- 04-Network Connectivity
- 01-MAC address table commands
- 02-Ethernet link aggregation commands
- 03-VLAN commands
- 04-Loop detection commands
- 05-Spanning tree commands
- 06-LLDP commands
- 07-Layer 2 forwarding commands
- 08-Port isolation commands
- 09-PPP commands
- 10-ARP commands
- 11-IP addressing commands
- 12-DHCP commands
- 13-DHCPv6 commands
- 14-DNS commands
- 15-NAT commands
- 16-IP performance optimization commands
- 17-IPv6 basics commands
- 18-Basic IP routing commands
- 19-Static routing commands
- 20-IPv6 static routing commands
- 21-IGMP snooping commands
- 22-MLD snooping commands
15-NAT commands | 252.83 KB |
NAT commands
address
Use address to add an address range to a NAT address group.
Use undo address to remove an address range from a NAT address group.
address start-address end-address
undo address start-address end-address
No address ranges exist.
NAT address group view
start-address end-address: Specifies the start and end IP addresses of the address range. The end address must not be lower than the start address. If they are the same, the address range has only one IP address. You can specify a maximum of 65535 addresses in an IP address range.
A NAT address group is a set of address ranges. The source address in a packet destined for an external network is translated into an address in one of the address ranges.
You can specify a maximum of 65535 addresses in one command execution. Make sure the address ranges in a single NAT address group or in multiple NAT address groups do not overlap.
# Add address ranges to an address group.
[Sysname] nat address-group 2
[Sysname-address-group-2] address 10.1.1.1 10.1.1.15
[Sysname-address-group-2] address 10.1.1.20 10.1.1.30
nat address-group
display nat address-group
Use display nat address-group to display NAT address group information.
display nat address-group [ group-id ]
group-id: Specifies the ID of a NAT address group. The value range for this argument is 0 to 65535. If you do not specify the group-id argument, this command displays information about all NAT address groups.
# Display information about all NAT address groups.
<Sysname> display nat address-group
NAT address group information:
Totally 5 NAT address groups.
Address group ID: 1 Address group name: a
Port range: 1-65535
Address information:
Start address End address
202.110.10.10 202.110.10.15
Address group ID: 2
Port range: 1-65535
202.110.10.20 202.110.10.25
202.110.10.30 202.110.10.35
Address group ID: 3
Port range: 1024-65535
202.110.10.40 202.110.10.50
Address group ID: 4
Port range: 10001-65535
202.110.10.60 202.110.10.65
Address group ID: 6
Port range: 1-65535
# Display information about NAT address group 1.
<Sysname> display nat address-group 1
Port range: 1-65535
NAT address group information |
Information about the NAT address group |
Address group ID |
ID of the NAT address group. |
Totally n NAT address groups |
Total number of NAT address groups. |
Address group name |
Name of the NAT address group. If no address group name is configured, this field is not displayed. |
Port range |
Port range for public IP addresses. |
Address information |
Information about the IP addresses in the address group. For addresses added by using the address command: · Start address—Start IP address of an address range. If you do not specify a start address for the range, this field displays hyphens (---). · End address—End IP address of an address range. If you do not specify an end address for the range, this field displays hyphens (---). |
nat address-group
display nat alg
Use display nat alg to display the NAT ALG status for all supported protocols.
display nat alg
# Display the NAT ALG status for all supported protocols.
<Sysname> display nat alg
NAT ALG:
DNS : Enabled
FTP : Disabled
H323 : Disabled
ICMP-ERROR : Disabled
ILS : Disabled
MGCP : Disabled
NBT : Disabled
PPTP : Disabled
RTSP : Disabled
RSH : Disabled
SCCP : Disabled
SIP : Disabled
SQLNET : Disabled
TFTP : Disabled
XDMCP : Disabled
display nat all
display nat all
Use display nat all to display all NAT configuration information.
display nat all
# Display all NAT configuration information.
<Sysname> display nat all
Address group ID: 1:
Port range: 1-65535
Address group ID: 2:
Port range: 1-65535
Address group ID: 3:
Address group ID: 4:
Address group ID: 6:
Port range: 1-65535
NAT inbound information:
Totally 1 NAT inbound rules.
Interface: Vlan-interface20
ACL: 2038
Address group ID: 2
Add route: Y NO-PAT:Y Reversible: N
Rule name: abc
Priority: 1000
NAT counting: 0
Config status: Active
NAT outbound information:
Totally 2 NAT outbound rules.
Interface: Vlan-interface10
ACL: 2036
Address group ID: 1
Port-preserved: Y NO-PAT: N Reversible: N
Rule name: lee
Priority: 122
NAT counting: 0
Config status: Inactive
Reasons for inactive status:
The following items don't exist or aren't effective: ACL.
ACL: 2037
Address group ID: 1
Port-preserved: N NO-PAT: Y Reversible: Y
Rule name: rabbit
Priority: 100
NAT counting: 0
Static NAT mappings:
Totally 2 inbound static NAT mappings.
Net-to-net:
Global IP : 2.2.2.1 – 2.2.2.255
Local IP : 1.1.1.0
Netmask : 255.255.255.0
ACL : 3000
Reversible : Y
Rule name : green
Priority : 4
NAT counting : 0
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2001
Reversible : Y
Rule name : blue
Priority : 4
NAT counting : 0
Totally 2 outbound static NAT mappings.
Net-to-net:
Local IP : 1.1.1.1 - 1.1.1.255
Global IP : 2.2.2.0
ACL : 3000
Reversible : Y
Rule name : yellow
Priority : 5
NAT counting : 0
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2001
Reversible : Y
Rule name : pink
Priority : 6
NAT counting : 0
Interfaces enabled with static NAT:
Totally 2 interfaces enabled with static NAT.
