- Released At: 12-05-2025
- Page Views:
- Downloads:
Interoperation Guide
For H3C Switches and Third-Party Switches
Document version: 6W102-20231025
Copyright © 2023 New H3C Technologies Co., Ltd. All rights reserved.
This document describes the interoperation between H3C switches and third-party devices, as well as configuration of the associated parameters for interoperation.
· Audience
· Network planners.
· Network administrators working with the switches.
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Procedures and information in the examples might be slightly different depending on the software or hardware version of the products.
You can email your comments about product documentation to [email protected].
We appreciate your comments.
EVPN and VXLAN interoperation guide
Interoperation with Cisco devices
Example: Configuring IBGP for interoperation
Example: Configuring EBGP for interoperation
Interoperation with Huawei devices
Interoperation with Ruijie devices
MSTP/PVST interoperation guide
LACP link aggregation interoperation guide
Example: Configuring static link aggregation for interoperation
Example: Configuring dynamic link aggregation for interoperation
Example: Configuring NTP interoperation with a Cisco device
Example: Configuring NTP interoperation with a Huawei device
Example: Configuring NTP interoperation with a Ruijie device
Example: Configuring LLDP interoperation with a Cisco device
Example: Configuring LLDP interoperation with a Huawei device
Configuring LLDP interoperation with a Ruijie device
Example: Configuring static routing and BFD association for interoperation
Example: Configuring OSPF and BFD association for interoperation
Example: Configuring IS-IS and BFD association for interoperation
Example: Configuring BGP and BFD association for interoperation
MPLS L3VPN interoperation guide
Interoperation with Hirschmann devices
Interoperability analysis
Table 1 EVPN and VXLAN interoperability analysis
H3C |
Cisco |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 1, configure the H3C and Cisco devices as follows:
· Configure H3C devices Switch A and Switch B as distributed EVPN gateways.
· Configure the Cisco device as an RR to reflect BGP routes.
· Configure EVPN to provide Layer 2 connectivity within the same VXLAN and Layer 3 connectivity among different VXLANs.
· Configure H3C device (Switch A)
# Enable L2VPN.
[SwitchA] l2vpn enable
# Set the VXLAN hardware resource mode.
[SwitchA] hardware-resource vxlan border40k
# Disable remote MAC address learning and remote ARP learning.
[SwitchA] vxlan tunnel mac-learning disable
[SwitchA] vxlan tunnel arp-learning disable
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA-ospf-1] area 0
[SwitchA-ospf-1] quit
# Configure interface Loopback 0.
[SwitchA] interface LoopBack 0
[SwitchA-LoopBack0] ip address 2.2.2.2 32
[SwitchA-LoopBack0] ospf 1 area 0
[SwitchA-LoopBack0] quit
# Configure the underlay network.
[SwitchA] interface GigabitEthernet 1/0/45
[SwitchA-GigabitEthernet1/0/45] port link-mode route
[SwitchA-GigabitEthernet1/0/45] ip address 13.0.0.1 255.255.255.252
[SwitchA-GigabitEthernet1/0/45] ospf 1 area 0.0.0.0
[SwitchA-GigabitEthernet1/0/45] quit
[SwitchA] interface GigabitEthernet 1/0/47
[SwitchA-GigabitEthernet1/0/47] port link-mode route
[SwitchA-GigabitEthernet1/0/47] ip address 11.0.0.2 255.255.255.252
[SwitchA-GigabitEthernet1/0/47] ospf 1 area 0.0.0.0
[SwitchA-GigabitEthernet1/0/47] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA-vlan1001] quit
# Create an EVPN instance on VSI v1, and configure an RD and RTs for the EVPN instance.
[SwitchA] vsi v1
[SwitchA-vsi-v1] arp suppression enable
[SwitchA-vsi-v1] flooding disable all
[SwitchA-vsi-v1] evpn encapsulation vxlan
[SwitchA-vsi-v1-evpn-vxlan] route-distinguisher 2.2.2.2:10001
[SwitchA-vsi-v1-evpn-vxlan] vpn-target 65001:10001
[SwitchA-vsi-v1-evpn-vxlan] quit
# Create VXLAN10001.
[SwitchA-vsi-v1] vxlan 10001
[SwitchA-vsi-v1-vxlan-10001] quit
[SwitchA-vsi-v1] quit
# Configure BGP to advertise EVPN routes.
[SwitchA] bgp 65001
[SwitchA-bgp-default] peer 1.1.1.1 as-number 65001
[SwitchA-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchA-bgp-default] address-family l2vpn evpn
[SwitchA-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchA-bgp-default-evpn] quit
[SwitchA-bgp-default] quit
# On GigabitEthernet 1/0/5, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface gigabitethernet 1/0/5
[SwitchA-GigabitEthernet1/0/5] service-instance 1
[SwitchA-GigabitEthernet1/0/5-srv1] encapsulation s-vid 1001
# Map Ethernet service instance 1 to VSI v1.
[SwitchA-GigabitEthernet1/0/5-srv1] xconnect vsi v1
[SwitchA-GigabitEthernet1/0/5-srv1] quit
# Configure RD and RTs for VPN instance vpn1.
[SwitchA] ip vpn-instance vpn1
[SwitchA-vpn-instance-vpn1] route-distinguisher 2.2.2.2:10001
[SwitchA-vpn-instance-vpn1] vpn-target 65001:10001
[SwitchA-vpn-instance-vpn1] address-family evpn
[SwitchA-vpn-evpn-vpn1] vpn-target 65001:10001
[SwitchA-vpn-evpn-vpn1] quit
[SwitchA-vpn-instance-vpn1] quit
# Configure VSI-interface 1.
[SwitchA] interface vsi-interface 1
[SwitchA-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface1] ip address 100.0.0.1 255.255.255.0
[SwitchA-Vsi-interface1] mac-address 0000-2017-0001
[SwitchA-Vsi-interface1] distributed-gateway local
[SwitchA-Vsi-interface1] quit
# Create VSI-interface 16777201 and associate it with VPN instance vpn1 and L3VNI 16777201.
[SwitchA] interface vsi-interface 16777201
[SwitchA-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchA-Vsi-interface3] l3-vni 16777201
[SwitchA-Vsi-interface3] quit
# Specify gateway interface VSI-interface 1 for VXLAN 10.
[SwitchA] vsi v1
[SwitchA-vsi-v1] gateway vsi-interface 1
· Configure H3C device (Switch B)
# Enable L2VPN.
[SwitchB] l2vpn enable
[SwitchB] hardware-resource vxlan border40k
[SwitchB] vxlan tunnel mac-learning disable
[SwitchB] vxlan tunnel arp-learning disable
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB-ospf-1] area 0
[SwitchB-ospf-1] quit
[SwitchB] interface LoopBack 0
[SwitchB-LoopBack0] ip address 3.3.3.3 32
[SwitchB-LoopBack0] ospf 1 area 0
[SwitchB-LoopBack0] quit
[SwitchB] interface GigabitEthernet 1/0/45
[SwitchB-GigabitEthernet1/0/45] port link-mode route
[SwitchB-GigabitEthernet1/0/45] ip address 13.0.0.2 255.255.255.252
[SwitchB-GigabitEthernet1/0/45] ospf 1 area 0.0.0.0
[SwitchB-GigabitEthernet1/0/45] quit
[SwitchB] interface GigabitEthernet 1/0/48
[SwitchB-GigabitEthernet1/0/48] port link-mode route
[SwitchB-GigabitEthernet1/0/48] ip address 12.0.0.2 255.255.255.252
[SwitchB-GigabitEthernet1/0/48] ospf 1 area 0.0.0.0
[SwitchB-GigabitEthernet1/0/48] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB-vlan1001] quit
[SwitchB] vsi v1
[SwitchB-vsi-v1] arp suppression enable
[SwitchB-vsi-v1] flooding disable all
[SwitchB-vsi-v1] evpn encapsulation vxlan
[SwitchB-vsi-v1-evpn-vxlan] route-distinguisher 3.3.3.3:10001
[SwitchB-vsi-v1-evpn-vxlan] vpn-target 65001:10001
[SwitchB-vsi-v1-evpn-vxlan] quit
# Create VXLAN 10001.
[SwitchB-vsi-v1] vxlan 10001
[SwitchB-vsi-v1-vxlan-10001] quit
[SwitchB-vsi-v1] quit
[SwitchB] bgp 65001
[SwitchB-bgp-default] peer 1.1.1.1 as-number 65001
[SwitchB-bgp-default] peer 1.1.1.1 connect-interface loopback 0
[SwitchB-bgp-default] address-family l2vpn evpn
[SwitchB-bgp-default-evpn] peer 1.1.1.1 enable
[SwitchB-bgp-default-evpn] quit
[SwitchB-bgp-default] quit
[SwitchB] interface gigabitethernet 1/0/5
[SwitchB-GigabitEthernet1/0/5] service-instance 1
[SwitchB-GigabitEthernet1/0/5-srv1] encapsulation s-vid 1001
[SwitchB-GigabitEthernet1/0/5-srv1] xconnect vsi v1
[SwitchB-GigabitEthernet1/0/5-srv1] quit
[SwitchB] ip vpn-instance vpn1
[SwitchB-vpn-instance-vpn1] route-distinguisher 3.3.3.3:10001
[SwitchB-vpn-instance-vpn1] vpn-target 65001:10001
[SwitchB-vpn-instance-vpn1] address-family evpn
[SwitchB-vpn-evpn-vpn1] vpn-target 65001:10001
[SwitchB-vpn-evpn-vpn1] quit
[SwitchB-vpn-instance-vpn1] quit
[SwitchB] interface vsi-interface 1
[SwitchB-Vsi-interface1] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface1] ip address 100.0.0.1 255.255.255.0
[SwitchB-Vsi-interface1] mac-address 0000-2017-0001
[SwitchB-Vsi-interface1] distributed-gateway local
[SwitchB-Vsi-interface1] quit
[SwitchB] interface vsi-interface 16777201
[SwitchB-Vsi-interface3] ip binding vpn-instance vpn1
[SwitchB-Vsi-interface3] l3-vni 16777201
[SwitchB-Vsi-interface3] quit
[SwitchB] vsi v1
[SwitchB-vsi-v1] gateway vsi-interface 1
# View device information. Nexus9000 93180YC-EX is used as an example.
Cisco# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2016, Cisco and/or its affiliates.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 07.56
NXOS: version 7.0(3)I4(2)
BIOS compile time: 06/08/2016
NXOS image file is: bootflash:///nxos.7.0.3.I4.2.bin
NXOS compile time: 7/21/2016 8:00:00 [07/21/2016 16:09:32]
Hardware
cisco Nexus9000 93180YC-EX chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 24634044 kB of memory.
Processor Board ID FDO20380BK7
Device name: CN93
bootflash: 53298520 kB
Kernel uptime is 1 day(s), 1 hour(s), 19 minute(s), 35 second(s)
Last reset at 776030 usecs after Wed Sep 20 02:52:01 2017
Reason: Reset Requested by CLI command reload
System version: 7.0(3)I4(2)
Service:
plugin
Core Plugin, Ethernet Plugin
# Switch the resource mode.
Cisco# configure terminal
Enter configuration commands, one per line. End with CNTL/Z.
Cisco(config)# system routing template-vxlan-scale
# Enable features required for network communication.
Cisco(config)#
Cisco(config)# nv overlay evpn
Cisco(config)# feature ospf
Cisco(config)# feature bgp
Cisco(config)# feature interface-vlan
Cisco(config)# feature lldp
Cisco(config)# feature vn-segment-vlan-based
Cisco(config)# feature nv overlay
# Create VLAN 101 and VLAN 1001.
Cisco(config)# vlan 101 ,1001
Cisco(config-vlan)# exit
# Configure the gateway MAC address.
Cisco(config)# fabric forwarding anycast-gateway-mac 0000.2017.0001
# Disable IGMP snooping.
Cisco(config)# no ip igmp snooping
# Create VN segment 16777201.
Cisco(config-vlan)# vn-segment 16777201
# Create VN segment 10001.
Cisco(config)# vlan 1001
Cisco(config-vlan)# vn-segment 10001
# Enable OSPF.
Cisco(config)# router ospf 1
Cisco(config-router)# exit
# Create a VRF.
Cisco(config)# vrf context vpn1
Cisco(config-vrf)# vni 16777201
Cisco(config-vrf)# rd 1.1.1.1:10001
Cisco(config-vrf)# address-family ipv4 unicast
Cisco(config-vrf-af-ipv4)# route-target import 65001:10001
Cisco(config-vrf-af-ipv4)# route-target import 65001:10001 evpn
Cisco(config-vrf-af-ipv4)# route-target export 65001:10001
Cisco(config-vrf-af-ipv4)# route-target export 65001:10001 evpn
Cisco(config-vrf-af-ipv4)# exit
Cisco(config-vrf)# exit
# Create VLAN-interface 101.
Cisco(config)# interface vlan 101
Cisco(config-if)# no shutdown
Cisco(config-if)# vrf member vpn1
Warning: Deleted all L3 config on interface Vlan101
Cisco(config-if)# exit
# Create VLAN-interface 1001.
Cisco(config)# interface vlan 1001
Warning: Deleted all L3 config on interface Vlan1001
Cisco(config-if)# ip address 100.0.0.1/24
Cisco(config-if)# fabric forwarding mode anycast-gateway
# Create interface nve1.
Cisco(config)# interface nve1
Cisco(config-if-nve)# no shutdown
Cisco(config-if-nve)# source-interface loopback0
Cisco(config-if-nve)# host-reachability protocol bgp
Cisco(config-if-nve)# member vni 10001
Cisco(config-if-nve-vni)# suppress-arp
Cisco(config-if-nve-vni)# ingress-replication protocol bgp
Cisco(config-if-nve-vni)# exit
Cisco(config-if-nve)# member vni 16777201 associate-vrf
Cisco(config-if-nve)# exit
# Configure the site-facing interface.
Cisco(config)# interface ethernet 1/5
Cisco(config-if)# switchport
Cisco(config-if)# switchport mode trunk
Cisco(config-if)# switchport trunk allowed vlan 1001
Cisco(config)# interface ethernet 1/47
Cisco(config-if)# ip address 11.0.0.1/30
Cisco(config-if)# ip router ospf 1 area 0.0.0.0
Cisco(config)# interface ethernet 1/48
Cisco(config-if)# ip address 12.0.0.1/30
# Create Loopback 0.
Cisco(config)# interface loopback0
Cisco(config-if)# ip address 1.1.1.1/32
# Configure BGP.
Cisco(config)# router bgp 65001
Cisco(config-router)# router-id 1.1.1.1
Cisco(config-router)# address-family l2vpn evpn
Cisco(config-router-af)# neighbor 2.2.2.2
Cisco(config-router-neighbor)# remote-as 65001
Cisco(config-router-neighbor)# update-source loopback 0
Cisco(config-router-neighbor)# address-family ipv4 unicast
Cisco(config-router-neighbor-af)# send-community both
Cisco(config-router-neighbor-af)# route-reflector-client
Cisco(config-router-neighbor-af)# exit
Cisco(config-router-neighbor)# address-family l2vpn evpn
Cisco(config-router-neighbor)# exit
Cisco(config-router)# neighbor 3.3.3.3
# Configure EVPN.
Cisco(config)# evpn
Cisco(config-evpn)# vni 10001 l2
Cisco(config-evpn-evi)# rd 1.1.1.1:10001
Cisco(config-evpn-evi)# route-target both 65001:10001
Cisco(config-evpn-evi)# exit
Cisco(config-evpn)# exit
· H3C device (Switch A)
# Verify that BGP L2VPN peers are connected.
[SwitchA] display bgp peer l2vpn evpn
BGP local router ID: 2.2.2.2
Local AS number: 65001
Total number of peers: 1 Peers in established state: 1
* - Dynamically created peer
1.1.1.1 65001 168 185 0 8 02:12:37 Established
# Verify that IPv4 neighbors have been discovered through inclusive multicast Ethernet tag (IMET) routes.
[SwitchA] display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: v1
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1.1.1.1:10001 1.1.1.1 1.1.1.1 VXLAN 10001
3.3.3.3:10001 3.3.3.3 3.3.3.3 VXLAN 10001
# Verify that EVPN routes have been learned for VPN instance vpn1.
[SwitchA] display evpn routing-table vpn-instance vpn1
VPN instance: vpn1 Local L3VNI: 16777201
IP address Next hop Outgoing interface NibID
100.0.0.111 1.1.1.1 Vsi-interface16777201 0x18000000
100.0.0.116 3.3.3.3 Vsi-interface16777201 0x18000001
# Verify that the device has learned EVPN ARP entries.
[SwitchA] display evpn route arp
Flags: D - Dynamic B - BGP L - Local active
G - Gateway S - Static M - Mapping
VPN instance: vpn1 Interface: Vsi-interface1
IP address MAC address Router MAC VSI index Flags
100.0.0.1 0000-2017-0001 703d-15b5-1c8d 0 GL
100.0.0.111 0000-1ed4-45a1 006b-f183-c327 0 B
100.0.0.115 0000-32eb-e6bc 703d-15b5-1c8d 0 DL
100.0.0.116 0000-1279-80ce 703d-15b5-1cff 0 B
# Verify that the device has learned IPv4 EVPN MAC entries.
[SwitchA] display evpn route mac
VSI name: v1
MAC address Link ID/Name Flags Next hop
0005-0000-0001 Tunnel1 B 1.1.1.1
0000-1279-80ce Tunnel0 B 3.3.3.3
0000-1ed4-45a1 Tunnel1 B 1.1.1.1
# Verify that the device has established VXLAN tunnels and mapped them to VXLANs.
[SwitchA] display vxlan tunnel
Total number of VXLANs: 2
VXLAN ID: 10001, VSI name: v1, Total tunnels: 2 (2 up, 0 down, 0 defect, 0 blocked)
Tunnel name Link ID State Type Flood proxy
Tunnel0 0x5000000 UP Auto Disabled
Tunnel1 0x5000001 UP Auto Disabled
VXLAN ID: 16777201, VSI name: Auto_L3VNI16777201_16777201
# Verify that the device has learned ARP flood suppression entries.
[SwitchA] display arp suppression vsi
IP address MAC address Vsi Name Link ID Aging
100.0.0.111 0000-1ed4-45a1 v1 0x5000001 N/A
100.0.0.115 0000-32eb-e6bc v1 0x0 16
100.0.0.116 0000-1279-80ce v1 0x5000000 N/A
# Verify that VSI information is correct.
[SwitchA] display l2vpn vsi verbose
VSI Name: Auto_L3VNI16777201_16777201
VSI Index : 1
VSI State : Down
MTU : 1500
Bandwidth : Unlimited
Broadcast Restrain : Unlimited
Multicast Restrain : Unlimited
Unknown Unicast Restrain: Unlimited
MAC Learning : Enabled
MAC Table Limit : -
MAC Learning rate : -
Drop Unknown : -
Flooding : Enabled
Statistics : Disabled
Gateway Interface : VSI-interface 16777201
VXLAN ID : 16777201
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
Tunnel Name Link ID State Type Flood proxy
ACs:
AC Link ID State Type
XGE1/0/5 srv1 0 Up Manual
· H3C device (Switch B)
[SwitchB] display bgp peer l2vpn evpn
BGP local router ID: 3.3.3.3
1.1.1.1 65001 667 688 0 7 09:50:51 Established
# Verify that IPv4 neighbors have been discovered through IMET routes.
[SwitchB] display evpn auto-discovery imet
VSI name: v1
2.2.2.2:10001 2.2.2.2 2.2.2.2 VXLAN 10001
[SwitchB] display ip routing-table vpn-instance vpn1
Destinations : 14 Routes : 14
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
100.0.0.0/24 Direct 0 0 100.0.0.1 Vsi1
100.0.0.0/32 Direct 0 0 100.0.0.1 Vsi1
100.0.0.1/32 Direct 0 0 127.0.0.1 InLoop0
100.0.0.111/32 BGP 255 0 1.1.1.1 Vsi16777201
100.0.0.115/32 BGP 255 0 2.2.2.2 Vsi16777201
100.0.0.255/32 Direct 0 0 100.0.0.1 Vsi1
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
[SwitchB] display evpn routing-table vpn-instance vpn1
100.0.0.115 2.2.2.2 Vsi-interface16777201 0x18000001
[SwitchB] display evpn route arp
100.0.0.1 0000-2017-0001 703d-15b5-1cff 0 GL
100.0.0.115 0000-32eb-e6bc 703d-15b5-1c8d 0 B
100.0.0.116 0000-1279-80ce 703d-15b5-1cff 0 DL
[SwitchB] display evpn route mac
VSI name: v1
0000-1279-80ce 0 DL -
0000-32eb-e6bc Tunnel0 B 2.2.2.2
[SwitchB] display vxlan tunnel
[SwitchB] display arp suppression vsi
100.0.0.116 0000-1279-80ce v1 0x0 11
100.0.0.115 0000-32eb-e6bc v1 0x5000000 N/A
[SwitchB] display l2vpn vsi verbose
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16777201
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
· Cisco device
# Verify that the device has established BGP EVPN peer relationships.
Cisco# show bgp l2vpn evpn neighbors
BGP neighbor is 2.2.2.2, remote AS 65001, ibgp link, Peer index 1
BGP version 4, remote router ID 2.2.2.2
BGP state = Established, up for 02:14:17
Using loopback0 as update source for this peer
Last read 00:00:31, hold time = 180, keepalive interval is 60 seconds
Last written 00:00:22, keepalive timer expiry due 00:00:37
Received 194 messages, 0 notifications, 0 bytes in queue
Sent 186 messages, 2 notifications, 0 bytes in queue
Connections established 3, dropped 2
Last reset by us 02:14:29, due to route-reflector configuration change
Last reset by peer never, due to No error
Neighbor capabilities:
Dynamic capability: advertised (mp, refresh, gr)
Dynamic capability (old): advertised
Route refresh capability (new): advertised received
Route refresh capability (old): advertised
4-Byte AS capability: advertised received
Address family IPv4 Unicast: advertised
Address family L2VPN EVPN: advertised received
Graceful Restart capability: advertised
Graceful Restart Parameters:
Address families advertised to peer:
IPv4 Unicast L2VPN EVPN
Address families received from peer:
Forwarding state preserved by peer for:
Restart time advertised to peer: 120 seconds
Stale time for routes advertised by peer: 300 seconds
Extended Next Hop Encoding Capability: advertised
Message statistics:
Sent Rcvd
Opens: 3 3
Notifications: 2 0
Updates: 36 26
Keepalives: 142 157
Route Refresh: 3 8
Capability: 0 0
Total: 186 194
Total bytes: 5677 5698
Bytes in queue: 0 0
For address family: IPv4 Unicast
BGP table version 2, neighbor version 0
0 accepted paths consume 0 bytes of memory
0 sent paths
Community attribute sent to this neighbor
Extended community attribute sent to this neighbor
Third-party Nexthop will not be computed.
