02-Virtual Technologies Configuration Guide
HomeSupportSwitchesS6530X SeriesConfigure & DeployConfiguration GuidesH3C S6530X Switch Series Configuration Guides-R8108Pxx-6W10002-Virtual Technologies Configuration Guide
01-IRF configuration
01-IRF configuration 863.20 KB
Configuring an IRF fabric· 1
About IRF· 1
IRF network model 1
IRF benefits· 1
Basic concepts· 2
IRF network topology· 4
Master election· 4
Interface naming conventions· 5
File system naming conventions· 5
Configuration synchronization· 6
Multi-active handling procedure· 6
MAD mechanisms· 8
Restrictions and guidelines: IRF configuration· 13
Hardware compatibility with IRF· 13
Software requirements for IRF· 14
Candidate IRF physical interfaces· 14
Transceiver modules and cables selection for IRF· 14
IRF port connection· 14
IRF physical interface configuration restrictions and guidelines· 14
Feature compatibility and configuration restrictions with IRF· 15
Configuration rollback restrictions· 15
IRF tasks at a glance· 16
Planning the IRF fabric setup· 16
Setting up an IRF fabric· 16
IRF setup tasks at a glance· 16
Assigning a member ID to each IRF member device· 17
Specifying a priority for each member device· 17
Binding physical interfaces to IRF ports· 18
Bulk-configuring basic IRF settings for a member device· 19
Connecting IRF physical interfaces· 20
Accessing the IRF fabric· 20
Configuring MAD·· 20
Restrictions and guidelines for MAD configuration· 20
Configuring LACP MAD·· 21
Configuring BFD MAD·· 22
Configuring ARP MAD·· 25
Configuring ND MAD·· 27
Excluding interfaces from the shutdown action upon detection of multi-active collision· 30
Recovering an IRF fabric· 31
Optimizing IRF settings for an IRF fabric· 31
Enabling IRF auto-merge· 31
Configuring a member device description· 31
Configuring IRF bridge MAC address settings· 32
Enabling software auto-update for software image synchronization· 33
Setting the IRF link down report delay· 34
Display and maintenance commands for IRF· 34
IRF configuration examples· 34
Example: Configuring an IRF fabric with LACP MAD enabled on an aggregate interface· 35
Example: Configuring an IRF fabric with BFD MAD enabled on a VLAN interface· 39
Example: Configuring an IRF fabric with ARP MAD enabled on a VLAN interface· 43
Example: Configuring an IRF fabric with ND MAD enabled on a VLAN interface· 47
Example: Configuring an IRF fabric with ARP MAD and management IP configured on the same management Ethernet port 51
Example: Removing member devices from an IRF fabric without MAD in place· 55
Example: Removing member devices from an IRF fabric with MAD in place· 57
About IRF
The Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
IRF network model
Figure 1 shows an IRF fabric that has two devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF benefits
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
Basic concepts
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices automatically elect a new master. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. Two devices cannot form an IRF fabric if they use the same member ID. A device cannot join an IRF fabric if its member ID has been used in the fabric.
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device has two IRF ports.
The IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down when all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward traffic between member devices, including IRF protocol packets and data packets that must travel across IRF member devices.
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 2. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 2 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 3.
Figure 3 IRF merge
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 settings, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 4, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to determine whether the packet is from the local IRF fabric. Then, the member device can handle the packet correctly.
Figure 4 A network that contains two IRF domains
An IRF fabric can use a daisy-chain or ring topology. As shown in Figure 5, a ring topology is more reliable. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy-chain topology. Rather, the IRF fabric changes to a daisy-chain topology without interrupting network services.
Figure 5 Daisy-chain topology vs. ring topology
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when split IRF fabrics merge. For information about the master device of the merged IRF fabric, see "Failure recovery."
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election.
A physical interface is numbered in the chassis-number/slot-number/interface-index format.
·     chassis-numberMember ID of the device. The default value for this argument is 1. Any change to the member ID takes effect after a reboot.
·     slot-number—Slot number of the interface, which is fixed at 0.
·     interface-indexInterface index on the device. Interface index depends on the number of physical interfaces available on the device. To identify the index of a physical interface, examine its index mark on the chassis.
For example, Ten-GigabitEthernet 2/0/1 represents the first fixed physical interface on member device 2. Set its link type to trunk, as follows:
[Sysname] interface ten-gigabitethernet 2/0/1
[Sysname-Ten-GigabitEthernet2/0/1] port link-type trunk
On a single-chassis fabric, you can use its storage device name to access its file system.
On a multichassis IRF fabric, you can use the storage device name to access the file system of the master. To access the file system of any other member device, use the name in the slotmember-ID#storage-device-name format.
For more information about storage device naming conventions, see Fundamentals Configuration Guide.
For example:
·     To create and access the test folder under the root directory of the flash memory on the master switch:
<Master> mkdir test
<Master> cd test
<Master> dir
Directory of flash:/test
The directory is empty.
2009784 KB total (1239680 KB free)
·     To create and access the test folder under the root directory of the flash memory on member device 3:
<Master> mkdir slot3#flash:/test
Creating directory slot3#flash:/test... Done.
<Master> cd slot3#flash:/test
<Master> dir
Directory of slot3#flash:/test
2009784 KB total (1239652 KB free)
IRF uses a strict running-configuration synchronization mechanism to make sure all member devices operate as if they were one device. When the master device fails, the remaining devices can still operate correctly to provide services.
The configuration synchronization mechanism has two phases: bulk sync at startup and real-time sync during operation.
1.     Bulk sync—Occurs when a device starts up in the following situations:
¡     The device reboots to join the IRF fabric as a new subordinate device.
In this situation, the device takes the following actions:
-     Pulls and loads the running configuration from the master device.
-     Loads the IRF member description, priority, and IRF port bindings locally configured for it by using the irf member description, irf member priority, and irf-port commands, respectively.
-     Pushes its IRF member description, priority, and IRF port bindings to the master device.
The configuration files on the device are retained, but they do not take effect.
¡     The entire IRF fabric reboots.
In this situation, all member devices in the IRF reboot simultaneously. The subordinate devices pull the startup configuration file from the master device and then extract the configuration from the file to run in memory.
2.     Real-time sync—Occurs while the IRF fabric is operating.
In this situation, the system takes the following actions:
¡     Saves all configuration changes you make to the running configuration on the master device.
¡     Pushes the configuration changes to the subordinate devices in real time.
Bulk sync and real-time sync ensure that all member devices in an IRF fabric run the same configuration. When the master device fails, the remaining member devices can still operate as configured.
To prevent configuration loss upon reboot of the IRF fabric, save configuration changes to all member devices by using the save all command while the IRF fabric is operating.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND to detect multi-active collisions. As a best practice, configure a minimum of one MAD mechanism on an IRF fabric. For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
For information about LACP, see Ethernet link aggregation in Layer 2—LAN Switching Configuration Guide. For information about BFD, see High Availability Configuration Guide. For information about ARP, see Layer 3—IP Services Configuration Guide. For information about ND, see IPv6 basics in Layer 3—IP Services Configuration Guide.
