- Released At: 30-05-2023
- Page Views:
- Downloads:
Intelligent Management Center |
WSM Dashboard Monitor Configuration Examples |
Document version: 5W100-20230529
Software version: IMC WSM 7.3 (E0505)
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved. No part of this manual may be reproduced or transmitted in any form or by any means without prior written consent of New H3C Technologies Co., Ltd. The information in this document is subject to change without notice. |
Example: Using WSM dashboard to monitor wireless services
Setting dashboard view parameters
Adding wireless service widgets
Introduction
This document provides examples for using WSM dashboard to monitor wireless services.
WSM provides wireless service data in the dashboard in real time to provide support for network analysis and operation decisions.
Before you use the dashboard to monitor wireless services, complete the following tasks:
· Create a WLAN to be monitored. Make sure the routes are reachable.
· Add wireless devices to WSM.
As shown in Figure 1, use WSM dashboard to monitor wireless services in an office building.
Analysis
To use WSM dashboard to monitor wireless services, complete the following tasks:
1. Configure a dashboard view to add widgets.
2. Open the dashboard to monitor wireless services in real time.
3. Analyze the wireless services based on the monitoring result.
Software versions used
This configuration example was created and verified on the following software versions:
· IMC PLAT 7.3 (E0504P04).
· IMC WSM 7.3 (E0505).
Procedures
Adding a dashboard view
1. Log in to IMC.
2. Click the icon at the
top right of the IMC home page.
3. From the navigation tree, select Dashboard > Configuration, as shown in Figure 2.
The dashboard configuration window appears, as shown in Figure 3.
Figure 3 Dashboard configuration window
4. Click the icon in the Grid Properties
area.
The Add View window appears, as shown in Figure 4.
5. Enter WLAN in the View Name field.
6. Click OK.
NOTE: An operator can add a maximum of 10 dashboard views. |
· In the Grid Properties area, set the following parameters as needed, as shown in Figure 5:
¡ Enter Wireless Service Monitor in the Title field.
¡ Use the default value 45 for the Title Size field.
¡ Use the default color for the Title Color field.
¡ The values of the Screen Width (PT) and Screen Height (PT) fields are automatically populated based on the computer resolution. In this example, the values are 1440 and 900, respectively. You can modify the values. The system automatically modifies the number of grids after you modify the values.
¡ Enter 3 in the Scroll Region Height field, which indicates that the height of the scroll region is the sum of the heights of three grids.
¡ Enter 4 in the Scroll Number field, which indicates that four widgets are deployed in the scroll region.
¡ Enter 4 in the Scroll Unit Column field, which indicates that the column of each widget occupies four grids.
¡ Use the default value 10 for the Scroll Interval(Second) field.
¡ Set the displaying order for the view in the Sortable view index field. If multiple views exist, the views will be displayed in the specified order.
· In the Global Settings area, you can select Switch Views to enable automatic view switching at the specified interval.
· In the View Management area, you can click
the switching icons or
to configure different
views. The switching action does not automatically save the current view
configuration. In this example, one view is configured.
You can use the scroll wheel to switch between different views when you display dashboard views.
Figure 5 Setting dashboard view parameters
1. In the Global Settings area, select Wireless LAN from the System Widgets list as shown in Figure 5. The Widget area will display only wireless service widgets.
2. In the Widget area, drag and drop widgets to the Scroll area and Panel area as needed, as shown in Figure 6:
a. Add the following widgets to the Scroll area:
- Wireless Alarm
- Client Count
- Rogue AP and Rogue Client
- Fit AP Model
b. Add the following widgets to the Panel area:
- Wireless Topology
- Resource Statistics
- Reasons for Association Failures - Today
- AP Bandwidth
3. Right-click a widget, and then select Preview from the shortcut menu to preview the monitor, as shown in Figure 7.
You can modify the number of grids occupied by the widgets or the location of the widgets based on the preview result in the panel area.
Setting widget parameters
You need to set widget parameters for some widgets. In this example, set widget parameters for the Wireless Topology widget.
To set widget parameters:
1. Right-click the Wireless Topology widget, and then select Configure Parameters from the shortcut menu.
The Add Location page appears.
2. Set the following parameters, as shown in Figure 8:
a. Select Floor from the Location Type list.
b. Select Canteen B1 from the Location Name list.
3. Click OK.
The canteen B1 wireless topology is displayed, as shown in Figure 9.
Figure 9 Canteen B1 wireless topology
Viewing the monitoring result
1. Point to the icon,
and then select Dashboard > WLAN from the shortcut menu.
The Wireless Service Monitor page appears, as shown in Figure 10.
Figure 10 Wireless Service Monitor
2. Right-click the Wireless Service Monitor page.
The Change Theme window appears, as shown in Figure 11.
3. Select a theme name.
Table 1 provides widgets and the wireless service each widget indicates.
Widget |
Displays information about alarm levels in bar charts. |
Displays the number of rogue APs and rogue clients detected by H3C fat APs and fit APs in bar charts. |
Displays the model name and proportion of fit APs in the WLAN in a pie chart. |
Displays the number of online clients in a time range. |
Displays the specified location view topology. |
Displays the trends of the send and receive rates of APs in a time range. |
Displays the number of alarms at each level for ACs, fit APs, and fat APs on the WLAN. The alarm information automatically changes every 5 seconds in the order of AC, fit AP, and fat AP. |
Displays the proportion of reasons for client association failures from 00:00 to the current time in bar charts. |
Analyzing the WLAN
You can analyze the running status of the WLAN based on the monitoring result.
For example, the Resource Statistics widget shows that a critical alarm occurs for a fit AP, as shown in Figure 12. Then you can use the wireless topology to locate this fit AP, as shown in Figure 13.
As shown in Figure 14, if a large number of rogue APs and rogue clients exist on the WLAN, you need to check for attacks on the WLAN and locate the problem to ensure WLAN security.
Figure 14 Rogue AP and Rogue Client
