Title | Size | Downloads |
00-About the S5130-EI Configuration Guides-book.pdf | 23.74 KB |
About the H3C S5130-EI configuration guides
Configuration guide |
Content |
Fundamentals Configuration Guide |
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes: · CLI · Login management (login methods such as Telnet, and user interface configuration and access control) · RBAC · FTP and TFTP · File system management · Configuration file management · Software upgrade · Emergency shell · Device management · Tcl · Python |
IRF Configuration Guide |
Describes the Intelligent Resilient Framework (IRF) technology, which provides data center class availability and scalability. IRF creates a fabric from multiple switches. The switches that form the IRF fabric work in 1:N redundancy and appear as one unit in the network. IRF improves management efficiency and streamlines network topologies. It is suitable for highly reliable enterprise networks and data centers. |
Layer 2—LAN Switching Configuration Guide |
Covers Layer 2 technologies and features used on a LAN switched network, such as VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN and so on. This guide includes: · Ethernet interface · Loopback, null, and inloopback interfaces · Bulk interface configuration · MAC address table and MAC Information · Ethernet link aggregation · Port isolation · Spanning tree · L2PT · Loop detection · VLAN (including super VLAN, private VLAN, and voice VLAN) · MVRP · QinQ · VLAN mapping · LLDP |
Layer 3—IP Services Configuration Guide |
Describes how to configure ARP, IP addressing, IP performance optimization, IP forwarding basics, IPv6 basics, DHCP, DNS, UDP helper, and DHCPv6. This guide includes: · ARP (including gratuitous ARP, proxy ARP and ARP snooping) · DHCP (including DHCP overview, DHCP server, DHCP relay agent, DHCP client, DHCP snooping, and BOOTP client) · Basic IP forwarding · IRDP · IP performance optimization · DHCPv6 (including DHCPv6 overview, DHCPv6 server, DHCPv6 relay agent, DHCPv6 client, and DHCPv6 snooping) |
Layer 3—IP Routing Configuration Guide |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy-based routing. This guide includes: · Basic IP routing · Static routing · Default route · RIP · OSPF · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 policy-based routing · Routing policy |
IP Multicast Configuration Guide |
Covers Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes: · Multicast overview · IGMP snooping · PIM snooping · Multicast VLAN · MLD snooping · IPv6 PIM snooping · IPv6 multicast VLAN |
ACL and QoS Configuration Guide |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This configuration guide includes: · ACL · QoS (including QoS overview, QoS policy, priority mapping, traffic policing, GTS, and rate limit, bandwidth guaranteeing group, congestion management, congestion avoidance, traffic filtering, priority marking, nesting, traffic redirecting, global CAR, and class-based accounting) · Data buffer · Appendixes |
Security Configuration Guide |
Covers identity authentication, access security, secure management, and attack protection features. This guide includes: · AAA · 802.1X · MAC authentication · Web authentication · Triple authentication · Port security · Password control · Public key management · PKI · IPsec, IKE, and IKEv2 · SSH · SSL · IP source guard · ARP attack protection · FIPS · User profile · Attack detection and prevention · ND attack defense · SAVI |
High Availability Configuration Guide |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · Ethernet OAM · CFD · DLDP · RRPP · Smart Link · Monitor Link · BFD · Track |
Network Management and Monitoring Configuration Guide |
Describes features that help you manage and monitor your network, for example, manage system events, and test network connectivity. This guide includes: · System maintenance and debugging (ping, tracert, and system debugging) · RMON · Mirroring (including port mirroring and traffic mirroring) · Process monitoring and maintenance · PoE · NETCONF · Packet capture |
OpenFlow Configuration Guide |
Describes the application scenarios, fundamentals, and configuration of OpenFlow. |
Acronyms |
Lists the significant acronyms in the configuration guides. |
