- 12-WLAN Advanced Features Command Reference
- 01-Bonjour gateway commands
- 02-Hotspot 2.0 commands
- 03-WLAN mesh commands
- 04-Wireless location commands
- 05-WLAN process maintenance commands
- 06-WLAN fast forwarding commands
- 07-WLAN optimization commands
- 08-AC hierarchy commands
- 09-WSA commands
- 10-WLAN probe commands
- 11-WLAN forwarding commands
11-WLAN forwarding commands | 41.24 KB |
display wlan forward statistics
Use display wlan forward statistics to display WLAN forwarding statistics.
# Display WLAN forwarding statistics.
<Sysname> display wlan forward statistics
Discarded frames:
Forwarding type error : 5
Packet validity check fail : 7
Service module discard : 0
Packets only for listening : 0
BSS/station info get fail : 13
Radio info get fail : 0
Tunnel info get fail : 3
Memory/MBUF fail : 3
Roaming discard : 0
Adjacency list get fail : 0
CAPWAP validity check fail : 0
Format conversion fail : 0
Inside packet decode fail : 0
Encrypt/decrypt fail : 0
Radio fragment/reassemble fail : 6
CAPWAP fragment/reassemble fail : 5
Priority process fail : 0
QoS/IP forward fail : 0
MAC forward fail : 0
Radio forward fail : 0
Fast broadcast not support : 0
Fast broadcast success : 0
Forwarding type error |
Number of packets discarded because neither local forwarding nor centralized forwarding is used. |
Packet validity check fail |
Number of packets discarded because of validity check failure. |
Service module discard |
Number of packets discarded by the service module. |
Packets only for listening |
Number of packets only for packet listening. |
BSS/station info get fail |
Number of packets from which the system fails to get BSS or client information. |
Radio info get fail |
Number of packets from which the system fails to get radio information. |
Tunnel info get fail |
Number of packets from which the system fails to get tunnel information. |
Memory/MBUF fail |
Number of packets discarded because of memory or MBUF operation failure. |
Roaming discard |
Number of packets discarded because of roaming. |
Adjacency list get fail |
Number of packets from which the system fails to get the adjacency list. |
CAPWAP validity check fail |
Number of packets discarded because of CAPWAP validity check failure. |
Format conversion fail |
Number of packets discarded because of format conversion failure. |
Inside packet decode fail |
Number of packets discarded because of decoding failure. |
Encrypt/decrypt fail |
Number of packets discarded because of encryption or decryption failure. |
Radio fragment/reassemble fail |
Number of packets discarded because of radio fragmentation or reassembling failure. |
CAPWAP fragment/reassemble fail |
Number of packets discarded because of tunnel fragmentation or reassembling failure. |
Priority process fail |
Number of packets discarded because of priority processing failure. |
QoS/IP forward fail |
Number of packets discarded because of QoS or IP forwarding failure. |
MAC forward fail |
Number of packets discarded because of MAC forwarding failure. |
Radio forward fail |
Number of packets discarded because of radio forwarding failure. |
Fast broadcast not support |
Number of packets not supported by fast broadcast forwarding. |
Fast broadcast sucess |
Number of packets successfully transmitted by fast broadcast forwarding. |
reset wlan forward statistics
Use reset wlan forward statistics to clear WLAN forwarding statistics.
# Clear WLAN forwarding statistics.
<Sysname> reset wlan forward statistics
