H3C S5560X-EI Traffic Statistics Collection-6W100
HomeSupportSwitchesS5560X-EI SeriesConfigure & DeployConfiguration GuidesH3C S5560X-EI Traffic Statistics Collection-6W100
Table of Contents
Related Documents
book
book 1.80 MB
Document version: 6W100-20240803
About traffic statistics collection· 1
Traffic statistics collection techniques· 1
CLI 1
SNMP· 2
About SNMP· 2
SNMP framework· 2
MIB and view-based MIB access control 2
Protocol versions· 3
Access control modes· 3
NETCONF· 4
About NETCONF· 4
NETCONF protocol stack· 4
NETCONF message formats· 5
NETCONF connection methods· 6
gRPC· 7
About gRPC· 7
gRPC protocol stack layers· 7
gRPC network architecture· 7
Telemetry technology based on gRPC· 7
Telemetry modes· 8
Protocol buffer code format 8
Proto definition files· 8
Collecting interface traffic statistics· 9
Collecting traffic statistics for a Layer 2 Ethernet interface or a Layer 2 aggregate interface· 9
CLI 9
SNMP· 15
NETCONF· 21
gRPC· 23
Collecting error packet statistics for an Ethernet interface· 24
CLI 24
SNMP· 26
NETCONF· 28
gRPC· 30
Collecting traffic statistics for Layer 3 Ethernet interfaces/Layer 3 Ethernet subinterfaces/Layer 3 aggregation group member interfaces· 31
CLI 31
SNMP· 41
NETCONF· 44
gRPC· 46
Collecting Layer 2 aggregate interface traffic statistics· 46
CLI 46
SNMP· 47
NETCONF· 50
gRPC· 52
Collecting Layer 3 aggregate interface traffic statistics· 53
CLI 53
SNMP· 54
NETCONF· 57
gRPC· 60
Collecting Layer 3 aggregate subinterface traffic statistics· 61
CLI 61
SNMP· 61
NETCONF· 64
gRPC· 66
Collecting VLAN interface traffic statistics· 68
CLI 68
SNMP· 69
NETCONF· 71
gRPC· 73
Collecting dropped packet statistics of an interface through MQC· 74
Requirements· 74
CLI 74
SNMP· 75
NETCONF· 77
gRPC· 81
Collecting Ethernet interface traffic statistics through MQC· 82
Requirements· 82
CLI 82
SNMP· 84
NETCONF· 86
gRPC· 88
Collecting VXLAN traffic statistics· 89
Collecting AC traffic statistics· 89
Requirements· 89
Restrictions and guidelines· 89
CLI 90
SNMP· 91
NETCONF· 93
gRPC· 95
Collecting VSI traffic statistics· 95
Requirements· 95
CLI 96
SNMP· 97
NETCONF· 99
gRPC· 101
Collecting VSI interface traffic statistics· 102
Requirements· 102
CLI 102
Collecting AC traffic statistics through MQC· 103
Requirements· 103
CLI 103
SNMP· 105
NETCONF· 107
gRPC· 109
Collecting VLAN traffic statistics· 110
Requirements· 110
CLI 110
Task· 110
Restrictions and guidelines· 110
Procedure· 110
Obtain traffic statistics· 111
Learn more· 111
SNMP· 112
Task· 112
Procedure· 112
Example: Obtain traffic statistics· 112
Learn more· 113
NETCONF· 114
Task· 114
Procedure· 114
Example: Obtain traffic statistics· 114
Learn more· 115
gRPC· 115
Task· 115
Procedure· 116
Obtain traffic statistics· 116
Learn more· 116
Collecting VPN instance traffic statistics· 116
Requirements· 116
CLI 117
Task· 117
Restrictions and guidelines· 117
Procedure· 117
Example: Obtain traffic statistics· 118
Learn more· 118
SNMP· 118
Task· 118
Procedure· 119
Example: Obtain traffic statistics· 119
Learn more· 121
NETCONF· 121
Task· 121
Procedure· 121
Example: Obtain traffic statistics· 121
Learn more· 122
gRPC· 122
Task· 122
Procedure· 123
Example: Obtain traffic statistics· 123
Learn more· 123
Collecting queue traffic statistics· 124
Collecting traffic statistics for interface queues· 124
Requirements· 124
CLI 124
SNMP· 125
NETCONF· 128
gRPC· 129
Collecting buffer traffic statistics for queues· 130
Requirements· 130
SNMP· 130
NETCONF· 131
gRPC· 135
Collecting packet drop statistics for queues· 136
Requirements· 136
SNMP· 136
NETCONF· 137
gRPC· 139
The traffic statistics collection feature classifies the incoming and outgoing traffic of a device and collects their statistics. This feature can collect traffic statistics for multiple features, for example, interface, tunnel, virtual private network (VPN), and virtual extensible local area network (VXLAN). You can use traffic statistics for data analysis, traffic accounting, and troubleshooting.
To meet the requirements of different users in different scenarios, H3C switches support the following traffic statistics collection methods:
·     CLI—Command line interface, a method provided by the device for traffic statistics collection that does not require third-party functionality. For more information about CLI-based traffic statistics collection, see "CLI."
·     SNMP—Simple Network Management Protocol. In this method, a network management system (NMS) collects traffic statistics of devices with different vendors, physical characteristics, and interconnection technologies on the network by using SNMP. For more information about SNMP, see "SNMP."
·     NETCONF—Network Configuration Protocol. NETCONF is an extensible markup language (XML)-based network management protocol that provides a programmable method for configuring and managing network devices. You can obtain traffic statistics of devices through this protocol. For more information about NETCONF, see "NETCONF."
·     gRPC—Google Remote Procedure Call. By configuring the gRPC dial-out mode on a device, you can enable the device to periodically push statistics to the collectors. For more information about gRPC, see "gRPC."
Configuring traffic statistics collection on a device will impact device forwarding performance. For example, when modular quality of service (QoS) configuration (MQC) is used to collect traffic statistics, the more interfaces that use MQC for traffic statistics collection, the lower the device forwarding performance. Use this feature as appropriate in necessary scenarios.
CLI
You can collect traffic statistics at the CLI in the following methods:
·     Execute the display interface/display ip interface/display ipv6 interface command to directly display the traffic statistics of the specified interface. This method is available for the following types of interfaces:
¡     Layer 2 Ethernet interface.
¡     Layer 3 Ethernet interface/subinterface.
¡     Layer 2 aggregate interface.
¡     Layer 3 aggregate interface/subinterface.
¡     VLAN interface.
¡     Breakout interface.
·     First enable Layer 3 traffic statistics collection on the specified interface, and then execute the display interface command to display traffic statistics of the interface. This method is available for Layer 2 Ethernet interfaces and Layer 3 Ethernet interfaces.
·     Configure the specified function first, and then enable the traffic statistics collection feature at the specified locations. For example, read the traffic statistics of attachment circuit (AC) or virtual switching instance (VSI) interfaces.
·     Obtain traffic statistics at a specific location through MQC. MQC defines actions to take on different types of traffic through QoS policies, and applies these policies to different destinations (for example, interfaces and VLANs) to collect traffic statistics. Compared with other CLI-based traffic statistics collection methods, MQC can collect statistics for more types of traffic. For example, you can configure traffic classes to match packets through various criteria, such as 802.1p priority in inner VLAN tag, DSCP, and ACL. The statistics include forwarded and dropped packets in packets or bytes, and packets dropped by filter actions or committed access rate (CAR) in packets or bytes.
The statistics that can be collected might vary by statistics collection method. For example, the display interface/display ip interface/display ipv6 interface commands only support collecting traffic statistics of interfaces and do not support collecting traffic statistics of VLANs or VPNs. MQC supports collecting traffic statistics of not only interfaces (except VLAN interfaces) but also VXLANs, VPNs, and VLANs.
SNMP
About SNMP
Simple Network Management Protocol (SNMP) is used for a management station to manage and collect traffic statistics for devices on a network, regardless of their vendors, physical characteristics, and interconnect technologies.
You can collect traffic statistics for H3C devices with SNMP get operations.
SNMP framework
The SNMP framework contains the following elements:
·     SNMP manager—Works on an NMS to monitor and manage the SNMP-capable devices in the network. It can get and set values of MIB objects on the agent.
·     SNMP agent—Works on a managed device to receive and handle requests from the NMS, and sends notifications to the NMS when events, such as an interface state change, occur.
·     Management Information Base (MIB)—Specifies the variables (for example, interface status and CPU usage) maintained by the SNMP agent for the SNMP manager to read and set.
Figure 1 Relationship between NMS, agent, and MIB
A MIB stores variables called "nodes" or "objects" in a tree hierarchy and identifies each node with a unique OID. An OID is a dotted numeric string that uniquely identifies the path from the root node to a leaf node. For example, object B in Figure 2 is uniquely identified by the OID {1.2.1.1}.
Figure 2 MIB tree
A MIB view represents a set of MIB objects (or MIB object hierarchies) with certain access privileges and is identified by a view name. The MIB objects included in the MIB view are accessible while those excluded from the MIB view are inaccessible.
A MIB view can have multiple view records each identified by a view-name oid-tree pair.
You control access to the MIB by assigning MIB views to SNMP groups or communities.
Protocol versions
SNMPv1, SNMPv2c, and SNMPv3 are supported in non-FIPS mode. Only SNMPv3 is supported in FIPS mode. An NMS and an SNMP agent must use the same SNMP version to communicate with each other.
·     SNMPv1—Uses community names for authentication. To access an SNMP agent, an NMS must use the same community name as set on the SNMP agent. If the community name used by the NMS differs from the community name set on the agent, the NMS cannot establish an SNMP session to access the agent or receive traps from the agent.
·     SNMPv2c—Uses community names for authentication. SNMPv2c is compatible with SNMPv1, but supports more operation types, data types, and error codes.
·     SNMPv3—Uses a user-based security model (USM) to secure SNMP communication. You can configure authentication and privacy mechanisms to authenticate and encrypt SNMP packets for integrity, authenticity, and confidentiality.
SNMP uses the following modes to control access to MIB objects:
·     View-based Access Control Model—VACM mode controls access to MIB objects by assigning MIB views to SNMP communities or users.
·     Role based access control—RBAC mode controls access to MIB objects by assigning user roles to SNMP communities or users.
¡     SNMP communities or users with the network-admin, mdc-admin, or level-15 predefined user role have read and write access to all MIB objects.
¡     SNMP communities or users with the network-operator or mdc-operator predefined user role have read-only access to all MIB objects.
¡     SNMP communities or users with a user-defined user role have access rights to MIB objects as specified by the rule command.
RBAC mode controls access on a per MIB object basis, and VACM mode controls access on a MIB view basis. As a best practice to enhance MIB security, use the RBAC mode.
If you create the same SNMP community or user with both modes multiple times, the most recent configuration takes effect.
NETCONF
About NETCONF
Network Configuration Protocol (NETCONF) is an XML-based network management protocol. It provides a programmable mechanism to manage and configure network devices. Network administrators can use NETCONF to configure network devices and retrieve their configuration and operational data. On a network that has devices from different vendors, you can develop a NETCONF-based management system to configure and manage devices in a simple and effective way.
The NETCONF protocol stack contains a content layer, operations layer, remote procedure call (RPC) layer, and transport protocol layer.
Table 1 NETCONF layer and XML layer mappings
NETCONF layer
XML layer
Content layer
Configuration data, operational state data, and statistics
Contains a set of managed objects, which can be configuration data, operational state data, and statistics.
For information about permission of access to the data nodes, see the NETCONF XML API references for the device.
Operations
<get>, <get-config>…
Defines a set of base operations invoked as RPC methods with XML-encoded parameters.
NETCONF comprehensively defines various traffic statistics operations for managed devices.
RPC
<rpc> and <rpc-reply>
Provides a simple, transport-independent framing mechanism for encoding RPCs. The <rpc> and <rpc-reply> elements are used to enclose NETCONF requests and responses (data at the operations layer and the content layer).
Transport protocol
In non-FIPS mode:
Console, Telnet, SSH, HTTP, HTTPS, and TLS
In FIPS mode:
Console, SSH, HTTPS, and TLS
Provides reliable, connection-oriented, serial data links.
The following transport layer sessions are supported in non-FIPS mode:
·     CLI sessions, including NETCONF over Telnet, NETCONF over SSH, and NETCONF over console sessions.
·     NETCONF over SOAP sessions, including NETCONF over SOAP over HTTP and NETCONF over SOAP over HTTPS sessions.
The following transport layer sessions are supported in FIPS mode:
·     CLI sessions, including NETCONF over SSH and NETCONF over console sessions.
·     NETCONF over SOAP over HTTPS sessions.
NETCONF
All NETCONF messages are XML-encoded and comply with the formats defined in RFC 4741. Any incoming NETCONF messages must pass XML Schema check before it can be processed. If a NETCONF message fails XML Schema check, the device sends an error message to the client.
For information about the NETCONF operations supported by the device and the operable data, see the NETCONF XML API references for the device.
The following example shows a NETCONF request that retrieves all data from all interfaces on the target device:
<?xml version="1.0" encoding="utf-8"?>
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <Ifmgr>
          <Interfaces>
                 <Interface/>
          </Interfaces>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
NETCONF over SOAP
All NETCONF over SOAP messages are contained in the <Body> element of SOAP messages. NETCONF over SOAP messages also comply with the following rules:
·     The SOAP messages must be XML encoded.
·     SOAP messages must use the SOAP Envelope namespaces and SOAP Encoding namespaces.
·     The SOAP messages cannot contain the following information:
¡     DTD references.
¡     XML processing instructions.
The following example shows a NETCONF over SOAP message for getting all parameters of all interfaces on the target device:
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
  <env:Header>
    <auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
      <auth:AuthInfo>800207F0120020C</auth:AuthInfo>
    </auth:Authentication>
  </env:Header>
  <env:Body>
      <get-bulk>
            <Ifmgr>
              <Interfaces>
                <Interface/>
              </Interfaces>
            </Ifmgr>
          </top>
        </filter>
      </get-bulk>
    </rpc>
  </env:Body>
</env:Envelope>
The switch series supports different NETCONF connection methods in non-FIPS mode and FIPS mode.
·     In non-FIPS mode:
¡     NETCONF over SSH.
¡     NETCONF over Telnet.
¡     NETCONF over console.
¡     NETCONF over SOAP over HTTP.
¡     NETCONF over SOAP over HTTPS.
·     In FIPS mode:
¡     NETCONF over SSH.
Select a connection method depending on the configuration method, as shown in Table 2.
Table 2 Configuration methods and NETCONF connection methods matrix
Login method
CLI in XML view
Telnet
NETCONF over Telnet
Console port
IMPORTANT IMPORTANT:
The console port has rate limiting, and the device does not generate prompts or warning in XML view. As a best practice to avoid configuration errors, do not use this method.
SSH
NETCONF over SSH
SSH-based configuration tool
SSH
NETCONF over SSH
SOAP-based configuration tool
HTTP or HTTPS
NETCONF over SOAP over HTTP/HTTPS
This document only introduces the NETCONF over SOAP method. For information about other methods, see H3C NETCONF-Based Device Configuration and Management Guide.
gRPC
About gRPC
gRPC is an open source remote procedure call (RPC) system initially developed at Google. It uses HTTP 2.0 and provides methods neutral to programming languages for network device configuration and management. The server and client developers can develop server-side and client-side custom capabilities in the gRPC framework.
