H3C FS5100-EI Switch Series Hardware Information and Specifications-6W101
HomeSupportSwitchesH3C FS5100-EI Switch SeriesProduct LiteratureHardware Information & SpecificationsH3C FS5100-EI Switch Series Hardware Information and Specifications-6W101
01-Hardware Information and Specifications.htm
1 Product models and technical specifications
Product models
This document is applicable to the FS5100-EI switch series. Table1-1 describes the FS5100-EI switch series models.
Table1-1 FS5100-EI switch series models
Switch series
Model
Product code
FS5100-EI series
Non-PoE switch
FS5100-12S-EI
LS-FS5100-12S-EI
FS5100-12MS-EI
LS-FS5100-12MS-EI
FS5100-20MS-EI
LS-FS5100-20MS-EI
FS5100-52F-EI-PS
LS-FS5100-52F-EI-PS
FS5100-8T2RS-EI
LS-FS5100-8T2RS-EI
FS5100-8T2RX-EI
LS-FS5100-8T2RX-EI
PoE switch
FS5100-8S-PWR-EI
LS-FS5100-8S-PWR-EI
FS5100-12S-PWR-EI
LS-FS5100-12S-PWR-EI
FS5100-12MS-PWR-EI
LS-FS5100-12MS-PWR-EI
FS5100-20MS-PWR-EI
LS-FS5100-20MS-PWR-EI
FS5100-8P2RS-EI
LS-FS5100-8P2RS-EI
FS5100-8P2RX-EI
LS-FS5100-8P2RX-EI
Technical specifications
Non-PoE switch models
Table1-2 Technical specifications for non-PoE switch models (1)
Item
FS5100-12S-EI
FS5100-12MS-EI
FS5100-20MS-EI
FS5100-52F-EI-PS
Dimensions (H × W × D)
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
43.6 × 294 × 179 mm (1.72 × 11.57 × 7.05 in)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
1.3 kg (2.87 lb)
1.3 kg (2.87 lb)
1.6 kg (3.53 lb)
7 kg (15.43 lb)
Console port
1 × serial console port
10/100/1000BASE-T autosensing Ethernet port
8
8
16
2 (The two ports form combo interfaces with their corresponding SFP ports, respectively.)
5G/2.5G/1000/100BASE-T autosensing Ethernet port
N/A
2
2
N/A
SFP port
N/A
N/A
N/A
48 (The two highest-numbered SPF ports form combo interfaces with their corresponding 10/100/1000 BASE-T autosensing Ethernet ports, respectively.)
SFP+ port
4
2
2
4
Power interface (PI)
N/A
N/A
N/A
·          4 × 56 V PIs
·          200 W load per PI
·          A maximum power supply distance of 200 m (656.17 ft)
Input voltage
·          Rated voltage range: 100 VAC to 240 VAC @ 50 or 60 Hz
·          Max. voltage range: 90 VAC to 264 VAC@ 47 to 63 Hz
Minimum power consumption
9 W
10 W
11 W
·          One power supply: 38 W
·          Two power supplies: 49 W
Maximum power consumption
15 W
16 W
20 W
·          One power supply: 1000 W
·          Two power supplies: 1000 W
Melting current of power supply fuse
3.15 A/250 V
2 A/250 V
2 A/250 V
16 A/250 V
Cooling system
Passive cooling
Passive cooling
Passive cooling
Built-in fans with left-to-right airflow
Operating temperature
–5ºC to +45ºC (23°F to 113°F)
Note:
The maximum acceptable temperature decreases by 0.33°C (32.59°F) for every 100 m (328.08 ft) increase in altitude from 0 m (0 ft).
Operating humidity
5% to 95%, noncondensing
Installation compliance
UL62368-1/EN62368-1/IEC62368-1/UL60950-1/IEC60950-1/GB4943.1
Table1-3 Technical specifications for non-PoE switch models (2)
Item
FS5100-8T2RS-EI
FS5100-8T2RX-EI
27 × 220 × 143.9 mm (1.06 × 8.66 × 5.67 in)
Weight (excluding the power adapter)
0.8 kg (1.76 lb)
0.8 kg (1.76 lb)
Console port
1
1
PSFP photoelectric hybrid port
2
N/A
PSFP+ photoelectric hybrid port
N/A
2
8
8
Input voltage
Power adapter input:
·          Rated voltage range: 100 VAC to 240 VAC @ 50/60 Hz
·          Max voltage range: 90 VAC to 264 VAC @ 47 to 63 Hz
PoE input voltage range: 44 VDC to 57 VDC
Note:
PoE input can supply power for the switch through a photoelectric hybrid port on the switch or the terminal block.