Collision handling
When detecting a multi-active collision, MAD disables all IRF fabrics except one from forwarding data traffic by placing them in Recovery state. The IRF fabrics placed in Recovery state are called inactive IRF fabrics. The IRF fabric that continues to forward traffic is called the active IRF fabric.
BFD MAD and LACP MAD use the following process to handle a multi-active collision:
1.     Compare the health states of split fabrics.‍ To view their health states, use the display system health command. For more information about this command, see device management in Fundamentals Command Reference.
2.     Set all fabrics to the Recovery state except the healthiest one.
3.     Compare the number of members in each fabric if all IRF fabrics are in the same health state.
4.     Set all fabrics to the Recovery state except the one that has the most members.
5.     Compare the member IDs of their masters if all IRF fabrics have the same number of members.
6.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
7.     Shut down all common network interfaces in the Recovery-state fabrics except for the following interfaces:
¡     Interfaces automatically excluded from being shut down by the system.
¡     Interfaces specified by using the mad exclude interface command.
ARP MAD and ND MAD use the following process to handle a multi-active collision:
1.     Compare the health states of split fabrics. To view their health states, use the display system health command. For more information about this command, see device management in Fundamentals Command Reference.
3.     Compare the member IDs of the masters in the IRF fabrics if all IRF fabrics have the same health state.
4.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shut down all common network interfaces in the Recovery-state fabrics except for the following interfaces:
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
When the failed IRF link between two split IRF fabrics is recovered, all member devices in the inactive IRF fabric automatically reboot to join the active IRF fabric as subordinate members. The network interfaces that have been shut down by MAD automatically restore their original state, as shown in Figure 6.
CAUTION
CAUTION:
If you inadvertently reboot the active IRF fabric after the failed IRF link recovers, its member devices will join the inactive IRF fabric with their network interfaces being shut down by MAD. To restore the original states of the network interfaces in the merged IRF fabric, use the mad restore command.
If the IRF auto-merge feature is enabled, the inactive IRF member devices will automatically reboot after the failed IRF link recovers and a manual reboot is typically not required.
Figure 6 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 7), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. This command brings up all network interfaces that were shut down by MAD. After the IRF link is repaired, merge the two parts into a unified IRF fabric.
Figure 7 Active IRF fabric fails before the IRF link is recovered
MAD mechanisms
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenarios
LACP MAD
·     Detection speed is fast.
·     Runs on existing aggregate links without requiring MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
BFD MAD
·     Intermediate device, if used, can come from any vendor.
Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for IRF fabrics that have only two members that are geographically close to one another.
ARP MAD
·     No intermediate device is required.
·     Does not require MAD dedicated ports.
·     Detection speed is slower than BFD MAD and LACP MAD.
·     The spanning tree feature must be enabled if common Ethernet ports are used for ARP MAD links.
Spanning tree-enabled non-link aggregation IPv4 network scenarios if common Ethernet ports are used.
ND MAD
·     The spanning tree feature must be enabled if common Ethernet ports are used for ND MAD links.
Spanning tree-enabled non-link aggregation IPv6 network scenarios if common Ethernet ports are used.
LACP MAD
As shown in Figure 8, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID (the member ID of the master). The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 8 LACP MAD scenario
BFD MAD
BFD MAD detects multi-active collisions by using BFD.
You can use common or management Ethernet ports for BFD MAD.
If management Ethernet ports are used, BFD MAD has the following requirements:
·     Use an intermediate device and make sure each IRF member device has a BFD MAD link to the intermediate device.
·     Assign each member device a MAD IP address on the master's management Ethernet port.
If common Ethernet ports are used, BFD MAD has the following requirements:
·     If an intermediate device is used, each member device must have a BFD MAD link to the intermediate device. If no intermediate device is used, all member devices must have a BFD MAD link to each other.
·     Assign all ports on the BFD MAD links to the same VLAN. Assign each member device a MAD IP address on the VLAN interface.
When you use BFD MAD, follow these restrictions and guidelines:
·     As a best practice, use an intermediate device to connect IRF member devices if the IRF fabric has more than two member devices. A full mesh of IRF members might cause broadcast loops.
·     As a best practice, preferentially use management Ethernet ports for BFD MAD.
·     The BFD MAD links and BFD MAD VLAN must be dedicated. Do not use the BFD MAD links or BFD MAD VLAN for any other purposes.
·     The MAD addresses identify the member devices and must belong to the same subnet.
·     Of all management Ethernet ports on an IRF fabric, only the master's management Ethernet port is accessible.
Figure 9 shows a typical BFD MAD scenario that uses an intermediate device. On the intermediate device, assign the ports on the BFD MAD links to the same VLAN.
Figure 10 shows a typical BFD MAD scenario that does not use an intermediate device.
With BFD MAD, the master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
Figure 9 BFD MAD scenario with an intermediate device
Figure 10 BFD MAD scenario without an intermediate device
ARP MAD
ARP MAD detects multi-active collisions by using extended ARP packets that convey the IRF domain ID and the active ID.
You can use common or management Ethernet ports for ARP MAD.
If management Ethernet ports are used, ARP MAD must work with an intermediate device. Make sure the following requirements are met:
·     Connect a management Ethernet port on each member device to the intermediate device.
·     On the intermediate device, you must assign the ports used for ARP MAD to the same VLAN.
If common Ethernet ports are used, ARP MAD can work with or without an intermediate device. Make sure the following requirements are met:
·     If an intermediate device is used, connect each IRF member device to the intermediate device, as shown in Figure 11. Run the spanning tree feature between the IRF fabric and the intermediate device. In this situation, data links can be used.
·     If no intermediate device is used, connect each IRF member device to all other member devices. In this situation, IRF links cannot be used for ARP MAD.
Each IRF member compares the domain ID and the active ID (the member ID of the master) in incoming extended ARP packets with its domain ID and active ID.
·     If the domain IDs are different, the extended ARP packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
·     If the domain IDs are the same, the device compares the active IDs.
¡     If the active IDs are different, the IRF fabric has split.
¡     If the active IDs are the same, the IRF fabric is integrated.
Figure 11 ARP MAD scenario
ND MAD
ND MAD detects multi-active collisions by using NS packets to transmit the IRF domain ID and the active ID.
You can use common or management Ethernet ports for ND MAD.
If management Ethernet ports are used, ND MAD must work with an intermediate device. Make sure the following requirements are met:
·     On the intermediate device, you must assign the ports used for ND MAD to the same VLAN.
If common Ethernet ports are used, ND MAD can work with or without an intermediate device. Make sure the following requirements are met:
·     If an intermediate device is used, connect each IRF member device to the intermediate device, as shown in Figure 12. Run the spanning tree feature between the IRF fabric and the intermediate device. In this situation, data links can be used.
·     If no intermediate device is used, connect each IRF member device to all other member devices. In this situation, IRF links cannot be used for ND MAD.
Each IRF member device compares the domain ID and the active ID (the member ID of the master) in incoming NS packets with its domain ID and active ID.