Route reflector client
For address family: L2VPN EVPN
BGP table version 76, neighbor version 76
4 accepted paths consume 496 bytes of memory
8 sent paths
Local host: 1.1.1.1, Local port: 35453
Foreign host: 2.2.2.2, Foreign port: 179
fd = 76
BGP neighbor is 3.3.3.3, remote AS 65001, ibgp link, Peer index 2
BGP version 4, remote router ID 3.3.3.3
BGP state = Established, up for 02:14:40
Last read 00:00:33, hold time = 180, keepalive interval is 60 seconds
Last written 00:00:13, keepalive timer expiry due 00:00:46
Received 185 messages, 0 notifications, 0 bytes in queue
Sent 185 messages, 2 notifications, 0 bytes in queue
Last reset by us 02:14:52, due to route-reflector configuration change
Message statistics:
Sent Rcvd
Opens: 3 3
Notifications: 2 0
Updates: 40 22
Keepalives: 137 152
Route Refresh: 3 8
Capability: 0 0
Total: 185 185
Total bytes: 6589 5220
Bytes in queue: 0 0
0 sent paths
8 sent paths
Local host: 1.1.1.1, Local port: 40155
Foreign host: 3.3.3.3, Foreign port: 179
fd = 77
# Verify that the device has established NVE peer relationships.
Cisco# show nve peers detail
Details of nve Peers:
Peer-Ip: 2.2.2.2
NVE Interface : nve1
Peer State : Up
Peer Uptime : 00:45:50
Router-Mac : 703d.15b5.1c8d
Peer First VNI : 16777201
Time since Create : 00:45:50
Configured VNIs : 10001,16777201
Provision State : add-complete
Route-Update : Yes
Peer Flags : RmacL2Rib, TunnelPD, DisableLearn
Learnt CP VNIs : 10001,16777201
Peer-ifindex-resp : Yes
Peer-Ip: 3.3.3.3
Peer State : Up
Router-Mac : 703d.15b5.1cff
Route-Update : Yes
# Verify that the device has learned NVE VNI entries.
Cisco# show nve vni
Codes: CP - Control Plane DP - Data Plane
UC - Unconfigured SA - Suppress ARP
Interface VNI Multicast-group State Mode Type [BD/VRF] Flags
nve1 10001 UnicastBGP Up CP L2 [1001] SA
nve1 16777201 n/a Up CP L3 [vpn1]
# Verify that the device has correct NVE VRF entries.
Cisco# show nve vrf
VRF-Name VNI Interface Gateway-MAC
vpn1 16777201 nve1 006b.f183.c327
# Verify that the NVE VXLAN configuration is correct.
Cisco# show nve vxlan-params
VxLAN Dest. UDP Port: 4789
# Verify that the VXLAN and VLAN mappings are correct.
Cisco# show vxlan
Vlan VN-Segment
101 16777201
1001 10001
# Verify that the BGP routes for L2VPN EVPN are correct.
BGP routing table information for VRF default, address family L2VPN EVPN
BGP table version is 88, local router ID is 1.1.1.1
Status: s-suppressed, x-deleted, S-stale, d-dampened, h-history, *-valid, >-best
Path type: i-internal, e-external, c-confed, l-local, a-aggregate, r-redist, I-i
njected
Origin codes: i - IGP, e - EGP, ? - incomplete, | - multipath, & - backup
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 1.1.1.1:10001 (L2VNI 10001)
*>i[2]:[0]:[0]:[48]:[0000.1279.80ce]:[0]:[0.0.0.0]/216
3.3.3.3 0 100 0 i
*>l[2]:[0]:[0]:[48]:[0000.1ed4.45a1]:[0]:[0.0.0.0]/216
1.1.1.1 100 32768 i
*>i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[0]:[0.0.0.0]/216
2.2.2.2 0 100 0 i
*>l[2]:[0]:[0]:[48]:[0005.0000.0001]:[0]:[0.0.0.0]/216
1.1.1.1 100 32768 i
*>i[2]:[0]:[0]:[48]:[0000.1279.80ce]:[32]:[100.0.0.116]/272
3.3.3.3 0 100 0 i
*>l[2]:[0]:[0]:[48]:[0000.1ed4.45a1]:[32]:[100.0.0.111]/272
1.1.1.1 100 32768 i
*>i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[32]:[100.0.0.115]/272
2.2.2.2 0 100 0 i
*>l[3]:[0]:[32]:[1.1.1.1]/88
1.1.1.1 100 32768 i
Route Distinguisher: 2.2.2.2:10001
2.2.2.2 0 100 0 i
2.2.2.2 0 100 0 i
*>i[3]:[0]:[32]:[2.2.2.2]/88
2.2.2.2 0 100 0 i
*>i[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
2.2.2.2 0 100 0 i
Route Distinguisher: 3.3.3.3:10001
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
*>i[3]:[0]:[32]:[3.3.3.3]/88
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
Route Distinguisher: 1.1.1.1:10001 (L3VNI 16777201)
3.3.3.3 0 100 0 i
2.2.2.2 0 100 0 i
3.3.3.3 0 100 0 i
2.2.2.2 0 100 0 i
# Verify that the device has learned EVPN MAC entries from Layer 2 routes.
Cisco# show l2route evpn mac all
Topology Mac Address Prod Next Hop (s)
101 703d.15b5.1c8d VXLAN 2.2.2.2
101 703d.15b5.1cff VXLAN 3.3.3.3
1001 0000.1279.80ce BGP 3.3.3.3
1001 0000.1ed4.45a1 Local Eth1/5
1001 0000.32eb.e6bc BGP 2.2.2.2
1001 0005.0000.0001 Local Eth1/5
# Verify that the device has learned EVPN MAC-IP routes from Layer 2 routes.
Cisco# show l2route evpn mac-ip all
Topology ID Mac Address Prod Host IP Next Hop
(s)
1001 0000.1ed4.45a1 HMM 100.0.0.111 N/A
1001 0000.32eb.e6bc BGP 100.0.0.115 2.2.2.2
1001 0000.1279.80ce BGP 100.0.0.116 3.3.3.3
# Verify that the device has created ARP suppression cache entries.
Cisco# show ip arp suppression-cache detail
Flags: + - Adjacencies synced via CFSoE
L - Local Adjacency
R - Remote Adjacency
L2 - Learnt over L2 interface
Ip Address Age Mac Address Vlan Physical-ifindex Flags
100.0.0.111 00:10:00 0000.1ed4.45a1 1001 Ethernet1/5 L
100.0.0.116 01:05:23 0000.1279.80ce 1001 (null) R
100.0.0.115 01:05:17 0000.32eb.e6bc 1001 (null) R
# Verify that routes have been learned for VPN instance vpn1.
Cisco# show ip route vrf vpn1
IP Route Table for VRF "vpn1"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
100.0.0.0/24, ubest/mbest: 1/0, attached
*via 100.0.0.1, Vlan1001, [0/0], 07:51:12, direct
100.0.0.1/32, ubest/mbest: 1/0, attached
*via 100.0.0.1, Vlan1001, [0/0], 07:51:12, local
100.0.0.111/32, ubest/mbest: 1/0, attached
*via 100.0.0.111, Vlan1001, [190/0], 07:37:29, hmm
100.0.0.115/32, ubest/mbest: 1/0
*via 2.2.2.2%default, [200/0], 07:36:52, bgp-65001, internal, tag 65001 (evp
n) segid: 16777201 tunnelid: 0x2020202 encap: VXLAN
100.0.0.116/32, ubest/mbest: 1/0
*via 3.3.3.3%default, [200/0], 07:36:58, bgp-65001, internal, tag 65001 (evp
n) segid: 16777201 tunnelid: 0x3030303 encap: VXLAN
As shown in Figure 2, configure the H3C and Cisco devices as follows:
· Configure the Cisco device as a distributed EVPN gateway.
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 2000
[SwitchA-bgp-default] peer 1.1.1.1 as-number 1000
[SwitchA-bgp-default] peer 1.1.1.1 ebgp-max-hop 10
[SwitchA-bgp-default] peer 3.3.3.3 as-number 1000
[SwitchA-bgp-default] peer 3.3.3.3 connect-interface loopback 0
[SwitchA-bgp-default] peer 3.3.3.3 ebgp-max-hop 10
[SwitchA-bgp-default-evpn] peer 3.3.3.3 enable
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 1000
[SwitchB-bgp-default] peer 1.1.1.1 as-number 1000
[SwitchB-bgp-default] peer 2.2.2.2 as-number 2000
[SwitchB-bgp-default] peer 2.2.2.2 connect-interface loopback 0
[SwitchB-bgp-default] peer 2.2.2.2 ebgp-max-hop 10
[SwitchB-bgp-default-evpn] peer 2.2.2.2 enable
[SwitchB] vsi v1
Cisco# show version
Software
BIOS: version 07.56
Hardware
Device name: CN93
Service:
plugin
# Enable OSPF.
# Create a VRF.
# Configure BGP.
Cisco(config)# router bgp 1000
Cisco(config-router-neighbor)# remote-as 2000
Cisco(config-router-neighbor)# ebgp-multihop 10
Cisco(config-router-neighbor)# remote-as 1000
# Configure EVPN.
Cisco(config)# evpn
Local AS number: 2000
Total number of peers: 2 Peers in established state: 2
1.1.1.1 1000 17 20 0 8 00:06:19 Established
3.3.3.3 1000 20 17 0 8 00:08:47 Established
VSI name: v1
[SwitchA] display ip routing-table vpn-instance vpn1
100.0.0.111/32 BGP 255 0 3.3.3.3 Vsi16777201
100.0.0.116/32 BGP 255 0 3.3.3.3 Vsi16777201
100.0.0.111 3.3.3.3 Vsi-interface16777201 0x18000000
100.0.0.116 3.3.3.3 Vsi-interface16777201 0x18000000
VSI name: v1
0005-0000-0001 Tunnel0 B 3.3.3.3
0000-1ed4-45a1 Tunnel0 B 3.3.3.3
100.0.0.115 0000-32eb-e6bc v1 0x0 7
100.0.0.111 0000-1ed4-45a1 v1 0x5000000 N/A
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16777201
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
[SwitchA] display bgp l2vpn evpn
Total number of routes from all PEs: 16
Route distinguisher: 1.1.1.1:10001
Total number of routes: 8
* >e [2][0][48][0000-1ed4-45a1][0][0.0.0.0]/104
3.3.3.3 0 1000i
* e 1.1.1.1 0 1000i
* >e [2][0][48][0000-1ed4-45a1][32][100.0.0.111]/136
3.3.3.3 0 1000i
* e 1.1.1.1 0 1000i
* >e [2][0][48][0005-0000-0001][0][0.0.0.0]/104
3.3.3.3 0 1000i
* e 1.1.1.1 0 1000i
* >e [3][0][32][1.1.1.1]/80
3.3.3.3 0 1000i
* e 1.1.1.1 0 1000i
Route distinguisher: 2.2.2.2:10001(vpn1)
Total number of routes: 5
* >e [2][0][48][0000-1279-80ce][32][100.0.0.116]/136
3.3.3.3 0 0 1000i
3.3.3.3 0 1000i
* > [2][0][48][0000-32eb-e6bc][32][100.0.0.115]/136
0.0.0.0 0 100 32768 i
* > [3][0][32][2.2.2.2]/80
* > [5][0][24][100.0.0.0]/80
Route distinguisher: 3.3.3.3:10001
* >e [2][0][48][0000-1279-80ce][0][0.0.0.0]/104
3.3.3.3 0 0 1000i
* e 1.1.1.1 0 1000i
3.3.3.3 0 0 1000i
* e 1.1.1.1 0 1000i
* >e [3][0][32][3.3.3.3]/80
3.3.3.3 0 0 1000i
* e 1.1.1.1 0 1000i
* >e [5][0][24][100.0.0.0]/80
3.3.3.3 0 0 1000i
* e 1.1.1.1 0 1000i
Local AS number: 1000
1.1.1.1 1000 22 25 0 8 00:11:02 Established
2.2.2.2 2000 22 24 0 4 00:12:15 Established
VSI name: v1
100.0.0.111 1.1.1.1 Vsi-interface16777201 0x18000001
100.0.0.115 2.2.2.2 Vsi-interface16777201 0x18000000
VSI name: v1
100.0.0.116 0000-1279-80ce v1 0x0 24
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16777201
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
# Verify that the BGP EVPN routes are correct.
[SwitchB] display bgp l2vpn evpn
Total number of routes from all PEs: 12
Total number of routes: 4
* >i [2][0][48][0000-1ed4-45a1][0][0.0.0.0]/104
1.1.1.1 100 0 i
* >i [2][0][48][0000-1ed4-45a1][32][100.0.0.111]/136
1.1.1.1 100 0 i
* >i [2][0][48][0005-0000-0001][0][0.0.0.0]/104
1.1.1.1 100 0 i
* >i [3][0][32][1.1.1.1]/80
1.1.1.1 100 0 i
* >e [2][0][48][0000-32eb-e6bc][0][0.0.0.0]/104
2.2.2.2 0 0 2000i
* i 2.2.2.2 0 100 0 2000i
* >e [2][0][48][0000-32eb-e6bc][32][100.0.0.115]/136
2.2.2.2 0 0 2000i
* >e [3][0][32][2.2.2.2]/80
2.2.2.2 0 0 2000i
2.2.2.2 0 0 2000i
Route distinguisher: 3.3.3.3:10001(vpn1)
Total number of routes: 6
* > [2][0][48][0000-1279-80ce][0][0.0.0.0]/104
* > [2][0][48][0000-1279-80ce][32][100.0.0.116]/136
1.1.1.1 100 0 i
2.2.2.2 0 0 2000i
* > [3][0][32][3.3.3.3]/80
· Cisco device
BGP neighbor is 2.2.2.2, remote AS 2000, ebgp link, Peer index 2
BGP state = Established, up for 00:13:21
External BGP peer might be upto 10 hops away
Last read 00:00:52, hold time = 180, keepalive interval is 60 seconds
Last written 00:00:20, keepalive timer expiry due 00:00:39
Received 29 messages, 0 notifications, 0 bytes in queue
Sent 27 messages, 1 notifications, 0 bytes in queue
Connections established 2, dropped 1
Last reset by us 00:13:33, due to address-family configuration change
Message statistics:
Sent Rcvd
Opens: 2 2
Notifications: 1 0
Updates: 8 12
Keepalives: 16 15
Route Refresh: 0 0
Capability: 0 0
Total: 27 29
Total bytes: 1111 1592
Bytes in queue: 0 0
0 sent paths
BGP table version 46, neighbor version 46
8 sent paths
Local host: 1.1.1.1, Local port: 56082
fd = 78
BGP neighbor is 3.3.3.3, remote AS 1000, ibgp link, Peer index 1
BGP state = Established, up for 00:14:35
Last read 00:00:47, hold time = 180, keepalive interval is 60 seconds
Last written 00:00:34, keepalive timer expiry due 00:00:25
Received 30 messages, 0 notifications, 0 bytes in queue
Sent 28 messages, 1 notifications, 0 bytes in queue
Last reset by us 00:14:48, due to address-family configuration change
Message statistics:
Sent Rcvd
Opens: 2 2
Notifications: 1 0
Updates: 8 11
Keepalives: 17 17
Route Refresh: 0 0
Capability: 0 0
Total: 28 30
Total bytes: 1213 1497
Bytes in queue: 0 0
0 sent paths
8 accepted paths consume 992 bytes of memory
8 sent paths
Local host: 1.1.1.1, Local port: 54671
fd = 77
Peer-Ip: 2.2.2.2
Peer State : Up
Peer Uptime : 00:14:55
Peer First VNI : 10001
Time since Create : 00:14:55
Route-Update : Yes
Peer-Ip: 3.3.3.3
Peer State : Up
Route-Update : Yes
Cisco# show nve vni
Cisco# show nve vrf
Cisco# show vxlan
Vlan VN-Segment
101 16777201
1001 10001
BGP table version is 52, local router ID is 1.1.1.1
njected
3.3.3.3 0 100 0 i
1.1.1.1 100 32768 i
1.1.1.1 100 32768 i
3.3.3.3 0 100 0 i
1.1.1.1 100 32768 i
*>e[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[32]:[100.0.0.115]/272
2.2.2.2 0 0 2000 i
1.1.1.1 100 32768 i
*>e[3]:[0]:[32]:[2.2.2.2]/88
2.2.2.2 0 0 2000 i
3.3.3.3 0 100 0 i
* e[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
2.2.2.2 0 0 2000 i
*>i 3.3.3.3 0 100 0 i
x i[2]:[0]:[0]:[48]:[0000.32eb.e6bc]:[0]:[0.0.0.0]/216
2.2.2.2 0 100 0 2000 i
x e 2.2.2.2 0 0 2000 i
2.2.2.2 0 0 2000 i
* i 2.2.2.2 0 100 0 2000 i
2.2.2.2 0 0 2000 i
*>e[5]:[0]:[0]:[24]:[100.0.0.0]:[0.0.0.0]/224
2.2.2.2 0 0 2000 i
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
3.3.3.3 0 100 0 i
2.2.2.2 0 0 2000 i
2.2.2.2 0 0 2000 i
3.3.3.3 0 100 0 i
2.2.2.2 0 0 2000 i
(s)
L - Local Adjacency
100.0.0.111 00:08:06 0000.1ed4.45a1 1001 Ethernet1/5 L
100.0.0.116 00:16:12 0000.1279.80ce 1001 (null) R
100.0.0.115 00:14:57 0000.32eb.e6bc 1001 (null) R
*via 100.0.0.1, Vlan1001, [0/0], 08:47:51, direct
*via 100.0.0.1, Vlan1001, [0/0], 08:47:51, local
*via 100.0.0.111, Vlan1001, [190/0], 08:34:08, hmm
*via 2.2.2.2%default, [20/0], 00:15:05, bgp-1000, external, tag 2000 (evpn)
*via 3.3.3.3%default, [200/0], 00:16:20, bgp-1000, internal, tag 1000 (evpn)
Table 2 EVPN and VXLAN interoperability analysis
H3C |
Huawei |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 3, configure the H3C and Huawei devices as follows:
· Configure the Huawei device as an RR to reflect BGP routes.
# Enable L2VPN.
# Configure OSPF.
[SwitchA]ospf 1
[SwitchA] interface HundredGigE 1/0/3
[SwitchA-HundredGigE1/0/3] ip address 31.1.1.1 255.255.255.0
[SwitchA-HundredGigE1/0/3] ospf 1 area 0.0.0.0
[SwitchA-HundredGigE1/0/3] quit
[SwitchA]interface HundredGigE 1/0/6
[SwitchA-HundredGigE1/0/6] ip address 61.1.1.1 24
[SwitchA-HundredGigE1/0/6] ospf 1 area 0
[SwitchA-HundredGigE1/0/6] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
# On HundredGigE 1/0/20, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface HundredGigE 1/0/20
[SwitchA-HundredGigE1/0/20] service-instance 1
[SwitchA-HundredGigE1/0/20-srv1000] encapsulation s-vid 1001
[SwitchA-HundredGigE1/0/20-srv1000] xconnect vsi v1
[SwitchA-HundredGigE1/0/20-srv1000] quit
# Create VSI-interface 16383 and associate it with VPN instance vpn1 and L3VNI 16383.
[SwitchA] interface vsi-interface 16383
[SwitchA-Vsi-interface3] l3-vni 16383
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB]
[SwitchB] interface HundredGigE 1/0/2
[SwitchB-HundredGigE1/0/2] ip address 21.0.0.1 24
[SwitchB-HundredGigE1/0/2] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/2] quit
[SwitchB]interface HundredGigE 1/0/6
[SwitchB-HundredGigE1/0/6] ip address 61.1.1.2 24
[SwitchB-HundredGigE1/0/6] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/6] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 100
[SwitchB] interface HundredGigE 1/0/20
[SwitchB-HundredGigE1/0/20] service-instance 1
[SwitchB-HundredGigE1/0/20-srv1000] encapsulation s-vid 1001
[SwitchB-HundredGigE1/0/20-srv1000] xconnect vsi v1
[SwitchB-HundredGigE1/0/20-srv1000] quit
[SwitchB-Vsi-interface1] ip address 100.0.0.1 24
[SwitchB] interface vsi-interface 16383
[SwitchB-Vsi-interface3] l3-vni 16383
[SwitchB] vsi v1
# View device information. Huawei CE6865-48S8CQ-EI is used as an example.
<HUAWEI> display version
Huawei Versatile Routing Platform Software
VRP (R) software, Version 8.191 (CE6865EI V200R019C10SPC800)
Copyright (C) 2012-2020 Huawei Technologies Co., Ltd.
HUAWEI CE6865-48S8CQ-EI uptime is 3 days, 18 hours, 29 minutes
CE6865-48S8CQ-EI(Master) 1 : uptime is 3 days, 18 hours, 28 minutes
StartupTime 2022/06/23 19:58:16
Memory Size : 4096 M bytes
Flash Size : 2048 M bytes
CE6865-48S8CQ-EI version information
1. PCB Version : CEM48S8CQP04 VER A
2. MAB Version : 1
3. Board Type : CE6865-48S8CQ-EI
4. CPLD1 Version : 102
5. CPLD2 Version : 102
6. BIOS Version : 205
# Configure OSPF.
<HUAWEI> sys immediately
Enter system view, return user view with return command.
[HUAWEI] ospf 1
[HUAWEI-ospf-1-area-0.0.0.0] quit
[HUAWEI-ospf-1] quit
[HUAWEI] interface 100GE 1/0/1
[HUAWEI-100GE1/0/1] undo portswitch
[HUAWEI-100GE1/0/1] ip address 31.1.1.2 24
[HUAWEI-100GE1/0/1] ospf enable 1 area 0
[HUAWEI-100GE1/0/1] quit
[HUAWEI] interface 100GE 1/0/2
[HUAWEI-100GE1/0/2] undo portswitch
[HUAWEI-100GE1/0/2] ip address 21.1.1.2 24
[HUAWEI-100GE1/0/2] ospf enable 1 area 0
[HUAWEI-100GE1/0/2] quit
[HUAWEI]interface LoopBack 0
[HUAWEI-LoopBack0] ip address 1.1.1.1 32
[HUAWEI-LoopBack0] ospf enable 1 area 0
[HUAWEI-LoopBack0] quit
# Enable EVPN as the control plane of VXLAN.
[HUAWEI] evpn-overlay enable
[HUAWEI] bgp 100
[HUAWEI-bgp] peer 2.2.2.2 as-number 100
[HUAWEI-bgp] peer 2.2.2.2 connect-interface LoopBack 0
[HUAWEI-bgp] peer 3.3.3.3 as-number 100
[HUAWEI-bgp] peer 3.3.3.3 connect-interface LoopBack 0
[HUAWEI-bgp] l2vpn-family evpn
[HUAWEI-bgp-af-evpn] peer 2.2.2.2 enable
Warning: This operation will reset the peer session. Continue? [Y/N]:y
[HUAWEI-bgp-af-evpn] peer 2.2.2.2 reflect-client
[HUAWEI-bgp-af-evpn] peer 3.3.3.3 enable
[HUAWEI-bgp-af-evpn] peer 3.3.3.3 reflect-client
[HUAWEI-bgp-af-evpn] undo policy vpn-target
[HUAWEI-bgp-af-evpn] quit
[HUAWEI-bgp] quit
# Create VLAN 1001.
[HUAWEI] vlan 1001
[HUAWEI-vlan1001] quit
# Configure service access.
[HUAWEI] bridge-domain 1001
[HUAWEI-bd1001] quit
[HUAWEI] interface 100GE 1/0/6.1 mode l2
[HUAWEI-100GE1/0/6.1] encapsulation dot1q vid 1001
[HUAWEI-100GE1/0/6.1] bridge-domain 1001
[HUAWEI-100GE1/0/6.1] quit
# Configure VPN instance vpn1 and an EVPN instance.
[HUAWEI] ip vpn-instance vpn1
[HUAWEI-vpn-instance-vpn1] vxlan vni 16383
[HUAWEI-vpn-instance-vpn1] ipv4-family
[HUAWEI-vpn-instance-vpn1-af-ipv4] route-distinguisher 1.1.1.1:10001
[HUAWEI-vpn-instance-vpn1-af-ipv4] vpn-target 65001:10001
IVT Assignment result:
Info: VPN-Target assignment is successful.
EVT Assignment result:
[HUAWEI-vpn-instance-vpn1-af-ipv4]vpn-target 65001:10001 evpn
[HUAWEI-vpn-instance-vpn1-af-ipv4] quit
[HUAWEI-vpn-instance-vpn1] quit
[HUAWEI-bd1001] vxlan vni 10001
[HUAWEI-bd1001] evpn
[HUAWEI-bd1001-evpn] route-distinguisher 1.1.1.1:10001
[HUAWEI-bd1001-evpn] vpn-target 65001:10001
[HUAWEI-bd1001-evpn] quit
# Enable head-end replication.
[HUAWEI] int Nve 1
Info: Ensure that the IP addresses and MAC addresses of the NVE interfaces on Devices are the same, as they are dual-active gateways using M-LAG.
[HUAWEI-Nve1] source 1.1.1.1
[HUAWEI-Nve1] vni 10001 head-end peer-list protocol bgp
[HUAWEI-Nve1] quit
# Configure a loopback interface and a Layer 3 VXLAN gateway.
[HUAWEI] int Eth-Trunk 1
[HUAWEI-Eth-Trunk1] service type tunnel
[HUAWEI-Eth-Trunk1] quit
[HUAWEI] int 100 1/0/5
[HUAWEI-100GE1/0/5] eth-trunk 1
[HUAWEI-100GE1/0/5] quit
[HUAWEI] int Vbdif 1001
[HUAWEI-Vbdif10] ip binding vpn-instance vpn1
Info: All IPv4 and IPv6 related configurations on this interface are removed.
[HUAWEI-Vbdif10] ip address 100.0.0.1 24
[HUAWEI-Vbdif10] mac-address 0000-2017-0001
Info: When configuring IP and MAC addresses on a VBDIF interface to implement M-LAG dual-active gateways, you must configure a virtual MAC address.
