H3C S12500X-AF Switches ISSU Guide-6W100
HomeSupportSwitchesH3C S12500X-AF Switch SeriesInstall & UpgradeUpgrade GuidesH3C S12500X-AF Switches ISSU Guide-6W100
Download Book
Table of Contents
Related Documents
ISSU Guide
Document version: 6W100-20190620
Copyright © 2019 New H3C Technologies Co., Ltd. All rights reserved.
The information in this document is subject to change without notice
Introduction· 1
Upgrade restrictions and guidelines· 1
Preparing for the upgrade· 1
Performing an ISSU in one step· 5
Network configuration· 6
Procedure· 6
Configuring the IRF fabric· 6
Performing an ISSU· 8
Performing an ISSU step by step· 13
Network configuration· 13
Procedure· 14
Configuring the IRF fabric· 14
Performing an ISSU· 16
References· 22
Introduction
H3C data center switches support ISSU in IRF mode. ISSU upgrades the Comware software with a minimum amount of downtime.
ISSU
In-Service Software Upgrade (ISSU) upgrades the Comware software with a minimum amount of downtime. This upgrade method is highly reliable.
Unless otherwise stated, the term "upgrade" refers to both software upgrade and downgrade in ISSU.
The Comware software includes the following types of images: boot image, system image and feature images. You can use ISSU to upgrade the images separately.
You can perform an ISSU in one step or step by step. A one-step ISSU enables you to start and finish an ISSU by using a single command. A step-by-step ISSU requires multiple steps but you can monitor the status and quit or roll back the upgrade during the ISSU.
IRF
The Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. It offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
The IRF technology provides the hardware basis for ISSU.
During an ISSU, follow these restrictions and guidelines:
·     Do not perform any of the following tasks:
¡     Reboot the device.
¡     Perform tasks that are irrelevant to the ISSU, such as modifying the configuration and displaying information.
¡     Modify, delete, or rename image files.
·     For better service continuity during a step-by-step ISSU, strictly follow the recommended ISSU procedure. Make sure a step is completed before you proceed to the next step.
·     You may use issu commands to upgrade all or some of the software images. If you are upgrading only some of the images, make sure the new images are compatible with the images that are not to be upgraded. The upgrade will fail if a conflict exists.
After an ISSU, you must log in to the device again before you can use the changed or added commands.
To perform a successful ISSU, make sure all requirements listed in Table 1 are met.
Table 1 Preparation requirements
Item
Requirements
Example (key information only)
IRF
Verify that all member devices are operating correctly.
<Sysname> display irf
MemberID  Slot  Role    Priority  CPU-MacDescription
 *+1      0     Master  1         00e0-fc0f-8c05  ---
   2      0     Standby 1         00e0-fc0f-8c35  ---
Verify that the IRF bridge MAC address is enabled to be permanent or remain unchanged for 12 minutes after the address owner leaves. If not, execute the irf mac-address persistent { always | timer } command.
Mac persistent              : always
Verify that all member devices are operating in the same system operating mode. Use the system-working-mode command to change the settings as required.
<Sysname> display system-working-mode
The current system working mode is advance.
Verify that all member devices are using the same hardware resource operating mode. Use the hardware-resource command to change the settings as required.
<Sysname> display hardware-resource tcam
Default         Current         Next
  NORMAL          ROUTING         ROUTING
<Sysname> display hardware-resource vxlan
  L2GW            L3GW            L3GW
Hardware
Verify that the CPU usage is lower than the alarm thresholds on each member device. As a best practice, make sure the CPU usage is lower than the recovery threshold.
<Sysname> display cpu-usage
Chassis 1 Slot 0 CPU 0 CPU usage:
       3% in last 5 seconds
       2% in last 1 minute
       2% in last 5 minutes
<Sysname> display cpu-usage configuration
CPU usage monitor is enabled.
Current monitor interval is 60 seconds.
Current severe alarm threshold is 99%.
Current minor alarm threshold is 80%.
Current recovery threshold is 60%.
Verify that the free memory space is more than the alarm thresholds on each member device. As a best practice, make sure the free memory space is more than the normal state threshold.
