Title | Size | Downloads |
H3C SecPath L5000-AD920 Application Delivery Security Gateway Hardware Information-5W100-book.pdf | 1.99 MB |
book | 1.99 MB |
Hardware Information and Specifications
Copyright © 2025 New H3C Technologies Co., Ltd. All rights reserved.
1 Chassis views and technical specifications
Temperature and humidity requirements
HVDC power cord specifications
Transceiver module specifications
Chassis views
H3C SecPath L5000-AD920 Application Delivery Security Gateway has the following sections: supervisor engine module (SEM) section, service module section, interface module section, fan tray section, power supply section, and hard disk section.
Figure1-1 Front view
Figure1-2 Rear view
(1) Hard disk section |
(2) Service module section |
(3) Interface module section |
(4) SEM section |
(5) Fan tray section |
(6) Power supply section |
Table1-1 Section descriptions for the device
Section |
Slot number |
Hard disk section |
HD 0 and HD 1 |
Hard disks are optional. |
SUBSLOT 2/1 and SUBSLOT 2/2 |
Used for installing service modules. For more information about the service module and device slot compatibility, see Table2-2. |
SUBSLOT 2/3 and SUBSLOT 2/4 |
Interface modules are required. |
SEM section |
SLOT 0 and SLOT 1 |
SEMs are required. |
Fan tray section |
FAN 1 and FAN 2 |
Fan trays are required. |
PWR 1 and PWR 2 |
Power supplies are required. Install the power supplies based on the actual power requirements of the device. |
NOTE: No SEMs, interface modules, service modules, hard disks, fan trays, and power supplies are provided with the device. Prepare them yourself as required. |
Interface numbering
Definition
The device provides multiple types of ports, including console ports, management Ethernet ports, 10G BASE-R fiber ports, and 40G BASE-R fiber ports.
When the device operates in standalone mode, the ports on the device are numbered in the interface-type X/Y/Z format.
· interface-type—Type of the interface, for example, 10G BASE-R.
· X—Slot number. Slot number of a module (SEM, interface module, or service module) on the device. For information about the slot number ranges, see Table1-1.
· Y—Subslot number, which is fixed at 0 for an SEM. The subslot number for a service module or an interface module varies by its installation slot. For example, if a service module installed in SUBSLOT 2/1 of the device, its subslot number is 1.
· Z—Number marked for the port on a module, starting from 1. The management Ethernet port is numbered M-GigabitEthernet 0/0/0.
When the device operates in IRF mode, the ports on the device are numbered in the interface-type W/X/Y/Z format.
· W—IRF member ID.
· Descriptions for other auguments are the same as those in standalone mode.
· The management Ethernet port is numbered M-GigabitEthernet 1/0/0/0.
Example
· The device operates in standalone mode, and an NSQM2QG4A0 interface module is installed in SUBSLOT 2/3 of the device. The interfaces on the interface module are numbered from FortyGigE 2/3/1 to FortyGigE 2/3/4.
· The device operates in IRF mode with IRF member ID 1, and an NSQM2QG4A0 interface module is installed in SUBSLOT 2/3 of the device. The interfaces on the interface module are numbered from FortyGigE 1/2/3/1 to FortyGigE 1/2/3/4.
Chassis specifications
Table1-2 Chassis specifications
Model |
Dimensions (H × W × D) |
Net weight |
Chassis power consumption range |
Maximum system power consumption |
L5000-AD920 |
88.1 × 440 × 660 mm (3.47 × 17.32 × 25.98 in) |
12 kg (26.46 lb) |
36 W to 79 W |
649 W |
The system power consumption of the device is the sum of the power consumptions of the chassis, all running modules, hard disks, and fan trays. It depends on the type and quantity of the modules installed and the power consumptions of the hard disks and fan trays. The system power consumption can be calculated as follows:
· Minimum system power consumption of the device: The sum of the minimum power consumptions of the chassis, modules, hard disks, and fan trays.