[HUAWEI-Vbdif10] arp distribute-gateway enable
[HUAWEI-Vbdif10] arp collect host enable
[HUAWEI-Vbdif10] quit
1.1.1.1 100 3053 2675 0 5 0043h54m Established
VSI name: v1
3.3.3.3:10001 61.1.1.2 3.3.3.3 VXLAN 10001
Destinations : 11 Routes : 11
100.0.0.102/32 BGP 255 0 3.3.3.3 Vsi16383
Flags: E - with valid ESI A - AD ready L - Local ES exists
VPN instance:vpn1 Local L3VNI:16383
IP address Nexthop Outgoing interface NibID Flags
100.0.0.102 3.3.3.3 Vsi-interface16383 0x18000000 -
G - Gateway S - Static M - Mapping I - Invalid
E - Multihoming ES sync F - Leaf
100.0.0.1 0000-2017-0001 78aa-8233-2201 0 GL
100.0.0.101 0010-9400-0001 78aa-8233-2201 0 DL
100.0.0.102 0010-9400-0002 741f-4aa1-2508 0 B
VSI name: v1
MAC address : 0010-9400-0001
Link ID/Name : 0x0
Flags : DL
Encap : VXLAN
Next hop : -
Color : -
MAC address : 0000-2017-0001
Link ID/Name : Tunnel1
Flags : BS
Encap : VXLAN
Next hop : 1.1.1.1
Color : -
MAC address : 0010-9400-0002
Link ID/Name : Tunnel0
Flags : B
Encap : VXLAN
Next hop : 3.3.3.3
Color : -
Tunnel Name Link ID State Type Flood Proxy
Tunnel0 0x50000000 UP Auto Disabled
Tunnel1 0x50000001 UP Auto Disabled
VXLAN ID: 16383, VSI name: Auto_L3VNI16383_16383
[SwitchA]display arp suppression vsi
IP address MAC address VSI Name Link ID Aging(min)
100.0.0.101 0010-9400-0001 v1 0x0 22
100.0.0.102 0010-9400-0002 v1 0x50000000 N/A
VSI Name: Auto_L3VNI16383_16383
VSI Index : 16383
VSI State : Down
MTU : 1500
Diffserv Mode : -
Broadcast Restrain : 4294967295 kbps
Multicast Restrain : 4294967295 kbps
Unknown Unicast Restrain: 4294967295 kbps
MAC Table Limit : -
Drop Unknown : -
PW Redundancy Mode : Slave
Flooding : Enabled
Gateway Interface : VSI-interface 16383
VXLAN ID : 16383
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
HGE1/0/20 srv1 0x0 Up Manual
Statistics: Disabled
BGP local router ID: 61.1.1.2
1.1.1.1 100 3253 3047 0 6 0046h35m Established
VSI name: v1
Destinations : 13 Routes : 13
100.0.0.101/32 BGP 255 0 2.2.2.2 Vsi16383
100.0.0.101 2.2.2.2 Vsi-interface16383 0x18000000 -
100.0.0.1 0000-2017-0001 741f-4aa1-2508 0 GL
100.0.0.101 0010-9400-0001 78aa-8233-2201 0 B
100.0.0.102 0010-9400-0002 741f-4aa1-2508 0 DL
VSI name: v1
MAC address Link ID/Name Flags Nexthop
0000-2017-0001 Tunnel1 BS 1.1.1.1
0010-9400-0001 Tunnel0 B 2.2.2.2
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16383
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
HGE1/0/20 srv1 0 Up Manual
· Huawei device
[HUAWEI] display bgp evpn peer
Status codes: * - Dynamic
BGP local router ID : 1.1.1.1
Local AS number : 100
Total number of peers : 2
Peers in established state : 2
Total number of dynamic peers : 0
Peer V AS MsgRcvd MsgSent OutQ Up/Down State PrefRcv
2.2.2.2 4 100 2848 3248 0 0046h31m Established 3
3.3.3.3 4 100 3041 3247 0 0046h31m Established 3
# Verify that the EVPN instance configuration is correct.
[HUAWEI] display evpn vpn-instance name 1001
EVPN-Instance Name RD Address-family
1001 1.1.1.1:10001 evpn
[HUAWEI] display ip routing-table vpn-instance vpn1
Proto: Protocol Pre: Preference
Route Flags: R - relay, D - download to fib, T - to vpn-instance, B - black hole route
Routing Table : vpn1
Destinations : 6 Routes : 6
Destination/Mask Proto Pre Cost Flags NextHop Interface
100.0.0.0/24 Direct 0 0 D 100.0.0.1 Vbdif1001
100.0.0.1/32 Direct 0 0 D 127.0.0.1 Vbdif1001
100.0.0.101/32 IBGP 255 0 RD 2.2.2.2 VXLAN
100.0.0.102/32 IBGP 255 0 RD 3.3.3.3 VXLAN
100.0.0.255/32 Direct 0 0 D 127.0.0.1 Vbdif1001
255.255.255.255/32 Direct 0 0 D 127.0.0.1 InLoopBack0
[HUAWEI] display vxlan tunnel
Number of vxlan tunnel : 2
Tunnel ID Source Destination State Type Uptime
4026531842 1.1.1.1 2.2.2.2 up dynamic 0046h01m
4026531843 1.1.1.1 3.3.3.3 up dynamic 0046h01m
As shown in Figure 4, configure the H3C and Huawei devices as follows:
· Configure the Huawei device as a distributed EVPN gateway.
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
[SwitchA-bgp-default] peer 1.1.1.1 as-number 200
[SwitchA-bgp-default] peer 3.3.3.3 as-number 200
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB] interface HundredGigE 1/0/6
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 1.1.1.1 as-number 200
[SwitchB-bgp-default] peer 2.2.2.2 as-number 100
[SwitchB] vsi v1
2. MAB Version : 1
# Configure OSPF.
<HUAWEI>sys immediately
[HUAWEI] ospf 1
[HUAWEI] interface LoopBack 0
[HUAWEI] bgp 200
[HUAWEI-bgp] peer 2.2.2.2 ebgp-max-hop 10
[HUAWEI-bgp] peer 3.3.3.3 as-number 200
[HUAWEI-bgp] quit
# Create VLAN 1001.
[HUAWEI] vlan 1001
[HUAWEI] interface Nve 1
[HUAWEI-Nve1] quit
[HUAWEI] interface Eth-Trunk 1
[HUAWEI]interface 100GE 1/0/5
[HUAWEI] interface Vbdif 1001
1.1.1.1 200 5 14 0 2 00:00:44 Established
3.3.3.3 200 9 9 0 5 00:00:53 Established
VSI name: v1
1.1.1.1:10001 1.1.1.1 3.3.3.3 VXLAN 10001
VSI name: v1
Link ID/Name : 0x0
Flags : DL
Encap : VXLAN
Next hop : -
Color : -
Flags : B
Encap : VXLAN
Next hop : 3.3.3.3
Color : -
Flags : BS
Encap : VXLAN
Next hop : 3.3.3.3
Color : -
VXLAN ID: 10001, VSI name: v1, Total tunnels: 1 (1 up, 0 down, 0 defect, 0 blocked)
[SwitchA]dis arp suppression vsi
100.0.0.101 0010-9400-0001 v1 0x0 24
VSI Index : 16383
VSI State : Down
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16383
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
1.1.1.1 200 27 41 0 2 00:14:58 Established
2.2.2.2 100 20 18 0 3 00:08:48 Established
VSI name: v1
[SwitchB]display evpn route arp
VSI name: v1
100.0.0.102 0010-9400-0002 v1 0x0 16
100.0.0.101 0010-9400-0001 v1 0x5000000 N/A
VSI Index : 1
VSI State : Down
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16383
VSI Name: v1
VSI Index : 0
VSI State : Up
MTU : 1500
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
· Huawei device
Local AS number : 200
2.2.2.2 4 100 24 12 0 00:06:58 Established 3
3.3.3.3 4 200 38 25 0 00:13:17 Established 6
100.0.0.101/32 EBGP 255 0 RD 2.2.2.2 VXLAN
4026531845 1.1.1.1 3.3.3.3 up dynamic 00:14:12
4026531846 1.1.1.1 2.2.2.2 up dynamic 00:08:01
Table 3 EVPN and VXLAN interoperability analysis
H3C |
Ruijie |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 5, configure the H3C and Ruijie devices as follows:
· Configure the Ruijie device as an RR to reflect BGP routes.
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA-HundredGigE1/0/6] ospf 1 area 0.0.0.0
[SwitchA]interface HundredGigE 1/0/5
[SwitchA-HundredGigE1/0/5] ip address 51.1.1.1 24
[SwitchA-HundredGigE1/0/5] ospf 1 area 0
[SwitchA-HundredGigE1/0/5] quit
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
# On HundredGigE 1/0/11, create Ethernet service instance 1 to match VLAN 1001.
[SwitchA] interface HundredGigE 1/0/11
[SwitchA-HundredGigE1/0/11] service-instance 1
[SwitchA-HundredGigE1/0/11-srv1000] encapsulation s-vid 1001
[SwitchA-HundredGigE1/0/11-srv1000] xconnect vsi v1
[SwitchA-HundredGigE1/0/11-srv1000] quit
[SwitchA-Vsi-interface1] ip address 100.0.0.1 24
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB] interface HundredGigE 1/0/3
[SwitchB-HundredGigE1/0/3] ip address 110.0.0.1 24
[SwitchB-HundredGigE1/0/3] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/3] quit
[SwitchB] interface HundredGigE 1/0/5
[SwitchB-HundredGigE1/0/5] ip address 51.1.1.2 24
[SwitchB-HundredGigE1/0/5] ospf 1 area 0.0.0.0
[SwitchB-HundredGigE1/0/5] quit
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 100
[SwitchB]interface HundredGigE 1/0/11
[SwitchB-HundredGigE1/0/11] service-instance 1
[SwitchB-HundredGigE1/0/11-srv1000] encapsulation s-vid 1001
[SwitchB-HundredGigE1/0/11-srv1000] xconnect vsi v1
[SwitchB-HundredGigE1/0/11-srv1000] quit
[SwitchB]vsi v1
[SwitchB-vsi-v1]gateway vsi-interface 1
[SwitchB-vsi-v1]quit
# View device information. Ruijie S6510-48VS8CQ is used as an example.
Ruijie> show version
System description : Ruijie Full 25G Routing Switch(S6510-48VS8CQ) By Ruijie Networks
System start time : 2022-06-10 17:56:53
System uptime : 16:16:51:47
System hardware version : 2.30
System software version : S6500_RGOS 11.0(5)B9P59
System patch number : NA
System serial number : G1QH10Q10637A
System boot version : 1.3.8
Module information:
Slot 0 : RG-S6510-48VS8CQ
Hardware version : 2.30
Boot version : 1.3.8
Software version : S6500_RGOS 11.0(5)B9P59
Serial number : G1QH10Q10637A
Ruijie>enable
Ruijie#configure terminal
Ruijie(config)#switch-mode vxlan slot 0
Ruijie(config)#fabric anycast-gateway-mac 0000.2017.0001
# Configure OSPF.
Ruijie(config)#route ospf 1
Ruijie(config-router)#area 0
Ruijie(config-router)#router-id 1.1.1.1
Ruijie(config-router)#exit
Ruijie(config)#interface loopback 0
Ruijie(config-if-Loopback 0)#ip address 1.1.1.1 32
Ruijie(config-if-Loopback 0)#ip ospf 1 area 0
Ruijie(config-if-Loopback 0)#exit
Ruijie(config)#interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip address 110.0.0.2 24
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf 1 area 0
Ruijie(config-if-HundredGigabitEthernet 0/49)#exit
Ruijie(config)#interface hundredGigabitEthernet 0/51
Ruijie(config-if-HundredGigabitEthernet 0/51)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/51)#ip address 61.1.1.2 24
Ruijie(config-if-HundredGigabitEthernet 0/51)#ip ospf 1 area 0
Ruijie(config-if-HundredGigabitEthernet 0/51)#exit
# Configure the device as a VTEP.
Ruijie(config)#vtep
Ruijie(config-vtep)#source loopback 0
Ruijie(config-vtep)#arp suppress enable
Ruijie(config-vtep)#exit
# Create a VRF.
Ruijie(config)#ip vrf vpn1
Ruijie(config-vrf)#rd 1.1.1.1:10001
Ruijie(config-vrf)#route-target both 65001:10001
Ruijie(config-vrf)#exit
# Configure an overlay router interface.
Ruijie(config)#interface overlayrouter 1
Ruijie(config-if-OverlayRouter 1)#ip vrf forwarding vpn1
Ruijie(config-if-OverlayRouter 1)#ip address 100.0.0.1 24
Ruijie(config-if-OverlayRouter 1)#anycast-gateway
Ruijie(config-if-OverlayRouter 1)#route-in-vni
Ruijie(config-if-OverlayRouter 1)#exit
Ruijie(config)#vxlan 10001
Ruijie(config-vxlan)#extend-vlan 1001
Ruijie(config-vxlan)#router-interface overlayRouter 1
Ruijie(config-vxlan)#arp suppress enable
Ruijie(config-vxlan)#exit
Ruijie(config)#route bgp 100
Ruijie(config-router)#neighbor 2.2.2.2 remote-as 100
Ruijie(config-router)#neighbor 2.2.2.2 update-source Loopback 0
Ruijie(config-router)#neighbor 3.3.3.3 remote-as 100
Ruijie(config-router)#neighbor 3.3.3.3 update-source Loopback 0
Ruijie(config-router)#address-family l2vpn evpn
Ruijie(config-router-af)#neighbor 2.2.2.2 activate
Ruijie(config-router-af)#neighbor 2.2.2.2 route-reflector-client
Ruijie(config-router-af)#neighbor 3.3.3.3 activate
Ruijie(config-router-af)#neighbor 3.3.3.3 route-reflector-client
Ruijie(config-router-af)#exit
# Configure EVPN.
Ruijie(config)#evpn
Ruijie(config-evpn)#vni 10001
Ruijie(config-evpn-vni)#rd 1.1.1.1:10001
Ruijie(config-evpn-vni)#route-target both 65001:10001
Ruijie(config-evpn-vni)#exit
1.1.1.1 100 116 109 0 8 01:30:19 Established
VSI name: v1
Destinations : 7 Routes : 7
100.0.0.103/32 BGP 255 0 3.3.3.3 Vsi16383
100.0.0.103 3.3.3.3 Vsi-interface16383 0x18000000 -
VPN instance: vpna Interface: Vsi-interface1
100.0.0.1 0000-2017-0001 - 3 BGI
100.0.0.101 0010-9400-000e - 3 B
100.0.0.102 0010-9400-000f 743a-2021-ae01 3 DL
100.0.0.103 0010-9400-000d 0000-fc00-0243 3 B
VSI name: v1
MAC address : 0010-9400-000f
Link ID/Name : 0x0
Flags : DL
Encap : VXLAN
Next hop : -
Color : -
MAC address : 0010-9400-000e
Flags : B
Encap : VXLAN
Next hop : 1.1.1.1
Color : -
Link ID/Name : -
Flags : BGI
Encap : VXLAN
Next hop : 1.1.1.1
Color : -
MAC address : 0010-9400-000d
Flags : B
Encap : VXLAN
Next hop : 3.3.3.3
Color : -
Total number of VXLANs: 4
VXLAN ID: 10, VSI name: vpna
VXLAN ID: 1000, VSI name: Auto_L3VNI1000_1000
100.0.0.1 0000-2017-0001 v1 0x50000001 N/A
100.0.0.102 0010-9400-000f v1 0x0 20
100.0.0.103 0010-9400-000d v1 0x50000000 N/A
100.0.0.101 0010-9400-000e v1 0x50000001 N/A
VSI Name: Auto_L3VNI1000_1000
VSI Index : 16383
VSI State : Down
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
Gateway Interface : VSI-interface 1000
VXLAN ID : 1000
VSI Name: v1
VSI Index : 3
VSI State : Up
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
HGE1/0/11 srv1 0x0 Up Manual
· Ruijie device
# Verify that the VXLAN configuration is correct.
Ruijie(config)#show vxlan
VXLAN Total Count: 1
VXLAN Capacity : 4000
VXLAN 10001
Symmetric property : FALSE
Router Interface : overlayrouter 1 (anycast)
Extend VLAN : 1001
VTEP Adjacency Count: 2
VTEP Adjacency List :
Interface Source IP Destination IP Type
OverlayTunnel 6145 1.1.1.1 3.3.3.3 dynamic
OverlayTunnel 6147 1.1.1.1 2.2.2.2 dynamic
As shown in Figure 6, configure the H3C and Ruijie devices as follows:
· Configure the Ruijie device as a distributed EVPN gateway.
# Enable L2VPN.
# Configure OSPF.
[SwitchA] ospf 1
[SwitchA] interface HundredGigE 1/0/6
[SwitchA]interface HundredGigE 0/0/5
# Create VLAN 1001.
[SwitchA] vlan 1001
[SwitchA] vsi v1
[SwitchA] bgp 100
[SwitchA]
[SwitchA]interface vsi-interface 16383
[SwitchA] vsi v1
# Enable L2VPN.
# Configure OSPF.
[SwitchB] ospf 1
[SwitchB]interface HundredGigE 1/0/5
# Create VLAN 1001.
[SwitchB] vlan 1001
[SwitchB] vsi v1
[SwitchB] bgp 200
[SwitchB-bgp-default] peer 2.2.2.2 connect-interface LoopBack0
[SwitchB]ip vpn-instance vpn1
[SwitchB] vsi v1
Module information:
Ruijie>enable
# Configure OSPF.
Ruijie(config)#vtep
# Create a VRF.
Ruijie(config)#route bgp 200
Ruijie(config-router)#neighbor 2.2.2.2 ebgp-multihop 10
Ruijie(config-router)#neighbor 3.3.3.3 remote-as 200
# Configure EVPN.
Ruijie(config)#evpn
1.1.1.1 200 31 42 0 6 00:18:08 Established
3.3.3.3 200 34 39 0 6 00:18:05 Established
VSI name: v1
VSI name: v1
Link ID/Name : 0x0
Flags : DL
Encap : VXLAN
Next hop : -
Color : -
Flags : B
Encap : VXLAN
Next hop : 1.1.1.1
Color : -
Link ID/Name : -
Flags : BGI
Encap : VXLAN
Next hop : 1.1.1.1
Color : -
Flags : B
Encap : VXLAN
Next hop : 3.3.3.3
Color : -
100.0.0.102 0010-9400-000f v1 0x0 24
VSI Index : 16382
VSI State : Down
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Enabled
VXLAN ID : 16383
VSI Name: v1
VSI Index : 3
VSI State : Up
MTU : 1500
Diffserv Mode : -
MAC Table Limit : -
Drop Unknown : -
Flooding : Disabled
VXLAN ID : 10001
Tunnels:
ACs:
· Ruijie device
VXLAN 10001
Extend VLAN : 1001
OverlayTunnel 6145 1.1.1.1 2.2.2.2 dynamic
OverlayTunnel 6147 1.1.1.1 16.1.105.99 dynamic
The STP, RSTP, and MSTP protocols supported by H3C are standard protocols defined in IEEE. Among the spanning tree protocols supported by Cisco, MSTP is a standard protocol, and Rapid PVST is a Cisco proprietary protocol.
As shown in Table 4, interoperation between H3C spanning tree protocols and Cisco spanning tree protocols is as follows:
· H3C MSTP can completely interoperate with Cisco MSTP.
To implement interoperation, first make sure the region configuration is the same on the connected H3C switches and Cisco switches. Additionally, you must execute the stp config-digest-snooping command on the H3C switches, and enable digest snooping on each interface connecting to a Cisco switch.
Additionally, on an H3C device, the MSTP BPDU format is legacy in Comware 5 and 802.1s in Comware 7. On a Cisco device, you must execute the spanning-tree mst pre-standard (legacy) command or the no spanning-tree mst pre-standard (802.1s) command to set the MSTP BPDU format to legacy or 802.1s, so that the H3C device and the Cisco device have the same MSTP BPDU format.
· H3C MSTP can partially interoperate with Cisco Rapid PVST.
If an H3C device is connected to a Cisco device through an access port, the H3C device will consider the Cisco device as an IEEE802.1D-capable device and perform spanning tree calculation normally. If an H3C device is connected to a Cisco device through a trunk port, a standard STP-capable H3C device can interoperate with a Rapid PVST-capable Cisco device in VLAN 1. However, in another VLAN, a standard STP-capable device cannot recognize Rapid PVST BPDUs. In this case, physical loops must be blocked on the standard STP-capable device, and the ports in blocking state must be on the standard STP-capable device (H3C) rather than on the Rapid PVST-capable device (Cisco). If you cannot do that, broadcast storms exist in VLANs other than VLAN 1.
Table 4 MSTP/PVST interoperability analysis
H3C |
Cisco |
Interoperability |
STP mode |
MSTP mode (legacy/802.1s encapsulation) |
Supported in instance 0 |
STP mode |
Rapid PVST mode |
Supported when Rapid PVST is not disabled for VLAN 1 on the Cisco device |
RSTP mode |
RSTP mode |
Rapid PVST mode |
MSTP mode |
Supported when the stp config-digest-snooping command is executed on an H3C device |
MSTP mode |
Rapid PVST mode |
As shown in Figure 7, an H3C device and a Cisco device are interconnected through two links. Configure MSTP on the H3C device and Cisco device to implement MSTP interoperability.
· Configure the H3C device
# Create VLAN-interface 2, and assign an IP address and subnet mask to the interface.
<H3C> system-view
[H3C] vlan 2
[H3C-vlan2] quit
[H3C] interface Vlan-interface 2
[H3C-Vlan-interface2] ip address 16.1.11.55 255.255.255.0
[H3C-Vlan-interface2] quit
# Enable digest snooping on GigabitEthernet 1/0/1.
[H3C] interface gigabitethernet 1/0/1
[H3C-GigabitEthernet1/0/1] stp config-digest-snooping
# Set the link type of GigabitEthernet 1/0/1 to trunk, and assign it to VLAN 2.
[H3C-GigabitEthernet1/0/1] port link-type trunk
[H3C-GigabitEthernet1/0/1] port trunk permit vlan 2
[H3C-GigabitEthernet1/0/1] quit
# Enable digest snooping on GigabitEthernet 1/0/2.
[H3C] interface gigabitethernet 1/0/2
[H3C-GigabitEthernet1/0/2] stp config-digest-snooping
# Set the link type of GigabitEthernet 1/0/2 to trunk, and assign it to VLAN 2.
[H3C-GigabitEthernet1/0/2] port link-type trunk
[H3C-GigabitEthernet1/0/2] port trunk permit vlan 2
[H3C-GigabitEthernet1/0/2] quit
# Enable digest snooping globally.
[H3C] stp global config-digest-snooping
# Enable the spanning tree protocol globally.
[H3C] stp global enable
NOTE: To ensure the consistency of the path cost calculation standard on the H3C switch and third-party switch, first check the path cost calculation standard of the third-party switch and then configure the standard on the H3C switch. |
# When the Cisco device uses the default path cost calculation standard, you must configure the H3C switch to calculate the default path cost by using the IEEE 802.1D-1998 standard.
[H3C] stp pathcost-standard dot1d-1998
# View information about this device.
This section takes a Cisco Nexus9000 C9236C device as an example.
Cisco# show version
Copyright (C) 2002-2017, Cisco and/or its affiliates.
All rights reserved.
Software
BIOS: version 07.56
NXOS: version 7.0(3)I4(6)
NXOS image file is: bootflash:///nxos.7.0.3.I4.6.bin
NXOS compile time: 3/9/2017 22:00:00 [03/10/2017 07:05:18]
Hardware
cisco Nexus9000 C9236C chassis
Intel(R) Xeon(R) CPU @ 1.80GHz with 16400984 kB of memory.
Processor Board ID FDO20511FC7
Device name: switch
Kernel uptime is 17 day(s), 20 hour(s), 9 minute(s), 30 second(s)
Last reset
Reason: Unknown
System version: 7.0(3)I4(6)
Service:
plugin
Active Package(s):
# Enter VLAN-interface 2 configuration mode, and assign an IP address to it.
Cisco(config)# interface vlan 2
Cisco(config-if)#ip address 16.1.11.56 255.255.255.0
Cisco(config-if)#exit
# Set the link type of Ethernet 1/11 to trunk, and assign it to VLAN 2.
Cisco(config)# interface Ethernet 1/11
Cisco(config-if)# switchport access vlan 2
Cisco(config-if)# switchport trunk allowed vlan 2
# Set the link type of Ethernet 1/13 to trunk, and assign it to VLAN 2.
Cisco(config-if)# interface Ethernet 1/13
Cisco(config-if)# end
# On the H3C device, display the brief spanning tree status and statistics.
[H3C] display stp brief
MST ID Port Role TP State Protection
0 GigabitEthernet1/0/1 DESI FORWARDING NONE
0 GigabitEthernet1/0/2 DESI FORWARDING NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on GigabitEthernet 1/0/2.
[H3C ] display stp instance 0 interface gigabitethernet 1/0/2
-------[CIST Global Info][Mode MSTP]-------
Bridge ID : 32768.1cab-3496-09f6
Bridge times : Hello 2s MaxAge 20s FwdDelay 15s MaxHops 20
Root ID/ERPC : 32768.1cab-3496-09f6, 0
RegRoot ID/IRPC : 32768.1cab-3496-09f6, 0
RootPort ID : 0.0
BPDU-Protection : Disabled
Bridge Config-
Digest-Snooping : Enabled
TC or TCN received : 2
Time since last TC : 0 days 0h:34m:14s
----[Port391(GigabitEthernet1/0/2)][FORWARDING]----
Port protocol : Enabled
Port role : Designated Port
Port ID : 128.391
Port cost(Legacy) : Config=auto, Active=1
Desg.bridge/port : 32768.1cab-3496-09f6, 128.391
Port edged : Config=disabled, Active=disabled
Point-to-Point : Config=auto, Active=true
Transmit limit : 10 packets/hello-time
TC-Restriction : Disabled
Role-Restriction : Disabled
Protection type : Config=none, Active=none
MST BPDU format : Config=auto, Active=802.1s
Port Config-
Rapid transition : False
Num of VLANs mapped : 2
Port times : Hello 2s MaxAge 20s FwdDelay 15s MsgAge 0s RemHops 20
BPDU sent : 1784
TCN: 0, Config: 0, RST: 0, MST: 1784
BPDU received : 0
TCN: 0, Config: 0, RST: 0, MST: 0
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on GigabitEthernet 1/0/1.
[H3C] display stp instance 0 interface gigabitethernet 1/0/1
RootPort ID : 0.0
Bridge Config-
Time since last TC : 0 days 0h:34m:21s
----[Port381(GigabitEthernet1/0/1)][FORWARDING]----
Port role : Designated Port (Boundary)
Port ID : 128.381
Desg.bridge/port : 32768.1cab-3496-09f6, 128.381
Port Config-
BPDU sent : 1787
TCN: 0, Config: 0, RST: 0, MST: 1787
BPDU received : 2
TCN: 0, Config: 0, RST: 2, MST: 0
Interoperation with Huawei devices
Interoperability analysis
Table 5 MSTP/PVST interoperability analysis
H3C |
Huawei |
Interoperability |
MSTP mode |
MSTP mode |
Supported |
As shown in Figure 8, an H3C device and a Huawei device are interconnected through two links. Configure MSTP on the H3C device and Huawei device to implement MSTP interoperability.