Table 3 shows the gRPC protocol stack.
Table 3 gRPC protocol stack layers
Layer
Content layer
Defines the data of the service module.
Two parties of communication must notify each other of the data models that they are using.
Protocol buffer encoding layer
gRPC encodes data by using the protocol buffer code format.
gRPC layer
Defines the protocol interaction format for remote procedure calls.
HTTP 2.0 layer
Carries gRPC.
TCP layer
TCP provides connection-oriented, reliable, and sequential data links.
As shown in Figure 3, a gRPC network uses the client/server model and transports messages between the client and the server over HTTP 2.0.
Figure 3 gRPC network architecture
The gRPC network uses the following mechanism:
1.     The gRPC server listens to connection requests from clients at the gRPC service port.
2.     A user or system runs a gRPC client application to connect to the gRPC server.
3.     The gRPC client calls methods provided in the .proto file to send requests.
4.     The gRPC server responds to the requests from the gRPC client.
H3C devices can act as gRPC servers or clients.
As shown in Figure 4, after a gRPC connection is established between the device and NMSs, the NMSs can subscribe to data of modules on the device.
Figure 4 Telemetry technology based on gRPC
Telemetry modes
The device supports the following telemetry modes:
·     Dial-in mode—The device acts as a gRPC server and the collectors act as gRPC clients. A collector initiates a gRPC connection to the device to subscribe to device data.
Dial-in mode typically applies to small networks and scenarios where collectors deploy configurations to devices.
·     Dial-out mode—The device acts as a gRPC client and the collectors act as gRPC servers. The device initiates gRPC connections to the collectors and pushes device data to the collectors as configured.
Dial-out mode typically applies to large networks where the collectors must collect data from a large number of devices.
H3C devices implement traffic statistics collection in dial-out mode.
Google Protocol Buffers provide a flexible mechanism for serializing structured data. Different from XML code and JSON code, the protocol buffer code is binary and provides higher performance.
You can define data structures in a proto definition file. Then, you can compile the file with utility protoc to generate code in a programing language such as Java and C++. Using the generated code, you can develop an application for a collector to communicate with the device.
H3C provides proto definition files for both dial-in mode and dial-out mode.
Proto definition files in dial-in mode
·     Public proto definition files.
The dial-in mode supports the grpc_service.proto public proto definition file, which defines the public RPC methods in dial-in mode (for example, login and logout).
·     Proto definition files for service modules.
The dial-in mode supports proto definition files for the following service modules: Device, Ifmgr, IPFW, LLDP, and Syslog.
Proto definition file in dial-out mode
The grpc_dialout.proto file defines the public RPC methods in dial-out mode.
Obtaining proto definition files
To obtain proto files, contact H3C Support.
IMPORTANT
IMPORTANT:
The traffic statistics collection procedure for Layer 2 Ethernet interfaces is the same as that for Layer 2 aggregate interfaces. The following uses Layer 2 Ethernet interfaces as an example.
CLI
Obtain the traffic statistics for interface Ten-GigabitEthernet 1/0/27.
·     You can use the display interface command to obtain the traffic statistics for Layer 2 Ethernet interfaces.
·     For Layer 2 aggregate interfaces, the statistics is not differentiated between IPv4 and IPv6 packets.
·     Layer 2 Ethernet interfaces support enabling Layer 3 traffic statistics collection. After Layer 3 traffic statistics collection is enabled, you can use the display interface command to view the IPv4 and IPv6 traffic statistics for a physical interface.
·     You cannot use the display ip interface and display ipv6 interface commands to view the traffic statistics for an interface.
·     To collect traffic statistics for an interface within a certain period of time, use the reset counters interface command in user view to clear the interface statistics and start a new statistics collection task.
·     The reset counters interface command can clear the interface statistics collected at the CLI, but cannot clear the interface statistics on MIB.
# (Optional.) Enable Layer 3 traffic statistics collection for Ten-GigabitEthernet 1/0/27.
<H3C> sys-view
[H3C] interface ten-gigabitethernet 1/0/27
[H3C-Ten-GigabitEthernet1/0/27] statistics l3-packet enable inbound
[H3C-Ten-GigabitEthernet1/0/27] statistics l3-packet enable outbound
·     If Layer 3 traffic statistics collection is not enabled, use the display interface command to perform traffic statistics collection.
# Obtain the traffic statistics for interface Ten-GigabitEthernet 1/0/27.
[H3C]display interface ten-gigabitethernet 1/0/27
 Peak input rate: 0 bytes/sec, at 2022-04-07 16:07:11
 Peak output rate: 0 bytes/sec, at 2022-04-07 16:07:11
 Last 300 seconds input: 0 packets/sec 0 bytes/sec 0%
 Last 300 seconds output: 0 packets/sec 0 bytes/sec 0%
 Input (total):  612 packets, 77760 bytes
         606 unicasts, 1 broadcasts, 5 multicasts, 0 pauses
 Input (normal):  612 packets, - bytes
         0 CRC, 0 frame, - overruns, 0 aborts
         - ignored, - parity errors
 Output (total): 614 packets, 77888 bytes
         607 unicasts, 3 broadcasts, 4 multicasts, 0 pauses
 Output (normal): 614 packets, - bytes
 Output: 0 output errors, - underruns, 0 buffer failures
         0 lost carrier, - no carrier
Peak input rate
Peak rate of inbound traffic in Bps, and the time when the peak inbound traffic rate occurred.
Peak output rate
Peak rate of outbound traffic in Bps, and the time when the peak outbound traffic rate occurred.
Last interval seconds input:  0 packets/sec 0 bytes/sec 0%
Last interval seconds output:  0 packets/sec 0 bytes/sec 0%
Average inbound or outbound traffic rate (in pps and Bps) in the last statistics polling interval, and the ratio of the actual rate to the interface bandwidth. To set the statistics polling interval (interval), use the flow-interval command.
A hyphen (-) indicates that the statistical item is not supported.
Input(total):  0 packets, 0 bytes
The two fields on the first line represent the inbound traffic statistics (in packets and bytes) for the interface. All inbound normal packets, abnormal packets, and normal pause frames were counted.
·     The four fields on the second line represent:
·     Number of inbound unicast packets.
·     Number of inbound broadcasts.
·     Number of inbound multicasts.
·     Number of inbound pause frames.
Input(normal):  0 packets, 0 bytes
The two fields on the first line represent the inbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of inbound normal unicast packets.
·     Number of inbound normal broadcasts.
·     Number of inbound normal multicasts.
·     Number of inbound normal pause frames.
input errors
Statistics for incoming error packets.
runts
Number of inbound frames meeting the following conditions:
·     Shorter than 64 bytes.
·     In correct format.
·     Containing valid CRCs.
giants
Number of inbound giants.
Giants refer to frames larger than the maximum frame length supported on the interface.
·     For an Ethernet interface that does not permit jumbo frames, the maximum frame length is as follows:
¡     1518 bytes (without VLAN tags).
¡     1522 bytes (with VLAN tags).
·     For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
throttles
Number of inbound frames that had a non-integer number of bytes.
CRC
Total number of inbound frames that had a normal length, but contained CRC errors.
frame
Total number of inbound frames that contained CRC errors and a non-integer number of bytes.
overruns
Number of packets dropped because the input rate of the port exceeded the queuing capability.
aborts
Total number of illegal inbound packets:
·     Fragment frames—CRC error frames shorter than 64 bytes. The length (in bytes) can be an integral or non-integral value.
·     Jabber frames—CRC error frames greater than the maximum frame length supported on the Ethernet interface (with an integral or non-integral length). For an Ethernet interface that does not permit jumbo frames, the maximum frame length is 1518 bytes (without VLAN tags) or 1522 bytes (with VLAN tags). For an Ethernet interface that permits jumbo frames, the maximum Ethernet frame length is set when you configure jumbo frame support on the interface.
·     Symbol error frames—Frames that contained a minimum of one undefined symbol.
·     Unknown operation code frames—Non-pause MAC control frames.
·     Length error frames—Frames whose 802.3 length fields did not match the actual frame length (46 to 1500 bytes).
ignored
Number of inbound frames dropped because the receiving buffer of the port ran low.
parity errors
Total number of frames with parity errors.
Output(total): 0 packets, 0 bytes
The two fields on the first line represent the outbound traffic statistics (in packets and bytes) for the interface. All outbound normal packets, abnormal packets, and normal pause frames were counted.
·     Number of outbound unicast packets.
·     Number of outbound broadcasts.
·     Number of outbound multicasts.
·     Number of outbound pause frames.
Output(normal): 0 packets, 0 bytes
The two fields on the first line represent the outbound normal traffic and pause frame statistics (in packets and bytes) for the interface.
·     Number of outbound normal unicast packets.
·     Number of outbound normal broadcasts.
·     Number of outbound normal multicasts.
·     Number of outbound normal pause frames.
output errors
Number of outbound packets with errors.
underruns
Number of packets dropped because the output rate of the interface exceeded the output queuing capability. This is a low-probability hardware anomaly.
buffer failures
Number of packets dropped because the transmitting buffer of the interface ran low.
aborts
Number of packets that failed to be transmitted, for example, because of Ethernet collisions.
deferred
Number of frames that the interface deferred to transmit because of detected collisions.
collisions
Number of frames that the interface stopped transmitting because Ethernet collisions were detected during transmission.
late collisions
Number of frames that the interface deferred to transmit after transmitting their first 512 bits because of detected collisions.
lost carrier
Number of carrier losses during transmission. This counter increases by one when a carrier is lost, and applies to serial WAN interfaces.
no carrier
Number of times that the port failed to detect the carrier when attempting to send frames. This counter increases by one when a port failed to detect the carrier, and applies to serial WAN interfaces.
·     After Layer 3 traffic statistics collection is enabled, use the display interface to perform traffic statistics.
IPv4 traffic statistics:
 Last 300 seconds input rate: 0 packets/sec, 0 bytes/sec
 Last 300 seconds output rate: 0 packets/sec, 0 bytes/sec
 Input: 300 packets, 38400 bytes
 Output: 300 packets, 38400 bytes
IPv6 traffic statistics:
Table 5 Command output
Peak input rate
Peak output rate
input errors
runts
giants
throttles
CRC
frame
overruns
aborts
ignored
parity errors
output errors
underruns
buffer failures
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Peak input rate
Peak output rate
IPv4 packet statistics.
IPv6 packet statistics.
Average inbound traffic rate (in pps and Bps) in the last 300 seconds.
Average outbound traffic rate (in pps and Bps) in the last 300 seconds.
Input: 0 packets, 0 bytes
Inbound traffic statistics (in packets and bytes) for the interface.
Output: 0 packets, 0 bytes
Outbound traffic statistics (in packets and bytes) for the interface.
SNMP
Use an NMS to obtain the inbound traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device (agent) through SNMP.
Figure 5 Network diagram for SNMP
·     For Layer 2 Ethernet interfaces, traffic statistics can be obtained using the following tables:
¡     ifEntry (with OID 1.3.6.1.2.1.2.2.1)
¡     ifXEntry (with OID 1.3.6.1.2.1.31.1.1)
¡     hh3cIfFlowStatEntry (with OID 1.3.6.1.4.1.25506.2.40.2.1.2.1.1)
¡     hh3cIfHCFlowStatEntry (with OID 1.3.6.1.4.1.25506.2.40.2.1.2.3.1)
¡     hh3cifPortProtocolStatEntry (with OID 1.3.6.1.4.1.25506.8.35.5.1.13.1)
·     For member ports of a Layer 2 aggregate interface, traffic statistics can be obtained using the following tables:
·     In the ifEntry table, the data length for the interface traffic statistics collection node is 32 bits and is 64 bits in the ifXEntry table. Therefore, the interface traffic statistics collection node in the ifEntry table might overflow but that in the ifXEntry table will not when traffic statistics collection is performed.  The nodes in the ifEntry table and the ifXEntry table are not exactly the same, and the two tables have an overlapping relationship. The interface traffic statistics in the ifXEntry table take precedence. If no interface traffic statistics are available in the ifXEntry table, check the ifEntry table.
·     You can use the nodes in the ifEntry, ifXEntry, hh3cIfFlowStatEntry, hh3cIfHCFlowStatEntry, and hh3cifPortProtocolStatEntry tables to obtain different data. For more information about the tables, see the MIB references for your device.
·     SNMPv1 or SNMPv2c (SNMPv1/v2c community creation by community name)
# Create an SNMPv2c read-write community named readtest for the agent.
<Agent> system-view
[Agent] snmp-agent sys-info version v2c
[Agent] snmp-agent community read readtest
# Configure the system contact and location information for the device for maintenance purposes.
[Agent] snmp-agent sys-info contact Mr.Wang-Tel:3306
[Agent] snmp-agent sys-info location telephone-closet,3rd-floor
# Create an SNMPv2c read-write community named readtest for the NMS. In addition, you can set the timeout timer and maximum number of retries. For more information, see the NMS manual.
IMPORTANT
IMPORTANT:
·     For correct communication between the NMS and agent, make sure the SNMP settings on the agent and the NMS match.
·     The access control method depends on the NMS you are using. For more information, see the NMS manual.
·     SNMPv1 or SNMPv2c (SNMPv1/v2c community creation by creating a user and the group that the user is assigned to)
# Create SNMPv2c group readCom. Add user readtest to readCom.
[Sysname] snmp-agent sys-info version v2c
[Sysname] snmp-agent group v2c readCom
[Sysname] snmp-agent usm-user v2c readtest readCom
IMPORTANT
IMPORTANT:
·     SNMPv3 (VACM)
# Enable SNMPv3.
<Agent> system-view
[Agent] snmp-agent sys-info version v3
# Include the subtree with OID 1.3.6.1.2.1.2 in the mibtest view.
[Agent] snmp-agent mib-view included mibtest 1.3.6.1.2.1.2
# Create SNMPv3 group managev3group and assign managev3group read-only access to the objects under the node in the mibtest view.
[Agent] snmp-agent group v3 managev3group privacy read-view mibtest
# Add user managev3user to SNMPv3 group managev3group, and set the authentication algorithm to SHA-1, authentication key to 123456TESTauth&!, encryption algorithm to AES, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 managev3user managev3group simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Configure the contact and location information for the device for maintenance purposes.
# Specify SNMPv3. Create SNMPv3 user VACMtest. Enable authentication and encryption. Set the authentication algorithm to SHA-1, authentication key to 123456TESTauth&!, encryption algorithm to AES, and encryption key to 123456TESTencr&!. Set the timeout timer and maximum number of retries. In addition, you can set the timeout timer and maximum number of retries. For more information, see the NMS manual.
IMPORTANT
IMPORTANT:
·     SNMP (RBAC)
# Enable SNMPv3.
<Agent> system-view
# Include the subtree with OID 1.3.6.1 in the mibtest view.
[Agent] role name test
[Agent-role-test] rule 1 permit read oid 1.3.6.1
[Agent-role-test] quit
# Add user RBACtest to SNMPv3 group managev3group and assign the user role test to it. Set the authentication algorithm to SHA-1, authentication key to 123456TESTauth&!, encryption algorithm to AES, and encryption key to 123456TESTencr&!.