· Maximum system power consumption of the device: The sum of the maximum power consumptions of the chassis, modules, hard disks, and fan trays.
For example, the device has two NSQM6SUP04A0 SEMs, two NS-ADEEMPA0 service modules, two NSQM2QG2TG8A0 interface modules, two NS-SSD-480G-SATA-SFF hard disks, and two FAN-20F-2-A fan trays. The minimum system power consumption of the device is 36 + 2 × 12 + 2 × 156 + 2 × 4 + 2 × 1.5 + 2 × 12 = 407 W, and the maximum system power consumption of the device is 79 + 2 × 19 + 2 × 188 + 2 × 18 + 2 × 3 + 2 × 57 = 649 W.
Table1-3 Indoor environment requirements
Item |
Temperature |
· Operating: 0°C to 40°C (32°F to 104°F) · Storage: –40°C to +70°C (–40°F to +158°F) |
Humidity |
· Operating: 5% RH to 95 RH, noncondensing · Storage: 5% RH to 95 RH, noncondensing |
Cooling system
The device uses front-rear airflow for heat dissipation. When you install the device, ensure that its airflow direction meets the ventilation requirement of the installation site. Plan the installation site for the device based on its airflow direction. For adequate ventilation, make sure the following requirements are met:
· The installation site has a good cooling system.
· Ensure a minimum of 100 mm (3.94 in) around the air inlet and outlet vents of the chassis.
The FAN-20F-2-A fan tray blows air from the power supply side to the port side. The fan tray handles are blue.
Figure1-3 Airflow of the chassis installed with FAN-20F-2-A fan trays
The FAN-20B-2-A fan tray draws air from the port side to the power supply side. The fan tray handles are red.
Figure1-4 Airflow of the chassis installed with FAN-20B-2-A fan trays
2 Removable components
Installation accessories
Table2-1 Installation accessories
Accessory |
Applicable device models |
Mounting brackets with cable management brackets |
All models |
Slide rails and chassis rails |
All models |
M6 rack screw |
All models |
Cage nut |
All models |
M4 mounting bracket screw |
All models |
Grounding cable |
All models |
Modules
Table2-2 displays the slots available for the modules. The mark on a module is used as its model name.
Table2-2 Module and device slot compatibility
Module type |
Module model |
Compatible slots |
SEM |
NSQM6SUP04A0 |
SLOT 0 and SLOT 1 |
Service module |
NS-ADEEMPA0 |
Service module |
NS-ADEEMPB0 |
Service module |
NS-ADEEMPC0 |
Service module |
NS-ADEEMPC1 |
Service module |
NS-ADEGMFAMA0 |
Interface module |
NSQM2QG2TG8A0 |
Interface module |
NSQM2QG4A0 |
Interface module |
NSQM2TG16A0 |
SEMs
NSQM6SUP04A0
The NSQM6SUP04A0 SEM provides one console port, one copper management Ethernet port, and one USB port.