<Sysname> display memory
Memory statistics are measured in KB:
Chassis 1 Slot 0:
             Total      Used      Free    Shared   Buffers    Cached   FreeRatio
Mem:      16337812  4163660  12174152         0      8392   2145168       87.6%
-/+ Buffers/Cache: 2010100  14327712
Swap:            0       0         0
<Sysname> display memory-threshold
Memory usage threshold: 100%
Free memory threshold:
    Minor: 256M
    Severe: 192M
    Critical: 128M
    Normal: 320M
    Early-warning: 384M
    Secure: 448M
Current memory state: Normal
Verify that all fan trays are in Normal state.
<Sysname> display fan
 Chassis 1:
 Fan-tray 1:
 Status    : Normal
 Fan Type  : LSXM108XFAN
 Fan number: 3
 Fan mode  : Auto
 Airflow Direction: Front-to-back
 Fan  Speed(rpm)
  1   5222
  2   5315
  3   5110
Verify that all power supplies are in Normal state.
<Sysname> display power
 Chassis 1:
PowerID State     InPower(W)  Current(A)  Voltage(V)  OutPower(W)     Type
  1      Normal      2400        7.25       53.80       390.05     PSR2400-54A
  9      Normal      2400        7.00       53.83       376.81     PSR2400-54A
  10     Normal      2400        6.00       53.82       322.92     PSR2400-54A
Information about reserved power:
  Slot  Status  Power(W)   Remarks
   0    Normal     34      Reserved for MPU
   1    Absent     34      Reserved for MPU
   3    Normal   1050      Powered on
  14    Normal    691      Powered on
Verify that the temperature is lower than the high-temperature warning threshold on each component.
<Sysname> display environment
System temperature information (degree centigrade):
 Chassis  Slot  Sensor    Temperature  Lower  Warning  Alarm  Shutdown
 1        0     inflow  1 26           0      48       60     NA
 1        0     hotspot 1 27           0      75       90     NA
 1        3     hotspot 1 27           0      75       90     95
 1        3     hotspot 2 28           0      75       90     95
 1        3     hotspot 3 27           0      75       90     95
 1        3     hotspot 4 30           0      75       90     95
 1        22    hotspot 1 51           0      75       90     95
 1        22    hotspot 2 46           0      75       90     95
 1        22    hotspot 3 37           0      75       90     95
Verify that all ports are forwarding traffic correctly.
<Sysname> display counters rate inbound interface
Usage: Bandwidth utilization in percentage
Interface            Usage (%)   Total (pps)   Broadcast (pps)   Multicast (pps)
FGE1/0/0/1                   0         57863                --                --
FGE1/0/0/2                   0         33070                --                --
FGE1/0/0/3                   0         32974                --                --
FGE1/0/0/4                   0         24992                --                --
Verify that the number of packets with CRC errors is not increasing.
<Sysname> display interface | include CRC
         0 CRC, 0 frame, 0 overruns, 0 aborts
         0 CRC, 0 frame, - overruns, 0 aborts
input:   0 input errors,- runts,- giants,- throttles,0 CRC
Aggregation
Identify the number of selected ports and the number of unselected ports
<Sysname> display link-aggregation summary
Aggregation Interface Type:
BAGG -- Bridge-Aggregation, BLAGG -- Blade-Aggregation, RAGG -- Route-Aggregatio
n, SCH-B -- Schannel-Bundle
Aggregation Mode: S -- Static, D -- Dynamic
Actor System ID: 0x8000, 3c8c-4002-e79f
AGG        AGG   Partner ID              Selected  Unselected  Individual  Share
Interface  Mode                          Ports     Ports       Ports       Type
BAGG11     D     0x8000, 0000-0000-0000  0         1           0           Shar
BAGG21     D     0x8000, 1cab-3495-9e3b  6         0           0           Shar
Verify that all member ports in dynamic aggregation groups use the long LACP timeout interval.
N/A
Services
Enable GR or NSR for protocols including LDP, RSVP, OSPF, ISIS, BGP, and FSPF.