The switch supports power adapter input and PoE input. Do not use both the input methods. If you use both the input methods, only the power adapter input takes effect.
Power consumption (static)
Single-port PoE input: 6.6 W
Dual-port PoE input: 8.7 W
Power adapter input: 5.5 W
Single-port PoE input: 9.2 W
Dual-port PoE input: 11 W
Power adapter input: 7.1 W
Power consumption (typical)
Single-port PoE input: 10.7 W
Dual-port PoE input: 11.5 W
Power adapter input: 9.4 W
Single-port PoE input: 12.6 W
Dual-port PoE input: 14.3 W
Power adapter input: 11.2 W
Power consumption (fully loaded)
Single-port PoE input: 11.3 W
Dual-port PoE input: 12.1 W
Power adapter input: 11.9 W
Single-port PoE input: 13.5 W
Dual-port PoE input: 14.5 W
Power adapter input: 13.3 W
Chassis leakage current compliance
UL62368-1/EN62368-1/IEC62368-1/GB4943.1
Cooling system
Passive cooling
3.15 A/250 V
Note:
Operating humidity
Fire resistance compliance
UL62368-1/EN62368 -1/IEC62368 -1/GB4943.1
PoE switch models
Table1-4 Technical specifications for PoE switch models (1)
Item
FS5100-8S-PWR-EI
FS5100-12S-PWR-EI
FS5100-12MS-PWR-EI
FS5100-20MS-PWR-EI
Weight
1.5 kg (3.31 lb)
1.5 kg (3.31 lb)
1.5 kg (3.31 lb)
2 kg (4.41 lb)
Console port
4
8
8
16
N/A
N/A
2
2
SFP+ port
4
4
2
2
Input voltage
·          Maximum voltage range: 90 VAC to 264 VAC @ 47 Hz to 63 Hz
Maximum PoE power per port
30 W
30 W
30 W (10/100/1000BASE-T autosensing Ethernet ports 1 and 2 do not support PoE.)
Total PoE power
65 W
125 W
125 W
125 W
10 W
12 W
12 W
13 W
Power consumption (fully configured, including PoE power)
90 W
160 W
160 W
160 W
3.15 A/250 V
6.3 A/250 V
6.3 A/250 V
6.3 A/250 V
Cooling system
Passive cooling
Passive cooling
Passive cooling
Passive cooling
Note:
Operating humidity
Table1-5 Technical specifications for non-PoE switch models (2)
Item
FS5100-8P2RS-EI
FS5100-8P2RX-EI
1.2 kg (2.65 lb)
1.2 kg (2.65 lb)
Console port
1
1
PSFP port
2
N/A
PSFP+ port
N/A
2
8
8
Input voltage
Note:
The switch supports power adapter input or PoE input. Do not use both the input methods. If you use both the input methods, only the power adapter input takes effect.
Max PoE power per port
30 W
Total PoE power
PoE input: 60 W
Power adapter input: 125 W
Single-port PoE input: 7.5 W
Dual-port PoE input: 8.5 W
Power adapter input: 8.5 W
Single-port PoE input: 8.8 W
Dual-port PoE input: 10.1 W
Power adapter input: 10.6 W
Single-port PoE input: 11.2 W
Dual-port PoE input: 11.3 W
Single-port PoE input: 12.4 W
Dual-port PoE input: 13.4 W
Power adapter input: 14.2 W
Single-port PoE input: 71.2 W
Dual-port PoE input: 71.4 W
Power adapter input: 150 W
Single-port PoE input: 74.7 W
Dual-port PoE input: 76.2 W
Power adapter input: 153.5 W
Cooling system
Passive cooling
5 A/250 V
Note:
Operating humidity
2 Chassis views
FS5100-8T2RS-EI
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) PSFP port
(3) PoE port (terminal block)
(4) Console port (CONSOLE)
(5) Power adapter receptacle
(6) System status LED (SYS)
(7) PSFP port LED
(8) 10/100/1000BASE-T autosensing Ethernet port LED
When you install a common transceiver module on a PSFP port, use a PoE port to receive power. Each PSFP port has its corresponding PoE port.