NAT logging:
Log enable : Enabled(ACL 2000)
Flow-begin : Disabled
Flow-end : Disabled
Flow-active : Enabled(10 minutes)
Port-block-assign : Disabled
Port-block-withdraw : Disabled
Alarm : Disabled
NO-PAT IP usage : Disabled
NAT mapping behavior:
Mapping mode : Endpoint-Independent
ACL : 2050
NAT ALG:
DNS : Enabled
FTP : Disabled
H323 : Enabled
ICMP-ERROR : Enabled
ILS : Enabled
MGCP : Enabled
NBT : Enabled
PPTP : Enabled
RSH : Enabled
RTSP : Enabled
SCCP : Enabled
SIP : Disabled
SQLNET : Enabled
TFTP : Enabled
XDMCP : Enabled
The output shows all NAT configuration information. Table 2 describes only the fields for the output of the nat alg command.
Information about the NAT address group. See Table 1 for output description. |
NAT inbound information: |
Inbound dynamic NAT configuration. See Table 4 for output description. |
NAT outbound information |
Outbound dynamic NAT configuration. See Table 7 for output description. |
Static NAT mappings |
Static NAT mappings. See Table 9 for output description. |
NAT logging |
NAT logging configuration. See Table 5 for output description. |
NAT counting |
Number of times the NAT rule is matched. |
NAT mapping behavior |
Mapping behavior mode of PAT: Endpoint-Independent or Address and Port-Dependent. |
ACL |
ACL number or name. If no ACL is specified for NAT, this field displays hyphens (---). |
Config status |
Status of the NAT mapping behavior configuration: Active or Inactive. |
Reasons for inactive status |
Reasons why the NAT mapping behavior configuration does not take effect. This field is available when the Config status is Inactive. |
NAT ALG |
NAT ALG configuration for different protocols. |
display nat eim
Use display nat eim to display information about NAT Endpoint-Independent Mapping (EIM) entries.
display nat eim
EIM entries are created when PAT operates in EIM mode. An EIM entry is a 3-tuple entry, and it records the mapping between a private address/port and a public address/port.
The EIM entry provides the following functions:
· The same EIM entry applies to subsequent connections initiated from the same source IP and port.
· The EIM entries allow reverse translation for connections initiated from external hosts to internal hosts.
# Display information about NAT EIM entries.
<Sysname> display nat eim
Slot 0:
Local IP/port: 192.168.100.100/1024
Global IP/port: 200.100.1.100/2048
Protocol: TCP(6)
Local IP/port: 192.168.100.200/2048
Global IP/port: 200.100.1.200/4096
Protocol: UDP(17)
Total entries found: 2
Protocol |
Protocol name and number. |
Total entries found |
Total number of EIM entries. |
nat mapping-behavior
nat outbound
display nat inbound
Use display nat inbound to display inbound dynamic NAT configuration.
display nat inbound
# Display inbound dynamic NAT configuration.
<Sysname> display nat inbound
Totally 2 NAT inbound rules.
ACL: 2038
Address group ID: 2
Add route: Y NO-PAT: Y Reversible: N
Rule name: abcd
Priority: 1000
NAT counting: 0
NAT inbound information |
Information about inbound dynamic NAT configuration. |
Totally n NAT inbound rules |
Total number of inbound dynamic NAT rules. |
Interface where the inbound dynamic NAT rule is configured. |
ACL |
ACL number or name. |
Address group ID |
ID of the NAT address group used by the inbound dynamic NAT rule. |
Add route |
Whether to add a route when a packet matches the inbound dynamic NAT rule: · Y—Adds a route. · N—Does not add a route. |
NO-PAT |
Whether NO-PAT or PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
Whether reverse address translation is allowed: · Y—Reverse address translation is allowed. · N—Reverse address translation is not allowed. |
Rule name |
Name of the NAT rule. |
Priority |
Priority of the NAT rule. |
NAT counting |
Config status |
Status of the inbound dynamic NAT rule: Active or Inactive. |
Reasons why the inbound dynamic NAT rule does not take effect: This field is available when the Config status is Inactive. |
nat inbound
display nat log
Use display nat log to display NAT logging configuration.
display nat log
# Display NAT logging configuration.
<Sysname> display nat log
NAT logging:
Flow-end : Disabled
Alarm : Disabled
NAT logging |
NAT logging configuration. |
Log enable |
Enabling status of NAT logging. If an ACL is specified for NAT logging, this field also displays the ACL number or name. |
Flow-begin |
Enabling status of logging for NAT session establishment events. |
Flow-end |
Enabling status of logging for NAT session removal events. |
Flow-active |
Enabling status of logging for active NAT flows. If it is enabled, this field also displays the interval in minutes at which active flow logs are generated. |
Port-block-assign |
This field is not supported in the current software version. Enabling status of NAT444 user logging for port block assignment. |
Port-block-withdraw |
This field is not supported in the current software version. Enabling status of NAT444 user logging for port block withdrawal. |
Alarm |
This field is not supported in the current software version. Enabling status of logging for NAT alarms. |
nat log enable
nat log flow-active
nat log flow-begin
display nat no-pat
Use display nat no-pat command to display information about NAT NO-PAT entries.
display nat no-pat
Default user roles
A NO-PAT entry records the mapping between a private address and a public address.
The NO-PAT entry provides the following functions:
· The same entry applies to subsequent connections initiated from the same source IP address.
· The NO-PAT entries allow reverse translation for connections initiated from external hosts to internal hosts.
Outbound and inbound NO-PAT address translations create their own NO-PAT tables. These two types of tables are displayed separately.