[Agent] snmp-agent usm-user v3 RBACtest user-role test simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
# Specify SNMPv3. Create SNMPv3 user RBACtest.  Enable authentication and encryption. Set the authentication algorithm to SHA-1, authentication key to 123456TESTauth&!, encryption algorithm to AES, and encryption key to 123456TESTencr&!. Set the timeout timer and maximum number of retries. In addition, you can set the timeout timer and maximum number of retries. For more information, see the NMS manual.
IMPORTANT
IMPORTANT:
IMPORTANT
IMPORTANT:
·     To obtain traffic statistics for an interface, you must first obtain the index of the interface and then use the index to obtain traffic statistics for the interface.
·     The interface index might vary by the ID of the IRF member device hosting the interface.
·     This example obtains the inbound traffic statistics for interface Ten-GigabitEthernet 1/0/27 through the MIB browser.
# As shown in Figure 6, obtain the index of interface Ten-GigabitEthernet 1/0/27 through the ifName node (1.3.6.1.2.1.31.1.1.1.1). As shown in Figure 7, the query results dialog box shows that the index is 27 for Ten-GigabitEthernet 1/0/27.
Figure 6 Obtaining the interface index
Figure 7 Query results for the index
# As shown in Figure 8, use the hh3cCBQoSAccountingRunInfoEntry table (with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1) to obtain the inbound traffic statistics (in packets) of interface Ten-GigabitEthernet 1/0/27.
# As shown in Figure 9, the query results are displayed in the Query results window.
Figure 8 Obtaining traffic statistics
Figure 9 Query results
Learn more
For more information about configuring SNMP, see SNMP configuration in the configuration guides for your device.
For more information about MIB files, see the MIB references for your device.
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 10 Network diagram for NETCONF
IMPORTANT
IMPORTANT:
The NETCONF client obtains interface traffic statistics through the NETCONF XML APIs provided by the device.
·     Enable the NETCONF over SOAP over HTTP feature.
# Enable the NETCONF over SOAP feature.
<H3C> system-view
[H3C] netconf soap http enable
Create user admin with permission to operate the device via NETCONF.
# Create a local device management user named admin. Set its password to admin and service type to HTTP.
[H3C] local-user admin class manage
[H3C-luser-manage-admin] password simple admin
[H3C-luser-manage-admin] service-type http
# Configure the user role authorized to user admin as network-admin.
[H3C-luser-manage-admin] authorization-attribute user-role network-admin
·     Enable the NETCONF over SOAP over HTTPS feature.
<H3C> system-view
[H3C] netconf soap https enable
# Create a local device management user named admin. Set its password to admin and service type to HTTPS.
[H3C-luser-manage-admin] service-type https
# Assign user role network-admin to the user..
·     The device provides two tables for interface traffic statistics collection: Ifmgr/Statistics table and IPFW/IPStatistic table. Using the Ifmgr/Statistics table, you can query statistics for the interfaces in packets and bytes, including statistics on unicast, non-unicast, unknown, and discarded packets. Using the IPFW/IPStatistic table, you can query statistics for IPv4 or IPv6 packets of an interface in packets.
·     The following is an example of using the Ifmgr/Statistics table to query the statistics for interface Ten-GigabitEthernet 1/0/27. The configuration procedure for using the IPFW/IPStatistic table to query interface statistics is similar. For more information about the Ifmgr/Statistics table and the IPFW/IPStatistic table, see the MIB references for your device.
# Copy and paste the following message to the NETCONF client.
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <IfIndex></IfIndex>
            <Name>Ten-GigabitEthernet1/0/27</Name>
            <AbbreviatedName></AbbreviatedName>
            <InOctets></InOctets>
            <InUcastPkts></InUcastPkts>
            <InNUcastPkts></InNUcastPkts>
            <InDiscards></InDiscards>
            <InErrors></InErrors>
            <InUnknownProtos></InUnknownProtos>
            <InRate></InRate>
            <OutOctets></OutOctets>
            <OutUcastPkts></OutUcastPkts>
            <OutNUcastPkts></OutNUcastPkts>
            <OutDiscards></OutDiscards>
            <OutErrors></OutErrors>
            <OutRate></OutRate>
            <LastClear></LastClear>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
# If the client receives a message like the following, it indicates that the operation was successful.
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
    <data>
               <Ifmgr>
                  <Statistics>
                     <Interface>
                        <IfIndex>27</IfIndex>
                        <AbbreviatedName>Ten-GigabitEthernet1/0/27</AbbreviatedName>
                        <InOctets>77760</InOctets>
                        <InUcastPkts>606</InUcastPkts>
                        <InNUcastPkts>6</InNUcastPkts>
                        <InDiscards>0</InDiscards>
                        <InErrors>0</InErrors>
                        <InUnknownProtos>0</InUnknownProtos>
                        <InRate>0</InRate>
                        <OutOctets>77888</OutOctets>
                        <OutUcastPkts>607</OutUcastPkts>
                        <OutNUcastPkts>7</OutNUcastPkts>
                        <OutDiscards>0</OutDiscards>
                        <OutErrors>0</OutErrors>
                        <OutRate>0</OutRate>
                        <LastClear>0000-00-00T00:00:00</LastClear>
                     </Interface>
                  </Statistics>
               </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
For more information about configuring NETCONF, see NETCONF configuration in the configuration guides for your device.
For more information about Ifmgr/Statistics and IPFW/IPStatistic, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device by using gRPC.
Figure 11 Network diagram for gRPC
# Configure IP addresses as required so the device and the collector can reach each other. (Details not shown.)
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path Ifmgr/Statistics.
IMPORTANT
IMPORTANT:
After sensor path Ifmgr/Statistics is added, the device will collect traffic statistics for all interfaces and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry] sensor-group test
[H3C-telemetry-sensor-group-test] sensor path ifmgr/statistics
[H3C-telemetry-sensor-group-test] quit
# Create a destination group named collector1 and add a collector to the group. In this example, the collector receives data on port 50050 at IPv4 address 192.168.2.1.
[H3C-telemetry] destination-group collector1
[H3C-telemetry-destination-group-collector1] ipv4-address 192.168.2.1 port 50050
[H3C-telemetry-destination-group-collector1] quit
# Create subscription A, configure the associated sensor group as test, data sampling and push interval as 30 seconds, and associate the target group with collector1.
[H3C-telemetry] subscription A
[H3C-telemetry-subscription-A] sensor-group test sample-interval 30
[H3C-telemetry-subscription-A] destination-group collector1
[H3C-telemetry-subscription-A] quit
The collector receives interface statistics pushed by the device every 30 seconds.
Learn more
For more information about configuring gRPC, see gRPC configuration in the configuration guides for your device.
CLI
Obtain error packet statistics for interface Ten-GigabitEthernet 1/0/27.
·     You can use the display interface command to obtain the error traffic statistics for Ethernet interface.
·     The statistics for error packets only support counting in the inbound direction and do not support counting in the outbound direction. The statistical value for input errors is equal to the sum of the values of runts, giants, throttles, CRC, frame, and aborts.
Use the display interface to perform traffic statistics.
Table 6 Command output
Obtain the traffic statistics of interface Ten-GigabitEthernet 1/0/27
input errors
runts
In correct format.
giants
throttles
CRC
frame
overruns
aborts
ignored
parity errors
output errors
underruns
buffer failures
Number of outbound frames dropped because the receiving buffer of the port ran low.
aborts
deferred
collisions
late collisions
lost carrier
no carrier
SNMP
Use an NMS to obtain the error packet statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device (agent) through SNMP.
Figure 12 Network diagram for SNMP
Configure SNMP. For more information, see "Procedure."
IMPORTANT
IMPORTANT:
·     To obtain error packet statistics for an interface, you must first obtain the index of the interface and then use the index to obtain error packet statistics for the interface.
·     You can view packet loss and error packet statistics on an interface by querying the ifInDiscards, ifOutDiscards, ifInErrors, and ifOutErrors nodes. The statistical method is the same for different tables. This example uses MIB Browser to query the ifInErrors node and obtain the inbound error traffic statistics for the interface Ten-GigabitEthernet 1/0/27.
# As shown in Figure 13, obtain the index of interface Ten-GigabitEthernet 1/0/27 through the ifName node (1.3.6.1.2.1.31.1.1.1.1). The query results dialog box shows that the index is 27 for Ten-GigabitEthernet 1/0/27.
Figure 13 Obtaining the interface index
Figure 14 Query results for the index
# Use the ifInErrors table (with OID 1.3.6.1.2.1.31.1.1.1.6) to obtain the inbound error packet statistics for Ten-GigabitEthernet 1/0/27. As shown in Figure 15, the query results are displayed in the Query results window.
Figure 15 Obtaining traffic statistics
Learn more
NETCONF
Figure 16 Network diagram for NETCONF
IMPORTANT
IMPORTANT:
Configure NETCONF. For more information, see "Procedure."
# Obtaining the interface index.
[H3C-probe]display system internal ifmgr list | include Ten-GigabitEthernet1/0/27
Ten-GigabitEthernet1/0/27(index:27)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
               <Ifmgr>
                  <Statistics>
                     <Interface>
                        <AbbreviatedName>XGE1/0/27</AbbreviatedName>
                        <InOctets>5090007388288</InOctets>
                        <InUcastPkts>39350156658</InUcastPkts>
                        <InNUcastPkts>0</InNUcastPkts>
                        <InErrors>415526968</InErrors>
                        <InRate>1081146628</InRate>
                        <OutOctets>55212</OutOctets>
                        <OutUcastPkts>0</OutUcastPkts>
                        <OutNUcastPkts>172</OutNUcastPkts>
                        <LastClear>2001-01-01T21:16:23</LastClear>
                     </Interface>
                  </Statistics>
               </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
gRPC
Figure 17 Network diagram for gRPC
Configure gRPC. For more information, see "Procedure."
Learn more
IMPORTANT
IMPORTANT:
The traffic statistics for Layer 3 Ethernet interfaces are the same as the statistics for Layer 3 Ethernet subinterfaces and Layer 3 aggregation group member interfaces. Take Layer 3 Ethernet interface traffic statistics as an example.
CLI
Obtain the traffic statistics for interface Ten-GigabitEthernet 1/0/11.
·     You can use the display interface command to obtain the traffic statistics for Layer 2 Ethernet interface. For Layer 3 aggregated member interfaces, the statistics is not differentiated between IPv4 and IPv6 packets..
·     Layer 3 Ethernet interfaces support Layer 3 traffic statistics. After Layer 3 traffic statistics collection is enabled, use the display interface command to view the IPv4 and IPv6 traffic statistics for an interface.
·     You can use the display ip interface or display ipv6 interface command to display traffic statistics for Layer 3 Ethernet interfaces and Layer 3 Ethernet subinterfaces but not Layer 3 aggregate interfaces or 10-GE interfaces.
·     For a Layer 3 Ethernet interface or Layer 3 Ethernet subinterface, unicast, multicast, and broadcast traffic is all counted in the unicast statistics.
·     If subinterfaces are created under a Layer 3 Ethernet interface, the traffic statistics for the Layer 3 Ethernet interface include the traffic statistics for the subinterfaces. Assume that interface Ten-GigabitEthernet 1/0/1 has forwarded 10,000 packets, subinterface Ten-GigabitEthernet 1/0/1.1  has forwarded 10,000 packets, and subinterface Ten-GigabitEthernet 1/0/1.2 has forwarded 10,000 packets. The number of packets forwarded by Ten-GigabitEthernet 1/0/1 is 30000, and the numbers of packets forwarded by Ten-GigabitEthernet 1/0/1.1 and Ten-GigabitEthernet 1/0/1.2 are both 10,000 in the traffic statistics.
·     The system does not distinguish traffic between subinterfaces with the same number under different main interfaces when collecting traffic statistics in the outbound direction of a Layer 3 Ethernet subinterface. For example, if both Ten-GigabitEthernet 1/0/1.2 and Ten-GigabitEthernet 1/0/2.2 use the resources of VLAN-interface 2 in the outbound direction, the outbound traffic for both interfaces is the sum of the traffic of these two interfaces.
# Configure Ten-GigabitEthernet 1/0/11 to operate in a Layer 3 mode.
<H3C> sys-view
[H3C] interface ten-gigabitethernet 1/0/11
[H3C-Ten-GigabitEthernet1/0/11] port link-mode route
# Configure IP addresses. (Details not shown)
# (Optional.) Enable Layer 3 traffic statistics collection for Ten-GigabitEthernet 1/0/11.
[H3C-Ten-GigabitEthernet1/0/11] statistics l3-packet enable inbound
[H3C-Ten-GigabitEthernet1/0/11] statistics l3-packet enable outbound
·     If Layer 3 traffic statistics collection is not enabled, use the display interface command to obtain traffic statistics.
# Obtain the traffic statistics for interface Ten-GigabitEthernet 1/0/11.
[H3C]display interface ten-gigabitethernet 1/0/11
Table 7 Command output
Peak input rate
Peak output rate
input errors
runts
giants
throttles
CRC
frame
overruns
aborts
ignored
parity errors
output errors
underruns
buffer failures
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Table 8 Command output
Peak input rate
Peak output rate
input errors
runts
giants
throttles
CRC
frame
overruns
aborts
ignored
parity errors
output errors
underruns
buffer failures
aborts
deferred
collisions
late collisions
lost carrier
no carrier
Peak input rate
Peak output rate
·     IPv4 packet statistics.
# Obtain the IPv4 traffic statistics for interface Ten-GigabitEthernet 1/0/11.
[H3C]dis ip interface ten-gigabitethernet 1/0/11
Ten-GigabitEthernet1/0/11 current state: UP
Internet Address is 41.41.41.2/24 Primary
Broadcast address: 41.41.41.255
The Maximum Transmit Unit: 1500 bytes
input packets : 300, bytes : 38400, multicasts : 0
output packets : 300, bytes : 38382, multicasts : 0
TTL invalid packet number:         0
ICMP packet input number:          0
  Echo reply:                      0
  Unreachable:                     0
  Source quench:                   0
  Routing redirect:                0
  Echo request:                    0
  Router advert:                   0
  Router solicit:                  0
  Time exceed:                     0
  IP header bad:                   0
  Timestamp request:               0
  Timestamp reply:                 0
  Information request:             0
  Information reply:               0
  Netmask request:                 0
  Netmask reply:                   0
  Unknown type:                    0
Table 9 Command output
current state
Physical link state of the interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed).
·     UP—The interface is both administratively and physically up.
Data link layer state of the interface.
·     UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist.
Internet Address
IP address of the interface. Possible IP address types include:
·     Primary—Manually configured primary IP address.
·     Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed.
·     DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide.
·     BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide.
·     Unnumbered—IP address borrowed from another interface.
·     Cellular-Allocated—IP address allocated through the modem manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide.
·     MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide.
Broadcast address
Broadcast address of the subnet attached to an interface.
MTU of the interface, in bytes.
input packets, bytes, multicasts
output packets, bytes, multicasts
All received and sent packets and bytes, and received and sent multicast packets on an interface (statistics start at the device startup).
Number of TTL-invalid packets received on the interface (statistics start at the device startup).
  Echo reply:
  Unreachable:
  Source quench:
  Routing redirect:
  Echo request:
  Router advert:
  Router solicit:
  Time exceed:
  IP header bad:
  Timestamp request:
  Timestamp reply:
  Information reply:
  Netmask request:
  Netmask reply:
  Unknown type:
Total number of ICMP packets received on the interface (statistics start at the device startup):
·     Echo reply packets.
·     Unreachable packets.