Figure2-1 Front view
(1) Reset button (RESET) |
(2) Console port |
(3) Captive screw |
(4) Ejector lever |
(5) Module status LED |
(6) System status LED |
(7) SEM status LED |
(8) Fan tray status LED |
(9) Power supply status LED |
(10) Copper management Ethernet port |
(11) Copper management Ethernet port LED |
(12) USB port |
(15) SEM active/standby status LED |
Table2-3 Technical specifications
Item |
Specification |
Memory |
8 GB (DDR4 SDRAM) |
42.6 × 108 × 212 mm (1.68 × 4.25 × 8.35 in) |
Power consumption |
12 W to 19 W |
Weight |
0.6 kg (1.32 lb) |
Hot swapping |
Not supported |
Ports |
1 × console port |
1 × USB port |
1 × copper management Ethernet port |
Compatible devices and slots |
· M9000-AD6 application delivery security gateway (slot 0 and slot 1) · L5000-AD920 application delivery security gateway (slot 0 and slot 1) |
NOTE: · For information about the software versions available for the SEM, see the release notes. · When you update the software or BootWare from BootWare, you can only use a copper management Ethernet port rather than a fiber management Ethernet port to transfer the software image files. · The USB port does not support USB extension cables. |
Table2-4 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
Compliant standard |
RS-232 |
Transmission baud rate |
9600 bps (default) to 115200 bps |
Cable type |
Common asynchronous serial port cable |
Transmission distance |
≤ 15 m (49.21 ft) |
Supported services |
· Provides connection to an ASCII terminal · Connects to the serial port on a local PC running a terminal emulation program · Supports command line interface (CLI) |
Table2-5 Copper management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
802.3, 802.3u, and 802.3ab |
Port type |
MDI/MDI-X autosensing |
Cable type |
Category 5 or above twisted pair cable |
100 m (328.08 ft) |
Port speed and duplex mode |
· 10 Mbps: Half/full duplex · 100 Mbps: Half/full duplex · 1000 Mbps: Full duplex |
Service modules
NS-ADEEMPA0
The NS-ADEEMPA0 ADE service module provides two console ports, two USB ports, and two copper management Ethernet ports.
Figure2-2 Front view
(1) Ejector lever |
(2) Console ports |
(3) Copper management Ethernet ports |
(4) CPU 0 status LED |
(5) CPU 1 status LED |
(6) USB ports (only for supplying power) |
(7) Offline button (reserved) |
(8) Offline LED (reserved) |
(9) Copper management Ethernet port LED (ACT) |
(10) Copper management Ethernet port LED (LINK) |
Table2-6 Technical specifications
Item |
Specification |
Memory |
64 GB RDIMM (two 16 GB RDIMMs per CPU) |
CPU storage |
16 GB (8 GB per CPU) |
CPUs |
2 |
44 × 191 × 365 mm (1.73 × 7.52 × 14.37 in) |
Weight |
2.45 kg (5.40 lb) |
Power consumption |
156 W to 188 W |
Hot swapping |
Not supported |
Ports |
2 × console ports |
2 × USB ports (only for supplying power) |
2 × copper management Ethernet ports |
· M9000-AD6 application delivery security gateway (SUBSLOT 2/1 and SUBSLOT 2/2) · L5000-AD920 application delivery security gateway (SUBSLOT 2/1 and SUBSLOT 2/2) |
Table2-7 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
RS-232 |
Cable type |
≤ 15 m (49.21 ft) |
· Provides connection to an ASCII terminal · Connects to the serial port on a local PC running a terminal emulation program · Supports CLI |
Table2-8 Copper management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port type |
Cable type |
100 m (328.08 ft) |
NS-ADEEMPB0
The NS-ADEEMPB0 ADE service module provides one console port, one USB port, and one copper management Ethernet port.
Figure2-3 Front view
(1) Ejector lever |
(2) Console port |
(3) Copper management Ethernet port |
(4) CPU status LED |
(5) USB port (only for supplying power) |
(6) Offline button (reserved) |
(7) Offline LED (reserved) |
(8) Copper management Ethernet port LED (ACT) |
(9) Copper management Ethernet port LED (LINK) |
Table2-9 Technical specifications
Item |
Specification |
Memory |
32 GB RDIMM |
CPU storage |
8 GB |
CPUs |
1 |
Weight |
2.1 kg (4.63 lb) |
Power consumption |
84 W to 107 W |
Hot swapping |
Not supported |
Ports |
1 × console port |
1 × USB port (only for supplying power) |
Table2-10 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
RS-232 |
Cable type |
≤ 15 m (49.21 ft) |
Table2-11 Copper management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port type |
Cable type |
100 m (328.08 ft) |
NS-ADEEMPC0/NS-ADEEMPC1
The NS-ADEEMPC0 and NS-ADEEMPC1 ADE service modules each provide two console ports, two USB ports, and two copper management Ethernet ports.