# Display information about NO-PAT entries for all cards.
<Sysname> display nat no-pat
Slot 0:
Global IP: 200.100.1.100
Local IP: 192.168.100.100
Reversible: N
Type : Inbound
Local IP: 192.168.100.200
Global IP: 200.100.1.200
Reversible: Y
Type : Outbound
Table 6 Command output
Global IP |
Public IP address. |
Local IP |
Private IP address. |
Reversible |
Type |
Type of the NO-PAT entry: · Inbound—A NO-PAT entry created during inbound dynamic NAT. · Outbound—A NO-PAT entry created during outbound dynamic NAT. |
Total number of NO-PAT entries. |
nat inbound
nat outbound
display nat outbound
Use display nat outbound to display outbound dynamic NAT configuration.
# Display outbound dynamic NAT configuration.
<Sysname> display nat outbound
Address group ID: 1
Rule name: acdefg
Priority: 1000
NAT counting: 0
ACL: 2037
Address group ID: ---
Rule name: abefg
Priority: 1000
NAT counting: 0
ACL: 2100
Address group ID: 2
Port-preserved: N NO-PAT: N Reversible: N
Priority: 0
NAT counting: 0
Information about outbound dynamic NAT configuration. |
Totally n NAT outbound rules |
Total number of outbound dynamic NAT rules. |
Interface where the outbound dynamic NAT rule is configured. |
ACL |
IPv4 ACL number or name. If no IPv4 ACL is specified for outbound dynamic NAT rule, this field displays hyphens (---). |
Address group ID |
ID of the address group used by the outbound dynamic NAT rule. If no address group is specified, the field displays hyphens (---). |
Port-preserved |
Whether to try to preserve the port numbers for PAT. · Y—Tries to preserve the port numbers. · N—Allows translating port numbers. |
NO-PAT |
Whether NO-PAT is used: · Y—NO-PAT is used. · N—PAT is used. |
Reversible |
Rule name |
Priority |
NAT counting |
Config status |
Status of the outbound dynamic NAT rule: Active or Inactive. |
Reasons why the outbound dynamic NAT rule does not take effect. This field is available when the Config status is Inactive. |
nat outbound
display nat session
Use display nat session to display NAT sessions.
display nat session [ [ responder ] { source-ip source-ip | destination-ip destination-ip } * ] [ verbose ]
responder: Displays NAT sessions by responder. If you do not specify this keyword, this command displays NAT sessions by initiator.
source-ip source-ip: Displays NAT sessions for the source IP address specified by the source-ip argument. The IP address must be the source IP address of the packet that triggers the session establishment.
destination-ip destination-ip: Displays NAT sessions for the destination IP address specified by the destination-ip argument. The IP address must be the destination IP address of the packet that triggers the session establishment.
verbose: Displays detailed information about NAT sessions. If you do not specify this keyword, this command displays brief information about NAT sessions.
If you do not specify any parameters, this command displays all NAT sessions.
# Display detailed information about NAT sessions.
<Sysname> display nat session verbose
Slot 0:
Initiator:
Source IP/port: 192.168.1.18/1877
Destination IP/port: 192.168.1.55/22
DS-Lite tunnel peer: -
Protocol: TCP(6)
Inbound interface: Vlan-interface10
Source security zone: SrcZone
Responder:
Source IP/port: 192.168.1.55/22
Destination IP/port: 192.168.1.10/1877
VPN instance/VLAN ID/VLL ID: -/-/-
Protocol: TCP(6)
Inbound interface: Vlan-interface20
Source security zone: DestZone
State: TCP_SYN_SENT
Application: SSH
Rule ID: -/-/-
Rule name:
Start time: 2011-07-29 19:12:36 TTL: 28s
Initiator->Responder: 1 packets 48 bytes
Responder->Initiator: 0 packets 0 bytes
Total sessions found: 1
Table 8 Command output
Initiator |
Session information about the initiator. |
Responder |
Session information about the responder. |
Source IP/port |
Source IP address and port number. |
Destination IP/port |
Destination IP address and port number. |
DS-Lite tunnel peer |
Destination address of the DS-Lite tunnel interface. If the session does not belong to any DS-Lite tunnel, this field displays a hyphen (-). |
VPN instance/VLAN ID/Inline ID |
The fields identify the following information: · VPN instance—MPLS L3VPN instance to which the session belongs. The VPN instance field is not supported in the current software version. · VLAN ID—VLAN ID to which the session belongs for Layer 2 forwarding. · Inline ID—INLINE to which the session belongs for Layer 2 forwarding. If no VPN instance, VLAN ID, or inline ID is specified, a hyphen (-) is displayed for the related field. |
Protocol |
Transport layer protocol type: DCCP, ICMP, Raw IP, SCTP, TCP, UDP, or UDP-Lite. |
Inbound interface |
Input interface. |
State |
NAT session status. |
Application |
Application layer protocol type, such as FTP and DNS. This field displays OTHER for the protocol types identified by non-well-known ports. |
Rule ID |
ID of the security policy rule. |
Rule name |
Name of the security policy rule. |
Start time |
Time when the session starts. |
TTL |
Remaining NAT session lifetime in seconds. |
Initiator->Responder |
Number of packets and packet bytes from the initiator to the responder. |
Responder->Initiator |
Number of packets and packet bytes from the responder to the initiator. |
Total sessions found |
Total number of sessions. |
reset nat session
display nat static
Use display nat static to display static NAT mappings.
display nat static
# Display static NAT mappings.
<Sysname> display nat static
Net-to-net:
Global IP : 1.1.1.1 - 1.1.1.255
Local IP : 2.2.2.0
ACL : 2000
Reversible : Y
NAT counting : 0
Rule name : abcdefg
Priority : 1000
IP-to-IP:
Global IP : 5.5.5.5
Local IP : 4.4.4.4
ACL : 2000
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
The following items don't exist or aren't effective: local VPN, global VPN, and ACL.
