00-Preface | 100.51 KB |
Preface
This command reference describes the fundamentals feature configuration commands. It includes the following feature modules:
· CLI.
· FTP and TFTP.
· RBAC.
· File system management.
· Login management.
· Software upgrade.
· Configuration file management.
· Tcl.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