Figure2-4 Front view
(1) Ejector lever |
(2) Console ports |
Table2-12 Technical specifications
Item |
Specification |
Memory |
CPU storage |
CPUs |
2 |
Weight |
2.45 kg (5.40 lb) |
Power consumption |
156 W to 204 W |
Hot swapping |
Not supported |
Ports |
2 × console ports |
Table2-13 Console port specifications
Item |
Specification |
Connector type |
RJ-45 |
RS-232 |
Cable type |
≤ 15 m (49.21 ft) |
Table2-14 Copper management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port type |
Cable type |
100 m (328.08 ft) |
NS-ADEGMFAMA0
The NS-ADEGMFAMA0 service module provides two USB console ports, one USB port (only for supplying power, not in host mode), and two copper management Ethernet ports.
Figure2-5 Front view
(1) Ejector lever |
(2) Copper management Ethernet port LED |
(3) USB port (only for supplying power, not in host mode) |
(4) Copper management Ethernet port |
(5) USB console port |
(6) CPU status LEDs |
Table2-15 Technical specifications
Item |
Specification |
Memory |
CPU storage |
CPUs |
2 |
Weight |
2.38 kg (5.25 lb) |
Power consumption |
231 W to 295 W |
Hot swapping |
Not supported |
Ports |
2 × USB console ports |
1 × USB port (only for supplying power, not in host mode) |
Table2-16 USB console port specifications
Item |
Specification |
Connector type |
Type-C USB |
RS-232 |
9600 bps to 115200 bps (default: 115200 bps) |
Cable type |
Type-C console cable |
≤ 10 m (32.81 ft) |
Table2-17 Copper management Ethernet port specifications
Item |
Specification |
Connector type |
RJ-45 |
Port type |
Cable type |
100 m (328.08 ft) |
Interface modules
NSQM2QG2TG8A0
The NSQM2QG2TG8A0 interface module provides eight 10G fiber ports and two 40G fiber ports.
Figure2-6 Front view
(1) 10G fiber ports |
(2) 40G fiber ports |
(3) Ejector lever |
(4) 40G fiber port LEDs |
(5) 10G fiber port LEDs |
(6) Captive screw |
Table2-18 Technical specifications
Item |
Specification |
37.4 × 174 × 192 mm (1.47 × 6.85 × 7.56 in) |
Power consumption |
4 W to 18 W |
Net weight |
0.8 kg (1.76 lb) |
Hot swapping |
Not supported |
Ports |
· 8 × 10GBASE-R fiber ports · 2 × 40GBASE-R fiber ports |
Connector type |
LC/MPO |
Available transceiver modules |
10GBASE-R-SFP+ ports: See Table2-19 40GBASE-R-QSFP+ ports: See Table2-20 |
· L5000-AD920 application delivery security gateway (SUBSLOT 2/3 and SUBSLOT 2/4) · M9000-AD6 application delivery security gateway (SUBSLOT 2/3 and SUBSLOT 2/4) |
Table2-19 SFP+ transceiver modules available for the 10GBASE-R fiber ports
Model |
Central wavelength (nm) |
Connector type |
Cable/Fiber type and diameter (µm) |
Maximum transmission distance |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
10 km (6.21 miles) |
SFP-XG-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
40 km (24.86 miles) |
Table2-20 QSFP+ transceiver modules available for the 40GBASE-R fiber ports
Model |
Connector type |
Mode bandwidth (MHz*km) |
QSFP-40G-SR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
100 m (328.08 ft) |
QSFP-40G-LR4-WDM1300 |
1310 |
LC |
9/125, SMF |
N/A |
QSFP-40G-CSR4-MM850 |
850 |
MPO |
50/125, MMF |
2000 |
300 m (984.25 ft) |
NSQM2QG4A0
The NSQM2QG4A0 interface module provides four 40G fiber ports.