Net-to-net:
Global IP : 2.2.2.0
ACL : 2000
Reversible : Y
Rule name : abefg
Priority : 1000
NAT counting : 0
IP-to-IP:
Local IP : 4.4.4.4
Global IP : 5.5.5.5
ACL: : 2001
Reversible : Y
Rule name : abcd
Priority : 1000
NAT counting : 0
Information about static NAT mapping configuration. |
Totally n inbound static NAT mappings |
Total number of inbound static NAT mappings. |
Totally n outbound static NAT mappings |
Total number of outbound static NAT mappings. |
Net-to-net |
Net-to-net static NAT mapping. |
IP-to-IP |
One-to-one static NAT mapping. |
Local IP |
Private IP address or address range. |
Global IP |
Public IP address or address range. |
Netmask |
Network mask. |
ACL |
ACL number or name. If no ACL is specified, this field is not displayed. |
Reversible |
Whether reverse address translation is allowed. If reverse address translation is allowed, this field displays Y. If reverse address translation is not allowed, this field is not displayed. |
Interfaces enabled with static NAT |
Interfaces on which static NAT is enabled. |
Totally n interfaces enabled with static NAT |
Total number of interfaces where static NAT is enabled. |
Interface on which static NAT is enabled. |
Rule name |
Priority |
NAT counting |
Config status |
Status of the static NAT mapping: Active or Inactive. |
Reasons why the static NAT mapping does not take effect. This field is available when the Config status is Inactive. |
nat static enable
nat static inbound
nat static inbound net-to-net
nat static outbound
nat static outbound net-to-net
display nat statistics
Use display nat statistics to display NAT statistics.
display nat statistics [ summary ]
summary: Displays NAT statistics summary. If you do not specify this keyword, this command displays detailed NAT statistics.
# Display detailed information about NAT statistics.
<Sysname> display nat statistics
Slot 0:
Session creation rate: 0
Total session entries: 100
Total EIM entries: 1
Total inbound NO-PAT entries: 0
Total outbound NO-PAT entries: 0
Total static port block entries: 10
Total dynamic port block entries: 15
Active static port block entries: 0
Active dynamic port block entries: 0
Table 10 Command output
Total session entries |
Number of NAT session entries. |
Session creation rate |
Number of NAT sessions created per second. |
Total EIM entries |
Total inbound NO-PAT entries |
Total number of inbound NO-PAT entries. |
Total outbound NO-PAT entries |
Total number of outbound NO-PAT entries. |
Total static port block entries |
This field is not supported in the current software version. Total number of static NAT444 mappings. |
Total dynamic port block entries |
This field is not supported in the current software version. Total number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
Active static port block entries |
This field is not supported in the current software version. Number of static port block mappings that are in use. |
Active dynamic port block entries |
This field is not supported in the current software version. Number of dynamic port block mappings that have been created. It equals the number of dynamically assigned port blocks. |
# Display NAT statistics summary.
<Sysname> display nat statistics summary
EIM: Total EIM entries.
SPB: Total static port block entries.
DPB: Total dynamic port block entries.
ASPB: Active static port block entries.
ADPB: Active dynamic port block entries.
Slot Sessions EIM SPB DPB ASPB ADPB
0 100 1 10 15 0 0
Table 11 Command output
Sessions |
EIM |
Number of EIM entries. |
SPB |
This field is not supported in the current software version. Number of static NAT444 mappings. |
DPB |
This field is not supported in the current software version. Number of dynamic port block mappings that can be created. It equals the number of port blocks for dynamic assignment, including the assigned and unassigned port blocks. |
ASPB |
This field is not supported in the current software version. Number of static port block mappings in use. |
ADPB |
nat address-group
Use nat address-group to create a NAT address group and enter its view, or enter the view of an existing NAT address group.
Use undo nat address-group to delete a NAT address group.
nat address-group group-id [ name group-name ]
undo nat address-group group-id
No NAT address groups exist.
name group-name: Assigns a name to the NAT address group. The group-name argument is a case-sensitive string of 1 to 63 characters.
A NAT address group is a set of address ranges. Use the address command to add an address range to a NAT address group. Dynamic NAT translates the source IP address of a packet into an IP address in the address group.
# Create a NAT address group numbered 1 and named abc.
[Sysname] nat address-group 1 name abc
address
display nat all
nat inbound
nat outbound
nat alg
Use nat alg to enable NAT ALG for the specified or all supported protocols.
Use undo nat alg to disable NAT ALG for the specified or all supported protocols.
nat alg { all | dns | ftp | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sqlnet | tftp | xdmcp }
undo nat alg { all | dns | ftp | icmp-error | ils | mgcp | nbt | pptp | rsh | rtsp | sccp | sqlnet | tftp | xdmcp }
NAT ALG is enabled for DNS, FTP, ICMP error messages, RTSP, and PPTP, and is disabled for the other supported protocols.
all: Enables NAT ALG for all supported protocols.
dns: Enables NAT ALG for DNS.
ftp: Enables NAT ALG for FTP.
icmp-error: Enables NAT ALG for ICMP error packets.
ils: Enables NAT ALG for ILS.
mgcp: Enables NAT ALG for MGCP.
nbt: Enables NAT ALG for NBT.
pptp: Enables NAT ALG for PPTP.
rsh: Enables NAT ALG for RSH.
rtsp: Enables NAT ALG for RTSP.
sccp: Enables NAT ALG for SCCP.
sqlnet: Enables NAT ALG for SQLNET.
tftp: Enables NAT ALG for TFTP.
xdmcp: Enables NAT ALG for XDMCP.
NAT ALG translates address or port information in the application layer payload to ensure connection establishment.
For example, an FTP application includes a data connection and a control connection. The IP address and port number for the data connection depend on the payload information of the control connection. This requires NAT ALG to translate the address and port information to establish the data connection.
# Enable NAT ALG for FTP.
[Sysname] nat alg ftp
display nat all
nat icmp-error reply
Use nat icmp-error reply to enable sending ICMP error messages upon NAT failures.