·     If the domain IDs are different, the NS packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
Figure 12 ND MAD scenario
An S6530X switch can form an IRF fabric only with switches in the same series.
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
On the S6530X switch series, you can use QSFP28 ports as IRF physical interfaces. However, you cannot use the 10G or 25G breakout Ethernet interfaces of a QSFP28 port as IRF physical interfaces.
When you connect QSFP28 ports, use the following guidelines:
·     Use QSFP28 or QSFP+ transceiver modules and fibers for long distance connection.
·     Use QSFP28 or QSFP+ cables for short distance connection.
For more information about the transceiver modules and cables, see the device installation guide and H3C Transceiver Modules User Guide.
The transceiver modules and cables available for the device are subject to change over time. For the most up-to-date list of transceiver modules and cables, contact your H3C sales representative.
IRF port connection
When you connect two neighboring IRF members, follow these restrictions and guidelines:
·     You must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
·     For high availability, bind multiple physical interfaces to an IRF port. You can bind a maximum of eight physical interfaces to an IRF port.
Figure 13 Connecting IRF physical interfaces
Command configuration restrictions
On a physical interface bound to an IRF port, you can execute only the following commands:
·     Basic interface commands, including shutdown and description. For more information about these commands, see Ethernet interface commands in Interface Command Reference.
·     The flow-interval command, which sets the statistics polling interval on an interface. For more information about this command, see Ethernet interface commands in Interface Command Reference.
·     The itu-channel command for setting the ITU channel number for a transceiver module. For more information about this command, see device management commands in Fundamentals Command Reference.
·     MAC address table configuration commands, including the mac-address static source-check enable command. In a VXLAN or EVPN network, to ensure successful forwarding of Layer 3 traffic across member devices, use the undo mac-address static source-check enable command on each IRF physical interface. For information about this command, see MAC address table commands in Layer 2—LAN Switching Command Reference.
·     LLDP commands, including:
¡     lldp admin-status.
¡     lldp check-change-interval.
¡     lldp enable.
¡     lldp encapsulation snap.
¡     lldp notification remote-change enable.
¡     lldp tlv-enable.
For more information about these commands, see LLDP in Layer 2—LAN Switching Command Reference.
Suppressing SNMP notifications of packet drops on IRF physical interfaces
Before an IRF member device forwards a packet, it examines its forwarding path in the IRF fabric for a loop. If a loop exists, the device discards the packet on the source interface of the looped path. This loop elimination mechanism will drop a large number of broadcast packets on the IRF physical interfaces.
To suppress SNMP notifications of packet drops that do not require attention, do not monitor packet forwarding on the IRF physical interfaces.
Routing settings
To form an IRF fabric, all member devices must use the same settings for the following routing features:
·     Maximum number of ECMP routes (set by using the max-ecmp-num command).
For more information about the routing features, see basic IP routing in Layer 3—IP Routing Configuration Guide.
The configuration rollback feature cannot roll back the following IRF settings:
·     Member device description (set by using the irf member description command).
·     Member device priority (set by using the irf member priority command).
·     IRF physical interface and IRF port bindings (set by using the port group interface command).
For more information about the configuration rollback feature, see configuration file management in Fundamentals Configuration Guide.
To configure IRF, perform the following tasks:
1.     Setting up an IRF fabric
2.     Configuring MAD
Configure a minimum of one MAD mechanism on an IRF fabric. For the MAD compatibility, see "MAD mechanism compatibility."
¡     Configuring LACP MAD
¡     Configuring BFD MAD
¡     Configuring ARP MAD
¡     Configuring ND MAD
¡     Excluding interfaces from the shutdown action upon detection of multi-active collision
This feature excludes an interface from the shutdown action for management or other special purposes when an IRF fabric transits to the Recovery state.
¡     Recovering an IRF fabric
3.     (Optional.) Optimizing IRF settings for an IRF fabric
¡     Enabling IRF auto-merge
When two IRF fabrics merge, this feature enables the IRF fabric that failed the master election to automatically reboot all its member devices to complete the merge.
¡     Configuring a member device description
¡     Configuring IRF bridge MAC address settings
¡     Enabling software auto-update for software image synchronization
This feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
¡     Setting the IRF link down report delay
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master device.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
·     IRF physical interfaces.
To set up an IRF fabric, perform the following tasks:
4.     Configure member IDs, priorities, and IRF physical interfaces separately.
a.     Assigning a member ID to each IRF member device
b.     (Optional.) Specifying a priority for each member device
c.     Binding physical interfaces to IRF ports
Skip these tasks if you configure member IDs, priorities, domain ID, and IRF physical interfaces in bulk.
5.     Bulk-configuring basic IRF settings for a member device
Skip this task if you configure member IDs, priorities, domain ID, and IRF physical interfaces separately.
6.     Connecting IRF physical interfaces
7.     Accessing the IRF fabric
CAUTION
CAUTION:
An IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on your live network.
To create an IRF fabric, you must assign a unique IRF member ID to each member device.
The new member ID of a device takes effect at a reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical network interfaces) are removed, regardless of whether you have saved the configuration.
2.     Assign a member ID to a member device.
irf member member-id renumber new-member-id
The default IRF member ID is 1.
CAUTION
CAUTION:
3.     (Optional.) Save the configuration.
save
If you have bound physical interfaces to IRF ports or assigned member priority, you must perform this step for these settings to take effect after the reboot.
4.     Return to user view.
5.     Reboot the device.
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. A larger priority value indicates a higher priority.
A change to member priority affects the election result at the next master election, but it does not cause an immediate master re-election.
2.     Specify a priority for the device.
irf member member-id priority priority
The default IRF member priority is 1.
Select qualified physical interfaces as IRF physical interfaces as described in "Candidate IRF physical interfaces."
Do not connect IRF physical interfaces to common network interfaces.
As a best practice, finish all IRF settings on the local and neighboring member devices before you use the undo shutdown command to bring up IRF physical interfaces. This configuration order avoids unnecessary reboots of the member devices.
After you bind physical interfaces to IRF ports for the first time, you must use the irf-port-configuration active command to activate the settings on the IRF ports.
The system activates the IRF port settings automatically only in the following situations:
·     The configuration file that the device starts with contains IRF port bindings.
·     You are adding physical interfaces to an IRF port (in UP state) after an IRF fabric is formed.
2.     Enter interface view or interface range view.
¡     Enter interface view.
¡     Enter interface range view. Choose one of the following commands:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-24> ]
To shut down a range of IRF physical interfaces, enter interface range view.
To shut down one IRF physical interface, enter its interface view.
3.     Shut down the physical interfaces.
shutdown
By default, interfaces on the device are disabled (in ADM or Administratively Down state).
You must always shut down a physical interface before binding it to an IRF port or removing the binding. If the system prevents you from shutting down an interface, follow the system instructions to disable its peer interface.
4.     Return to system view.
5.     Enter IRF port view.
irf-port member-id/irf-port-number
6.     Bind each physical interface to the IRF port.
port group interface interface-type interface-number [ mode enhanced ]
By default, no physical interfaces are bound to an IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port.
