| book | 1.68 MB |
Table of Contents
New and Modified Commands· 1-3
2 H3C S3600 Series Documentation Guide· 2-1
Obtaining the Documentation· 2-1
Finding Documents at the H3C Website· 2-2
Broadband Ethernet Access for Residential Communities· 3-2
Branch or Small- to Medium-Sized Enterprise Networks· 3-2
Large Enterprise and Campus Networks· 3-3
1 About This Document
The H3C S3600 Series Ethernet Switches Command Manual, Release 1702 describes the commands available in the S3600 series software release 1702.
Audience
This document is for administrators who are configuring and maintaining the S3600 series switches.
Part Organization
Table 1-1 presents the part organization of this document:
Part | Features |
1 CLI | CLI Configuration Commands |
2 Login | l Login User Controlling Commands l User Level Switching Commands |
3 Configuration File Management | |
4 VLAN | |
5 IP Address and Performance | |
6 Voice VLAN | |
7 GVRP | |
8 Port Basic Configuration | |
9 Link Aggregation | |
10 Port Isolation | |
11 Port Security-Port Binding | l Port Security Configuration Commands l Port Binding Configuration Commands |
12 DLDP | DLDP Configuration Commands |
13 MAC Address Table Management | |
14 Auto Detect | Auto Detect Configuration Commands |
15 MSTP | MSTP Configuration Commands |
16 Routing Protocol | l Static Route Configuration Commands l RIP v1/v2 Configuration Commands l OSPF Configuration Commands (available only on the S3600-EI series) l Routing Policy Configuration Commands l Route Capacity Limiting Configuration Commands (available only on the S3600-EI series) |
17 Multicast | l Common Multicast Configuration Commands l IGMP Configuration Commands (available only on the S3600-EI series) l PIM Configuration Commands (available only on the S3600-EI series) l MSDP Configuration Commands (available only on the S3600-EI series) |
18 802.1X and System Guard | l 802.1X Configuration Commands l Quick EAD Deployment Configuration Commands l HABP Configuration Commands l System Guard Configuration Commands |
19 AAA | l AAA Configuration Commands l RADIUS Configuration Commands l HWTACACS Configuration Commands l EAD Configuration Commands |
20 Web Authentication | Web Authentication Configuration Commands |
21 MAC Address Authentication | l MAC Address Authentication Basic Function Configuration Commands l MAC Address Authentication Enhanced Function Configuration Commands |
22 VRRP | VRRP Configuration Commands |
23 ARP | l ARP Attack Defense Configuration Commands l Proxy ARP Configuration Commands |
24 DHCP | l DHCP Server Configuration Commands (available only on the S3600-EI series) l DHCP Relay Agent Configuration Commands l DHCP Snooping Configuration Commands l DHCP Packet Rate Limit Configuration Commands l DHCP/BOOTP Client Configuration Commands |
25 ACL | |
26 QoS-QoS Profile | |
27-Web Cache Redirection | Web Cache Redirection Configuration Commands (available only on the S3600-EI series) |
28 Mirroring | Mirroring Configuration Commands |
29-IRF Fabric | IRF Fabric Configuration Commands |
30 Cluster | l Neighbor Discovery Protocol (NDP) Configuration Commands l Neighbor Topology Discovery Protocol (NTDP) Configuration Commands l Cluster Configuration Commands |
31-PoE-PoE Profile | l PoE Configuration Commands l PoE Profile Configuration Commands |
32-UDP Helper | |
33 SNMP-RMON | l SNMP Configuration Commands l RMON Configuration Commands |
34 NTP | |
35 SSH | SSH Configuration Commands |
36 File System Management | |
37 FTP-SFTP-TFTP | l FTP Server Configuration Commands l FTP Client Configuration Commands l SFTP Server Configuration Commands |
38 Information Center | |
39 System Maintenance and Debugging | l Basic System Configuration Commands |
40 VLAN-VPN | l VLAN VPN Configuration Commands l Selective QinQ Configuration Commands l BPDU Tunnel Configuration Commands |
41 HWPing | |
42 IPv6 Management | |
43 DNS | |
44 Smart Link-Monitor Link | l Smart Link Configuration Commands l Monitor Link Configuration Commands |
45 Access Management | Access Management Configuration Commands |
46 LLDP | LLDP Configuration Commands |
47 PKI | PKI Configuration Commands |
48 SSL | SSL Configuration Commands |
49 HTTPS | HTTPS Configuration Commands |
H3C S3600 Series Ethernet Switches Operation Manual, Release 1702 and H3C S3600 Series Ethernet Switches Command Manual, Release 1702 are for software release 1702.