Use undo nat icmp-error reply to restore the default.
No ICMP error messages are sent upon NAT failures.
Disabling sending ICMP error messages upon NAT failures reduces useless packets, saves bandwidth, and avoids exposing the device IP address to the public network.
This command is required for traceroute.
# Enable sending ICMP error messages upon NAT failures.
[Sysname] nat icmp-error reply
nat inbound
Use nat inbound to configure an inbound dynamic NAT rule.
Use undo nat inbound to delete an inbound dynamic NAT rule.
nat inbound { ipv4-acl-number | name ipv4-acl-name } address-group { group-id | name group-name } [ no-pat [ reversible ] [ add-route ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat inbound { ipv4-acl-number | name ipv4-acl-name }
No inbound dynamic NAT rules exist.
Interface view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999.
name ipv4-acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters. The ACL name must start with an English letter and to avoid confusion, it cannot be all.
address-group group-id: Specifies an address group for address translation.
group-id: Specifies the address group ID. The value range for this argument is 0 to 65535.
name group-name: Specifies the address group name, a case-insensitive string of 1 to 63 characters.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT supports only TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the internal network to the external network.
add-route: Automatically adds a route to the source address after translation. The output interface is the NAT interface and the next hop is the source address before translation.
rule rule-name: Specifies a name for the rule, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the rule does not have a name.
priority priority: Specifies a priority for the rule, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the rule has the lowest priority among the same type of NAT rules.
disable: Disables the inbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the inbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
counting: Enables NAT counting. The number of flows that use the address mapping is counted.
Inbound dynamic NAT translates the source IP addresses of incoming packets permitted by the ACL into IP addresses in the address group.
Inbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation.
· NO-PAT—Performs only IP address translation.
The NO-PAT mode supports reverse address translation. Reverse address translation uses ACL reverse matching to identify packets to be translated. ACL reverse matching works as follows:
· Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
· Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Inbound dynamic NAT typically cooperates with one of the following to implement bidirectional NAT:
· Outbound dynamic NAT (the nat outbound command).
· Outbound static NAT (the nat static command).
An address group cannot be used by both the nat inbound and nat outbound commands. It cannot be used by the nat inbound command in both PAT and NO-PAT modes.
Do not specify the add-route keyword if the subnets where the internal and external networks reside overlap. For other network scenarios:
· If you specify the add-route keyword, the device automatically adds a route to the source address after translation for a packet. The destination address is the NATed address in the NAT address group, the output interface is the interface where the command is executed, and the next hop is the source address before translation.
· If you do not specify the add-route keyword, you must manually add the route. As a best practice, add routes manually because automatic route adding is slow.
An ACL can be used by only one inbound dynamic NAT rule on an interface.
You can configure multiple inbound dynamic NAT rules on an interface.
Inbound dynamic NAT rules configured with the same priority value are matched by using their ACLs.
· NAT rules with named ACLs have higher priorities than NAT rules with unnamed ACLs.
· NAT rules with named ACLs are matched in alphabetical order of their ACL names.
· NAT rules with unnamed ACLs are matched in descending order of their ACL numbers.
# Configure ACL 2001 to permit packets only from subnet 10.110.10.0/24 to pass through.
[Sysname] acl basic 2001
[Sysname-acl-ipv4-basic-2001] rule permit source 10.110.10.0 0.0.0.255
[Sysname-acl-ipv4-basic-2001] rule deny
# Create address group 1 and add the address range of 202.110.10.10 to 202.110.10.12 to the group.
[Sysname-address-group-1] address 202.110.10.10 202.110.10.12
[Sysname-address-group-1] quit
# Configure an inbound NO-PAT rule on interface VLAN-interface 10. NAT translates the source addresses of incoming packets into the addresses in address group 1, and automatically adds routes for translated packets. Set the rule name to abc, and the priority to 0.
[Sysname-Vlan-interface10] nat inbound 2001 address-group 1 no-pat add-route rule abc priority 0
display nat all
display nat inbound
display nat no-pat
nat inbound rule move
Use nat inbound rule move to change the priority of an inbound dynamic NAT rule.
nat inbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the rule be moved.
after: Moves the rule nat-rule-name1 to the line after the rule nat-rule-name2 (called the reference rule). The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule plus one.
before: Moves the rule nat-rule-name1 to the line before the rule nat-rule-name2. The priority value of the reference rule is not changed. The priority value of the moved rule equals the priority value of the reference rule minus one.
nat-rule-name2: Specifies the name of the NAT rule as a reference rule for the NAT rule to be moved.
This command is applicable only to named inbound dynamic NAT rules.
A NAT rule appearing earlier on the rule list has a higher priority for packet matching.
# Move the inbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Vlan-interface10] nat inbound rule move abc before def
nat inbound
nat log alarm
Use nat log alarm to enable NAT alarm logging.
Use undo nat log alarm to disable NAT alarm logging.
nat log alarm
undo nat log alarm
NAT alarm logging is disabled.
Packets that need to be translated are dropped if the NAT resources are not enough. In NO-PAT, the NAT resources refer to the public IP addresses. In EIM PAT, the NAT resources refer to public IP addresses and ports. NAT alarm logging monitors the usage of NAT resources and outputs logs if the NAT resources are not enough.
Before configuring alarm logging for NAT, you must configure the custom NAT log generation and outputting features. For more information about information center, see System Management Configuration Guide.
This command take effect only after you use the nat log enable command to enable NAT logging.
# Enable NAT alarm logging.
[Sysname] nat log alarm
display nat all
display nat log
nat log enable
nat log enable
Use nat log enable to enable NAT logging.
Use undo nat log enable to disable NAT logging.
nat log enable [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat log enable
NAT logging is disabled.
acl: Specifies an ACL.