7.     Return to system view.
8.     Enter interface view or interface range view.
9.     Bring up the physical interfaces.
10.     Return to system view.
11.     Save the configuration.
save
Activating IRF port configurations causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the IRF port settings.
Use the easy IRF feature to bulk-configure basic IRF settings for a member device, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
·     Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
·     Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
CAUTION
CAUTION:
·     Use caution when you change the member ID of an IRF member device. An IRF member ID uniquely identifies a device in an IRF fabric. An IRF member ID change can invalidate member ID-related settings, including interface and file path settings, and cause data loss. Make sure you fully understand its impact on the live network.
·     The member device reboots immediately after you specify a new member ID for it. Make sure you are aware of the impact of this operation on the network.
If you execute the easy-irf command multiple times, the following settings take effect:
·     The most recent settings for the member ID, domain ID, and priority.
·     IRF port bindings added through repeated executions of the command. To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
If you specify IRF physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
·     Do not enter spaces between the interface type and interface number.
·     Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
2.     Bulk-configure basic IRF settings for the device.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
Make sure the new member ID is unique in the IRF fabric to which the device will be added.
Follow the restrictions in "IRF port connection" to connect IRF physical interfaces as well as based on the topology and cabling scheme. The devices perform master election. The member devices that fail the master election automatically reboot to form an IRF fabric with the master device.
The IRF fabric appears as one device after it is formed. You configure and manage all IRF members at the CLI of the master. All settings you have made are automatically propagated to the IRF members.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any member device.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet and SNMP.
When you log in to an IRF fabric, you are placed at the CLI of the master, regardless of at which member device you are logged in.
For more information, see login configuration in Fundamentals Configuration Guide.
Configuring MAD
As a best practice, configure a minimum of one MAD mechanism on an IRF fabric for prompt IRF split detection. Because MAD mechanisms use different collision handling processes, follow these restrictions and guidelines when you configure multiple MAD mechanisms on an IRF fabric:
·     Do not configure LACP MAD together with ARP MAD or ND MAD.
·     Do not configure BFD MAD together with ARP MAD or ND MAD.
Assigning IRF domain IDs
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
If LACP MAD, ARP MAD, or ND MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
Actions on interfaces shut down by MAD
To prevent a multi-active collision from causing network issues, avoid using the undo shutdown command to bring up the interfaces shut down by a MAD mechanism on a Recovery-state IRF fabric.
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
CAUTION
CAUTION:
Changing the IRF domain ID of an IRF member device will remove that member device from the IRF fabric. This member device will be unable to exchange IRF protocol packets with the remaining member devices in the IRF fabric.
3.     Create an aggregate interface and enter aggregate interface view.
¡     Enter Layer 2 aggregate interface view.
¡     Enter Layer 3 aggregate interface view.
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
LACP MAD takes effect only on dynamic aggregate interfaces.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
7.     Enter Ethernet interface view or interface range view.
¡     Enter Ethernet interface view.
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
Multichassis link aggregation is allowed.
Configuring BFD MAD
Restrictions and guidelines for configuring BFD MAD
As a best practice, use the following procedure to set up BFD MAD:
1.     Choose a BFD MAD link scheme as described in "BFD MAD."
2.     Configure BFD MAD.
3.     Connect the BFD MAD links.
When you configure BFD MAD on a VLAN interface, follow these restrictions and guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks:
¡     On the IRF fabric and the intermediate device, create a VLAN for BFD MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of BFD MAD links to the BFD MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the BFD MAD VLAN.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if that port is not on a BFD MAD link. If you have assigned that port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude that port from the BFD MAD VLAN.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN and its member ports for any purpose other than configuring BFD MAD.
·     Use only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
·     Regardless of whether an intermediate device is used, you must assign all Layer 2 Ethernet ports used for BFD MAD on a member device to a Layer 2 aggregate interface to avoid loops if multiple Layer 2 Ethernet ports on the member device are used for BFD MAD for high availability. In addition, assign the Layer 2 aggregate interface to the BFD MAD VLAN. The numbers of the Layer 2 aggregate interfaces in the same BFD MAD VLAN on different member devices must be different.
MAD IP address
·     To avoid network issues, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
When you configure BFD MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for BFD MAD
Connect a management Ethernet port on each IRF member device to the common Ethernet ports on the intermediate device.
BFD MAD VLAN
·     On the intermediate device, create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
Configuring BFD MAD on a VLAN interface
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
CAUTION
CAUTION:
3.     Create a VLAN dedicated to BFD MAD.
vlan vlan-id
By default, only VLAN 1 exists.
Perform this step also on the intermediate device (if any).
5.     Enter Ethernet interface view or interface range view.
To assign a range of ports to the BFD MAD VLAN, enter interface range view.
To assign one port to the BFD MAD VLAN, enter Ethernet interface view.
6.     Assign the port or the range of ports to the BFD MAD VLAN.
¡     Assign the ports to the VLAN as access ports.
port access vlan vlan-id
¡     Assign the ports to the VLAN as trunk ports.
port trunk permit vlan vlan-id
¡     Assign the ports to the VLAN as hybrid ports.
port hybrid vlan vlan-id { tagged | untagged }
The link type of BFD MAD ports can be access, trunk, or hybrid.
The default link type of a port is access.
8.     Enter VLAN interface view.
interface vlan-interface vlan-interface-id
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the VLAN interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on any VLAN interfaces.
Repeat this step to assign a MAD IP address to each member device on the VLAN interface.
Configuring BFD MAD on a management Ethernet port
CAUTION
CAUTION:
3.     Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
4.     Enable BFD MAD.
mad bfd enable
5.     Assign a MAD IP address to each member device.
By default, no MAD IP addresses are configured.
Configuring ARP MAD
Restrictions and guidelines for configuring ARP MAD
As a best practice, use the following procedure to set up ARP MAD:
1.     Choose an ARP MAD link scheme as described in "ARP MAD."
2.     Configure ARP MAD.
3.     Connect the ARP MAD links.
When you configure ARP MAD on a VLAN interface, follow these restrictions and guidelines:
Category
ARP MAD VLAN
·     Do not enable ARP MAD on VLAN-interface 1.
¡     On the IRF fabric and the intermediate device, create a VLAN for ARP MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of ARP MAD links to the ARP MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the ARP MAD VLAN.
·     Do not use the ARP MAD VLAN for any other purposes.
ARP MAD and feature configuration
If an intermediate device is used, make sure the following requirements are met:
·     Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ARP MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
·     Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
·     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
When you configure ARP MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for ARP MAD
Connect a management Ethernet port on each member device to the common Ethernet ports on the intermediate device.
ARP MAD VLAN
On the intermediate device, create a VLAN for ARP MAD, and assign the ports used for ARP MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
Configuring ARP MAD on a VLAN interface
CAUTION
CAUTION:
3.     Configure the IRF bridge MAC address to change as soon as the address owner leaves.
undo irf mac-address persistent
By default, the IRF bridge MAC address does not change after the address owner leaves.
CAUTION
CAUTION:
IRF bridge MAC address change will cause transient traffic disruption.
