H3C S3100-52P Ethernet Switch Command Manual-Release 1702-6W100
HomeSupportSwitchesH3C S3100 Switch SeriesReference GuidesCommand ReferencesH3C S3100-52P Ethernet Switch Command Manual-Release 1702-6W100
To read the whole book, click the link on the right side to download the whole book; to read the individual chapters, click the links on the left.
About This Guide
The H3C S3100-52P Ethernet Switch Command Manual, Release 1702 describes the commands available in the software release 1702 for the S3100-52P switch.
Audience
This guide is for administrators managing the S3100-52P switch, hereafter referred to as the switch.
Part Organization
Table 1-1 presents the part organization of this guide:
Table 1-1 Part organization
Part
Features
1 CLI
CLI Configuration commands
2 Login
l      Login Commands
l      Controlling Logging in Users Commands
l      Switching User Level Commands
3 Configuration File Management
Configuration File Management Commands
4 VLAN
l      VLAN Configuration Commands
l      Port-Based VLAN Configuration Commands
l      Protocol-Based VLAN Configuration Commands
5 IP Address and Performance
l      IP Address Configuration Commands
l      IP Performance Configuration Commands
6 Voice VLAN
Voice VLAN Configuration Commands
7 GVRP
l      GARP Configuration Commands
l      GVRP Configuration Commands
8 Port Basic Configuration
Port Basic Configuration Commands
9 Link Aggregation
Link Aggregation Configuration Commands
10 Port Isolation
Port Isolation Configuration Commands
11 Port Security-Port Binding
l      Port Security Configuration Commands
l      Port Binding Configuration Commands
12 DLDP
DLDP Configuration Commands
13 MAC Address Table Management
MAC Address Table Management Configuration Commands
14 MSTP
MSTP Configuration Commands
15 Static Route.
Static route Commands
16 Multicast
l      Common Multicast Configuration Commands
l      IGMP Snooping Configuration Commands
17 802.1x and System Guard
l      802.1x Configuration Commands
l      Quick EAD Deployment Configuration Commands
l      HABP Configuration Commands
l      System Guard Configuration Commands
18 AAA
l      AAA Configuration Commands
l      RADIUS Configuration Commands
l      HWTACACS Configuration Commands
l      EAD Configuration Commands
19 Web Authentication
Web Authentication Configuration Commands
20 MAC Address Authentication
l      MAC Address Authentication Basic Function Configuration Commands
l      MAC Address Authentication Enhanced Function Configuration Commands
21 ARP
l      ARP Configuration Commands
l      ARP Attack Defense Configuration Commands
22 DHCP
l      DHCP Snooping Configuration Commands
l      DHCP Rate Limit Configuration Commands
l      DHCP/BOOTP Client Configuration Commands
23 ACL
ACL Configuration Commands
24 QoS-QoS Profile
l      QoS Configuration Commands
l      QoS Profile Configuration Commands
25 Mirroring
Mirroring Configuration Commands
26 Stack-Cluster
l      Stack Configuration Commands
l      Neighbor Discovery Protocol (NDP) Configuration Commands
l      Neighbor Topology Discovery Protocol (NTDP) Configuration Commands
l      Cluster Configuration Commands
l      Enhanced Cluster Feature Configuration Commands
27 SNMP-RMON
l      SNMP Commands
l      RMON Commands
28 NTP
NTP Configuration Commands
29 SSH
SSH Configuration Commands
30 File System Management
l      File System Configuration Commands
l      File Attribute Configuration Commands
31 FTP-SFTP-TFTP
l      FTP Server Configuration Commands
l      FTP Client Configuration Commands
l      SFTP Server Configuration Commands
l      SFTP Client Configuration Commands
l      TFTP Configuration Commands
32 Information Center
Information Center Configuration Commands
33 System Maintenance and Debugging
l      Basic System Configuration Commands
l      Network Connectivity Test Commands
l      Device Management Commands
l      Scheduled Task Configuration Commands
34 VLAN-VPN
l      VLAN VPN Configuration Commands
l      Selective QinQ Configuration Commands
l      BPDU Tunnel Configuration Commands
35 HWPing
l      HWPing Client Commands
l      HWPing Server Commands
36 IPv6 Management
l      Basic IPv6 Configuration Commands
l      IPv6 Application Configuration Commands
37 DNS
DNS Configuration Commands
38 Smart Link-Monitor Link
l      Smart Link Configuration Commands
l      Monitor Link Configuration Commands
39 LLDP
LLDP Configuration Commands
40 PKI
PKI Configuration Commands
41 SSL
SSL Configuration Commands
42 HTTPS
HTTPS Configuration Commands
Correspondence Between Documentation and Software
H3C S3100-52P Ethernet Switch Operation Manual-Release 1702 and H3C S3100-52P Ethernet Switch Command Manual-Release 1702 are for the software version of Release1702 of the S3100-52P.