·     Source quench packets.
·     Routing redirect packets.
·     Echo request packets.
·     Router advertisement packets.
·     Router solicitation packets.
·     Time exceeded packets.
·     IP header bad packets.
·     Timestamp request packets.
·     Timestamp reply packets.
·     Information request packets.
·     Information reply packets.
·     Netmask request packets.
·     Netmask reply packets.
·     Unknown type packets.
·     IPv6 packet statistics.
[H3C]dis ipv6 interface ten-gigabitethernet 1/0/11
IPv6 is enabled, link-local address is FE80::2E0:FCFF:FE00:6851
  Global unicast address(es):
    41::2, subnet is 41::/64
  Joined group address(es):
    FF02::1
FF02::2
    FF02::1:FF00:2
    FF02::1:FF00:6851
  MTU is 1500 bytes
IPv6 Packet statistics:
  InReceives:                    300
  InTooShorts:                   0
  InTruncatedPkts:               0
  InHopLimitExceeds:             0
  InBadHeaders:                  0
  InBadOptions:                  0
  ReasmReqds:                    0
  ReasmOKs:                      0
  InFragDrops:                   0
  InFragTimeouts:                0
  OutFragFails:                  0
  InDelivers:                    304
  OutRequests:                   4
  OutForwDatagrams:              300
  InNoRoutes:                    0
  OutFragOKs:                    0
  OutFragCreates:                0
  InMcastPkts:                   0
  InMcastNotMembers:             0
  OutMcastPkts:                  1
  InAddrErrors:                  0
SNMP
Use an NMS to obtain the inbound traffic statistics for Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/11 through SNMP.
Figure 18 Network diagram for SNMP
·     For Layer 3 Ethernet interfaces,  traffic statistics can be obtained using the following tables:
¡     ipIfStatsEntry (with OID 1.3.6.1.2.1.4.31.3.1)
# Switch to a Layer 3 Ethernet interface.
<H3C> sys-view
# Configure IP address (Details not shown)
# Configure SNMP. For more information, see "Procedure."
IMPORTANT
IMPORTANT:
·     You can view packet loss and error packet statistics on an interface by querying the ifInDiscards, ifOutDiscards, ifInErrors, and ifOutErrors nodes. The statistical method is the same for different tables. This example uses MIB Browser to query the ifInErrors node and obtain the inbound error traffic statistics for the interface Ten-GigabitEthernet 1/0/11.
# Obtain the index of interface Ten-GigabitEthernet 1/0/11 through the ifName node (1.3.6.1.2.1.31.1.1.1.1). The query results dialog box shows that the index is 11 for Ten-GigabitEthernet 1/0/11.
Figure 19 Obtaining the interface index
Figure 20 Query result for index
# As shown in Figure 21, use the ifHCInOctets table (with OID 1.3.6.1.2.1.31.1.1.1.6) to obtain the inbound traffic statistics (in packets) of Ten-GigabitEthernet 1/0/11.
# The query results dialog box shows that the index is.
Figure 21 Obtaining traffic statistics
Figure 22 Obtaining traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/11 on the device named Agent.
Figure 23 Network diagram for NETCONF
IMPORTANT
IMPORTANT:
<H3C> sys-view
# Configure NETCONF. For more information, see "Procedure."
·     The following is an example of using the Ifmgr/Statistics table to query the statistics for interface Ten-GigabitEthernet 1/0/11. The configuration procedure for using the IPFW/IPStatistic table to query interface statistics is similar. For more information about the Ifmgr/Statistics table and the IPFW/IPStatistic table, see the MIB references for your device.
[H3C-probe]display system internal ifmgr list | include Ten-GigabitEthernet1/0/11
        Ten-GigabitEthernet1/0/11(index:11)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <IfIndex>11</IfIndex>
            <Name>Ten-GigabitEthernet1/0/11</Name>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
               <Ifmgr>
                  <Statistics>
                     <Interface>
                        <AbbreviatedName>XGE1/0/11</AbbreviatedName>
                        <InRate>0</InRate>
                     </Interface>
                  </Statistics>
               </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain traffic statistics for Layer 3 Ethernet interface Ten-GigabitEthernet 1/0/11 on the device by using gRPC.
Figure 24 Network diagram for gRPC
Learn more
CLI
Obtain the traffic statistics for Layer 2 aggregate interface Bridge-Aggregation 2
·     To obtain the traffic statistics for a Layer 2 aggregate interface, use the display interface command. The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics.
·     Layer 3 traffic statistics collection is not available for Layer 2 aggregate interfaces.
·     The display ip interface and display ipv6 interface commands do not display traffic statistics for interfaces.
·     To determine whether an interface works correctly within a period by collecting the traffic statistics within that period, first use the reset counters interface command to clear the statistics.
·     The reset counters interface command can clear the counters in the output from the display interface command, but does not clear the counters of MIB nodes.
# Obtain the traffic statistics for Layer 2 aggregate interface Bridge-Aggregation 2.
[H3C]display interface Bridge-Aggregation2
Bridge-Aggregation2
Last 300 seconds input:  1 packets/sec 254 bytes/sec 0%
Last 300 seconds output:  1 packets/sec 254 bytes/sec 0%
Input (total):  610 packets, 77632 bytes
        603 unicasts, 2 broadcasts, 5 multicasts, 0 pauses
Input (normal):  610 packets, - bytes
Output (total): 619 packets, 78296 bytes
        605 unicasts, 6 broadcasts, 8 multicasts, 0 pauses
Output (normal): 619 packets, - bytes
Table 10 Command output
Bridge-Aggregation2
Layer 2 aggregate interface name.
Last clearing of counters
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup.
Average input rate over the last 300 seconds.
Average output rate over the last 300 seconds.
Input/Output (total)
Statistics of all packets received or sent on the interface.
Input/Output (normal)
Statistics of all normal packets received or sent on the interface.
SNMP
Use an NMS to obtain the inbound traffic statistics for interface Bridge-Aggregation 2 through SNMP.
Figure 25 Network diagram for SNMP
·     For Layer 2 aggregate interfaces, traffic statistics collection is performed by using the following tables: ifEntry (with OID 1.3.6.1.2.1.2.2.1), ifXEntry (with OID 1.3.6.1.2.1.31.1.1), hh3cIfFlowStatEntry (with OID 1.3.6.1.4.1.25506.2.40.2.1.2.1.1), and ipIfStatsEntry (with OID 1.3.6.1.2.1.4.31.3.1).
·     The data length of the interface traffic statistics nodes in the ifEntry table is 32 bits, and the data length of some nodes in the ifXEntry table are 64 bits. Therefore, the interface traffic statistics nodes of the ifEntry table might have data overflow in collecting interface traffic statistics. The interface traffic statistics nodes of the ifXEntry table do not have data overflow issues. The nodes in the ifEntry table and the ifXEntry table are not completely identical, but they have some overlapping nodes. If target data can be found in the ifXEntry table, use the data in the ifXEntry table. If the data cannot be found in the ifXEntry table, check the ifEntry table.
·     You can use the nodes in the following tables to obtain different traffic statistics: ifEntry, ifXEntry, hh3cIfFlowStatEntry, hh3cIfHCFlowStatEntry, and hh3cifPortProtocolStatEntry. For more information about the ifEntry, ifXEntry, hh3cIfFlowStatEntry, hh3cIfHCFlowStatEntry, and ipIfStatsEntry tables, see the MIB references for your device.
·     To obtain traffic statistics for an interface, you must first obtain the index of the interface, and then use the index to obtain traffic statistics for the interface.
·     A main interface and its subinterfaces use unique indexes. You must obtain the index of the target interface or subinterface.
·     This example obtains the inbound traffic statistics for the Bridge-Aggregation 2 interface through the MIB browser.
# Use the ifName node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of the Bridge-Aggregation 2 interface. The query results dialog box shows that the index is 662 for interface Bridge-Aggregation 2, as shown in Figure 26.
Figure 26 Obtaining the interface index
# As shown in Figure 27, use the ifHCInOctets table (with OID 1.3.6.1.2.1.31.1.1.1.6) to obtain the inbound traffic statistics (in Byte) of interface Bridge-Aggregation 2.
Figure 27 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 2 aggregate interface Bridge-Aggregation 2 on the device named Agent.
Figure 28 Network diagram for NETCONF
·     The device provides the Ifmgr/Statistics and IPFW/IPStatistic tables for collecting interface traffic statistics. Use the Ifmgr/Statistics table to obtain interface traffic statistics in both bytes and packets, including statistics for unicast packets, non-unicast packets, unknown packets, discarded packets, and other types of packets. Use the IPFW/IPStatistic table to obtain interface traffic statistics about IPv4 or IPv6 packets in packets.
·     The following procedure uses the Ifmgr/Statistics table to obtain the traffic statistics for Bridge-Aggregation 2. The procedure is similar if you use the IPFW/IPStatistic table. For more information about the Ifmgr/Statistics and IPFW/IPStatistic tables, see the MIB references for your device.
# Obtain the interface index.
[H3C-probe]display system internal ifmgr list | in Bridge-Aggregation2
        Bridge-Aggregation2(index:662)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <IfIndex>662</IfIndex>
            <Name>Bridge-Aggregation2</Name>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
               <Ifmgr>
                  <Statistics>
                     <Interface>
                        <AbbreviatedName>BAGG2</AbbreviatedName>
                        <InOctets>77632</InOctets>
                        <InUcastPkts>603</InUcastPkts>
                        <InNUcastPkts>7</InNUcastPkts>
                        <InRate>0</InRate>
                        <OutOctets>78296</OutOctets>
                        <OutUcastPkts>605</OutUcastPkts>
                        <OutNUcastPkts>14</OutNUcastPkts>
                     </Interface>
                  </Statistics>
               </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
For more information about the Ifmgr/Statistics and IPFW/IPStatistic tables, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain traffic statistics for Layer 2 aggregate interface Bridge-Aggregation 2 on the device by using gRPC.
Figure 29 Network diagram for gRPC
See "Procedure" for detailed configuration procedure.
The collector receives interface traffic statistics pushed by the device every 30 seconds.
Learn more
CLI
Obtain the traffic statistics for Layer 3 aggregate interface Route-Aggregation 2.
·     To obtain the traffic statistics for a Layer 3 aggregate subinterface, use the display interface command. The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics.
·     Layer 3 traffic statistics collection is not available for Layer 3 aggregate interfaces.
·     If subinterfaces are created on a Layer 3 aggregate interface, the traffic statistics for the main interface contains statistics for the traffic forwarded by the subinterfaces.
·     If the number of a Layer 3 subinterface is the same as the number of another Layer 3 subinterface or a VLAN interface's tag, the statistics data will be accumulated in collecting outbound packet statistics. For example, if Route-Aggregation 1.3 and Route-Aggregation 2.3 exist or Route-Aggregation 1.3 and VLAN-interface 3 exist, VLAN tag 3 is used in the outbound direction for the subinterfaces and VLAN interface. In this case, the statistics for the two interfaces will be accumulated and counted together.
# Create Layer 3 aggregate interface Route-Aggregation 2.
<H3C> sys-view
[H3C] interface route-aggregation 2
# Obtain the traffic statistics for Layer 3 aggregate interface Route-Aggregation 2.
[H3C]display interface route-aggregation 2
Route-Aggregation2
Last 300 seconds input rate: 255 bytes/sec, 2040 bits/sec, 2 packets/sec
Last 300 seconds output rate: 255 bytes/sec, 2040 bits/sec, 2 packets/sec
611 packets input, 77696 bytes, 0 drops
627 packets output, 78912 bytes, 0 drops
Table 11 Command output
Bridge-Aggregation2
Input
Statistics of all packets received on the interface.
output
Statistics of all normal packets sent on the interface.
SNMP
Use an NMS to obtain the inbound traffic statistics for interface Route-Aggregation 2 through SNMP.
Figure 30 Network diagram for SNMP
·     The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics for Layer 3 aggregate interfaces.
·     For Layer 3 aggregate interfaces, traffic statistics collection is performed by using the following tables: ifEntry (with OID 1.3.6.1.2.1.2.2.1), ifXEntry (with OID 1.3.6.1.2.1.31.1.1), hh3cIfFlowStatEntry (with OID 1.3.6.1.4.1.25506.2.40.2.1.2.1.1), and hh3cIfHCFlowStatEntry (with OID 1.3.6.1.4.1.25506.2.40.2.1.2.3.1).
·     You can use the nodes in the following tables to obtain different traffic statistics: ifEntry, ifXEntry, hh3cIfFlowStatEntry, and hh3cIfHCFlowStatEntry. For more information about the ifEntry, ifXEntry, hh3cIfFlowStatEntry, hh3cIfHCFlowStatEntry, and hh3cIfHCFlowStatEntry tables, see the MIB references for your device.
<H3C> sys-view
# Assign interfaces Ten-GigabitEthernet 1/0/27 through Ten-GigabitEthernet 1/0/28 to aggregation group 2.
[H3C-Ten-GigabitEthernet1/0/27] port link-aggregation group 2
[H3C] interface ten-gigabitethernet 1/0/28
[H3C-Ten-GigabitEthernet1/0/28] port link-aggregation group 2
Example: Obtain traffic statistics
·     This example obtains inbound traffic statistics for the Route-Aggregation 2 interface from the ifXTable table through the MIB browser.
# Use the ifDescr node (1.3.6.1.2.1.2.2.1.2) to obtain the index of the Route-Aggregation 2 interface. The query results dialog box shows that the index is 662 for interface Route-Aggregation 2, as shown in Figure 31.
Figure 31 Obtaining the interface index
# As shown in Figure 32, use the ifInOctets table (with OID 1.3.6.1.2.1.2.2.1.10) to obtain the inbound traffic statistics (in bytes) of interface Route-Aggregation 2. The query results dialog box shows the query results.
Figure 32 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 3 aggregate interface Route-Aggregation 2 on the device named Agent.
Figure 33 Network diagram for NETCONF
<H3C> sys-view
·     Use the Ifmgr/Statistics table to obtain interface traffic statistics in both bytes and packets, including statistics for unicast packets, non-unicast packets, unknown packets, discarded packets, and other types of packets.
·     The following procedure uses the Ifmgr/Statistics table to obtain the traffic statistics for Route-Aggregation 2. The procedure is similar if you use the IPFW/IPStatistic table. For more information about the Ifmgr/Statistics and IPFW/IPStatistic tables, see the MIB references for your device.
[H3C-probe]display system internal ifmgr list | in Route-Aggregation2
        Route-Aggregation2(index:662)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <Name>Route-Aggregation2</Name>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
         <Ifmgr>
             <Statistics>
                 <Interface>
                    <AbbreviatedName>RAGG2</AbbreviatedName>
                    <InOctets>77696</InOctets>
                    <InNUcastPkts>8</InNUcastPkts>
                    <InRate>0</InRate>
                    <OutOctets>78912</OutOctets>
                    <OutNUcastPkts>22</OutNUcastPkts>
                 </Interface>
             </Statistics>
         </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain traffic statistics for Layer 3 aggregate interface Route-Aggregation 2 on the device by using gRPC.
Figure 34 Network diagram for gRPC
<H3C> sys-view
# See "Procedure" for detailed configuration procedure.
Learn more
Collecting Layer 3 aggregate subinterface traffic statistics
CLI
Obtain the traffic statistics for Layer 3 aggregate subinterface Route-Aggregation 2.1.