You must enable NAT logging before you enable NAT session logging or NAT alarm logging.
The acl keyword takes effect only for NAT session logging. If an ACL is specified, flows matching the permit rule might trigger NAT session logs. If you do not specify an ACL, all flows processed by NAT might trigger NAT session logs.
# Enable NAT logging.
[Sysname] nat log enable
display nat all
display nat log
nat log alarm
nat log flow-active
nat log flow-begin
nat log flow-end
nat log flow-active
Use nat log flow-active to enable logging for active NAT flows and set the logging interval.
Use undo nat log flow-active to disable logging for active NAT flows.
nat log flow-active time-value
Logging for active NAT flows is disabled.
time-value: Specifies the interval for logging active NAT flows, in the range of 10 to 120 minutes.
Active NAT flows are NAT sessions that last for a long time. The logging feature helps track active NAT flows by periodically logging the active NAT flows.
Logging for active NAT flows takes effect only after you enable NAT logging.
# Enable logging for active NAT flows and set the logging interval to 10 minutes.
[Sysname] nat log flow-active 10
display nat all
display nat log
nat log enable
nat log flow-begin
Use nat log flow-begin to enable logging for NAT session establishment events.
Use undo nat log flow-begin to disable logging for NAT session establishment events.
nat log flow-begin
Logging for NAT session establishment events is disabled.
Logging for NAT session establishment events takes effect only after you enable NAT logging.
# Enable logging for NAT session establishment events.
[Sysname] nat log flow-begin
display nat all
display nat log
nat log enable
nat log flow-end
Use nat log flow-end to enable logging for NAT session removal events.
Use undo nat log flow-end to disable logging for NAT session removal events.
nat log flow-end
Logging for NAT session removal events is disabled.
Logging for NAT session removal events takes effect only after you enable NAT logging.
# Enable logging for NAT session removal events.
[Sysname] nat log flow-end
display nat all
display nat log
nat log enable
nat mapping-behavior endpoint-independent
Use nat mapping-behavior endpoint-independent to specify the Endpoint-Independent Mapping (EIM) mode for PAT.
Use undo nat mapping-behavior to restore the default.
nat mapping-behavior endpoint-independent [ acl { ipv4-acl-number | name ipv4-acl-name } ]
undo nat mapping-behavior endpoint-independent
Address and Port-Dependent Mapping applies.
acl: Specifies an ACL to define the applicable scope of Endpoint-Independent Mapping.
PAT supports the following NAT mapping modes:
· Endpoint-Independent Mapping—Uses the same IP and port mapping (EIM entry) for packets from the same source and port to any destination. EIM allows external hosts to access the internal hosts by using the translated IP address and port. It allows internal hosts behind different NAT gateways to access each other.
· Address and Port-Dependent Mapping—Uses different IP and port mappings for packets with the same source IP and port to different destination IP addresses and ports. APDM allows an external host to access an internal host only under the condition that the internal host has previously accessed the external host. It is secure, but it does not allow internal hosts behind different NAT gateways to access each other.
This command takes effect only on outbound PAT. Address and Port-Dependent Mapping always applies to inbound PAT.
If you specify an ACL, Endpoint-Independent Mapping applies to packets that are permitted by the ACL. If you do not specify an ACL, Endpoint-Independent Mapping applies to all packets.
# Apply the Endpoint-Independent Mapping mode to all packets for address translation.
[Sysname] nat mapping-behavior endpoint-independent
# Apply the Endpoint-Independent Mapping mode to FTP and HTTP packets, and the Address and Port-Dependent Mapping mode to other packets for address translation.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 80
[Sysname-acl-ipv4-adv-3000] rule permit tcp destination-port eq 21
[Sysname] nat mapping-behavior endpoint-independent acl 3000
nat outbound
display nat eim
nat outbound
Use nat outbound to configure an outbound dynamic NAT rule.
Use undo nat outbound to delete an outbound dynamic NAT rule.
NO-PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] address-group { group-id | name group-name } no-pat [ reversible ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
undo nat outbound [ ipv4-acl-number | name ipv4-acl-name ]
PAT:
nat outbound [ ipv4-acl-number | name ipv4-acl-name ] [ address-group { group-id | name group-name } ] [ port-preserved ] [ rule rule-name ] [ priority priority ] [ disable ] [ description text ] [ counting ]
No outbound dynamic NAT rules exist.
Interface view
address-group: Specifies an address group for NAT. If you do not specify an address group, the IP address of the interface is used as the NAT address. Easy IP is used.
no-pat: Uses the NO-PAT mode. If you do not specify this keyword, PAT is used. PAT only supports TCP, UDP, and ICMP query packets. For an ICMP packet, the ICMP ID is used as its source port number.
reversible: Enables reverse address translation. Reverse address translation uses existing NO-PAT entries to translate the destination address for connections actively initiated from the external network to the internal network.
port-preserved: Tries to preserve port number for PAT.
disable: Disables the outbound dynamic NAT rule. If you do not specify this keyword, the rule is enabled.
description text: Specifies a description for the outbound dynamic NAT rule. The text argument is a case-insensitive string of 1 to 63 characters.
Outbound dynamic NAT is typically configured on the interface connected to the external network. You can configure multiple outbound dynamic NAT rules on an interface.
Outbound dynamic NAT supports the following modes:
· PAT—Performs both IP address translation and port translation. The PAT mode allows external hosts to actively access the internal hosts if the Endpoint-Independent Mapping behavior is used.
· NO-PAT—Performs only IP address translation. The NO-PAT mode allows external hosts to actively access the internal hosts if you specify the reversible keyword. If an ACL is specified, reverse address translation only applies to packets permitted by ACL reverse matching. ACL reverse matching works as follows:
¡ Compares the source IP address/port of a packet with the destination IP addresses/ports in the ACL.
