02-IRF Configuration Guide
HomeSupportSwitchesS5130 SeriesConfigure & DeployConfiguration GuidesH3C S5130-HI Configuration Guides-Release 1111-6W10002-IRF Configuration Guide
Title Size Downloads
02-IRF Configuration Guide-book.pdf 842.08 KB
Table of Contents
Related Documents
book
book 842.08 KB
Preface
The H3C S5130-HI documentation set includes 11 configuration guides, which describe the software features for the H3C S5130-HI Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The IRF Configuration Guide describes how to set up an IRF fabric of multiple switches, including:
·     Plan the switch roles in the IRF fabric.
·     Connect the IRF links.
·     Detect IRF splits and maintain the IRF fabric.
This preface includes:
·     Audience
·     Conventions
·     About the H3C S5130-HI documentation set
·     Obtaining documentation
·     Technical support
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the S5130-HI series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access point.
Represents a security product, such as a firewall, UTM, multiservice security gateway, or load-balancing device.
Represents a security card, such as a firewall, load-balancing, NetStream, SSL VPN, IPS, or ACG card.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your switch.
The H3C S5130-HI documentation set includes:
Category
Documents
Purposes
Hardware specifications and installation
Compliance and safety manual
CE DOC
Provides regulatory information and the safety instructions that must be followed during installation.
Installation quick start
Provides basic installation instructions.
Installation guide
Provides a complete guide to hardware installation and hardware specifications.
Fan assemblies installation manual
Describes the appearance, specifications, and installation and removal of hot-swappable fan assemblies.
Power modules user manual
Describes the appearance, specifications, and installation and removal of hot-swappable power modules.
User manuals for interface cards
Describe the specifications, installation, and replacement of expansion interface cards.
Pluggable transceiver modules installation guide
Guides you through installing SFP/SFP+/QSFP+ transceiver modules.
Pluggable modules manual
Describes the hot-swappable modules available for the H3C switches, their external views, and specifications.
Software configuration
Configuration guides
Describe software features and configuration procedures.
Command references
Provide a quick reference to all available commands.
Operations and maintenance
MIB Companion
Describes the MIBs for the software release.
Release notes
Provide information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading.
You can access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions.
[Software Download]—Provides the documentation released with the software version.
Technical support
[email protected]
http://www.h3c.com
We appreciate your comments.
