Title | Size | Downloads |
00-About the H3C S10500 Configuration Guides-book.rar | 28.78 MB |
About the H3C S10500 configuration guides
The H3C S10500 configuration guides describe the software features for the H3C S10500 Switch Series and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply the software features to different network scenarios.
Configuration guide |
Content |
Describes how to use the command line interface of the switch, log in to and set up the switch, and use the basic management functions. This guide includes: · CLI · RBAC · Login management · FTP and TFTP · File system management · Configuration file management · Software upgrade · ISSU · Emergency shell configuration · Automatic configuration · Device management · Tcl · Management with BootWare · Python · License management |
Covers the configuration of the H3C proprietary virtual technologies. This guide includes: · IRF · MDC |
Covers the configuration of various interfaces. This guide includes: · Bulk interface configuration · Ethernet interface · Loopback, null, and inloopback interface |
Covers Layer 2 technologies and features used on a LAN switched network, including VLAN technology, port isolation, and spanning tree. You can use these features to divide broadcast domains, remove Layer 2 loops, isolate users within a VLAN, remark VLAN tags, implement VLAN VPNs over the Internet, and so on. This guide includes: · MAC address table · Ethernet link aggregation · Port isolation · VLAN · MVRP · QinQ · VLAN mapping · Loop detection · Spanning tree · LLDP · L2PT · Service loopback group |
Describes IP addressing (including static and dynamic IPv4 and IPv6 address assignment), network performance optimization, ARP, and interoperation between IPv4 and IPv6. This guide includes: · ARP · IP addressing · DHCP · DNS · IP forwarding basics · Fast forwarding · Adjacency table · IRDP · IP performance optimization · UDP helper · IPv6 basics · DHCPv6 · IPv6 fast forwarding · Tunneling · GRE |
Covers the routing technologies for IPv4 and IPv6 networks of different sizes, route filtering, route control, and policy-based routing. This guide includes: · Basic IP routing · Static routing · RIP · OSPF · IS-IS · BGP · Policy-based routing · IPv6 static routing · RIPng · OSPFv3 · IPv6 IS-IS · IPv6 policy-based routing · Routing policy · DCN |
Covers Layer 3 IPv4 multicast protocols (IGMP, PIM, and MSDP), Layer 3 IPv6 multicast protocols (MLD and IPv6 PIM), Layer 2 IPv4 multicast protocols (IGMP snooping, PIM snooping, and multicast VLAN), and Layer 2 IPv6 multicast protocols (MLD snooping, IPv6 PIM snooping, and IPv6 multicast VLAN). This guide includes: · Multicast overview · IGMP snooping · Multicast VLAN · Multicast routing and forwarding · Multicast VPN · MLD snooping · IPv6 multicast VLAN |
Describes fundamentals and configuration of MPLS and its extended functions. This guide includes: · Basic MPLS · Static LSP · LDP · MPLS TE · Static CRLSP · RSVP · Tunnel policy · MPLS L3VPN · MPLS L2VPN · VPLS · MPLS OAM · MCE |
Describes how to classify traffic with ACLs, and allocate network resources and manage congestions with QoS technologies to improve network performance and network use efficiency. You can use ACLs to help other function modules (such as QoS and IP routing) classify or filter traffic. This guide includes: · ACL · QoS · Time range |
Covers security features. The major security features available on the switch include identity authentication, access security, secure management, and attack protection. This guide includes: · AAA · 802.1X · MAC authentication · Portal · Port security · Password control · Keychain · Public key management · PKI · IPsec · SSH · SSL · Attack detection and prevention · TCP attack prevention · IP source guard · uRPF · MFF · FIPS · MACsec · 802.1X client · Web authentication · Triple authentication |
Describes high availability technologies and features available on the switch for failure detection and failover. Failure detection technologies focus on fault detection and isolation. Failover technologies focus on network recovery. This guide includes: · Ethernet OAM · CFD · DLDP · RRPP · ERPS · Smart Link · Monitor Link · VRRP · BFD · Track · Process placement |
Describes features that help you manage and monitor your network, for example, manage system events, sample packets, assess network performance, synchronize time among network devices, and test network connectivity. This guide includes: · System maintenance and debugging · NQA · PoE · NETCONF · EAA · Process monitoring and maintenance · Sampler · Mirroring · sFlow · Information center · GOLD · Packet capture · VCF fabric |
Describes how to configure the H3C open application platform (OAP) module connected to your switch to exchange information between your switch and the OAP module. This configuration guide includes: · OAP |
Describes Fibre Channel over Ethernet (FCoE) fundamentals and configuration. In an FCoE solution, the server uses an FCoE-capable Ethernet adapter. The FCoE switch (FCoE forwarder) integrates the functions of both the traditional IP switch and the FC switch. The FCoE solution reduces the number of network adapters, switches, and cables, and reduces the network operation and maintenance workload. |
Describes TRILL fundamentals and configuration. TRansparent Interconnection of Lots of Links (TRILL) is suitable for large flat Layer 2 networks in data centers. |
Describes how to enable Edge Virtual Bridging (EVB), configure negotiation parameters, and establish S-channels between the EVB station and the EVB bridge. |
Describes how to use the H3C MAC-in-IP technology Ethernet Virtual Interconnect (EVI) to provide Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. EVI enables dynamic allocation and management of resources and transparent migration of virtual machines between network sites. |
Describes OpenFlow fundamentals and configuration, including OpenFlow instance, controllers for an OpenFlow switch, OpenFlow timers, and dynamic MAC address support. OpenFlow separates the data forwarding and routing decision functions. A controller makes routing decisions and assigns flow table entries to an OpenFlow switch. An OpenFlow switch matches and forwards packets by using the flow table entries obtained from a controller. |
Describes VXLAN fundamentals and configuration. Virtual eXtensible LAN (VXLAN) is a MAC-in-UDP technology that provides Layer 2 connectivity between distant network sites across an IP network. |
Describes EVPN fundamentals and configuration. Ethernet Virtual Private Network (EVPN) is a Layer 2 VPN technology that provides both Layer 2 and Layer 3 connectivity between distant network sites across an IP network. EVPN uses MP-BGP in the control plane and VXLAN in the data plane. |