Compared with Release 1602, many new commands are added in Release 1702. For details, refer to Table 1-2.
Table 1-2 Added commands in Release 1702
Added command in Release 1702
Manual
command-alias enable
01-CLI
command-alias mapping
display command-alias
icmp acl-priority
05-IP Address and Performance
voice vlan qos trust
06-Voice VLAN
voice vlan qos
flow-control no-pauseframe-sending
08-Port Basic Configuration
loopback-detection shutdown enable
loopback-detection interface-list enable
port-security guest-vlan
11-Port Security-Port Binding
port-security timer guest-vlan-reauth
port-security timer autolearn
igmp-snooping special-query source-ip
16-Multicast Protocol
system-guard cpu-rcv-limit
17-802.1x and System-Guard
attribute-ignore
18-AAA
web-authentication timer max-online
19-Web Authentication
web-authentication protocol
ARP attack detection commands
21-ARP
ip check dot1x enable
22-DHCP
reset dhcp-snooping
ruleIPv6 ACL
23-ACL
mirroring stp-collaboration
25-Mirroring
cluster-local-user
26-Stack-Cluster
cluster-snmp-agent community
cluster-snmp-agent group v3
cluster-snmp-agent mib-view included
cluster-snmp-agent usm-user v3
display job
33-System Maintenance and Debugging
job
port auto-power-down
time at
time delay
view
igmp transparent enable
34-VLAN-VPN
New HWPing commands are added including adv-factor, datafill, description, display hwping statistics, filesize, history keep-time, history-record enable, hwping-agent clear, hwping-agent max-requests, sendpacket passroute, statistics, statistics keep-time, test-time begin and ttl.
35-HWping
LLDP commands
39-LLDP
PKI commands
40-PKI
SSL commands
41-SSL
HTTPS commands
42-HTTPS
Compared with Release 1602, some commands’ keywords are added or changed in Release 1702. For details, refer to Table 1-3.
Table 1-3 Changed command in Release 1702
Modified command in Release 1702
Manual
storm-constrain { broadcast | multicast | unicast } max-packets min-packets { pps | kbps }
am user-bind mac-addr mac-address ip-addr ip-address [ interface interface-type interface-number ]
vlan-assignment-mode vlan-list
18-AAA
web-authentication customize file web-file
ip check source ip-address [ mac-address ] [ qos-profile string ]
22-DHCP
cluster switch-to { member-number | mac-address mac-address | administrator | sysname member-sysname }
26-Stack-Cluster
Conventions
Command conventions
Convention
Boldface
The keywords of a command line are in Boldface.
italic
Command arguments are in italic.
Items (keywords or arguments) in square brackets [ ] are optional.
{ x | y | ... }
Alternative items are grouped in braces and separated by vertical bars. One is selected.
[ x | y | ... ]
Optional alternative items are grouped in square brackets and separated by vertical bars. One or none is selected.
{ x | y | ... } *
Alternative items are grouped in braces and separated by vertical bars. A minimum of one or a maximum of all can be selected.
[ x | y | ... ] *
Optional alternative items are grouped in square brackets and separated by vertical bars. Many or none can be selected.
&<1-n>
The argument(s) before the ampersand (&) sign can be entered 1 to n times.
A line starting with the # sign is comments.
Command line interface (CLI) commands of H3C products are case insensitive.
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Means reader be extremely careful. Improper operation may cause bodily injury.
Means reader be careful. Improper operation may cause data loss or damage to equipment.
Means a complementary description.
Means techniques helpful for you to make configuration with ease.
Obtaining Documentation and Technical Support
Hangzhou H3C Technologies Co., Ltd. (hereafter referred to as H3C) provides various ways for you to obtain product documents and new feature releases in a convenient and timely manner. The documentations are available with:
l          CD-ROMs shipped with the devices
l          H3C website
l          Software release notes
CD-ROM
H3C delivers a CD-ROM together with each device. The CD-ROM contains a complete set of electronic documents of the product, including operation manuals and command manuals. After installing the reader program provided by the CD-ROM, you can search for the desired contents in a convenient way through the reader interface.