N/A
Disable BFD for protocols including LDP, RSVP, OSPF, ISIS, RIP, BGP, VRRP, and NQA.
N/A
Version
Read the software release notes. Make sure ISSU is supported for upgrading the current software version to the new software version.
N/A
Use ISSU to upgrade the software running on S12500X-AF devices, for example, from Release 2710 to Release 2712.
As shown in Figure 1, configure the two switches to form an IRF fabric. Use ISSU to upgrade the software from Release 2710 to Release 2712. The two software versions are compatible.
Figure 1 Network diagram
Logging in to the device
# Log in to the device by using Telnet or the console port.
Configuring IRF member devices
1.     Configure Device A:
# Assign member priority 2 to Device A.
[DeviceA] irf member 1 priority 2
# Bind FortyGigE 1/1/0/1 to IRF-port 1/1.
[DeviceA] interface FortyGigE 1/1/0/1
[DeviceA-FortyGigE1/1/0/1] shutdown
[DeviceA-FortyGigE1/1/0/1] quit
[DeviceA] irf-port 1/1
[DeviceA-irf-port1/1] port group interface FortyGigE 1/1/0/1
[DeviceA-irf-port1/1] quit
[DeviceA-FortyGigE1/1/0/1] undo shutdown
[DeviceA-FortyGigE1/1/0/1] save
# Activate the IRF port.
[DeviceA] irf-port-configuration active
[DeviceB] quit
2.     Configure Device B:
# Change the ID of Device B from 1 to 2.
[DeviceB] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]:y
# Reboot Device B.
[DeviceB] reboot
# Assign member priority 1 to Device B.
[DeviceB] irf member 1 priority 1
# Bind FortyGigE 2/1/0/1 to IRF-port 2/2.
[DeviceB] interface FortyGigE 2/1/0/1
[DeviceB-FortyGigE2/1/0/1] shutdown
[DeviceB-FortyGigE2/1/0/1] quit
[DeviceB] irf-port 2/2
[DeviceB-irf-port2/2] port group interface FortyGigE 2/1/0/1
[DeviceB-irf-port2/2] quit
[DeviceB-FortyGigE2/1/0/1] undo shutdown
[DeviceB-FortyGigE2/1/0/1] save
[DeviceB] irf-port-configuration active
[DeviceB] quit
Displaying device information
# Display device information.
<DeviceA> display device
Slot   Type                State    Subslot  Soft Ver             Patch Ver
1/0    LSXM1SUPB1          Master   0        S12508X-AF-2710      None
1/1    NONE                Absent   0        NONE                 None
1/2    NONE                Absent   0        NONE                 None
1/3    LSXM1QGS36HB1       Normal   0        S12508X-AF-2710      None
1/4    NONE                Absent   0        NONE                 None
1/5    NONE                Absent   0        NONE                 None
1/6    NONE                Absent   0        NONE                 None
1/7    NONE                Absent   0        NONE                 None
1/8    NONE                Absent   0        NONE                 None
1/9    NONE                Absent   0        NONE                 None
1/10   NONE                Absent   0        NONE                 None
1/11   NONE                Absent   0        NONE                 None
1/12   NONE                Absent   0        NONE                 None
1/13   NONE                Absent   0        NONE                 None
1/14   LSXM1SFH08D1        Normal   0        S12508X-AF-2710      None
1/15   NONE                Absent   0        NONE                 None
2/0    LSXM1SUPB1          Slave    0        S12508X-AF-2710      None
2/1    NONE                Absent   0        NONE                 None
2/2    NONE                Absent   0        NONE                 None
2/3    LSXM1QGS36HB1       Normal   0        S12508X-AF-2710      None
2/4    NONE                Absent   0        NONE                 None
2/5    NONE                Absent   0        NONE                 None
2/6    NONE                Absent   0        NONE                 None
2/7    NONE                Absent   0        NONE                 None
2/8    NONE                Absent   0        NONE                 None
2/9    NONE                Absent   0        NONE                 None
2/10   NONE                Absent   0        NONE                 None
2/11   NONE                Absent   0        NONE                 None
2/12   NONE                Absent   0        NONE                 None
2/13   NONE                Absent   0        NONE                 None
2/14   LSXM1SFH08D1        Normal   0        S12508X-AF-2710      None
2/15   NONE                Absent   0        NONE                 None
The command output indicates that the two devices have formed an IRF fabric. Chassis 1 is the master and Chassis 2 is the subordinate member. The two members are operating correctly.