4.     Create a VLAN dedicated to ARP MAD.
vlan vlan-id
Do not configure ARP MAD on VLAN-interface 1.
Perform this task also on the intermediate device (if any).
5.     Return to system view.
6.     Enter Ethernet interface view or interface range view.
To assign a range of ports to the ARP MAD VLAN, enter interface range view.
To assign one port to the ARP MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ARP MAD VLAN.
The link type of ARP MAD ports can be access, trunk, or hybrid.
8.     Return to system view.
9.     Enter VLAN interface view.
10.     Assign the interface an IP address.
By default, no IP addresses are assigned to any VLAN interfaces.
11.     Enable ARP MAD.
mad arp enable
By default, ARP MAD is disabled.
Configuring ARP MAD on a management Ethernet port
CAUTION
CAUTION:
CAUTION
CAUTION:
4.     Enter management Ethernet interface view.
5.     Assign an IP address to the management Ethernet port.
By default, no IP addresses are configured.
6.     Enable ARP MAD.
mad arp enable
Configuring ND MAD
Restrictions and guidelines for configuring ND MAD
As a best practice, use the following procedure to set up ND MAD:
1.     Choose an ND MAD link scheme as described in "ND MAD."
2.     Configure ND MAD.
3.     Connect the ND MAD links.
When you configure ND MAD on a VLAN interface, follow these restrictions and guidelines:
Category
ND MAD VLAN
·     Do not enable ND MAD on VLAN-interface 1.
¡     On the IRF fabric and the intermediate device, create a VLAN for ND MAD.
¡     On the IRF fabric and the intermediate device, assign the ports of ND MAD links to the ND MAD VLAN.
¡     On the IRF fabric, create a VLAN interface for the ND MAD VLAN.
·     Do not use the ND MAD VLAN for any other purposes.
ND MAD and feature configuration
·     Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ND MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
When you configure ND MAD on a management Ethernet port, follow these restrictions and guidelines:
Category
Management Ethernet ports for ND MAD
ND MAD VLAN
On the intermediate device, create a VLAN for ND MAD, and assign the ports used for ND MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN.
Configuring ND MAD on a VLAN interface
CAUTION
CAUTION:
CAUTION
CAUTION:
4.     Create a VLAN dedicated to ND MAD.
vlan vlan-id
Do not configure ND MAD on VLAN-interface 1.
To assign a range of ports to the ND MAD VLAN, enter interface range view.
To assign one port to the ND MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ND MAD VLAN.
The link type of ND MAD ports can be access, trunk, or hybrid.
10.     Assign the interface an IPv6 address.
ipv6 address { ipv6-address/prefix-length | ipv6-address prefix-length }
By default, no IPv6 addresses are assigned to a VLAN interface.
11.     Enable ND MAD.
mad nd enable
By default, ND MAD is disabled.
Configuring ND MAD on a management Ethernet port
CAUTION
CAUTION:
CAUTION
CAUTION:
5.     Assign an IPv6 address to the management Ethernet port.
ipv6 address { ipv6-address/pre-length | ipv6 address pre-length }
By default, no IPv6 addresses are assigned to a management Ethernet port.
6.     Enable ND MAD.
mad nd enable
When an IRF fabric transits to the Recovery state, the system automatically excludes the following network interfaces from being shut down:
·     Interfaces used for BFD MAD.
·     Member interfaces of an aggregate interface if the aggregate interface is excluded from being shut down.
You can exclude an interface from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
If the Layer 2 ports of a VLAN interface are distributed on multiple member devices, the exclusion operation might introduce IP collision risks. The VLAN interface might be up on both active and inactive IRF fabrics.
2.     Configure an interface to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all network interfaces on a Recovery-state IRF fabric are shut down, except for the network interfaces automatically excluded by the system.
If the active IRF fabric fails before the IRF link is recovered, perform this task on the inactive IRF fabric to recover the inactive IRF fabric for traffic forwarding. The manual recovery operation brings up all interfaces that were shut down by MAD on the inactive IRF fabric.
2.     Recover the inactive IRF fabric.
mad restore
When two IRF fabrics merge, you must reboot the member devices in the IRF fabric that fails in the master election. The auto-merge feature enables the IRF fabric to automatically reboot all its member devices to complete the merge.
If this feature is disabled, you must manually reboot the devices that failed the master election to complete the merge.
2.     Enable IRF auto-merge.
irf auto-merge enable
By default, this feature is enabled.
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
The bridge MAC address of a system must be unique on a switched LAN. IRF bridge MAC address identifies an IRF fabric by Layer 2 protocols (for example, LACP) on a switched LAN.
By default, an IRF fabric uses the bridge MAC address of the master as the IRF bridge MAC address. After the master leaves, the IRF bridge MAC address persists for a period of time or permanently depending on the IRF bridge MAC persistence setting. When the IRF bridge MAC persistence timer expires, the IRF fabric uses the bridge MAC address of the current master as the IRF bridge MAC address.
In special occasions that require a fixed special IRF bridge MAC address, you can specify that MAC address as the IRF bridge MAC address. For example, when you replace an IRF fabric as a whole, you can configure the new IRF fabric with the IRF bridge MAC address of the existing IRF fabric before the replacement to minimize service interruption.
The IRF bridge MAC persistence setting does not take effect on the manually specified IRF bridge MAC address.
If IRF fabric merge occurs, IRF determines the IRF bridge MAC address of the merged IRF fabric as follows:
1.     When IRF fabrics merge, IRF ignores the IRF bridge MAC addresses and checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
2.     After IRF fabrics merge, the merged IRF fabric uses the bridge MAC address of the merging IRF fabric that won the master election as the IRF bridge MAC address.
Restrictions and guidelines for IRF bridge MAC address configuration
CAUTION
CAUTION:
Bridge MAC address change will cause transient traffic disruption.
When you configure IRF bridge MAC persistence, follow these restrictions and guidelines:
·     If ARP MAD or ND MAD is used with the spanning tree feature, you must disable IRF bridge MAC persistence by using the undo irf mac-address persistent command. In addition, do not specify a MAC address as the IRF bridge MAC address.
·     If the IRF fabric has multichassis aggregate links, do not use the undo irf mac-address persistent command. Use of this command might cause traffic disruption.
Configuring IRF bridge MAC persistence
2.     Configure IRF bridge MAC persistence.
¡     Retain the bridge MAC address permanently even if the address owner has left the fabric.
irf mac-address persistent always
¡     Retain the bridge MAC address for 6 minutes after the address owner leaves the fabric.
irf mac-address persistent timer
¡     Change the bridge MAC address as soon as the address owner leaves the fabric.
The irf mac-address persistent timer command avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
Specifying a MAC address as the IRF bridge MAC address
2.     Specify a MAC address as the IRF bridge MAC address.
irf mac-address mac-address
CAUTION
CAUTION:
If an IRF fabric splits after you configure the IRF bridge MAC address, both the split IRF fabrics use the configured bridge MAC address as the IRF bridge MAC address.
The software auto-update feature automatically synchronizes the current software images of the master to devices that are attempting to join the IRF fabric.