Figure2-7 Front view
(1) 40G fiber ports |
(2) Ejector lever |
(3) 40G fiber port LEDs |
(4) Captive screw |
Table2-21 Technical specifications
Item |
Specification |
Power consumption |
4 W to 15 W |
Net weight |
0.7 kg (1.54 lb) |
Hot swapping |
Not supported |
Ports |
4 × 40GBASE-R fiber ports |
Connector type |
LC/MPO |
40GBASE-R-QSFP+ ports: See Table2-22 |
Table2-22 QSFP+ transceiver modules available for the 40GBASE-R fiber ports
Model |
Connector type |
850 |
MPO |
50/125, MMF |
2000 |
100 m (328.08 ft) |
1310 |
LC |
9/125, SMF |
N/A |
850 |
MPO |
50/125, MMF |
2000 |
300 m (984.25 ft) |
NSQM2TG16A0
The NSQM2TG16A0 interface module provides sixteen 10G fiber ports.
Figure2-8 Front view
(2) Ejector lever |
(3) 10G fiber port LEDs |
(4) Captive screw |
Table2-23 Technical specifications
Item |
Specification |
Power consumption |
5 W to 23 W |
Net weight |
0.84 kg (1.85 lb) |
Hot swapping |
Not supported |
Ports |
16 × 10GBASE-R fiber ports |
Connector type |
LC |
Table2-24 SFP transceiver modules available for the 10GBASE-R fiber ports
Model |
Connector type |
SFP-GE-SX-MM850-A |
850 |
LC |
50/125, MMF |
550 m (1804.46 ft) |
SFP-GE-SX-MM850-D |
850 |
LC |
50/125, MMF |
SFP-GE-LX-SM1310-A |
1310 |
LC |
9/125, SMF |
SFP-GE-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-GE-LH40-SM1310 |
1310 |
LC |
9/125, SMF |
SFP-GE-LH40-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-GE-LH40-SM1550 |
1550 |
LC |
9/125, SMF |
SFP-GE-LH80-SM1550 |
1550 |
LC |
9/125, SMF |
80 km (49.71 miles) |
SFP-GE-LH80-SM1550-D |
1550 |
LC |
9/125, SMF |
SFP-GE-LH100-SM1550 |
1550 |
LC |
9/125, SMF |
100 km (62.14 miles) |
SFP-GE-T |
N/A |
RJ-45 |
Category 5 twisted pair cable |
100 m (328.08 ft) |
SFP-GE-T-D |
N/A |
RJ-45 |
100 m (328.08 ft) |
NOTE: · All 10G fiber ports on the NSQM2TG16A0 interface module support 1000 Mbps autosensing. · If you install an NSQM2TG16A0 interface module on SUBSLOT 2/4 of the device, the 10GBASE-R-SFP+ ports numbered 1 through 4 do not support 1000 Mbps autosensing. |
Table2-25 SFP+ transceiver modules available for the 10GBASE-R fiber ports
Model |
Connector type |
SFP-XG-SX-MM850-A |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-SX-MM850-D |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-SX-MM850-E |
850 |
LC |
50/125, MMF |
300 m (984.25 ft) |
SFP-XG-LX-SM1310 |
1310 |
LC |
9/125, SMF |
SFP-XG-LX-SM1310-D |
1310 |
LC |
9/125, SMF |
SFP-XG-LX-SM1310-E |
1310 |
LC |
9/125, SMF |
1550 |
LC |
9/125, SMF |
SFP-XG-LH40-SM1550-D |
1550 |
LC |
9/125, SMF |
Fan trays
The device provides two fan tray slots FAN1 and FAN2. The FAN-20B-2-A and FAN-20F-2-A fan trays are available for the device. To ensure adequate heat dissipation, you must install two fan trays of the same model before you power on the device.