Figure2-2 Rear panel
(1) Security slot
(2) Grounding screw
FS5100-8P2RS-EI
Figure2-3 Front panel
(2) PSFP port
(6) LED mode switching button
(7) 10/100/1000BASE-T autosensing Ethernet port LED
(8) PSFP port LED
(9) System status LED (SYS)
(10) Mode LED (MODE)
Figure2-4 Rear panel
(1) Grounding screw
FS5100-8T2RX-EI
Figure2-5 Front panel
(2) PSFP+ port
(7) PSFP+ port LED
When you install a common transceiver module on a PSFP+ port, use a PoE port to receive power. Each PSFP+ port has its corresponding PoE port.
Figure2-6 Rear panel
(1) Security slot
(2) Grounding screw
FS5100-8P2RX-EI
Figure2-7 Front panel
(2) PSFP+ port
(8) PSFP+ port LED
Figure2-8 Rear panel
(1) Grounding screw
FS5100-8S-PWR-EI
Figure2-9 Front panel
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP+ port LED
(4) System status LED (SYS)
(5) Mode LED (MODE)
(7) Console port (CONSOLE)
(8) SFP+ port
Figure2-10 Rear panel
(1) AC-input power receptacle
(2) Grounding screw
FS5100-12S-EI
Figure2-11 Front panel
(3) System status LED (SYS)
(4) SFP+ port LED
(5) Console port (CONSOLE)
(6) SFP+ port
Figure2-12 Rear panel
(2) Grounding screw
FS5100-12S-PWR-EI
Figure2-13 Front panel
(4) Mode LED (MODE)
(5) SFP+ port LED
(8) SFP+ port
Figure2-14 Rear panel
(2) Grounding screw
FS5100-12MS-EI
Figure2-15 Front panel
(2) 5G/2.5G/1000/100BASE-T autosensing Ethernet port
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(4) 5G/2.5G/1000/100BASE-T autosensing Ethernet port LED
(5) System status LED (SYS)
(6) SFP+ port LED
(8) SFP+ port
Figure2-16 Rear panel
(2) Grounding screw
FS5100-12MS-PWR-EI
Figure2-17 Front panel
(6) Mode LED (MODE)
(7) SFP+ port LED
(8) LED mode switching button
(9) Console port (CONSOLE)
(10) SFP+ port
Figure2-18 Rear panel
(2) Grounding screw
FS5100-20MS-EI
Figure2-19 Front panel
(4) SFP+ port LED
(6) 5G/2.5G/1000/100BASE-T autosensing Ethernet port LED
(8) SFP+ port
Figure2-20 Rear panel
(2) Grounding screw
FS5100-20MS-PWR-EI
Figure2-21 Front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(7) 5G/2.5G/1000/100BASE-T autosensing Ethernet port LED
(10) SFP+ port
Figure2-22 Rear panel
(2) Grounding screw
FS5100-52F-EI-PS
Figure2-23 Front panel
(1) SFP port LED
(2) SFP port
(6) Power supply 2 status LED (PWR2)
(7) Power supply 1 status LED (PWR1)
(9) SFP+ port
(10) SFP+ port LED
Figure2-24 Rear panel
(1) Grounding screw
(2) PI
(3) PI LED
(4) Removable power supply 1
(5) Removable power supply 2
The FS5100-52F-EI-PS switch has two power supply slots on the rear panel and came with power supply slot PWR1 empty and power supply slot PWR2 installed with a filler panel. You can install one or two power supplies as needed. In Figure2-24, two PSR920-54A-B power supplies are installed in the power supply slots.
3 Removable components
Only the FS5100-52F-EI-PS switch provides removable power supply slots, and you can use the PSR920-54A-B power supply to power the device.
One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy.
Table3-1 describes the power supply available for the FS5100-52F-EI-PS switch.
Table3-1 Power supply available for the FS5100-52F-EI-PS switch
Model
Item
Specification
Remarks
PSR920-54A-B
Rated input voltage
100 VAC to 240 VAC @ 50 Hz or 60 Hz
For more information about the power supply, see H3C PSR920-54A-B Power Supply User Manual-APW100.
Max input voltage
90 VAC to 290 VAC @ 47 Hz to 63 Hz
Max output power
920 W
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item
Specification
Connector type
RJ-45
Compliant standard
EIA/TIA-232
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·          Provides connection to an ASCII terminal.
·          Provides connection to the serial port of a local PC running terminal emulation program.
