H3C ANT-2507P-S4 Directional Antenna Installation Guide-6W100
HomeSupportWireless​External AntennaInstall & UpgradeInstallation GuidesH3C ANT-2507P-S4 Directional Antenna Installation Guide-6W100
Download Book
H3C ANT-2507P-S4 directional antenna installation guide
Technical specifications
The ANT-2507P-S4 dual-band directional Wi-Fi antenna is designed for use in indoor environments. It is connected to the device through RP-SMA male connectors.
Figure 1 Antenna view
Table 1 Technical specifications
Item
ANT-2507P-S4
Frequency range
·     2400 MHz to 2500 MHz
·     5150 MHz to 5850 MHz
Polarization type
Horizontal and vertical
Gain
7 dBi
Horizontal beamwidth (HBW)
60 degrees
Vertical beamwidth (VBW)
35 degrees
Impedance
50 Ω
Voltage standing wave ratio (VSWR)
< 2.0
Maximum power
20 W
Connector
RP-SMA-J
Dimensions (H × W × D)
35 × 229 × 229 mm (1.38 × 9.02 × 9.02 in)
Weight (including the antenna casing)
0.43 kg (0.95 lb)
Figure 2 through Figure 5 show the horizontal and vertical radiation patterns.
Figure 2 2.4 GHz horizontal pattern
Figure 3 2.4 GHz vertical pattern
Figure 4 5 GHz horizontal pattern
Figure 5 5 GHz vertical pattern
Safety precautions
WARNING
WARNING!
·     Installing antennas carries some level of risk. For your safety, read the following safety precautions carefully before your operation.
·     Keep the antenna away from power sources, street lamps, power distribution boxes, or other places that might cause electrical shock.
·     Do not touch any power lines for your safety.
·     Keep safety in mind when you select your installation site. Keep away from electric power lines and other lines.
·     Do not work alone when you install the antenna.
·     If the antenna, antenna cable, or any other installation accessory drops, get away from it to avoid bodily injury.
·     To avoid any potential hazards, always have a professional handle power connection rather than attempting it yourself.
·     If an accident, for example, electrical shock, occurs, immediately call for qualified emergency help.
Installation guidelines
To ensure optimal performance of the antenna, follow these guidelines:
·     Keep the antenna away from metal obstacles, such as heating pipes and air conditioners.
·     The material and thickness of walls determine the number of walls that the RF signal can penetrate. 5 GHz signal attenuation is large. Avoid signal penetration through solid walls.
Mounting the antenna
1.     Put the antenna over the AP front.
2.     Use M2.6 × 6 mm screws to secure the antenna.
3.     Connect the RP-SMA male connectors on the antenna to the RP-SMA female connectors on the AP.
Figure 6 Mounting the antenna