FAN-20F-2-A
Figure2-9 FAN-20F-2-A fan tray view
(1) Handle |
(2) Alarm LED |
Table2-26 Technical specifications
Item |
Specification |
Dimensions (H × W × D), excluding the handles |
84.5 × 87 × 209 mm (3.33 × 3.43 × 8.23 in) |
Airflow direction |
Blows air from the power supply side to the port side |
Hot swapping |
Supported |
Max fan speed |
13300 R.P.M |
Maximum air flow rate |
120 CFM (3.40 m3/min) |
Max power consumption |
57 W |
Operating voltage |
12 V |
FAN-20B-2-A
Figure2-10 FAN-20B-2-A fan tray view
(1) Handle |
(2) Alarm LED |
Table2-27 Use FAN-20B-2-A fan tray specification
Item |
Specification |
Airflow direction |
Draws air from the port side to the power supply side |
Hot swapping |
Supported |
Max fan speed |
13300 R.P.M |
57 W |
Operating voltage |
12 V |
Hard disks
Table2-28 Hard disk specifications
Hard disk model |
Weight |
Capacity |
Power consumption |
Hot swapping |
NS-SSD-480G-SATA-SFF |
19.0 × 76 × 119 mm (0.75 × 2.99 × 4.69 in) |
0.07 kg (0.15 lb) |
480 GB |
1.5 W to 3 W |
Not supported |
Power supplies
The device comes with three power supply slots installed with filler panels and one power supply slot empty. The device supports AC, DC, and HVDC power supplies and power supply redundancy. If you install more than one power supply on the device, you can hot swap the redundant power supplies. To install multiple power supplies for the device, make sure they are the same model.
AC power supply
The PSR650B-12A1 is a removable power supply that supports AC input and DC output. It provides a maximum output of 650 W. The product code of the power supply is PSR650B-12A1.
Table2-29 PSR650B-12A1 power supply features
Feature |
Protection function |
The power supply provides protection against input overcurrent, input undervoltage, output overvoltage, output shortcircuit, and overtemperature conditions. |
Support for redundancy |
Two power supplies can be connected in parallel to achieve 1+1 redundancy and load balancing. |
Support for hot swapping |
You can remove one of the power supplies in 1+1 redundancy when the device is operating. |
Figure2-11 PSR650B-12A1 power supply
(1) Latch |
(2) Status LED |
(3) AC power input receptacle |
(4) Handle |
Table2-30 Technical specifications
Item |
Specification |
Model |
PSR650B-12A1 |
Rated AC input voltage range |
100 VAC to 240 VAC @ 50 or 60 Hz |
Output voltage |
12 V |
Max output current |
52.9 A (12 V) |
Max output power |
650 W |
40.2 × 51 × 300 mm (1.58 × 2.01 × 11.81 in) |
Net weight |
0.96 kg (2.12 lb) |
DC power supply
The PSR650B-12D1 power supply supports DC input and DC output. It provides a maximum output of 650 W. The product code of the power supply is PSR650B-12D1.
Table2-31 PSR650B-12D1 power supply features
Feature |
Figure2-12 PSR650B-12D1 power supply
(1) Latch |
(2) Status LED |
(3) DC power input receptacle |
(4) Handle |
Table2-32 Technical specifications
Item |
Specification |
Model |
PSR650B-12D1 |
Rated input voltage range |
–40 VDC to –60 VDC |
Output voltage |
5 VDC |
3 A (5 V) |
Max output power |
650 W |
Net weight |
0.96 kg (2.12 lb) |
HVDC power supply
The PSR650B-12AHD-F is an HVDC power supply that supports AC input, HVDC input (240 VDC or 336 VDC), and DC output. It provides a maximum output of 650 W.
Table2-33 PSR650B-12AHD-F power supply features
Feature |
Multiple power supplies can be connected in parallel to achieve redundancy and load balancing. |
You can remove one of the power supplies in redundancy when the device is operating. |
Figure2-13 PSR650B-12AHD-F power supply
(1) Latch |
(2) Status LED |
(3) Input receptacle |
(4) Handle |
Table2-34 Technical specifications
Item |
Specification |
Model |
PSR650B-12AHD-F |
· AC input: 100 VAC to 240 VAC @ 50 or 60 Hz · HVDC input: 240 VDC to 380 VDC |
Output voltage |
12 V/5 V |
52.9 A (12 V)/3 A (5 V) |
Max output power |
650 W |
Net weight |
0.96 kg (2.12 lb) |
AC power cord specifications
AC power cords are used for connecting the AC power supplies of the device to the external AC power supply system.