¡ Translates the destination IP address of the packet according to the matching NO-PAT entry, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
When you specify a NAT address group, follow these restrictions and guidelines:
· An address group cannot be used by both the nat inbound and nat outbound commands.
· An address group cannot be used by the nat outbound command in both PAT and NO-PAT modes.
When you specify an ACL, follow these restrictions and guidelines:
· An ACL can be used by only one outbound dynamic NAT rule on an interface.
· If you specify an ACL, NAT translates the source IP addresses of outgoing packets permitted by the ACL into IP addresses in the address group. If you do not specify an ACL, NAT translates all packets.
· Outbound dynamic NAT rules with ACLs configured on an interface takes precedence over those without ACLs. If two ACL-based dynamic NAT rules are configured, the rule with the higher ACL number has higher priority.
Outbound dynamic NAT rules configured with the same priority value and an ACL are matched by using the ACLs in the rule.
# Configure an outbound dynamic PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1
[Sysname-Vlan-interface10] quit
Or
# Configure an outbound NO-PAT rule on interface VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat
Or
# Enable Easy IP to use the IP address of VLAN-interface 10 as the translated address.
[Sysname] interface Vlan-interface 10
Or
# Configure an outbound NO-PAT rule on VLAN-interface 10 to translate the source addresses of outgoing packets permitted by ACL 2001 into the addresses in address group 1. Enable reverse address translation.
[Sysname-Vlan-interface10] nat outbound 2001 address-group 1 no-pat reversible
display nat eim
nat outbound rule move
Use nat outbound rule move to change the priority of an outbound dynamic NAT rule.
nat outbound rule move nat-rule-name1 { after | before } nat-rule-name2
Interface view
nat-rule-name1: Specifies the name of the NAT rule to be moved.
This command is applicable only to named outbound dynamic NAT rules.
# Move the outbound dynamic NAT rule abc to the line before the rule def.
[Sysname-Vlan-interface10] nat outbound rule move abc before def
nat outbound
nat static enable
Use nat static enable to enable static NAT on an interface.
Use undo nat static enable to disable static NAT on an interface.
nat static enable
Static NAT is disabled.
Interface view
Static NAT mappings take effect on an interface only after static NAT is enabled on the interface.
# Configure an outbound static NAT mapping between private IP address 192.168.1.1 and public IP address 2.2.2.2, and enable static NAT on VLAN-interface 10.
[Sysname] nat static outbound 192.168.1.1 2.2.2.2
[Sysname-Vlan-interface10] nat static enable
display nat all
display nat static
nat static
nat static net-to-net
nat static inbound
Use nat static inbound to configure a one-to-one mapping for inbound static NAT.
Use undo nat static inbound to delete a one-to-one mapping for inbound static NAT.
nat static inbound global-ip local-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound global-ip local-ip
No NAT mappings exist.
global-ip: Specifies a public IP address.
local-ip: Specifies a private IP address.
acl: Specifies an ACL to identify the internal hosts that can access the external network.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP address.
rule rule-name: Specifies a name for the mapping, a case-sensitive string of 1 to 63 characters. It cannot contain backward slashes (\), forward slashes (/), colons (:), asterisks (*), question marks (?), left angle brackets (<), right angle brackets (>), vertical bars (|), quotation marks ("), or at signs (@). If you do not specify this option, the mapping does not have a name.
priority priority: Specifies a priority for the mapping, in the range of 0 to 2147483647. A smaller value represents a higher priority. If you do not specify this option, the mapping has the lowest priority among the same type of NAT rules.
disable: Disables the one-to-one inbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of a packet from the external network to the internal network matches the global-ip, the source IP address is translated into the local-ip. When the destination IP address of a packet from the internal network to the external network matches the local-ip, the destination IP address is translated into the global-ip.
· If you do not specify an ACL, the source address of all incoming packets and the destination address of all outgoing packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP address.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
¡ Translates the destination IP address of the packet according to the mapping, and then compares the translated destination IP address/port with the source IP addresses/ports in the ACL.
Static NAT takes precedence over dynamic NAT when both are configured on an interface.
You can configure multiple inbound static NAT mappings by using the nat static inbound command and the nat static inbound net-to-net command.
One-to-one mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
· Mappings with named ACLs have higher priorities than mappings with unnamed ACLs.
· Mappings with named ACLs are matched in alphabetical order of their ACL names.
· Mappings with unnamed ACLs are matched in descending order of their ACL numbers.
# Configure an inbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
[Sysname] nat static inbound 2.2.2.2 192.168.1.1
display nat all
display nat static
nat static enable
Use nat static inbound net-to-net to configure a net-to-net mapping for inbound static NAT.
Use undo nat static inbound net-to-net to remove a net-to-net mapping for inbound static NAT.
nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static inbound net-to-net global-start-address global-end-address local local-network { mask-length | mask }
global-start-address global-end-address: Specifies a public address range which can contain a maximum of 255 addresses. The global-end-address must not be lower than global-start-address. If they are the same, only one public address is specified.
local-network: Specifies a private network address.
mask-length: Specifies the mask length of the private network address, in the range of 8 to 31.
mask: Specifies the mask of the private network address.
reversible: Enables reverse address translation for connections actively initiated from the internal network to the private IP addresses.
disable: Disables the net-to-net inbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a public network through a start address and an end address, and a private network through a private address and a mask.
When the source address of a packet from the external network matches the public address range, the source address is translated into a private address in the private address range. When the destination address of a packet from the internal network matches the private address range, the destination address is translated into a public address in the public address range.
The public end address cannot be greater than the greatest IP address in the subnet determined by the public start address and the private network mask. For example, if the private address is 2.2.2.0 with a mask 255.255.255.0 and the public start address is 1.1.1.100, the public end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of incoming packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the internal network to the private IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of incoming packets permitted by the ACL is translated. If packets of connections actively initiated from the internal network to the private IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for inbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an inbound static NAT between public network address 202.100.1.0/24 and private network address 192.168.1.0/24.
