial File Transfer Protocol
TLS
Transport Layer Security
TLS
Transparent LAN Service
ToS
Type of Service
TP
Topology Protection
TPDU
Transport Protocol Data Unit
TPID
Tag Protocol Identifier
TRIP
Triggered RIP
TS
Traffic Shaping
TST
Test
TTL
Time to Live
TTY
True Type Terminal
TU
Tributary Unit
TXOPLimit
Transmission Opportunity Limit
U
Return
UA
Unnumbered Acknowledge
U-APSD
Unscheduled automatic power-save delivery
UBR
Unspecified Bit Rate
UDLD
Uni-directional Link Direction
UNI
User Network Interface
URL
Uniform Resource Locator
URPF
Unicast Reverse Path Forwarding
USM
User-Based Security Model
UTC
Coordinated Universal Time
V
Return
VAD
Voice Activity Detection
VAM
VPN Address Management
VC
Virtual Circuit
VC
Virtual Container
VCC
Virtual Circuit Connection
VCN
Virtual Circuit Number
VE
Virtual Ethernet
VE-Bridge
Virtual Ethernet Bridge
VF Owner
Virtual Forwarder Owner
VLAN
Virtual Local Area Network
VoD
Video on Demand
VoIP
Voice over IP
VP
Virtual Path
VPC
Virtual Path Connection
VPDN
Virtual Private Dial-up Network
VPLS
Virtual Private LAN Service
VPN
VRRP
Virtual Router Redundancy Protocol
VSAN
Virtual Storage Area Network
VSI
Virtual Switch Instance
VT
Virtual-template
VTP
VLAN Trunking Protocol
VTY
Virtual Type Terminal
W
Return
WAI
WLAN Authentication Infrastructure
WAN
Wide Area Network
WAPI
WLAN Authentication and Privacy Infrastructure
WDS
Wireless Distribution System
WEP
Wired Equivalent Privacy
WFQ
WIDS
Wireless Intrusion Detection System
WiNet
Wisdom Network
WINS
Windows Internet Naming Service
WLAN
Wireless Local Area Network
WMM
Wi-Fi Multimedia
WPA
Wi-Fi Protected Access
WPI
WLAN Privacy Infrastructure
WRED
Weighted Random Early Detection
WRR
Weighted Round Robin
WWN
World Wide Name
WWW
World Wide Web
X
Return
XENPAK
10-Gigabit Ethernet Transceiver Package
XFP
10-Gigabit small Form-factor Pluggable
XML
Extensible Markup Language
Z
Return
ZBR
Zone Border Router