<H3C> sys-view
[H3C-Route-Aggregation2] quit
# Create Layer 3 aggregate subinterface Route-Aggregation 2.1.
[H3C] interface route-aggregation 2.1
# Obtain the traffic statistics for Layer 3 aggregate subinterface Bridge-Aggregation 2.1.
[H3C]display interface route-aggregation 2.1
Route-Aggregation2.1
Input (total):  416 packets, 54258 bytes
Output (total):  400 packets, 52800 bytes
Table 12 Command output
Bridge-Aggregation2.1
Layer 2 aggregate subinterface name.
Input
output
SNMP
Use an NMS to obtain the inbound traffic statistics for subinterface Route-Aggregation 2.1 through SNMP.
Figure 35 Network diagram for SNMP
For more information about the ifEntry table, see the MIB references for your device.
The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics for Layer 3 aggregate subinterfaces.
<H3C> sys-view
·     This example obtains inbound traffic statistics for the Route-Aggregation 2.1 subinterface from the ifEntry table through the MIB browser.
# Use the ifDescr node (1.3.6.1.2.1.2.2.1.2) to obtain the index of the Route-Aggregation 2.1 subinterface. The query results dialog box shows that the index is 2181 for subinterface Route-Aggregation 2.1, as shown in Figure 36.
Figure 36 Obtaining the interface index
# As shown in Figure 37, use the ifInOctets table (with OID 1.3.6.1.2.1.2.2.1.10) to obtain the inbound traffic statistics (in bytes) of subinterface Route-Aggregation 2.1. The query results dialog box shows the query results.
Figure 37 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 3 aggregate subinterface Route-Aggregation 2.1 on the device named Agent.
Figure 38 Network diagram for NETCONF
·     The NETCONF client obtains interface traffic statistics through the NETCONF XML APIs provided by the device.
·     The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics for Layer 3 aggregate subinterfaces.
<H3C> sys-view
[H3C-probe]dis system internal ifmgr list | in Route-Aggregation2.1
          |--------Route-Aggregation2.1(index:655)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <IfIndex>655</IfIndex>
            <Name>Route-Aggregation2.1</Name>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
         <Ifmgr>
             <Statistics>
                 <Interface>
                     <AbbreviatedName>RAGG2.1</AbbreviatedName>
                     <InOctets>80256</InOctets>
                     <InUcastPkts>613</InUcastPkts>
                     <InDiscards>18446744073709551615</InDiscards>
                     <InErrors>18446744073709551615</InErrors>
                     <InUnknownProtos>18446744073709551615</InUnknownProtos>
                     <InRate>80256</InRate>
                     <OutOctets>0</OutOctets>
                     <OutNUcastPkts>0</OutNUcastPkts>
                     <OutDiscards>18446744073709551615</OutDiscards>
                     <OutErrors>18446744073709551615</OutErrors>
                 </Interface>
             </Statistics>
         </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain traffic statistics for Layer 3 aggregate subinterface Route-Aggregation 2.1 on the device by using gRPC.
Figure 39 Network diagram for gRPC
<H3C> sys-view
# Enable gRPC.
[H3C] grpc enable
# Create a sensor group named test, and add sensor path Ifmgr/Statistics to it.
[H3C] telemetry
# Create subscription A, specify sensor group test for the subscription, set the data collection interval to 30 seconds, and specify destination group collector1 for the subscription.
Learn more
Collecting VLAN interface traffic statistics
CLI
Obtain the traffic statistics for VLAN-interface 20.
·     To obtain the traffic statistics for a VLAN interface, use the display interface command. The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics.
·     For a Layer 3 interface, unicast, multicast, and broadcast traffic are all counted as unicast packets.
·     If subinterfaces are created on a main interface, the traffic statistics for the main interface contains statistics for the traffic forwarded by the subinterfaces.
·     If the number of a Layer 3 subinterface same as the number of another Layer 3 subinterface or a VLAN interface's tag, the statistics data will be accumulated in collecting outbound packet statistics. For example, if Ten-GigabitEthernet 1/0/1.3 and Ten-GigabitEthernet 1/0/2.3 or Ten-GigabitEthernet 1/0/1.3 and VLAN-interface 3 exist, VLAN tag 3 is used in the outbound direction for the subinterfaces and VLAN interface. In this case, the statistics for the two interfaces will be accumulated and counted together.
·     The outbound traffic statistics for VLAN interfaces only counts Layer 3 packets, and both Layer 2 and Layer 3 packets are counted in the inbound direction.
# Create VLAN 20.
<H3C> sys-view
[H3C] vlan 20
[H3C-vlan20] quit
# Create VLAN-interface 20.
[H3C] interface vlan-interface 20
# Obtain traffic statistics for VLAN-Interface 20.
[H3C]display interface vlan-interface 20
Vlan-interface20
Current state: UP
Line protocol state: UP
Description: Vlan-interface20 Interface
Bandwidth: 10000000 kbps
IP packet frame type: Ethernet II, hardware address: 882a-5e25-dc9b
IPv6 packet frame type: Ethernet II, hardware address: 882a-5e25-dc9b
Table 13 Command output
SNMP
Use an NMS to obtain the inbound traffic statistics for interface VLAN-interface 20 through SNMP.
Figure 40 Network diagram for SNMP
·     Interfaces traffic statistics collection is performed by using the ifEntry (with OID 1.3.6.1.2.1.2.2.1) and ifXEntry (with OID 1.3.6.1.2.1.31.1.1) tables. The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics for VLAN interfaces.
·     You can use the nodes in the ifEntry and ifXEntry tables to obtain different traffic statistics. For more information about the ifEntry and ifXEntry tables, see the MIB references for your device.
# Create VLAN 20.
<H3C> sys-view
[H3C] vlan 20
[H3C-vlan20] quit
·     This example obtains inbound traffic statistics for the VLAN-interface 20 interface from the ifXTable table through the MIB browser.
# Use the ifName node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of the VLAN-interface 20 interface. The query results dialog box shows that the index is 656 for interface VLAN-interface 20, as shown in Figure 41.
Figure 41 Obtaining the interface index
# As shown in Figure 42, use the ifInOctets table (with OID 1.3.6.1.2.1.2.2.1.10) to obtain the inbound traffic statistics (in bytes) of VLAN-interface 20.
Figure 42 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for VLAN-interface 20 on the device named Agent.
Figure 43 Network diagram for NETCONF
# Create VLAN 20.
<H3C> sys-view
[H3C] vlan 20
[H3C-vlan20] quit
·     The device provides the Ifmgr/Statistics and IPFW/IPStatistic tables for collecting interface traffic statistics. Use the Ifmgr/Statistics table to obtain interface traffic statistics in both bytes and packets, including statistics for unicast packets, non-unicast packets, unknown packets, discarded packets, and other types of packets. Use the IPFW/IPStatistic table to obtain interface traffic statistics about IPv4 or IPv6 packets in packets. The device does not distinguish between IPv4 and IPv6 packets when collecting traffic statistics for VLAN interfaces.
[H3C] probe
[H3C-probe]dis system internal  ifmgr  list | include vlan-interface20
         Vlan-interface20(index:656)
  <get-bulk>
        <Ifmgr>
          <Statistics>
           <Interface>
            <IfIndex>656</IfIndex>
            <Name></Name>
            <InRate></InRate>
            <OutRate></OutRate>
           </Interface>
          </Statistics>
        </Ifmgr>
      </top>
    </filter>
  </get-bulk>
</rpc>
    <data>
               <Ifmgr>
                  <Statistics>
                     <Interface>
                        <Name>Vlan-interface20</Name>
                        <AbbreviatedName>Vlan20</AbbreviatedName>
                        <InOctets>8000</InOctets>
                        <InUcastPkts>65</InUcastPkts>
                        <InRate>8000</InRate>
                        <OutOctets>3840</OutOctets>
                        <OutUcastPkts>30</OutUcastPkts>
                        <OutRate>3840</OutRate>
                     </Interface>
                  </Statistics>
               </Ifmgr>
      </top>
    </data>
</rpc-reply>
Learn more
For more information about the Ifmgr/Statistics tables, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain traffic statistics for VLAN-interface 20 on the device by using gRPC.
Figure 44 Network diagram for gRPC
# Create VLAN 20.
<H3C> sys-view
[H3C] vlan 20
[H3C-vlan20] quit
[H3C-Vlan-interface20] quit
Learn more
Collecting dropped packet statistics of an interface through MQC
Requirements
Configure MQC to obtain statistics of packets dropped by CAR on an interface.
If you have configured both CAR through MQC and queue scheduling profiles in the outbound direction of an interface, the device processes the traffic first based on queue scheduling profiles and then based on CAR. Therefore, even if some packets are colored red and dropped by CAR, these packets still occupy the scheduling bandwidth in the queue scheduling profiles.
CLI
Obtain the statistics of packets dropped by CAR on interface Ten-GigabitEthernet 1/0/27.
# Configure traffic class car to match all traffic.
<H3C> sys-view
[H3C] traffic classifier car
[H3C-classifier-car] if-match any
[H3C-classifier-car] quit
# Create traffic behavior car. Configure traffic policing (CAR) in the traffic behavior, and set the committed information rate (CIR) to 10000 kbps and committed burst size (CBS) to 625152 bytes.
[H3C]traffic behavior car
[H3C-behavior-car] car cir 10000 cbs 625152
[H3C-behavior-car] quit
# Create a QoS policy, and associate traffic class car with traffic behavior car in the QoS policy.
[H3C]qos policy car
[H3C-qospolicy-car] classifier car behavior car
[H3C-qospolicy-car] quit
# Apply the QoS policy to the outbound direction of interface Ten-GigabitEthernet 1/0/27.
[H3C-Ten-GigabitEthernet1/0/27] qos apply policy car outbound
[H3C-Ten-GigabitEthernet1/0/27] quit
# Obtain the statistics of packets dropped by CAR on interface Ten-GigabitEthernet 1/0/27.
[H3C]display qos policy interface ten-gigabitethernet 1/0/27
Interface: Ten-GigabitEthernet1/0/27
  Direction: Outbound
  Policy: car
   Classifier: car
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: car
      Committed Access Rate:
        CIR 10000 (kbps), CBS 625152 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : discard
        Green packets : 18 (Packets)
        Red packets   : 0 (Packets)
SNMP
Use an NMS to obtain statistics of packets dropped by CAR on interface Ten-GigabitEthernet 1/0/27 through SNMP.
Figure 45 Network diagram for SNMP
Configure CAR-based traffic management. For more information, see "Procedure."
This example uses the MIB browser to obtain the statistics of packets dropped by CAR on interface Ten-GigabitEthernet 1/0/27 of the device named Agent.
# As shown in Figure 46, use the ifDescr subnode (1.3.6.1.2.1.31.1.1.1.1.2) of the ifName node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of the Ethernet interface. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 46 Obtaining the interface index
# Obtain the index of the QoS policy applied to the interface by the interface index in the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2. As shown in Figure 47, the index of the QoS policy applied to interface Ten-GigabitEthernet 1/0/27 is 1.
Figure 47 Obtaining the index of a QoS policy applied to an interface
# Obtain the statistics of packets dropped by CAR on interface Ten-GigabitEthernet 1/0/27 through the hh3cCBQoSCarRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.3.1.
Figure 48 Statistics of packets dropped by CAR
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain queue buffer traffic statistics of interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 49 Network diagram for NETCONF
The device provides the QSTAT/QueueStat table for collecting  interface queue traffic statistics. You can obtain statistics in bytes or packets by using the QSTAT/InterfaceStat table.
This example uses the QSTAT/InterfaceStat table to obtain statistics of interface Ten-GigabitEthernet 1/0/27.
# Execute the display system internal ifmgr list | include Ten-GigabitEthernet1/0/27 command in probe view on the device to obtain the index of interface Ten-GigabitEthernet 1/0/27.
<H3C> sys-view
[H3C] probe
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
  <get-bulk>
    <filter type="subtree">
      <top xmlns="http://www.h3c.com/netconf/data:1.0">
        <QSTAT>
          <InterfaceStat>
            <Statistics>
               <Direction></Direction>
               <QueueID></QueueID>
               <PassPkt></PassPkt>
               <PassByte></PassByte>
               <DropPkt></DropPkt>
               <DropByte></DropByte>
               <PacketRate></PacketRate>
               <BitRate></BitRate>
               <PeakPacketRate></PeakPacketRate>
               <PeakBitRate></PeakBitRate>
               <TotalQueLen></TotalQueLen>
               <CurrQueLen></CurrQueLen>
               <QueUseRatio></QueUseRatio>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
      </top>
    </filter>
  </get-bulk>
</rpc>
   <data>
        <QSTAT>
            <QueueStat>
                 <Statistics>
                    <Direction>1</Direction>
                    <QueueID>0</QueueID>
                    <PassPkt>0</PassPkt>
                    <PassByte>0</PassByte>
                    <DropPkt>0</DropPkt>
                    <DropByte>0</DropByte>
                    <PacketRate>0</PacketRate>
                    <BitRate>0</BitRate>
                    <CurrQueLen>0</CurrQueLen>
                 </Statistics>
                    <Statistics>
                    <QueueID>1</QueueID>
                 </Statistics>
                 <Statistics>
                    <QueueID>2</QueueID>
                    <PassPkt>3983693702452</PassPkt>
                    <PassByte>533804491661232</PassByte>
                    <DropPkt>2705999003341</DropPkt>
                    <DropByte>346367872427648</DropByte>
                    <PacketRate>11260285</PacketRate>
                    <BitRate>11528004744</BitRate>
                    <CurrQueLen>2</CurrQueLen>
                 </Statistics>
                 <Statistics>
                    <QueueID>3</QueueID>
                 </Statistics>
                 <Statistics>
                    <QueueID>4</QueueID>
                 </Statistics>
                 <Statistics>
                    <QueueID>5</QueueID>
                  </Statistics>
                  <Statistics>
                    <QueueID>6</QueueID>
                 </Statistics>
                 <Statistics>
                    <QueueID>7</QueueID>
                    <PassPkt>314548</PassPkt>
                    <PassByte>39913188</PassByte>
                 </Statistics>
             </QueueStat>
        </QSTAT>
     </top>
   </data>
</rpc-reply>
Learn more
For more information about QSTAT/QueueStat, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain the queue buffer traffic statistics of  interface Ten-GigabitEthernet 1/0/27 on the device through gRPC.
Figure 50 Network diagram for gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path QSTAT/QueueStat.
After sensor path QSTAT/QueueStat is added, the device will collect traffic statistics of all interface queue buffers and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path qstat/queuestat
# Configure a subscription named A to bind sensor group test with destination group collector1. Set the data sampling interval to 30 seconds.
The collector receives data pushed by the device every 30 seconds.
Learn more
Collecting Ethernet interface traffic statistics through MQC
Requirements
Obtain Ethernet interface traffic statistics through MQC.
CLI
Obtain inbound traffic statistics of interface Ten-GigabitEthernet 1/0/27 through MQC.
·     The device supports configuring a traffic accounting action by using the accounting [ byte | packet ]* command.
·     The accounting byte command collects traffic statistics in bytes, while the accounting packet command collects traffic statistics in packets. If neither the byte keyword nor the packet keyword is specified for the accounting command, the device collects traffic statistics in packets. If both the byte and packet keywords are specified for the accounting command, the device collects traffic statistics in packets and bytes.