[Sysname] nat static inbound net-to-net 202.100.1.1 202.100.1.255 local 192.168.1.0 24
display nat all
display nat static
nat static enable
nat static inbound rule move
Use nat static inbound rule move to change the priority of an inbound one-to-one static NAT rule.
nat static inbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command is applicable only to named inbound one-to-one static NAT rules.
# Move the inbound one-to-one static NAT rule abc to the line before the inbound one-to-one static NAT rule def.
[Sysname] nat static inbound rule move abc before def
nat static inbound
nat static outbound
Use nat static outbound to configure a one-to-one mapping for outbound static NAT.
Use undo nat static outbound to remove a one-to-one mapping for outbound static NAT.
nat static outbound local-ip global-ip [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound local-ip global-ip
acl: Specifies an ACL to define the destination IP addresses that internal hosts can access.
ipv4-acl-number: Specifies an ACL by its number in the range of 3000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP address.
disable: Disables the one-to-one outbound static mapping. If you do not specify this keyword, the mapping is enabled.
When the source IP address of an outgoing packet matches the local-ip, the IP address is translated into the global-ip. When the destination IP address of an incoming packet matches the global-ip, the destination IP address is translated into the local-ip.
· If you do not specify an ACL, the source address of all outgoing packets and the destination address of all incoming packets are translated.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP address.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP address are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Static NAT takes precedence over dynamic NAT when they are both configured on an interface.
You can configure multiple outbound static NAT mappings by using the nat static outbound command and the nat static outbound net-to-net command.
One-to-one mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between public IP address 2.2.2.2 and private IP address 192.168.1.1.
# Configure outbound static NAT, and allow the internal user 192.168.1.1 to access the external network 3.3.3.0/24 by using the public IP address 2.2.2.2.
[Sysname] acl advanced 3001
[Sysname-acl-ipv4-adv-3001] rule permit ip destination 3.3.3.0 0.0.0.255
[Sysname-acl-ipv4-adv-3001] quit
[Sysname] nat static outbound 192.168.1.1 2.2.2.2 acl 3001
display nat all
display nat static
nat static enable
Use nat static outbound net-to-net to configure a net-to-net outbound static NAT mapping.
Use undo nat static outbound net-to-net to remove the specified net-to-net outbound static NAT mapping.
nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask } [ acl { ipv4-acl-number | name ipv4-acl-name } [ reversible ] ] [ rule rule-name ] [ priority priority ] [ disable ] [ counting ]
undo nat static outbound net-to-net local-start-address local-end-address global global-network { mask-length | mask }
local-start-address local-end-address: Specifies a private address range which can contain a maximum of 255 addresses. The local-end-address must not be lower than local-start-address. If they are the same, only one private address is specified.
global-network: Specifies a public network address.
mask-length: Specifies the mask length of the public network address, in the range of 8 to 31.
mask: Specifies the mask of the public network address.
ipv4-acl-number: Specifies an ACL number in the range of 2000 to 3999.
reversible: Enables reverse address translation for connections actively initiated from the external network to the public IP addresses.
disable: Disables the net-to-net outbound static mapping. If you do not specify this keyword, the mapping is enabled.
Specify a private network through a start address and an end address, and a public network through a public address and a mask.
When the source address of a packet from the internal network matches the private address range, the source address is translated into a public address in the public address range. When the destination address of a packet from the external network matches the public address range, the destination address is translated into a private address in the private address range.
The private end address cannot be greater than the greatest IP address in the subnet determined by the private start address and the public network mask. For example, the public address is 2.2.2.0 with a mask 255.255.255.0, and the private start address is 1.1.1.100. The private end address cannot be greater than 1.1.1.255, the greatest IP address in the subnet 1.1.1.0/24.
· If you specify an ACL and do not specify the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. The destination address is not translated for connections actively initiated from the external network to the public IP addresses.
· If you specify both an ACL and the reversible keyword, the source address of outgoing packets permitted by the ACL is translated. If packets of connections actively initiated from the external network to the public IP addresses are permitted by ACL reverse matching, the destination address is translated. ACL reverse matching works as follows:
Net-to-net mappings for outbound static NAT that are configured with the same priority value and an ACL are matched by using the ACLs in the mappings.
# Configure an outbound static NAT mapping between private network address 192.168.1.0/24 and public network address 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24
# Configure outbound static NAT. Allow internal users on subnet 192.168.1.0/24 to access the external subnet 3.3.3.0/24 by using public IP addresses on subnet 2.2.2.0/24.
[Sysname] nat static outbound net-to-net 192.168.1.1 192.168.1.255 global 2.2.2.0 24 acl 3001
display nat all
display nat static
nat static enable
nat static outbound rule move
Use nat static outbound rule move to change the priority of an outbound one-to-one static NAT rule.
nat static outbound rule move nat-rule-name1 { after | before } nat-rule-name2
This command is applicable only to named outbound one-to-one static NAT rules..
# Move the outbound one-to-one static NAT rule abc to the line before the outbound one-to-one static NAT rule def.
[Sysname] nat static outbound rule move abc before def
nat static outbound
reset nat count statistics
Use reset nat count statistics to clear NAT counting statistics.
reset nat count statistics { all | dynamic | static }
all: Clears all counting statistics for NAT mappings.
dynamic: Clears counting statistics for dynamic NAT mappings.
static: Clears counting statistics for static NAT mappings.
# Clear all counting statistics for static NAT mappings.
<Sysname> reset nat count statistics all
display nat inbound
display nat static
reset nat session
Use reset nat session to clear NAT sessions.
# Clear all NAT sessions.
<Sysname> reset nat session
display nat session