<H3C>system-view
# Create VLAN-interface 10, and assign an IP address and subnet mask to the interface.
[H3C] vlan 10
[H3C-vlan10] quit
[H3C]interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 255.255.255.0
[H3C-Vlan-interface10] quit
# Enable digest snooping on HundredGigE 1/0/1.
[H3C]interface HundredGigE 1/0/1
[H3C-HundredGigE1/0/1] stp config-digest-snooping
# Set the link type of HundredGigE 1/0/1 to trunk, and assign it to VLAN 10.
[H3C-HundredGigE1/0/1] port link-type trunk
[H3C-HundredGigE1/0/1] port trunk permit vlan 10
[H3C-HundredGigE1/0/1] quit
# Enable digest snooping on HundredGigE 1/0/2.
[H3C]interface HundredGigE 1/0/2
[H3C-HundredGigE1/0/2] stp config-digest-snooping
# Set the link type of HundredGigE 1/0/2 to trunk, and assign it to VLAN 10.
[H3C-HundredGigE1/0/2] port link-type trunk
[H3C-HundredGigE1/0/2] port trunk permit vlan 10
[H3C-HundredGigE1/0/2] quit
# When the Huawei device uses the default path cost calculation standard, you must configure the H3C switch to calculate the default path cost by using the IEEE 802.1t standard.
[H3C] stp pathcost-standard dot1t
This section takes a Huawei CE6865-48S8CQ-EI device as an example.
2. MAB Version : 1
# Enable STP, RSTP, or MSTP on the device.
<HUAWEI>system-view immediately
[HUAWEI]stp enable
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
[HUAWEI]interface vlanif 10
[HUAWEI-Vlanif10]ip address 100.0.0.2 24
[HUAWEI-Vlanif10]quit
# Assign 100GE 1/0/1 to VLAN10.
[HUAWEI]interface 100GE 1/0/1
[HUAWEI-100GE1/0/1]port link-type trunk
[HUAWEI-100GE1/0/1]port trunk allow-pass vlan 10
[HUAWEI-100GE1/0/1]quit
# Assign 100GE 1/0/2 to VLAN10.
[HUAWEI]interface 100GE 1/0/2
[HUAWEI-100GE1/0/2]port link-type trunk
[HUAWEI-100GE1/0/2]port trunk allow-pass vlan 10
[HUAWEI-100GE1/0/2]quit
MST ID Port Role STP State Protection
0 HundredGigE1/0/1 DESI FORWARDING NONE
0 HundredGigE1/0/2 DESI FORWARDING NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on HundredGigE 1/0/1.
[H3C] display stp instance 0 interface HundredGigE 1/0/1
Bridge ID : 32768.743a-2021-ae00
Root ID/ERPC : 32768.743a-2021-ae00, 0
RegRoot ID/IRPC : 32768.743a-2021-ae00, 0
RootPort ID : 0.0
Bridge Config-
TC or TCN received : 0
Time since last TC : 0 days 0h:41m:50s
----[Port51(HundredGigE1/0/1)][FORWARDING]----
Port ID : 128.51
Desg.bridge/port : 32768.743a-2021-ae00, 128.51
Port Config-
Rapid transition : True
BPDU sent : 1256
TCN: 0, Config: 0, RST: 0, MST: 1256
BPDU received : 3
TCN: 0, Config: 0, RST: 0, MST: 3
Interoperation with Ruijie devices
Table 6 MSTP/PVST interoperability analysis
H3C |
Ruijie |
Interoperability |
MSTP mode |
MSTP mode |
Supported |
As shown in Figure 9, an H3C device and a Ruijie device are interconnected through two links. Configure MSTP on the H3C device and Ruijie device to implement interoperability.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 24
# Set the link type of HundredGigE 1/0/3 to trunk, and assign it to VLAN 10.
[H3C] interface HundredGigE 1/0/3
[H3C-HundredGigE1/0/3] port link-type trunk
[H3C-HundredGigE1/0/3] port trunk permit vlan 10
# Enable digest snooping on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] stp config-digest-snooping
[H3C-HundredGigE1/0/3] quit
# Set the link type of HundredGigE 1/0/4 to trunk, and assign it to VLAN 10.
[H3C]interface HundredGigE 1/0/4
[H3C-HundredGigE1/0/4] port link-type trunk
[H3C-HundredGigE1/0/4] port trunk permit vlan 10
# Enable digest snooping on HundredGigE 1/0/4.
[H3C-HundredGigE1/0/4] stp config-digest-snooping
[H3C-HundredGigE1/0/4] quit
# When the Ruijie device uses the default path cost calculation standard, you must configure the H3C switch to calculate the default path cost by using the IEEE 802.1t standard.
This section takes a Ruijie S6510-48VS8CQ device as an example.
Ruijie>show version
Module information:
# Enable the spanning tree protocol.
Ruijie>enable
Ruijie(config)#spanning-tree
# Assign an IP address to VLAN-interface 10.
Ruijie(config)#interface vlan 10
Ruijie(config-if-VLAN 10)#ip address 100.0.0.2 24
Ruijie(config-if-VLAN 10)#no shutdown
Ruijie(config-if-VLAN 10)#exit
# Set the link type of HundredGigabitEthernet 0/49 to trunk, and assign it to VLAN 10.
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport mode trunk
Ruijie(config-if-HundredGigabitEthernet 0/49)#switchport trunk allowed vlan only 10
Ruijie(config-if-HundredGigabitEthernet 0/49)#no shutdown
# Set the link type of HundredGigabitEthernet 0/50 to trunk, and assign it to VLAN 10.
Ruijie(config)#interface hundredGigabitEthernet 0/50
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport mode trunk
Ruijie(config-if-HundredGigabitEthernet 0/50)#switchport trunk allowed vlan only 10
Ruijie(config-if-HundredGigabitEthernet 0/50)#no shutdown
Ruijie(config-if-HundredGigabitEthernet 0/50)#exit
0 HundredGigE1/0/3 DESI FORWARDING NONE
0 HundredGigE1/0/4 DESI FORWARDING NONE
# On the H3C device, display the brief spanning tree status and statistics of MSTI 0 on HundredGigE 1/0/3.
[H3C] display stp instance 0 interface HundredGigE 1/0/3
Bridge ID : 32768.0000-fc00-0242
Root ID/ERPC : 32768.0000-fc00-0242, 0
RegRoot ID/IRPC : 32768.0000-fc00-0242, 0
RootPort ID : 0.0
Bridge Config-
Digest-Snooping : Disabled
Time since last TC : 0 days 0h:7m:27s
----[Port5(HundredGigE1/0/3)][FORWARDING]----
Port ID : 128.5
Desg.bridge/port : 32768.0000-fc00-0242, 128.5
Port Config-
BPDU sent : 240
TCN: 0, Config: 0, RST: 0, MST: 240
BPDU received : 1
LACP link aggregation interoperation guide
Interoperation with Cisco devices
Table 7 Interoperability analysis
H3C |
Cisco |
Interoperability |
Static (default) |
On (default) |
Supported |
Dynamic |
Active |
Supported |
Example: Configuring static link aggregation for interoperation
As shown in Figure 10, an H3C device and a Cisco device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Cisco device to increase the link bandwidth and improve link reliability.
# Create Layer 3 aggregate interface 1, and assign an IP address and subnet mask to the interface.
<H3C> system-view
[H3C] interface Route-aggregation 1
[H3C-Route-Aggregation1] ip address 16.1.105.33 24
[H3C-Route-Aggregation1] quit
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/1 to Layer 3 aggregation group 1.
[H3C-GigabitEthernet1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface GigabitEthernet 1/0/2 to Layer 3 aggregation group 1.
[H3C] interface GigabitEthernet 1/0/2
[H3C-GigabitEthernet1/0/2] port link-aggregation group 1
Cisco# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source. This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0 or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
BIOS: version 07.56
BIOS compile time: 06/08/2016
Hardware
Device name: switch
bootflash: 53298520 kB
Last reset
Reason: Unknown
Service:
plugin
Core Plugin, Ethernet Plugin
Active Package(s):
# Assign an IP addresses to a port channel (aggregate interface).
Cisco# configure terminal
Cisco(config)# interface channel-group 1
Cisco(config-if)# ip address 16.1.105.34 255.255.255.0
# Set the aggregation mode to manual (static) for Ethernet 1/3.
Cisco(config)# interface Ethernet 1/3
Cisco(config-if)# channel-group 1 mode on
# Set the aggregation mode to manual (static) for Ethernet 1/5.
Cisco(config-if)# interface Ethernet 1/5
# On the H3C device, display aggregation group details.
[H3C] display link-aggregation verbose
Port: A -- Auto port, M -- Management port, R -- Reference port
G -- Defaulted, H -- Expired
Aggregation Mode: Static
Management VLANs: None
Port Status Priority Oper-Key
GE1/0/1(R) S 32768 1
GE1/0/2 S 32768 1
# On the H3C device, verify that you can successfully ping the remote device.
[H3C ] ping 16.1.105.34
Ping 16.1.105.34 (16.1.105.34): 56 data bytes, press CTRL_C to break
56 bytes from 16.1.105.34: icmp_seq=0 ttl=255 time=2.537 ms
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.000 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=1.935 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.044 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.143 ms
--- Ping statistics for 16.1.105.34 ---
round-trip min/avg/max/std-dev = 1.935/2.132/2.537/0.214 ms
Example: Configuring dynamic link aggregation for interoperation
As shown in Figure 11, an H3C device and a Cisco device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic link aggregation on the H3C device and Cisco device to increase the link bandwidth and improve link reliability.
<H3C> system-view
# Configure Layer 3 aggregate interface 1 to operate in dynamic aggregation mode.
[H3C-Route-Aggregation1] link-aggregation mode dynamic
Cisco# show version
Software
BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
Service:
plugin
Active Package(s):
# Enable LACP.
Cisco(config)# feature lacp
Cisco(config-if)# exit
# Set the LACP mode to active on Ethernet 1/3.
Cisco(config-if)# channel-group 1 mode active
# Set the LACP mode to active on Ethernet 1/5.
Aggregation Mode: Dynamic
System ID: 0x8000, 1cab-3496-09f6
Local:
Port Status Priority Index Oper-Key Flag
GE1/0/1(R) S 32768 1 1 {ACDEF}
GE1/0/2 S 32768 2 1 {ACDEF}
Remote:
Actor Priority Index Oper-Key SystemID Flag
GE1/0/1 32768 265 32768 0x8000, 2c33-113a-eaef {ACDEF}
GE1/0/2 32768 273 32768 0x8000, 2c33-113a-eaef {ACDEF}
[H3C] ping 16.1.105.34
Request time out
56 bytes from 16.1.105.34: icmp_seq=1 ttl=255 time=2.331 ms
56 bytes from 16.1.105.34: icmp_seq=2 ttl=255 time=2.063 ms
56 bytes from 16.1.105.34: icmp_seq=3 ttl=255 time=2.202 ms
56 bytes from 16.1.105.34: icmp_seq=4 ttl=255 time=2.219 ms
5 packet(s) transmitted, 4 packet(s) received, 20.0% packet loss
round-trip min/avg/max/std-dev = 2.063/2.204/2.331/0.095 ms
Table 8 Interoperability analysis
H3C |
Huawei |
Interoperability |
Static (default) |
Normal |
Supported |
Dynamic |
Lacp-Static/lacp-Dynamic |
Supported |
As shown in Figure 12, an H3C device and a Huawei device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Huawei device to increase the link bandwidth and improve link reliability.
<H3C> system-view
[H3C-Route-Aggregation1] ip address 100.0.0.1 24
# Assign Layer 3 Ethernet interface HundredGigE 1/0/1 to Layer 3 aggregation group 1.
[H3C] interface HundredGigE 1/0/1
[H3C-HundredGigE1/0/1] port link-aggregation group 1
# Assign Layer 3 Ethernet interface HundredGigE 1/0/2 to Layer 3 aggregation group 1.
[H3C] interface HundredGigE 1/0/2
[H3C-HundredGigE1/0/2] port link-aggregation group 1
2. MAB Version : 1
# Assign an IP address to interface Eth-Trunk 1.
[HUAWEI-Eth-Trunk1]undo portswitch
[HUAWEI-Eth-Trunk1]ip address 100.0.0.2 24
[HUAWEI-Eth-Trunk1]quit
# Assign 100GE 1/0/1 to Eth-Trunk 1.
[HUAWEI-100GE1/0/1]eth-trunk 1
# Assign 100GE 1/0/2 to Eth-Trunk 1.
[HUAWEI-100GE1/0/2]eth-trunk 1
HGE1/0/1 S 32768 1
HGE1/0/2(R) S 32768 1
[H3C] ping 100.0.0.2
Ping 100.0.0.2 (100.0.0.2): 56 data bytes, press CTRL+C to break
56 bytes from 100.0.0.2: icmp_seq=0 ttl=254 time=0.927 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=254 time=0.614 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=254 time=0.603 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=254 time=1.021 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=254 time=0.631 ms
--- Ping statistics for 100.0.0.2 ---
round-trip min/avg/max/std-dev = 0.603/0.759/1.021/0.178 ms
[H3C] %Oct 19 17:29:07:624 2021 H3C PING/6/PING_STATISTICS: Ping statistics for 100.0.0.2: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 0.603/0.759/1.021/0.178 ms.
As shown in Figure 13, an H3C device and a Huawei device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic link aggregation on the H3C device and Huawei device to increase the link bandwidth and improve link reliability.
<H3C> system-view
[H3C] interface Route-Aggregation 1
2. MAB Version : 1
# Configure Eth-Trunk 1 to operate in dynamic LACP mode.
[HUAWEI]interface Eth-Trunk 1
[HUAWEI-Eth-Trunk1]mode lacp-dynamic
Creation Mode: Manual
System ID: 0x8000, 743a-2021-ae00
Local:
HGE1/0/1(R) S 32768 1 1 {ACDEF}
HGE1/0/2 S 32768 2 1 {ACDEF}
Remote:
HGE1/0/1 32768 1 337 0x8000, a4be-2b3a-50d1 {ACDEF}
HGE1/0/2 32768 2 337 0x8000, a4be-2b3a-50d1 {ACDEF}
56 bytes from 100.0.0.2: icmp_seq=0 ttl=254 time=1.094 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=254 time=0.753 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=254 time=0.666 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=254 time=0.686 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=254 time=0.566 ms
round-trip min/avg/max/std-dev = 0.566/0.753/1.094/0.181 ms
Table 9 Interoperability analysis
H3C |
Ruijie |
Interoperability |
Static (default) |
On (default) |
Supported |
Dynamic |
active |
Supported |
As shown in Figure 14, an H3C device and a Ruijie device are interconnected through their Layer 2 Ethernet interfaces. Configure static link aggregation on the H3C device and Ruijie device to increase the link bandwidth and improve link reliability.
<H3C> system-view
# Assign Layer 3 Ethernet interface HundredGigE 1/0/3 to Layer 3 aggregation group 1.
[H3C-HundredGigE1/0/3] port link-aggregation group 1
# Assign Layer 3 Ethernet interface HundredGigE 1/0/4 to Layer 3 aggregation group 1.
[H3C-HundredGigE1/0/4] port link-aggregation group 1
Ruijie>show version
Module information:
# Enter Aggregateport 1 configuration mode.
Ruijie>enable
Enter configuration commands, one per line. End with CNTL/Z.
Ruijie(config)#interface aggregatePort 1
# Configure the interface as a Layer 3 interface.
Ruijie(config-if-AggregatePort 1)#no switchport
# Assign an IP address to the interface.
Ruijie(config-if-AggregatePort 1)#ip address 100.0.0.2 24
Ruijie(config-if-AggregatePort 1)#exit
# Configure HundredGigabitEthernet 0/ 49 as a Layer 3 interface, and assign it to Aggregateport 1.
Ruijie(config)# interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#port-group 1
# Configure HundredGigabitEthernet 0/ 50 as a Layer 3 interface, and assign it to Aggregateport 1.
Ruijie(config)# interface hundredGigabitEthernet 0/50
Ruijie(config-if-HundredGigabitEthernet 0/50)#no switchport
Ruijie(config-if-HundredGigabitEthernet 0/50)#port-group 1
Role: P -- Primary, S -- Secondary
Port Status Priority Oper-Key Role
HGE1/0/3(R) S 32768 1 None
HGE1/0/4 S 32768 1 None
Ping 100.0.0.2 (100.0.0.2): 56 data bytes, press CTRL_C to break
56 bytes from 100.0.0.2: icmp_seq=0 ttl=64 time=23.359 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=64 time=1.215 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=64 time=1.395 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=64 time=1.237 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=64 time=1.223 ms
round-trip min/avg/max/std-dev = 1.215/5.686/23.359/8.837 ms
As shown in Figure 15, an H3C device and a Ruijie device are interconnected through their Layer 2 Ethernet interfaces. Configure dynamic aggregation on the H3C device and Ruijie device to increase the link bandwidth and improve link reliability.
<H3C>system-view
[H3C]interface HundredGigE 1/0/3
[H3C-HundredGigE1/0/4]port link-aggregation group 1
[H3C-HundredGigE1/0/4]quit
Ruijie>show version
Module information:
Ruijie>enable
# Configure HundredGigabitEthernet 0/ 49 as a Layer 3 interface, and assign it to Aggregateport 1 in active LACP mode.
Ruijie(config-if-HundredGigabitEthernet 0/49)#port-group 1 mode active
# Configure HundredGigabitEthernet 0/ 50 as a Layer 3 interface, and assign it to Aggregateport 1 in active LACP mode.
Ruijie(config-if-HundredGigabitEthernet 0/50)#port-group 1 mode active
Ruijie(config)#
System ID: 0x8000, 0000-fc00-0242
Local:
HGE1/0/3(R) S 32768 1 1 {ACDEF}
HGE1/0/4 S 32768 2 1 {ACDEF}
Remote:
HGE1/0/3 32768 49 1 0x8000, c0b8-e672-cd08 {ACDEF}
HGE1/0/4 32768 50 1 0x8000, c0b8-e672-cd08 {ACDEF}
56 bytes from 100.0.0.2: icmp_seq=0 ttl=64 time=1.596 ms
56 bytes from 100.0.0.2: icmp_seq=1 ttl=64 time=1.342 ms
56 bytes from 100.0.0.2: icmp_seq=2 ttl=64 time=1.376 ms
56 bytes from 100.0.0.2: icmp_seq=3 ttl=64 time=1.354 ms
56 bytes from 100.0.0.2: icmp_seq=4 ttl=64 time=1.299 ms
round-trip min/avg/max/std-dev = 1.299/1.393/1.596/0.104 ms
IS-IS interoperation guide
Table 10 IS-IS interoperability analysis
H3C |
Cisco |
Interoperability |
Supported if the isis small-hello command is configured |
Supported if the no isis hello-padding always command is configured |
Interoperation with Cisco devices is supported only after you configure specific commands, because H3C devices and Cisco devices use different MTU settings. The MTU is 1500 for H3C devices and is 9000 for Cisco devices. |
As shown in Figure 16, the H3C device has a Layer 3 connection to the Cisco device. Establish an IS-IS neighbor relationship between the H3C device and the Cisco device.
Configuring H3C device.
# Enable NSR for IS-IS process 1.
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] non-stop-routing
# Set the IS level to Level-2.
[H3C-isis-1] is-level level-2
# Set the bandwidth reference value to 10000 Mbps for IS-IS process 1.
[H3C-isis-1] bandwidth-reference 100000
# Configure the device to send and receive only wide cost style packets.
[H3C-isis-1] cost-style wide
# Set the maximum SPF calculation interval to 1 second, the minimum SPF calculation interval to 50 milliseconds, and the incremental SPF calculation interval to 50 milliseconds.
[H3C-isis-1] timer spf 1 50 50
# Specify a host name for the local IS.
[H3C-isis-1] is-name 12516
# Configure NET 48.0001.1001.7220.0160.00 for IS-IS process 1.
[H3C-isis-1] network-entity 48.0001.1001.7220.0160.00
[H3C-isis-1] quit
# Assign an IP address to GigabitEthernet1/0/1.501.
[H3C] interface gigabitethernet 1/0/1.501
[H3C-GigabitEthernet1/0/1.501] ip address 172.16.16.46 255.255.255.252
# Enable IS-IS on GigabitEthernet1/0/1.501.
[H3C-GigabitEthernet1/0/1.501] isis enable 1
# Set the network type of GigabitEthernet1/0/1.501 to P2P.
[H3C-GigabitEthernet1/0/1.501] isis circuit-type p2p
# Configure GigabitEthernet1/0/1.501 to send small hello packets.
[H3C-GigabitEthernet1/0/1.501] isis small-hello
[H3C-GigabitEthernet1/0/1.501] quit
# Assign an IP address to GigabitEthernet1/0/1.502.
[H3C] interface gigabitethernet 1/0/1.502
[H3C-GigabitEthernet1/0/1.502] ip address 172.16.16.50 255.255.255.252
# Enable IS-IS on GigabitEthernet1/0/1.502.
[H3C-GigabitEthernet1/0/1.502] isis enable 1
# Set the network type of GigabitEthernet1/0/1.502 to P2P.
[H3C-GigabitEthernet1/0/1.502] isis circuit-type p2p
# Configure GigabitEthernet1/0/1.502 to send small hello packets.
[H3C-GigabitEthernet1/0/1.502] isis small-hello
Take Cisco Nexus9000 C9236C as a configuration example. The device information is as follows:
Cisco# show version
Software
BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
Service:
plugin
Active Package(s):
# Configure IS-IS.
Cisco(config)# router isis 1
Cisco(config-router)# net 48.0001.0000.0000.0001.00
Cisco(config-router)# is-type level-1-2
Cisco(config-router)# address-family ipv4 unicast
Cisco(config-router-af)# default-information originate
Cisco(config-router)# exit
# Configure dot1q encapsulation on Ethernet1/7.501 and assign an IP address to the interface.
Cisco(config-)# interface Ethernet1/7.501
Cisco(config-if)# encapsulation dot1q 501
Cisco(config-if)# ip address 172.16.16.45/30
# Configure IS-IS on Ethernet1/7.501.
Cisco(config-if)# no isis hello-padding always
Cisco(config-if)# isis network point-to-point
Cisco(config-if)# isis circuit-type level-1-2
Cisco(config-if)# ip router isis 1
Cisco(config-if)# no shutdown
# Configure dot1q encapsulation on Ethernet1/7.502 and assign an IP address to the interface.
Cisco(config)# interface Ethernet1/7.502
Cisco(config-if)# encapsulation dot1q 502
Cisco(config-if)# ip address 172.16.16.49/30
# Configure IS-IS on Ethernet1/7.502.
# Configure IS-IS on Ethernet1/7 and assign an IP address to the interface.
Cisco(config-if)# ip address 116.1.1.1/30
# On the H3C device, display IS-IS neighbor information.
[H3C] display isis peer
Peer information for IS-IS(1)
System ID: Cisco
Interface: GE1/0/1.501 Circuit Id: 001
State: Up HoldTime: 27s Type: L2 PRI: --
System ID: Cisco
Interface: GE1/0/1.502 Circuit Id: 001
State: Up HoldTime: 29s Type: L2 PRI: --
# On the H3C device, display all IS-IS routes.
[H3C] display ip routing-table protocol isis
Summary count : 4
ISIS Routing table status : <Active>
Summary count : 2
116.1.1.0/30 IS_L2 15 11 172.16.16.45 GE1/0/1.501
172.16.16.49 GE1/0/1.502
ISIS Routing table status : <Inactive>
Summary count : 2
172.16.16.44/30 IS_L2 15 10 0.0.0.0 GE1/0/1.501
172.16.16.48/30 IS_L2 15 10 0.0.0.0 GE1/0/1.502
Table 11 IS-IS interoperability analysis
H3C |
Huawei |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 17, the H3C device has a Layer 3 connection to the Huawei device. Establish an IS-IS neighbor relationship between the H3C device and the Huawei device.
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
# Assign an IP address to HundredGigE1/0/1.
[H3C-HundredGigE1/0/1] ip address 100.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/1.
[H3C-HundredGigE1/0/1] isis enable 1
# Set the network type of HundredGigE1/0/1 to P2P.
[H3C-HundredGigE1/0/1] isis circuit-type p2p
Configuring Huawei device.
Take Huawei CE6865-48S8CQ-EI as a configuration example. The device information is as follows:
<HUAWEI>display version
2. MAB Version : 1
# Enable IS-IS and enter IS-IS view.
[HUAWEI]isis 1
# Set the IS level to Level-2 for the device.
[HUAWEI-isis-1]is-level level-2
Info: IS-IS level changed. The process 1 will be reset.
# Configure NET 48.0001.1001.7220.0170.00 for the IS-IS process.
[HUAWEI-isis-1]network-entity 48.0001.1001.7220.0170.00
[HUAWEI-isis-1]cost-style wide
Info: Cost style Changed. IS-IS process 1 will be reset.
[HUAWEI-isis-1]quit
# Assign an IP address to 100GE1/0/1.
[HUAWEI-100GE1/0/1]ip address 100.0.0.2 24
# Create IS-IS process 1, and then enable this process on 100GE1/0/1.
[HUAWEI-100GE1/0/1]isis enable 1
# Set the network type of 100GE1/0/1 (broadcast interface) to P2P.
[HUAWEI-100GE1/0/1]isis circuit-type p2p
System ID: 1001.7220.0170
Interface: HGE1/0/1 Circuit Id: 061
State: Up HoldTime: 25s Type: L2 PRI: --
Summary count : 2
Summary count : 0
Summary count : 1
100.0.0.0/24 IS_L2 15 10 0.0.0.0 HGE1/0/1
Table 12 IS-IS interoperability analysis
H3C |
Ruijie |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 18, the H3C device has a Layer 3 connection to the Ruijie device. Establish an IS-IS neighbor relationship between the H3C device and the Ruijie device.
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
# Assign an IP address to HundredGigE1/0/3.
[H3C-HundredGigE1/0/3] ip address 100.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/3.