·     This example collects traffic statistics in packets.
# Configure traffic class aa to match all traffic.
<H3C> sys-view
[H3C] traffic classifier aa
[H3C-classifier-aa] if-match any
[H3C-classifier-aa] quit
# Configure traffic behavior aa to collect traffic statistics in packets.
[H3C]traffic behavior aa
[H3C-behavior-aa] accounting packet
[H3C-behavior-aa] quit
# Create a QoS policy, and associate traffic class aa with traffic behavior aa in the QoS policy.
[H3C]qos policy aa
[H3C-qospolicy-aa] classifier aa behavior aa
[H3C-qospolicy-aa] quit
# Apply the QoS policy to the inbound direction of interface Ten-GigabitEthernet 1/0/27.
[H3C] interface ten-gigabitethernet 1/0/27
[H3C-Ten-GigabitEthernet1/0/27] qos apply policy aa inbound
# Obtain the traffic statistics of interface Ten-GigabitEthernet 1/0/27.
[H3C]dis qos policy  interface ten-gigabitethernet 1/0/27
  Direction: Inbound
  Policy: car
   Classifier: car
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: car
      Accounting enable:
        18 (Packets)
Table 14 Command output
Direction
Direction in which the QoS policy is applied.
policy
QoS policy name.
Classifier
Traffic class name and its contents, which could be of various types.
Operator
Logical relationship between match criteria.
Rule(s)
Match criteria.
if-match any
Matches all packets passing through the interface.
Behavior
Name and content of the traffic behavior.
Accounting enable
Traffic accounting action.
Learn more
For more information about configuring MQC, see QoS configuration and QoS commands for your device.
SNMP
Use an NMS to obtain the inbound traffic statistics of interface Ten-GigabitEthernet 1/0/27 through SNMP.
Figure 51 Network diagram for SNMP
Configure MQC to collect traffic statistics of the Ethernet interface. For more information, see "Procedure."
·     To obtain traffic statistics of an Ethernet interface, you must first obtain the index of the Ethernet interface and then use the index to obtain traffic statistics of the Ethernet interface.
·     The Ethernet interface index might vary by the ID of the IRF member device hosting the interface.
·     To obtain the traffic statistics of interface Ten-GigabitEthernet 1/0/27, you must first use the ifName node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of the interface. Then, use the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2 to obtain the index of the QoS policy applied to the specified interface. Finally, use the index of the QoS policy applied to the specified interface to obtain the traffic statistics of the interface in the subtable of the hh3cCBQoSAccountingRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1. For more information about the hh3cCBQoSAccountingRunInfoEntry table, see the MIB references for your device.
·     This example obtains the inbound traffic statistics of the Ethernet interface through the MIB browser.
As shown in Figure 52, use the ifDescr subnode (1.3.6.1.2.1.31.1.1.1.1.2) of the ifName node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of the Ethernet interface. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 52 Obtaining the interface index
# Obtain the index of the QoS policy applied to the interface by the interface index in the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2. As shown in Figure 53, the index of the QoS policy applied to interface Ten-GigabitEthernet 1/0/27 is 1.
Figure 53 Obtaining the index of a QoS policy applied to an interface
# As shown in Figure 54, use the hh3cCBQoSAccountingRunInfoEntry table (with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1) to obtain the inbound traffic statistics (in packets) of interface Ten-GigabitEthernet 1/0/27.
Figure 54 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics of Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 55 Network diagram for NETCONF
The NETCONF client obtains Ethernet interface traffic statistics through the NETCONF XML APIs provided by the device.
Configure the device as described in "Procedure."
The device provides the MQC/AccountRunInfo table for collecting traffic statistics through MQC. You can obtain statistics in bytes and packets by using the MQC/AccountRunInfo table.
This example uses the MQC/AccountRunInfo table to obtain statistics of interface Ten-GigabitEthernet 1/0/27.
  <get-bulk>
        <MQC>
          <AccountRunInfo>
            <AccountRunInfoEntry>
              <AppType></AppType>                 //MQC application destination: 1 for interface and 2 for VLAN
              <AppMainIndex></AppMainIndex>       //Main index of the MQC application destination
              <AppSubIndex></AppSubIndex>         //Subindex of the MQC application destination
              <AppDirection></AppDirection>       //Direction in which the MQC policy is applied: 1 for inbound and 2 for outbound
              <CBMapIndex></CBMapIndex>           //Index of the classifier-behavior association
              <AccountPkts></AccountPkts>         //Traffic statistics in packets
              <AccountBytes></AccountBytes>       //Traffic statistics in bytes
            </AccountRunInfoEntry>
          </AccountRunInfo>
        </MQC>
      </top>
    </filter>
  </get-bulk>
</rpc>
<data>
      <MQC>
        <AccountRunInfo>
              <AppType>1</AppType>
              <AppMainIndex>50</AppMainIndex>
              <AppSubIndex>0</AppSubIndex>
              <AppDirection>1</AppDirection>
              <CBMapIndex>0</CBMapIndex>
              <AccountPkts>150</AccountPkts>
           </AccountRunInfo>
      /MQC>
   </top>
   </data>
</rpc-reply>
Learn more
For more information about MQC/AccountRunInfo, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain traffic statistics of Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device by using gRPC.
Figure 56 Network diagram for gRPC
# Configure MQC to collect traffic statistics of the Ethernet interface. For more information, see "Procedure."
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path MQC/AccountRunInfo.
After sensor path MQC/AccountRunInfo is added, the device will collect traffic statistics of all interfaces and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path mqc/accountruninfo
Learn more
Collecting VXLAN traffic statistics
Collecting AC traffic statistics
Requirements
Obtain traffic statistics for ACs.
The VTEP uses the following methods to assign customer frames to a VXLAN:
·     Ethernet service instance-to-VSI mapping—This method uses the frame match criterion of an Ethernet service instance to match a list of VLANs or all packets on a Layer 2 Ethernet interface. The received data packets that match the Ethernet service instance on the Layer Ethernet interface 2 belong to the VSI and VXLAN associated with the Ethernet service instance.
·     VLAN-based VXLAN assignment—This method maps a VLAN to a VXLAN. The VTEP assigns all frames of the VLAN to the VXLAN.
Traffic statistics collection for Ethernet service instances takes effect only if frame match criteria are configured for the Ethernet service instances and the Ethernet service instances are mapped to VSIs. If the frame match criterion or VSI mapping is modified for an Ethernet service instance, traffic statistics for the Ethernet service instance are cleared for recollection.
If VLAN-based VXLAN assignment is used, enable AC traffic statistics for ACs of a VLAN for the device to collection traffic statistics for the automatically generated ACs in that VLAN. If you enable VLAN-based VXLAN assignment and map a VLAN to a VXLAN, the device automatically performs the following operations:
1.     Creates an Ethernet service instance that uses the VLAN ID as its instance ID on each interface in the VLAN. The matching outer VLAN ID of the Ethernet service instances is the VLAN ID.
2.     Maps the Ethernet service instances to the VSI of the VXLAN.
For ACs, inbound Layer 2 broadcast packets will also be counted as outgoing packets in AC traffic statistics.
To determine whether an AC works correctly within a period by collecting AC traffic statistics within that period, first use the reset l2vpn statistics ac command in user view to clear the statistics.
CLI
Obtain traffic statistics for Ethernet service instance 1000.
·     Method 1:
# Create Ethernet service instance 1000 on Ten-GigabitEthernet 1/0/27, and mapped the Ethernet service instance to a VSI.
<H3C> sys-view
[H3C-Ten-GigabitEthernet1/0/27] service-instance 1000
[H3C-Ten-GigabitEthernet1/0/27-srv1000] encapsulation s-vid 1000
[H3C-Ten-GigabitEthernet1/0/27-srv1000] xconnect vsi vsi3
# Enable VSI traffic statistics.
[H3C-Ten-GigabitEthernet1/0/27-srv1000] statistics enable
[H3C-Ten-GigabitEthernet1/0/27-srv1000] quit
·     Method 2:
# Create VSI vsi3 and enter VSI view.
<H3C> sys-view
[H3C] vsi vsi3
# Create a VXLAN and enter VXLAN view.
[H3C-vsi-vsi3] vxlan 1000
[H3C-vsi-vsi3] quit
# Enable VLAN-based VXLAN assignment.
[H3C] vxlan vlan-based
# Create VLAN 1000 and enter the VLAN view.
[H3C] vlan 1000
# Map the VLAN to the VXLAN.
[H3C-vlan1000] vxlan vni 1000
# Enable AC traffic statistics for the VLAN.
[H3C-vlan1000] ac statistics enable
[H3C]dis l2vpn service-instance verbose
Interface: XGE1/0/27
  Service Instance: 1000
    Type          : Manual
    Encapsulation : s-vid 1000
    Bandwidth     : -
    VSI Name      : vsi3
    Link ID       : 1
    State         : Up
    Statistics    : Enabled
    Input Statistics:
      Octets   :0
      Packets  :0
    Output Statistics:
      Octets   :544
      Packets  :8
Table 15 Command output
Name of a Layer 2 Ethernet interface or Layer 2 aggregate interface.
Service Instance
Ethernet service instance ID.
Type and traffic match mode of the Ethernet service instance:
·     Dynamic (MAC-based)—Dynamic Ethernet service instance in MAC-based traffic match mode.
·     Dynamic (VLAN-based)—Dynamic Ethernet service instance in VLAN-based traffic match mode.
·     Manual—Static Ethernet service instance in VLAN-based traffic match mode.
Encapsulation
Frame match criterion of the Ethernet service instance. If the Ethernet service instance does not contain a frame match criterion, the command does not display this field.
Bandwidth
Bandwidth limit in kbps. If no bandwidth limit is set for the Ethernet service instance, Unlimited is displayed.
Link ID
Ethernet service instance's link ID on the VSI.
Ethernet service instance state:
·     Up.
·     Down.
DF state
Whether the device is the designated forwarder for the AC at a multihomed EVPN site:
·     BDF—The device is a backup designated forwarder.
·     DF—The device is the designated forwarder.
This field is not displayed if no Ethernet segment identifier is configured on the interface.
Statistics
Packet statistics state:
·     Enabled—The packet statistics feature is enabled for the Ethernet service instance.
·     Disabled—The packet statistics feature is disabled for the Ethernet service instance.
Input Statistics
Incoming traffic statistics:
·     Octets—Number of incoming bytes.
·     Packets—Number of incoming packets.
Output Statistics
Outgoing traffic statistics:
·     Octets—Number of outgoing bytes.
·     Packets—Number of outgoing packets.
SNMP
Configure VXLAN. For more information, see "Procedure."
·     To obtain traffic statistics for an Ethernet service instance, you must first obtain the index of the interface hosting the Ethernet service instance and use the index to obtain traffic statistics for the Ethernet service instance.
·     The following procedure uses a MIB browser to obtain inbound traffic statistics for Ethernet service instance 1000 on Ten-GigabitEthernet 1/0/27 from the hh3cEvcSrvInstStatInfoEntry table (with OID 1.3.6.1.4.1.25506.2.106.1.4.1).
·     For more information about the hh3cEvcSrvInstStatInfoEntry table, see the MIB references for your device.
# As shown in Figure 57, use the ifDescr node (1.3.6.1.2.1.31.1.1.1.1) to obtain the index of interface Ten-GigabitEthernet 1/0/27. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27, as shown in Figure 58.
Figure 57 Obtaining the interface index
Figure 58 Interface index query result
# As shown in Figure 59, obtain inbound traffic statistics for Ethernet service instance 1000 on Ten-GigabitEthernet 1/0/27 from the hh3cEvcSrvInstInPackets node (with OID 1.3.6.1.4.1.25506.2.106.1.4.1.1) in the hh3cEvcSrvInstStatInfoEntry table.
Figure 59 Obtaining traffic statistics for Ethernet service instance 1000
Learn more
NETCONF
·     Use the L2VPN/VSIStatistics table to obtain the traffic statistics for VSI interfaces. For more information about L2VPN/VSIStatistics, see H3C Comware 7 NETCONF XML API Reference.
·     This example uses Ethernet service instance 1000.
  <get>
        <L2VPN>
          <ACs>
            <AC>
              <IfIndex></IfIndex>
              <SrvID>1000</SrvID>
              <VsiName></VsiName>
              <AccessMode></AccessMode>
              <Hub></Hub>
              <Statistics></Statistics>
              <Bandwidth></Bandwidth>
              <LearningMode></LearningMode>
              <InPkts></InPkts>
              <OutPkts></OutPkts>
              <Flooding></Flooding>
              <FloodType></FloodType>
              <ForwardingMode></ForwardingMode>
              <TrackEntryNumber></TrackEntryNumber>
              <InPktsRate></InPktsRate>
              <InOctetsRate></InOctetsRate>
              <OutPktsRate></OutPktsRate>
              <OutOctetsRate></OutOctetsRate>
              </AC>
          </ACs>
        </L2VPN>
      </top>
    </filter>
  </get>
</rpc>
    <data>
         <L2VPN>
            <ACs>
               <AC>
                  <SrvID>1000</SrvID>
                  <VsiName>aa</VsiName>
                  <AccessMode>1</AccessMode>
                  <Statistics>true</Statistics>
                  <Bandwidth>4294967295</Bandwidth>
                  <LearningMode>0</LearningMode>
                  <Flooding>true</Flooding>
                  <InPkts>12815354350</InPkts>
                  <InOctets>1640365356800</InOctets>
                  <OutPkts>12815447070</OutPkts>
                  <InPktsRate>8261191</InPktsRate>
                  <InOctetsRate>1057432529</InOctetsRate>
                  <OutPktsRate>8261223</OutPktsRate>
                  <OutOctetsRate>0</OutOctetsRate>
               </AC>
            </ACs>
         </L2VPN>
      </top>
    </data>
</rpc-reply>
gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path L2VPN/VSIStatistics to it.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path l2vpn/vsistatistics
Learn more
Collecting VSI traffic statistics
Requirements
Obtain VSI traffic statistics.
CLI
Obtain traffic statistics for VSI vsi3.
·     To enable VSI traffic statistics, execute the statistics enable command in VSI view. To obtain traffic statistics, execute the display l2vpn vsi verbose command.
·     To determine whether a VSI works correctly within a period by collecting VSI traffic statistics within that period, first use the reset l2vpn statistics vsi command to clear the statistics.
Enable traffic statistics for manually created tunnels.
<H3C> sys-view
[H3C] vsi vsi3
[H3C-vsi-vsi3] statistics enable
[H3C]display l2vpn vsi verbose
VSI Name: vsi3
  VSI Index               : 0
  VSI State               : Up
  Input Statistics        :
    Octets   :6737029504
    Packets  :52633043
    Errors   :0
    Discards :0
  Output Statistics       :
    Octets   :9158149482
    Packets  :105266086
    Errors   :0
    Discards :0
Table 16 Command output
Statistics
·     Enabled—The packet statistics feature is enabled for the VSI.
·     Disabled—The packet statistics feature is disabled for the VSI.
Input statistics
·     Errors—Number of error packets.
·     Discards—Number of discarded packets.
Output statistics
SNMP
Use an NMS to obtain the inbound traffic statistics in bytes for VSI vsi3 from the device Agent through SNMP.
Figure 60 Network diagram for SNMP
See "Procedure."
·     To obtain traffic statistics for a VSI, you must first obtain the index of the VSI, and then use the index to obtain traffic statistics for the VSI.
