Title | Size | Downloads |
H3C S12500X-AF LSXM1CGQ48KB1 Card Manual-APW101-book.pdf | 22.25 KB |
book | 22.25 KB |
LSXM1CGQ48KB1 48-port 100G QSFP28 Ethernet Optical interface module
1 Identifier
The module identifier LSXM1CGQ48KB1 is in the upper right corner of the front panel.
2 Specifications
CAUTION: This module can be used only with Type K switching fabric modules, which have a character string of SFK in their module identifiers (LSXM1SFK08F1 for example). Module damage will occur if this module is used with a switching fabric module that is not Type K. |
NOTE: Switching fabric module slots are covered by fan trays. To verify the module identifiers of the switching fabric modules when the switch is operating, use the display device command. |
Table 1 Module specifications
Item |
Specification |
Processor |
Intel processor (Quad-Core) @ 2.2 GHz |
SDRAM |
16 GB DDR4 SDRAM |
Power consumption |
395 W to 765 W |
Ports |
48 × 100GE QSFP28 ports |
Transmission rate |
100 Gbps. |
Compatible device models |
· S12516X-AF switch (configured with high performance fan trays) · S12508X-AF switch (configured with high performance fan trays) · S12500X-2L switch · S12500X-CF switch series |
Compatible switching fabric modules |
Type K switching fabric modules |
IMPORTANT: · To verify compatibility of the module with the software release you are using, see the release notes. · To use the module on an S12500X-CF switch, install switching fabric modules in the third to eighth higher-numbered switching fabric module slots. The module fails to start up if no switching fabric module is installed in the six slots. · For information about transceiver modules and cables available for the module, see H3C S12500X-AF Switch Series Cards and Transceiver Modules Compatibility Matrixes or H3C S12500X-CF Switch Series Cards and Transceiver Modules Compatibility Matrixes. |
3 Related documentation
For module installation, see H3C S12500X-AF Switch Series Installation Guide, H3C S12500X-2L Switch Installation Guide, or H3C S12500X-CF Switch Series Installation Guide.
For software upgrade, see the release notes for the device.
Copyright © 2020 New H3C Technologies Co., Ltd.