Table2-35 AC power cords supported by the device
AC power cord code |
Cable length |
Wire diameter |
Cable type |
04041104 |
3 m (9.84 ft) |
3 mm2 (0.0047 in2) |
AC power cord |
Connects a PSR650B-12A1 AC power supply |
DC power cords are used for connecting the DC power supplies of the device to the external DC power supply system.
Table2-36 DC power cords supported by the device
DC power cord code |
Cable length |
Wire diameter |
Cable type |
0404A0DG |
3 m (9.84 ft) |
DC power cord |
Connects a PSR650B-12D1 DC power supply |
NOTE: Power plug specifications vary by country or region. Select a compatible power cord that matches the required plug specification. For power plugs required by different countries or regions, see H3C Power Cords & Cables User Guide. |
HVDC power cords are used for connecting the HVDC power supplies of the device to the external AC or HVDC power supply system. No HVDC power cords are provided with the power suppply. Prepare them yourself as required.
Table2-37 HVDC power cords supported by the device
HVDC power cord code |
Cable length |
Wire diameter |
Cable type |
0404A0TA |
3 m (9.84 ft) |
HVDC power cord |
Used for AC or HVDC power supply |
0404A0TC |
3 m (9.84 ft) |
PDU AC power cord |
Used for AC power supply |
0404A0TD |
3 m (9.84 ft) |
AC power cord |
For information about the transceiver modules available for the modules, see "Modules."
3 LEDs
The device provides a variety of LEDs. The LED status indicates the operating status of the device.
SEM LEDs
The SEM provides multiple LEDs to indicate the operating status of the modules, fan trays, and power supplies. For the LED status and description, see Table3-1.
LED |
Mark |
Status |
LINK/ACT |
Flashing |
A link is present, and the port is sending or receiving data. |
On |
A link is present on the port. |
Off |
No link is present on the port. |
PWR |
Steady green |
All power supplies in the chassis are operating correctly. |
Steady red |
A power supply in the chassis does not have power output, because the power supply is faulty, the power supply is not powered on, the power cable is faulty, or the external power supply system has a power outage. |
Off |
The following are the possible causes: · No power supplies exist in the chassis. · No power supplies in the chassis have power output, because the power supplies are faulty, the power supplies are not powered on, the power cables are faulty, or the external power supply system has a power outage. |
FAN |
Steady green |
All fan trays are present and operating correctly. |
Steady red |
A fan tray has failed or is not present. |
Off |
The device is not powered on. |
Module status LED |
SYS SUBSLOT |
Flashing green |
The module in the corresponding slot is operating correctly. |
Steady green |
The module in the corresponding slot is starting up. |
Steady red |
The module in the corresponding slot is faulty. |
Flashing red |
The temperature of the module in the corresponding slot is abnormal. The temperature is higher than the upper temperature threshold or lower than the lower temperature threshold. |
Off |
No module is available in the corresponding slot. |
System status LED |
SLOT (SYS) |
Fast flashing green (4 Hz) |
The system is loading software from the SEM. |
Slowly flashing green (0.5 Hz) |
The system is operating correctly. |
Steady green |
The system is starting up. |
Steady red |
The system is faulty. |
Flashing red |
The temperature of the system is abnormal. The temperature is higher than the upper temperature threshold or lower than the lower temperature threshold. |
Off |
SEM status LED |
SLOT (SUP) |
Flashing green |
The SEM in the corresponding slot is operating correctly. |
Steady green |
The SEM in the corresponding slot is starting up. |
Steady red |
The SEM in the corresponding slot is faulty. |
Flashing red |
The temperature of the SEM in the corresponding slot is abnormal. The temperature is higher than the upper temperature threshold or lower than the lower temperature threshold. |
Off |
The SEM in the corresponding slot is not present. |
ACTIVE |
On |
The SEM is in active state. |
Off |
The following are the possible causes: · The SEM is in standby state. · The SEM has failed. To identify the failure, see the module status LED description. |
Service module LEDs
The service module provides CPU status LEDs and management Ethernet port LEDs to indicate its operating status. For the LED status and description, see Table3-2 and Table3-3.