See Table 1-2 for new commands introduced in software release 1702.
Table 1-2 New commands in software release 1702
New commands | Reference |
command-alias enable | 01-CLI |
command-alias mapping | |
display command-alias | |
icmp acl-priority | 05-IP Address and Performance |
voice vlan qos trust | 06-Voice VLAN |
voice vlan qos | |
flow-control no-pauseframe-sending | 08-Port Basic Configuration |
loopback-detection shutdown enable | |
loopback-detection interface-list enable | |
port-security guest-vlan | 11-Port Security-Port Binding |
port-security timer guest-vlan-reauth | |
port-security timer autolearn | |
prune delay (available only on the S3600-EI series) | 17-Multicast Protocol |
igmp-snooping special-query source-ip | |
igmp-snooping query-pkt-deny | |
system-guard cpu-rcv-limit | 18-802.1X and System-Guard |
attribute-ignore | 19-AAA |
web-authentication timer max-online | 20-Web Authentication |
web-authentication protocol | |
VRRP configuration commands (available only on the S3600-SI series Ethernet switches) | 22-VRRP |
ARP attack defense configuration commands | 23-ARP |
MFF configuration commands | |
ip check dot1x enable | 24-DHCP |
reset dhcp-snooping [ ip-address ] | |
dhcp relay inform replace enable | |
25-ACL | |
28-Mirroring | |
cluster-local-user | 30-Cluster |
cluster-snmp-agent community | |
cluster-snmp-agent group v3 | |
cluster-snmp-agent mib-view included | |
cluster-snmp-agent usm-user v3 | |
display job | 39-System Maintenance and Debugging |
job | |
port auto-power-down | |
time at | |
time delay | |
view | |
40-VLAN-VPN | |
New HWPing commands, including: adv-factor, datafill, description, display hwping statistics, filesize, history keep-time, history-record enable, hwping-agent clear, hwping-agent max-requests, sendpacket passroute, statistics, statistics keep-time, test-time begin, and ttl. | 41-HWping |
LLDP configuration commands | 46-LLDP |
PKI configuration commands | 47-PKI |
SSL configuration commands | 48-SSL |
HTTPS configuration commands | 49-HTTPS |
See Table 1-3 for command modifications in software release 1702 relative to software release 1602.
Table 1-3 Modified command in release 1702
Modified command | Reference |
storm-constrain { broadcast | multicast | unicast } max-packets min-packets { pps | kbps } | 08-Port Basic Configuration |
am user-bind mac-addr mac-address ip-addr ip-address [ interface interface-type interface-number ] | 11-Port Security-Port Binding |
vlan-assignment-mode vlan-list | 19-AAA |
web-authentication customize file web-file | 20-Web Authentication |
ip check source ip-address [ mac-address ] [ qos-profile string ] | 24-DHCP |
cluster switch-to { member-number | mac-address mac-address | administrator | sysname member-sysname } | 30-Cluster |
Conventions
Command conventions
Convention | Description |
Boldface | The keywords of a command line are in Boldface. |
italic | Command arguments are in italic. |
[ ] | Items (keywords or arguments) in square brackets [ ] are optional. |
{ x | y | ... } | Alternative items are grouped in braces and separated by vertical bars. One is selected. |
[ x | y | ... ] | Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected. |
{ x | y | ... } * | Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected. |
[ x | y | ... ] * | Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected. |
&<1-n> | The argument(s) before the ampersand (&) sign can be entered 1 to n times. |
# | A line starting with the # sign contains comments. |
Command line interface (CLI) commands of H3C products are case insensitive.
GUI conventions
Boldface | Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
> | Multi-level menus are separated by angle brackets. For example, File > Create > Folder. |
Symbols
| Means reader be extremely careful. Improper operation may cause bodily injury. |
| Means reader be careful. Improper operation may cause data loss or damage to equipment. |
| Means a complementary description. |
| Means techniques helpful for you to make configuration with ease. |
You can obtain the H3C S3600 series documentation in these ways:
l CD-ROMs shipped with the devices
l H3C website
l Software release notes
CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete set of electronic documents of the product, including operation manuals and command manuals. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
H3C Website
To obtain up-to-date documentation and technical support, go to http://www.h3c.com.
