About the S5130-EI Configuration Guides
HomeSupportSwitchesH3C S5130 Switch SeriesConfigure & DeployConfiguration GuidesH3C S5130-EI Switch Series Configuration Guides-Release 310x-6W102About the S5130-EI Configuration Guides
Download Book
About the H3C S5130-EI configuration guides
The H3C S5130-EI configuration guides describe the software features for the H3C S5130-EI Switch Series, and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide
Content
Fundamentals Configuration Guide
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes:
·     CLI
·     Login management (login methods such as Telnet, and user interface configuration and access control)
·     RBAC
·     FTP and TFTP
·     File system management
·     Configuration file management
·     Software upgrade
·     Emergency shell
·     Device management
·     Tcl
·     Automatic configuration
IRF Configuration Guide
Describes the H3C proprietary Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers.
Layer 2—LAN Switching Configuration Guide
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes:
·     Ethernet interface
·     Loopback, null, and inloopback interfaces
·     Bulk interface configuration
·     MAC address table and MAC Information
·     Ethernet link aggregation
·     Port isolation
·     Spanning tree
·     Loop detection
·     VLAN (including VLAN, super VLAN, private VLAN, and voice VLAN)
·     MVRP
·     QinQ
·     VLAN mapping
·     LLDP
Layer 3—IP Services Configuration Guide
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, and DHCPv6. This guide includes:
·     ARP (ARP, gratuitous ARP, proxy ARP and ARP snooping)
·     IP addressing
·     DHCP (DHCP overview, DHCP server, DHCP relay agent, DHCP client, DHCP snooping, and BOOTP client)
·     DNS
·     Basic IP forwarding
·     IRDP
·     IP performance optimization
·     UDP helper
·     Basic IPv6 settings
·     DHCPv6 (DHCPv6 overview, DHCPv6 server, DHCPv6 relay agent, DHCPv6 client, and DHCPv6 snooping)
Layer 3—IP Routing Configuration Guide
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy-based routing. This guide includes:
·     Basic IP routing
·     Static routing
·     Default route
·     RIP
·     OSPF
·     Policy-based routing
·     IPv6 static routing
·     RIPng
·     OSPFv3
·     IPv6 policy-based routing
·     Routing policy
IP Multicast Configuration Guide
Covers Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes:
·     Multicast overview
·     IGMP snooping
·     PIM snooping
·     Multicast VLAN
·     MLD snooping
·     IPv6 PIM snooping
·     IPv6 multicast VLAN
ACL and QoS Configuration Guide
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes:
·     ACL
·     QoS, including the following:
? QoS overview
? QoS policy
? Priority mapping
? Traffic policing, GTS, and rate limit
? Congestion management
? Congestion avoidance
? Traffic filtering
? Priority marking
? Nesting
? Traffic redirecting
? Global CAR
? Class-based accounting
·     Time range
·     Data buffer
·     Appendixes
Security Configuration Guide
Covers security features. The major security features available on the switch include: identity authentication, secure management, and attack protection. This guide includes:
·     AAA
·     802.1X
·     MAC authentication
·     Portal authentication
·     Port security
·     Password control
·     Public key management
·     PKI
·     IPsec and IKE
·     SSH
·     SSL
·     IP source guard
·     ARP attack protection
·     MFF
·     Crypto engines
·     FIPS
·     User profile
High Availability Configuration Guide
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes:
·     Ethernet OAM
·     CFD
·     DLDP
·     Smart Link
·     Monitor Link
·     BFD
·     Track
Network Management and Monitoring Configuration Guide
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes:
·     System maintenance and debugging (ping, tracert, and system debugging)
·     NTP and SNTP
·     Information center
·     SNMP
·     RMON
·     NQA
·     Mirroring (including port mirroring and traffic mirroring)
·     sFlow
·     Process monitoring and maintenance
·     EAA
·     PoE
·     NETCONF
OpenFlow Configuration Guide
Describes the application scenarios, fundamentals, and configuration of OpenFlow.
Acronyms
Lists the significant acronyms in the configuration guides.
