00-About the S5130-HI Command References
HomeSupportSwitchesH3C S5130 Switch SeriesReference GuidesCommand ReferencesH3C S5130-HI Switch Series Command References-Release 1312-6W10100-About the S5130-HI Command References
Download Book
  • Released At: 15-01-2020
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
About the H3C S5130-HI command references
The H3C S5130-HI command references describe the commands and command syntax options available for the H3C S5130-HI Switch Series.
Command reference
Content
Fundamentals Command Reference
Covers the commands for logging in to and setting up the switch. This command reference includes:
·         Basic CLI.
·         RBAC.
·         Login management.
·         FTP and TFTP.
·         File system management.
·         Configuration file management.
·         Software upgrade.
·         ISSU.
·         Device management.
·         Tcl.
·         Python.
·         License management.
·         Automatic configuration.
IRF Command Reference
Covers the commands for configuring IRF and IRF 3.1.
Layer 2—LAN Switching Command Reference
Covers the commands for configuring Layer 2 technologies and features in a LAN switched network. This command reference includes:
·         Ethernet interface.
·         Loopback, null, and inloopback interfaces.
·         Bulk interface configuration.
·         MAC address table and MAC Information.
·         Ethernet link aggregation.
·         Port isolation.
·         Spanning tree.
·         Loop detection.
·         VLAN (including VLAN, super VLAN, private VLAN, and voice VLAN).
·         MVRP.
·         QinQ.
·         VLAN mapping.
·         LLDP.
·         L2PT.
·         Service loopback group.
Layer 3—IP Services Command Reference
Covers the commands for configuring IP addressing, IP performance optimization, ARP, IP forwarding basic, DHCP, DNS, UDP helper, IPv6 basics, and DHCPv6 server. This command reference includes:
·         ARP (including gratuitous ARP, proxy ARP, and ARP snooping).
·         IP addressing.
·         DHCP.
·         DNS (including DDNS).
·         IP forwarding basics (including basic IP forwarding and load sharing).
·         Fast forwarding.
·         IRDP.
·         IP performance optimization.
·         UDP helper.
·         IPv6 basics.
·         DHCPv6.
·         IPv6 fast forwarding.
·         HTTP redirect.
Layer 3—IP Routing Command Reference
Covers the commands for configuring routes for IPv4 and IPv6 networks of different sizes. This command reference includes:
·         Basic IP routing.
·         Static routing.
·         RIP.
·         OSPF.
·         IS-IS.
·         BGP.
·         Policy-based routing.
·         IPv6 static routing.
·         RIPng.
·         OSPFv3.
·         IPv6 IS-IS.
·         IPv6 policy-based routing.
·         Routing policy.
IP Multicast Command Reference
Covers the commands for Layer 3 IPv4 multicast protocols (including IGMP, PIM, and MSDP), Layer 3 IPv6 multicast protocols (including MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (including IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (including MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This command reference includes:
·         IGMP snooping.
·         PIM snooping.
·         Multicast VLAN.
·         Multicast routing and forwarding.
·         IGMP.
·         PIM.
·         MSDP.
·         MLD snooping.
·         IPv6 PIM snooping.
·         IPv6 multicast VLAN.
·         IPv6 multicast routing and forwarding.
·         MLD.
·         IPv6 PIM.
ACL and QoS Command Reference
Covers the commands for classifying traffic with ACLs, and allocating network resources and managing congestions with QoS technologies to improve network performance and network use efficiency. This command reference includes:
·         ACL.
·         QoS (including QoS policy, priority mapping, GTS and rate limit,  queue-based accounting, congestion management, per-port queue-based accounting, congestion avoidance, and aggregate CAR).
·         Data buffer.
·         Time range.
·         QCN.
Security Command Reference
Covers security feature commands. Available security features include identity authentication, secure management, and attack protection. This command reference includes:
·         AAA.
·         802.1X.
·         MAC authentication.
·         Portal.
·         Web authentication.
·         Port security.
·         User profile.
·         Password control.
·         Keychain.
·         Public key management.
·         PKI.
·         IPsec and IKE.
·         SSH.
·         SSL.
·         Attack detection and prevention.
·         IP source guard.
·         ARP attack protection.
·         ND attack defense.
·         uRPF.
·         SAVI.
·         MFF.
·         Crypto engine.
·         FIPS.
·         802.1X client.
High Availability Command Reference
Covers high availability commands for managing failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This command reference includes:
·         Ethernet OAM.
·         CFD.
·         DLDP.
·         RRPP.
·         ERPS.
·         Smart Link.
·         Monitor Link.
·         VRRP.
·         BFD.
·         Track.
·         Process placement.
Network Management and Monitoring Command Reference
Covers the commands that help you manage and monitor your network, for example, manage system events, and test network connectivity. This command reference includes:
·         System maintenance and debugging (ping, tracert, and system debugging).
·         NQA.
·         NTP (including SNTP).
·         PoE.
·         SNMP.
·         RMON.
·         Event MIB.
·         NETCONF.
·         CWMP.
·         EAA.
·         Process monitoring and maintenance.
·         Mirroring (including both port and flow mirroring).
·         sFlow.
·         Information center.
·         Packet capture.
OpenFlow Command Reference
Covers the commands for configuring OpenFlow.
