LSQM1SDNB0 SDN Automation Module Card Manual-APW102
HomeSupportInstall & UpgradeCard Module ManualsLSQM1SDNB0 SDN Automation Module Card Manual-APW102
Download Book
  • Released At: 09-01-2020
  • Page Views:
  • Downloads:
Table of Contents
Related Documents
H3C LSQM1SDNB0 SDN automation module
1  Identifier
The module identifier LSQM1SDNB0 is in the upper right corner of the front panel.
2  About the module
The LSQM1SDNB0 is an SDN automation module built with server components required for ADCampus solutions. Plug and play, it supports fully automated deployment at small and medium-sized campus networks. It can deliver controller, authentication, and address assignment functions, eliminating the need for installing physical servers.
Figure 1 LSQM1SDNB0 front panel
(1) USB ports (3 in total)
(2) VGA connector
(3) Management Ethernet port
(4) Management Ethernet port LED (LINK/ACT)
(5) Console port (CONSOLE)
(6) Shutdown LED and button (SHUTDOWN)
(7) Ejector lever
(8) Captive screw
3  Specifications
Table 1 Module specifications
Item
Specifications
Hard disk
480GB SSD
Memory
Two memory slots
Standard configuration: 64 GB (two 32GB memory bars)
Dimensions (H × W × D)
40 × 399 × 355 mm (1.57 × 15.71 × 13.98 in)
Weight
3.40 kg (7.50 lb)
Power consumption
102 to 124 W
Hot swapping
Not supported
Ports
·         3 × USB2.0 ports (used by technical support for debugging only)
·         1 × VGA connector
·         1 × 10/100/1000BASE-T management Ethernet port
·         1 × console port (used by technical support for debugging only)
Ambient temperature
·         Operating: 0°C to 45°C (32°F to 113°F)
·         Storage: –40°C to +70°C (–40°F to +158°F)
Ambient humidity
·         Operating: 5% RH to 95% RH, noncondensing
·         Storage: 5% RH to 95% RH, noncondensing
·      To verify the compatibility of the card with the software release you are using, see the release notes.
·      For information about transceiver modules and cables available for the card, see the cards and transceiver modules compatibility matrixes for the device.
Table 2 10/100/1000BASE-T management Ethernet port specifications
Item
Specification
Standard
802.3, 802.3u, and 802.3ab
Auto-MDI/MDIX
Supported
Cable
Category 5 or above twisted pair cable
Transmission distance
100 m (328.08 ft)
Rate and duplex mode
10/100/1000 Mbps, full-duplex
4  LEDs
Table 3 LED description
LED
Status
10/100/1000BASE-T management Ethernet port LED (LINK/ACT)
Steady green
A 10/100/1000M link is present on the port.
Flashing green
The port is sending or receiving data at 10/100/1000 Mbps.
Off
No link is present on the port.
Shutdown LED (SHUTDOWN)
Steady green
The module is operating.
Flashing green
The module is being shut down. You can shut down the module only after the LED turns off.
Off
The module is not operating.
5  Installing and removing the module
CAUTION
CAUTION:
·      Wear a reliably grounded ESD wrist strap or ESD gloves when installing or removing the module.
·      Do not touch the components on the module.
The module can be installed in a horizontal or vertical slot. When installing the module in a horizontal slot, make sure its component side faces up. When installing the module in a vertical slot, make sure its component side faces left.
The installation and removal procedures are the same for horizontal and vertical slots. The following procedures install and remove the module in a horizontal slot.
5.1  Installing the module
1.        Face the front panel of the device. Remove the filler panel from the target slot.
This example installs the module in slot 2 on an S7506E switch.
2.        Place the module on a workbench with its component side facing up. Open the ejector levers of the module.
3.        Gently push the module into the slot along the guide rails.
4.        Close the ejector levers and make sure the module makes close contact with the backplane.
5.        Use a Phillips screwdriver to fasten the captive screws on the module.
Figure 2 Installing the module
5.2  Removing the module
IMPORTANT
IMPORTANT:
Before removing the module, press the shutdown button on the module for a minimum of 2 seconds until the shutdown LED flashes green. You can remove the module only after the shutdown LED turns off.
To remove the module:
1.        Use a Phillips screwdriver to loosen the captive screws on the module until all pressure is released.
2.        Simultaneously open the ejector levers of the module to disengage the module connector from the backplane. Then pull the module gently out of the slot along the guide rails.
3.        Place the removed module on an anti-static workbench or put it in an anti-static bag, with the component side facing up.
4.        If you are not to install a new module, install a filler panel in the slot to prevent dust and ensure good ventilation in the device.
6  Software upgrade
For information about upgrading the software, see the release notes for the module.
Copyright © 2019 New H3C Technologies Co., Ltd.