·     To obtain traffic statistics for a VSI, use the nodes under the hh3cVsiEntry (with OID 1.3.6.1.4.1.25506.2.105.1.2.1) and hh3cVsiPerfEntry (with OID 1.3.6.1.4.1.25506.2.105.1.7.1) nodes. For more information about the nodes under the hh3cVsiEntry and hh3cVsiPerfEntry nodes, see the MIB references for your device.
·     This example obtains the inbound traffic statistics in bytes of VSI vsi3 through the MIB browser.
# As shown in Figure 61, obtain the index of VSI vsi3 from the hh3cVsiEntry node (with OID 1.3.6.1.4.1.25506.2.105.1.2.1). The query results dialog box shows that the index is 1 for VSI vsi3.
Figure 61 Obtaining the VSI index
# As shown in Figure 62, use the hh3cVsiPerfEntry node (with OID 1.3.6.1.4.1.25506.2.105.1.7.1) to obtain the inbound traffic statistics in bytes for the index value of 0 1. The query results dialog box shows the query results.
Figure 62 Obtain traffic statistics
Learn more
For more information about configuring SNMP, see SNMP configuration in the configuration guides for your device.
For more information about MIB files, see the MIB references for your device.
NETCONF
Figure 63 Network diagram for NETCONF
Use the L2VPN/VSIStatistics table to obtain VSI traffic statistics. The L2VPN/VSIStatistics table provides interface traffic statistics in both bytes and packets, including statistics for incoming or outgoing normal packets, error packets, and discarded packets.
The following procedure uses the L2VPN/VSIStatistics table to obtain traffic statistics for VSI vsi3.
# Copy and paste the following message to the NETCONF client.
  <get-bulk>
        <L2VPN>
          <VSIStatistics>
            <Statistics>
              <VsiName>vsi3</VsiName>             //VSI name
              <InPkts></InPkts>                   //Inbound packet count
              <InOctets></InOctets>               //Inbound byte count
              <InErrors></InErrors>               //Inbound error packet count
              <InDiscards></InDiscards>           //Inbound dropped packet count
              <OutPkts></OutPkts>                 //Outbound packet count
              <OutOctets></OutOctets>             //Outbound byte count
              <OutErrors></OutErrors>             //Outbound error packet count
              <OutDiscards></OutDiscards>         //Outbound dropped packet count
              <InPktsRate></InPktsRate>           //Inbound packet rate
                      <InOctetsRate></InOctetsRate>       //Inbound byte rate
              <OutPktsRate></OutPktsRate>         //Outbound packet rate
              <OutOctetsRate></OutOctetsRate>     //Outbound byte rate
              <AcInPkts></AcInPkts>               //AC inbound packet count
              <AcInOctets></AcInOctets>           //AC inbound byte count
              <AcOutPkts></AcOutPkts>             //AC outbound packet count
              <AcOutOctets></AcOutOctets>         //AC outbound byte count
              <AcInPktsRate></AcInPktsRate>       //AC inbound packet rate
              <AcInOctetsRate></AcInOctetsRate>   //AC inbound byte rate
              <AcOutPktsRate></AcOutPktsRate>     //AC outbound packet rate
              <AcOutOctetsRate></AcOutOctetsRate> //AC outbound byte rate
            </Statistics>
          </VSIStatistics>
        </L2VPN>
# If the requested operation succeeds, the server responds with the following information.
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
         <data>
               <L2VPN>
                  <VSIStatistics>
                     <Statistics>
                        <InPkts>45537431676</InPkts>
                        <InOctets>5828791254528</InOctets>
                        <InErrors>0</InErrors>
                        <InDiscards>0</InDiscards>
                        <OutPkts>91075403010</OutPkts>
                        <OutOctets>7923560061870</OutOctets>
                        <OutErrors>0</OutErrors>
                        <OutDiscards>0</OutDiscards>
                        <InPktsRate>8575395</InPktsRate>
                        <InOctetsRate>1097650645</InOctetsRate>
                        <OutPktsRate>17151031</OutPktsRate>
                        <OutOctetsRate>1492139697</OutOctetsRate>
                        <AcInPkts>0</AcInPkts>
                        <AcInOctets>0</AcInOctets>
                        <AcOutPkts>0</AcOutPkts>
                        <AcOutOctets>0</AcOutOctets>
                        <AcInPktsRate>0</AcInPktsRate>
                        <AcInOctetsRate>0</AcInOctetsRate>
                        <AcOutPktsRate>0</AcOutPktsRate>
                        <AcOutOctetsRate>0</AcOutOctetsRate>
                     </Statistics>
                  </VSIStatistics>
               </L2VPN>
            </top>
         </data>
      </rpc-reply>
      </top>
    </filter>
  </get>
</rpc>
gRPC
Figure 64 Network diagram for gRPC
# Configure IP addresses as required so the device and the collector can reach each other. (Details not shown.)
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path l2vpn/vsistatistics to it.
After sensor path l2vpn/vsistatistics is added, the device will collect traffic statistics for all interfaces and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry] sensor-group test
[H3C-telemetry-sensor-group-test] quit
# Create a destination group named collector1 and add a collector to the group. In this example, the collector receives data on port 50050 at IPv4 address 192.168.2.1.
[H3C-telemetry] destination-group collector1
[H3C-telemetry-destination-group-collector1] ipv4-address 192.168.2.1 port 50050
[H3C-telemetry-destination-group-collector1] quit
[H3C-telemetry] subscription A
[H3C-telemetry-subscription-A] sensor-group test sample-interval 30
[H3C-telemetry-subscription-A] destination-group collector1
[H3C-telemetry-subscription-A] quit
Learn more
For more information about configuring gRPC, see gRPC configuration in the configuration guides for your device.
Collecting VSI interface traffic statistics
Requirements
Obtain VSI interface traffic statistics.
·     To collect VSI interface traffic statistics, first execute the statistics enable command in VSI view. After you disable packet statistics for a VSI, the incoming and outgoing traffic statistics on its VSI interface will be cleared.
·     The device collects both Layer 2 and Layer 3 traffic statistics for VSI interfaces.
·     You can obtaining VSI interface traffic statistics only from the CLI.
CLI
Obtain the traffic statistics for VSI interface 3.
# Creating a VSI interface.
[H3C] interface vsi-interface 3
[H3C-Vsi-interface3] ip address 200.0.0.1 255.0.0.0
[H3C-Vsi-interface3] quit
# Specify VSI-interface 3 as the gateway interface for VSI vsi3.
[H3C] vsi vsi3
[H3C-vsi-vsi3] gateway vsi-interface 3
[H3C-vsi-vsi3] quit
[H3C]dis interface Vsi-interface 3
Vsi-interface3
Input (total):  31 packets, 3904 bytes
Output (total):  34 packets, 4096 bytes
Table 17 Command output
Last time when the reset counters interface vsi-interface command was used to clear interface statistics.
This field displays Never if the reset counters interface vsi-interface command has never been used on the interface since the device startup.
Total numbers of input packets and bytes.
Total numbers of output packets and bytes.
Collecting AC traffic statistics through MQC
Requirements
Obtain AC traffic statistics through MQC.
Before you obtain AC traffic statistics through MQC, configure rules to match the target VXLAN tunnel in a traffic behavior, and apply the QoS policy referencing the traffic behavior to the Layer 2 Ethernet interface that acts as the outgoing interface for the target VXLAN tunnel.
CLI
Obtain traffic statistics for interface Ten-GigabitEthernet 1/0/27 through MQC.
The device supports configuring a traffic accounting action by using the accounting [ byte | packet ]* command. The accounting byte command collects traffic statistics in bytes, while the accounting packet command collects traffic statistics in packets. If neither the byte keyword nor the packet keyword is specified for the accounting command, the device collects traffic statistics in packets. If both the byte and packet keywords are specified for the accounting command, the device collects traffic statistics in packets and bytes. This example collects traffic statistics in packets.
If sites are interconnected at Layer 2, specify the inner MAC addresses of traffic. If sites are interconnected at Layer 3, specify the inner IP addresses of traffic.
·     For Layer 2 interconnection:
# Create Layer 2 ACL 4000, and configure rule 0 to match VXLAN packets source from MAC address 0000-0000-0001 and destined for MAC address 0000-0000-0006.
<H3C> sys-view
[H3C] acl mac 4000
[H3C-acl-ipv4-adv-4000] rule 0 permit vxlan inner-source-mac 0000-0000-0001 ffff-ffff-ffff inner-dest-mac 0000-0000-0006 ffff-ffff-ffff
[H3C-acl-ipv4-adv-4000] quit
[H3C-classifier-aa] if-match acl 4000
·     For Layer 3 interconnection:
# Create advanced ACL 3000, and configure rule 0 to match VXLAN packets sourced from IP address 100.0.0.1 and destined for IP address 101.0.0.1 in VXLAN 1.
<H3C> sys-view
[H3C] acl advance 3000
[H3C-acl-ipv4-adv-3000] rule 0 permit vxlan vxlan-id 1 inner-protocol ip inner-source 100.0.0.1 0 inner-destination 101.0.0.1 0
[H3C-acl-ipv4-adv-3000] quit
[H3C-classifier-aa] if-match acl 3000
[H3C]qos policy aa
·     # Obtain the VXLAN traffic statistics for interface Ten-GigabitEthernet 1/0/27 (Layer 2 interconnection).
  Direction: inbound
  Policy: aa
   Classifier: aa
     Operator: AND
     Rule(s) :
      If-match acl 4000
     Behavior: aa
      Accounting enable:
        98928876 (Packets)
·     # Obtain the VXLAN traffic statistics for interface Ten-GigabitEthernet 1/0/27 (Layer 3 interconnection).
  Direction: inbound
  Policy: aa
   Classifier: aa
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: aa
      Accounting enable:
        98928876 (Packets)
Table 18 Command output
Direction
policy
QoS policy name.
Classifier
Traffic class name and its match criteria.
Operator
Operator for match criteria in the traffic class.
Rule(s)
Match criteria.
Behavior
Behavior name and its contents.
Accounting enable
Class-based accounting action.
Learn more
SNMP
Use an NMS to obtain the VXLAN traffic statistics on interface Ten-GigabitEthernet 1/0/27 through SNMP.
Obtain VXLAN traffic statistics for interface Ten-GigabitEthernet 1/0/27 through MQC, as shown in "Procedure."
·     This example uses the MIB browser to obtain the VXLAN traffic statistics on Ten-GigabitEthernet 1/0/27.
·     To obtain the VXLAN traffic statistics, you must first use the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2 to obtain the object index of the QoS policy applied to the related interface. Then, use the index to obtain outbound VXLAN traffic statistics in the subtable of the hh3cCBQoSAccountingRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1. For more information about the hh3cCBQoSAccountingRunInfoEntry table, see the MIB references for your device.
# As shown in Figure 65, obtain the index of interface Ten-GigabitEthernet 1/0/27 through the ifName subnode (1.3.6.1.2.1.31.1.1.1.1.2) of the ifXentry node (1.3.6.1.2.1.31.1.1.1.1). The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 65 Obtaining the interface index
# Obtain the index of the QoS policy applied to the interface by the interface index in the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2. As shown in Figure 66, the index of the QoS policy applied to interface Ten-GigabitEthernet 1/0/27 is 1.
Figure 66 Obtaining the index of a QoS policy applied to an interface
# As shown in Figure 67, use the hh3cCBQoSAccountingRunInfoEntry table (with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1) to obtain the inbound VXLAN traffic statistics for Ten-GigabitEthernet 1/0/27.
Figure 67 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain VXLAN packet statistics for Ten-GigabitEthernet 1/0/27.
The device provides the MQC/IfPolicyAccount table for collecting VXLAN traffic statistics. You can obtain statistics in bytes or packets by using the MQC/IfPolicyAccount table.
This example uses the MQC/AccountRunInfo table to obtain statistics for interface Ten-GigabitEthernet 1/0/27.
<H3C> sys-view
[H3C] probe
[H3C-probe]display system internal ifmgr list | include Ten-GigabitEthernet1/0/27
         Ten-GigabitEthernet1/0/27(index:27)
  <get-bulk>
        <MQC>
          <IfPolicyAccount>
            <Interface>
              <IfIndex>27</IfIndex>           //Interface index
              <Direction></Direction>         //Direction in which the QoS policy is applied
              <ClassName></ClassName>         //Traffic class name
              <Packets></Packets>             //Traffic statistics in packets
              <Bytes></Bytes>                 //Traffic statistics in bytes
              <pps></pps>                     //Traffic statistics in pps
              <bps></bps>                     //Traffic statistics in bps
            </Interface>
          </IfPolicyAccount>
        </MQC>
      </top>
    </filter>
  </get-bulk>
</rpc>
# If the client receives a message like the following, it indicates that the operation was successful.
<data>
      <MQC>
         <IfPolicyAccount>
            <Interface>
               <Direction>0</Direction>
               <ClassName>aa</ClassName>
               <Packets>98928876</Packets>
               <pps>0</pps>
            </Interface>
         </IfPolicyAccount>
      </MQC>   </top>
   </data>
</rpc-reply>
Learn more
For more information about configuring NETCONF, see NETCONF configuration in the configuration guides for your device.
For more information about MQC/IfPolicyAccount, see H3C Comware 7 NETCONF XML API Reference.
gRPC
Use a collector to obtain the VXLAN traffic statistics for interface Ten-GigabitEthernet 1/0/27 on the device through gRPC.
Figure 68 Network diagram for gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path MQC/IfPolicyAccount.
After sensor path MQC/IfPolicyAccount is added, the device will collect traffic statistics for all interfaces on the device and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path mqc/ifpolicyaccount
Learn more
For more information about configuring gRPC, see gRPC configuration in the configuration guides.
Collecting VLAN traffic statistics
Requirements
Obtain VLAN traffic statistics through MQC.
CLI
Obtain inbound and outbound traffic statistics of VLAN 2 through MQC.
<H3C> sys-view
[H3C]qos policy aa
# Apply the QoS policy to the inbound direction and outbound direction of the VLAN.
[H3C] qos vlan-policy aa vlan 2 inbound
[H3C] qos vlan-policy aa vlan 2 outbound
# Obtain traffic statistics of VLAN 2.
[H3C]display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: aa
   Classifier: aa
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: aa
      Accounting enable:
        1193773738 (Packets)
Vlan 2
  Direction: Outbound
  Policy: aa
   Classifier: aa
     Operator: AND
     Rule(s) :
      If-match any
     Behavior: aa
      Accounting enable:
        250116562 (Packets)
Table 19 Command output
Direction
policy
QoS policy name.
Classifier
Operator
Rule(s)
Match criteria
if-match any
Behavior
Accounting enable
Learn more
SNMP
Use an NMS to obtain inbound traffic statistics of VLAN 2 through SNMP.
Figure 69 Network diagram for SNMP
Configure MQC to obtain traffic statistics of the VLAN. For more information, see "Procedure."
·     This example obtains the inbound traffic statistics of tunnel0 through the MIB browser.
·     Assume that a QoS policy has been configured and applied to the inbound direction of VLAN 2 on the device.
·     To obtain the traffic statistics of the VLAN, you must first use the hh3cCBQoSVlanApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2 to obtain the index of the QoS policy applied to the VLAN. Then, use the index of the QoS policy to obtain the traffic statistics of the VLAN in the subtable of the hh3cCBQoSAccountingRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1. For more information about the hh3cCBQoSAccountingRunInfoEntry table, see the MIB references for your device.
