| Title | Size | Downloads |
| H3C CR16000-F Routers CE1 Subcard Datasheet-5W103-book.pdf | 163.78 KB |
| book | 163.78 KB |
H3C CR16000-F Series |
CE1 Subcard Datasheet |
Copyright © 2015 to 2022 New H3C Technologies Co., Ltd. All rights reserved.
Overview
The following CE1 subcards are available for the CR16000-F routers.
Table 1 CE1 cards available for the CR16000-F routers
Card model |
MIC-ET16L |
16-port E1 electrical interface card (HM96 male connector) |
Key features
Channelized ports
An E1 port on the MIC-ET16L can operate in either channelized or unchannelized mode. When operating in unchannelized mode, each E1 port provides a bandwidth of 2.048 Mbps. When operating in channelized mode, each E1 port is subdivided into 32 timeslots (64 kbps per timeslot). Each timeslot can be used as a logical interface and supports timeslot bundling.
MP-group supported
Each MIC-ET16L subcard supports 16 MP-groups. Each MP-group contains up to 16 ports.
An MP-group can be used as a logical interface to carry the traffic of various services, providing multiple options for bandwidth and line selection.
Specifications
The figures in this section are for illustration only.
Front panel
Figure 2 MIC-ET16L front panel
(1) E1-HM96 Ethernet copper ports (16 in total) |
(2) Port status LED |
Technical specifications
Item |
Specifications |
Dimensions (H × W × D) |
18 × 165 × 142 mm (0.71 × 6.50 × 5.59 in) |
Power consumption |
8.6 W to 8.7 W |
Ports |
16 |
Connector type |
HM96 male connector |
Port speed |
E1 |
Transmission medium and max transmission distance |
For more information, see Table 3. |
LEDs
Table 2 E1-HM96 copper port status LED description
Status |
Flashing green |
The port is sending or receiving data. |
Steady green |
A link is present. |
Steady red |
An alarm has occurred. |
Off |
No link is present. |
Transceiver modules and cables
The MIC-ET16L subcard provides HM96 male connector with E1 port. Use different cables for conversion from HM96 to RJ-45, BNC or SMB as needed.
Table 3 E1 port cable types
Model |
SR0M7CAB1 |
HM96 E1 cable, 75 ohm, BNC, 3 m (9.84 ft) |
SR0M7CAB2 |
HM96 E1 cable, 120 ohm, RJ-45, 3 m (9.84 ft) |
SR0M7CAB3 |
HM96 E1 cable, 75 ohm, SMB, 3 m (9.84 ft) |
Environment requirements
Make sure the ambient environment meets the following requirements:
· Temperature and humidity requirements
Table 4 Temperature and humidity requirements
Item |
Specifications |
Operating temperature |
0°C to 45°C (32°F to 113°F) |
Storage temperature |
–40°C to +70°C (–40°F to +158°F) |
Operating humidity |
10% RH to 95% RH, non-condensing |
Storage humidity |
5% RH to 95% RH, non-condensing |
· Dust protection requirements
Table 5 Dust concentration limits in the equipment room
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
· Corrosive gas protection requirements
Table 6 Corrosive gas concentration limits in the equipment room
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