To join an IRF fabric, a device must use the same software images as the master in the fabric.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as its main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric if software auto-update is disabled.
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting member devices during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status messages to configuration terminals (see Network Management and Monitoring Configuration Guide).
Make sure the device you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the Boot menu to delete files.
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
Make sure the IRF link down report delay is shorter than the heartbeat or hello timeout settings of upper-layer protocols (for example, OSPF). If the report delay is longer than the timeout setting of a protocol, unnecessary recalculations might occur.
Set the delay to 0 seconds in the following situations:
·     The IRF fabric requires a fast master/subordinate or IRF link switchover.
·     The RRPP, BFD, or GR feature is used.
·     You want to shut down an IRF physical interface or reboot an IRF member device. (After you complete the operation, reconfigure the delay depending on the network condition.)
2.     Set the IRF link down report delay.
irf link-delay interval
The default IRF link down report delay is 4 seconds (4000 milliseconds).
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
display irf configuration
Display MAD configuration.
display mad [ verbose ]
The IRF configuration examples show how to set up IRF fabrics that use different MAD mechanisms.
As shown in Figure 14, set up a four-chassis IRF fabric at the access layer of the enterprise network.
Configure LACP MAD on the multichassis aggregation to Device E, which supports extended LACP.
Figure 14 Network diagram
1.     Configure settings for IRF setup on Device A:
# Shut down the physical interfaces used for IRF links. In this example, the physical interfaces are shut down in batch. For more information, see Layer 2—LAN Switching Configuration Guide.
[Sysname] interface range hundredgige 1/0/49 to hundredgige 1/0/52
[Sysname-if-range] shutdown
[Sysname-if-range] quit
# Bind HundredGigE 1/0/49 and HundredGigE 1/0/50 to IRF-port 1/1.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] port group interface hundredgige 1/0/49
[Sysname-irf-port1/1] port group interface hundredgige 1/0/50
[Sysname-irf-port1/1] quit
# Bind HundredGigE 1/0/51 and HundredGigE 1/0/52 to IRF-port 1/2.
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface hundredgige 1/0/51
[Sysname-irf-port1/2] port group interface hundredgige 1/0/52
[Sysname-irf-port1/2] quit
# Bring up the physical interfaces and save the configuration.
[Sysname-if-range] undo shutdown
[Sysname] save
# Activate the IRF port configuration.
[Sysname] irf-port-configuration active
2.     Configure settings for IRF setup on Device B:
# Change the member ID of Device B to 2 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue? [Y/N]:y
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 14, and log in to Device B. (Details not shown.)
# Shut down the physical interfaces for IRF links.
[Sysname] interface range hundredgige 2/0/49 to hundredgige 2/0/52
# Bind HundredGigE 2/0/49 and HundredGigE 2/0/50 to IRF-port 2/1.
[Sysname] irf-port 2/1
[Sysname-irf-port2/1] port group interface hundredgige 2/0/49
[Sysname-irf-port2/1] port group interface hundredgige 2/0/50
[Sysname-irf-port2/1] quit
# Bind HundredGigE 2/0/51 and HundredGigE 2/0/52 to IRF-port 2/2.
[Sysname] irf-port 2/2
[Sysname-irf-port2/2] port group interface hundredgige 2/0/51
[Sysname-irf-port2/2] port group interface hundredgige 2/0/52
[Sysname-irf-port2/2] quit
[Sysname] save
The two devices perform master election, and the one that has lost the election reboots to form an IRF fabric with the master.
3.     Configure settings for IRF setup on Device C:
# Change the member ID of Device C to 3 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 3
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 14, and log in to Device C. (Details not shown.)
[Sysname] interface range hundredgige 3/0/49 to hundredgige 3/0/52
# Bind HundredGigE 3/0/49 and HundredGigE 3/0/50 to IRF-port 3/1.
[Sysname] irf-port 3/1
[Sysname-irf-port3/1] port group interface hundredgige 3/0/49
[Sysname-irf-port3/1] port group interface hundredgige 3/0/50
[Sysname-irf-port3/1] quit
# Bind HundredGigE 3/0/51 and HundredGigE 3/0/52 to IRF-port 3/2.
[Sysname] irf-port 3/2
[Sysname-irf-port3/2] port group interface hundredgige 3/0/51
[Sysname-irf-port3/2] port group interface hundredgige 3/0/52
[Sysname-irf-port3/2] quit
[Sysname] save
Device C reboots to join the IRF fabric.
4.     Configure settings for IRF setup on Device D:
# Change the member ID of Device D to 4 and reboot the device to have the change take effect.
[Sysname] irf member 1 renumber 4
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 14, and log in to Device D. (Details not shown.)
# Shut down the physical interfaces.
[Sysname] interface range hundredgige 4/0/49 to hundredgige 4/0/52
# Bind HundredGigE 4/0/49 and HundredGigE 4/0/50 to IRF-port 4/1.
[Sysname] irf-port 4/1
[Sysname-irf-port4/1] port group interface hundredgige 4/0/49
[Sysname-irf-port4/1] port group interface hundredgige 4/0/50
[Sysname-irf-port4/1] quit
# Bind HundredGigE 4/0/51 and HundredGigE 4/0/52 to IRF-port 4/2.
[Sysname] irf-port 4/2
[Sysname-irf-port4/2] port group interface hundredgige 4/0/51
[Sysname-irf-port4/2] port group interface hundredgige 4/0/52
[Sysname-irf-port4/2] quit
[Sysname] save
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
5.     Configure LACP MAD on the IRF fabric:
# Set the domain ID of the IRF fabric to 1.
[Sysname] irf domain 1
# Create a dynamic aggregate interface and enable LACP MAD.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] link-aggregation mode dynamic
[Sysname-Bridge-Aggregation2] mad enable
[Current domain ID is: 1]:
The assigned domain ID is: 1
[Sysname-Bridge-Aggregation2] quit
# Assign Twenty-FiveGigE 1/0/1, Twenty-FiveGigE 2/0/1, Twenty-FiveGigE 3/0/1, and Twenty-FiveGigE 4/0/1 to the aggregate interface.
[Sysname] interface range twenty-fivegige 1/0/1 twenty-fivegige 2/0/1 twenty-fivegige 3/0/1 twenty-fivegige 4/0/1
[Sysname-if-range] port link-aggregation group 2
6.     Configure Device E as the intermediate device for LACP MAD:
CAUTION
CAUTION:
If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
# Create a dynamic aggregate interface.
# Assign HundredGigE 1/0/49, HundredGigE 1/0/50, HundredGigE 1/0/51, and HundredGigE 1/0/52 to the aggregate interface.
Example: Configuring an IRF fabric with BFD MAD enabled on a VLAN interface
As shown in Figure 15, set up a four-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure BFD MAD on the IRF fabric and set up BFD MAD links between each member device and the intermediate device.
·     Disable the spanning tree feature on the ports used for BFD MAD, because the two features conflict with each other.