Available switch models
All switch models
Table4-2 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·          10 Mbit/s, half/full-duplex
·          100 Mbit/s, half/full-duplex
·          1000 Mbit/s, full-duplex
·          MDI/MDI-X, autosensing
Max transmission distance
100 m (328.08 ft)
All switch models
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
·          IEEE 802.3i
·          IEEE 802.3u,
·          IEEE 802.3ab
5G/2.5G/1000/100 BASE-T autosensing Ethernet port
Table4-3 5G/2.5G/1000/100 BASE-T autosensing Ethernet port specifications
Item
Connector type
RJ-45
·          100 Mbps, half/full-duplex
·          1 Gbps, full-duplex
·          2.5 Gbps, full-duplex
·          5 Gbps, full-duplex
·          5 G mode: 100 m (328.08 ft) over Category-5e or above twisted pair
·          2.5 G mode: 200 m (656.17 ft) over Category-5e or above twisted pair
·          1 G mode: 140 m (459.32 ft) over Category-5e or above twisted pair
·          100 M mode: 100 m (328.084 ft) over Category-5e or above twisted pair
The maximum transmission distance depends on the target device and the twisted pair quality.
FS5100-12MS-EI, FS5100-12MS-PWR-EI, FS5100-20MS-EI, and FS5100-20MS-PWR-EI
Transmission medium
Category-5e (or above) twisted pair cable
·          IEEE 802.3ab
·          IEEE 802.3an
PSFP port
A PSFP port can provide 1 Gbps data links and receive power from a power supply switch at the same time through a hybrid copper-fiber cable.
Table4-4 PSFP port specifications
Item
Available transceiver modules and cables
GE SFP transceiver modules and cables in Table4-5.
FS5100-8T2RS-EI, FS5100-8P2RS-EI
A PSFP port can provide 1 Gbps data links and receive PoE power at the same time only when it is installed with an SFP-GE-POE transceiver module.
Table4-5 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Central wavelength
Connector
Cable specifications
Modal bandwidth (MHz*km)
Max. transmission distance
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-POE
1310 nm
LC
SMF
N/A
10 km (6.21 miles)
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm multi-mode optical fiber
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm multi-mode optical fiber
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm single-mode fiber
N/A
10 km (6.21 miles)
50/125 µm multi-mode fiber
500/400
550 m (1804.46 ft)
62.5/125 µm multi-mode fiber
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310 nm
RX: 1490 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490 nm
RX: 1310 nm
SFP-GE-LH40-SM1310-BIDI
TX: 1310 nm
RX: 1550 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, and the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
SFP port
Table4-6 SFP port specifications
Item
Specification
GE SFP transceiver modules and cables in Table4-7.
FS5100-52F-EI-PS
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles), make sure the ambient temperature does not exceed 40°C (104°F).
Table4-7 GE SFP transceiver modules and cables
Central wavelength
Connector
Copper SFP transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.08 ft)
Fiber SFP transceiver module
SFP-GE-SX-MM850-A
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
N/A
10 km (6.21 miles)
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
N/A
40 km (24.86 miles)
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
9/125 μm single-mode fiber
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
N/A
100 km (62.14 miles)
TX: 1310 nm
RX: 1490 nm
LC
N/A
10 km (6.21 miles)
TX: 1490 nm
RX: 1310 nm
TX: 1310 nm
RX: 1550 nm
LC
N/A
40 km (24.86 miles)
TX: 1550 nm
RX: 1310 nm
SFP-GE-LH70-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
N/A
70 km (43.50 miles)
SFP-GE-LH70-SM1550-BIDI
TX: 1550 nm
RX: 1490 nm
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
·       As a best practice, use H3C SFP/SFP+ transceiver modules or cables for the SFP+ ports.
·       The H3C SFP/SFP+ transceiver modules and cables available for the SFP+ ports are subject to change over time. For the most up-to-date list of H3C SFP/SFP+ transceiver modules and SFP+ cables available for the SFP+ ports, contact your H3C sales representative or technical support engineer.
·       For the specifications of the H3C SFP/SFP+ transceiver modules and cables, see H3C Transceiver Modules User Guide.
PSFP+ port
A PSFP+ port can provide 1 Gbps or 10 Gbps data links and receive power from a power supply switch at the same time through a hybrid copper-fiber cable.
Table4-8 PSPF+ port specifications
Item
Specification
·          GE SFP transceiver modules and cables in Table4-5.
·          10-GE SFP+ transceiver modules in Table4-9.
·          SFP+ copper and fiber cables in Table4-10.
FS5100-8T2RX-EI, FS5100-8P2RX-EI
·          A PSFP+ port can provide 10 Gbps data links and receive PoE power at the same time only when it is installed with an SFP-XG-POE-MR transceiver module.
