H3C LSWM18CQMSEC Interface Card User Manual-6PW106
HomeSupportInstall & UpgradeInstallation GuidesH3C LSWM18CQMSEC Interface Card User Manual-6PW106
Download Book
  • Released At: 13-06-2020
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C LSWM18CQMSEC interface card user manual-6PW106
Introduction
Overview
The LSWM18CQMSEC interface card provides eight QSFP28 ports. These QSFP28 ports support MACsec.
Figure 1 Front panel
(1) QSFP28 port LED
(2) QSFP28 port
QSFP28 ports
You can install the following transceiver modules and cables in the QSFP28 ports on the card:
·    QSFP28 transceiver modules described in Table 1 and Table 2
·    QSFP28 cables in Table 3
·    QSFP28 to SFP28 copper cables in Table 4
·    QSFP+ transceiver modules in Table 5 and Table 6
·    QSFP+ cables in Table 7
·    QSFP+ to SFP+ copper cables in Table 8
Table 1 QSFP28 transceiver modules available for the QSFP28 ports (1)
Central wavelength (nm)
Connector
QSFP-100G-ER4L-WDM1300
Four lanes:
·     1294.531296.59
·     1299.021301.09
·     1303.541305.63
·     1308.091310.19
LC
QSFP-100G-SR4-MM850
850
MPO (PC polished, 12-fiber)
QSFP-100G-PSM4-SM1310
12951325
MPO (APC polished, 12-fiber)
QSFP-100G-LR4-WDM1300
Four lanes:
·   1295
·   1300
·   1304
·   1309
LC
QSFP-100G-LR4L-WDM1300
Four lanes:
·   1264.51277.5
·   1284.51297.5
·   1304.51317.5
·   1324.51337.5
LC
QSFP-100G-SWDM4-MM850
Four lanes:
·     850
·     880
·     910
·     940
LC
Table 2 QSFP28 transceiver modules available for the QSFP28 ports (2)
Cable/fiber diameter (µm)
Modal bandwidth (MHz × km)
Max transmission distance
Single-mode, 9/125
N/A
40 km (24.85 miles)
QSFP-100G-SR4-MM850
Multi-mode, 50/125
2000
70 m (229.66 ft)
4700
100 m (328.08 ft)
Single-mode, 9/125
N/A
0.5km (0.31 miles)
Single-mode, 9/125
N/A
10 km (6.21 miles)
Single-mode, 9/125
N/A
2km (1.24 miles)
Multi-mode, 50/125
2000
75 m (246.06 ft)
4700
100 m (328.08 ft)
Table 3 QSFP28 cables available for the QSFP28 ports
Cable model
Cable length
Data rate
QSFP28 copper cable
QSFP-100G-D-CAB-1M
1 m (3.28 ft)
100 Gbps
QSFP-100G-D-CAB-3M
3 m (9.84 ft)
QSFP-100G-D-CAB-5M
5 m (16.40 ft)
QSFP28 fiber cable
QSFP-100G-D-AOC-7M
7 m (22.97 ft)
100 Gbps
QSFP-100G-D-AOC-10M
10 m (32.81 ft)
QSFP-100G-D-AOC-20M
20 m (65.62 ft)
Table 4 QSFP28 to SFP28 copper cables available for the QSFP28 ports
Cable length
Data rate
QSFP-100G-4SFP-25G-CAB-1M
1 m (3.28 ft)
100 Gbps
QSFP-100G-4SFP-25G-CAB-3M
3 m (9.84 ft)
QSFP-100G-4SFP-25G-CAB-5M
5 m (16.40 ft)
Table 5 QSFP+ transceiver modules available for the QSFP28 ports (1)
Connector
QSFP-40G-SR4-MM850
850
QSFP-40G-CSR4-MM850
850
QSFP-40G-LR4-PSM1310
1310
QSFP-40G-BIDI-SR-MM850
850
LC
QSFP-40G-LR4-WDM1300
Four lanes:
·   1271
·   1291
·   1311
·   1331
LC
QSFP-40G-LR4L-WDM1300
Four lanes:
·   1271
·   1291
·   1311
·   1331
LC
Table 6 QSFP+ transceiver modules available for the QSFP28 ports (2)
QSFP-40G-SR4-MM850
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
QSFP-40G-CSR4-MM850
Multi-mode, 50/125
2000
300 m (984.25 ft)
4700
400 m (1312.33 ft)
Single-mode, 9/125
N/A
10 km (6.21 miles)
Multi-mode, 50/125
2000
100 m (328.08 ft)
4700
150 m (492.12 ft)
Single-mode, 9/125
N/A
10 km (6.21 miles)
Single-mode, 9/125
N/A
2 km (1.24 miles)
Table 7 QSFP+ cables available for the QSFP28 ports
QSFP+ cable
Cable length
Data rate
QSFP+ copper cable
LSWM1QSTK0
1 m (3.28 ft)
40 Gbps
LSWM1QSTK1
3 m (9.84 ft)
LSWM1QSTK2
5 m (16.40 ft)
QSFP+ fiber cable
QSFP-40G-D-AOC-7M
7 m (22.97 ft)
40 Gbps
QSFP-40G-D-AOC-10M
10 m (32.81 ft)
QSFP-40G-D-AOC-20M
20 m (65.62 ft)
Table 8 QSFP+ to SFP+ copper cables available for the QSFP28 ports
Cable length
Data rate
LSWM1QSTK3
1 m (3.28 ft)
40 Gbps
LSWM1QSTK4
3 m (9.84 ft)
LSWM1QSTK5
5 m (16.40 ft)
·   As a best practice, use H3C transceiver modules and cables for the card.