Performing an ISSU
Verifying that the member devices have sufficient storage space
# View the amount of free storage space on member devices.
·     On the master:
<DeviceA> dir chassis1slot0#flash:/
Directory of flash:
   0 -rw-        2901 Jan 01 2011 03:13:38   210235A1UMH1610000122017011911451076132.ak
   1 -rw-   120552448 Jan 02 2011 11:37:58   R2710.ipe
   2 -rw-      118386 Jan 01 2011 02:43:16   diag_A_B_C_20110101-021505.tar.gz
   3 -rw-      104500 Jan 01 2011 00:29:18   diag_H3C_20110101-002803.tar.gz
   4 -rw-      113895 Jan 01 2011 01:11:50   diag_TD2+_20110101-011053.tar.gz
   5 drw-           - Jan 01 2011 00:01:13   diagfile
   6 -rw-         512 Jan 01 2011 01:00:05   fd8ef19a214ea12039a2f5ac6ef936fd.cfg
   7 -rw-        4086 Jan 02 2011 10:52:18   ifindex.dat
   8 -rw-         238 Jan 01 2011 11:05:44   lauth.dat
   9 drw-           - Jan 01 2011 03:14:28   license
  10 drw-           - Jan 01 2011 05:18:02   logfile
  11 drw-           - Jan 01 2011 01:02:09   ovsdb
  12 drw-           - Jan 01 2011 11:05:58   pkey
  13 drw-           - Jan 01 2011 11:05:50   pki
  14 -rw-    14478336 Jan 01 2011 10:38:36   boot-e2601.bin
  15 -rw-    14476288 Jan 01 2011 10:52:24   boot-r2710.bin
  16 -rw-   102051840 Jan 01 2011 10:44:11   system-e2601.bin
  17 -rw-   106068992 Jan 01 2011 10:57:47   system-r2710.bin
  18 drw-           - Jan 01 2011 00:01:13   seclog
  19 -rw-       15632 Jan 02 2011 10:52:25   startup.cfg
  20 -rw-      313105 Jan 02 2011 10:52:26   startup.mdb
  21 drw-           - Jan 01 2011 03:08:27   test
  22 -rw-      163053 Jan 01 2011 10:45:18   test1.tar.gz
  23 -rw-      149436 Jan 01 2011 10:46:32   test2.tar.gz
  24 dr--           - Jan 01 2011 00:49:46   versionInfo
  25 -rw-        3844 Jan 01 2011 03:26:03   vlan.txt
  26 -rw-        4214 Jan 01 2011 03:01:40   xinjianshiyan.txt
524288 KB total (170948 KB free)
·     On the subordinate member:
<DeviceA> dir chassis2slot0#flash:/
Directory of flash:
The command output shows the amount of free storage space on each member device.
# Compare the sizes of the upgrade image files with the amount of free storage space. If the free storage space is insufficient, continue with the next step to delete unused files to release more storage space.
# Delete unused files on the member devices.
·     On the master:
<DeviceA> delete /unreserved chassis1slot0#flash:/r2710.ipe
The file cannot be restored. Delete flash:/r2710.ipe? [Y/N]:y
Deleting the file permanently will take a long time. Please wait...
Deleting file flash:/r2710.ipe... Done.
<DeviceA> delete /unreserved chassis2slot0#flash:/r2710.ipe
·     The delete /unreserved file command deletes a file permanently. The file cannot be restored.
·     The delete file command (without /unreserved) moves a file to the recycle bin. The file is still using storage space. To delete the file from the recycle bin, you must execute the reset recycle-bin command in the directory where the file resided.
Downloading the upgrade file to the master
You can use FTP or TFTP to download the upgrade file. In this example, FTP is used and the device acts as the FTP client. The PC acts as the FTP server.
