Title | Size | Downloads |
07-ACL and QoS Configuration Guide-book.pdf | 1.49 MB |
Preface
The H3C S5130-HI documentation set includes 11 configuration guides, which describe the software features for the H3C S5130-HI Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The ACL and QoS Configuration Guide describes the following features and tasks that help you get started with the switch:
· IPv4 ACLs and IPv6 ACLs.
· Packet filtering by using ACLs.
· Traffic control by using QoS polices.
· Common QoS techniques such as traffic policing, congestion management, and congestion avoidance.
This preface includes:
· Audience
· About the H3C S5130-HI documentation set
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with the S5130-HI series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device. |
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card. |
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
The H3C S5130-HI documentation set includes:
Category |
Documents |
Purposes |
Hardware specifications and installation |
Compliance and safety manual CE DOC |
Provides regulatory information and the safety instructions that must be followed during installation. |
Installation quick start |
Provides basic installation instructions. |
Installation guide |
Provides a complete guide to hardware installation and hardware specifications. |
Fan assemblies installation manual |
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies. |
Power modules user manual |
Describes the appearance, specifications, and installation and removal of hot-swappable power modules. |
User manuals for interface cards |
Describe the specifications, installation, and replacement of expansion interface cards. |
Pluggable transceiver modules installation guide |
Guides you through installing SFP/SFP+/QSFP+ transceiver modules. |
Pluggable modules manual |
Describes the hot-swappable modules available for the H3C switches, their external views, and specifications. |
Software configuration |
Configuration guides |
Describe software features and configuration procedures. |
Command references |
Provide a quick reference to all available commands. |
Operations and maintenance |
MIB Companion |
Describes the MIBs for the software release. |
Release notes |
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Obtaining documentation
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Software Download]—Provides the documentation released with the software version.
Technical support
http://www.h3c.com
Documentation feedback
We appreciate your comments.