[H3C-HundredGigE1/0/3] isis enable 1
# Set the network type of HundredGigE1/0/3 to P2P.
[H3C-HundredGigE1/0/3] isis circuit-type p2p
# Assign an IP address to HundredGigE1/0/4.
[H3C] interface HundredGigE 1/0/4
[H3C-HundredGigE1/0/4] ip address 200.0.0.1 24
# Enable IS-IS process 1 on HundredGigE1/0/4.
[H3C-HundredGigE1/0/4] isis enable 1
# Set the network type of HundredGigE1/0/4 to P2P.
[H3C-HundredGigE1/0/4] isis circuit-type p2p
Configuring Ruijie device.
Take Ruijie S6510-48VS8CQ as a configuration example. The device information is as follows:
Ruijie>show version
Module information:
# Create an IS-IS instance.
Ruijie>enable
Ruijie(config)#route isis 1
# Set the NET address for IS-IS.
Ruijie(config-router)#net 48.0001.1001.7220.0170.00
# Specify the IS-IS level.
Ruijie(config-router)#is-type level-1-2
# Configure HundredGigabitEthernet 0/49 to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip address 100.0.0.2 24
# Enable support for IPv4 IS-IS routes on HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip router isis 1
# Set the network type of HundredGigabitEthernet 0/49 (broadcast interface) to P2P.
Ruijie(config-if-HundredGigabitEthernet 0/49)#isis network point-to-point
# Configure HundredGigabitEthernet 0/50 to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie(config-if-HundredGigabitEthernet 0/50)#ip address 200.0.0.2 24
# Enable support for IPv4 IS-IS routes on HundredGigabitEthernet 0/50.
Ruijie(config-if-HundredGigabitEthernet 0/50)#ip router isis 1
# Set the network type of HundredGigabitEthernet 0/50 (broadcast interface) to P2P.
Ruijie(config-if-HundredGigabitEthernet 0/50)#isis network point-to-point
<H3C> display isis peer
Interface: HGE0/0/3 Circuit Id: 001
Interface: HGE1/0/4 Circuit Id: 002
State: Up HoldTime: 26s Type: L2 PRI: --
<H3C> display ip routing-table protocol isis
Summary count : 2
Summary count : 0
Summary count : 2
100.0.0.0/24 IS_L2 15 10 0.0.0.0 HGE1/0/3
200.0.0.0/24 IS_L2 15 10 0.0.0.0 HGE1/0/4
NTP interoperation guide
Table 13 NTP interoperability analysis
H3C |
Cisco |
Interoperability |
NTP server |
NTP client in unicast mode |
Time can be synchronized between H3C and Cisco devices. |
NTP server |
Example: Configuring NTP interoperation with a Cisco device
As shown in Figure 19, an H3C device and a Cisco device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Cisco device as the NTP server to synchronize the time of the H3C device with the Cisco device.
· Configure the H3C device.
# Assign an IP address to GigabitEthernet 1/0/1.
<H3C> system-view
[H3C-GigabitEthernet1/0/1] ip address 16.10.10.11 255.255.255.0
# Enable NTP.
[H3C] ntp-service enable
# Specify NTP for obtaining the time.
[H3C] clock protocol ntp
# Specify the NTP server 16.10.10.10.
[H3C] ntp-service unicast-server 16.10.10.10
· Configure the Cisco device.
# View information about the Cisco device.
The Cisco Nexus9000 C9236C device is used in this example.
Cisco# show version
Software
BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
Service:
plugin
Active Package(s):
# Configure NTP settings.
Cisco(config)# interface Ethernet 1/7
Cisco(config-if)# ip address 16.10.10.10/24
Cisco(config)# feature ntp
Cisco(config)# ntp master
# View the current system date and time on the H3C device.
[H3C] display clock
06:07:42.650 UTC Tue 03/29/2011
# View brief information about all IPv4 NTP sessions on the H3C device.
[H3C] display ntp-service sessions
source reference stra reach poll now offset delay disper
[12345]16.10.10.10 127.127.1.0 9 255 64 22 -2.882 2.9144 2.7313
Total sessions: 1
# View the current system date and time on the Cisco device.
Cisco(config)# show clock
06:06:51.294 UTC Tue Mar 29 2011
Table 14 NTP interoperability analysis
H3C |
Huawei |
Interoperability |
NTP server |
Time can be synchronized between H3C and Huawei devices. |
NTP server |
Example: Configuring NTP interoperation with a Huawei device
As shown in Figure 20, an H3C device and a Huawei device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Huawei device as the NTP server to synchronize the time of the H3C device with the Huawei device.
# Assign an IP address to HundredGigE 1/0/1.
<H3C> system-view
# Enable NTP.
# Specify the NTP server 100.0.0.2.
[H3C] ntp-service unicast-server 100.0.0.2
· Configure the Huawei device.
# View information about the Huawei device.
The Huawei CE6865-48S8CQ-EI device is used in this example.
2. MAB Version : 1
# Enable IPv4 and IPv6 NTP.
[HUAWEI]undo ntp server disable
# Specify the local clock as the NTP clock reference.
[HUAWEI]ntp-service refclock-master 2
[H3C] display clock
11:19:56 UTC Thu 03/31/2022
# View the current system date and time on the Huawei device.
[HUAWEI] display clock
2022-03-31 11:20:01
Thursday
Time Zone(DefaultZoneName) : UTC
Table 15 NTP interoperability analysis
H3C |
Ruijie |
Interoperability |
NTP server |
Time can be synchronized between H3C and Ruijie devices. |
NTP server |
Example: Configuring NTP interoperation with a Ruijie device
As shown in Figure 21, an H3C device and a Ruijie device are connected with Layer 3 Ethernet interfaces. Configure the H3C device as an NTP client and the Ruijie device as the NTP server to synchronize the time of the H3C device with the Ruijie device.
<H3C>system-view
# Enable NTP.
· Configure the Ruijie device.
# View information about the Ruijie device.
The Ruijie S6510-48VS8CQ device is used in this example.
Ruijie>show version
Module information:
# Configure the interface to operate in Layer 3 mode and assign an IP address to the interface.
Ruijie>enable
# Configure the device as NTP server.
Ruijie(config)#ntp master
[H3C] display clock
19:51:01 UTC Mon 04/11/2022
# View the current system date and time on the Ruijie device.
Ruijie(config)#show clock
19:51:18 UTC Mon, Apr 11, 2022
LLDP interoperation guide
The Link Layer Discovery Protocol (LLDP) is a standard link layer protocol that allows network devices from different vendors to discover neighbors and exchange system and configuration information. For interconnection with devices of other vendors, LLDP is available as long as LLDP is enabled on both the local and peer devices. To enable H3C devices to exchange information with Cisco devices that supports only Cisco-proprietary CDP, enable CDP compatibility on H3C devices.
Table 16 LLDP interoperability analysis
H3C |
Cisco |
Interoperability |
LLDP operating mode is TxRx |
LLDP neighbor relationship can be established. |
LLDP |
CDP |
Supported when CDP compatibility is enabled on H3C devices. |
Example: Configuring LLDP interoperation with a Cisco device
As shown in Figure 22, an H3C device and a Cisco device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Cisco device for these two devices to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
# Enable LLDP globally.
<H3C> system-view
[H3C] lldp global enable
# Enable LLDP on GigabitEthernet 1/0/1.
[H3C-GigabitEthernet1/0/1] lldp enable
# Configure LLDP to operate in TxRx mode on GigabitEthernet 1/0/1.
[H3C-GigabitEthernet1/0/1] lldp admin-status txrx
Cisco# show version
Software
BIOS: version 07.56
Hardware
Device name: switch
Last reset
Reason: Unknown
Service:
plugin
Active Package(s):
# Configure LLDP.
Cisco(config-if)# lldp receive
Cisco(config-if)# lldp transmit
# Verifying detailed LLDP information on the H3C device received by the nearest bridge agent on all ports from neighboring devices.
[H3C] display lldp neighbor-information
LLDP neighbor-information of port 371[GigabitEthernet1/0/1]:
LLDP agent nearest-bridge:
LLDP neighbor index : 1
ChassisID/subtype : 2c33-113a-eb08/MAC address
PortID/subtype : Ethernet1/7/Interface name
Capabilities : Bridge, Router
# Display the LLDP information that the H3C device receives from the neighboring devices in the form of a list.
[H3C] display lldp neighbor-information list
Chassis ID : * -- -- Nearest nontpmr bridge neighbor
# -- -- Nearest customer bridge neighbor
Default -- -- Nearest bridge neighbor
Local Interface Chassis ID Port ID System Name
GE1/0/1 2c33-113a-eb08 Ethernet1/7 Cisco
Table 17 LLDP interoperability analysis
H3C |
Huawei |
Interoperability |
LLDP operating mode is TxRx. |
Example: Configuring LLDP interoperation with a Huawei device
As shown in Figure 23, an H3C device and a Huawei device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Huawei device for them to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
<H3C> system-view
# Enable LLDP on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] lldp admin-status txrx
# Enable LLDP on HundredGigE 1/0/2.
[H3C-HundredGigE1/0/2] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/2.
[H3C-HundredGigE1/0/2] lldp admin-status txrx
2. MAB Version : 1
<HUAWEI> system-view immediately
[HUAWEI]lldp enable
# Enable LLDP on 100GE 1/0/1.
[HUAWEI-100GE1/0/1]undo lldp disable
# Configure LLDP to operate in Tx and Rx modes.
[HUAWEI-100GE1/0/1]lldp admin-status txrx
# Enable LLDP on 100GE 1/0/2.
[HUAWEI-100GE1/0/2]undo lldp disable
[HUAWEI-100GE1/0/2]lldp admin-status txrx
LLDP neighbor-information of port 51[HundredGigE1/0/1]:
LLDP neighbor index : 2
ChassisID/subtype : a4be-2b3a-50d1/MAC address
PortID/subtype : 100GE1/0/1/Interface name
LLDP neighbor-information of port 98[HundredGigE1/0/2]:
PortID/subtype : 100GE1/0/2/Interface name
HGE1/0/1 a4be-2b3a-50d1 100GE1/0/1 HUAWEI
HGE1/0/2 a4be-2b3a-50d1 100GE1/0/2 HUAWEI
Table 18 LLDP interoperability analysis
H3C |
Ruijie |
Interoperability |
Configuring LLDP interoperation with a Ruijie device
As shown in Figure 24, an H3C device and a Ruijie device connects to each other through Layer 2 Ethernet interfaces. Configure the H3C device to interoperate with the Ruijie device for them to establish the LLDP neighbor relationship. Then, they can discover each other and exchange system and configuration information.
<H3C> system-view
# Enable LLDP on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] lldp admin-status txrx
# Enable LLDP on HundredGigE1/0/4.
[H3C-HundredGigE1/0/4] lldp enable
# Configure the nearest bridge to operate in TxRx mode on HundredGigE 1/0/4.
[H3C-HundredGigE1/0/4] lldp admin-status txrx
The Rujie S6510-48VS8CQ device is used in this example.
Ruijie>show version
Module information:
# Enable LLDP.
Ruijie>enable
Ruijie(config)#lldp enable
# Enable LLDP on HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#lldp enable
# Configure the LLDP operating mode.
Ruijie(config-if-HundredGigabitEthernet 0/49)#lldp mode txrx
# Enable LLDP on HundredGigabitEthernet 0/50.
Ruijie(config-if-HundredGigabitEthernet 0/50)#lldp enable
Ruijie(config-if-HundredGigabitEthernet 0/50)#lldp mode txrx
LLDP neighbor-information of port 5[HundredGigE1/0/3]:
ChassisID/subtype : c0b8-e672-cd08/MAC address
PortID/subtype : HundredGigabitEthernet 0/49/Interface name
Capabilities : Repeater, Bridge, Router
LLDP neighbor-information of port 6[HundredGigE1/0/4]:
PortID/subtype : HundredGigabitEthernet 0/50/Interface name
HGE1/0/3 c0b8-e672-cd08 HundredGigabitEthernet 0/49 Ruijie
HGE1/0/4 c0b8-e672-cd08 HundredGigabitEthernet 0/50 Ruijie
PIM-SM interoperation guide
Table 19 PIM SM interoperability analysis
H3C |
Cisco |
Interoperability |
Enable PIM-SM. |
Enable PIM-SM. |
Layer 3 multicast interoperability |
As shown in Figure 25, an H3C device and a Cisco device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Cisco device.
Configuring the H3C device
# Enable IP multicast routing on the public network and enter PIM view of the public network.
<H3C> system-view
[H3C] multicast routing
[H3C-mrib] quit
[H3C] pim
# Configure the interface with IP address 16.1.10.4 as a C-BSR for the global-scoped zone on the public network.
[H3C-pim] c-bsr 16.1.10.4
# Configure the interface with IP address 16.1.10.4 as a C-RP.
[H3C-pim] c-rp 16.1.10.4
[H3C-pim] quit
# Create VLAN 100.
[H3C] vlan 100
[H3C-Vlan100] quit
# Assign an IP address to VLAN interface 100.
[H3C] interface vlan-interface 100
[H3C-Vlan-interface-100] ip address 16.1.10.4 255.255.255.0
# Enable PIM-SM on VLAN interface 100.
[H3C-Vlan-interface-100] pim sm
[H3C-Vlan-interface-100] quit
# Configure GigabitEthernet 1/0/1 as a trunk port, and assign it to VLAN 100.
[H3C-GigabitEthernet1/0/1] port trunk permit vlan 100
Configuring the Cisco device
This section uses a Cisco Nexus9000 C93180YC-FX device as an example. The following is the device information:
Cisco# show version
Copyright (C) 2002-2019, Cisco and/or its affiliates.
Software
BIOS: version 05.43
NXOS: version 9.3(3)
BIOS compile time: 11/22/2020
NXOS image file is: bootflash:///nxos.9.3.3.bin
NXOS compile time: 12/22/2019 2:00:00 [12/22/2019 14:00:37]
Hardware
cisco Nexus9000 C93180YC-FX Chassis
Intel(R) Xeon(R) CPU D-1528 @ 1.90GHz with 32827212 kB of memory.
Processor Board ID FDO25250294
Device name: cisco
bootflash: 115805708 kB
Kernel uptime is 167 day(s), 6 hour(s), 51 minute(s), 41 second(s)
Last reset at 744629 usecs after Thu Jan 13 02:02:26 2022
Reason: Module PowerCycled
System version:
Service: HW check by card-client
plugin
Active Package(s):
# Configure PIM.
Cisco(config)# feature pim
Cisco(config)# ip pim auto-rp forward listen
Cisco(config)# ip pim bsr forward listen
# Assign an IP address to VLAN interface 10.
Cisco(config)# interface vlan 100
Cisco(config-if)# ip address 16.1.10.2 255.255.255.0
# Enable the PIM sparse mode.
Cisco(config-if)# ip pim sparse-mode
# Configure Ethernet1/9 as a trunk port, and assign it to VLAN 100.
Cisco(config)# interface Ethernet 1/9
Cisco(config-if)# switchport mode trunk
Cisco(config-if)# switchport trunk allowed vlan 100
# Display PIM information for all interfaces on the H3C device.
[H3C] display pim interface
Interface NbrCnt HelloInt DR-Pri DR-Address
Vlan100 1 30 1 16.1.10.4 (local)
# Display information about all PIM neighbors on the H3C device.
[H3C] display pim neighbor
Total Number of Neighbors = 1
Neighbor Interface Uptime Expires DR-Priority Mode
16.1.10.2 Vlan100 00:12:15 00:01:26 1 B
# Display BSR information on the H3C device.
[H3C] display pim bsr-info
Scope: non-scoped
State: Elected
Bootstrap timer: 00:00:27
Elected BSR address: 16.1.10.4
Priority: 64
Hash mask length: 30
Uptime: 00:00:53
Candidate BSR address: 16.1.10.4
Priority: 64
# Display information about all RPs on the H3C device.
[H3C] display pim rp-info
BSR RP information:
Scope: non-scoped
Group/MaskLen: 224.0.0.0/4
RP address Priority HoldTime Uptime Expires
16.1.10.4 (local) 192 180 00:17:12 00:02:47
# Display PIM information for all interfaces on the Cisco device.
Cisco(config-if)# show ip pim interface
PIM Interface Status for VRF "default"
Vlan100, Interface status: protocol-up/link-up/admin-up
IP address: 16.1.10.2, IP subnet: 16.1.10.0/24
PIM DR: 16.1.10.4, DR's priority: 1
PIM neighbor count: 1
PIM hello interval: 30 secs, next hello sent in: 00:00:17
PIM neighbor holdtime: 105 secs
PIM configured DR priority: 1
PIM configured DR delay: 3 secs
PIM border interface: no
PIM GenID sent in Hellos: 0x21f2f9b7
PIM Hello MD5-AH Authentication: disabled
PIM Neighbor policy: none configured
PIM Join-Prune inbound policy: none configured
PIM Join-Prune outbound policy: none configured
PIM Join-Prune interval: 1 minutes
PIM Join-Prune next sending: 0 minutes
PIM BFD enabled: no
PIM passive interface: no
PIM VPC SVI: no
PIM Auto Enabled: no
PIM Interface Statistics, last reset: never
General (sent/received):
Hellos: 61/55 (early: 0), JPs: 0/0, Asserts: 0/0
Grafts: 0/0, Graft-Acks: 0/0
DF-Offers: 0/0, DF-Winners: 0/0, DF-Backoffs: 0/0, DF-Passes: 0/0
Errors:
Checksum errors: 0, Invalid packet types/DF subtypes: 0/0
Authentication failed: 0
Packet length errors: 0, Bad version packets: 0, Packets from self: 0
Packets from non-neighbors: 0
Packets received on passiveinterface: 0
JPs received on RPF-interface: 0
(*,G) Joins received with no/wrong RP: 0/0
(*,G)/(S,G) JPs received for SSM/Bidir groups: 0/0
JPs filtered by inbound policy: 0
JPs filtered by outbound policy: 0
# Display information about all PIM neighbors on the Cisco device.
Cisco(config-if)# show ip pim neighbor
PIM Neighbor Status for VRF "default"
Neighbor Interface Uptime Expires DR Bidir- BFD ECMP Redirect
Priority Capable State Capable
16.1.10.4 Vlan100 00:23:12 00:01:43 1 no n/a no
# Display information about all RPs on the Cisco device.
Cisco(config-if)# show ip pim rp
PIM RP Status Information for VRF "default"
BSR: 16.1.10.4, uptime: 00:05:41, expires: 00:01:49,
priority: 64, hash-length: 30
Auto-RP RPA: unknown
BSR RP Candidate policy: None
BSR RP policy: None
Auto-RP Announce policy: None
Auto-RP Discovery policy: None
RP: 16.1.10.4, (0),
uptime: 00:05:20 priority: 192,
RP-source: 16.1.10.4 (B),
group ranges:
224.0.0.0/4 , expires: 00:02:39 (B)
cisco(config-if)#
# Display all PIM routing entries on the Cisco device.
Cisco(config-if)# show ip pim route
PIM Routing Table for VRF "default" - 1 entries
(*, 232.0.0.0/8), expires 00:02:20
Incoming interface: Null, RPF nbr 0.0.0.0
Oif-list: (0) 00000000, Timeout-list: (0) 00000000
Immediate-list: (0) 00000000, Immediate-timeout-list: (0) 00000000
Sgr-prune-list: (0) 00000000 Timeout-interval: 2, JP-holdtime round-up: 3
Table 20 PIM-SM interoperability analysis
H3C |
Huawei |
Interoperability |
Support |
Support |
Yes |
As shown in Figure 26, an H3C device and a Huawei device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Huawei device.
<H3C> system-view
[H3C-mrib] quit
[H3C] pim
# Configure the interface with IP address 100.0.0.1 as a C-BSR for the global-scoped zone on the public network.
[H3C-pim] c-bsr 100.0.0.1
# Configure the interface with IP address 100.0.0.1 as a C-RP.
[H3C-pim] c-rp 100.0.0.1
[H3C-pim] quit
# Create VLAN 10.
[H3C] vlan 10
[H3C-vlan10] quit
# Configure HundredGigE 1/0/1 as a trunk port, and assign it to VLAN 10.
[H3C-Vlan-interface10] undo shutdown
# Enable PIM-SM.
[H3C-Vlan-interface10] pim sm
Configuring the Huawei device
This section uses a Huawei CE6865-48S8CQ-EI device as an example. The following is the device information:
<HUAWEI> display version
Huawei Versatile Routing Platform Software
VRP (R) software, Version 8.191 (CE6865EI V200R019C10SPC800)
Copyright (C) 2012-2020 Huawei Technologies Co., Ltd.
HUAWEI CE6865-48S8CQ-EI uptime is 3 days, 18 hours, 29 minutes
CE6865-48S8CQ-EI(Master) 1 : uptime is 3 days, 18 hours, 28 minutes
StartupTime 2022/06/23 19:58:16
Memory Size : 4096 M bytes
Flash Size : 2048 M bytes
CE6865-48S8CQ-EI version information
1. PCB Version : CEM48S8CQP04 VER A
2. MAB Version : 1
3. Board Type : CE6865-48S8CQ-EI
4. CPLD1 Version : 102
5. CPLD2 Version : 102
6. BIOS Version : 205
# Enable IP multicast routing.
Enter system view, return user view with return command.
[HUAWEI]multicast routing-enable
# Create VLAN 10.
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
# Configure 100GE1/0/1 as a trunk port, and assign it to VLAN 10.
[HUAWEI]interface Vlanif 10
# Enable PIM-SM on VLAN interface 10.
[HUAWEI-Vlanif10]pim sm
Vlan10 1 30 1 100.0.0.2
100.0.0.2 Vlan10 00:02:29 00:01:16 1
Scope: non-scoped
State: Elected
Bootstrap timer: 00:00:56
Elected BSR address: 100.0.0.1
Priority: 64
Uptime: 00:02:13
Candidate BSR address: 100.0.0.1
Priority: 64
BSR RP information:
Scope: non-scoped
100.0.0.1 (local) 192 180 00:02:34 00:02:25
# Display PIM information for all interfaces on the Huawei device.
[HUAWEI] display pim interface
VPN-Instance: public net
Interface State NbrCnt HelloInt DR-Pri DR-Address
Vlanif10 up 1 30 1 100.0.0.2 (local)
# Display information about all PIM neighbors on the Huawei device.
[HUAWEI] display pim neighbor
Total: 1
Neighbor Interface Uptime Expires Dr-Priority BFD-Session
100.0.0.1 Vlanif10 00:32:53 00:01:30 1 N
# Display BSR information on the Huawei device.
[HUAWEI] display pim bsr-info
Elected AdminScoped BSR Count: 0
Elected BSR Address: 100.0.0.1
Priority: 64
State: Accept Preferred
Scope: Not scoped
# Display information about all RPs on the Huawei device.
[HUAWEI] display pim rp-info
PIM-SM BSR RP Number:1
RP: 100.0.0.1
Priority: 192
Uptime: 00:08:58
Expires: 00:02:48
BIDIR: N
Uptime: 00:09:16
Expires: 00:01:40
C-RP Count: 1
Table 21 PIM-SM interoperability analysis
H3C |
Ruijie |
Interoperability |
Support |
Support |
Yes |
As shown in Figure 27, an H3C device and a Ruijie device are connected through Layer 2 Ethernet interfaces. Configure Layer 3 multicast between the H3C device and the Ruijie device.
<H3C>system-view
[H3C-mrib] quit
[H3C] pim
[H3C-pim] quit
# Create VLAN 10.
[H3C] vlan 10
[H3C-vlan10] quit
# Configure HundredGigE 1/0/3 as a trunk port, and assign it to VLAN 10.
Configuring the Ruijie device
This section uses a Ruijie RG-S6510-48VS8CQ device as an example. The following is the device information:
Ruijie>show version
System description : Ruijie Full 25G Routing Switch(S6510-48VS8CQ) By Ruijie Networks
System start time : 2022-06-10 17:56:53
System uptime : 16:16:51:47
System hardware version : 2.30
System software version : S6500_RGOS 11.0(5)B9P59
System patch number : NA
System serial number : G1QH10Q10637A
System boot version : 1.3.8
Module information:
Slot 0 : RG-S6510-48VS8CQ
Hardware version : 2.30
Boot version : 1.3.8
Software version : S6500_RGOS 11.0(5)B9P59
Serial number : G1QH10Q10637A
Ruijie>enable
Ruijie#configure terminal
Ruijie(config)#ip multicast-routing
# Create VLAN 10.
Ruijie(config)#vlan 10
Ruijie(config-vlan)#exit
# Configure HundredGigabitEthernet 0/49 as a trunk port, and assign it to VLAN 10.
Ruijie(config-if-VLAN 10)#ip pim sparse-mode
100.0.0.2 Vlan10 00:03:25 00:01:20 1
Scope: non-scoped
State: Elected
Bootstrap timer: 00:00:37
Priority: 64
Uptime: 00:06:33
Priority: 64
BSR RP information:
Scope: non-scoped
100.0.0.1 (local) 192 180 02:59:48 00:02:12
# Display PIM information for all interfaces on the Ruijie device.
Ruijie#show ip pim sparse-mode interface
Address Interface VIFindex Ver/Mode Nbr-Count DR-Prior DR
100.0.0.2 VLAN 10 1 v2/S 1 1 100.0.0.2
# Display information about all PIM neighbors on the Ruijie device.
Ruijie#show ip pim sparse-mode neighbor
Neighbor Interface Uptime/Expires Ver DR
Address Priority/Mode
100.0.0.1 VLAN 10 02:55:09/00:01:20 v2 1 /
# Display BSR information on the Ruijie device.
Ruijie#show ip pim sparse-mode bsr-router
PIMv2 Bootstrap information
Uptime: 00:36:06, BSR Priority: 64, Hash mask length: 30
Expires: 00:01:24
Role: Non-candidate BSR Priority: 0, Hash mask length: 10
# Display information about all RPs on the Ruijie device.
Ruijie#show ip pim sparse-mode rp mapping
PIM Group-to-RP Mappings
Group(s): 224.0.0.0/4
RP: 100.0.0.1(Not self)
Info source: 100.0.0.1, via bootstrap, priority 192
Uptime: 00:36:04, expires: 00:02:16
BFD interoperation guide
Table 22 BFD interoperability analysis
H3C |
Cisco |
Interoperability |
Supported |
Supported |
Supported |
Example: Configuring static routing and BFD association for interoperation
As shown in Figure 28, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
# Configure interface HundredGigE 1/0/1 as a trunk port and assign the interface to VLAN10.
[H3C-HundredGigE1/0/1] undo port trunk permit vlan 1
# Specify the IP address for VLAN-interface 10 as 100.0.0.1.
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on VLAN-interface 10.