The contents in the manual are subject to update on an irregular basis due to product version upgrade or some other reasons. Therefore, the contents in the CD-ROM may not be the latest version. This manual serves the purpose of user guide only. Unless otherwise noted, all the information in the document set does not claim or imply any warranty. For the latest software documentation, go to the H3C website.
H3C Website
To obtain up-to-date documentation and technical support, go to http://www.h3c.com and select your country or region. Depending on your selection, you will be redirected to either of the following websites:
Go to the following columns for different categories of product documentation:
[Products & Solutions]: Provides information about products and technologies, as well as solutions.
[Technical Support & Document > Technical Documents]: Provides several categories of product documentation, such as installation, configuration, and maintenance.
[Technical Support & Document > Software Download]: Provides the documentation released with the software version.
Software Release Notes
With software upgrade, new software features may be added. You can acquire the information about the newly added software features through software release notes.
Related Documentation
H3C S3100-52P Ethernet Switch Operation Manual describes the principles and configuration procedures of the software features.
Other related documentation and their contents are listed in Table 2-1.
Table 2-1 Related documentation
Document title
Describes the commands for the S3100-52P Ethernet Switch. A master index of all commands covered by the whole manual is provided for your convenience.
H3C S3100-52P Ethernet Switch Operation Manual, Release 1702
Introduces the principles and configuration procedures of the software features for the S3100-52P Ethernet Switch.
H3C S3100-52P Ethernet Switch Installation Manual
Introduces the appearance, installation, power-on and startup, troubleshooting and maintenance of the H3C S3100-52P Ethernet switch.
H3C S3100-52P Ethernet Switch Compliance and Safety Manual
Introduces the security-preventive measures that you must comply with when installing and maintaining the H3C S3100-52P Ethernet switch.
H3C Low-End Ethernet Switches Configuration Guide
Introduces the typical application scenarios of the H3C S3100-52P Ethernet switch, and the related configuration procedures and configuration guidelines.
Reading Documents of Interest
l              To get an idea of the basic principles and configuration procedures of supported software features, read H3C S3100-52P Ethernet Switch Operation Manual at the H3C website.
l              To learn about the uses and parameters of commands and the meanings of displayed information, read H3C S3100-52P Ethernet Switch Command Manual at the H3C website.
l              To learn about the hardware characteristics, installation, and troubleshooting of available switch models and pluggable hardware components, read H3C S3100-52P Ethernet Switch Installation Manual at the H3C website.
Documentation Feedback
We appreciate your comments.
Product Overview
H3C S3100-52P Ethernet switch is a Layer 2 wire speed Ethernet switch developed by H3C independently. It is the intelligent and manageable switch designed for network environments where high performance, high port density, and ease of installation are required.
Table 3-1 S3100-52P Ethernet switch hardware specifications
Model
Power supply unit (PSU)
Number of service ports
Number of 100 Mbps ports
Number of 1,000 Mbps uplink ports
Console port
H3C S3100-52P
AC-input
52
48 10/100 Mbps ports(electrical)
4 Gigabit (SFP) ports
1
Networking Applications
You can deploy S3100-52P Ethernet switch on many types of networks, such as enterprise networks and broadband access networks. Following are several typical networking applications.
Broadband Ethernet Access for Residential Communities
On the broadband access network of a residential community, an S3100-52P Ethernet switch is located in the center. It is downlinked to S3100 series switches to reach the Ethernet users and uplinked to a core Layer 3 switch through a GE port to connect to the MAN backbone.
Figure 3-1 Connecting community Ethernet to MAN using S3100-52P Ethernet switch
Application for Connecting Branches or Small- to Medium-Sized Enterprises
For small-to medium-sized enterprises or branches of a large enterprise, S3100-52P Ethernet switch can serve as a downstream device connected to the backbone switch, and can be connected to the headquarters or other branches through Layer 3 switches or routers. As the enterprise size increases, the network also can expand by subtending the S3100-52P Ethernet switch.
Figure 3-2 S3100-52P Ethernet switch application in branch network of midsize/large enterprise
Application in Large Enterprise and Campus Networks
In a large enterprise or campus network, the S3100-52P Ethernet switch can operate on the access layer. They are uplinked to layer 3 switches, S3600 Series or S5600 Series for example; and uplinked to a layer 3 switch. These switches together provide a network-wide intranet solution that covers Gigabit-to-backbone and 100 Mbps-to-desktop.
Figure 3-3 S3100-52P Ethernet switch application in large enterprise and campus network