Figure 15 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 15, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 15, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 15, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure BFD MAD on the IRF fabric:
# Create VLAN 3, and add Twenty-FiveGigE 1/0/1, Twenty-FiveGigE 2/0/1, Twenty-FiveGigE 3/0/1, and Twenty-FiveGigE 4/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] port twenty-fivegige 1/0/1 twenty-fivegige 2/0/1 twenty-fivegige 3/0/1 twenty-fivegige 4/0/1
[Sysname-vlan3] quit
# Create VLAN-interface 3, and configure a MAD IP address for each member device on the VLAN interface.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad bfd enable
[Sysname-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[Sysname-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[Sysname-Vlan-interface3] mad ip address 192.168.2.3 24 member 3
[Sysname-Vlan-interface3] mad ip address 192.168.2.4 24 member 4
[Sysname-Vlan-interface3] quit
# Disable the spanning tree feature on Twenty-FiveGigE 1/0/1, Twenty-FiveGigE 2/0/1, Twenty-FiveGigE 3/0/1, and Twenty-FiveGigE 4/0/1.
[Sysname-if-range] undo stp enable
6.     Configure Device E as the intermediate device for BFD MAD:
# Create VLAN 3, and assign HundredGigE 1/0/49, HundredGigE 1/0/50, HundredGigE 1/0/51, and HundredGigE 1/0/52 to VLAN 3 for forwarding BFD MAD packets.
<DeviceE> system-view
[DeviceE] vlan 3
[DeviceE-vlan3] port hundredgige 1/0/49 to hundredgige 1/0/52
[DeviceE-vlan3] quit
Example: Configuring an IRF fabric with ARP MAD enabled on a VLAN interface
As shown in Figure 16, set up a four-chassis IRF fabric in the enterprise network.
·     Configure ARP MAD on the IRF fabric and use the links connected to Device E for transmitting ARP MAD packets.
·     To prevent loops, run the spanning tree feature between Device E and the IRF fabric.
Figure 16 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 16, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 16, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 16, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure ARP MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ARP MAD VLAN to MSTI 1 in the MST region.
[Sysname] stp global enable
[Sysname-mst-region] region-name arpmad
[Sysname-mst-region] instance 1 vlan 3
[Sysname-mst-region] quit
# Configure the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
[Sysname] undo irf mac-address persistent
# Create VLAN 3, and assign Twenty-FiveGigE 1/0/1, Twenty-FiveGigE 2/0/1, Twenty-FiveGigE 3/0/1, and Twenty-FiveGigE 4/0/1 to VLAN 3.
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IP address, and enable ARP MAD on the interface.
[Sysname-Vlan-interface3] ip address 192.168.2.1 24
[Sysname-Vlan-interface3] mad arp enable
6.     Configure Device E as the intermediate device for ARP MAD:
CAUTION
CAUTION:
If the intermediate device is also in an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
[DeviceE] stp global enable
[DeviceE] stp region-configuration
[DeviceE-mst-region] region-name arpmad
[DeviceE-mst-region] instance 1 vlan 3
[DeviceE-mst-region] active region-configuration
[DeviceE-mst-region] quit
# Create VLAN 3, and assign HundredGigE 1/0/49, HundredGigE 1/0/50, HundredGigE 1/0/51, and HundredGigE 1/0/52 to VLAN 3 for forwarding ARP MAD packets.
[DeviceE] vlan 3
Example: Configuring an IRF fabric with ND MAD enabled on a VLAN interface
As shown in Figure 17, set up a four-chassis IRF fabric in the IPv6 enterprise network.
·     Configure ND MAD on the IRF fabric and use the links connected to Device E for transmitting ND MAD packets.
Figure 17 Network diagram
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device B to Device A as shown in Figure 17, and log in to Device B. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device C to Device A as shown in Figure 17, and log in to Device C. (Details not shown.)
[Sysname] save
[Sysname] quit
<Sysname> reboot
# Connect Device D to Device B and Device C as shown in Figure 17, and log in to Device D. (Details not shown.)
[Sysname] save
5.     Configure ND MAD on the IRF fabric:
# Enable the spanning tree feature globally. Map the ND MAD VLAN to MSTI 1 in the MST region.
[Sysname-mst-region] region-name ndmad
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IPv6 address, and enable ND MAD on the interface.
[Sysname-Vlan-interface3] ipv6 address 2001::1 64
[Sysname-Vlan-interface3] mad nd enable
6.     Configure Device E as the intermediate device for ND MAD:
CAUTION
CAUTION:
[DeviceE-mst-region] region-name ndmad
# Create VLAN 3, and add HundredGigE 1/0/49, HundredGigE 1/0/50, HundredGigE 1/0/51, and HundredGigE 1/0/52 to VLAN 3 for forwarding ND MAD packets.
[DeviceE] vlan 3
Example: Configuring an IRF fabric with ARP MAD and management IP configured on the same management Ethernet port
IMPORTANT
IMPORTANT:
This example is also applicable to a two-chassis IRF fabric running ND MAD, except that you must configure ND MAD rather than ARP MAD.
As shown in Figure 18, use Device A and Device B to set up a two-chassis IRF fabric.
Use management Ethernet port M-GigabitEthernet 0/0/0 to perform ARP MAD for IRF split detection and to provide device access for management purposes.
Configure management IP addresses for the IRF fabric and each member device on the management port to meet the following requirements:
·     The administrator can use the same management IP address to access the IRF fabric before and after an active/subordinate switchover.
·     The administrator can access each member device for failure recovery through their respective management IP addresses after the IRF fabric splits.
Figure 18 Network diagram
When you configure management IP addresses, follow these restrictions and guidelines:
·     To make sure you can access the IRF fabric at the same IP address after a master/subordinate switchover, use the ip address ip-address { mask-length | mask } command to configure a management IP address on the management port, in this example, on M-GigabitEthernet 0/0/0. You can use this address to access the IRF fabric as long as the fabric has not split. This address might be inaccesible for an IP conflict after the IRF fabric splits, because it exists on all member devices. In the context of IRF, this address is called a global management IP address.
·     To access each member device for failure recovery after the IRF fabric splits, use the ip address ip-address { mask-length | mask } irf-member member-id command to configure a management IP address for each member device on the management port, in this example, on M-GigabitEthernet 0/0/0. In the context of IRF, this address is called a member-specific management IP address.
·     Make sure the management IP addresses assigned to all IRF member devices on the same management Ethernet port belong to the same subnet. Make sure the management IP addresses assigned to an IRF member device on different management Ethernet ports belong to different subnets.
·     You must manually make sure the management IP addresses configured on the subordinate devices will not cause IP address conflicts on the network. When the IRF fabric is running correctly, only the IP addresses of the management Ethernet ports on the master device take effect. The management IP addresses of the management Ethernet ports on the subordinate devices do not take effect. If a management IP address on a subordinate device conflicts with an IP address in the network, the system cannot detect the IP conflict, causing network issues after an IRF split.
When the IRF fabric is integrated, you can access the IRF fabric by using either the global management IP address or the management IP address specific to the master device. As a best practice to prevent the management IP address from changing upon a master/subordinate switchover, use the global management IP address as long as the IRF fabric is integrated.