[H3C-Vlan-interface10] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on VLAN-interface 10.
[H3C-Vlan-interface10] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on VLAN-interface 10 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-Vlan-interface10] bfd detect-multiplier 3
# Assign an IP address to interface Loopback 0.
[H3C] interface LoopBack0
[H3C-LoopBack0] ip address 1.1.1.1 32
[H3C-LoopBack0] quit
# Configure a static route, and enable BFD to detect the next hop reachability for the static route. When the next hop becomes unreachable, the backup route can immediately take over.
[H3C] ip route-static 2.2.2.2 32 Vlan-interface10 100.0.0.2 bfd control-packet
# Configure the following settings on Cisco Nexus9000 C93180YC-FX as an example.
cisco# show version
Software
BIOS: version 05.43
Hardware
Device name: cisco-leaf2
System version:
plugin
Active Package(s):
# Create VLAN 10.
cisco# configure terminal
cisco(config-if)# vlan 10
cisco(config-vlan)# exit
# Set the link type for ETH 1/54 as trunk and assign the interface to VLAN 10.
cisco(config)# interface ethernet 1/54
cisco(config-if)# no shutdown
cisco(config-if)# switchport
cisco(config-if)# switch mode trunk
cisco(config-if)# switchport trunk allowed vlan 10
cisco(config-if)# exit
# Assign an IP address to VLAN-interface 10 and configure BFD parameters for VLAN-interface 10.
cisco(config)# interface vlan 10
cisco(config-if)# ip address 100.0.0.2 255.255.255.0
cisco(config-if)# bfd interval 300 min_rx 300 multiplier 3
# Assign an IP address to the loopback interface.
cisco(config)# interface loopback 0
cisco(config-if)# ip address 2.2.2.2 255.255.255.255
# Associate static routing with BFD for fast failure detection.
cisco(config)# ip route static bfd vlan 10 100.0.0.1
# Display brief information about all BFD sessions on the H3C device.
[H3C] display bfd session
Total Session Num: 1 Up Session Num: 1 Init Mode: Active
257/1090519047 100.0.0.1 100.0.0.2 Up 674ms Vlan10
# Display detailed information about all BFD sessions on the H3C device.
[H3C] display bfd session verbose
Local Discr: 257 Remote Discr: 1090519047
Source IP: 100.0.0.1 Destination IP: 100.0.0.2
Session State: Up Interface: Vlan-interface10
Min Tx Inter: 300ms Act Tx Inter: 300ms
Min Rx Inter: 300ms Detect Inter: 900ms
Rx Count: 1300 Tx Count: 1359
Connect Type: Direct Running Up for: 00:05:45
Hold Time: 784ms Auth mode: None
Detect Mode: Async Slot: 1
Protocol: STATIC
Version: 1
Diag Info: No Diagnostic
# Display BFD neighbor information on the Cisco device.
cisco(config-if)# show bfd neighbors
OurAddr NeighAddr LD/RD RH/RS Holdown(mult) State Int Vrf Type
100.0.0.2 100.0.0.1 1090519047/257 Up 737(3) Up Vlan10 default SH
Example: Configuring OSPF and BFD association for interoperation
As shown in Figure 29, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
# Create OSPF area 0 and enter OSPF area view.
<H3C> system-view
[H3C] ospf 100
[H3C-ospf-100] area 0
[H3C-ospf-100-area-0.0.0.0]qu
[H3C-ospf-100] quit
# Enable OSPF process 100 on HundredGigE1/0/1 in OSPF area 0.
[H3C-HundredGigE1/0/1] ospf 100 area 0
# Enable BFD for OSPF.
[H3C-HundredGigE1/0/1] ospf bfd enable
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on HundredGigE 1/0/1 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-HundredGigE1/0/1] bfd detect-multiplier 3
cisco# show version
Software
BIOS: version 05.43
Hardware
System version:
plugin
Active Package(s):
# Run OSPF and enable BFD.
cisco(config)# router ospf 100
cisco(config-router)# area 0 default-cost 1
cisco(config-router)# bfd
cisco(config-router)# exit
# Enable OSPF process 100 on the interface in the specified OSPF area.
cisco(config-if)# ip router ospf 100 area 0.0.0.0
# Enable BFD for the interface.
cisco(config-if)# ip ospf bfd
# Configure BFD session parameters.
cisco(config)# bfd interval 300 min_rx 300 multiplier 3
# Display OSPF neighbor information on the H3C device.
[H3C] display ospf peer
OSPF Process 100 with Router ID 3.3.3.4
Neighbor Brief Information
Area: 0.0.0.0
Router ID Address Pri Dead-Time State Interface
2.2.2.2 100.0.0.2 1 33 Full/BDR HGE1/0/1
Total sessions: 1 Up sessions: 1 Init mode: Active
IPv4 session working in control mode:
40768/16389 100.0.0.1 100.0.0.2 Up 616ms HGE0/0/1
Local Discr: 257 Remote Discr: 1090519048
Session State: Up Interface: HundredGigE1/0/1
Rx Count: 749 Tx Count: 846
Connect Type: Direct Running Up for: 00:03:40
Hold Time: 817ms Auth mode: None
Protocol: OSPF
Version: 1
# Display OSPF neighbor information on the Cisco device.
cisco(config)# show ip ospf neighbors
OSPF Process ID 100 VRF default
Total number of neighbors: 1
Neighbor ID Pri State Up Time Address Interface
3.3.3.4 1 FULL/DR 00:01:59 100.0.0.1 Eth1/54
cisco(config)# show bfd neighbors
100.0.0.2 100.0.0.1 1090519048/257 Up 810(3) Up Eth1/54 default SH
Example: Configuring IS-IS and BFD association for interoperation
As shown in Figure 30, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
# Create IS-IS process 1.
<H3C> system-view
[H3C] isis 1
# Set the NET to 10.0000.0000.0000.0002.00.
[H3C-isis-1] network-entity 10.0000.0000.0000.0002.00
[H3C-isis-1] quit
# Enable IS-IS process 1 on HundredGigE 1/0/1.
# Set the network type of HundredGigE 1/0/1 to P2P.
# Enable BFD on IS-IS interface HundredGigE 1/0/1.
[H3C-HundredGigE1/0/1] isis bfd enable
cisco# show version
Software
BIOS: version 05.43
Hardware
System version:
plugin
Active Package(s):
# Enable the IS-IS feature and enable IS-IS process 1.
cisco(config)# feature isis
cisco(config)# router isis 1
cisco(config-router)# is-type level-2
# Set the NET for the IS-IS process.
cisco(config-router)# net 10.0000.0000.0000.0001.00
# Activate the IS-IS process on the interface.
cisco(config-if)# ip router isis 1
# Set the interface type to P2P.
cisco(config-if)# medium p2p
cisco(config-if)# isis bfd
# Display IS-IS neighbor information on the H3C device.
System ID: 0000.0000.0001
Interface: HGE1/0/1 Circuit Id: 001
State: Up HoldTime: 20s Type: L2 PRI: --
257/1090519050 100.0.0.1 100.0.0.2 Up 778ms HGE1/0/1
Local Discr: 257 Remote Discr: 1090519050
Rx Count: 234128 Tx Count: 267540
Connect Type: Direct Running Up for: 19:29:08
Hold Time: 820ms Auth mode: None
Protocol: ISIS_P2P
Version: 1
# Display IS-IS route information on the Cisco device.
cisco(config-if)# show isis route
IS-IS process: 1 VRF: default
IS-IS IPv4 routing table
100.0.0.0/24, L2, direct
*via Ethernet1/54, metric 1, L2, direct
100.0.0.2 100.0.0.1 1090519050/257 Up 641(3) Up Eth1/54 default SH
Example: Configuring BGP and BFD association for interoperation
As shown in Figure 31, an H3C device is connected with a Cisco device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Cisco device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
<H3C> system-view
# In BGP instance view, create a BGP peer and set its AS number to 200.
[H3C] bgp 100
[H3C-bgp-default] peer 100.0.0.2 as-number 200
# Enable BFD for the link to the BGP peer.
[H3C-bgp-default] peer 100.0.0.2 bfd
# In BGP instance view, create the BGP IPv4 unicast address family and enter its view.
[H3C-bgp-default] address-family ipv4 unicast
# In BGP IPv4 unicast address family view, enable BGP to exchange IPv4 unicast routing information with peer 100.0.0.2.
[H3C-bgp-default-ipv4] peer 100.0.0.2 enable
[H3C-bgp-default-ipv4] quit
[H3C-bgp-default] quit
cisco# show version
All rights reserved.
Software
BIOS: version 05.43
Hardware
System version:
plugin
Active Package(s):
# Specify the remote AS number as 100 for the peer.
cisco(config)# router bgp 200
cisco(config-router)# neighbor 100.0.0.1 remote-as 100
cisco(config-router-neighbor)# address-family ipv4 unicast
cisco(config-router-neighbor-af)# neighbor 100.0.0.1 remote-as 100
# Enable BFD for the peer.
cisco(config-router-neighbor)# bfd
# Display brief information about all BGP IPv4 unicast peers on the H3C device.
[H3C] display bgp peer ipv4
BGP local router ID: 3.3.3.4
Local AS number: 100
Total number of peers: 1 Peers in established state: 1
* - Dynamically created peer
100.0.0.2 200 8 19 0 0 00:04:50 Established
257/1090519049 100.0.0.1 100.0.0.2 Up 900ms HGE1/0/1
Local Discr: 257 Remote Discr: 1090519049
Rx Count: 1355 Tx Count: 1406
Connect Type: Direct Running Up for: 00:05:33
Hold Time: 688ms Auth mode: None
Protocol: BGP
Version: 1
# Display BGP session information on the Cisco device.
cisco(config)# show bgp sessions
Total peers 1, established peers 1
ASN 200
VRF default, local ASN 200
peers 1, established peers 1, local router-id 2.2.2.2
State: I-Idle, A-Active, O-Open, E-Established, C-Closing, S-Shutdown
Neighbor ASN Flaps LastUpDn|LastRead|LastWrit St Port(L/R) Notif(S/R)
100.0.0.1 100 0 00:05:55|00:00:49|00:00:54 E 44009/179 0/0
# Display BFD session information on the Cisco device.
100.0.0.2 100.0.0.1 1090519049/257 Up 878(3) Up Eth1/54 default SH
Table 23 BFD interoperability analysis
H3C |
Huawei |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 32, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
# Configure interface HundredGigE 1/0/1 as a trunk port and assign the interface to VLAN 10.
# Configure the following settings on Huawei CE6865-48S8CQ-EI as an example.
2. MAB Version : 1
# Create VLAN 10.
[HUAWEI]vlan 10
[HUAWEI-vlan10]quit
# Set the link type for 100GE 1/0/1 as trunk and assign the interface to VLAN 10.
[HUAWEI-100GE1/0/1]undo port trunk allow-pass vlan 1
# Assign an IP address to the VLAN interface.
[HUAWEI]interface LoopBack 0
[HUAWEI-LoopBack0]ip address 2.2.2.2 32
[HUAWEI-LoopBack0]quit
# Configure BFD parameters for the static route.
[HUAWEI]ip route-static bfd Vlanif 10 100.0.0.1 local-address 100.0.0.2 min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
# Associate the static route with BFD for fast failure detection.
[HUAWEI]ip route-static 1.1.1.1 32 Vlanif 10 100.0.0.1 bfd enable
40768/16385 100.0.0.1 100.0.0.2 Up 762ms Vlan10
Local Discr: 40768 Remote Discr: 16385
Destination port: 3784 Session State: Up
Rx Count: 1109 Tx Count: 1160
Connect Type: Direct Running Up for: 00:07:15
Hold Time: 734ms Auth Mode: None
Detect Mode: Async Slot: 0
Protocol: STATIC
Version: 1
As shown in Figure 33, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
<H3C> system-view
[H3C] ospf 100
[H3C-ospf-100] quit
# Enable OSPF process 100 on HundredGigE 1/0/1 in OSPF area 0.
2. MAB Version : 1
# Run OSPF.
[HUAWEI]ospf 100
[HUAWEI-ospf-100-area-0.0.0.0]quit
[HUAWEI-ospf-100]quit
[HUAWEI-100GE1/0/1]ip address 100.0.0.2 255.255.255.0
[HUAWEI-100GE1/0/1]ospf enable 100 area 0.0.0.0
[HUAWEI-100GE1/0/1]ospf bfd enable
[HUAWEI-100GE1/0/1]ospf bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
OSPF Process 100 with Router ID 1.1.1.1
Area: 0.0.0.0
16.1.111.51 100.0.0.2 1 37 Full/DR HGE0/0/1
Local Discr: 40768 Remote Discr: 16389
Interface: HundredGigE0/0/1
Rx Count: 19560 Tx Count: 19548
Connect Type: Direct Running Up for: 05:22:40
Hold Time: 776ms Auth Mode: None
Protocol: OSPF
Version: 1
As shown in Figure 34, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
<H3C> system-view
[H3C] isis 1
# Configure the router to receive and send only wide cost style packets.
# Set the NET to 48.0001.1001.7220.0160.00.
[H3C-isis-1] quit
[H3C-HundredGigE1/0/1] quit
2. MAB Version : 1
# Enable IS-IS process 1.
<HUAWEI>system-view immediately
[HUAWEI]isis 1
# Specify the IS-IS device to receive and send only wide cost style packets.
[HUAWEI-isis-1]quit
[HUAWEI]interface 100GE 1/0/1
# Activate the IS-IS process on 100GE 1/0/1.
# Set the network type of 100GE 1/0/1 to P2P.
# Enable BFD for 100GE 1/0/1.
[HUAWEI-100GE1/0/1]isis bfd enable
[HUAWEI-100GE1/0/1]isis bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
[HUAWEI-100GE1/0/1]quit
40768/16390 100.0.0.1 100.0.0.2 Up 797ms HGE1/0/1
Local Discr: 40768 Remote Discr: 16390
Rx Count: 481 Tx Count: 494
Connect Type: Direct Running Up for: 00:03:12
Hold Time: 653ms Auth Mode: None
Protocol: ISIS_P2P
Version: 1
As shown in Figure 35, an H3C device is connected with a Huawei device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Huawei device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
<H3C> system-view
[H3C] bgp 100
2. MAB Version : 1
[HUAWEI] interface 100GE 1/0/1
[HUAWEI]bgp 200
[HUAWEI-bgp]peer 100.0.0.1 as-number 100
[HUAWEI-bgp]peer 100.0.0.1 bfd enable
[HUAWEI-bgp]peer 100.0.0.1 bfd min-tx-interval 300 min-rx-interval 300 detect-multiplier 3
[HUAWEI-bgp]quit
BGP local router ID: 1.1.1.1
100.0.0.2 200 12 216 0 0 00:08:30 Established
40768/16391 100.0.0.1 100.0.0.2 Up 737ms HGE1/0/1
Local Discr: 40768 Remote Discr: 16391
Rx Count: 131 Tx Count: 212
Connect Type: Direct Running Up for: 00:00:42
Hold Time: 694ms Auth Mode: None
Protocol: BGP
Version: 1
Interoperation with Ruijie devices
Table 24 BFD interoperability analysis
H3C |
Ruijie |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 36, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between static routing and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the static routing module.
# Create VLAN 10.
<H3C> system-view
[H3C] vlan 10
[H3C-vlan10] quit
[H3C-HundredGigE1/0/1] port link-type trunk
[H3C-HundredGigE1/0/1] port trunk permit vlan 10
[H3C] interface Vlan-interface 10
[H3C-Vlan-interface10] ip address 100.0.0.1 24
[H3C-Vlan-interface10] quit
# Configure the following settings on Ruijie S6510-48VS8CQ as an example.
Ruijie>show version
Module information:
Ruijie>enable
# Set the link type for HundredGigabitEthernet 0/49 as trunk and assign the interface to VLAN 10.
Ruijie(config)#interface hundredGigabitEthernet 0/49
Ruijie(config-if-HundredGigabitEthernet 0/49)#exit
# Assign an IP address to the VLAN-interface 10.
Ruijie(config)#interface vlAN 10
Ruijie(config-if-VLAN 10)#ip address 100.0.0.2 24
# Configure BFD parameters.
Ruijie(config-if-VLAN 10)#bfd interval 300 min_rx 300 multiplier 3
Ruijie(config-if-VLAN 10)#exit
# Configure a static route.
Ruijie(config)#ip route 1.1.1.1 255.255.255.255 VLAN 10 100.0.0.1
# Associate the static route with BFD.
Ruijie(config)#ip route static bfd VLAN 10 100.0.0.1 source 100.0.0.2
40768/8192 100.0.0.1 100.0.0.2 Up 788ms Vlan10
Local Discr: 40768 Remote Discr: 8192
Rx Count: 1375 Tx Count: 1372
Connect Type: Direct Running Up for: 00:01:07
Hold Time: 888ms Auth Mode: None
Protocol: STATIC
Version: 1
As shown in Figure 37, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between OSPF and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the OSPF module.
<H3C> system-view
[H3C] ospf 1
[H3C-ospf-1] area 0
[H3C-ospf-1-area-0.0.0.0] quit
[H3C-ospf-1] quit
# Assign an IP address to HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] ip address 100.0.0.1 255.255.255.0
# Enable OSPF process 1 on HundredGigE 1/0/3 in OSPF area 0.
[H3C-HundredGigE1/0/3] ospf 1 area 0
[H3C-HundredGigE1/0/3] ospf bfd enable
# Set the minimum interval for transmitting single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] bfd min-transmit-interval 300
# Set the minimum interval for receiving single-hop BFD control packets to 300 milliseconds on HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] bfd min-receive-interval 300
# Set the detection time multiplier to 3 on HundredGigE 1/0/3 for control-packet-mode single-hop detection and echo-packet-mode detection.
[H3C-HundredGigE1/0/3] bfd detect-multiplier 3
[H3C-HundredGigE1/0/3] quit
Ruijie>show version
Module information:
# Create an OSPF process and enter OSPF configuration mode.
Ruijie>enable
Ruijie(config)#route ospf 1
# Specify an area.
Ruijie(config-router)#area 0
Ruijie(config-router)#exit
# Assign an IP address to HundredGigabitEthernet 0/49.
Ruijie(config-if-HundredGigabitEthernet 0/49)#no switchport
# Add the interface to the specified area.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf 1 area 0
# Enable BFD for the specified OSPF interface for link detection.
Ruijie(config-if-HundredGigabitEthernet 0/49)#ip ospf bfd
Ruijie(config-if-HundredGigabitEthernet 0/49)#bfd interval 300 min_rx 300 multiplier 3
OSPF Process 1 with Router ID 16.1.105.99
Area: 0.0.0.0
2.2.2.2 100.0.0.2 1 39 Full/DR HGE0/0/3
40768/8192 100.0.0.1 100.0.0.2 Up 836ms HGE1/0/3
Interface: HundredGigE1/0/3
Rx Count: 164 Tx Count: 188
Connect Type: Direct Running Up for: 00:00:48
Hold Time: 727ms Auth Mode: None
Protocol: OSPF
Version: 1
As shown in Figure 38, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between IS-IS and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the IS-IS module.
<H3C> system-view
[H3C] isis 1
[H3C-isis-1] quit
[H3C] interface HundredGigE 1/0/3
# Enable IS-IS process 1 on HundredGigE 1/0/3.
# Set the network type of HundredGigE 1/0/3 to P2P.
# Enable BFD on IS-IS interface HundredGigE 1/0/3.
[H3C-HundredGigE1/0/3] isis bfd enable
Ruijie>show version
Module information:
Ruijie>enable
# Set the NET for IS-IS.
# Set the IS level.
# Set the metric type.
Ruijie(config-router)#metric-style wide
# Assign an IP address to HundredGigabitEthernet 0/49, and enable IS-IS on the interface.
# Specify the broadcast interface type as Point-to-Point.
# Enable BFD for IS-IS on the interface.
Ruijie(config-if-HundredGigabitEthernet 0/49)#isis bfd
Interface: HGE1/0/3 Circuit Id: 002
State: Up HoldTime: 24s Type: L2 PRI: --
40769/8192 100.0.0.1 100.0.0.2 Up 680ms HGE1/0/3
Local Discr: 40769 Remote Discr: 8192
Rx Count: 1863 Tx Count: 1893
Connect Type: Direct Running Up for: 00:09:23
Hold Time: 633ms Auth Mode: None
Protocol: ISIS_P2P
Version: 1
As shown in Figure 39, an H3C device is connected with a Ruijie device through a Layer 2 switch. Configure association between BGP and BFD. When the link between the H3C or Ruijie device and the Layer 2 switch fails, BFD can immediately detect the failure and notify the BGP module.
<H3C> system-view
[H3C] bgp 100
[H3C-bgp-default ]quit
Ruijie>show version
Module information:
# Assign an IP address to HundredGigabitEthernet 0/49 and configure BFD parameters for the interface.
Ruijie>enable
# Enable BGP and specify the local AS number as 200.
Ruijie(config)#route bgp 200
# Create peer 100.0.0.1.
Ruijie(config-router)#neighbor 100.0.0.1 remote-as 100
# Associate BFD with the peer.
Ruijie(config-router)#neighbor 100.0.0.1 fall-over bfd
40768/16391 100.0.0.1 100.0.0.2 Up 737ms HGE1/0/3
Protocol: BGP
Version: 1
MPLS-LDP interoperation guide
Interoperation with Huawei devices
Table 25 MPLS-LDP interoperability analysis
H3C |
Huawei |
Interoperability |
Configure Open Shortest Path First (OSPF) and local Label Distribution Protocol (LDP) sessions |
LDP Label Switched Path (LSP) interoperation can be established |
As shown in Figure 40, two H3C devices and one Huawei device form a Multiprotocol Label Switching (MPLS) network. Configure OSPF and local LDP sessions on the three devices to enable LDP LSP interoperation between LSRA and LSRC. LDP dynamically assigns labels based on routing information. When you use LDP to dynamically establish LSPs, you must configure the routing protocol (OSPF in this example) to ensure that the devices can reach each other at Layer 3.
1. Configure the IP address and subnet mask of each interface (including the loopback interfaces) as shown in Figure 40. (Details not shown.)
2. Configure LSRA:
# Configure OSPF.
<LSRA> system-view
[LSRA] ospf 1
[LSRA-ospf-1] area 0
[LSRA-ospf-1-area-0.0.0.0] network 1.1.1.1 0.0.0.0
[LSRA-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[LSRA-ospf-1-area-0.0.0.0] quit
[LSRA-ospf-1] quit
# Configure MPLS and LDP.
[LSRA] mpls lsr-id 1.1.1.1
[LSRA] mpls ldp
[LSRA-ldp] quit
[LSRA] interface HundredGigE 2/0/4
[LSRA-HundredGigE2/0/4] mpls enable
[LSRA-HundredGigE2/0/4] mpls ldp enable
[LSRA-HundredGigE2/0/4] quit
3. Configure LSRC:
# Configure OSPF.
<LSRC> system-view
[LSRC] ospf 1
[LSRC-ospf-1] area 0
[LSRC-ospf-1-area-0.0.0.0] network 3.3.3.3 0.0.0.0
[LSRC-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[LSRC-ospf-1-area-0.0.0.0] quit
[LSRC-ospf-1] quit
[LSRC] mpls lsr-id 3.3.3.3
[LSRC] mpls ldp
[LSRC-ldp] quit
[LSRC] interface HundredGigE 2/0/4
[LSRC-HundredGigE2/0/4] mpls enable
[LSRC-HundredGigE2/0/4] mpls ldp enable
[LSRC-HundredGigE2/0/4] quit
4. Configure the Huawei device:
# This section takes a Huawei CE6860-48S8CQ-EI device as an example. Display the device information as follows:
<LSRB> display version
VRP (R) software, Version 8.180 (CE6860EI V200R005C10SPC800)
Copyright (C) 2012-2018 Huawei Technologies Co., Ltd.
