- Released At: 27-04-2025
- Page Views:
- Downloads:
H3C Switches License Matrixes
Some of the features for the switches are license-based. To use these features, you must install licenses for them. This document provides information about the license-based features and licenses available for them. For information about registering, installing, or managing a license, see H3C Switches and Routers Licensing Guide.
Some switches support the license for the unified wired and wireless access controller feature. You can purchase licenses to add the number of APs to be managed. For more information, see H3C Comware 7 or 9 Wireless Products Licensing Guide.
IMPORTANT: License-based features and attributes of licenses might change with software version over time. This document contains information about only licenses for software versions shipped with the switches and some of the information might change over time. To obtain the most up-to-date information about licenses or information about licenses for software versions not listed in this document, contact your H3C sales representative or contact H3C Support. |
IMPORTANT: · Support for features in data center licenses and campus licenses varies by software version. · In the current software version, H3C switches support only formal licenses. Preinstalled licenses are not supported. · You can activate the licenses on the H3C switches from the CLI, from the Web interface, and remotely. Support for these methods varies by switch model and software version. · Support for licenses and license activation methods changes over time. For more information, contact your H3C sales representative or contact H3C Support. |
Table 1 H3C switches license matrix
Feature |
Supported products |
Formal licenses |
Start time of formal license validity period |
H3C S12500R HFR Ethernet Optical Interface Module 10G(SFP+) Port Activation License (one license per port) |
S12500R switch router series (installed with the LSXM1TGS48HFR1 module) S12500R switch router series (installed with the LSXM1MOD24KBR1 module and LSXM1TGS24C1 expansion interface module) |
Permanent |
Date and time when the activation file for the license is generated on the license management platform. |
H3C S12500R HFR Ethernet Optical Interface Module 40G(QSFP+) Port Activation License (one license per port) |
S12500R switch router series (installed with the LSXM1CGQ6QGHFR1 or LSXM1CGQ18QGHFR1 module) |
Permanent |
H3C S12500R KBR Ethernet Optical Interface Module 100G(QSFP28) Port Activation License (one license per port) H3C S12500R HFR Ethernet Optical Interface Module 100G(QSFP28) Port Activation License (one license per port) |
S12500R switch router series (installed with the LSXM1CGQ6QGHFR1 or LSXM1CGQ18QGHFR1 module) S12500R switch router series (installed with the LSXM1CGQ48KBR1, LSXM1CGQFX16KBR1, or LSXM1MOD24KBR1 module and LSXM1CGQ18C1 expansion interface module, or installed with the LSXM1MOD24KBR1 module and LSXM1CGQ8C1 expansion interface module) |
Permanent |
H3C S12500R Chassis-Wide HFR Ethernet Interface Module Ports Activation License (one license per device) |
S12500R switch router series (installed with the LSXM1TGS48HFR1, LSXM1CGQ6QGHFR1, or LSXM1CGQ18QGHFR1 module) |
Permanent |
H3C Advanced Data Center Licenses (including EVI, MDC, SPBM, TRILL, FCoE, EVB, and LISP) |
· S12500X-AF switch series (supported only in versions earlier than R3203) · S12500-X switch series (supported only in R1005P01 and later versions, excluding R1106 and R1109) · S9800 switch series (supported only in R2135 and later versions) · S10500 switch series (supported only in versions from R2105 to R7150) |
Permanent |
H3C Advanced Data Center Licenses (including EVI, SPBM, EVB, FCoE, and TRILL) |
· S6890 switch series (supported only in versions earlier than R3606) · S6800 switch series (supported only in R2609 and later versions) · S6860 and S6861 switch series · S5830V2 and S5820V2 switch series (supported only in R2208 and later versions) · S6300 and S6520-EI switch series |
Permanent |
H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches,3-Year 1-Device |
S9855/S9825 switch series (supported only in versions E9128 to E9129P02) |
Three years |
H3C Enhanced Lossless Ethernet Feature License for Fixed-Port Switches, 1 Device |
Permanent |
Date and time when the license code is first activated. |
H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches,1-Year 1-Device |
One year |
H3C-LIS-B-LOSSLESS-FL-H3C Enhanced Lossless Ethernet Feature License for Fixed-Port Switches,Device Count Configurable |
Permanent |
H3C-LIS-B-LOSSLESS-Y1-FL-H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches,1-Year and Device Count Configurable |
One year |
H3C-LIS-B-LOSSLESS-Y3-FL-H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches,3-Year and Device Count Configurable |
Three years |
H3C Advanced Campus Licenses (including EVI, MDC, SPBM, TRILL, FCoE, EVB, and LISP) |
· S12500X-AF switch series (supported only in versions earlier than R3203) · S12500-X switch series (supported only in R1005P01 and later versions, excluding R1106 and R1109) · S9800 switch series (supported only in R2135 and later versions) · S6890 switch series (supported only in versions earlier than R3606) · S10500 switch series (supported only in versions from R2105 to R7150) |
Permanent |
H3C S6850 Switch Intelligent Routing Characteristic License |
· S6805 switch series (supported only in E6705 and later versions) · S6825 switch series (supported only in E6705 and later versions) · S6850 switch series (supported only in E6705 and later versions) · S9850 switch series (supported only in E6705 and later versions) · S9820-64H switch (supported only in E6705 and later versions) |
Permanent |