1.     Run the FTP server program on the PC. Configure a user and set the password. Specify the working directory and save the upgrade file to the directory. The IP address of the PC is 2.2.2.2.
The device is not shipped with an FTP server program. You must purchase and install an FTP server program separately.
2.     Make sure the device and PC can reach each other. (Details not shown.)
3.     Download the upgrade file to the root directory of the default file system on the master. In this example, the upgrade file is R2712.ipe.
# Log in to the FTP server from the IRF fabric.
<DeviceA> ftp 2.2.2.2
Connected to 2.2.2.2 (2.2.2.2).
User (2.2.2.2:(none)):username                       ---Enter the username.
Password:                                            ---Enter the password.
230 Logged in successfully
Remote system type is MSDOS.
ftp>
# Set the file transfer mode to binary. The default file transfer mode is binary.
ftp> binary
200 Type is Image (Binary)
# Download upgrade file R2712.ipe to the root directory of the default file system on the master.
ftp> get r2712.ipe
227 Entering Passive Mode (2,2,2,2,7,100)
150 "C:\r2712.ipe " file ready to send (385 bytes) in in IMAGE / Binary mode
226 Transfer finished successfully.
74948608 bytes received in 35.974 seconds (896.00 kbyte/s)
ftp> bye
221 Windows FTP Server (WFTPD, by Texas Imperial Software) says goodbye
1.     Verify that the IRF fabric is in Stable state, that is, the State field in the output from the display system stable state command displays Stable.
<DeviceA> display issu state
ISSU state: Init
Compatibility: Unknown
Work state: Normal
Upgrade method: Chassis by chassis
Upgraded chassis: None
Current upgrading chassis: None
Current version list:
  boot: 7.1.070, Release 2710
  system: 7.1.070, Release 2710
Current software images:
  flash:/boot-r2710.bin
  flash:/system-r2710.bin
<DeviceA> display system stable state
System state     : Stable
Redundancy state : Stable
Chassis    Slot    CPU    Role       State
1          0       0      Active     Stable
1          3       0      Other      Stable
1          14      0      Other      Stable
2          0       0      Active     Stable
2          3       0      Other      Stable
2          14      0      Other      Stable
The command output shows that both IRF member devices are in Stable state. You can start an ISSU.
2.     Perform a one-step ISSU.
In IRF mode, an ISSU is performed chassis by chassis. Execute the one-step ISSU command on the subordinate member.
<DeviceA> issu one-step file ipe flash:/r2712.ipe chassis 2
This operation will delete the rollback point information for the previous upgrade and maybe get unsaved configuration lost. Continue? [Y/N]:y
Verifying the file flash:/r2712.ipe on chassis 2 slot 0............Done.
Decompressing file boot-r2712.bin to flash:/boot-r2712.bin....................Done.
Decompressing file system-r2712.bin to flash:/system-r2712.bin.......................................................................................................................................Done.
Decompression completed.
Do you want to delete flash:/r2712.ipe now? [Y/N]:n
This operation might take several minutes, please wait...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................
The command performs the following operations:
a.     Perform an reboot upgrade on the subordinate member.
b.     Perform a switchover.
c.     Perform an reboot upgrade on the original master.
3.     Verify that the ISSU is finished.
ISSU state: Init
Work state: Normal
Upgrade method: Chassis by Chassis
Current upgrading Chassis: None
  boot: 7.1.070, Release 2712
  system: 7.1.070, Release 2712
If the ISSU state field displays Init, the ISSU is finished.
4.     Display device information.
1/0    LSXM1SUPB1          Slave    0        S12508X-AF-2712      None
1/3    LSXM1QGS36HB1       Normal   0        S12508X-AF-2712      None
1/14   LSXM1SFH08D1        Normal   0        S12508X-AF-2712      None
2/0    LSXM1SUPB1          Master   0        S12508X-AF-2712      None
2/3    LSXM1QGS36HB1       Normal   0        S12508X-AF-2712      None
2/14   LSXM1SFH08D1        Normal   0        S12508X-AF-2712      None
The command output shows that the original subordinate member is now the master. The software version has been upgraded from 2710 to 2712.