HUAWEI CE6860-48S8CQ-EI uptime is 2 days, 13 hours, 54 minutes
CE6860-48S8CQ-EI(Master) 1 : uptime is 2 days, 13 hours, 53 minutes
StartupTime 2023/02/08 20:04:57
Memory Size : 2048 M bytes
Flash Size : 1024 M bytes
CE6860-48S8CQ-EI version information
1. PCB Version : CEM48S8CQP01 VER A
2. MAB Version : 2
3. Board Type : CE6860-48S8CQ-EI
4. CPLD1 Version : 104
5. CPLD2 Version : 104
6. BIOS Version : 192
# Configure OSPF.
<LSRB> system-view
[LSRB] ospf 1
[LSRB-ospf-1] area 0
[LSRB-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[LSRB-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[LSRB-ospf-1-area-0.0.0.0] network 13.1.1.0 0.0.0.255
[LSRB-ospf-1-area-0.0.0.0] quit
[LSRB-ospf-1] quit
[LSRB] mpls lsr-id 2.2.2.2
[LSRB] mpls
[LSRB-mpls] quit
[LSRB] mpls ldp
[LSRB-mpls-ldp] quit
[LSRB] interface 100GE 1/0/1
[LSRB-100GE1/0/1] mpls
[LSRB-100GE1/0/1] mpls ldp
[LSRB-100GE1/0/1] quit
[LSRB] interface 100GE 1/0/2
[LSRB-100GE1/0/2] mpls
[LSRB-100GE1/0/2] mpls ldp
[LSRB-100GE1/0/2] quit
# Execute the display mpls ldp lsp command on the H3C devices to display information about LSPs generated by LDP. Use LSRA as an example:
<LSRA> display mpls ldp lsp
Status Flags: * - stale, L - liberal, B - backup, N/A - unavailable
FECs: 3 Ingress: 2 Transit: 2 Egress: 1
FEC In/Out Label Nexthop OutInterface
1.1.1.1/32 3/-
2.2.2.2/32 -/3 12.1.1.2 HGE2/0/4
24128/3 12.1.1.2 HGE2/0/4
3.3.3.3/32 -/45 12.1.1.2 HGE2/0/4
24127/45 12.1.1.2 HGE2/0/4
# Detect the reachability of the LDP LSP from LSRA to LSRC on LSRA.
<LSRA> ping mpls ipv4 3.3.3.3 32
MPLS ping FEC 3.3.3.3/32 with 100 bytes of data:
100 bytes from 13.1.1.2: Sequence=1 time=1 ms
100 bytes from 13.1.1.2: Sequence=2 time=1 ms
100 bytes from 13.1.1.2: Sequence=3 time=1 ms
100 bytes from 13.1.1.2: Sequence=4 time=1 ms
100 bytes from 13.1.1.2: Sequence=5 time=1 ms
--- Ping statistics for FEC 3.3.3.3/32 ---
Round-trip min/avg/max = 1/1/1 ms
<LSRA>%Feb 10 15:44:06:798 2023 H3C LSPV/6/LSPV_PING_STATIS_INFO: -MDC=1; Ping statistics for FEC 3.3.3.3/32: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/1/1 ms.
# Detect the reachability of the LDP LSP from LSRC to LSRA on LSRC.
<LSRC> ping mpls ipv4 1.1.1.1 32
MPLS ping FEC 1.1.1.1/32 with 100 bytes of data:
100 bytes from 12.1.1.1: Sequence=1 time=1 ms
100 bytes from 12.1.1.1: Sequence=2 time=1 ms
100 bytes from 12.1.1.1: Sequence=3 time=1 ms
100 bytes from 12.1.1.1: Sequence=4 time=1 ms
100 bytes from 12.1.1.1: Sequence=5 time=1 ms
--- Ping statistics for FEC 1.1.1.1/32 ---
<LSRC> %Feb 10 15:46:52:766 2023 H3C LSPV/6/LSPV_PING_STATIS_INFO: -MDC=1; Ping statistics for FEC 1.1.1.1/32: 5 packets transmitted, 5 packets received, 0.0% packets loss, round-trip min/avg/max = 1/1/1 ms.
# On the Huawei device, execute the display mpls ldp session command to view information of the sessions between LDP peers.
<LSRB> display mpls ldp session
LDP Session(s) in Public Network
LAM: Label Advertisement Mode, KA: KeepAlive
SsnAge: Session Age, Unit(DDDD:HH:MM)
An asterisk (*) before a session means the session is being deleted.
PeerID Status LAM SsnRole SsnAge KASent/Rcv
1.1.1.1:0 Operational DU Active 0000:20:32 4930/4928
3.3.3.3:0 Operational DU Passive 0000:20:21 4889/4888
TOTAL: 2 Session(s) Found.
# Detect the reachability of the LDP LSPs from LSRB to LSRA and LSRC on LSRB.
<LSRB> ping lsp -a 2.2.2.2 ip 1.1.1.1 32
LSP PING FEC: IPV4 PREFIX 1.1.1.1/32/ : 100 data bytes, press CTRL_C to break
Reply from 12.1.1.1: bytes=100 Sequence=1 time=2 ms
Reply from 12.1.1.1: bytes=100 Sequence=2 time=1 ms
Reply from 12.1.1.1: bytes=100 Sequence=3 time=1 ms
Reply from 12.1.1.1: bytes=100 Sequence=4 time=2 ms
Reply from 12.1.1.1: bytes=100 Sequence=5 time=2 ms
--- FEC: IPV4 PREFIX 1.1.1.1/32 ping statistics ---
5 packet(s) transmitted
5 packet(s) received
0.00% packet loss
round-trip min/avg/max = 1/1/2 ms
<LSRB> ping lsp -a 2.2.2.2 ip 3.3.3.3 32
LSP PING FEC: IPV4 PREFIX 3.3.3.3/32/ : 100 data bytes, press CTRL_C to break
Reply from 13.1.1.2: bytes=100 Sequence=1 time=2 ms
Reply from 13.1.1.2: bytes=100 Sequence=2 time=2 ms
Reply from 13.1.1.2: bytes=100 Sequence=3 time=2 ms
Reply from 13.1.1.2: bytes=100 Sequence=4 time=2 ms
Reply from 13.1.1.2: bytes=100 Sequence=5 time=2 ms
--- FEC: IPV4 PREFIX 3.3.3.3/32 ping statistics ---
0.00% packet loss
round-trip min/avg/max = 2/2/2 ms
LDP VPLS interoperation guide
Interoperability analysis
Table 26 LDP VPLS interoperability analysis
H3C |
Huawei |
Interoperability |
Configure OSPF and LDP Virtual Private LAN Service (VPLS) |
Configure OSPF and LDP VPLS in bridge domain (BD) mode |
Supported |
As shown in Figure 41, three H3C devices and one Huawei device form a VPLS network. Configure OSPF and LDP VPLS on PE1 and PE2 separately to enable connectivity between CE1 and CE2.
NOTE: The Huawei device supports LDP VPLS only in BD mode. |
1. Configure CE1 (H3C device):
# Configure VLAN-interface 10.
<CE1> system-view
[CE1] vlan 10
[CE1-vlan10] quit
[CE1] interface Vlan-interface 10
[CE1-Vlan-interface10] ip address 11.1.1.1 255.255.255.0
[CE1-Vlan-interface10] quit
# Configure interface HundredGigE 2/0/8 .
[CE1]interface HundredGigE 2/0/8
[CE1-HundredGigE2/0/8] port link-mode bridge
[CE1-HundredGigE2/0/8] port link-type trunk
[CE1-HundredGigE2/0/8] port trunk permit vlan 10
[CE1-HundredGigE2/0/8] quit
2. Configure PE1 (H3C device):
# Create a loopback interface.
<PE1> system-view
[PE1] interface loopback 0
[PE1-LoopBack0] quit
[PE1] interface HundredGigE 2/0/8
[PE1-HundredGigE2/0/8] port link-mode bridge
[PE1-HundredGigE2/0/8] port link-type trunk
[PE1-HundredGigE2/0/8] port trunk permit vlan 10
[PE1-HundredGigE2/0/8] quit
# Configure interface HundredGigE 2/0/4 .
[PE1] interface HundredGigE 2/0/4
[PE1-HundredGigE2/0/8] port link-mode route
[PE1-HundredGigE2/0/8] ip address 12.1.1.1 24
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[PE1-ospf-1] quit
# Configure MPLS.
[PE1] mpls lsr-id 1.1.1.1
[PE1] mpls ldp
[PE1-ldp] quit
# Enable Layer 2 VPN (L2VPN).
[PE1] l2vpn enable
# Create a pseudowire (PW) class and configure a PW data encapsulation type for the PW class.
[PE1] pw-class h3c
[PE1-pw-h3c] pw-type ethernet
[PE1-pw-h3c] quit
# Configure virtual switching instance (VSI) aaa to use LDP to establish LDP PWs.
[PE1] vsi aaa
[PE1-vsi-aaa] pwsignaling ldp
# Configure the peer PE address as 2.2.2.2, PW ID as 500, and PW data encapsulation type as Ethernet. If the PW data encapsulation type is not specified, the default encapsulation type is VLAN. Make sure the PW data encapsulation type is the same as that on the peer Huawei switch.
[PE1-vsi-aaa-ldp] peer 2.2.2.2 pw-id 500 pw-class h3c
[PE1-vsi-aaa-ldp-2.2.2.2-500] quit
# Create a service instance on interface GigabitEthernet 2/0/8 and bind it to VSI instance aaa.
[PE1] interface gigabitethernet 2/0/8
[PE1-GigabitEthernet2/0/8] port link-mode bridge
[PE1-GigabitEthernet2/0/8] service-instance 10
[PE1-GigabitEthernet2/0/8-srv10] encapsulation s-vid 10
[PE1-GigabitEthernet2/0/8-srv10] xconnect vsi aaa access-mode ethernet
[PE1-GigabitEthernet2/0/8-srv10] quit
[PE1-GigabitEthernet2/0/8] quit
3. Configure CE2 (H3C device):
# Configure the subinterface to terminate the outermost two layers of VLAN tags for VLAN-tagged packets. (When CE1 is connected to PE1 in VLAN mode, the packets sent out of the Huawei switch carry two layers of VLAN tags. Therefore, you must configure CE2 to remove the two layers of VLAN tags to ensure connectivity between CE1 and CE2.)
<CE2> system-view
[CE2]interface HundredGigE 2/0/4.1
[CE2-HundredGigE2/0/4.1]ip address 11.1.1.2 255.255.255.0
[CE2-HundredGigE2/0/4.1] vlan-type dot1q vid 10 second-dot1q 10
[CE2-HundredGigE2/0/4.1] quit
4. Configure PE2 (Huawei device):
<PE2> display version
2. MAB Version : 2
# Configure interface Loopback 1.
<PE2> system-view immediately
[PE2] interface loopback1
[PE2-Loopback1] ip address 2.2.2.2 32
[PE2-Loopback1] quit
# Configure interface 100GE 1/0/1.
[PE2] interface 100GE 1/0/1
[PE2-100GE1/0/1] undo portswitch
[PE2-100GE1/0/1] ip address 12.1.1.2 24
[PE2-100GE1/0/1] quit
[PE2] interface 100GE 1/0/2.1 mode l2
[PE2-100GE1/0/2.1] quit
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2.0.0.0.0
[PE2-ospf-1-area-0.0.0.0] network 12.1.1.0 0.0.0.255
[PE2-ospf-1] quit
# Configure MPLS.
[PE2] mpls lsr-id 2.2.2.2
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2] interface 100ge 1/0/1
[PE2-10GE1/0/1] mpls
[PE2-10GE1/0/1] mpls ldp
[PE2-10GE1/0/1] quit
# Configure MPLS L2VPN.
[PE2] mpls l2vpn
[PE2-l2vpn] quit
# Configure a VSI. (The CE6860EI V200R005C10SPC800 version supports creating VSIs only in BD mode).
[PE2] vsi aaa bd-mode
[PE2-vsi-aaa] encapsulation ethernet
[PE2-vsi-aaa] pwsignal ldp
[PE2-vsi-aaa-ldp] vsi-id 500
[PE2-vsi-aaa-ldp] peer 1.1.1.1
[PE2-vsi-aaa-ldp] quit
[PE2-vsi-aaa] quit
# Configure a VSI.
[PE2] bridge-domain 500
[PE2-bd10] l2 binding vsi aaa
[PE2-bd10] quit
# Bind the VSI to interface 100GE 1/0/2.1.
[PE2-100GE1/0/2.1] encapsulation dot1q vid 10
[PE2-100GE1/0/2.1] bridge-domain 500
# On PE1, execute the display l2vpn pw verbose command to verify that the established PW is in up state.
[PE1] display l2vpn pw verbose
VSI Name: aaa
Peer: 2.2.2.2 PW ID: 500
Signaling Protocol : LDP
Link ID : 1024 PW State : Up
In Label : 24253 Out Label: 54
MTU : 1500
PW Attributes : Main
VCCV CC : -
VCCV BFD : -
Tunnel Group ID : 0x800000330000000
Tunnel NHLFE IDs : 6
# Execute the display vpls vsi name aaa command on PE 2 to verify that a VSI named aaa has established a PW to PE2 and the VSI is up.
[PE2] display vpls vsi name aaa verbose
***VSI Name : aaa
Administrator VSI : no
Isolate Spoken : disable
VSI Index : 3
PW Signaling : ldp
Member Discovery Style : --
Bridge-domain Mode : enable
Service Type : e-lan
PW MAC Learn Style : qualify
Encapsulation Type : ethernet
MTU : 1500
Ignore AcState : disable
P2P VSI : disable
Create Time : 2 days, 17 hours, 40 minutes, 37 seconds
VSI State : up
Resource Status : --
VSI ID : 500
*Peer Router ID : 1.1.1.1
Negotiation-vc-id : 500
primary or secondary : primary
ignore-standby-state : no
VC Label : 54
Peer Type : dynamic
Session : up
Tunnel ID : 0x0000000001004c4b81
Broadcast Tunnel ID : --
Broad BackupTunnel ID : --
CKey : 129
NKey : 16777583
Stp Enable : 0
PwIndex : 129
Control Word : disable
BFD for PW : unavailable
Access Bridge-domain : Bridge-domain 500
Vac State : up
Last Up Time : 2023/02/15 11:33:44
Total Up Time : 1 days, 20 hours, 35 minutes, 47 seconds
**PW Information:
*Peer Ip Address : 1.1.1.1
PW State : up
Local VC Label : 54
Remote VC Label : 24253
Remote Control Word : disable
PW Type : label
Local VCCV : alert lsp-ping bfd
Remote VCCV : lsp-ping
Ckey : 129
Nkey : 16777583
Main PW Token : 0x0
Slave PW Token : 0x0
Tnl Type : ldp
OutInterface : --
Backup OutInterface : --
Stp Enable : 0
Mac Flapping : 0
Monitor Group Name : --
PW Last Up Time : 2023/02/15 19:33:36
PW Total Up Time : 2 days, 11 hours, 14 minutes, 45 seconds
# Display the MAC address entries of the VSI on PE1.
[PE1] display l2vpn mac-address vsi aaa
MAC Address State VSI Name Link ID/Name Aging
7485-c41b-4201 Dynamic aaa HGE2/0/8 Aging
74d6-cb83-2081 Dynamic aaa 1024 Aging
--- 2 mac address(es) found ---
# Display the MAC address entries on PE2.
[PE2] display mac-address
Flags: * - Backup
# - forwarding logical interface, operations cannot be performed based
on the interface.
BD : bridge-domain Age : dynamic MAC learned time in seconds
MAC Address VLAN/VSI/BD Learned-From Type Age
7485-c41b-4201 -/aaa/500 1.1.1.1 dynamic 18077
74d6-cb83-2081 -/aaa/500 100GE1/0/2.1 dynamic 12868
Total items: 2
# Verify that you can successfully ping CE2 (11.1.1.2) from CE1 (11.1.1.1).
[CE1] ping 11.1.1.2
Ping 11.1.1.2 (11.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 11.1.1.2: icmp_seq=0 ttl=255 time=1.495 ms
56 bytes from 11.1.1.2: icmp_seq=1 ttl=255 time=1.149 ms
56 bytes from 11.1.1.2: icmp_seq=2 ttl=255 time=2.108 ms
56 bytes from 11.1.1.2: icmp_seq=3 ttl=255 time=1.277 ms
56 bytes from 11.1.1.2: icmp_seq=4 ttl=255 time=1.157 ms
--- Ping statistics for 11.1.1.2 ---
round-trip min/avg/max/std-dev = 1.149/1.437/2.108/0.358 ms
[CE1]%Feb 16 05:51:35:465 2023 Switch B PING/6/PING_STATISTICS: -MDC=1; Ping statistics for 11.1.1.2: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.149/1.437/2.108/0.358 ms.
# Verify that you can successfully ping CE1 (11.1.1.1) from CE2 (11.1.1.2).
[CE2] ping 11.1.1.1
Ping 11.1.1.1 (11.1.1.1): 56 data bytes, press CTRL+C to break
56 bytes from 11.1.1.1: icmp_seq=0 ttl=255 time=1.768 ms
56 bytes from 11.1.1.1: icmp_seq=1 ttl=255 time=1.823 ms
56 bytes from 11.1.1.1: icmp_seq=2 ttl=255 time=1.392 ms
56 bytes from 11.1.1.1: icmp_seq=3 ttl=255 time=1.343 ms
56 bytes from 11.1.1.1: icmp_seq=4 ttl=255 time=1.222 ms
--- Ping statistics for 11.1.1.1 ---
round-trip min/avg/max/std-dev = 1.222/1.510/1.823/0.241 ms
[CE2]%Feb 16 13:45:49:212 2023 H3C PING/6/PING_STATISTICS: Ping statistics for 11.1.1.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.222/1.510/1.823/0.241 ms.
MPLS L3VPN interoperation guide
Table 27 MPLS L3VPN interoperability analysis
H3C |
Huawei |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 42, three H3C devices and one Huawei device form an MPLS Layer 3 VPN (L3VPN) network. Configure External Border Gateway Protocol (EBGP)between CEs and PEs to exchange VPN routing information. Configure OSPF between PE1 and PE2 for internal connectivity between PEs. Configure Multi-Protocol Internal Border Gateway Protocol (MP-IBGP) between PEs to exchange VPN routing information to. At last, connectivity between CE1 and CE2 is achieved.
1. Configure PE1 (H3C device):
<PE1> system-view
[PE1] interface loopback 1
[PE1-LoopBack1] ip address 1.1.1.1 32
[PE1-LoopBack1] quit
# Configure interface HundredGigE 2/0/4.
[PE1-HundredGigE2/0/4] ip address 12.1.1.1 24
[PE1-HundredGigE2/0/4] quit
# Configure OSPF.
[PE1] ospf 1
[PE1-ospf-1] area 0
[PE1-ospf-1] quit
[PE1] mpls ldp
[PE1-ldp] quit
[PE1-HundredGigE2/0/4] mpls enable
[PE1-HundredGigE2/0/4] mpls ldp enable
# Configure a VPN instance to connect CE1 to PE1.
[PE1] ip vpn-instance vpn1
[PE1-vpn-instance-vpn1] route-distinguisher 100:1
[PE1-vpn-instance-vpn1] vpn-target 111:1
[PE1-vpn-instance-vpn1] quit
[PE1-HundredGigE2/0/8] ip binding vpn-instance vpn1
[PE1-HundredGigE2/0/8] ip address 11.1.1.2 24
# Establish EBGP peer relationships between PEs and CEs, and redistribute VPN routes.
[PE1] bgp 200
[PE1-bgp-default-vpn1] peer 11.1.1.1 as-number 100
[PE1-bgp-default-ipv4-vpn1] peer 11.1.1.1 enable
[PE1-bgp-default-vpn1] quit
[PE1-bgp-default] quit
# Establish an MP-IBGP peer relationship between PEs.
[PE1] bgp 200
[PE1-bgp-default] peer 2.2.2.2 as-number 200
[PE1-bgp-default] peer 2.2.2.2 connect-interface loopback 1
[PE1-bgp-default-vpnv4] peer 2.2.2.2 enable
[PE1-bgp-default-vpnv4] quit
2. Configure CE1 (H3C device):
# Configure interface HundredGigE 2/0/8.
<CE1> system-view
[CE1] interface HundredGigE 2/0/8
[CE1-HundredGigE2/0/8] ip address 11.1.1.1 24
[CE1] bgp 100
[CE1-bgp-default] peer 11.1.1.2 as-number 200
[CE1-bgp-default-ipv4] peer 10.1.1.2 enable
[CE1-bgp-default-ipv4] quit
[CE1-bgp-default] quit
<CE2> system-view
[CE2] interface HundredGigE 2/0/4
[CE2-HundredGigE2/0/8] ip address 13.1.1.2 24
[CE2-HundredGigE2/0/8] quit
[CE2] bgp 300
[CE2-bgp-default] peer 13.1.1.1 as-number 200
[CE2-bgp-default-ipv4] peer 13.1.1.1 enable
[CE2-bgp-default-ipv4] import-route direct
[CE2-bgp-default-ipv4] quit
[CE2-bgp-default] quit
2. MAB Version : 2
# Configure OSPF.
[PE2] ospf 1
[PE2-ospf-1] area 0
[PE2-ospf-1-area-0.0.0.0] network 2.2.2.2 0.0.0.0
[PE2-ospf-1] quit
[PE2] mpls
[PE2-mpls] quit
[PE2] mpls ldp
[PE2-mpls-ldp] quit
[PE2-100GE1/0/1] mpls
[PE2-100GE1/0/1] mpls ldp
# Configure a VPN instance to connect CE2 to PE2.
[PE2] ip vpn-instance vpn1
[PE2-vpn-instance-vpn1] ipv4-family
[PE2-vpn-instance-vpn1-af-ipv4] route-distinguisher 100:1
[PE2-vpn-instance-vpn1-af-ipv4] vpn-target 111:1 both
[PE2-vpn-instance-vpn1-af-ipv4] quit
[PE2-vpn-instance-vpn1] quit
[PE2-100GE1/0/1] ip binding vpn-instance vpn1
[PE2-100GE1/0/1] ip address 13.1.1.1 24
# Establish an EBGP peer relationship between PE2 and CE2, and redistribute VPN routes.
[PE2] bgp 200
[PE2-bgp] ipv4-family vpn-instance vpn1
[PE2-bgp-vpn1] peer 13.1.1.2 as-number 300
[PE2-bgp-vpn1] quit
[PE2-bgp] quit
# Execute the display bgp peer vpnv4 command to verify that IBGP peer relationships in Established state have been established between PEs.
[PE1] display bgp peer vpnv4
Local AS number: 200
2.2.2.2 200 1720 1912 0 3 24:51:49 Established
# Execute the display bgp peer vpnv4 command to verify that EBGP peer relationships in Established state have been established between PE1 and CE1.
[PE1] display bgp peer ipv4 vpn-instance vpn1
11.1.1.1 100 328 307 0 2 04:51:03 Established
# Verify that you can successfully ping CE1 from PE1.
<PE1> ping -vpn-instance vpn1 11.1.1.1
56 bytes from 11.1.1.1: icmp_seq=0 ttl=255 time=2.323 ms
56 bytes from 11.1.1.1: icmp_seq=1 ttl=255 time=1.274 ms
56 bytes from 11.1.1.1: icmp_seq=2 ttl=255 time=1.405 ms
56 bytes from 11.1.1.1: icmp_seq=3 ttl=255 time=1.230 ms
56 bytes from 11.1.1.1: icmp_seq=4 ttl=255 time=1.497 ms
--- Ping statistics for 11.1.1.1 in VPN instance vpn1 ---
round-trip min/avg/max/std-dev = 1.230/1.546/2.323/0.400 ms
<PE1>%Feb 22 16:32:25:730 2023 H3C PING/6/PING_VPN_STATISTICS: -MDC=1; Ping statistics for 11.1.1.1 in VPN instance vpn1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.230/1.546/2.323/0.400 ms.
# Execute the display bgp vpnv4 all the peer command to verify that BGP peer relationships in Established state have been established from PE2 to PE1 and CE 2.
[PE2] display bgp vpnv4 all peer
BGP local router ID : 2.2.2.2
Local AS number : 200
Total number of peers : 2
Peers in established state : 2
Peer V AS MsgRcvd MsgSent OutQ Up/Down State PrefRcv
1.1.1.1 4 200 1925 1734 0 0025h03m Established 2
Peer of IPv4-family for vpn instance :
VPN-Instance vpn1, Router ID 2.2.2.2:
13.1.1.2 4 300 1305 1666 0 21:26:10 Established 3
# Verify that you can successfully ping CE2 from PE2.
<PE2> ping -vpn-instance vpn1 13.1.1.2
PING 13.1.1.2: 56 data bytes, press CTRL_C to break
Reply from 13.1.1.2: bytes=56 Sequence=1 ttl=255 time=4 ms
Reply from 13.1.1.2: bytes=56 Sequence=2 ttl=255 time=2 ms
Reply from 13.1.1.2: bytes=56 Sequence=3 ttl=255 time=1 ms
Reply from 13.1.1.2: bytes=56 Sequence=4 ttl=255 time=1 ms
Reply from 13.1.1.2: bytes=56 Sequence=5 ttl=255 time=2 ms
--- 13.1.1.2 ping statistics ---
0.00% packet loss
round-trip min/avg/max = 1/2/4 ms
# Verify that you can successfully ping CE2 from CE1.
<CE1> ping 13.1.1.2
Ping 13.1.1.2 (13.1.1.2): 56 data bytes, press CTRL+C to break
56 bytes from 13.1.1.2: icmp_seq=0 ttl=253 time=1.953 ms
56 bytes from 13.1.1.2: icmp_seq=1 ttl=253 time=1.355 ms
56 bytes from 13.1.1.2: icmp_seq=2 ttl=253 time=1.166 ms
56 bytes from 13.1.1.2: icmp_seq=3 ttl=253 time=1.063 ms
56 bytes from 13.1.1.2: icmp_seq=4 ttl=253 time=1.177 ms
--- Ping statistics for 13.1.1.2 ---
round-trip min/avg/max/std-dev = 1.063/1.343/1.953/0.319 ms
<CE1>%Feb 22 08:40:23:685 2023 Switch B PING/6/PING_STATISTICS: -MDC=1; Ping statistics for 13.1.1.2: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.063/1.343/1.953/0.319 ms.