· S6805 switch series (supported only in E6705 and later versions) · S6825 switch series (supported only in E6705 and later versions) · S6850 switch series (supported only in E6705 and later versions) · S9850 switch series (supported only in E6705 and later versions) · S9820 switch series (supported only in E6705 and later versions) |
Permanent |
Permanent |
H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches, 1-Year 1-Device |
One year |
One year |
Three years |
H3C Enhanced Lossless Ethernet Feature Subscription and Support License for Fixed-Port Switches, 3-Year and Device Count Configurable |
Three years |
H3C Enhanced Lossless Feature License for Modular Switches, 1 Device |
· S12500G-AF switch series (supported in versions R8053P05 to R8055P03) · S12500CR switch series (supported in versions R8053P07 to R8055P03) · S10500X-G switch series (supported only in versions earlier than R7755P03) |
Permanent |
H3C Enhanced Lossless Feature License for Modular Switches,Device Count Configurable |
Permanent |
H3C Enhanced Lossless Feature Subscription and Support License for Modular Switches(One Year),1 Device |
One year |
H3C Enhanced Lossless Feature Subscription and Support License for Modular Switches(One Year),Device Count Configurable |
One year |
H3C Enhanced Lossless Feature Subscription and Support License for Modular Switches(Three Years),1 Device |
Three years |
H3C Enhanced Lossless Feature Subscription and Support License for Modular Switches(Three Years),Device Count Configurable |
Three years |
H3C Modular Switch Upgrade From 2.5G to 5G Feature License,12 ports |
S10500X-G switch series (supported only in E7758P01 and later versions) |
Permanent |
H3C Modular Switch Upgrade From 2.5G to 5G Feature Flexible License,12 ports |
Permanent |
H3C Modular Switch Upgrade From 2.5G to 10G Feature License,12 ports |
Permanent |
H3C Modular Switch Upgrade From 2.5G to 10G Feature Flexible License,12 ports |
Permanent |
H3C Advanced Data Center Licenses (including MDC, EVI, EVB, FCoE, and TRILL) |
· S12500G-AF switch series · S10500X-G switch series · S10500X switch series · S10500 switch series (supported only in R7150 and later versions) · S7500E switch series (supported only in R7150 and later versions) · S7500E-X switch series · S7500X-G switch series (supported only in R7736P07 and later versions) · S7500X switch series |
Permanent |
H3C Advanced Campus Licenses (including MDC) |
· S12500G-AF switch series · S10500X switch series · S10500X-G switch series · S10500 switch series (supported only in R7150 and later versions) · S7500E switch series (supported only in R7150 and later versions) · S7500E-X switch series · S7500X-G switch series (supported only in R7736P07 and later versions) · S7500X switch series |
Permanent |
SDN Multicast NAT License |
· S6550XE-HI switch series · S12500G-AF switch series (supported only in R7595P02 and later versions) · S12500CR switch series (supported only in R8053P05 and later versions) · S10500X switch series (supported only in R7595P02 and later versions) · S10500X-G switch series · S10500 switch series (supported only in R7595P02 and later versions) · S7500X-G switch series (supported only in R7734P03 and later versions) |
Permanent |
Enhanced Access Controller License |
· S6550XE-HI switch series · S6520XE-HI switch series · S6520X-H and S6520X-EI switch series · S6520X-18C-SI, S6520X-26C-SI, S6520X-16ST-SI, S6520X-24ST-SI, S6520X-10XT-SI, S6520X-16XT-SI, S6520X-26XC-UPWR-SI, and S6520X-54XC-UPWR-SI switches · S6520-16S-SI and S6520-24S-SI switches · S5560X-HI and S5560X-EI switch series · S5560-EI switch series · S5500V2-EI switch series · S12500G-AF switch series · S10500X switch series · S10500X-G switch series · S10500 switch series (supported only in R7536 and later versions) · S9900X switch series · S7500E switch series (supported only in R7536 and later versions) · S7500E-X switch series (supported only in R7536 and later versions) · S7500X switch series (supported only in R7536 and later versions) · S7500X-G switch series (supported only in R7747P07 and later versions) |
Permanent |
H3C VS700 Comware 7 License, 6 Months The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
V6850-56HF vSwitch simulator |
180 days |
H3C VS900 Comware 9 License, 6 Months The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
V6890-54CDF vSwitch simulator |
180 days |
H3C VS700 Comware 7 License, 1 year (product code: LIS-VS700-Y1) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
One year |
H3C VS700 Comware 7 License, 1 year (product code: LIS-VS700-Y1-FL) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
One year |
H3C VS900 Comware 9 License, 1 year (product code: LIS-VS900-Y1) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
One year |
H3C VS900 Comware 9 License, 1 year (product code: LIS-VS900-Y1-FL) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
One year |
H3C VS700 Comware 7 License, 3 years (product code: LIS-VS700-Y3) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
Three years |
H3C VS700 Comware 7 License, 3 years (product code: LIS-VS700-Y3-FL) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
Three years |
H3C VS900 Comware 9 License, 3 years (product code: LIS-VS900-Y3) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
Three years |
H3C VS900 Comware 9 License, 3 years (product code: LIS-VS900-Y3-FL) The trial period before license installation depends on the software version. For more information, see the release notes or installation guide for the product. |
Three years |
NOTE: Formal license—A formal license can be installed, uninstalled, and transferred. To gain most from a license-based feature, purchase a formal license for it. For information about registering, installing, and managing a license, see H3C Switches and Routers Licensing Guide. When a formal license expires, the license-based feature becomes unavailable. To continue to use the feature, you must purchase and install a new formal license for it. |
