Title | Size | Downloads |
02-IRF Configuration Guide-book.pdf | 795.33 KB |
Preface
This configuration guide describes how to set up an IRF fabric of multiple H3C S5130-EI switches, including:
· Plan the switch roles in the IRF fabric.
· Connect the IRF links.
· Detect IRF splits and maintain the IRF fabric.
· Audience
· About the H3C S5130-EI documentation set
Audience
· Network planners.
· Network administrators working with the S5130-EI switch series.
Conventions
This section describes the conventions used in the documentation.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device. |
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5130-EI documentation set includes the following categories of documents:
Category |
Documents |
Purposes |
Hardware specifications and installation |
Compliance and safety manual CE DOC |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Provides basic installation instructions. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
Power modules user manual |
Describes the appearance, specifications, and installation and removal of hot-swappable power modules. |
Pluggable transceiver modules installation guide |
Guides you through installing SFP/SFP+ transceiver modules. |
Pluggable modules manual |
Describes the hot-swappable modules available for the H3C switches, their external views, and specifications. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
MIB Companion |
Describes the MIBs for the software release. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Software Download]—Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