# Verify that you can successfully ping CE1 from CE 2.
<CE2> ping 11.1.1.1
56 bytes from 11.1.1.1: icmp_seq=0 ttl=253 time=1.732 ms
56 bytes from 11.1.1.1: icmp_seq=1 ttl=253 time=1.256 ms
56 bytes from 11.1.1.1: icmp_seq=2 ttl=253 time=1.279 ms
56 bytes from 11.1.1.1: icmp_seq=3 ttl=253 time=2.485 ms
56 bytes from 11.1.1.1: icmp_seq=4 ttl=253 time=2.700 ms
round-trip min/avg/max/std-dev = 1.256/1.890/2.700/0.602 ms
<CE2>%Feb 22 16:34:49:957 2023 H3C PING/6/PING_STATISTICS: Ping statistics for 11.1.1.1: 5 packet(s) transmitted, 5 packet(s) received, 0.0% packet loss, round-trip min/avg/max/std-dev = 1.256/1.890/2.700/0.602 ms.
M-LAG interoperation guide
Table 28 Interoperability analysis
H3C |
Huawei |
Interoperability |
Supported |
Supported |
Supported |
Scenario |
Model |
Recommended versions |
Data center |
S12500X-AF/S12500G-AF/S12500F-AF |
· Type H cards of S12500X-AF/S12500F-AF: R2825 · All cards of S12500G-AF: R7625 and later |
S9820/S9850 |
S9820/S9850: R6710 |
S6800/S6860/S6812[S6813]/S6805/S6825/S6850/S6890/S6900 |
· S6800/S6860/S6900/S6805/S6850/S6825: R6710 · S6890: R2825 · S6812/S6813: F6628P22 |
Campus |
S12500G-AF/S12500-XS |
R7625 and later |
S10500X |
R7625 and later |
S7600/S7600E-X/S7500X |
R7625 and later |
S6550XE-HI/S6525XE-HI/S6520X-EI/S6520X-HI/S5560X-EI/S5560X-HI |
· S6550XE-HI/S6525XE-HI: E8106 and later · S6520X-EI/S6520X-HI: F6628P11 and later · S5560X-EI/S5560X-HI: F6628P11 and later |
As shown in Figure 43, H3C devices and Huawei devices are interconnected through their respective Layer 2 Ethernet aggregate interfaces. Configure Multi-Chassis Link Aggregation Group (MLAG) on H3C and Huawei devices separately to virtualize two physical devices into one device, achieving device-level redundancy protection and traffic load balancing.
1. Configure SwitchA (H3C device):
# Set the M-LAG system MAC address.
[SwitchA] m-lag system-mac 0000-0000-1111
# Set the M-LAG system number.
[SwitchA] m-lag system-number 1
# Set the M-LAG system priority.
[SwitchA] m-lag system-priority 100
# Create VLAN 1000.
[SwitchA] vlan 1000
[SwitchA-vlan1000] quit
# Set the link mode of Ten-HundredGigE 1/0/48 to route (Layer 3), and assign the interface an IP address. The IP address will be used as the source IP address of keepalive packets.
[SwitchA] interface Ten-GigabitEthernet1/0/48
[SwitchA-Ten-GigabitEthernet1/0/48] port link-mode route
[SwitchA-Ten-GigabitEthernet1/0/48] ip address 22.254.121.7 255.255.255.254
[SwitchA-Ten-GigabitEthernet1/0/48] quit
# Configure the destination and source IP addresses of keepalive packets.
[SwitchA] m-lag keepalive ip destination 22.254.121.6 source 22.254.121.7
# Exclude the interface used for M-LAG keepalive detection from the shutdown action by MAD.
[SwitchA] m-lag mad exclude interface Ten-GigabitEthernet 1/0/48
# Create Layer 2 aggregate interfaces 1, 256, and 1002 in dynamic aggregation mode.
[SwitchA] interface Bridge-Aggregation 1
[SwitchA-Bridge-Aggregation1] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation1] quit
[SwitchA] interface Bridge-Aggregation 256
[SwitchA-Bridge-Aggregation256] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation256] quit
[SwitchA] interface Bridge-Aggregation 1002
[SwitchA-Bridge-Aggregation1002] link-aggregation mode dynamic
[SwitchA-Bridge-Aggregation1002] quit
# Assign Ten-GigabitEthernet 1/0/7 and Ten-GigabitEthernet 1/0/8 to aggregation group 1. Assign Ten-GigabitEthernet 1/0/2 to aggregation group 1002. Assign FortyGigE 1/0/53 and FortyGigE 1/0/54 to aggregation group 256.
[SwitchA] interface Ten-GigabitEthernet1/0/7
[SwitchA-Ten-GigabitEthernet1/0/7] port link-aggregation group 1
[SwitchA-Ten-GigabitEthernet1/0/7] quit
[SwitchA] interface Ten-GigabitEthernet1/0/8
[SwitchA-Ten-GigabitEthernet1/0/8] port link-aggregation group 1
[SwitchA-Ten-GigabitEthernet1/0/8] quit
[SwitchA] interface Ten-GigabitEthernet1/0/2
[SwitchA-Ten-GigabitEthernet1/0/2] port link-aggregation group 1002
[SwitchA-Ten-GigabitEthernet1/0/2] quit
[SwitchA] interface FortyGigE 1/0/53
[SwitchA-FortyGigE1/0/53] port link-aggregation group 256
[SwitchA-FortyGigE1/0/53] quit
[SwitchA] interface FortyGigE 1/0/54
[SwitchA-FortyGigE1/0/54] port link-aggregation group 256
[SwitchA-FortyGigE1/0/54] quit
# Configure Layer 2 aggregate interface Bridge-Aggregation 256 as the peer-link interface.
[SwitchA-Bridge-Aggregation256] port m-lag peer-link 1
# Assign aggregate interfaces Bridge-Aggregation 1 and Bridge-Aggregation 1002 to VLAN 1000.
[SwitchA-Bridge-Aggregation1] port link-type trunk
[SwitchA-Bridge-Aggregation1] undo port trunk permit vlan 1
[SwitchA-Bridge-Aggregation1] port trunk permit vlan 1000
[SwitchA-Bridge-Aggregation1002] port link-type trunk
[SwitchA-Bridge-Aggregation1002] undo port trunk permit vlan 1
[SwitchA-Bridge-Aggregation1002] port trunk permit vlan 1000
# Assign Layer 2 aggregate interface Bridge-Aggregation 1 to M-LAG group 1000. Assign Layer 2 aggregate interface Bridge-Aggregation 1002 to M-LAG group 1002.
[SwitchA-Bridge-Aggregation1] port m-lag group 1000
[SwitchA-Bridge-Aggregation1002] port m-lag group 1002
2. Configure Switch B (H3C device):
[SwitchB] m-lag system-mac 0000-0000-1111
[SwitchB] m-lag system-number 2
[SwitchB] m-lag system-priority 100
# Create VLAN 1000.
[SwitchB] vlan 1000
[SwitchB-vlan1000] quit
# Set the link mode of Ten-GigabitEthernet 1/0/48 to route (Layer 3), and assign the interface an IP address. The IP address will be used as the source IP address of keepalive packets.
[SwitchB] interface Ten-GigabitEthernet1/0/48
[SwitchB-Ten-GigabitEthernet1/0/48] port link-mode route
[SwitchB-Ten-GigabitEthernet1/0/48] ip address 22.254.121.6 255.255.255.254
[SwitchB-Ten-GigabitEthernet1/0/48] quit
[SwitchB] m-lag keepalive ip destination 22.254.121.7 source 22.254.121.6
[SwitchB] m-lag mad exclude interface Ten-GigabitEthernet 1/0/48
[SwitchB] interface Bridge-Aggregation 1
[SwitchB-Bridge-Aggregation1] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation1] quit
[SwitchB] interface Bridge-Aggregation 256
[SwitchB-Bridge-Aggregation256] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation256] quit
[SwitchB] interface Bridge-Aggregation 1002
[SwitchB-Bridge-Aggregation1002] link-aggregation mode dynamic
[SwitchB-Bridge-Aggregation1002] quit
[SwitchB] interface Ten-GigabitEthernet1/0/7
[SwitchB-Ten-GigabitEthernet1/0/7] port link-aggregation group 1
[SwitchB-Ten-GigabitEthernet1/0/7] quit
[SwitchB] interface Ten-GigabitEthernet1/0/8
[SwitchB-Ten-GigabitEthernet1/0/8] port link-aggregation group 1
[SwitchB-Ten-GigabitEthernet1/0/8] quit
[SwitchB] interface Ten-GigabitEthernet1/0/2
[SwitchB-Ten-GigabitEthernet1/0/2] port link-aggregation group 1002
[SwitchB-Ten-GigabitEthernet1/0/2] quit
[SwitchB] interface FortyGigE 1/0/53
[SwitchB-FortyGigE 1/0/53] port link-aggregation group 256
[SwitchB-FortyGigE 1/0/53] quit
[SwitchB] interface FortyGigE 1/0/54
[SwitchB-FortyGigE 1/0/54] port link-aggregation group 256
[SwitchB-FortyGigE 1/0/54] quit
# Configure Layer 2 aggregated interface 256 as the peer-link interface.
[SwitchB-Bridge-Aggregation256] port m-lag peer-link 1
[SwitchB-Bridge-Aggregation1] port link-type trunk
[SwitchB-Bridge-Aggregation1] undo port trunk permit vlan 1
[SwitchB-Bridge-Aggregation1] port trunk permit vlan 1000
[SwitchB-Bridge-Aggregation1002] port link-type trunk
[SwitchB-Bridge-Aggregation1002] undo port trunk permit vlan 1
[SwitchB-Bridge-Aggregation1002] port trunk permit vlan 1000
[SwitchB-Bridge-Aggregation1] port m-lag group 1000
[SwitchB-Bridge-Aggregation1002] port m-lag group 1002
3. Configure HUAWEIA (Huawei device):
# This section takes a Huawei CE6865-48S8CQ-EI device as an example. Display the device information as follows:
<HUAWEIA> display version
2. MAB Version : 1
# Create VLAN 1000.
<HUAWEIA> system-view
[~HUAWEIA] vlan 1000
[~HUAWEIA-vlan1000] quit
[~HUAWEIA] commit
# Set the link mode of 25GE 1/0/15 to Layer 3, and assign the interface an IP address. The IP address will be used as the source IP address of keepalive packets.
[~HUAWEIA] interface 25GE 1/0/15
[~HUAWEIA-25GE1/0/15] undo portswitch
[~HUAWEIA-25GE1/0/15] ip address 10.254.120.2 255.255.255.0
[~HUAWEIA-25GE1/0/15] quit
[~HUAWEIA] commit
# Create a Dynamic Fabric Service (DFS) group and configure the DFS group priority. Bind the DFS group to an IP address.
[~HUAWEIA] dfs-group 1
[~HUAWEIA-dfs-group-1] priority 150
[~HUAWEIA-dfs-group-1] source ip 10.254.120.2
[~HUAWEIA-dfs-group-1] quit
[~HUAWEIA] commit
# Create Layer 2 aggregate interfaces Eth-Trunk 1 and Eth-Trunk 10, and configure these interfaces to operate in dynamic LACP mode.
[~HUAWEIA] interface Eth-Trunk 1
[~HUAWEIA-Eth-Trunk1] mode lacp-dynamic
[~HUAWEIA-Eth-Trunk1] quit
[~HUAWEIA] interface Eth-Trunk 10
[~HUAWEIA-Eth-Trunk10] mode lacp-dynamic
[~HUAWEIA-Eth-Trunk10] quit
# Create Layer 2 aggregate interface Eth-Trunk 0 and configure the interface to operate in static LACP mode.
[~HUAWEIA] interface Eth-Trunk 0
[~HUAWEIA-Eth-Trunk0] mode lacp-static
[~HUAWEIA-Eth-Trunk0] quit
[~HUAWEIA] commit
# Assign 25G 1/0/7 and 25G 1/0/8 to aggregation group 1. Assign 100GE 1/0/1 and 100GE 1/0/2 to aggregation group 0. Assign 25G 1/0/3 to aggregation group 10.
[~HUAWEIA] interface 25GE 1/0/7
[~HUAWEIA-25GE1/0/7] eth-trunk 1
[~HUAWEIA-25GE1/0/7] quit
[~HUAWEIA] interface 25GE 1/0/8
[~HUAWEIA-25GE1/0/8] eth-trunk 1
[~HUAWEIA-25GE1/0/8] quit
[~HUAWEIA] interface 100GE 1/0/1
[~HUAWEIA-100GE1/0/1] eth-trunk 0
[~HUAWEIA-100GE1/0/1] quit
[~HUAWEIA] interface 100GE 1/0/2
[~HUAWEIA-100GE1/0/2] eth-trunk 0
[~HUAWEIA-100GE1/0/2] quit
[~HUAWEIA] interface 25GE 1/0/3
[~HUAWEIA-25GE1/0/3] eth-trunk 10
[~HUAWEIA-25GE1/0/3] quit
[~HUAWEIA] commit
# Specify interface Eth-Trunk 0 as the peer-link interface.
[~HUAWEIA-Eth-Trunk0] peer-link 1
[*HUAWEIA-Eth-Trunk0] qui
[*HUAWEIA] commit
Committing....done.
# Assign Eth-Trunk 1 and Eth-Trunk 10 to VLAN 1000.
[~HUAWEIA]interface Eth-Trunk 1
[~HUAWEIA-Eth-Trunk1] port link-type trunk
[~HUAWEIA-Eth-Trunk1] undo port trunk allow-pass vlan 1
[~HUAWEIA-Eth-Trunk1] port trunk allow-pass vlan 1000
[~HUAWEIA]interface Eth-Trunk 10
[~HUAWEIA-Eth-Trunk10] port link-type trunk
[~HUAWEIA-Eth-Trunk10] undo port trunk allow-pass vlan 1
[~HUAWEIA-Eth-Trunk10] port trunk allow-pass vlan 1000
[*HUAWEIA] commit
4. Configure HUAWEIB (Huawei device):
<HUAWEIB> display version
2. MAB Version : 1
# Create VLAN 1000.
<HUAWEIB> system-view
[~HUAWEIB] vlan 1000
[~HUAWEIB-vlan1000] quit
[~HUAWEIB] commit
[~HUAWEIB] interface 25GE 1/0/15
[~HUAWEIB-25GE1/0/15] undo portswitch
[~HUAWEIB-25GE1/0/15] ip address 10.254.120.2 255.255.255.0
[~HUAWEIB-25GE1/0/15] quit
[~HUAWEIB] commit
[~HUAWEIB] dfs-group 1
[~HUAWEIB-dfs-group-1] priority 150
[~HUAWEIB-dfs-group-1] source ip 10.254.120.2
[~HUAWEIB-dfs-group-1] quit
[~HUAWEIB] commit
[~HUAWEIB] interface Eth-Trunk 1
[~HUAWEIB-Eth-Trunk1] mode lacp-dynamic
[~HUAWEIB-Eth-Trunk1] quit
[~HUAWEIB] interface Eth-Trunk 10
[~HUAWEIB-Eth-Trunk10] mode lacp-dynamic
[~HUAWEIB-Eth-Trunk10] quit
[~HUAWEIB] interface Eth-Trunk 0
[~HUAWEIB-Eth-Trunk0] mode lacp-static
[~HUAWEIB-Eth-Trunk0] quit
[~HUAWEIB] commit
[~HUAWEIB] interface 25GE 1/0/7
[~HUAWEIB-25GE1/0/7] eth-trunk 1
[~HUAWEIB-25GE1/0/7] quit
[~HUAWEIB] interface 25GE 1/0/8
[~HUAWEIB-25GE1/0/8] eth-trunk 1
[~HUAWEIB-25GE1/0/8] quit
[~HUAWEIB] interface 100GE 1/0/1
[~HUAWEIB-100GE1/0/1] eth-trunk 0
[~HUAWEIB-100GE1/0/1] quit
[~HUAWEIB] interface 100GE 1/0/2
[~HUAWEIB-100GE1/0/2] eth-trunk 0
[~HUAWEIB-100GE1/0/2] quit
[~HUAWEIB] interface 25GE 1/0/3
[~HUAWEIB-25GE1/0/3] eth-trunk 10
[~HUAWEIB-25GE1/0/3] quit
[~HUAWEIB] commit
[~HUAWEIB-Eth-Trunk0] peer-link 1
Info: Prepare for configuring the peer-link. Please wait.....done.
[*HUAWEIB-Eth-Trunk0] qui
[*HUAWEIB] commit
[~HUAWEIB]interface Eth-Trunk 1
[~HUAWEIB-Eth-Trunk1] port link-type trunk
[~HUAWEIB-Eth-Trunk1] undo port trunk allow-pass vlan 1
[~HUAWEIB-Eth-Trunk1] port trunk allow-pass vlan 1000
[~HUAWEIB]interface Eth-Trunk 10
[~HUAWEIB-Eth-Trunk10] port link-type trunk
[~HUAWEIB-Eth-Trunk10] undo port trunk allow-pass vlan 1
[~HUAWEIB-Eth-Trunk10] port trunk allow-pass vlan 1000
[*HUAWEIB] commit
# On the H3C device, verify the M-LAG details.
[SwitchA] display m-lag summary
Flags: A -- Aggregate interface down, B -- No peer M-LAG interface configured
C -- Configuration consistency check failed
Peer-link interface: BAGG256
Peer-link interface state (cause): UP
Keepalive link state (cause): UP
M-LAG interface information
M-LAG IF M-LAG group Local state (cause) Peer state Remaining down time(s)
BAGG1 1000 UP UP -
BAGG1002 1002 UP UP -
[SwitchB] display m-lag summary
BAGG1 1000 UP UP -
# On the Huawei device, verify the M-LAG details.
[~HUAWEIA] display dfs-group 1 m-lag
* : Local node
Heart beat state : OK
Node 1 *
Dfs-Group ID : 1
Priority : 150
Address : ip address 10.254.120.2
State : Master
Causation : -
System ID : ccbb-fe01-abf1
SysName : HUAWEIA
Version : V200R019C10SPC800
Device Type : CE6865EI
Node 2
Dfs-Group ID : 1
Priority : 100
Address : ip address 10.254.120.3
State : Backup
Causation : -
System ID : ccbb-fe01-abe1
SysName : HUAWEIB
[~HUAWEIA]disp dfs-group 1 m-lag
* : Local node
Node 2 *
Dfs-Group ID : 1
Priority : 100
State : Backup
Causation : -
SysName : HUAWEIB
Node 1
Dfs-Group ID : 1
Priority : 150
State : Master
Causation : -
SysName : HUAWEIA
[~HUAWEI-2]
# Verify that you can successfully ping Device B from Device A.
<DeviceA> ping 10.0.0.1
Ping 10.0.0.1 (10.0.0.1): 56 data bytes, press CTRL+C to break
56 bytes from 10.0.0.1: icmp_seq=0 ttl=255 time=1.519 ms
56 bytes from 10.0.0.1: icmp_seq=1 ttl=255 time=1.262 ms
56 bytes from 10.0.0.1: icmp_seq=2 ttl=255 time=1.256 ms
56 bytes from 10.0.0.1: icmp_seq=3 ttl=255 time=1.184 ms
56 bytes from 10.0.0.1: icmp_seq=4 ttl=255 time=1.116 ms
--- Ping statistics for 10.0.0.1 ---
round-trip min/avg/max/std-dev = 1.116/1.267/1.519/0.137 ms
# Verify that you can successfully ping Device A from Device B.
<DeviceB> ping 10.0.0.2
Ping 10.0.0.2 (10.0.0.2): 56 data bytes, press CTRL+C to break
56 bytes from 10.0.0.2: icmp_seq=0 ttl=255 time=1.519 ms
56 bytes from 10.0.0.2: icmp_seq=1 ttl=255 time=1.262 ms
56 bytes from 10.0.0.2: icmp_seq=2 ttl=255 time=1.256 ms
56 bytes from 10.0.0.2: icmp_seq=3 ttl=255 time=1.184 ms
56 bytes from 10.0.0.2: icmp_seq=4 ttl=255 time=1.116 ms
--- Ping statistics for 10.0.0.2 ---
MRP interoperation guide
Interoperation with Hirschmann devices
Table 29 Interoperability analysis
H3C |
Hirschmann |
Interoperability |
Supported |
Supported |
Supported |
As shown in Figure 44, connect an H3C device to an MRP network formed with Hirschmann devices.
As shown in Figure 45, configure the H3C device as the MRM to detect loops and manage the ring network.
Figure 44 Connecting the H3C device to the Hirschmann MRP network
Figure 45 Configuring the H3C device as the MRM of the MRP network
· Configure the H3C device (Device D):
# Create VLAN 4000.
<H3C> system-view
[H3C] vlan 4000
# Create redundancy domain 1 and configure VLAN 4000 for MRP frame transmission in redundancy domain 1.
[H3C] iec-mrp redundancy-domain 1
[H3C-iec-mrp-redundancy-domain1] iec-mrp vlan 4000
# Configure the device as an MRC in the redundancy domain.
[H3C-iec-mrp-redundancy-domain1] iec-mrp role client
[H3C-iec-mrp-redundancy-domain1] quit
# Configure GigabitEthernet 1/0/1 as a ring port in redundancy domain 1.
[H3C] interface GigabitEthernet1/0/1
[H3C-GigabitEthernet1/0/1] port link-type trunk
[H3C-GigabitEthernet1/0/1] port trunk permit vlan all
[H3C-GigabitEthernet1/0/1] undo stp enable
[H3C-GigabitEthernet1/0/1] port iec-mrp redundancy-domain 1
[H3C-GigabitEthernet1/0/1] quit
# Configure GigabitEthernet 1/0/3 as a ring port in redundancy domain 1.
[H3C] interface GigabitEthernet1/0/3
[H3C-GigabitEthernet1/0/3] port link-type trunk
[H3C-GigabitEthernet1/0/3] port trunk permit vlan all
[H3C-GigabitEthernet1/0/3] undo stp enable
[H3C-GigabitEthernet1/0/3] port iec-mrp redundancy-domain 1
[H3C-GigabitEthernet1/0/3] quit
# Enable MRP for redundancy domain 1.
[H3C-iec-mrp-redundancy-domain1] iec-mrp enable
· Configure the Hirschmann device (Device A):
# Create VLAN 100 and VLAN 4000, and configure interface 1/3 to permit the VLANs.
(Hirschmann Railswitch) (Config)# vlan participation all include 100
(Hirschmann Railswitch) (Config)# vlan participation all include 4000
(Hirschmann Railswitch) (Config)# interface 1/3
(Hirschmann Railswitch) (Interface 1/3)# vlan acceptframe all
(Hirschmann Railswitch) (Interface 1/3)# vlan participation include 4000
(Hirschmann Railswitch) (Interface 1/3)# vlan tagging 4000
(Hirschmann Railswitch) (Interface 1/3)# vlan participation include 100
(Hirschmann Railswitch) (Interface 1/3)# vlan tagging 100
(Hirschmann Railswitch) (Interface 1/3)# no spanning-tree port mode
(Hirschmann Railswitch) (Interface 1/3)# exit
# Configure the device as the MRM in the redundancy domain.
(Hirschmann Railswitch) (Config)# mrp current-domain mode manager
# Configure VLAN 4000 for MRP frame transmission.
(Hirschmann Railswitch) (Config)# mrp current-domain vlan 4000
# Configure interface 1/3 as the primary ring port and interface 1/4 as the secondary ring port.
(Hirschmann Railswitch) (Config)# mrp current-domain port primary 1/3
(Hirschmann Railswitch) (Config)# mrp current-domain port secondary 1/4
# Enable MRP.
(Hirschmann Railswitch) (Config)# mrp current-domain operation enable
· Configure the Hirschmann device (Device B):
(Hirschmann Railswitch) (Config)# mrp current-domain mode client
# Enable MRP.
· Configure the Hirschmann device (Device C):
# Enable MRP.
<H3C> system-view
[H3C-iec-mrp-redundancy-domain1] iec-mrp role manager
# Display redundancy domain information on the H3C device.
[H3C] display iec-mrp redundancy-domain 1 ver
Redundancy domain ID : 1
Domain name : N/A
Domain UUID : FFFFFFFF-FFFF-FFFF-FFFF-FFFFFFFFFFFF
Device role : MRM
Device priority : 32768
VLAN ID : 4000
Enhanced mode : Disabled
Convergence profile : 500 ms
Block state : Supported
Ring ports : GigabitEthernet1/0/1 forwarding
: GigabitEthernet1/0/3 forwarding
Link down change interval : 20 ms
Link up change interval : 20 ms
Link change count : 4
# Display redundancy domain information on the Hirschmann device.
(Hirschmann Railswitch) #show mrp current-domain summary
Domain ID: 255.255.255.255.255.255.255.255.255.255.255.255.255.255.255.255
(Default MRP domain)
ConfigurationSettings:
Advanced Mode(react on link change)...........n/a(Switch is notManager)
ManagerPriority...............................n/a(Switch is notManager)
Mode of Switch(administrative setting)........Client
Mode of Switch(real operating state)..........Client
DomainName....................................<empty>
Recovery delay.................................500ms
Port Number,Primary...........................1/3,State:Forwarding
Port Number,Secondary.........................1/4,State:NotConnected
VLANID........................................4000
Operation......................................Enabled
GeneralOperatingStates:
MRP Setup Info(Config.Failure)...............Ring PortLinkError
Client-relatedOperatingStates:
Link DownInterval.............................20msec
Link UpInterval...............................20msec
Link ChangeCount..............................8
BlockedSupport................................Enabled