Table3-2 NS-ADEEMPA0/NS-ADEEMPB0/NS-ADEEMPC0/NS-ADEEMPC1 service module LED description
LED |
Mark |
Status |
CPU status LED |
RUN/ALM |
Slowly flashing green (1 Hz) |
The CPU is operating correctly. |
The CPU is loading software. |
Off |
The CPU is not operating. |
N/A |
· LINK: On · ACT: Flashing |
· LINK: On · ACT: Off |
· LINK: Off · ACT: Off |
Table3-3 NS-ADEGMFAMA0 service module LED description
LED |
Mark |
Status |
CPU status LED |
RUN/ALM |
Slowly flashing green |
Fast flashing green |
Steady red |
The CPU is faulty. |
Off |
N/A |
Steady green |
Flashing green |
Off |
Interface module LEDs
The device supports multiple interface module models, and the type and quantity of LEDs vary by interface module model.
10G fiber port LED
An interface module that has 10G fiber ports provides a LED for each 10G fiber port to indicate their operating status.
Table3-4 10G fiber port LED description
LED status |
Flashing |
The port is sending or receiving data. |
On |
Off |
40G fiber port LED
An interface module that has 40G fiber ports provides a LED for each 40G fiber port to indicate their operating status.
Table3-5 40G fiber port LED description
LED status |
Flashing |
On |
Off |
Fan tray alarm LEDs
Table3-6 Fan tray alarm LED description
LED status |
On |
The fan tray is operating incorrectly. |
Off |
The fan tray is operating correctly. |
Power supply LEDs
Table3-7 Power supply LED description
LED status |
Steady green |
The power supply is operating correctly and is in active state. |
Flashing green |
The power supply is operating correctly and is in standby state. |
Steady red |
The power supply has failed or has entered a protection state. |
Alternating between red and green |
An alarm has occurred when one of the following conditions exists on the power supply but the power supply does not enter protection state: · Output overvoltage. · Output undervoltage. · Output overcurrent. · Output power overload. · Overtemperature. |
Flashing red |
The power supply does not have power input, but other power supplies have correct power input. |
Off |
All power supplies do not have power input. |
4 Installing the device
This document covers the views and specifications of the device and removable components, slots, interface numbering, and LEDs. For more information about the installation method and procedure, see the installation guide for the product.
· To mount the device in a standard 19-inch rack, make sure the rack meets the requirements described in Table4-1.
· To install multiple devices, ensure a distance of 1 RU (44.45 mm, or 1.75 in) between neighbor devices.
· The device is heavy. Install both mounting brackets and slide rails to support the weight of the device.
· To avoid bodily injury or device damage, use a minimum of two persons to rack-mount the device.
Table4-1 Recommended rack dimensions
Device model |
Device dimensions |
Rack requirements |
L5000-AD920 |
· Height—88.1 mm (3.47 in) · Width—440 mm (17.32 in) · Total depth—775.5 mm (30.53 in) ¡ 660 mm (25.98 in) for the chassis ¡ 90 mm (3.54 in) for the cable management bracket at the chassis front ¡ 25.5 mm (1.00 in) for the power supply handle at the chassis rear |
· A minimum of 1 m (3.28 ft) in depth (recommended) · A minimum of 100 mm (3.94 in) between the front rack posts and the front door · A minimum of 760 mm (29.92 in) between the front rack posts and the rear door · 518 mm (20.39 in) to 923 mm (36.34 in) from the front rack posts to the rear rack posts |