# Use the hh3cCBQoSVlanApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2 to obtain the index of the QoS policy applied to VLAN 2. As shown in Figure 70, the query results dialog box shows that the index is 1 for the QoS policy applied to the VLAN.
Figure 70 Obtaining the interface index
In the query results of the hh3cCBQoSVlanApplyObjectIndex table as shown in Figure 70, 2.1 indicates that the QoS policy is applied in the inbound direction of VLAN 2, and 1 is the index of the QoS policy applied to VLAN 2.
# Use the index obtained in the preceding step to obtain the traffic statistics of VLAN 2 in the subtable of the hh3cCBQoSAccountingRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1. As shown in Figure 71, obtain the statistics in packets. The query results dialog shows that 100 packets are received in VLAN 2.
Figure 71 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics of VLAN 2 on the device named Agent.
Figure 72 Network diagram for NETCONF
The device provides the MQC/VLANPolicyAccount table for collecting packet statistics of a VLAN. You can obtain statistics in bytes or packets by using the MQC/VLANPolicyAccount table.
This example uses the MQC/AccountRunInfo table to obtain statistics of VLAN 2.
  <get-bulk>
        <MQC>
          <VLANPolicyAccount>
            <VLAN>
              <VLANID>2</VLANID>
              <Packets></Packets>
              <Bytes></Bytes>
              <pps></pps>
              <bps></bps>
            </VLAN>
          </VLANPolicyAccount>
        </MQC>
      </top>
    </filter>
  </get-bulk>
</rpc>
<data>
      <MQC>
         <VLANPolicyAccount>
            <VLAN>
                <VLANID>2</VLANID>             //VLAN ID
                <Direction>0</Direction>       //0 for inbound and 1 for outbound
                <ClassName>test</ClassName>    //Traffic class name
                <Packets>52133621124</Packets> //Traffic statistics in packets
                <pps>12668937</pps>            //Traffic statistics in pps
                </VLAN>
      /MQC>
   </top>
   </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain traffic statistics of the device by using gRPC.
Figure 73 Network diagram for gRPC
# Configure MQC to obtain traffic statistics of the VLAN. For more information, see "Procedure."
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path MQC/VLANPolicyAccount.
After sensor path MQC/VLANPolicyAccount is added, the device will collect traffic statistics of all VLANs with QoS policies applied and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path mqc/vlanpolicyaccount
Learn more
Collecting VPN instance traffic statistics
Requirements
Obtain traffic statistics for a VPN instance through MQC.
Before obtaining the traffic of a VPN instance through MQC, you must configure an ACL to match the VPN instance in a traffic class, and apply a QoS policy that references the traffic class to the interface bound to the VPN instance. The device supports obtaining MQC traffic statistics through CLI, SNMP, NETCONF, and gRPC.
CLI
Obtain inbound traffic statistics for VPN instance vpn1 through MQC.
# Create advanced ACL 3000. Configure rule 0 to match inbound IP packets of VPN instance vpn1.
<H3C> sys-view
[H3C-acl-ipv4-adv-3000] rule 0 permit ip vpn-instance vpn1
[H3C]qos policy aa
# Obtain the traffic statistics for interface Ten-GigabitEthernet 1/0/27.
  Direction: Inbound
  Policy: aa
   Classifier: aa
     Operator: AND
     Rule(s) :
      If-match acl 3000
     Behavior: aa
      Accounting enable:
        98928876 (Packets)
Table 20 Command output
Direction
policy
QoS policy name.
Classifier
Operator
Rule(s)
Match criteria.
if-match acl 3000
Matches packets that match ACL 3000 and pass through the interface.
Behavior
Accounting enable
Learn more
SNMP
Use an NMS to obtain the inbound traffic statistics for VPN instance vpn1 through SNMP.
Figure 74 Network diagram for SNMP
Configure MQC to obtain inbound traffic statistics for VPN instance vpn1. For more information, see "Procedure."
Configure SNMP. For more information, see "SNMP."
·     This example obtains the inbound traffic statistics for VPN instance vpn1 through the MIB browser.
·     To obtain the traffic statistics for the VPN, you must first use the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.3.1.2 to obtain the index of the QoS policy applied to the specified interface. Then, use the index of the QoS policy to obtain the traffic statistics for the VPN instance in the subtable of the hh3cCBQoSAccountingRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1. For more information about the hh3cCBQoSAccountingRunInfoEntry table, see the MIB references for your device.
As shown in Figure 75, use the ifDescr subnode of the ifName node (1.3.6.1.2.1.2.2.1.2) to obtain the index of interface Ten-GigabitEthernet 1/0/27. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 75 Obtaining the interface index
# Obtain the index of the QoS policy applied to the interface by the interface index in the hh3cCBQoSIntApplyObjectIndex table with OID 1.3.6.1.4.1.25506.2.65.2.1.5.5.2.1.2. As shown in Figure 76, the index of the QoS policy applied to interface Ten-GigabitEthernet 1/0/27 is 6.
Figure 76 Obtaining the index of a QoS policy applied to an interface
# As shown in Figure 77, use the hh3cCBQoSAccountingRunInfoEntry table (with OID 1.3.6.1.4.1.25506.2.65.2.1.5.6.8.1) to obtain the inbound traffic statistics (in packets) of VPN instance vpn1.
Figure 77 Obtain traffic statistics
Learn more
NETCONF
Install the NETCONF client software on the host, and use NETCONF to obtain traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 78 Network diagram for NETCONF
Configure NETCONF. For more information, see "NETCONF."
The device provides the MQC/IfPolicyAccount table for collecting packet statistics for an interface. You can obtain statistics in bytes or packets by using the MQC/IfPolicyAccount table.
This example uses the MQC/IfPolicyAccount table to obtain statistics for interface Ten-GigabitEthernet 1/0/27.
  <get-bulk>
        <MQC>
          <IfPolicyAccount>
            <Interface>
              <Direction></Direction>         //QoS policy application direction
            </Interface>
          </IfPolicyAccount>
        </MQC>
      </top>
    </filter>
  </get-bulk>
</rpc>
<data>
      <MQC>
         <IfPolicyAccount>
            <Interface>
               <pps>0</pps>
            </Interface>
         </IfPolicyAccount>
      </MQC>   </top>
   </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain traffic statistics for Layer 2 Ethernet interface Ten-GigabitEthernet 1/0/27 on the device by using gRPC.
Figure 79 Network diagram for gRPC
# Configure MQC to obtain inbound traffic statistics for VPN instance vpn1. For more information, see "Procedure."
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
[H3C] telemetry
Learn more
Collecting queue traffic statistics
This chapter describe how  to collect queue traffic statistics by using the following methods: CLI, SNMP, NETCONF, and gRPC. Before you can collect queue traffic statistics, configure a QoS policy for traffic statistics collection and apply it to an interface or VLAN.
Collecting traffic statistics for interface queues
Requirements
Obtain outbound traffic statistics of interface queues.
·     Only outbound traffic statistics collection is supported.
·     The number of forwarded packets, the number of dropped packets, and the current queue length can be collected.
CLI
Obtain per-queue traffic statistics in the outbound direction of Ten-GigabitEthernet 1/0/27.
<H3C> display qos queue-statistics interface ten-gigabitethernet 1/0/27 outbound
 Direction: outbound
 Forwarded: 8614890247 packets, 1498990957070 bytes
 Dropped: 22096410 packets, 2828340480 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Dropped: 0 packets, 0 bytes
  Current queue length: 0 packets
 Queue 1
 Queue 2
  Forwarded: 8614889788 packets, 1498990823112 bytes, 7184 pps, 10001024 bps
  Current queue length: 26142 packets
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
  Forwarded: 459 packets, 133958 bytes, 0 pps, 0 bps
Table 21 Command output
Interface whose per-queue traffic statistics are to be displayed.
Direction
Direction whose per-queue traffic statistics are to be displayed.
Forwarded
The number of packets forwarded and the number of bytes forwarded.
Dropped
The number of packets dropped and the bytes of packets dropped.
Queue 0, Queue 1, Queue 2, Queue 3, Queue 4, Queue 5, Queue 6, Queue 7
Traffic statistics of a queue
The current queue length.
Learn more
SNMP
Use an NMS to obtain the outbound queue traffic statistics of interface Ten-GigabitEthernet 1/0/27 through SNMP.
Figure 80 Network diagram for SNMP
Configure SNMP. For more information, see "Procedure."
·     This example uses the MIB browser to obtain the queue traffic statistics on the device named Agent.
·     To obtain the queue traffic statistics  for an interface, first obtain the interface index by using the ifDescr table (OID: 1.3.6.1.2.1.2.2.1.2).
·     The interface index might vary by the ID of the IRF member device hosting the interface.
As shown in Figure 81, use the ifDescr subnode (1.3.6.1.2.1.31.1.1.1.1.2) of the ifName (1.3.6.1.2.1.31.1.1.1.1) node to obtain the index of Ten-GigabitEthernet 1/0/27. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 81 Obtaining the interface index
# Obtain the queue traffic statistics by the interface index in the hh3cIfQoSHardwareQueueRunInfoEntry table with OID 1.3.6.1.4.1.25506.2.65.1.1.2.1.1, as shown in Figure 82.
You can obtain the following queue traffic statistics in the hh3cIfQoSHardwareQueueRunInfoEntry table:
·     Number of packets forwarded (hh3cIfQoSPassPackets, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1).
·     Number of packets dropped (hh3cIfQoSDropPackets, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.2).
·     Number of bytes forwarded (hh3cIfQoSPassBytes, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.3).
·     Number of bytes dropped (hh3cIfQoSDropPBytes, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.6).
·     Current queue length (hh3cIfQoSCurQueuePkts, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.1; hh3cIfQoSCurQueueBytes, OID: 1.3.6.1.4.1.25506.2.65.1.1.2.1.1.10).
The following takes obtaining the number of packets forwarded as an example. For more information, see the MIB files for the device.
Figure 82 Obtaining the number of packets forwarded
Learn more
NETCONF
Install the NETCONF client software on a host, and use NETCONF to obtain the queue traffic statistics of interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 83 Network diagram for NETCONF
Configure NETCONF. For more information, see "Procedure."
The device provides the QSTAT/InterfaceStat table for collecting interface queue traffic statistics. You can obtain statistics in bytes or packets by using the QSTAT/InterfaceStat table.
  <get-bulk>
        <QSTAT>
          <InterfaceStat>
            <Statistics>
              <PassPacket></PassPacket>
              <DropPacket></DropPacket>
              <AgingPacket></AgingPacket>
              <AgingByte></AgingByte>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
      </top>
    </filter>
  </get-bulk>
</rpc>
If the requested operation succeeds, the device responds with the requested NETCONF configuration datastore. The following is a sample response:
   <data>
        <QSTAT>
          <InterfaceStat>
            <Statistics>
              <PassPacket>578853253273</PassPacket>
              <PassByte>97793557880219</PassByte>
              <DropPacket>67748792372</DropPacket>
              <DropByte>8671845423616</DropByte>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
     </top>
   </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain the outbound traffic statistics of interface Ten-GigabitEthernet 1/0/27 on the device through gRPC.
Figure 84 Network diagram for gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
# Create a sensor group named test, and add sensor path QSTAT/InterfaceStat.
After sensor path QSTAT/InterfaceStat is added, the device will collect traffic statistics of all interfaces on the device and upload the statistics to the collector.
[H3C] telemetry
[H3C-telemetry-sensor-group-test] sensor path qstat/interfacestat
Learn more
Collecting buffer traffic statistics for queues
Requirements
Obtain buffer traffic statistics for queues.
SNMP
Use an NMS to obtain the buffer traffic statistics for queues of interface Ten-GigabitEthernet 1/0/27 through SNMP.
Figure 85 Network diagram for SNMP
Example: Obtain traffic statistics
This example uses the MIB browser to obtain the buffer traffic statistics for queues of interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Learn more
NETCONF
Figure 86 Network diagram for NETCONF
  <get-bulk>
        <QSTAT>
          <InterfaceStat>
            <Statistics>
               <QueueID></QueueID>
               <PassPkt></PassPkt>
               <DropPkt></DropPkt>
               <BitRate></BitRate>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
      </top>
    </filter>
  </get-bulk>
</rpc>
   <data>
        <QSTAT>
            <QueueStat>
                 <Statistics>
                 </Statistics>
                    <Statistics>
                 </Statistics>
                 <Statistics>
                 </Statistics>
                 <Statistics>
                 </Statistics>
                 <Statistics>
                 </Statistics>
                 <Statistics>
                  </Statistics>
                  <Statistics>
                 </Statistics>
                 <Statistics>
                 </Statistics>
             </QueueStat>
        </QSTAT>
     </top>
   </data>
</rpc-reply>
Learn more
gRPC
Figure 87 Network diagram for gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
[H3C] telemetry
Learn more
Collecting packet drop statistics for queues
Requirements
Obtain packet drop statistics for queues.
SNMP
Use an NMS to obtain the packet drop statistics of interface Ten-GigabitEthernet 1/0/27 through SNMP.
Figure 88 Network diagram for SNMP
Example: Obtain packet drop statistics
Use the reset counters interface command to clear history packet drop statistics if you want to collect packet drop statistics for a specific time period.
As shown in Figure 89, use the ifName subnode (1.3.6.1.2.1.31.1.1.1.1.2) of the ifXEntry (1.3.6.1.2.1.31.1.1.1.1) node to obtain the index of Ten-GigabitEthernet 1/0/27. The query results dialog box shows that the index is 27 for interface Ten-GigabitEthernet 1/0/27.
Figure 89 Obtaining the interface index
# Obtain the packet drop statistics by the interface index in the hh3cifPktBufEgDrop table with OID 1.3.6.1.4.1.25506.8.35.1.5.1.6, as shown in Figure 90.
Figure 90 Obtaining the packet drop statistics
Learn more
NETCONF
Install the NETCONF client software on a host, and use NETCONF to obtain the packet drop statistics of interface Ten-GigabitEthernet 1/0/27 on the device named Agent.
Figure 91 Network diagram for NETCONF
The NETCONF client obtains packet drop statistics through the NETCONF XML APIs provided by the device.
The device provides the QSTAT/InterfaceStat table for collecting packet drop statistics for interfaces. You can obtain statistics in bytes or packets by using the QSTAT/InterfaceStat table.
This example uses the QSTAT/InterfaceStat table to obtain the packet drop statistics for Ten-GigabitEthernet 1/0/27.
  <get-bulk>
        <QSTAT>
          <InterfaceStat>
            <Statistics>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
      </top>
    </filter>
  </get-bulk>
</rpc>
   <data>
        <QSTAT>
          <InterfaceStat>
            <Statistics>
            </Statistics>
          </InterfaceStat>
        </QSTAT>
     </top>
   </data>
</rpc-reply>
Learn more
gRPC
Use a collector to obtain the packet drop statistics for interface Ten-GigabitEthernet 1/0/27 on the device through gRPC.
Figure 92 Network diagram for gRPC
# Enable gRPC.
<H3C> system-view
[H3C] grpc enable
After sensor path QSTAT/InterfaceStat is added, the device will collect packet drop statistic of all interfaces on the device and upload the statistics to the collector.
[H3C] telemetry
Learn more