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Related Documentation
Use the documents listed in Table 2-1 together with H3C S3600 Series Ethernet Switches Command Manual to make full use of the benefits delivered by the S3600 series.
Table 2-1 Related documentation
Document title | Description |
H3C S3600 Series Ethernet Switches Operation Manual-Release 1702 | Describes software features and guides you through the configuration procedures. An index is available for the ease of retrieval. |
H3C S3600 Series Ethernet Switches Installation Manual | Describes the physical views and hardware specifications of the H3C S3600 series switches, and guides you through the installation, power-on and startup, troubleshooting and maintenance procedures. |
H3C S3600 Series Ethernet Switches Compliance and Safety Manual | Provides the safety and regulatory compliance statements, and describes the protection actions that you must take when installing and maintaining the H3C S3600 series switches. |
H3C Low-End Ethernet Switches Configuration Guide | Describes the typical application scenarios, and provides configuration examples and configuration guidelines. |
All these documents are available at the H3C website:
l For software feature descriptions and configuration procedures, see H3C S3600 Series Ethernet Switches Operation Manual.
l For command reference, see H3C S3600 Series Ethernet Switches Command Manual.
l For hardware specifications, installation, and troubleshooting, see H3C S3600 Series Ethernet Switches Installation Manual.
l For typical application scenarios, configuration examples, and configuration guidelines, see H3C Low-End Ethernet Switches Configuration Guides.
Documentation Feedback
We appreciate your comments.
Product Overview
The H3C S3600 Series Ethernet Switches are multilayer switching products. They support abundant Layer 3 features and enhanced extended functions, in addition to Layer 2 features. The switches come in two series:
l The S3600-SI series supports basic routing functions, DHCP, basic IRF functions, and IGMP-Snooping.
l The S3600-EI series supports advanced routing functions, DHCP, enhanced IRF functions, and enhanced multicast functions (including PIM-DM and PIM-SM).
See Table 3-1 for all S3600 switch models and their basic hardware specifications.
Table 3-1 S3600 switch hardware summary
Model | Power supply unit (PSU) | Number of service ports | Number of 100 Mbps ports | Number of 1,000 Mbps uplink ports | Console port |
H3C S3600-28P-SI | AC-input | 28 | 24 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-28P-PWR-SI | AC-/DC-input | 28 | 24 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-28TP-SI | AC-input | 28 | 24 10/100 Mbps (electrical) | 2 Gigabit (SFP) ports 2 x 10/100/1,000 Mbps ports (electrical) | 1 |
H3C S3600-52P-SI | AC-input | 52 | 48 10/100 Mbps (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-28P-EI | AC-/DC-input | 28 | 24 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-28F-EI | AC-/DC-input | 28 | 24 100 Mbps (SFP) ports | 2 Gigabit (SFP) ports 2 10/100/1,000 Mbps ports (electrical) | 1 |
H3C S3600-28P-PWR-EI | AC-/DC-input | 28 | 24 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-52P-EI | AC-/DC-input | 52 | 48 10/100 Mbps ports (electrical) | 4 Gigabit ports (SFP) | 1 |
H3C S3600-52P-PWR-EI | AC-/DC-input | 52 | 48 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
H3C S3600-52P-PWR-SI | AC-/DC-input | 52 | 48 10/100 Mbps ports (electrical) | 4 Gigabit (SFP) ports | 1 |
Network Scenarios
You can deploy the S3600 series on many types of networks, such as enterprise and broadband access networks. This section describes several typical application scenarios for the S3600 series.
Deploy an S3600 series switch at the center of the broadband access network for a residential community. Connect the switch to the access S3100 series switches to reach end users, and to an upstream core Layer 3 switch through a GE port to access the MAN backbone.
Figure 3-1 Community access network
Deploy the S3600 series switches as backbone switches on a branch or small-to medium-sized enterprise network. Connect the switches to the headquarters or other branches through routers. As the business grows, you can cascade the S3600 series to extend the network.
Figure 3-2 Branch or small-to medium-sized enterprise network
Deploy the S3600 series switches at the distribution layer of a large enterprise or campus network to implement Gigabit-to-backbone and 100 Mbps-to-desktop together with other H3C switches. Connect the S3600 switches to the access Layer 2 switches (for example, the S3100 series), and to the core Layer 3 switches through GE ports.
Figure 3-3 S3600 series application in a large enterprise or campus network