When you configure ARP MAD on a management Ethernet port, follow the restrictions and guidelines in "Configuring ARP MAD."
Setting up the IRF fabric
# Shut down the physical interfaces used for IRF connection. This example uses HundredGigE 1/0/49 and HundredGigE 1/0/50 for IRF connection.
[Sysname] interface range hundredgige 1/0/49 to hundredgige 1/0/50
# Bind HundredGigE 1/0/49 and HundredGigE 1/0/50 to IRF-port 1/2.
[Sysname-irf-port1/2] port group interface hundredgige 1/0/49
[Sysname-irf-port1/2] port group interface hundredgige 1/0/50
# Bring up the physical interfaces.
# Save the running configuration to the next-startup configuration file.
[Sysname] save
# Assign member ID 2 to Device B, and reboot the device to have the change take effect.
[Sysname] quit
<Sysname> reboot
# Shut down the physical interfaces used for IRF connection. This example uses HundredGigE 2/0/49 and HundredGigE 2/0/50 for IRF connection.
[Sysname] interface range hundredgige 2/0/49 to hundredgige 2/0/50
[Sysname] save
# Connect Device B to Device A, as shown in Figure 18.
Device A and Device B perform master election. The device that has failed master election automatically reboots to form an IRF fabric with the other device. A two-chassis IRF fabric is formed.
Configuring management IP addresses
# Assign IP address 192.168.1.1/24 to the IRF fabric on management Ethernet port M-GigabitEthernet 0/0/0.
[Sysname] interface m-gigabitethernet 0/0/0
[Sysname-M-GigabitEthernet0/0/0] ip address 192.168.1.1 24
# On management Ethernet port M-GigabitEthernet 0/0/0, assign IP addresses 192.168.1.101/24 and 192.168.1.102/24 to IRF member device 1 (Device A) and IRF member device 2 (Device B), respectively. After the IRF fabric splits, the administrator can use IP addresses 192.168.1.101/24 and 192.168.1.102/24 to log in to Device A and Device B, respectively.
[Sysname-M-GigabitEthernet0/0/0] ip address 192.168.1.101 24 irf-member 1
[Sysname-M-GigabitEthernet0/0/0] ip address 192.168.1.102 24 irf-member 2
[Sysname-M-GigabitEthernet0/0/0] quit
# Exclude management Ethernet port M-GigabitEthernet 0/0/0 from being shut down by MAD upon detection of multi-active collisions.
[Sysname] mad exclude interface m-gigabitethernet 0/0/0
Configuring ARP MAD
1.     Configure the IRF fabric:
# Enable ARP MAD on management Ethernet port M-GigabitEthernet 0/0/0.
[Sysname-M-GigabitEthernet0/0/0] mad arp enable
[Sysname] save
2.     Configure Device C (a switch that supports ARP) as the intermediate device for ARP MAD:
CAUTION
CAUTION:
# Create VLAN 100.
<DeviceC> system-view
[DeviceC] vlan 100
# Assign GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to VLAN 100 for forwarding ARP MAD packets.
[DeviceC-vlan100] port gigabitethernet 1/0/1 to gigabitethernet 1/0/2
[DeviceC-vlan100] quit
# Disconnect the IRF links between Device A and Device B. Verify that you can use 192.168.1.101 and 192.168.1.102 to log in to Device A and Device B, respectively. (Details not shown.)
# Execute the display mad verbose command on Device A and Device B to verify that MAD is correctly functioning, as follows:
·     The Multi-active recovery state field displays Yes on one device and displays No on the other device.
·     On each device, the IRF physical interfaces and management Ethernet port M-GigabitEthernet 0/0/0 are excluded from being shut down by MAD.
#  Execute the display interface brief command on Device A and Device B to verify that the MAD shutdown action is performed correctly, as follows:
·     On the device in Recovery state, all network interfaces have been shut down by MAD except the IRF physical interfaces and management Ethernet port M-GigabitEthernet 0/0/0.
·     On the device not in Recovery state, no network interfaces are shut down by MAD.
Example: Removing member devices from an IRF fabric without MAD in place
As shown in Figure 19 or Figure 20, an IRF fabric is in daisy-chain or ring topology. The IRF fabric contains four member devices, in which member 1 is the master device. MAD is not configured on the IRF fabric.
Remove member devices 3 and 4 from the IRF fabric.
Figure 19 Network diagram (daisy-chain topology)
Figure 20 Network diagram (ring topology)
1.     Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves the fabric.
<System> system-view
[System] undo irf mac-address persistent
2.     Shut down the network interfaces that connect member devices 3 and 4 to the upstream and downstream devices. (Details not shown.)
3.     Use one of the following methods to split the IRF fabric into two IRF fabrics (IRF 1 and IRF 2):
¡     Disconnect the physical IRF links between IRF 1 and IRF 2, as shown in Figure 21 or Figure 22.
Figure 21 Disconnecting physical IRF links (daisy-chain topology)
Figure 22 Disconnecting physical IRF links (ring topology)
¡     Shut down the IRF physical interfaces that connect IRF 1 and IRF 2, as shown in Figure 21 or Figure 22. (Details not shown.)
The IRF fabric splits into IRF 1 and IRF 2. Because MAD is not configured, both IRF 1 and IRF 2 are active. The member devices in IRF 2 automatically elect a master on split.
4.     Handle IRF 2:
¡     To retain IRF 2 in the network, log in to IRF 2, modify the IP addresses that conflict with those on IRF 1 and change its domain ID. (Details not shown.)
¡     To remove IRF 2 from the network, disconnect all physical network connections from the IRF fabric and remove IRF configuration from all member devices in the IRF fabric. (Details not shown.)
5.     Bring up the network interfaces that have been shut down on the removed member devices. (Details not shown.)
6.     Remove IRF port bindings from unused IRF physical interfaces on IRF 1. (Details not shown.)
Example: Removing member devices from an IRF fabric with MAD in place
As shown in Figure 23 or Figure 24, an IRF fabric is in daisy-chain or ring topology. The IRF fabric contains four member devices, in which member 1 is the master device. MAD is configured on the IRF fabric.
Figure 23 Network diagram (daisy-chain topology)
Figure 24 Network diagram (ring topology)
¡     Disconnect the physical IRF links between IRF 1 and IRF 2, as shown in Figure 25 or Figure 26.
Figure 25 Disconnecting physical IRF links (daisy-chain topology)
Figure 26 Disconnecting physical IRF links (ring topology)
¡     Shut down the IRF physical interfaces that connect IRF 1 and IRF 2, as shown in Figure 25 or Figure 26. (Details not shown.)
The IRF fabric splits into IRF 1 and IRF 2. Because MAD is configured, IRF 1 remains active and IRF 2 is placed in Recovery state and becomes inactive.
4.     Handle IRF 2:
¡     To retain IRF 2 in the network, log in to IRF 2, modify the IP addresses that conflict with those on IRF 1, change its domain ID, and recover IRF 2.
[System] irf domain 2
[System] mad restore