As shown in Figure 2, configure the two switches to form an IRF fabric. Use ISSU to upgrade the software from Release 2710 to Release 2712. The two software versions are compatible.
Figure 2 Network diagram
[DeviceB] quit
# Reboot Device B.
[DeviceB] reboot
[DeviceB] quit
Performing an ISSU
·     On the master:
Directory of flash:
Directory of flash:
·     On the master:
ftp>
ftp> binary
ftp> get r2712.ipe
ftp> bye
1.     Verify that the device is in Stable state, that is, the State field in the output from the display system stable state command displays Stable.
ISSU state: Init
Work state: Normal
1          0       0      Active     Stable
1          3       0      Other      Stable
1          14      0      Other      Stable
2          0       0      Active     Stable
2          3       0      Other      Stable
2          14      0      Other      Stable
2.     Upgrade the startup software images and specify the images as the main startup software images on the subordinate member.
In IRF mode, an ISSU is performed chassis by chassis. Start an ISSU from the subordinate member.
<DeviceA> issu load file ipe flash:/r2712.ipe chassis 2
Verifying the file flash:/r2712.ipe on chassis 2 slot 0...........Done.
Decompressing file boot-r2712.bin to flash:/boot-r2712.bin.....................Done.
Decompressing file system-r2712.bin to flash:/system-r2712.bin...............................................................................................................................................Done.
Copying file flash:/boot-r2712.bin to chassis2slot0#flash:/boot-r2712.bin.....................................Done.
Copying file flash:/system-r2712.bin to chassis2slot0#flash:/system-r2712.bin.............................................................................................................................................................................................................................................................................Done.
Verifying the file flash:/boot-r2712.bin on chassis 2 slot 0.....Done.
Verifying the file flash:/system-r2712.bin on chassis 2 slot 0.........................Done.
Identifying the upgrade methods...Done.
  Running Version             New Version
  Release 2710                Release 2712
  Chassis    Slot             Upgrade Way
  2          0                Reboot
This operation might take several minutes, please wait.......Done.
3.     Verify that the system is in a stable state.
IMPORTANT
IMPORTANT:
After executing the issu load command, you must make sure the system enters a stable state before you proceed to the next step. If the system reported an error in the previous step, verify that the system is in a stable state and then use the issu rollback command to roll back the upgrade.
ISSU state: Loaded
Compatibility: Compatible
Work state: Normal
Upgraded chassis:
  chassis 2
Previous version list:
Previous software images:
Upgrade version list:
Upgrade software images:
The command output shows that the ISSU process is in Loaded state (a stable state) and is waiting for a switchover. Chassis 2 has been upgraded from Release 2710 to Release 2712 and Chassis 1 has not.
4.     Perform a master/subordinate switchover.
<DeviceA> issu run switchover
  Chassis    Slot             Switchover Way
  1          0                Master subordinate switchover
5.     Verify that the system is in a stable state.
IMPORTANT
IMPORTANT:
After executing the issu run switchover command, you must make sure the system enters a stable state before you proceed to the next step. If the system reported an error in the previous step, verify that the system is in a stable state and then use the issu rollback command to roll back the upgrade.
ISSU state: Switchover
Work state: Normal
Upgraded chassis:
  chassis 2
The command output shows that the ISSU process is in Switchover state (a stable state). A master/subordinate switchover is finished and the ISSU process is waiting for a commit operation. Chassis 2 has been upgraded from Release 2710 to Release 2712 and Chassis 1 has not.
6.     Upgrade the original master.
<DeviceA> issu commit chassis 1
  1          0                Reboot
This operation might take several minutes, please wait......Done.
The automatic rollback timer starts when you execute the issu run switchover command. By default, the automatic rollback timer is 45 minutes. Please execute the issu commit command before the timer expires. After using this command for one member, wait for the member to restart and join the IRF fabric before using this command for another member.
7.     Verify that the ISSU is finished.
ISSU state: Init
Work state: Normal
References
For more information about ISSU, see Fundamentals Configuration Guide.
For more information about IRF, see IRF Configuration Guide.