·   H3C transceiver modules and cables available for the card are subject to change over time. For the most recent list of H3C transceiver modules and cables available for the card, contact H3C Support or marketing staff.
·   The transceiver modules and cables available for the card vary by product model. For the specific compatibility information, see the product installation guide or contact H3C Support or marketing staff.
·   For more information about H3C transceiver modules and cables, see H3C Transceiver Modules User Guide at www.h3c.com.
LEDs
Table 9 describes QSFP28 port LEDs on the front panel.
Table 9 QSFP28 port LED description
LED status
Steady green
A transceiver module is installed in the port. The port is operating at 100 Gbps, and a link is present on the port.
Flashing green
The port is sending or receiving data at 100 Gbps.
Steady yellow
A transceiver module is installed in the port. The port is operating at 10/25/40 Gbps, and a link is present on the port.
Flashing yellow (3 Hz)
The port is sending or receiving data at 10/25/40 Gbps.
Off
No transceiver module is installed in the port, or no link is present on the port.
Installing and removing the card
CAUTION
CAUTION:
·   Before you install or remove the card, wear an ESD wrist strap and make sure the strap makes good skin contact and is reliably grounded.
·   To avoid device damage, do not use excessive force when you install or remove the card.
·   The LSWM18CQMSEC interface card is hot swappable. However, do not install or remove it during the startup of the switch.
Installing the card
1.   Remove the filler panel (if any) from the target slot.
Keep the removed filler panel secure for future use.
2.   Unpack the interface card.
Figure 2 LSWM18CQMSEC interface card
(1) Ejector lever
(2) Latch
3.   Press the latch on the card to release the ejector lever.
4.   As shown by callout 1 in Figure 3, insert the card slowly into the slot along the guide rails.
5.   Rotate inward the ejector lever as shown by callout 2 in Figure 3 until the latch locks the ejector lever in place.
Figure 3 Installing the card
Removing the card
1.   Prepare an anti-static bag.
2.   Remove the cables from the card.
3.   Press the latch to release the ejector lever
4.   Rotate outward the ejector lever as shown by callout 1 in Figure 4.
5.   Pull out the interface card slowly out of the interface card slot, as shown by callout 2 in Figure 4.
6.   Place the removed interface card in the anti-static bag.
7.   If you are not to install a new card, install a filler panel in the slot to prevent dust and ensure good ventilation in the device.
Figure 4 Removing the card
Installing and removing QSFP28/QSFP+ transceiver modules and cables
For information about installing and removing QSFP28 transceiver modules, QSFP28 cables, QSFP28 to SFP28 cables, QSFP+ transceiver modules, QSFP+ cables, and QSFP+ to SFP+ cables, see H3C Transceiver Modules and Network Cables Installation Guide at www.h3c.com.
Verifying the installation
After the installation is complete, determine whether the interface card is operating correctly.
If the card fails to operate correctly, perform the following steps:
1.   Reinstall the card following the installation procedures described in this document.
2.   If the problem persists, contact H3C Support.
Technical support
New H3C Technologies Co., Ltd. provides customers with comprehensive technical support and service. If you purchase the products from the sales agent of New H3C Technologies Co., Ltd., please contact our sales agent or technical personnel.
Website: http://www.h3c.com
BOM: 3101A0PD