·          A PSFP+ port can provide 1 Gbps data links and receive PoE power at the same time only when it is installed with an SFP-GE-POE transceiver module.
Table4-9 10-GE SFP+ transceiver modules
Central wavelength
Connector
Fiber
SFP-XG-SX-MM850-D
850 nm
LC
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-POE-MR
1310 nm
LC
SMF
N/A
1.4 km (0.87 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LX-SM1270-BIDI
TX: 1270 nm
RX: 1330 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
TX: 1330 nm
RX: 1270 nm
SFP-XG-LH40-SM1270-BIDI
TX: 1270 nm
RX: 1330 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
TX: 1330 nm
RX: 1270 nm
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules and the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-10 SFP+ copper and fiber cables available for the SFP+ ports
Item
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
SFP+ port
Table4-11 SPF+ port specifications
Item
Specification
·          GE SFP transceiver modules and cables in Table4-7.
·          10-GE SFP+ transceiver modules in Table4-12.
·          SFP+ copper and fiber cables in Table4-13.
FS5100-8S-PWR-EI, FS5100-12S-EI, FS5100-12S-PWR-EI, FS5100-12MS-EI, FS5100-12MS-PWR-EI, FS5100-20MS-EI, FS5100-20MS-PWR-EI, FS5100-52F-EI-PS
Table4-12 10-GE SFP+ transceiver modules
Central wavelength
Connector
Fiber
SFP-XG-SX-MM850-D
850 nm
LC
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850 nm
LC
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850 nm
LC
2000
300 m (984.25 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550  nm
LC
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550 nm
LC
N/A
80 km (49.71 miles)
TX: 1270 nm
RX: 1330 nm
LC
N/A
10 km (6.21 miles)
TX: 1330 nm
RX: 1270 nm
TX: 1270 nm
RX: 1330 nm
LC
N/A
40 km (24.86 miles)
TX: 1330 nm
RX: 1270 nm
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
Table4-13 SFP+ copper and fiber cables available for the SFP+ ports
Item
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 10-GE SFP+ cable
(1) Connector
(2) Pull latch
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-14 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Flashing red (3 Hz)
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Power supply status LED
The FS5100-52F-EI-PS switch provides PWR1 and PWR2 LEDs on the front panel to indicate the operating status of the power supplies.
Table4-15 Removable power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on.
Off
No power supply is installed in the power supply slot.
Mode LED (MODE)
Each PoE switch provides a mode LED (MODE). The mode LED works in conjunction with the Ethernet port LEDs to indicate the operating state of the Ethernet ports and the switch.
You can use the LED mode switching button to change the indication of the mode LED.
Table4-16 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The Ethernet port LEDs are showing link state of the ports.
Flashing green
The Ethernet port LEDs are showing the PoE status of the ports.
Flashing yellow
The Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
SFP/SFP+ port LED
Table4-17 SFP/SFP+ port LED description
Status
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
·          No link is present on the port.
·          The mode LED is operating in PoE mode.
PSFP/PSFP+ port LED
Table4-18 PSFP/PSFP+ port LED description
Status
Mode LED
PSFP/PSFP+ port LED
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing yellow (IRF mode)
Steady green
The PSFP/PSFP+ port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
Autosensing Ethernet port LEDs
On a PoE switch, the Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table4-19 describes the Ethernet port LEDs on a PoE switch.
Table4-20 describes the Ethernet port LEDs on a non-PoE switch.
This section is available for the following Ethernet port LEDs:
·           10/100/1000BASE-T autosensing Ethernet port LEDs
·           5G/2.5G/1000BASE-T autosensing Ethernet port LEDs
Table4-19 Ethernet port LED description for PoE switch models
Mode LED status
Ethernet port LED status
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
·          The maximum PoE power provided by the port does not meet the power requirement of the PD.
·          PoE power supply overcurrent, overvoltage, or short-circuit has occurred.
·          The remaining power of the switch does not meet the power supply requirement of the port.
Steady yellow
The port has failed to supply power.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Steady green
The Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
Table4-20 Ethernet port LED description for non-PoE switch models
Steady green
Flashing green
Off
PI LED
The switch provides PI LEDs to indicate the operating status of the PIs.
Table4-21 PI LED description
LED mark
Status
OUT1
OUT2
OUT3
OUT4
On
The PI is outputting power correctly.
Off
Power output failure has occurred on the PI.
不同款型规格的资料略有差异, 详细信息请向具体销售和400咨询。 H3C保留在没有任何通知或提示的情况下对资料内容进行修改的权利!
