H3C C5060-510002-A omnidirectional Antenna Installation Guide-6W100
HomeSupportWireless​External AntennaInstall & UpgradeInstallation GuidesH3C C5060-510002-A omnidirectional Antenna Installation Guide-6W100
Download Book
H3C C5060-510002-A omnidirectional antenna installation guide
Technical specifications
The C5060-510002-A dual-band omnidirectional Wi-Fi antenna is designed for use in indoor environments. It is connected to the device through the SMA reverse polarity connector.
Figure 1 Antenna view
Figure 2 Antenna connector
Table 1 Technical specifications
Item
C5060-510002-A
Frequency range
2400 MHz to 2500 MHz/4900 MHz to 5825 MHz
Polarization type
Vertical
Gain
2/3 dBi
Horizontal beamwidth (HBW)
360 degrees
Vertical beamwidth (VBW)
50/50 degrees
Horizontal out of roundness
± 1.5 dB
Impedance
50 Ω
Voltage standing wave ratio (VSWR)
≤ 2.0
Maximum power
1 W
Connector
Connector position
Bottom
Dimensions (diameter × length)
13 × 150 mm (0.51 × 5.91 in)
Weight
0.1 kg (0.22 lb)
Color
White
Operating temperature
–10°C to +60°C (14°F to 140°F)
Operating humidity
5 % to 95%
Application scenario
Indoor
Installation method
Direct mounting
Figure 3 through Figure 6 show the horizontal and vertical radiation patterns.
Figure 3 2.4 GHz horizontal pattern
Figure 4 2.4 GHz vertical pattern
Figure 5 5 GHz horizontal pattern
Figure 6 5 GHz vertical pattern
Safety precautions
WARNING
WARNING!
·     Installing antennas carries some level of risk. For your safety, read the following safety precautions carefully before your operation.
·     Keep the antenna away from places that might cause electrical shock such as power sources.
·     Do not touch any power lines for your safety.
·     Keep safety in mind when you select your installation site. Keep away from electric power lines and other lines.
·     Do not work alone when you install the antenna.
·     If the antenna or any other installation accessory drops, get away from it to avoid bodily injury.
·     To avoid any potential hazards, always have a professional handle power connection rather than attempting it yourself.
·     If an accident, for example, electrical shock, occurs, immediately call for qualified emergency help.
Installation guidelines
To ensure optimal performance of the antenna, follow these guidelines:
·     Keep the antenna away from metal obstacles, such as heating pipes and air conditioners.
·     The material and thickness of walls determine the number of walls that the RF signal can penetrate. 5 GHz signal attenuation is large. Avoid signal penetration through solid walls.
Choosing a mounting location
To ensure optimal coverage, follow these guidelines when choosing a mounting location for the antenna:
·     Determine appropriate antenna mounting location and height. Make sure no obstruction, especially no solid walls and metal plates, exists between the antenna and the target coverage area.
·     The AP must be installed at a location where wires (cables or fibers) and power (local power supply or PoE) can reach.
Mounting the antenna
1.     Unfold the antenna to 180 degrees.
2.     Attach the antenna to the antenna port on the device. Do not over-tighten the antenna to avoid damage.
Change the antenna orientation to vertical to achieve better signal coverage.
Figure 7 Mounting the antenna
